path: root/net/ipv4/xfrm4_policy.c
2019-12-24net: add bool confirm_neigh parameter for dst_ops.update_pmtuHangbin Liu
The MTU update code is supposed to be invoked in response to real networking events that update the PMTU. In IPv6 PMTU update function __ip6_rt_update_pmtu() we called dst_confirm_neigh() to update neighbor confirmed time. But for tunnel code, it will call pmtu before xmit, like: - tnl_update_pmtu() - skb_dst_update_pmtu() - ip6_rt_update_pmtu() - __ip6_rt_update_pmtu() - dst_confirm_neigh() If the tunnel remote dst mac address changed and we still do the neigh confirm, we will not be able to update neigh cache and ping6 remote will failed. So for this ip_tunnel_xmit() case, _EVEN_ if the MTU is changed, we should not be invoking dst_confirm_neigh() as we have no evidence of successful two-way communication at this point. On the other hand it is also important to keep the neigh reachability fresh for TCP flows, so we cannot remove this dst_confirm_neigh() call. To fix the issue, we have to add a new bool parameter for dst_ops.update_pmtu to choose whether we should do neigh update or not. I will add the parameter in this patch and set all the callers to true to comply with the previous way, and fix the tunnel code one by one on later patches. v5: No change. v4: No change. v3: Do not remove dst_confirm_neigh, but add a new bool parameter in dst_ops.update_pmtu to control whether we should do neighbor confirm. Also split the big patch to small ones for each area. v2: Remove dst_confirm_neigh in __ip6_rt_update_pmtu. Suggested-by: David Miller <davem@davemloft.net> Reviewed-by: Guillaume Nault <gnault@redhat.com> Acked-by: David Ahern <dsahern@gmail.com> Signed-off-by: Hangbin Liu <liuhangbin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2019-09-20ipv4: Revert removal of rt_uses_gatewayDavid Ahern
Julian noted that rt_uses_gateway has a more subtle use than 'is gateway set': https://lore.kernel.org/netdev/alpine.LFD.2.21.1909151104060.2546@ja.home.ssi.bg/ Revert that part of the commit referenced in the Fixes tag. Currently, there are no u8 holes in 'struct rtable'. There is a 4-byte hole in the second cacheline which contains the gateway declaration. So move rt_gw_family down to the gateway declarations since they are always used together, and then re-use that u8 for rt_uses_gateway. End result is that rtable size is unchanged. Fixes: 1550c171935d ("ipv4: Prepare rtable for IPv6 gateway") Reported-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: David Ahern <dsahern@gmail.com> Reviewed-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com>
2019-04-30Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec-next Steffen Klassert says: ==================== pull request (net-next): ipsec-next 2019-04-30 1) A lot of work to remove indirections from the xfrm code. From Florian Westphal. 2) Support ESP offload in combination with gso partial. From Boris Pismenny. 3) Remove some duplicated code from vti4. From Jeremy Sowden. Please note that there is merge conflict between commit: 8742dc86d0c7 ("xfrm4: Fix uninitialized memory read in _decode_session4") from the ipsec tree and commit: c53ac41e3720 ("xfrm: remove decode_session indirection from afinfo_policy") from the ipsec-next tree. The merge conflict will appear when those trees get merged during the merge window. The conflict can be solved as it is done in linux-next: https://lkml.org/lkml/2019/4/25/1207 Please pull or let me know if there are problems. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2019-04-23xfrm: remove decode_session indirection from afinfo_policyFlorian Westphal
No external dependencies, might as well handle this directly. xfrm_afinfo_policy is now 40 bytes on x86_64. Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2019-04-23xfrm: remove init_path indirection from afinfo_policyFlorian Westphal
handle this directly, its only used by ipv6. Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2019-04-23xfrm: remove tos indirection from afinfo_policyFlorian Westphal
Only used by ipv4, we can read the fl4 tos value directly instead. Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2019-04-08ipv4: Add support to rtable for ipv6 gatewayDavid Ahern
Add support for an IPv6 gateway to rtable. Since a gateway is either IPv4 or IPv6, make it a union with rt_gw4 where rt_gw_family decides which address is in use. When dumping the route data, encode an ipv6 nexthop using RTA_VIA. Signed-off-by: David Ahern <dsahern@gmail.com> Reviewed-by: Ido Schimmel <idosch@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2019-04-08ipv4: Prepare rtable for IPv6 gatewayDavid Ahern
To allow the gateway to be either an IPv4 or IPv6 address, remove rt_uses_gateway from rtable and replace with rt_gw_family. If rt_gw_family is set it implies rt_uses_gateway. Rename rt_gateway to rt_gw4 to represent the IPv4 version. Signed-off-by: David Ahern <dsahern@gmail.com> Reviewed-by: Ido Schimmel <idosch@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2018-03-27net: Drop pernet_operations::asyncKirill Tkhai
Synchronous pernet_operations are not allowed anymore. All are asynchronous. So, drop the structure member. Signed-off-by: Kirill Tkhai <ktkhai@virtuozzo.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2018-03-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Fun set of conflict resolutions here... For the mac80211 stuff, these were fortunately just parallel adds. Trivially resolved. In drivers/net/phy/phy.c we had a bug fix in 'net' that moved the function phy_disable_interrupts() earlier in the file, whilst in 'net-next' the phy_error() call from this function was removed. In net/ipv4/xfrm4_policy.c, David Ahern's changes to remove the 'rt_table_id' member of rtable collided with a bug fix in 'net' that added a new struct member "rt_mtu_locked" which needs to be copied over here. The mlxsw driver conflict consisted of net-next separating the span code and definitions into separate files, whilst a 'net' bug fix made some changes to that moved code. The mlx5 infiniband conflict resolution was quite non-trivial, the RDMA tree's merge commit was used as a guide here, and here are their notes: ==================== Due to bug fixes found by the syzkaller bot and taken into the for-rc branch after development for the 4.17 merge window had already started being taken into the for-next branch, there were fairly non-trivial merge issues that would need to be resolved between the for-rc branch and the for-next branch. This merge resolves those conflicts and provides a unified base upon which ongoing development for 4.17 can be based. Conflicts: drivers/infiniband/hw/mlx5/main.c - Commit 42cea83f9524 (IB/mlx5: Fix cleanup order on unload) added to for-rc and commit b5ca15ad7e61 (IB/mlx5: Add proper representors support) add as part of the devel cycle both needed to modify the init/de-init functions used by mlx5. To support the new representors, the new functions added by the cleanup patch needed to be made non-static, and the init/de-init list added by the representors patch needed to be modified to match the init/de-init list changes made by the cleanup patch. Updates: drivers/infiniband/hw/mlx5/mlx5_ib.h - Update function prototypes added by representors patch to reflect new function names as changed by cleanup patch drivers/infiniband/hw/mlx5/ib_rep.c - Update init/de-init stage list to match new order from cleanup patch ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2018-03-14ipv4: lock mtu in fnhe when received PMTU < net.ipv4.route.min_pmtuSabrina Dubroca
Prior to the rework of PMTU information storage in commit 2c8cec5c10bc ("ipv4: Cache learned PMTU information in inetpeer."), when a PMTU event advertising a PMTU smaller than net.ipv4.route.min_pmtu was received, we would disable setting the DF flag on packets by locking the MTU metric, and set the PMTU to net.ipv4.route.min_pmtu. Since then, we don't disable DF, and set PMTU to net.ipv4.route.min_pmtu, so the intermediate router that has this link with a small MTU will have to drop the packets. This patch reestablishes pre-2.6.39 behavior by splitting rtable->rt_pmtu into a bitfield with rt_mtu_locked and rt_pmtu. rt_mtu_locked indicates that we shouldn't set the DF bit on that path, and is checked in ip_dont_fragment(). One possible workaround is to set net.ipv4.route.min_pmtu to a value low enough to accommodate the lowest MTU encountered. Fixes: 2c8cec5c10bc ("ipv4: Cache learned PMTU information in inetpeer.") Signed-off-by: Sabrina Dubroca <sd@queasysnail.net> Reviewed-by: Stefano Brivio <sbrivio@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2018-02-28inet: whitespace cleanupStephen Hemminger
Ran simple script to find/remove trailing whitespace and blank lines at EOF because that kind of stuff git whines about and editors leave behind. Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2018-02-16xfrm: reuse uncached_list to track xdstsXin Long
In early time, when freeing a xdst, it would be inserted into dst_garbage.list first. Then if it's refcnt was still held somewhere, later it would be put into dst_busy_list in dst_gc_task(). When one dev was being unregistered, the dev of these dsts in dst_busy_list would be set with loopback_dev and put this dev. So that this dev's removal wouldn't get blocked, and avoid the kmsg warning: kernel:unregister_netdevice: waiting for veth0 to become \ free. Usage count = 2 However after Commit 52df157f17e5 ("xfrm: take refcnt of dst when creating struct xfrm_dst bundle"), the xdst will not be freed with dst gc, and this warning happens. To fix it, we need to find these xdsts that are still held by others when removing the dev, and free xdst's dev and set it with loopback_dev. But unfortunately after flow_cache for xfrm was deleted, no list tracks them anymore. So we need to save these xdsts somewhere to release the xdst's dev later. To make this easier, this patch is to reuse uncached_list to track xdsts, so that the dev refcnt can be released in the event NETDEV_UNREGISTER process of fib_netdev_notifier. Thanks to Florian, we could move forward this fix quickly. Fixes: 52df157f17e5 ("xfrm: take refcnt of dst when creating struct xfrm_dst bundle") Reported-by: Jianlin Shi <jishi@redhat.com> Reported-by: Hangbin Liu <liuhangbin@gmail.com> Tested-by: Eyal Birger <eyal.birger@gmail.com> Signed-off-by: Xin Long <lucien.xin@gmail.com> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2018-02-15net/ipv4: Remove fib table id from rtableDavid Ahern
Remove rt_table_id from rtable. It was added for getroute to return the table id that was hit in the lookup. With the changes for fibmatch the table id can be extracted from the fib_info returned in the fib_result so it no longer needs to be in rtable directly. Signed-off-by: David Ahern <dsahern@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2018-02-13net: Convert pernet_subsys, registered from inet_init()Kirill Tkhai
arp_net_ops just addr/removes /proc entry. devinet_ops allocates and frees duplicate of init_net tables and (un)registers sysctl entries. fib_net_ops allocates and frees pernet tables, creates/destroys netlink socket and (un)initializes /proc entries. Foreign pernet_operations do not touch them. ip_rt_proc_ops only modifies pernet /proc entries. xfrm_net_ops creates/destroys /proc entries, allocates/frees pernet statistics, hashes and tables, and (un)initializes sysctl files. These are not touched by foreigh pernet_operations xfrm4_net_ops allocates/frees private pernet memory, and configures sysctls. sysctl_route_ops creates/destroys sysctls. rt_genid_ops only initializes fields of just allocated net. ipv4_inetpeer_ops allocated/frees net private memory. igmp_net_ops just creates/destroys /proc files and socket, noone else interested in. tcp_sk_ops seems to be safe, because tcp_sk_init() does not depend on any other pernet_operations modifications. Iteration over hash table in inet_twsk_purge() is made under RCU lock, and it's safe to iterate the table this way. Removing from the table happen from inet_twsk_deschedule_put(), but this function is safe without any extern locks, as it's synchronized inside itself. There are many examples, it's used in different context. So, it's safe to leave tcp_sk_exit_batch() unlocked. tcp_net_metrics_ops is synchronized on tcp_metrics_lock and safe. udplite4_net_ops only creates/destroys pernet /proc file. icmp_sk_ops creates percpu sockets, not touched by foreign pernet_operations. ipmr_net_ops creates/destroys pernet fib tables, (un)registers fib rules and /proc files. This seem to be safe to execute in parallel with foreign pernet_operations. af_inet_ops just sets up default parameters of newly created net. ipv4_mib_ops creates and destroys pernet percpu statistics. raw_net_ops, tcp4_net_ops, udp4_net_ops, ping_v4_net_ops and ip_proc_ops only create/destroy pernet /proc files. ip4_frags_ops creates and destroys sysctl file. So, it's safe to make the pernet_operations async. Signed-off-by: Kirill Tkhai <ktkhai@virtuozzo.com> Acked-by: Andrei Vagin <avagin@virtuozzo.com> Signed-off-by: David S. Miller <davem@davemloft.net>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-11net: xfrm: support setting an output mark.Lorenzo Colitti
On systems that use mark-based routing it may be necessary for routing lookups to use marks in order for packets to be routed correctly. An example of such a system is Android, which uses socket marks to route packets via different networks. Currently, routing lookups in tunnel mode always use a mark of zero, making routing incorrect on such systems. This patch adds a new output_mark element to the xfrm state and a corresponding XFRMA_OUTPUT_MARK netlink attribute. The output mark differs from the existing xfrm mark in two ways: 1. The xfrm mark is used to match xfrm policies and states, while the xfrm output mark is used to set the mark (and influence the routing) of the packets emitted by those states. 2. The existing mark is constrained to be a subset of the bits of the originating socket or transformed packet, but the output mark is arbitrary and depends only on the state. The use of a separate mark provides additional flexibility. For example: - A packet subject to two transforms (e.g., transport mode inside tunnel mode) can have two different output marks applied to it, one for the transport mode SA and one for the tunnel mode SA. - On a system where socket marks determine routing, the packets emitted by an IPsec tunnel can be routed based on a mark that is determined by the tunnel, not by the marks of the unencrypted packets. - Support for setting the output marks can be introduced without breaking any existing setups that employ both mark-based routing and xfrm tunnel mode. Simply changing the code to use the xfrm mark for routing output packets could xfrm mark could change behaviour in a way that breaks these setups. If the output mark is unspecified or set to zero, the mark is not set or changed. Tested: make allyesconfig; make -j64 Tested: https://android-review.googlesource.com/452776 Signed-off-by: Lorenzo Colitti <lorenzo@google.com> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2017-07-18xfrm: remove flow cacheFlorian Westphal
After rcu conversions performance degradation in forward tests isn't that noticeable anymore. See next patch for some numbers. A followup patcg could then also remove genid from the policies as we do not cache bundles anymore. Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-07-18net: xfrm: revert to lower xfrm dst gc limitFlorian Westphal
revert c386578f1cdb4dac230395 ("xfrm: Let the flowcache handle its size by default."). Once we remove flow cache, we don't have a flow cache limit anymore. We must not allow (virtually) unlimited allocations of xfrm dst entries. Revert back to the old xfrm dst gc limits. Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-02-09xfrm: policy: make policy backend constFlorian Westphal
2017-02-09xfrm: policy: remove family fieldFlorian Westphal
Only needed it to register the policy backend at init time. Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2017-02-09xfrm: policy: remove garbage_collect callbackFlorian Westphal
Just call xfrm_garbage_collect_deferred() directly. This gets rid of a write to afinfo in register/unregister and allows to constify afinfo later on. Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2016-09-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/mediatek/mtk_eth_soc.c drivers/net/ethernet/qlogic/qed/qed_dcbx.c drivers/net/phy/Kconfig All conflicts were cases of overlapping commits. Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-10net: l3mdev: remove redundant callsDavid Ahern
A previous patch added l3mdev flow update making these hooks redundant. Remove them. Signed-off-by: David Ahern <dsa@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-08Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec Steffen Klassert says: ==================== ipsec 2016-09-08 1) Fix a crash when xfrm_dump_sa returns an error. From Vegard Nossum. 2) Remove some incorrect WARN() on normal error handling. From Vegard Nossum. 3) Ignore socket policies when rebuilding hash tables, socket policies are not inserted into the hash tables. From Tobias Brunner. 4) Initialize and check tunnel pointers properly before we use it. From Alexey Kodanev. 5) Fix l3mdev oif setting on xfrm dst lookups. From David Ahern. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2016-08-22xfrm: Only add l3mdev oif to dst lookupsDavid Ahern
Subash reported that commit 42a7b32b73d6 ("xfrm: Add oif to dst lookups") broke a wifi use case that uses fib rules and xfrms. The intent of 42a7b32b73d6 was driven by VRFs with IPsec. As a compromise relax the use of oif in xfrm lookups to L3 master devices only (ie., oif is either an L3 master device or is enslaved to a master device). Fixes: 42a7b32b73d6 ("xfrm: Add oif to dst lookups") Reported-by: Subash Abhinov Kasiviswanathan <subashab@codeaurora.org> Signed-off-by: David Ahern <dsa@cumulusnetworks.com> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2016-06-16net: xfrm: fix old-style declarationArnd Bergmann
Modern C standards expect the '__inline__' keyword to come before the return type in a declaration, and we get a couple of warnings for this with "make W=1" in the xfrm{4,6}_policy.c files: net/ipv6/xfrm6_policy.c:369:1: error: 'inline' is not at beginning of declaration [-Werror=old-style-declaration] static int inline xfrm6_net_sysctl_init(struct net *net) net/ipv6/xfrm6_policy.c:374:1: error: 'inline' is not at beginning of declaration [-Werror=old-style-declaration] static void inline xfrm6_net_sysctl_exit(struct net *net) net/ipv4/xfrm4_policy.c:339:1: error: 'inline' is not at beginning of declaration [-Werror=old-style-declaration] static int inline xfrm4_net_sysctl_init(struct net *net) net/ipv4/xfrm4_policy.c:344:1: error: 'inline' is not at beginning of declaration [-Werror=old-style-declaration] static void inline xfrm4_net_sysctl_exit(struct net *net) Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-12-22Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec Steffen Klassert says: ==================== pull request (net): ipsec 2015-12-22 Just one patch to fix dst_entries_init with multiple namespaces. From Dan Streetman. Please pull or let me know if there are problems. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-03xfrm: dst_entries_init() per-net dst_opsDan Streetman
Remove the dst_entries_init/destroy calls for xfrm4 and xfrm6 dst_ops templates; their dst_entries counters will never be used. Move the xfrm dst_ops initialization from the common xfrm/xfrm_policy.c to xfrm4/xfrm4_policy.c and xfrm6/xfrm6_policy.c, and call dst_entries_init and dst_entries_destroy for each net namespace. The ipv4 and ipv6 xfrms each create dst_ops template, and perform dst_entries_init on the templates. The template values are copied to each net namespace's xfrm.xfrm*_dst_ops. The problem there is the dst_ops pcpuc_entries field is a percpu counter and cannot be used correctly by simply copying it to another object. The result of this is a very subtle bug; changes to the dst entries counter from one net namespace may sometimes get applied to a different net namespace dst entries counter. This is because of how the percpu counter works; it has a main count field as well as a pointer to the percpu variables. Each net namespace maintains its own main count variable, but all point to one set of percpu variables. When any net namespace happens to change one of the percpu variables to outside its small batch range, its count is moved to the net namespace's main count variable. So with multiple net namespaces operating concurrently, the dst_ops entries counter can stray from the actual value that it should be; if counts are consistently moved from one net namespace to another (which my testing showed is likely), then one net namespace winds up with a negative dst_ops count while another winds up with a continually increasing count, eventually reaching its gc_thresh limit, which causes all new traffic on the net namespace to fail with -ENOBUFS. Signed-off-by: Dan Streetman <dan.streetman@canonical.com> Signed-off-by: Dan Streetman <ddstreet@ieee.org> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2015-10-30Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec-next Steffen Klassert says: ==================== pull request (net-next): ipsec-next 2015-10-30 1) The flow cache is limited by the flow cache limit which depends on the number of cpus and the xfrm garbage collector threshold which is independent of the number of cpus. This leads to the fact that on systems with more than 16 cpus we hit the xfrm garbage collector limit and refuse new allocations, so new flows are dropped. On systems with 16 or less cpus, we hit the flowcache limit. In this case, we shrink the flow cache instead of refusing new flows. We increase the xfrm garbage collector threshold to INT_MAX to get the same behaviour, independent of the number of cpus. 2) Fix some unaligned accesses on sparc systems. From Sowmini Varadhan. 3) Fix some header checks in _decode_session4. We may call pskb_may_pull with a negative value converted to unsigened int from pskb_may_pull. This can lead to incorrect policy lookups. We fix this by a check of the data pointer position before we call pskb_may_pull. 4) Reload skb header pointers after calling pskb_may_pull in _decode_session4 as this may change the pointers into the packet. 5) Add a missing statistic counter on inner mode errors. Please pull or let me know if there are problems. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2015-10-23xfrm4: Reload skb header pointers after calling pskb_may_pull.Steffen Klassert
A call to pskb_may_pull may change the pointers into the packet, so reload the pointers after the call. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2015-10-23xfrm4: Fix header checks in _decode_session4.Steffen Klassert
We skip the header informations if the data pointer points already behind the header in question for some protocols. This is because we call pskb_may_pull with a negative value converted to unsigened int from pskb_may_pull in this case. Skipping the header informations can lead to incorrect policy lookups, so fix it by a check of the data pointer position before we call pskb_may_pull. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2015-09-29net: Replace vrf_master_ifindex{, _rcu} with l3mdev equivalentsDavid Ahern
Replace calls to vrf_master_ifindex_rcu and vrf_master_ifindex with either l3mdev_master_ifindex_rcu or l3mdev_master_ifindex. The pattern: oif = vrf_master_ifindex(dev) ? : dev->ifindex; is replaced with oif = l3mdev_fib_oif(dev); And remove the now unused vrf macros. Signed-off-by: David Ahern <dsa@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-29xfrm: Let the flowcache handle its size by default.Steffen Klassert
The xfrm flowcache size is limited by the flowcache limit (4096 * number of online cpus) and the xfrm garbage collector threshold (2 * 32768), whatever is reached first. This means that we can hit the garbage collector limit only on systems with more than 16 cpus. On such systems we simply refuse new allocations if we reach the limit, so new flows are dropped. On syslems with 16 or less cpus, we hit the flowcache limit. In this case, we shrink the flow cache instead of refusing new flows. We increase the xfrm garbage collector threshold to INT_MAX to get the same behaviour, independent of the number of cpus. The xfrm garbage collector threshold can still be set below the flowcache limit to reduce the memory usage of the flowcache. Tested-by: Dan Streetman <dan.streetman@canonical.com> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2015-09-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: net/ipv4/arp.c The net/ipv4/arp.c conflict was one commit adding a new local variable while another commit was deleting one. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-17net: Fix vti use case with oif in dst lookupsDavid Ahern
Steffen reported that the recent change to add oif to dst lookups breaks the VTI use case. The problem is that with the oif set in the flow struct the comparison to the nh_oif is triggered. Fix by splitting the FLOWI_FLAG_VRFSRC into 2 flags -- one that triggers the vrf device cache bypass (FLOWI_FLAG_VRFSRC) and another telling the lookup to not compare nh oif (FLOWI_FLAG_SKIP_NH_OIF). Fixes: 42a7b32b73d6 ("xfrm: Add oif to dst lookups") Signed-off-by: David Ahern <dsa@cumulusnetworks.com> Acked-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-15net: Add FIB table id to rtableDavid Ahern
Add the FIB table id to rtable to make the information available for IPv4 as it is for IPv6. Signed-off-by: David Ahern <dsa@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-08-25xfrm: Use VRF master index if output device is enslavedDavid Ahern
Directs route lookups to VRF table. Compiles out if NET_VRF is not enabled. With this patch able to successfully bring up ipsec tunnels in VRFs, even with duplicate network configuration. Signed-off-by: David Ahern <dsa@cumulusnetworks.com> Acked-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com> Acked-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-08-11xfrm: Add oif to dst lookupsDavid Ahern
Rules can be installed that direct route lookups to specific tables based on oif. Plumb the oif through the xfrm lookups so it gets set in the flow struct and passed to the resolver routines. Signed-off-by: David Ahern <dsa@cumulusnetworks.com> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2015-04-03ipv4: coding style: comparison for equality with NULLIan Morris
The ipv4 code uses a mixture of coding styles. In some instances check for NULL pointer is done as x == NULL and sometimes as !x. !x is preferred according to checkpatch and this patch makes the code consistent by adopting the latter form. No changes detected by objdiff. Signed-off-by: Ian Morris <ipm@chirality.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-09net: Remove protocol from struct dst_opsEric W. Biederman
After my change to neigh_hh_init to obtain the protocol from the neigh_table there are no more users of protocol in struct dst_ops. Remove the protocol field from dst_ops and all of it's initializers. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-14xfrm: Introduce xfrm_input_afinfo to access the the callbacks properlySteffen Klassert
IPv6 can be build as a module, so we need mechanism to access the address family dependent callback functions properly. Therefore we introduce xfrm_input_afinfo, similar to that what we have for the address family dependent part of policies and states. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2013-11-01xfrm: Fix null pointer dereference when decoding sessionsSteffen Klassert
On some codepaths the skb does not have a dst entry when xfrm_decode_session() is called. So check for a valid skb_dst() before dereferencing the device interface index. We use 0 as the device index if there is no valid skb_dst(), or at reverse decoding we use skb_iif as device interface index. Bug was introduced with git commit bafd4bd4dc ("xfrm: Decode sessions with output interface."). Reported-by: Meelis Roos <mroos@linux.ee> Tested-by: Meelis Roos <mroos@linux.ee> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2013-10-28xfrm: Increase the garbage collector thresholdSteffen Klassert
With the removal of the routing cache, we lost the option to tweak the garbage collector threshold along with the maximum routing cache size. So git commit 703fb94ec ("xfrm: Fix the gc threshold value for ipv4") moved back to a static threshold. It turned out that the current threshold before we start garbage collecting is much to small for some workloads, so increase it from 1024 to 32768. This means that we start the garbage collector if we have more than 32768 dst entries in the system and refuse new allocations if we are above 65536. Reported-by: Wolfgang Walter <linux@stwm.de> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2013-09-16xfrm: Decode sessions with output interface.Steffen Klassert
The output interface matching does not work on forward policy lookups, the output interface of the flowi is always 0. Fix this by setting the output interface when we decode the session. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2013-02-06xfrm: make gc_thresh configurable in all namespacesMichal Kubecek
The xfrm gc threshold can be configured via xfrm{4,6}_gc_thresh sysctl but currently only in init_net, other namespaces always use the default value. This can substantially limit the number of IPsec tunnels that can be effectively used. Signed-off-by: Michal Kubecek <mkubecek@suse.cz> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2013-02-06xfrm: remove unused xfrm4_policy_fini()Michal Kubecek
Function xfrm4_policy_fini() is unused since xfrm4_fini() was removed in 2.6.11. Signed-off-by: Michal Kubecek <mkubecek@suse.cz> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2012-11-13xfrm: Fix the gc threshold value for ipv4Steffen Klassert
The xfrm gc threshold value depends on ip_rt_max_size. This value was set to INT_MAX with the routing cache removal patch, so we start doing garbage collecting when we have INT_MAX/2 IPsec routes cached. Fix this by going back to the static threshold of 1024 routes. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2012-10-08ipv4: introduce rt_uses_gatewayJulian Anastasov
Add new flag to remember when route is via gateway. We will use it to allow rt_gateway to contain address of directly connected host for the cases when DST_NOCACHE is used or when the NH exception caches per-destination route without DST_NOCACHE flag, i.e. when routes are not used for other destinations. By this way we force the neighbour resolving to work with the routed destination but we can use different address in the packet, feature needed for IPVS-DR where original packet for virtual IP is routed via route to real IP. Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-31ipv4: Properly purge netdev references on uncached routes.David S. Miller
When a device is unregistered, we have to purge all of the references to it that may exist in the entire system. If a route is uncached, we currently have no way of accomplishing this. So create a global list that is scanned when a network device goes down. This mirrors the logic in net/core/dst.c's dst_ifdown(). Signed-off-by: David S. Miller <davem@davemloft.net>
