path: root/net/ipv4/proc.c
2007-04-25[IPV4] SNMP: Move some statistic bits to net/ipv4/proc.c.YOSHIFUJI Hideaki
This also fixes memory leak in error path. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-12[PATCH] mark struct file_operations const 7Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-10[NET] IPV4: Fix whitespace errors.YOSHIFUJI Hideaki
2006-12-02[NET]: Supporting UDP-Lite (RFC 3828) in LinuxGerrit Renker
This is a revision of the previously submitted patch, which alters the way files are organized and compiled in the following manner: * UDP and UDP-Lite now use separate object files * source file dependencies resolved via header files net/ipv{4,6}/udp_impl.h * order of inclusion files in udp.c/udplite.c adapted accordingly [NET/IPv4]: Support for the UDP-Lite protocol (RFC 3828) This patch adds support for UDP-Lite to the IPv4 stack, provided as an extension to the existing UDPv4 code: * generic routines are all located in net/ipv4/udp.c * UDP-Lite specific routines are in net/ipv4/udplite.c * MIB/statistics support in /proc/net/snmp and /proc/net/udplite * shared API with extensions for partial checksum coverage [NET/IPv6]: Extension for UDP-Lite over IPv6 It extends the existing UDPv6 code base with support for UDP-Lite in the same manner as per UDPv4. In particular, * UDPv6 generic and shared code is in net/ipv6/udp.c * UDP-Litev6 specific extensions are in net/ipv6/udplite.c * MIB/statistics support in /proc/net/snmp6 and /proc/net/udplite6 * support for IPV6_ADDRFORM * aligned the coding style of protocol initialisation with af_inet6.c * made the error handling in udpv6_queue_rcv_skb consistent; to return `-1' on error on all error cases * consolidation of shared code [NET]: UDP-Lite Documentation and basic XFRM/Netfilter support The UDP-Lite patch further provides * API documentation for UDP-Lite * basic xfrm support * basic netfilter support for IPv4 and IPv6 (LOG target) Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV4]: add the UdpSndbufErrors and UdpRcvbufErrors MIBsMartin Bligh
Signed-off-by: Martin Bligh <mbligh@google.com> Signed-off-by: Andrew Morton <akpm@osdl.org>
2006-04-11[PATCH] for_each_possible_cpu: network codesKAMEZAWA Hiroyuki
for_each_cpu() actually iterates across all possible CPUs. We've had mistakes in the past where people were using for_each_cpu() where they should have been iterating across only online or present CPUs. This is inefficient and possibly buggy. We're renaming for_each_cpu() to for_each_possible_cpu() to avoid this in the future. This patch replaces for_each_cpu with for_each_possible_cpu under /net Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-05[PATCH] percpu data: only iterate over possible CPUsEric Dumazet
percpu_data blindly allocates bootmem memory to store NR_CPUS instances of cpudata, instead of allocating memory only for possible cpus. As a preparation for changing that, we need to convert various 0 -> NR_CPUS loops to use for_each_cpu(). (The above only applies to users of asm-generic/percpu.h. powerpc has gone it alone and is presently only allocating memory for present CPUs, so it's currently corrupting memory). Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: James Bottomley <James.Bottomley@steeleye.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Jens Axboe <axboe@suse.de> Cc: Anton Blanchard <anton@samba.org> Acked-by: William Irwin <wli@holomorphy.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03[INET_SOCK]: Move struct inet_sock & helper functions to net/inet_sock.hArnaldo Carvalho de Melo
To help in reducing the number of include dependencies, several files were touched as they were getting needed headers indirectly for stuff they use. Thanks also to Alan Menegotto for pointing out that net/dccp/proto.c had linux/dccp.h include twice. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-29[NET]: Add const markers to various variables.Arjan van de Ven
the patch below marks various variables const in net/; the goal is to move them to the .rodata section so that they can't false-share cachelines with things that get written to, as well as potentially helping gcc a bit with optimisations. (these were found using a gcc patch to warn about such variables) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-25[NET]: Wider use of for_each_*cpu()John Hawkes
In 'net' change the explicit use of for-loops and NR_CPUS into the general for_each_cpu() or for_each_online_cpu() constructs, as appropriate. This widens the scope of potential future optimizations of the general constructs, as well as takes advantage of the existing optimizations of first_cpu() and next_cpu(), which is advantageous when the true CPU count is much smaller than NR_CPUS. Signed-off-by: John Hawkes <hawkes@sgi.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-08-29[NET]: Fix sparse warningsArnaldo Carvalho de Melo
Of this type, mostly: CHECK net/ipv6/netfilter.c net/ipv6/netfilter.c:96:12: warning: symbol 'ipv6_netfilter_init' was not declared. Should it be static? net/ipv6/netfilter.c:101:6: warning: symbol 'ipv6_netfilter_fini' was not declared. Should it be static? Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[TIMEWAIT]: Introduce inet_timewait_death_rowArnaldo Carvalho de Melo
That groups all of the tables and variables associated to the TCP timewait schedulling/recycling/killing code, that now can be isolated from the TCP specific code and used by other transport protocols, such as DCCP. Next changeset will move this code to net/ipv4/inet_timewait_sock.c Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
