This patch removes the following unused EXPORT_SYMBOL's:
- ip_vs_try_bind_dest
- ip_vs_find_dest
Signed-off-by: Adrian Bunk <bunk@kernel.org>
This patch fixes the problem with node overload on director fail-over.
Given the scenario: 2 nodes each accepting 3 connections at a time and 2
directors, director failover occurs when the nodes are fully loaded (6
connections to the cluster) in this case the new director will assign
another 6 connections to the cluster, If the same real servers exist
there.
The problem turned to be in not binding the inherited connections to
the real servers (destinations) on the backup director. Therefore:
"ipvsadm -l" reports 0 connections:
root@test2:~# ipvsadm -l
IP Virtual Server version 1.2.1 (size=4096)
Prot LocalAddress:Port Scheduler Flags
-> RemoteAddress:Port Forward Weight ActiveConn InActConn
TCP test2.local:5999 wlc
-> node473.local:5999 Route 1000 0 0
-> node484.local:5999 Route 1000 0 0
while "ipvs -lnc" is right
root@test2:~# ipvsadm -lnc
IPVS connection entries
pro expire state source virtual destination
TCP 14:56 ESTABLISHED 192.168.0.10:39164 192.168.0.222:5999
192.168.0.51:5999
TCP 14:59 ESTABLISHED 192.168.0.10:39165 192.168.0.222:5999
192.168.0.52:5999
So the patch I am sending fixes the problem by binding the received
connections to the appropriate service on the backup director, if it
exists, else the connection will be handled the old way. So if the
master and the backup directors are synchronized in terms of real
services there will be no problem with server over-committing since
new connections will not be created on the nonexistent real services
on the backup. However if the service is created later on the backup,
the binding will be performed when the next connection update is
received. With this patch the inherited connections will show as
inactive on the backup:
-> node473.local:5999 Route 1000 0 1
-> node484.local:5999 Route 1000 0 1
rumen@test2:~$ cat /proc/net/ip_vs
TCP C0A800DE:176F wlc
-> C0A80033:176F Route 1000 0 1
-> C0A80032:176F Route 1000 0 1
Regards,
Rumen Bogdanovski
Acked-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Rumen G. Bogdanovski <rumen@voicecho.com>
Signed-off-by: Simon Horman <horms@verge.net.au>
This patch makes /proc/net per network namespace. It modifies the global
variables proc_net and proc_net_stat to be per network namespace.
The proc_net file helpers are modified to take a network namespace argument,
and all of their callers are fixed to pass &init_net for that argument.
This ensures that all of the /proc/net files are only visible and
usable in the initial network namespace until the code behind them
has been updated to be handle multiple network namespaces.
Making /proc/net per namespace is necessary as at least some files
in /proc/net depend upon the set of network devices which is per
network namespace, and even more files in /proc/net have contents
that are relevant to a single network namespace.
Slab destructors were no longer supported after Christoph's
c59def9f222d44bb7e2f0a559f2906191a0862d7 change. They've been
BUGs for both slab and slub, and slob never supported them
either.
This rips out support for the dtor pointer from kmem_cache_create()
completely and fixes up every single callsite in the kernel (there were
about 224, not including the slab allocator definitions themselves,
or the documentation references).
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Make all initialized struct seq_operations in net/ const
Signed-off-by: Philippe De Muyter <phdm@macqel.be>
Many struct file_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: (45 commits)
[IPV4]: Restore multipath routing after rt_next changes.
[XFRM] IPV6: Fix outbound RO transformation which is broken by IPsec tunnel patch.
[NET]: Reorder fields of struct dst_entry
[DECNET]: Convert decnet route to use the new dst_entry 'next' pointer
[IPV6]: Convert ipv6 route to use the new dst_entry 'next' pointer
[IPV4]: Convert ipv4 route to use the new dst_entry 'next' pointer
[NET]: Introduce union in struct dst_entry to hold 'next' pointer
[DECNET]: fix misannotation of linkinfo_dn
[DECNET]: FRA_{DST,SRC} are le16 for decnet
[UDP]: UDP can use sk_hash to speedup lookups
[NET]: Fix whitespace errors.
[NET] XFRM: Fix whitespace errors.
[NET] X25: Fix whitespace errors.
[NET] WANROUTER: Fix whitespace errors.
[NET] UNIX: Fix whitespace errors.
[NET] TIPC: Fix whitespace errors.
[NET] SUNRPC: Fix whitespace errors.
[NET] SCTP: Fix whitespace errors.
[NET] SCHED: Fix whitespace errors.
[NET] RXRPC: Fix whitespace errors.
Replace appropriate pairs of "kmem_cache_alloc()" + "memset(0)" with the
corresponding "kmem_cache_zalloc()" call.
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Andi Kleen <ak@muc.de>
Cc: Roland McGrath <roland@redhat.com>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: Greg KH <greg@kroah.com>
Acked-by: Joel Becker <Joel.Becker@oracle.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Jan Kara <jack@ucw.cz>
Cc: Michael Halcrow <mhalcrow@us.ibm.com>
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Cc: Chris Wright <chrisw@sous-sol.org>
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Replace all uses of kmem_cache_t with struct kmem_cache.
The patch was generated using the following script:
#!/bin/sh
# Replace one string by another in all the kernel sources.
set -e
for file in `find * -name "*.c" -o -name "*.h"|xargs grep -l $1`; do
quilt add $file
sed -e "1,\$s/$1/$2/g" $file >/tmp/$$
mv /tmp/$$ $file
quilt refresh
done
The script was run like this
sh replace kmem_cache_t "struct kmem_cache"
Signed-off-by: Christoph Lameter <clameter@sgi.com>
CC [M] net/ipv4/ipvs/ip_vs_conn.o
/pub/scm/linux/kernel/git/acme/net-2.6/net/ipv4/ipvs/ip_vs_conn.c: In
function 'ip_vs_conn_new':
/pub/scm/linux/kernel/git/acme/net-2.6/net/ipv4/ipvs/ip_vs_conn.c:606:
warning: implicit declaration of function 'net_ratelimit'
function 'ip_vs_random_dropentry':
/pub/scm/linux/kernel/git/acme/net-2.6/net/ipv4/ipvs/ip_vs_conn.c:810:
warning: implicit declaration of function 'net_random'
Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
The attached patch (against current -GIT) is a cleanup patch which does
following:
o lookup debug messages shifted back to 9
o added more informational value to flags and refcnt since those
entries can be in multiple referenced structures
o cleanup 80 char violation
It's the prepatch to the session pool implementation and helps very much
to debug and monitor important variables and structures regarding the
threshold limitation and persistency without the thousands of lookup
messages which noone is interested in.
Signed-off-by: Horms <horms@verge.net.au>
To help in reducing the number of include dependencies, several files were
touched as they were getting needed headers indirectly for stuff they use.
Thanks also to Alan Menegotto for pointing out that net/dccp/proto.c had
linux/dccp.h include twice.
the patch below marks various variables const in net/; the goal is to
move them to the .rodata section so that they can't false-share
cachelines with things that get written to, as well as potentially
helping gcc a bit with optimisations. (these were found using a gcc
patch to warn about such variables)
Signed-off-by: Arjan van de Ven <arjan@infradead.org>
ip_vs_ftp when loaded can create NAT connections with unknown client
port for passive FTP. For such expectations we lookup with cport=0 on
incoming packet but it matches the format of the persistence templates
causing packets to other persistent virtual servers to be forwarded to
real server without creating connection. Later the reply packets are
treated as foreign and not SNAT-ed.
This patch changes the connection lookup for packets from clients:
* introduce IP_VS_CONN_F_TEMPLATE connection flag to mark the
connection as template
* create new connection lookup function just for templates -
ip_vs_ct_in_get
* make sure ip_vs_conn_in_get hits only connections with
IP_VS_CONN_F_NO_CPORT flag set when s_port is 0. By this way
we avoid returning template when looking for cport=0 (ftp)
Signed-off-by: Julian Anastasov <ja@ssi.bg>
Agostino di Salle noticed that persistent templates are not
invalidated due to buggy optimization.
This patch puts mostly read only data in the right section
(read_mostly), to help sharing of these data between CPUS without
memory ping pongs.
On one of my production machine, tcp_statistics was sitting in a
heavily modified cache line, so *every* SNMP update had to force a
reload.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
An addition to the last ipvs changes that move
update_defense_level/si_meminfo to keventd:
- ip_vs_random_dropentry now runs in process context and should use _bh
locks to protect from softirqs
- update_defense_level still needs _bh locks after si_meminfo is called,
for the same purpose
In an smp system, it is possible for an connection timer to expire, calling
ip_vs_conn_expire while the connection table is being flushed, before
ct_write_lock_bh is acquired.
Since the list iterator loop in ip_vs_con_flush releases and re-acquires the
spinlock (even though it doesn't re-enable softirqs), it is possible for the
expiration function to modify the connection list, while it is being traversed
in ip_vs_conn_flush.
The result is that the next pointer gets set to NULL, and subsequently
dereferenced, resulting in an oops.
Signed-off-by: Neil Horman <nhorman@redhat.com>
Acked-by: JulianAnastasov
infrastructure for it.
Let it rip!
