path: root/net/ipv4/ip_input.c
2012-05-15net: Convert net_ratelimit uses to net_<level>_ratelimitedJoe Perches
Standardize the net core ratelimited logging functions. Coalesce formats, align arguments. Change a printk then vprintk sequence to use printf extension %pV. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2012-03-12net: ipv4: Standardize prefixes for message loggingJoe Perches
Add #define pr_fmt(fmt) as appropriate. Add "IPv4: ", "TCP: ", and "IPsec: " to appropriate files. Standardize on "UDPLite: " for appropriate uses. Some prefixes were previously "UDPLITE: " and "UDP-Lite: ". Add KBUILD_MODNAME ": " to icmp and gre. Remove embedded prefixes as appropriate. Add missing "\n" to pr_info in gre.c. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-11net: Convert printks to pr_<level>Joe Perches
Use a more current kernel messaging style. Convert a printk block to print_hex_dump. Coalesce formats, align arguments. Use %s, __func__ instead of embedding function names. Some messages that were prefixed with <foo>_close are now prefixed with <foo>_fini. Some ah4 and esp messages are now not prefixed with "ip ". The intent of this patch is to later add something like #define pr_fmt(fmt) "IPv4: " fmt. to standardize the output messages. Text size is trivially reduced. (x86-32 allyesconfig) $ size net/ipv4/built-in.o* text data bss dec hex filename 887888 31558 249696 1169142 11d6f6 net/ipv4/built-in.o.new 887934 31558 249800 1169292 11d78c net/ipv4/built-in.o.old Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-09ipv4: Make ip_rcv_options() return bool.David S. Miller
2012-03-09ipv4: Make ip_call_ra_chain() return bool.David S. Miller
2011-06-21ip: introduce ip_is_fragment helper inline functionPaul Gortmaker
There are enough instances of this: iph->frag_off & htons(IP_MF | IP_OFFSET) that a helper function is probably warranted. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-22inet: constify ip headers and in6_addrEric Dumazet
Add const qualifiers to structs iphdr, ipv6hdr and in6_addr pointers where possible, to make code intention more obvious. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-14netfilter: fix Kconfig dependenciesPatrick McHardy
Fix dependencies of netfilter realm match: it depends on NET_CLS_ROUTE, which itself depends on NET_SCHED; this dependency is missing from netfilter. Since matching on realms is also useful without having NET_SCHED enabled and the option really only controls whether the tclassid member is included in route and dst entries, rename the config option to IP_ROUTE_CLASSID and move it outside of traffic scheduling context to get rid of the NET_SCHED dependeny. Reported-by: Vladis Kletnieks <Valdis.Kletnieks@vt.edu> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-06-28net: use this_cpu_ptr()Eric Dumazet
use this_cpu_ptr(p) instead of per_cpu_ptr(p, smp_processor_id()) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-10net-next: remove useless union keywordChangli Gao
remove useless union keyword in rtable, rt6_info and dn_route. Since there is only one member in a union, the union keyword isn't useful. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-07net: avoid two atomic ops in ip_rcv_options()Eric Dumazet
in_dev_get() -> __in_dev_get_rcu() in a rcu protected function. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-07ip: Router Alert RCU conversionEric Dumazet
Straightforward conversion to RCU. One rwlock becomes a spinlock, and is static. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-03ipv4: add LINUX_MIB_IPRPFILTER snmp counterEric Dumazet
Christoph Lameter mentioned that packets could be dropped in input path because of rp_filter settings, without any SNMP counter being incremented. System administrator can have a hard time to track the problem. This patch introduces a new counter, LINUX_MIB_IPRPFILTER, incremented each time we drop a packet because Reverse Path Filter triggers. (We receive an IPv4 datagram on a given interface, and find the route to send an answer would use another interface) netstat -s | grep IPReversePathFilter IPReversePathFilter: 21714 Reported-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17net: Use ip_route_input_noref() in input pathEric Dumazet
Use ip_route_input_noref() in ip fast path, to avoid two atomic ops per incoming packet. Note: loopback is excluded from this optimization in ip_rcv_finish() Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-20Merge branch 'master' of /repos/git/net-next-2.6Patrick McHardy
Conflicts: Documentation/feature-removal-schedule.txt net/ipv6/netfilter/ip6t_REJECT.c net/netfilter/xt_limit.c Signed-off-by: Patrick McHardy <kaber@trash.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-25netfilter: ipv4: use NFPROTO values for NF_HOOK invocationJan Engelhardt
The semantic patch that was used: // <smpl> @@ @@ (NF_HOOK |NF_HOOK_COND |nf_hook )( -PF_INET, +NFPROTO_IPV4, ...) // </smpl> Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2009-11-25net: use net_eq to compare netsOctavian Purdila
Generated with the following semantic patch @@ struct net *n1; struct net *n2; @@ - n1 == n2 + net_eq(n1, n2) @@ struct net *n1; struct net *n2; @@ - n1 != n2 + !net_eq(n1, n2) applied over {include,net,drivers/net}. Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-18inet: rename some inet_sock fieldsEric Dumazet
In order to have better cache layouts of struct sock (separate zones for rx/tx paths), we need this preliminary patch. Goal is to transfert fields used at lookup time in the first read-mostly cache line (inside struct sock_common) and move sk_refcnt to a separate cache line (only written by rx path) This patch adds inet_ prefix to daddr, rcv_saddr, dport, num, saddr, sport and id fields. This allows a future patch to define these fields as macros, like sk_refcnt, without name clashes. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-14net: constify struct net_protocolAlexey Dobriyan
Remove long removed "inet_protocol_base" declaration. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-26inet: Call skb_orphan before tproxy activatesHerbert Xu
As transparent proxying looks up the socket early and assigns it to the skb for later processing, we must drop any existing socket ownership prior to that in order to distinguish between the case where tproxy is active and where it is not. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-03net: skb->dst accessorsEric Dumazet
Define three accessors to get/set dst attached to a skb struct dst_entry *skb_dst(const struct sk_buff *skb) void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst) void skb_dst_drop(struct sk_buff *skb) This one should replace occurrences of : dst_release(skb->dst) skb->dst = NULL; Delete skb->dst field Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-03net: skb->rtable accessorEric Dumazet
Define skb_rtable(const struct sk_buff *skb) accessor to get rtable from skb Delete skb->rtable field Setting rtable is not allowed, just set dst instead as rtable is an alias. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-27snmp: add missing counters for RFC 4293Neil Horman
The IP MIB (RFC 4293) defines stats for InOctets, OutOctets, InMcastOctets and OutMcastOctets: http://tools.ietf.org/html/rfc4293 But it seems we don't track those in any way that easy to separate from other protocols. This patch adds those missing counters to the stats file. Tested successfully by me With help from Eric Dumazet. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/isdn/i4l/isdn_net.c fs/cifs/connect.c
2008-11-12net: shy netns_ok checkAlexey Dobriyan
Failure to pass netns_ok check is SILENT, except some MIB counter is incremented somewhere. And adding "netns_ok = 1" (after long head-scratching session) is usually the last step in making some protocol netns-ready... Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03net: clean up net/ipv4/ip_fragment.c tcp_timer.c ip_input.cJianjun Kong
Signed-off-by: Jianjun Kong <jianjun@zeuux.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-31net: replace NIPQUAD() in net/ipv4/ net/ipv6/Harvey Harrison
Using NIPQUAD() with NIPQUAD_FMT, %d.%d.%d.%d or %u.%u.%u.%u can be replaced with %pI4 Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-13net: Rationalise email address: Network Specific PartsAlan Cox
Clean up the various different email addresses of mine listed in the code to a single current and valid address. As Dave says his network merges for 2.6.28 are now done this seems a good point to send them in where they won't risk disrupting real changes. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-18mib: put ip statistics on struct netPavel Emelyanov
Similar to tcp one. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-16mib: add net to IP_INC_STATS_BHPavel Emelyanov
2008-06-11net: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-08net/ipv4: correct RFC 1122 section reference in commentJ.H.M. Dassen (Ray)
RFC 1122 does not have a section 3.1.2.2. The requirement to silently discard datagrams with a bad checksum is in section 3.2.1.2 instead. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=10611 Signed-off-by: J.H.M. Dassen (Ray) <jdassen@debian.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-14[IPV4]: Use NIPQUAD_FMT to format ipv4 addresses.YOSHIFUJI Hideaki
And use %u to format port. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26[NET] NETNS: Omit sock->sk_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-sock inlines: sock_net(), sock_net_set() and per-inet_timewait_sock inlines: twsk_net(), twsk_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-26[NET] NETNS: Omit net_device->nd_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-net_device inlines: dev_net(), dev_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-24[NETNS]: Drop packets in the non-initial namespace on the per/protocol basis.Denis V. Lunev
IP layer now can handle multiple namespaces normally. So, process such packets normally and drop them only if the transport layer is not aware about namespaces. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-24[NETNS]: Process IP layer in the context of the correct namespace.Denis V. Lunev
Replace all the rest of the init_net with a proper net on the IP layer. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-24[NETNS]: Add namespace parameter to ip_options_compile.Denis V. Lunev
ip_options_compile uses inet_addr_type which requires a namespace. The packet argument is optional, so parameter is the only way to obtain it. Pass the init_net there for now. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-22[IPV4]: Always pass ip_options pointer into ip_options_compile.Denis V. Lunev
This makes code a bit more uniform and straigthforward. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-05[IPV4]: Add 'rtable' field in struct sk_buff to alias 'dst' and avoid castsEric Dumazet
(Anonymous) unions can help us to avoid ugly casts. A common cast it the (struct rtable *)skb->dst one. Defining an union like : union { struct dst_entry *dst; struct rtable *rtable; }; permits to use skb->rtable in place. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPv4] RAW: Compact the API for the kernelPavel Emelyanov
The raw sockets functions are explicitly used from inside the kernel in two places: 1. in ip_local_deliver_finish to intercept skb-s 2. in icmp_error For this purposes many functions and even data structures, that are naturally internal for raw protocol, are exported. Compact the API to two functions and hide all the other (including hash table and rwlock) inside the net/ipv4/raw.c Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: NET_CLS_ROUTE : convert ip_rt_acct to per_cpu variablesEric Dumazet
ip_rt_acct needs 4096 bytes per cpu to perform some accounting. It is actually allocated as a single huge array [4096*NR_CPUS] (rounded up to a power of two) Converting it to a per cpu variable is wanted to : - Save space on machines were num_possible_cpus() < NR_CPUS - Better NUMA placement (each cpu gets memory on its node) Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: Introduce NF_INET_ hook valuesPatrick McHardy
The IPv4 and IPv6 hook values are identical, yet some code tries to figure out the "correct" value by looking at the address family. Introduce NF_INET_* values for both IPv4 and IPv6. The old values are kept in a #ifndef __KERNEL__ section for userspace compatibility. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[IPV4]: Uninline netfilter okfnsPatrick McHardy
Now that we don't pass double skb pointers to nf_hook_slow anymore, gcc can generate tail calls for some of the netfilter hook okfn invocations, so there is no need to inline the functions anymore. This caused huge code bloat since we ended up with one inlined version and one out-of-line version since we pass the address to nf_hook_slow. Before: text data bss dec hex filename 8997385 1016524 524652 10538561 a0ce41 vmlinux After: text data bss dec hex filename 8994009 1016524 524652 10535185 a0c111 vmlinux ------------------------------------------------------- -3376 All cases have been verified to generate tail-calls with and without netfilter. The okfns in ipmr and xfrm4_input still remain inline because gcc can't generate tail-calls for them. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[IPV4]: Change ip_defrag to return an integerHerbert Xu
Now that ip_frag always returns the packet given to it on input, we can change it to return an integer indicating error instead. This patch does that and updates all its callers accordingly. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make packet reception network namespace safeEric W. Biederman
This patch modifies every packet receive function registered with dev_add_pack() to drop packets if they are not from the initial network namespace. This should ensure that the various network stacks do not receive packets in a anything but the initial network namespace until the code has been converted and is ready for them. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-30[IPV4] SNMP: Support InMcastPkts and InBcastPktsMitsuru Chinen
A received IP multicast datagram should be counted as InMcastPkts. By the same token, a received IP broadcast datagram should be counted as InBcastPkts. Signed-off-by: Mitsuru Chinen <mitch@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-30[IPV4] SNMP: Support InTruncatedPktsMitsuru Chinen
An IP datagram which is being discarded because the datagram frame didn't carry enough data should be counted as InTruncatedPkts. Signed-off-by: Mitsuru Chinen <mitch@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
