path: root/net/ipv4/inet_diag.c
2006-09-28[IPV4]: inet_diag annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-21[NET]: Conversions from kmalloc+memset to k(z|c)alloc.Panagiotis Issaris
Signed-off-by: Panagiotis Issaris <takis@issaris.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-09[INET_DIAG]: Introduce sk_diag_fillArnaldo Carvalho de Melo
To be called from inet_diag_get_exact, also rename inet_diag_fill to inet_csk_diag_fill, for consistency with inet_twsk_diag_fill. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-09[INET_DIAG]: Introduce inet_twsk_diag_dump & inet_twsk_diag_fillArnaldo Carvalho de Melo
To properly dump TIME_WAIT sockets and to reduce complexity a bit by having per socket class accessor routines. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-09[INET_DIAG]: whitespace/simple cleanupsArnaldo Carvalho de Melo
2006-01-09[INET_DIAG]: Use inet_twsk() with TIME_WAIT socketsArnaldo Carvalho de Melo
The fields being accessed in inet_diag_dump are outside sock_common, the common part of struct sock and struct inet_timewait_sock. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IPV6]: Introduce inet6_timewait_sockArnaldo Carvalho de Melo
Out of tcp6_timewait_sock, that now is just an aggregation of inet_timewait_sock and inet6_timewait_sock, using tw_ipv6_offset in struct inet_timewait_sock, that is common to the IPv6 transport protocols that use timewait sockets, like DCCP and TCP. tw_ipv6_offset plays the struct inet_sock pinfo6 role, i.e. for the generic code to find the IPv6 area in a timewait sock. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IPV6]: Introduce inet6_rsk()Arnaldo Carvalho de Melo
And inet6_rsk_offset in inet_request_sock, for the same reasons as inet_sock's pinfo6 member. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-10[NETLINK]: Make netlink_callback->done() optionalThomas Graf
Most netlink families make no use of the done() callback, making it optional gets rid of all unnecessary dummy implementations. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETLINK]: Add "groups" argument to netlink_kernel_createPatrick McHardy
Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[INET_DIAG]: Move the tcp_diag interface to the proper placeArnaldo Carvalho de Melo
With this the previous setup is back, i.e. tcp_diag can be built as a module, as dccp_diag and both share the infrastructure available in inet_diag. If one selects CONFIG_INET_DIAG as module CONFIG_INET_TCP_DIAG will also be built as a module, as will CONFIG_INET_DCCP_DIAG, if CONFIG_IP_DCCP was selected static or as a module, if CONFIG_INET_DIAG is y, being statically linked CONFIG_INET_TCP_DIAG will follow suit and CONFIG_INET_DCCP_DIAG will be built in the same manner as CONFIG_IP_DCCP. Now to aim at UDP, converting it to use inet_hashinfo, so that we can use iproute2 for UDP sockets as well. Ah, just to show an example of this new infrastructure working for DCCP :-) [root@qemu ~]# ./ss -dane State Recv-Q Send-Q Local Address:Port Peer Address:Port LISTEN 0 0 *:5001 *:* ino:942 sk:cfd503a0 ESTAB 0 0 127.0.0.1:5001 127.0.0.1:32770 ino:943 sk:cfd50a60 ESTAB 0 0 127.0.0.1:32770 127.0.0.1:5001 ino:947 sk:cfd50700 TIME-WAIT 0 0 127.0.0.1:32769 127.0.0.1:5001 timer:(timewait,3.430ms,0) ino:0 sk:cf209620 Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[INET_DIAG]: Rename tcp_diag.[ch] to inet_diag.[ch]Arnaldo Carvalho de Melo
Next changeset will introduce net/ipv4/tcp_diag.c, moving the code that was put transitioanlly in inet_diag.c. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
