commit a9b3cd7f32 (rcu: convert uses of rcu_assign_pointer(x, NULL) to
RCU_INIT_POINTER) did a lot of incorrect changes, since it did a
complete conversion of rcu_assign_pointer(x, y) to RCU_INIT_POINTER(x,
y).
We miss needed barriers, even on x86, when y is not NULL.
CC: Stephen Hemminger <shemminger@vyatta.com>
CC: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
The reverse path filter module will use fib_lookup.
If CONFIG_IP_MULTIPLE_TABLES is not set, fib_lookup is
only a static inline helper that calls fib_table_lookup,
so export that too.
These files are non modular, but need to export symbols using
the macros now living in export.h -- call out the include so
that things won't break when we remove the implicit presence
of module.h from everywhere.
When assigning a NULL value to an RCU protected pointer, no barrier
is needed. The rcu_assign_pointer, used to handle that but will soon
change to not handle the special case.
Convert all rcu_assign_pointer of NULL value.
//smpl
@@ expression P; @@
- rcu_assign_pointer(P, NULL)
+ RCU_INIT_POINTER(P, NULL)
// </smpl>
Compiler is not smart enough to avoid double BSWAP instructions in
ntohl(inet_make_mask(plen)).
Lets cache this value in struct leaf_info, (fill a hole on 64bit arches)
With route cache disabled, this saves ~2% of cpu in udpflood bench on
x86_64 machine.
After discovering that wide use of prefetch on modern CPUs
could be a net loss instead of a win, net drivers which were
relying on the implicit inclusion of prefetch.h via the list
headers showed up in the resulting cleanup fallout. Give
them an explicit include via the following $0.02 script.
#!/bin/bash
MANUAL=""
for i in `git grep -l 'prefetch(.*)' .` ; do
grep -q '<linux/prefetch.h>' $i
if [ $? = 0 ] ; then
continue
fi
( echo '?^#include <linux/?a'
echo '#include <linux/prefetch.h>'
echo .
echo w
echo q
) | ed -s $i > /dev/null 2>&1
if [ $? != 0 ]; then
echo $i needs manual fixup
MANUAL="$i $MANUAL"
fi
done
echo ------------------- 8\<----------------------
echo vi $MANUAL
Signed-off-by: Paul <paul.gortmaker@windriver.com>
[ Fixed up some incorrect #include placements, and added some
non-network drivers and the fib_trie.c case - Linus ]
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits)
macvlan: fix panic if lowerdev in a bond
tg3: Add braces around 5906 workaround.
tg3: Fix NETIF_F_LOOPBACK error
macvlan: remove one synchronize_rcu() call
networking: NET_CLS_ROUTE4 depends on INET
irda: Fix error propagation in ircomm_lmp_connect_response()
irda: Kill set but unused variable 'bytes' in irlan_check_command_param()
irda: Kill set but unused variable 'clen' in ircomm_connect_indication()
rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport()
be2net: Kill set but unused variable 'req' in lancer_fw_download()
irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication()
atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined.
rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer().
rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler()
rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection()
rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window()
pkt_sched: Kill set but unused variable 'protocol' in tc_classify()
isdn: capi: Use pr_debug() instead of ifdefs.
tg3: Update version to 3.119
tg3: Apply rx_discards fix to 5719/5720
Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c
as per Davem.
The rcu callback __leaf_info_free_rcu() just calls a kfree(),
so we use kfree_rcu() instead of the call_rcu(__leaf_info_free_rcu).
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
drivers/net/tg3.c
fib_trie_table() is called during netns creation and
Chromium uses clone(CLONE_NEWNET) to sandbox renderer process.
Don't print anything.
fib_select_default() is a complete NOP, and completely pointless
to invoke, when we have no more than 1 default route installed.
And this is far and away the common case.
So remember how many prefixlen==0 routes we have in the routing
table, and elide the call when we have no more than one of those.
This cuts output route creation time by 157 cycles on Niagara2+.
In order to add the new int to fib_table, we have to correct the type
of ->tb_data[] to unsigned long, otherwise the private area will be
unaligned on 64-bit systems.
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
drivers/net/smsc911x.c
Add __rcu annotations and lockdep checks.
Add const qualifiers
node_parent() and node_parent_rcu() can use
rcu_dereference_index_check()
The "ipv4: Inline fib_semantic_match into check_leaf"
change forgets to return the route errors. check_leaf should
return the same results as fib_table_lookup.
Signed-off-by: Julian Anastasov <ja@ssi.bg>
Move the scope value out of the fib alias entries and into fib_info,
so that we always use the correct scope when recomputing the nexthop
cached source address.
Reported-by: Julian Anastasov <ja@ssi.bg>
fib_table_delete forgets to match the routes by prefsrc.
Callers can specify known IP in fc_prefsrc and we should remove
the exact route. This is needed for cases when same local or
broadcast addresses are used in different subnets and the
routes differ only in prefsrc. All callers that do not provide
fc_prefsrc will ignore the route prefsrc as before and will
delete the first occurence. That is how the ip route del default
magic works.
Current callers are:
- ip_rt_ioctl where rtentry_to_fib_config provides fc_prefsrc only
when the provided device name matches IP label with colon.
- inet_rtm_delroute where RTA_PREFSRC is optional too
- fib_magic which deals with routes when deleting addresses
and where the fc_prefsrc is always set with the primary IP
for the concerned IFA.
To start doing these conversions, we need to add some temporary
flow4_* macros which will eventually go away when all the protocol
code paths are changed to work on AF specific flowi objects.
I intend to turn struct flowi into a union of AF specific flowi
structs. There will be a common structure that each variant includes
first, much like struct sock_common.
This is the first step to move in that direction.
This elimiates a lot of pure overhead due to parameter
passing.
GCC emits all kinds of crazy zero extensions when we go from signed
int, to unsigned short, etc. etc.
This transformation has to be legal because:
1) In tkey_extract_bits() in mask_pfx(), the values are used to
perform shifts, on which negative values are undefined by C.
2) In fib_table_lookup() we perform comparisons with unsigned
values, constants, and additions. None of which should
encounter negative values.
If we end up including include/linux/node.h (either explicitly
or implicitly) that header has a definition of "structt node"
too.
So rename the one we use in fib_trie to "rt_trie_node" to avoid
the conflict.
fib_hash_init() --> fib_trie_init()
fib_hash_table() --> fib_trie_table()
Both fib_trie and fib_hash have a local implementation of
fib_table_select_default(). This is completely unnecessary
code duplication.
Since we now remember the fib_table and the head of the fib
alias list of the default route, we can implement one single
generic version of this routine.
Looking at the fib_hash implementation you may get the impression
that it's possible for there to be multiple top-level routes in
the table for the default route. The truth is, it isn't, the
insert code will only allow one entry to exist in the zero
prefix hash table, because all keys evaluate to zero and all
keys in a hash table must be unique.
This will be used later to implement fib_select_default() in a
completely generic manner, instead of the current situation where the
default route is re-looked up in the TRIE/HASH table and then the
available aliases are analyzed.
We forgot to use __GFP_HIGHMEM in several __vmalloc() calls.
In ceph, add the missing flag.
In fib_trie.c, xfrm_hash.c and request_sock.c, using vzalloc() is
cleaner and allows using HIGHMEM pages as well.
When we stop a namespace we flush the table and free one, but the
added fn_zone-s (and their hashes if grown) are leaked. Need to free.
Tries releases all its stuff in the flushing code.
Shame on us - this bug exists since the very first make-fib-per-net
patches in 2.6.27 :(
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Update broken web addresses in arch directory.
Update broken web addresses in the kernel.
Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget
Revert "Fix typo: configuation => configuration" partially
ida: document IDA_BITMAP_LONGS calculation
ext2: fix a typo on comment in ext2/inode.c
drivers/scsi: Remove unnecessary casts of private_data
drivers/s390: Remove unnecessary casts of private_data
net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data
drivers/infiniband: Remove unnecessary casts of private_data
drivers/gpu/drm: Remove unnecessary casts of private_data
kernel/pm_qos_params.c: Remove unnecessary casts of private_data
fs/ecryptfs: Remove unnecessary casts of private_data
fs/seq_file.c: Remove unnecessary casts of private_data
arm: uengine.c: remove C99 comments
arm: scoop.c: remove C99 comments
Fix typo configue => configure in comments
Fix typo interrest[ing|ed] => interest[ing|ed]
Fix various typos of valid in comments
Fix up trivial conflicts in:
drivers/char/ipmi/ipmi_si_intf.c
drivers/usb/gadget/rndis.c
net/irda/irnet/irnet_ppp.c
Perf tools session at NFWS 2010 pointed out a false sharing on struct
fib_alias that can be avoided pretty easily, if we set FA_S_ACCESSED bit
only if needed (ie : not already set)
The patch below updates broken web addresses in the kernel
Cc: Maciej W. Rozycki <macro@linux-mips.org>
Cc: Finn Thain <fthain@telegraphics.com.au>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Mike Frysinger <vapier.adi@gmail.com>
Acked-by: Ben Pfaff <blp@cs.stanford.edu>
Acked-by: Hans J. Koch <hjk@linutronix.de>
Reviewed-by: Finn Thain <fthain@telegraphics.com.au>
fib_table_lookup() might use fls() to speedup an open coded loop.
Noticed while doing a profile analysis.
fib_lookup() converted to be called in RCU protected context, no
reference taken and released on a contended cache line (fib_clntref)
fib_table_lookup() and fib_semantic_match() get an additional parameter.
struct fib_info gets an rcu_head field, and is freed after an rcu grace
period.
Stress test :
(Sending 160.000.000 UDP frames on same neighbour,
IP route cache disabled, dual E5540 @2.53GHz,
32bit kernel, FIB_HASH) (about same results for FIB_TRIE)
Before patch :
real 1m31.199s
user 0m13.761s
sys 23m24.780s
After patch:
real 1m5.375s
user 0m14.997s
sys 15m50.115s
Before patch Profile :
13044.00 15.4% __ip_route_output_key vmlinux
8438.00 10.0% dst_destroy vmlinux
5983.00 7.1% fib_semantic_match vmlinux
5410.00 6.4% fib_rules_lookup vmlinux
4803.00 5.7% neigh_lookup vmlinux
4420.00 5.2% _raw_spin_lock vmlinux
3883.00 4.6% rt_set_nexthop vmlinux
3261.00 3.9% _raw_read_lock vmlinux
2794.00 3.3% fib_table_lookup vmlinux
2374.00 2.8% neigh_resolve_output vmlinux
2153.00 2.5% dst_alloc vmlinux
1502.00 1.8% _raw_read_lock_bh vmlinux
1484.00 1.8% kmem_cache_alloc vmlinux
1407.00 1.7% eth_header vmlinux
1406.00 1.7% ipv4_dst_destroy vmlinux
1298.00 1.5% __copy_from_user_ll vmlinux
1174.00 1.4% dev_queue_xmit vmlinux
1000.00 1.2% ip_output vmlinux
After patch Profile :
13712.00 15.8% dst_destroy vmlinux
8548.00 9.9% __ip_route_output_key vmlinux
7017.00 8.1% neigh_lookup vmlinux
4554.00 5.3% fib_semantic_match vmlinux
4067.00 4.7% _raw_read_lock vmlinux
3491.00 4.0% dst_alloc vmlinux
3186.00 3.7% neigh_resolve_output vmlinux
3103.00 3.6% fib_table_lookup vmlinux
2098.00 2.4% _raw_read_lock_bh vmlinux
2081.00 2.4% kmem_cache_alloc vmlinux
2013.00 2.3% _raw_spin_lock vmlinux
1763.00 2.0% __copy_from_user_ll vmlinux
1763.00 2.0% ip_output vmlinux
1761.00 2.0% ipv4_dst_destroy vmlinux
1631.00 1.9% eth_header vmlinux
1440.00 1.7% _raw_read_unlock_bh vmlinux
Reference results, if IP route cache is enabled :
real 0m29.718s
user 0m10.845s
sys 7m37.341s
25213.00 29.5% __ip_route_output_key vmlinux
9011.00 10.5% dst_release vmlinux
4817.00 5.6% ip_push_pending_frames vmlinux
4232.00 5.0% ip_finish_output vmlinux
3940.00 4.6% udp_sendmsg vmlinux
3730.00 4.4% __copy_from_user_ll vmlinux
3716.00 4.4% ip_route_output_flow vmlinux
2451.00 2.9% __xfrm_lookup vmlinux
2221.00 2.6% ip_append_data vmlinux
1718.00 2.0% _raw_spin_lock_bh vmlinux
1655.00 1.9% __alloc_skb vmlinux
1572.00 1.8% sock_wfree vmlinux
1345.00 1.6% kfree vmlinux
Use rcu_dereference_rtnl() helper
Change hard coded constants in fib_flag_trans()
7 -> RTN_UNREACHABLE
8 -> RTN_PROHIBIT
Here is one more of these warnings and a patch below:
Sep 5 23:52:33 del kernel: [46044.244833] ===================================================
Sep 5 23:52:33 del kernel: [46044.269681] [ INFO: suspicious rcu_dereference_check() usage. ]
Sep 5 23:52:33 del kernel: [46044.277000] ---------------------------------------------------
Sep 5 23:52:33 del kernel: [46044.285185] net/ipv4/fib_trie.c:1756 invoked rcu_dereference_check() without protection!
Sep 5 23:52:33 del kernel: [46044.293627]
Sep 5 23:52:33 del kernel: [46044.293632] other info that might help us debug this:
Sep 5 23:52:33 del kernel: [46044.293634]
Sep 5 23:52:33 del kernel: [46044.325333]
Sep 5 23:52:33 del kernel: [46044.325335] rcu_scheduler_active = 1, debug_locks = 0
Sep 5 23:52:33 del kernel: [46044.348013] 1 lock held by pppd/1717:
Sep 5 23:52:33 del kernel: [46044.357548] #0: (rtnl_mutex){+.+.+.}, at: [<c125dc1f>] rtnl_lock+0xf/0x20
Sep 5 23:52:33 del kernel: [46044.367647]
Sep 5 23:52:33 del kernel: [46044.367652] stack backtrace:
Sep 5 23:52:33 del kernel: [46044.387429] Pid: 1717, comm: pppd Not tainted 2.6.35.4.4a #3
Sep 5 23:52:33 del kernel: [46044.398764] Call Trace:
Sep 5 23:52:33 del kernel: [46044.409596] [<c12f9aba>] ? printk+0x18/0x1e
Sep 5 23:52:33 del kernel: [46044.420761] [<c1053969>] lockdep_rcu_dereference+0xa9/0xb0
Sep 5 23:52:33 del kernel: [46044.432229] [<c12b7235>] trie_firstleaf+0x65/0x70
Sep 5 23:52:33 del kernel: [46044.443941] [<c12b74d4>] fib_table_flush+0x14/0x170
Sep 5 23:52:33 del kernel: [46044.455823] [<c1033e92>] ? local_bh_enable_ip+0x62/0xd0
Sep 5 23:52:33 del kernel: [46044.467995] [<c12fc39f>] ? _raw_spin_unlock_bh+0x2f/0x40
Sep 5 23:52:33 del kernel: [46044.480404] [<c12b24d0>] ? fib_sync_down_dev+0x120/0x180
Sep 5 23:52:33 del kernel: [46044.493025] [<c12b069d>] fib_flush+0x2d/0x60
Sep 5 23:52:33 del kernel: [46044.505796] [<c12b06f5>] fib_disable_ip+0x25/0x50
Sep 5 23:52:33 del kernel: [46044.518772] [<c12b10d3>] fib_netdev_event+0x73/0xd0
Sep 5 23:52:33 del kernel: [46044.531918] [<c1048dfd>] notifier_call_chain+0x2d/0x70
Sep 5 23:52:33 del kernel: [46044.545358] [<c1048f0a>] raw_notifier_call_chain+0x1a/0x20
Sep 5 23:52:33 del kernel: [46044.559092] [<c124f687>] call_netdevice_notifiers+0x27/0x60
Sep 5 23:52:33 del kernel: [46044.573037] [<c124faec>] __dev_notify_flags+0x5c/0x80
Sep 5 23:52:33 del kernel: [46044.586489] [<c124fb47>] dev_change_flags+0x37/0x60
Sep 5 23:52:33 del kernel: [46044.599394] [<c12a8a8d>] devinet_ioctl+0x54d/0x630
Sep 5 23:52:33 del kernel: [46044.612277] [<c12aabb7>] inet_ioctl+0x97/0xc0
Sep 5 23:52:34 del kernel: [46044.625208] [<c123f6af>] sock_ioctl+0x6f/0x270
Sep 5 23:52:34 del kernel: [46044.638046] [<c109d2b0>] ? handle_mm_fault+0x420/0x6c0
Sep 5 23:52:34 del kernel: [46044.650968] [<c123f640>] ? sock_ioctl+0x0/0x270
Sep 5 23:52:34 del kernel: [46044.663865] [<c10c3188>] vfs_ioctl+0x28/0xa0
Sep 5 23:52:34 del kernel: [46044.676556] [<c10c38fa>] do_vfs_ioctl+0x6a/0x5c0
Sep 5 23:52:34 del kernel: [46044.688989] [<c1048676>] ? up_read+0x16/0x30
Sep 5 23:52:34 del kernel: [46044.701411] [<c1021376>] ? do_page_fault+0x1d6/0x3a0
Sep 5 23:52:34 del kernel: [46044.714223] [<c10b6588>] ? fget_light+0xf8/0x2f0
Sep 5 23:52:34 del kernel: [46044.726601] [<c1241f98>] ? sys_socketcall+0x208/0x2c0
Sep 5 23:52:34 del kernel: [46044.739140] [<c10c3eb3>] sys_ioctl+0x63/0x70
Sep 5 23:52:34 del kernel: [46044.751967] [<c12fca3d>] syscall_call+0x7/0xb
Sep 5 23:52:34 del kernel: [46044.764734] [<c12f0000>] ? cookie_v6_check+0x3d0/0x630
This patch fixes the warning:
stack backtrace:
Pid: 1717, comm: pppd Not tainted 2.6.35.4a #3
Call Trace:
Allow trie_firstleaf() to be called either under rcu_read_lock()
protection or with RTNL held. The same annotation is added to
node_parent_rcu() to prevent a similar warning a bit later.
Followup of commits 634a4b20 and 4eaa0e3c.
Signed-off-by: Jarek Poplawski <jarkao2@gmail.com>
This patch removes from net/ (but not any netfilter files)
all the unnecessary return; statements that precede the
last closing brace of void functions.
It does not remove the returns that are immediately
preceded by a label as gcc doesn't like that.
Done via:
$ grep -rP --include=*.[ch] -l "return;\n}" net/ | \
xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }'
Followup of commit 634a4b20
Allow tnode_get_child_rcu() to be called either under rcu_read_lock()
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Allow fib_find_node() to be called either under rcu_read_lock()
The FIB algorithim for IPV4 is set at compile time, but kernel goes through
the overhead of function call indirection at runtime. Save some
cycles by turning the indirect calls to direct calls to either
hash or trie code.
Here is rework and cleanup of the resize function.
Some bugs we had. We were using ->parent when we should use
node_parent(). Also we used ->parent which is not assigned by
inflate in inflate loop.
Also a fix to set thresholds to power 2 to fit halve
and double strategy.
max_resize is renamed to max_work which better indicates
it's function.
Reaching max_work is not an error, so warning is removed.
max_work only limits amount of work done per resize.
(limits CPU-usage, outstanding memory etc).
The clean-up makes it relatively easy to add fixed sized
root-nodes if we would like to decrease the memory pressure
on routers with large routing tables and dynamic routing.
If we'll need that...
Its been tested with 280k routes.
Work done together with Robert Olsson.
Signed-off-by: Jens Låås <jens.laas@its.uu.se>
Signed-off-by: Robert Olsson <robert.olsson@its.uu.se>
String literals are constant, and usually, we can also tag the array
of pointers const too, moving it to the .rodata section.
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
While looking for other fib_trie problems reported by Pawel Staszewski
I noticed there are a few uses of tnode_get_child() and node_parent()
in lookups instead of their rcu versions.
During large updates there could be triggered warnings like: "Fix
inflate_threshold_root. Now=25 size=11 bits" if inflate() of the root
node isn't finished in 10 loops. It should be much rarer now, after
changing the threshold from 15 to 25, and a temporary problem, so
this patch tries to handle it automatically using a fix variable to
increase by one inflate threshold for next root resizes (up to the 35
limit, max fix = 10). The fix variable is decreased when root's
inflate() finishes below 7 loops (even if some other, smaller table/
trie is updated -- for simplicity the fix variable is global for now).
Reported-by: Pawel Staszewski <pstaszewski@itcare.pl>
Reported-by: Jorge Boncompte [DTI2] <jorge@dti2.net>
Tested-by: Pawel Staszewski <pstaszewski@itcare.pl>
During trie_rebalance() we free memory after resizing with call_rcu(),
but large updates, especially with PREEMPT_NONE configs, can cause
memory stresses, so this patch calls synchronize_rcu() in
tnode_free_flush() after each sync_pages to guarantee such freeing
(especially before resizing the root node).
The value of sync_pages = 128 is based on Pawel Staszewski's tests as
the lowest which doesn't hinder updating times. (For testing purposes
there was a sysfs module parameter to change it on demand, but it's
removed until we're sure it could be really useful.)
The patch is based on suggestions by: Paul E. McKenney
Pawel Staszewski wrote:
<blockquote>
Some time ago i report this:
http://bugzilla.kernel.org/show_bug.cgi?id=6648
and now with 2.6.29 / 2.6.29.1 / 2.6.29.3 and 2.6.30 it back
dmesg output:
oprofile: using NMI interrupt.
Fix inflate_threshold_root. Now=15 size=11 bits
cat /proc/net/fib_triestat
Basic info: size of leaf: 40 bytes, size of tnode: 56 bytes.
Main:
Aver depth: 2.28
Max depth: 6
Leaves: 276539
Prefixes: 289922
Internal nodes: 66762
1: 35046 2: 13824 3: 9508 4: 4897 5: 2331 6: 1149 7: 5
9: 1 18: 1
Pointers: 691228
Null ptrs: 347928
Total size: 35709 kB
</blockquote>
It seems, the current threshold for root resizing is too aggressive,
and it causes misleading warnings during big updates, but it might be
also responsible for memory problems, especially with non-preempt
configs, when RCU freeing is delayed long after call_rcu.
It should be also mentioned that because of non-atomic changes during
resizing/rebalancing the current lookup algorithm can miss valid leaves
so it's additional argument to shorten these activities even at a cost
of a minimally longer searching.
This patch restores values before the patch "[IPV4]: fib_trie root
node settings", commit: 965ffea43d4ebe8cd7b9fee78d651268dd7d23c5 from
v2.6.22.
Pawel's report:
<blockquote>
I dont see any big change of (cpu load or faster/slower
routing/propagating routes from bgpd or something else) - in avg there
is from 2% to 3% more of CPU load i dont know why but it is - i change
from "preempt" to "no preempt" 3 times and check this my "mpstat -P ALL
1 30"
always avg cpu load was from 2 to 3% more compared to "no preempt"
Basic info: size of leaf: 20 bytes, size of tnode: 36 bytes.
Main:
Aver depth: 2.44
Max depth: 6
Leaves: 277814
Prefixes: 291306
Internal nodes: 66420
1: 32737 2: 14850 3: 10332 4: 4871 5: 2313 6: 942 7: 371 8: 3 17: 1
Pointers: 599098
Null ptrs: 254865
Total size: 18067 kB
</blockquote>
According to this and other similar reports average depth is slightly
increased (~0.2), and root nodes are shorter (log 17 vs. 18), but
there is no visible performance decrease. So, until memory handling is
improved or added parameters for changing this individually, this
patch resets to safer defaults.
Alas current delaying of freeing old tnodes by RCU in trie_rebalance
is still not enough because we can free a top tnode before updating a
t->trie pointer.
My previous patch, which explicitly delays freeing of tnodes by adding
them to the list to flush them after the update is finished, isn't
strict enough. It treats exceptionally tnodes without parent, assuming
they are newly created, so "invisible" for the read side yet.
But the top tnode doesn't have parent as well, so we have to exclude
all exceptions (at least until a better way is found). Additionally we
need to move rcu assignment of this node before flushing, so the
return type of the trie_rebalance() function is changed.
Reported-by: Yan Zheng <zheng.yan@oracle.com>
While doing trie_rebalance(): resize(), inflate(), halve() RCU free
tnodes before updating their parents. It depends on RCU delaying the
real destruction, but if RCU readers start after call_rcu() and before
parent update they could access freed memory.
It is currently prevented with preempt_disable() on the update side,
but it's not safe, except maybe classic RCU, plus it conflicts with
memory allocations with GFP_KERNEL flag used from these functions.
This patch explicitly delays freeing of tnodes by adding them to the
list, which is flushed after the update is finished.
drivers/net/wireless/ath/ath5k/phy.c
drivers/net/wireless/iwlwifi/iwl-agn.c
drivers/net/wireless/iwlwifi/iwl3945-base.c
It seems we can fix this by disabling preemption while we re-balance the
trie. This is with the CONFIG_CLASSIC_RCU. It's been stress-tested at high
loads continuesly taking a full BGP table up/down via iproute -batch.
Note. fib_trie is not updated for CONFIG_PREEMPT_RCU
Reported-by: Andrei Popa
