path: root/net/ipv4/fib_semantics.c
2007-03-25[IPv4] fib: Fix out of bound access of fib_props[]Thomas Graf
Fixes a typo which caused fib_props[] to have the wrong size and makes sure the value used to index the array which is provided by userspace via netlink is checked to avoid out of bound access. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] IPV4: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-08[NETLINK]: Don't BUG on undersized allocationsPatrick McHardy
Currently netlink users BUG when the allocated skb for an event notification is undersized. While this is certainly a kernel bug, its not critical and crashing the kernel is too drastic, especially when considering that these errors have appeared multiple times in the past and it BUGs even if no listeners are present. This patch replaces BUG by WARN_ON and changes the notification functions to inform potential listeners of undersized allocations using a unique error code (EMSGSIZE). Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NETLINK]: Do precise netlink message allocations where possibleThomas Graf
Account for the netlink message header size directly in nlmsg_new() instead of relying on the caller calculate it correctly. Replaces error handling of message construction functions when constructing notifications with bug traps since a failure implies a bug in calculating the size of the skb. Signed-off-by: Thomas Graf <tgraf@suug.ch> Acked-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: net/ipv4/fib annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4] bug: open-coded inet_make_mask() in fib_semantic_match() is brokenAl Viro
... and works only on little-endian Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: fib_semantic_match() annotationsAl Viro
'mask' and 'zone' arguments are net-endian Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: ip_fib_check_default() annotatedAl Viro
2006-09-28[IPV4]: RTA_{DST,SRC,GATEWAY,PREFSRC} annotatedAl Viro
these are passed net-endian; use be32 netlink accessors Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: FIB_RES_PREFSRC() annotatedAl Viro
2006-09-22[IPv4]: Convert FIB dumping to use new netlink apiThomas Graf
2006-09-22[IPv4]: FIB configuration using struct fib_configThomas Graf
Introduces struct fib_config replacing the ugly struct kern_rta prone to ordering issues. Avoids creating faked netlink messages for auto generated routes or requests via ioctl. A new interface net/nexthop.h is added to help navigate through nexthop configuration arrays. A new struct nl_info will be used to carry the necessary netlink information to be used for notifications later on. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPv4] route: Convert route notifications to use rtnl_notify()Thomas Graf
2006-09-22[NET]: Introduce RTA_TABLE/FRA_TABLE attributesPatrick McHardy
Introduce RTA_TABLE route attribute and FRA_TABLE routing rule attribute to hold 32 bit routing table IDs. Usespace compatibility is provided by continuing to accept and send the rtm_table field, but because of its limited size it can only carry the low 8 bits of the table ID. This implies that if larger IDs are used, _all_ userspace programs using them need to use RTA_TABLE. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NET]: Use u32 for routing table IDsPatrick McHardy
Use u32 for routing table IDs in net/ipv4 and net/decnet in preparation of support for a larger number of routing tables. net/ipv6 already uses u32 everywhere and needs no further changes. No functional changes are made by this patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV4] fib: convert reader/writer to spinlockStephen Hemminger
Ther is no point in using a more expensive reader/writer lock for a low contention lock like the fib_info_lock. The only reader case is in handling route redirects. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-17[IPV4]: severe locking bug in fib_semantics.cAlexey Kuznetsov
Found in 2.4 by Yixin Pan <yxpan@hotmail.com>. > When I read fib_semantics.c of Linux-2.4.32, write_lock(&fib_info_lock) = > is used in fib_release_info() instead of write_lock_bh(&fib_info_lock). = > Is the following case possible: a BH interrupts fib_release_info() while = > holding the write lock, and calls ip_check_fib_default() which calls = > read_lock(&fib_info_lock), and spin forever. Signed-off-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-21[IPV4]: Fix nexthop realm dumping for multipath routesPatrick McHardy
Routing realms exist per nexthop, but are only returned to userspace for the first nexthop. This is due to the fact that iproute2 only allows to set the realm for the first nexthop and the kernel refuses multipath routes where only a single realm is present. Dump all realms for multipath routes to enable iproute to correctly display them. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-21[NET]: Conversions from kmalloc+memset to k(z|c)alloc.Panagiotis Issaris
Signed-off-by: Panagiotis Issaris <takis@issaris.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-09[NETLINK]: illegal use of pid in rtnetlinkAlexey Kuznetsov
When a netlink message is not related to a netlink socket, it is issued by kernel socket with pid 0. Netlink "pid" has nothing to do with current->pid. I called it incorrectly, if it was named "port", the confusion would be avoided. Signed-off-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[INET_SOCK]: Move struct inet_sock & helper functions to net/inet_sock.hArnaldo Carvalho de Melo
To help in reducing the number of include dependencies, several files were touched as they were getting needed headers indirectly for stuff they use. Thanks also to Alan Menegotto for pointing out that net/dccp/proto.c had linux/dccp.h include twice. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-29[NET]: Add const markers to various variables.Arjan van de Ven
the patch below marks various variables const in net/; the goal is to move them to the .rodata section so that they can't false-share cachelines with things that get written to, as well as potentially helping gcc a bit with optimisations. (these were found using a gcc patch to warn about such variables) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-03[IPV4]: Replace __in_dev_get with __in_dev_get_rcu/rtnlHerbert Xu
The following patch renames __in_dev_get() to __in_dev_get_rtnl() and introduces __in_dev_get_rcu() to cover the second case. 1) RCU with refcnt should use in_dev_get(). 2) RCU without refcnt should use __in_dev_get_rcu(). 3) All others must hold RTNL and use __in_dev_get_rtnl(). There is one exception in net/ipv4/route.c which is in fact a pre-existing race condition. I've marked it as such so that we remember to fix it. This patch is based on suggestions and prior work by Suzanne Wood and Paul McKenney. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[IPV4]: Prepare FIB core for RCU.Robert Olsson
* RCU versions of hlist_***_rcu * fib_alias partial rcu port just whats needed now. Signed-off-by: Robert Olsson <Robert.Olsson@data.slu.se> Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETLINK]: Convert netlink users to use group numbers instead of bitmasksPatrick McHardy
2005-08-05[IPV4]: Fix memory leak during fib_info hash expansion.David S. Miller
When we grow the tables, we forget to free the olds ones up. Noticed by Yan Zheng. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[NETLINK]: Set correct pid for ioctl originating netlink eventsJamal Hadi Salim
This patch ensures that netlink events created as a result of programns using ioctls (such as ifconfig, route etc) contains the correct PID of those events. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[NETLINK]: Correctly set NLM_F_MULTI without checking the pidJamal Hadi Salim
This patch rectifies some rtnetlink message builders that derive the flags from the pid. It is now explicit like the other cases which get it right. Also fixes half a dozen dumpers which did not set NLM_F_MULTI at all. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
