path: root/net/ipv4/fib_frontend.c
2007-07-19[NET] IPV4: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2007-07-10[IPV4]: The scheduled removal of multipath cached routing support.David S. Miller
With help from Chris Wedgwood. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-07[NETLINK]: Mark netlink policies constPatrick McHardy
Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-31[IPV4]: Kill references to bogus non-existent CONFIG_IP_NOSIOCRTDavid S. Miller
2007-04-27[IPV4] nl_fib_lookup: Initialise res.r before fib_res_put(&res)Sergey Vlasov
When CONFIG_IP_MULTIPLE_TABLES is enabled, the code in nl_fib_lookup() needs to initialize the res.r field before fib_res_put(&res) - unlike fib_lookup(), a direct call to ->tb_lookup does not set this field. Signed-off-by: Sergey Vlasov <vsu@altlinux.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETLINK]: Switch cb_lock spinlock to mutex and allow to override itPatrick McHardy
Switch cb_lock to mutex and allow netlink kernel users to override it with a subsystem specific mutex for consistent locking in dump callbacks. All netlink_dump_start users have been audited not to rely on any side-effects of the previously used spinlock. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[IPv4]: Use rtnl registration interfaceThomas Graf
Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETLINK]: Introduce nlmsg_hdr() helperArnaldo Carvalho de Melo
For the common "(struct nlmsghdr *)skb->data" sequence, so that we reduce the number of direct accesses to skb->data and for consistency with all the other cast skb member helpers. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETLINK]: Infinite recursion in netlink.Alexey Kuznetsov
Reply to NETLINK_FIB_LOOKUP messages were misrouted back to kernel, which resulted in infinite recursion and stack overflow. The bug is present in all kernel versions since the feature appeared. The patch also makes some minimal cleanup: 1. Return something consistent (-ENOENT) when fib table is missing 2. Do not crash when queue is empty (does not happen, but yet) 3. Put result of lookup Signed-off-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-25[IPv4] fib: Fix out of bound access of fib_props[]Thomas Graf
Fixes a typo which caused fib_props[] to have the wrong size and makes sure the value used to index the array which is provided by userspace via netlink is checked to avoid out of bound access. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] IPV4: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NETLINK]: Remove unused dst_pid field in netlink_skb_parmsThomas Graf
The destination PID is passed directly to netlink_unicast() respectively netlink_multicast(). Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[IPV4] nl_fib_lookup: Rename fl_fwmark to fl_markThomas Graf
For the sake of consistency. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Rethink mark field in struct flowiThomas Graf
Now that all protocols have been made aware of the mark field it can be moved out of the union thus simplyfing its usage. The config options in the IPv4/IPv6/DECnet subsystems to enable respectively disable mark based routing only obfuscate the code with ifdefs, the cost for the additional comparison in the flow key is insignificant, and most distributions have all these options enabled by default anyway. Therefore it makes sense to remove the config options and enable mark based routing by default. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-18[IPv4] fib: Remove unused fib_config membersThomas Graf
2006-09-28[IPV4]: net/ipv4/fib annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: inet_addr_type() annotationsAl Viro
argument and inferred net-endian variables in callers annotated. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: annotate inetdev.h helpersAl Viro
inet_confirm_addr(), inet_ifa_byprefix(), ip_dev_find(), inet_make_mask() and inet_ifa_match() annotated, along with inferred net-endian variables Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: annotate struct in_ifaddrAl Viro
ifa_local, ifa_address, ifa_mask, ifa_broadcast and ifa_anycast are net-endian. Annotated them and variables that are inferred to be net-endian. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: struct fib_config IPv4 address fields annotatedAl Viro
2006-09-28[IPV4]: RTA_{DST,SRC,GATEWAY,PREFSRC} annotatedAl Viro
these are passed net-endian; use be32 netlink accessors Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: fib_validate_source() annotationsAl Viro
annotated arguments and inferred net-endian variables in callers Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NETLINK]: Make use of NLA_STRING/NLA_NUL_STRING attribute validationThomas Graf
Converts existing NLA_STRING attributes to use the new validation features, saving a couple of temporary buffers. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPv4]: Convert route get to new netlink apiThomas Graf
Fixes various unvalidated netlink attributes causing memory corruptions when left empty by userspace applications. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPv4]: Convert FIB dumping to use new netlink apiThomas Graf
2006-09-22[IPv4]: FIB configuration using struct fib_configThomas Graf
Introduces struct fib_config replacing the ugly struct kern_rta prone to ordering issues. Avoids creating faked netlink messages for auto generated routes or requests via ioctl. A new interface net/nexthop.h is added to help navigate through nexthop configuration arrays. A new struct nl_info will be used to carry the necessary netlink information to be used for notifications later on. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV4]: Increase number of possible routing tables to 2^32Patrick McHardy
Increase the number of possible routing tables to 2^32 by replacing the fixed sized array of pointers by a hash table and replacing iterations over all possible table IDs by hash table walking. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NET]: Introduce RTA_TABLE/FRA_TABLE attributesPatrick McHardy
Introduce RTA_TABLE route attribute and FRA_TABLE routing rule attribute to hold 32 bit routing table IDs. Usespace compatibility is provided by continuing to accept and send the rtm_table field, but because of its limited size it can only carry the low 8 bits of the table ID. This implies that if larger IDs are used, _all_ userspace programs using them need to use RTA_TABLE. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NET]: Use u32 for routing table IDsPatrick McHardy
Use u32 for routing table IDs in net/ipv4 and net/decnet in preparation of support for a larger number of routing tables. net/ipv6 already uses u32 everywhere and needs no further changes. No functional changes are made by this patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPv4]: Move interface address bits to linux/if_addr.hThomas Graf
2006-09-22[IPV4]: Use Protocol Independant Policy Routing Rules FrameworkThomas Graf
2006-06-17[NET]: Export ip_dev_find()Sean Hefty
Export ip_dev_find() to allow locating a net_device given an IP address. Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-04-14[IPV4]: Possible cleanups.Adrian Bunk
This patch contains the following possible cleanups: - make the following needlessly global function static: - arp.c: arp_rcv() - remove the following unused EXPORT_SYMBOL's: - devinet.c: devinet_ioctl - fib_frontend.c: ip_rt_ioctl - inet_hashtables.c: inet_bind_bucket_create - inet_hashtables.c: inet_bind_hash - tcp_input.c: sysctl_tcp_abc - tcp_ipv4.c: sysctl_tcp_tw_reuse - tcp_output.c: sysctl_tcp_mtu_probing - tcp_output.c: sysctl_tcp_base_mss Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-14x86: Work around compiler code generation bug with -OsLinus Torvalds
Some versions of gcc generate incorrect code for the inet_check_attr() function, apparently due to a totally bogus index -> pointer comparison transformation. At least "gcc version 4.0.1 20050727 (Red Hat 4.0.1-5)" from FC4 is affected, possibly others too. This changes the function subtly so that the buggy gcc transformation doesn't trigger. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] capable/capability.h (net/)Randy Dunlap
net: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03[INET_SOCK]: Move struct inet_sock & helper functions to net/inet_sock.hArnaldo Carvalho de Melo
To help in reducing the number of include dependencies, several files were touched as they were getting needed headers indirectly for stuff they use. Thanks also to Alan Menegotto for pointing out that net/dccp/proto.c had linux/dccp.h include twice. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-12-01[NETLINK]: Fix processing of fib_lookup netlink messagesThomas Graf
The receive path for fib_lookup netlink messages is lacking sanity checks for header and payload and is thus vulnerable to malformed netlink messages causing illegal memory references. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-22[IPV4]: Fix secondary IP addresses after promotionJamal Hadi Salim
This patch fixes the problem with promoting aliases when: a) a single primary and > 1 secondary addresses b) multiple primary addresses each with at least one secondary address Based on earlier efforts from Brian Pomerantz <bapper@piratehaven.org>, Patrick McHardy <kaber@trash.net> and Thomas Graf <tgraf@suug.ch> Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-08[NET]: kfree cleanupJesper Juhl
From: Jesper Juhl <jesper.juhl@gmail.com> This is the net/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in net/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Arnaldo Carvalho de Melo <acme@conectiva.com.br> Acked-by: Marcel Holtmann <marcel@holtmann.org> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Andrew Morton <akpm@osdl.org>
2005-10-29[IPV4]: Fix issue reported by Coverity in ipv4/fib_frontend.cJayachandran C
fib_del_ifaddr() dereferences ifa->ifa_dev, so the code already assumes that ifa->ifa_dev is non-NULL, the check is unnecessary. Signed-off-by: Jayachandran C. <c.jayachandran at gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-03[IPV4]: Replace __in_dev_get with __in_dev_get_rcu/rtnlHerbert Xu
The following patch renames __in_dev_get() to __in_dev_get_rtnl() and introduces __in_dev_get_rcu() to cover the second case. 1) RCU with refcnt should use in_dev_get(). 2) RCU without refcnt should use __in_dev_get_rcu(). 3) All others must hold RTNL and use __in_dev_get_rtnl(). There is one exception in net/ipv4/route.c which is in fact a pre-existing race condition. I've marked it as such so that we remember to fix it. This patch is based on suggestions and prior work by Suzanne Wood and Paul McKenney. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETLINK]: Add "groups" argument to netlink_kernel_createPatrick McHardy
2005-08-29[NETLINK]: Convert netlink users to use group numbers instead of bitmasksPatrick McHardy
2005-08-29[NETLINK]: Remove unused groups member from struct netlink_skb_parmsPatrick McHardy
2005-08-29[NETLINK]: Add properly module refcounting for kernel netlink sockets.Harald Welte
- Remove bogus code for compiling netlink as module - Add module refcounting support for modules implementing a netlink protocol - Add support for autoloading modules that implement a netlink protocol as soon as someone opens a socket for that protocol Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[IPV4]: possible cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make needlessly global code static - #if 0 the following unused global function: - xfrm4_state.c: xfrm4_state_fini - remove the following unneeded EXPORT_SYMBOL's: - ip_output.c: ip_finish_output - ip_output.c: sysctl_ip_default_ttl - fib_frontend.c: ip_dev_find - inetpeer.c: inet_peer_idlock - ip_options.c: ip_options_compile - ip_options.c: ip_options_undo - net/core/request_sock.c: sysctl_max_syn_backlog Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-20[NETLINK]: fib_lookup() via netlinkRobert Olsson
Below is a more generic patch to do fib_lookup via netlink. For others we should say that we discussed this as a way to verify route selection. It's also possible there are others uses for this. In short the fist half of struct fib_result_nl is filled in by caller and netlink call fills in the other half and returns it. In case anyone is interested there is a corresponding user app to compare the full routing table this was used to test implementation of the LC-trie. Signed-off-by: David S. Miller <davem@davemloft.net>
