This is a revision of the previously submitted patch, which alters
the way files are organized and compiled in the following manner:
* UDP and UDP-Lite now use separate object files
* source file dependencies resolved via header files
net/ipv{4,6}/udp_impl.h
* order of inclusion files in udp.c/udplite.c adapted
accordingly
[NET/IPv4]: Support for the UDP-Lite protocol (RFC 3828)
This patch adds support for UDP-Lite to the IPv4 stack, provided as an
extension to the existing UDPv4 code:
* generic routines are all located in net/ipv4/udp.c
* UDP-Lite specific routines are in net/ipv4/udplite.c
* MIB/statistics support in /proc/net/snmp and /proc/net/udplite
* shared API with extensions for partial checksum coverage
[NET/IPv6]: Extension for UDP-Lite over IPv6
It extends the existing UDPv6 code base with support for UDP-Lite
in the same manner as per UDPv4. In particular,
* UDPv6 generic and shared code is in net/ipv6/udp.c
* UDP-Litev6 specific extensions are in net/ipv6/udplite.c
* MIB/statistics support in /proc/net/snmp6 and /proc/net/udplite6
* support for IPV6_ADDRFORM
* aligned the coding style of protocol initialisation with af_inet6.c
* made the error handling in udpv6_queue_rcv_skb consistent;
to return `-1' on error on all error cases
* consolidation of shared code
[NET]: UDP-Lite Documentation and basic XFRM/Netfilter support
The UDP-Lite patch further provides
* API documentation for UDP-Lite
* basic xfrm support
* basic netfilter support for IPv4 and IPv6 (LOG target)
Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
We currently allocate a fixed size (TCP_SYNQ_HSIZE=512) slots hash table for
each LISTEN socket, regardless of various parameters (listen backlog for
example)
On x86_64, this means order-1 allocations (might fail), even for 'small'
sockets, expecting few connections. On the contrary, a huge server wanting a
backlog of 50000 is slowed down a bit because of this fixed limit.
This patch makes the sizing of listen hash table a dynamic parameter,
depending of :
- net.core.somaxconn tunable (default is 128)
- net.ipv4.tcp_max_syn_backlog tunable (default : 256, 1024 or 128)
- backlog value given by user application (2nd parameter of listen())
For large allocations (bigger than PAGE_SIZE), we use vmalloc() instead of
kmalloc().
We still limit memory allocation with the two existing tunables (somaxconn &
tcp_max_syn_backlog). So for standard setups, this patch actually reduce RAM
usage.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
->faddr is net-endian; annotated as such, variables inferred to be net-endian
annotated.
This is just a minor buglet I came across by accident - when inet_init
fails to register raw_prot, it jumps to out_unregister_udp_proto which
should unregister UDP _and_ TCP.
Signed-off-by: Olaf Kirch <okir@suse.de>
annotated address arguments (port number left alone for now); ditto
for inferred net-endian variables in callers.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Change net/core, ipv4 and ipv6 sysctl variables to __read_mostly.
Couldn't actually measure any performance increase while testing (.3%
I consider noise), but seems like the right thing to do.
Signed-off-by: Brian Haley <brian.haley@hp.com>
config.h is automatically included by kbuild these days.
Signed-off-by: Dave Jones <davej@redhat.com>
This labels the flows that could utilize IPSec xfrms at the points the
flows are defined so that IPSec policy and SAs at the right label can
be used.
The following protos are currently not handled, but they should
continue to be able to use single-labeled IPSec like they currently
do.
ipmr
ip_gre
ipip
igmp
sit
sctp
ip6_tunnel (IPv6 over IPv6 tunnel device)
decnet
Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com>
Certain subsystems in the stack (e.g., netfilter) can break the partial
checksum on GSO packets. Until they're fixed, this patch allows this to
work by recomputing the partial checksums through the GSO mechanism.
Once they've all been converted to update the partial checksum instead of
clearing it, this workaround can be removed.
We don't want nasty Xen guests to pass a TCPv6 packet in with gso_type set
to TCPv4 or even UDP (or a packet that's both TCP and UDP).
When GSO packets come from an untrusted source (e.g., a Xen guest domain),
we need to verify the header integrity before passing it to the hardware.
Since the first step in GSO is to verify the header, we can reuse that
code by adding a new bit to gso_type: SKB_GSO_DODGY. Packets with this
bit set can only be fed directly to devices with the corresponding bit
NETIF_F_GSO_ROBUST. If the device doesn't have that bit, then the skb
is fed to the GSO engine which will allow the packet to be sent to the
hardware if it passes the header check.
This patch changes the sg flag to a full features flag. The same method
can be used to implement TSO ECN support. We simply have to mark packets
with CWR set with SKB_GSO_ECN so that only hardware with a corresponding
NETIF_F_TSO_ECN can accept them. The GSO engine can either fully segment
the packet, or segment the first MTU and pass the rest to the hardware for
further segmentation.
This patch adds the GSO implementation for IPv4 TCP.
Convert inet_init to an fs_initcall to make sure its called before any
device driver's initcall.
No code changes, just tidying up, in some cases moving EXPORT_SYMBOLs
to just after the function exported, etc.
Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
This patch extends {get|set}sockopt compatibility layer in order to
move protocol specific parts to their place and avoid huge universal
net/compat.c file in the future.
Signed-off-by: Dmitry Mishin <dim@openvz.org>
net: Use <linux/capability.h> where capable() is used.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Currently all network protocols need to call dev_ioctl as the default
fallback in their ioctl implementations. This patch adds a fallback
to dev_ioctl to sock_ioctl if the protocol returned -ENOIOCTLCMD.
This way all the procotol ioctl handlers can be simplified and we don't
need to export dev_ioctl.
To help in reducing the number of include dependencies, several files were
touched as they were getting needed headers indirectly for stuff they use.
Thanks also to Alan Menegotto for pointing out that net/dccp/proto.c had
linux/dccp.h include twice.
I noticed that some of 'struct proto_ops' used in the kernel may share
a cache line used by locks or other heavily modified data. (default
linker alignement is 32 bytes, and L1_CACHE_LINE is 64 or 128 at
least)
This patch makes sure a 'struct proto_ops' can be declared as const,
so that all cpus can share all parts of it without false sharing.
This is not mandatory : a driver can still use a read/write structure
if it needs to (and eventually a __read_mostly)
I made a global stubstitute to change all existing occurences to make
them const.
This should reduce the possibility of false sharing on SMP, and
speedup some socket system calls.
As DCCP needs to be called in the same spots.
Now we have a member in inet_sock (is_icsk), set at sock creation time from
struct inet_protosw->flags (if INET_PROTOSW_ICSK is set, like for TCP and
DCCP) to see if a struct sock instance is a inet_connection_sock for places
like the ones in ip_sockglue.c (v4 and v6) where we previously were looking if
sk_type was SOCK_STREAM, that is insufficient because we now use the same code
for DCCP, that has sk_type SOCK_DCCP.
There is a coding error in inet_create that causes it to always return
ESOCKTNOSUPPORT. It should return EPROTONOSUPPORT when there are
protocols registered for a given socket type but none of them match
the requested protocol.
This is based on a patch by Jayachandran C.
This is the net/ part of the big kfree cleanup patch.
Remove pointless checks for NULL prior to calling kfree() in net/.
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Cc: Arnaldo Carvalho de Melo <acme@conectiva.com.br>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Create one iterator for walking over FIB trie, and use it
for all the /proc functions. Add a /proc/net/route
output for backwards compatibility with old applications.
Make initialization of fib_trie same as fib_hash so no #ifdef
is needed in af_inet.c
Fixes: http://bugzilla.kernel.org/show_bug.cgi?id=5209
Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
This patch puts mostly read only data in the right section
(read_mostly), to help sharing of these data between CPUS without
memory ping pongs.
On one of my production machine, tcp_statistics was sitting in a
heavily modified cache line, so *every* SNMP update had to force a
reload.
Of this type, mostly:
CHECK net/ipv6/netfilter.c
net/ipv6/netfilter.c:96:12: warning: symbol 'ipv6_netfilter_init' was not declared. Should it be static?
net/ipv6/netfilter.c:101:6: warning: symbol 'ipv6_netfilter_fini' was not declared. Should it be static?
Syntax is net-pf-PROTOCOL_FAMILY-PROTOCOL-SOCK_TYPE and if this
fails net-pf-PROTOCOL_FAMILY-PROTOCOL.
Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
With this we're very close to getting all of the current TCP
refactorings in my dccp-2.6 tree merged, next changeset will export
some functions needed by the current DCCP code and then dccp-2.6.git
will be born!
This also moved inet_iif from tcp to inet_hashtables.h, as it is
needed by the inet_lookup callers, perhaps this needs a bit of
polishing, but for now seems fine.
From tcp_v4_rebuild_header, that already was pretty generic, I only
needed to use sk->sk_protocol instead of the hardcoded IPPROTO_TCP and
establish the requirement that INET transport layer protocols that
want to use this function map TCP_SYN_SENT to its equivalent state.
Makes IPv4 ip_rcv registration happen last in af_inet.
Signed-off-by: Robert Olsson <Robert.Olsson@data.slu.se>
Signed-off-by: Neil Horman <nhorman@redhat.com>
Signed-off-by: Sridhar Samudrala <sri@us.ibm.com>
Ross moved. Remove the bad email address so people will find the correct
one in ./CREDITS.
Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk>
A lot of places in there are including major.h for no reason whatsoever.
Removed. And yes, it still builds.
The history of that stuff is often amusing. E.g. for net/core/sock.c
the story looks so, as far as I've been able to reconstruct it: we used
to need major.h in net/socket.c circa 1.1.early. In 1.1.13 that need
had disappeared, along with register_chrdev(SOCKET_MAJOR, "socket",
&net_fops) in sock_init(). Include had not. When 1.2 -> 1.3 reorg of
net/* had moved a lot of stuff from net/socket.c to net/core/sock.c,
this crap had followed...
Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk>
infrastructure for it.
Let it rip!
