So far we handled boolean input by forcing them with !! and assigning
them into a bool. This allowed userspace to send values > 1 which were
used as 1. We should be stricter here and return -EINVAL for all but
0 or 1.
Signed-off-by: Stefan Schmidt <stefan@osg.samsung.com>
Acked-by: Alexander Aring <alex.aring@gmail.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Signed-off-by: Phil Sutter <phil@nwl.cc>
Cc: Alexander Aring <alex.aring@gmail.com>
We receive all 802.15.4 frames on the packet handler "lowpan_rcv" this
patch checks if the wpan device belongs to a lowpan interface.
Signed-off-by: Alexander Aring <alex.aring@gmail.com>
This patch fixes 802.15.4 packet layer registration when mutliple
lowpan interfaces will be added. We need to register the packet layer at
the first lowpan interface and deregister it at the last interface. This
done by open_count variable which is protected by rtnl.
Additional do a quiet fix by adding dev_put(real_dev) when netdev
registration fails, which fix the refcount for the wpan dev.
This patch introduced the 6lowpan netdev private data struct. We name it
lowpan_priv and it's placed at the beginning of netdev private data. All
lowpan interfaces should allocate this room at first of netdev private
data. 6LoWPAN LL private data can be allocate by additional netdev private
data, e.g. dev->priv_size should be "sizeof(struct lowpan_priv) +
sizeof(LL_LOWPAN_PRIVATE_DATA)".
This patch fixes the error handling for lowpan_xmit_fragment by replace
"-PTR_ERR" to "PTR_ERR". PTR_ERR returns already a negative errno code.
This patch introduce a new mib entry which isn't part of 802.15.4 but
useful as default behaviour to set the ack request bit or not if we
don't know if the ack request bit should set. This is currently used for
stacks like IEEE 802.15.4 6LoWPAN.
Reviewed-by: Stefan Schmidt <stefan@osg.samsung.com>
We currently supports multiple lowpan interfaces per wpan interface. I
never saw any use case into such functionality. We drop this feature now
because it's much easier do deal with address changes inside the under
laying wpan interface.
This patch removes the multiple lowpan interface and adds a lowpan_dev
netdev pointer into the wpan_dev, if this pointer isn't null the wpan
interface belongs to the assigned lowpan interface.
Tested-by: Stefan Schmidt <stefan@osg.samsung.com>
arch/s390/net/bpf_jit_comp.c
drivers/net/ethernet/ti/netcp_ethss.c
net/bridge/br_multicast.c
net/ipv4/ip_fragment.c
All four conflicts were cases of simple overlapping
changes.
Followup patch will call it after inet_frag_queue was freed, so q->net
doesn't work anymore (but netf = q->net; free(q); mem_limit(netf) would).
Tested-by: Frank Schreuder <fschreuder@transip.nl>
This patch help to implement suspend/resume in mac802154, these
hooks will be run before the device is suspended and after it
resumes.
Signed-off-by: Varka Bhadram <varkab@cdac.in>
This patch will export the supported commands by the devices
to the userspace. This will be useful to check if HardMAC
drivers can support a specific command or not.
The AF_IEEE802154 sockaddr looks like this:
struct sockaddr_ieee802154 {
sa_family_t family; /* AF_IEEE802154 */
struct ieee802154_addr_sa addr;
struct ieee802154_addr_sa {
int addr_type;
u16 pan_id;
union {
u8 hwaddr[IEEE802154_ADDR_LEN];
u16 short_addr;
On most architectures there will be implicit structure padding here,
in two different places:
* In struct sockaddr_ieee802154, two bytes of padding between 'family'
(unsigned short) and 'addr', so that 'addr' starts on a four byte
boundary.
* In struct ieee802154_addr_sa, two bytes at the end of the structure,
to make the structure 16 bytes.
When calling recvmsg(2) on a PF_IEEE802154 SOCK_DGRAM socket, the
ieee802154 stack constructs a struct sockaddr_ieee802154 on the
kernel stack without clearing these padding fields, and, depending
on the addr_type, between four and ten bytes of uncleared kernel
stack will be copied to userspace.
We can't just insert two 'u16 __pad's in the right places and zero
those before copying an address to userspace, as not all architectures
insert this implicit padding -- from a quick test it seems that avr32,
cris and m68k don't insert this padding, while every other architecture
that I have cross compilers for does insert this padding.
The easiest way to plug the leak is to just memset the whole struct
sockaddr_ieee802154 before filling in the fields we want to fill in,
and that's what this patch does.
Cc: stable@vger.kernel.org
Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org>
This patch make to use the same naming convention that mac802154
tracing follows and fixes the format specifier for extended addr.
This patch sets the acknowledge request bit inside the 802.15.4 mac
header when frame retries is 0 or above. The other frame retries value
which is -1 indicates that the transmitter doesn't care about an
acknowledge frame which will be ignored after transmitting if the node
sends anyway an ack frame after receiving. This is currently unnecessary
traffic if the max frame retries parameter is -1.
This patch adds support for setting the current cca ed level value over
nl802154.
Reviewed-by: Varka Bhadram <varkabhadram@gmail.com>
This patch adds information about the current cca ed level when the phy
is dumped over nl802154.
This patch adds transmission power setting support for IEEE-802.15.4
devices via nl802154.
This patch fix the handling to call cca mode setting. If the phy isn't
flag then the driver doesn't support this setting.
Reported-by: Varka Bhadram <varkabhadram@gmail.com>
ieee802154_get_dev() only returns devices that have dev->type ==
ARPHRD_IEEE802154, therefore, there is no need to check this again
in raw_bind().
In the past, 802.15.4 interfaces and 6LoWPAN interfaces used the
same dev->type (ARPHRD_IEEE802154), and 802.15.4 interfaces were
distinguished from 6LoWPAN interfaces by their differing dev->mtu.
6LoWPAN interfaces have their own ARPHRD type now, so there is no
longer any need to check dev->mtu to distinguish 802.15.4 devices
from 6LoWPAN devices.
The proper return code for trying to send a packet that exceeds the
outgoing interface's MTU is EMSGSIZE, not EINVAL, so patch ieee802154's
raw_sendmsg() to do the right thing. (Its dgram_sendmsg() was already
returning EMSGSIZE for this case.)
This patch removes the mib lock. The new locking mechanism is to protect
the mib values with the rtnl lock. Note that this isn't always necessary
if we have an interface up the most mib values are readonly (e.g.
address settings). With this behaviour we can remove locking in
hotpath like frame parsing completely. It depends on context if we need
to hold the rtnl lock or not, this makes the callbacks of
ieee802154_mlme_ops unnecessary because these callbacks hols always the
locks.
This patch will use atomic operations for sequence number incrementation
while MAC header generation. Upper layers like af_802154 or 6LoWPAN
could call this function in a parallel context while generating 802.15.4
MAC header before queuing into wpan interfaces transmit queue.
This patch removes the pib lock which is now replaced by rtnl lock. The
new interface already use the rtnl lock only. Nevertheless this patch
will fix issues while using new and old interface at the same time.
This patch add support to nl802154 to dump all phy capabilities which is
inside the wpan_phy_supported struct. Also we introduce a new method to
dumping supported channels. The new method will offer a easier interface
and has lesser netlink traffic.
This patch adds capability flags for supported interface types.
This patch introduce a flag property for the wpan phy structure.
The current flag settings in ieee802154_hw are accessable in mac802154
layer only which is okay for flags which indicates MAC handling which
are done by phy. For real PHY layer settings like cca mode, transmit
power, cca energy detection level.
The difference between these flags are that the MAC handling flags are
only handled in mac802154/HardMac layer e.g. on an interface up. The phy
settings are direct netlink calls from nl802154 into the driver layer
and the nl802154 need to have a chance to check if the driver supports
this handling before sending to the next layer.
We also check now on PHY flags while dumping and setting pib attributes.
In comparing with MIB attributes the 802.15.4 gives us an default value
which we assume when a transceiver implement less functionality. In case
of MIB settings the nl802154 layer doesn't need to check on the
ieee802154_hw flags then.
This patch adds support for phy supported handling for all other already
existing handling 802.15.4 functionality. We assume now a fully 802.15.4
complaint transceiver at phy allocation. If a transceiver can support
802.15.4 default values only, then the values should be overwirtten by
values the transceiver supports. If the transceiver doesn't set the
according hardware flags, we assume the 802.15.4 defaults now which
cannot be changed.
Suggested-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de>
This patch introduce the wpan_phy_supported struct for wpan_phy. There
is currently no way to check if a transceiver can handle IEEE 802.15.4
complaint values. With this struct we can check before if the
transceiver supports these values before sending to driver layer.
Acked-by: Varka Bhadram <varkabhadram@gmail.com>
Cc: Alan Ott <alan@signal11.us>
This patch change the handling of cca energy detection level from dbm to
mbm. This prepares to handle floating point cca energy detection levels
values. The old netlink 802.15.4 will convert the dbm value to mbm for
handling backward compatibility.
This patch change the handling of transmit power level from dbm to mbm.
This prepares to handle floating point transmit power levels values. The
old netlink 802.15.4 will convert the dbm value to mbm for handling
This patch change the transmit power from s8 to s32. This prepares to store a
mbm value instead dbm inside the transmit power variable. The old
interface keep the a s8 dbm value, which should be backward compatibility
when assign s8 to s32.
This patch moves the value validation out of softmac layer. We need
to be sure now that this value is accepted by the transceiver/mac802154 or
"possible" hardmac drivers before calling rdev-ops.
This patch cleanups the -EINVAL cases by combining them in one
condition.
Four minor merge conflicts:
1) qca_spi.c renamed the local variable used for the SPI device
from spi_device to spi, meanwhile the spi_set_drvdata() call
got moved further up in the probe function.
2) Two changes were both adding new members to codel params
structure, and thus we had overlapping changes to the
initializer function.
3) 'net' was making a fix to sk_release_kernel() which is
completely removed in 'net-next'.
4) In net_namespace.c, the rtnl_net_fill() call for GET operations
had the command value fixed, meanwhile 'net-next' adjusted the
argument signature a bit.
This also matches example merge resolutions posted by Stephen
Rothwell over the past two days.
In preparation for changing how struct net is refcounted
on kernel sockets pass the knowledge that we are creating
a kernel socket from sock_create_kern through to sk_alloc.
This patch fix endian convertions for extended address and short address
handling when TP_printk is called.
Cc: Guido Günther <agx@sigxcpu.org>
This code is based on commit 6bab2e19c5ffd
("cfg80211: pass name_assign_type to rdev_add_virtual_intf()")
This will expose in sysfs whether the ifname of a IEEE-802.15.4
device is set by userspace or generated by the kernel.
We are using two types of name_assign_types
o NET_NAME_ENUM: Default interface name provided by kernel
o NET_NAME_USER: Interface name provided by user.
Enabling tracing via
echo 1 > /sys/kernel/debug/tracing/events/cfg802154/enable
enables event tracing like
iwpan dev wpan0 set pan_id 0xbeef
cat /sys/kernel/debug/tracing/trace
# tracer: nop
# entries-in-buffer/entries-written: 2/2 #P:1
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
iwpan-2663 [000] .... 170.369142: 802154_rdev_set_pan_id: phy0, wpan_dev(1), pan id: 0xbeef
iwpan-2663 [000] .... 170.369177: 802154_rdev_return_int: phy0, returned: 0
Signed-off-by: Guido Günther <agx@sigxcpu.org>
The semantic patch that fixes this problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r@
type T;
identifier f;
static T f (...) { ... }
identifier r.f;
declarer name EXPORT_SYMBOL;
-EXPORT_SYMBOL(f);
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
It's only necessary to offer the name and index, others value are
available over netlink.
Currently the wpan_phy under /sys/class/ieee802154/ is named as
"wpan-phy#", this patch will change the name to phy. This will
introduce the same naming convention like wireless.
Note: wpan-tools users will not type "wpan-phy#" anymore, just a simple
"phy#" is enough.
Currently there exists two interface types with ARPHRD_IEEE802154. These
are the 802.15.4 interfaces and 802.15.4 6LoWPAN interfaces. This is
more a bug because some userspace applications checks on this value like
wireshark. This occurs that wireshark will always try to parse a lowpan
interface as 802.15.4 frames. With ARPHRD_6LOWPAN wireshark will parse
it as IPv6 frames which is correct.
Much applications checks on this value to readout the EUI64 mac address
which should be the same for ARPHRD_6LOWPAN. BTLE 6LoWPAN and ieee802154
6LoWPAN will share now the same ARPHRD.
git://git.kernel.org/pub/scm/linux/kernel/git/bluetooth/bluetooth-next
Johan Hedberg says:
pull request: bluetooth-next 2015-03-02
Here's the first bluetooth-next pull request targeting the 4.1 kernel:
- ieee802154/6lowpan cleanups
- SCO routing to host interface support for the btmrvl driver
- AMP code cleanups
- Fixes to AMP HCI init sequence
- Refactoring of the HCI callback mechanism
- Added shutdown routine for Intel controllers in the btusb driver
- New config option to enable/disable Bluetooth debugfs information
- Fix for early data reception on L2CAP fixed channels
Please let me know if there are any issues pulling. Thanks.
After TIPC doesn't depend on iocb argument in its internal
implementations of sendmsg() and recvmsg() hooks defined in proto
structure, no any user is using iocb argument in them at all now.
Then we can drop the redundant iocb argument completely from kinds of
implementations of both sendmsg() and recvmsg() in the entire
networking stack.
Suggested-by: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Ying Xue <ying.xue@windriver.com>
6LoWPAN currently doesn't supports x-netns and works only in init_net.
With this patch, we ensure that:
- the wpan interface cannot be moved to another netns;
- the 6lowpan interface cannot be moved to another netns;
- the wpan interface is in the same netns than the 6lowpan interface;
- the 6lowpan interface is in init_net.
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Contrary to common expectations for an "int" return, these functions
return only a positive value -- if used correctly they cannot even
return 0 because the message header will necessarily be in the skb.
This makes the very common pattern of
if (genlmsg_end(...) < 0) { ... }
be a whole bunch of dead code. Many places also simply do
return nlmsg_end(...);
and the caller is expected to deal with it.
This also commonly (at least for me) causes errors, because it is very
common to write
if (my_function(...))
/* error condition */
and if my_function() does "return nlmsg_end()" this is of course wrong.
Additionally, there's not a single place in the kernel that actually
needs the message length returned, and if anyone needs it later then
it'll be very easy to just use skb->len there.
Remove this, and make the functions void. This removes a bunch of dead
code as described above. The patch adds lines because I did
- return nlmsg_end(...);
+ nlmsg_end(...);
+ return 0;
I could have preserved all the function's return values by returning
skb->len, but instead I've audited all the places calling the affected
functions and found that none cared. A few places actually compared
the return value with <= 0 in dump functionality, but that could just
be changed to < 0 with no change in behaviour, so I opted for the more
efficient version.
One instance of the error I've made numerous times now is also present
in net/phonet/pn_netlink.c in the route_dumpit() function - it didn't
check for <0 or <=0 and thus broke out of the loop every single time.
I've preserved this since it will (I think) have caused the messages to
userspace to be formatted differently with just a single message for
every SKB returned to userspace. It's possible that this isn't needed
for the tools that actually use this, but I don't even know what they
are so couldn't test that changing this behaviour would be acceptable.
Since commit ea81ac2e7050798109356150ea16e71622a5c329 ("ieee802154:
create 6lowpan sub-directory") we have a subdirectory for the ieee802154
6lowpan implementation. This commit also moves the Kconfig entry inside
of net/ieee802154/6lowpan/ and forgot to rename the Makefile entry from
obj-$(CONFIG_IEEE802154_6LOWPAN) to obj-y and handle the
obj-$(CONFIG_IEEE802154_6LOWPAN) inside the created 6lowpan directory.
This will occur that the ieee802154_6lowpan can't be build.
