path: root/net/dsa
2015-06-28dsa: fix promiscuity leak on slave dev open errorGilad Ben-Yossef
DSA master netdev promiscuity counter was not being properly decremented on slave device open error path. Signed-off-by: Gilad Ben-Yossef <gilad@benyossef.com> CC: Gilad Ben-Yossef <giladb@ezchip.com> CC: David S. Miller <davem@davemloft.net> CC: Florian Fainelli <f.fainelli@gmail.com> CC: Guenter Roeck <linux@roeck-us.net> CC: Andrew Lunn <andrew@lunn.ch> CC: Scott Feldman <sfeldma@gmail.com> Acked-by: Andrew Lunn <andrew@lunn.ch> Acked-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/phy/amd-xgbe-phy.c drivers/net/wireless/iwlwifi/Kconfig include/net/mac80211.h iwlwifi/Kconfig and mac80211.h were both trivial overlapping changes. The drivers/net/phy/amd-xgbe-phy.c file got removed in 'net-next' and the bug fix that happened on the 'net' side is already integrated into the rest of the amd-xgbe driver. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-31net: dsa: Properly propagate errors from dsa_switch_setup_oneFlorian Fainelli
While shuffling some code around, dsa_switch_setup_one() was introduced, and it was modified to return either an error code using ERR_PTR() or a NULL pointer when running out of memory or failing to setup a switch. This is a problem for its caler: dsa_switch_setup() which uses IS_ERR() and expects to find an error code, not a NULL pointer, so we still try to proceed with dsa_switch_setup() and operate on invalid memory addresses. This can be easily reproduced by having e.g: the bcm_sf2 driver built-in, but having no such switch, such that drv->setup will fail. Fix this by using PTR_ERR() consistently which is both more informative and avoids for the caller to use IS_ERR_OR_NULL(). Fixes: df197195a5248 ("net: dsa: split dsa_switch_setup into two functions") Reported-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Tested-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-13switchdev: don't use anonymous union on switchdev attr/obj structsScott Feldman
Older gcc versions (e.g. gcc version 4.4.6) don't like anonymous unions which was causing build issues on the newly added switchdev attr/obj structs. Fix this by using named union on structs. Signed-off-by: Scott Feldman <sfeldma@gmail.com> Reported-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-12switchdev: convert STP update to switchdev attr setScott Feldman
STP update is just a settable port attribute, so convert switchdev_port_stp_update to an attr set. For DSA, the prepare phase is skipped and STP updates are only done in the commit phase. This is because currently the DSA drivers don't need to allocate any memory for STP updates and the STP update will not fail to HW (unless something horrible goes wrong on the MDIO bus, in which case the prepare phase wouldn't have been able to predict anyway). Signed-off-by: Scott Feldman <sfeldma@gmail.com> Acked-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-12switchdev: convert parent_id_get to switchdev attr getScott Feldman
Switch ID is just a gettable port attribute. Convert switchdev op switchdev_parent_id_get to a switchdev attr. Note: for sysfs and netlink interfaces, SWITCHDEV_ATTR_PORT_PARENT_ID is called with SWITCHDEV_F_NO_RECUSE to limit switch ID user-visiblity to only port netdevs. So when a port is stacked under bond/bridge, the user can only query switch id via the switch ports, but not via the upper devices Signed-off-by: Scott Feldman <sfeldma@gmail.com> Acked-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-12switchdev: s/swdev_/switchdev_/Jiri Pirko
Turned out that "switchdev" sticks. So just unify all related terms to use this prefix. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: Scott Feldman <sfeldma@gmail.com> Acked-by: Roopa Prabhu <roopa@cumulusnetworks.com> Acked-by: Andy Gospodarek <gospo@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-09net: dsa: Add lockdep class to tx queues to avoid lockdep splatAndrew Lunn
DSA stacks an Ethernet device on top of an Ethernet device. This can cause false positive lockdep splats for the transmit queue: Acked-by: Florian Fainelli <f.fainelli@gmail.com> ============================================= [ INFO: possible recursive locking detected ] 4.0.0-rc7-01838-g70621a215fc7 #386 Not tainted --------------------------------------------- kworker/0:0/4 is trying to acquire lock: (_xmit_ETHER#2){+.-...}, at: [<c040e95c>] sch_direct_xmit+0xa8/0x1fc but task is already holding lock: (_xmit_ETHER#2){+.-...}, at: [<c03f4208>] __dev_queue_xmit+0x4d4/0x56c other info that might help us debug this: Possible unsafe locking scenario: CPU0 ---- lock(_xmit_ETHER#2); lock(_xmit_ETHER#2); To avoid this, walk the tq queues of the dsa slaves and set a lockdep class. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-29net: dsa: Fix scope of eeprom-length propertyGuenter Roeck
eeprom-length is a switch property, not a dsa property, and thus needs to be attached to the switch node, not to the dsa node. Reported-by: Andrew Lunn <andrew@lunn.ch> Fixes: 6793abb4e849 ("net: dsa: Add support for switch EEPROM access") Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-17net: dsa: use DEVICE_ATTR_RW to declare temp1_maxVivien Didelot
Since commit da4759c (sysfs: Use only return value from is_visible for the file mode), it is possible to reduce the permissions of a file. So declare temp1_max with the DEVICE_ATTR_RW macro and remove the write permission in dsa_hwmon_attrs_visible if set_temp_limit isn't provided. Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/mellanox/mlx4/cmd.c net/core/fib_rules.c net/ipv4/fib_frontend.c The fib_rules.c and fib_frontend.c conflicts were locking adjustments in 'net' overlapping addition and removal of code in 'net-next'. The mlx4 conflict was a bug fix in 'net' happening in the same place a constant was being replaced with a more suitable macro. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-06net: dsa: fix filling routing table from OF descriptionPavel Nakonechny
According to description in 'include/net/dsa.h', in cascade switches configurations where there are more than one interconnected devices, 'rtable' array in 'dsa_chip_data' structure is used to indicate which port on this switch should be used to send packets to that are destined for corresponding switch. However, dsa_of_setup_routing_table() fills 'rtable' with port numbers of the _target_ switch, but not current one. This commit removes redundant devicetree parsing and adds needed port number as a function argument. So dsa_of_setup_routing_table() now just looks for target switch number by parsing parent of 'link' device node. To remove possible misunderstandings with the way of determining target switch number, a corresponding comment was added to the source code and to the DSA device tree bindings documentation file. This was tested on a custom board with two Marvell 88E6095 switches with following corresponding routing tables: { -1, 10 } and { 8, -1 }. Signed-off-by: Pavel Nakonechny <pavel.nakonechny@skitlab.ru> Reviewed-by: Andrew Lunn <andrew@lunn.ch> Reviewed-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-02dsa: implement ndo_get_iflinkNicolas Dichtel
Don't use dev->iflink anymore. CC: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-29net: dsa: Add basic framework to support ndo_fdb functionsGuenter Roeck
Provide callbacks for ndo_fdb_add, ndo_fdb_del, and ndo_fdb_dump. Reviewed-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-25net: dsa: Handle non-bridge master changeGuenter Roeck
Master change notifications may occur other than when joining or leaving a bridge, for example when being added to or removed from a bond or Open vSwitch. In that case, do nothing instead of asking the switch driver to remove a port from a bridge that it didn't join. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-20net: dsa: make NET_DSA manually selectable from the configMathieu Olivari
Change bd76a116707bd2381da36cf7c3183df11293f1d6 made all DSA drivers depend on NET_DSA rather than selecting them. However, as the only way to select this option was to actually select a driver, it made DSA impossible to enable at all. This patch adds an explicit entry which the user will have to enable prior selecting a driver. Signed-off-by: Mathieu Olivari <mathieu@codeaurora.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-16dsa: change "select" to "depends on" for NET_SWITCHDEV and for NET_DSAJiri Pirko
This would fix randconfig compile error: net/built-in.o: In function `netdev_switch_fib_ipv4_abort': (.text+0xf7811): undefined reference to `fib_flush_external' Also it fixes following warnings: warning: (NET_DSA) selects NET_SWITCHDEV which has unmet direct dependencies (NET && INET) warning: (NET_DSA_MV88E6060 && NET_DSA_MV88E6131 && NET_DSA_MV88E6123_61_65 && NET_DSA_MV88E6171 && NET_DSA_MV88E6352 && NET_DSA_BCM_SF2) selects NET_DSA which has unmet direct dependencies (NET && HAVE_NET_DSA && NET_SWITCHDEV) Reported-by: Randy Dunlap <rdunlap@infradead.org> Suggested-by: Alexei Starovoitov <alexei.starovoitov@gmail.com> Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-16switchdev: use new swdev opsScott Feldman
Move swdev wrappers over to new swdev ops (from previous ndo ops). No functional changes to the implementation. Signed-off-by: Scott Feldman <sfeldma@gmail.com> rocker: move to new swdev ops Signed-off-by: Scott Feldman <sfeldma@gmail.com> dsa: move to new swdev ops Signed-off-by: Scott Feldman <sfeldma@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-14net: dsa: do not use slave MII bus for fixed PHYsFlorian Fainelli
Commit cd28a1a9baee7 ("net: dsa: fully divert PHY reads/writes if requested") introduced a check for particular PHYs that need to be accessed using the slave MII bus created by DSA, but this check was too inclusive. This would prevent fixed PHYs from being successfully registered because those should not go through the slave MII bus created by DSA. Make sure we check that the PHY is not a fixed PHY to prevent that from happening. Fixes: cd28a1a9baee7 ("net: dsa: fully divert PHY reads/writes if requested") Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-11net: dsa: fully divert PHY reads/writes if requestedFlorian Fainelli
In case a PHY is found via Device Tree, and is also flagged by the switch driver as needing indirect reads/writes using the switch driver implemented MDIO bus, make sure that we bind this PHY to the slave MII bus in order for this to happen. Without this, we would succeed in having the PHY driver probe()'s function to use slave MII bus read/write functions, because this is done during dsa_slave_mii_init(), but past that point, the PHY driver would not go through these diverted reads and writes. Fixes: 0d8bcdd383b88 ("net: dsa: allow for more complex PHY setups") Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-11net: dsa: move PHY setup on DSA MII bus to its own functionFlorian Fainelli
In preparation for dealing with indirect reads and writes towards certain PHY devices, move the code which deals with binding the PHY device to the slave MII bus created by DSA to its own function: dsa_slave_phy_connect(). Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-09net: dsa: utilize of_find_net_device_by_nodeFlorian Fainelli
Using of_find_device_by_node() restricts the search to platform_device that match the specified device_node pointer. This is not even remotely true for network devices backed by a pci_device for instance. of_find_net_device_by_node() allows us to do a more thorough lookup to find the struct net_device corresponding to a particular device_node pointer. For symetry with the non-OF code path, we hold the net_device pointer in dsa_probe() just like what dev_to_net_dev() does when we call this function. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-06net: dsa: extract dsa switch tree setup and removalFlorian Fainelli
Extract the core logic that setups a 'struct dsa_switch_tree' and removes it, update dsa_probe() and dsa_remove() to use the two helper functions. This will be useful to allow for other callers to setup this structure differently. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-06net: dsa: let switches specify their tagging protocolFlorian Fainelli
In order to support the new DSA device driver model, a dsa_switch should be able to advertise the type of tagging protocol supported by the underlying switch device. This also removes constraints on how tagging can be stacked to each other. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-06net: dsa: split dsa_switch_setup into two functionsFlorian Fainelli
Split the part of dsa_switch_setup() which is responsible for allocating and initializing a 'struct dsa_switch' and the part which is doing a given switch device setup and slave network device creation. This is a preliminary change to allow a separate caller of dsa_switch_setup_one() which may have externally initialized the dsa_switch structure, outside of dsa_switch_setup(). Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-06net: dsa: allow deferred probingFlorian Fainelli
In preparation for allowing a different model to register DSA switches, update dsa_of_probe() and dsa_probe() to return -EPROBE_DEFER where appropriate. Failure to find a phandle or Device Tree property is still fatal, but looking up the internal device structure associated with a Device Tree node is something that might need to be delayed based on driver probe ordering. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-06net: dsa: update dsa_of_{probe, remove} to use a device pointerFlorian Fainelli
In preparation for allowing a different mechanism to register DSA switch devices and driver, update dsa_of_probe and dsa_of_remove to take a struct device pointer since neither of these two functions uses the struct platform_device pointer. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-25net: dsa: Introduce dsa_is_port_initializedGuenter Roeck
To avoid race conditions when using the ds->ports[] array, we need to check if the accessed port has been initialized. Introduce and use helper function dsa_is_port_initialized for that purpose and use it where needed. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-25net: dsa: integrate with SWITCHDEV for HW bridgingFlorian Fainelli
In order to support bridging offloads in DSA switch drivers, select NET_SWITCHDEV to get access to the port_stp_update and parent_get_id NDOs that we are required to implement. To facilitate the integratation at the DSA driver level, we implement 3 types of operations: - port_join_bridge - port_leave_bridge - port_stp_update DSA will resolve which switch ports that are currently bridge port members as some Switch hardware/drivers need to know about that to limit the register programming to just the relevant registers (especially for slow MDIO buses). We also take care of setting the correct STP state when slave network devices are brought up/down while being bridge members. Finally, when a port is leaving the bridge, we make sure we set in BR_STATE_FORWARDING state, otherwise the bridge layer would leave it disabled as a result of having left the bridge. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Tested-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-25net: dsa: Ensure that port array elements are initialized before being usedGuenter Roeck
A network device notifier can be called for one or more of the created slave devices before all slave devices have been registered. This can result in a mismatch between ds->phys_port_mask and the registered devices by the time the call is made, and it can result in a slave device being added to a bridge before its entry in ds->ports[] has been initialized. Rework the initialization code to initialize entries in ds->ports[] in dsa_slave_create. With this change, dsa_slave_create no longer needs to return slave_dev but can return an error code instead. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-17net: dsa: Set valid phy interface typeGuenter Roeck
If the phy interface mode is not found in devicetree, or if devicetree is not configured, of_get_phy_mode returns -ENODEV. The current code sets the phy interface mode to the return value from of_get_phy_mode without checking if it is valid. This invalid phy interface mode is passed as parameter to of_phy_connect or to phy_connect_direct. This sets the phy interface mode to the invalid value, which in turn causes problems for any code using phydev->interface. Fixes: b31f65fb4383 ("net: dsa: slave: Fix autoneg for phys on switch MDIO bus") Fixes: 0d8bcdd383b8 ("net: dsa: allow for more complex PHY setups") Cc: Florian Fainelli <f.fainelli@gmail.com> Cc: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-09net: dsa: Remove redundant phy_attach()Andrew Lunn
dsa_slave_phy_setup() finds the phy for the port via device tree and using of_phy_connect(), or it uses the fall back of taking a phy from the switch internal mdio bus and calling phy_connect_direct(). Either way, if a phy is found, phy_attach_direct() is called to attach the phy to the slave device. In dsa_slave_create(), a second call to phy_attach() is made. This results in the warning "PHY already attached". Remove this second, redundant attaching of the phy. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Acked-by: Florian Fainelli <f.fainelli@gmail.com> Tested-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-07dsa: correctly determine the number of switches in a systemTobias Waldekranz
The number of connected switches was sourced from the number of children to the DSA node, change it to the number of available children, skipping any disabled switches. Fixes: 5e95329b701c4 ("dsa: add device tree bindings to register DSA switches") Signed-off-by: Tobias Waldekranz <tobias@waldekranz.com> Acked-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-25net: dsa: set slave MII bus PHY maskVivien Didelot
When registering a mdio bus, Linux assumes than every port has a PHY and tries to scan it. If a switch port has no PHY registered, DSA will fail to register the slave MII bus. To fix this, set the slave MII bus PHY mask to the switch PHYs mask. As an example, if we use a Marvell MV88E6352 (which is a 7-port switch with no registered PHYs for port 5 and port 6), with the following declared names: static struct dsa_chip_data switch_cdata = { [...] .port_names[0] = "sw0", .port_names[1] = "sw1", .port_names[2] = "sw2", .port_names[3] = "sw3", .port_names[4] = "sw4", .port_names[5] = "cpu", }; DSA will fail to create the switch instance. With the PHY mask set for the slave MII bus, only the PHY for ports 0-4 will be scanned and the instance will be successfully created. Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com> Tested-by: Florian Fainelli <f.fainelli@gmail.com> Acked-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-14Merge tag 'driver-core-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core update from Greg KH: "Here's the set of driver core patches for 3.19-rc1. They are dominated by the removal of the .owner field in platform drivers. They touch a lot of files, but they are "simple" changes, just removing a line in a structure. Other than that, a few minor driver core and debugfs changes. There are some ath9k patches coming in through this tree that have been acked by the wireless maintainers as they relied on the debugfs changes. Everything has been in linux-next for a while" * tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits) Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries" fs: debugfs: add forward declaration for struct device type firmware class: Deletion of an unnecessary check before the function call "vunmap" firmware loader: fix hung task warning dump devcoredump: provide a one-way disable function device: Add dev_<level>_once variants ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries ath: use seq_file api for ath9k debugfs files debugfs: add helper function to create device related seq_file drivers/base: cacheinfo: remove noisy error boot message Revert "core: platform: add warning if driver has no owner" drivers: base: support cpu cache information interface to userspace via sysfs drivers: base: add cpu_device_create to support per-cpu devices topology: replace custom attribute macros with standard DEVICE_ATTR* cpumask: factor out show_cpumap into separate helper function driver core: Fix unbalanced device reference in drivers_probe driver core: fix race with userland in device_add() sysfs/kernfs: make read requests on pre-alloc files use the buffer. sysfs/kernfs: allow attributes to request write buffer be pre-allocated. fs: sysfs: return EGBIG on write if offset is larger than file size ...
2014-12-11net: dsa: propagate error code from dsa_slave_phy_setupFlorian Fainelli
In case we cannot attach to our slave netdevice PHY, error out and propagate that error up to the caller: dsa_slave_create(). Fixes: 0d8bcdd383b8 ("net: dsa: allow for more complex PHY setups") Signed-off-by: Andrey Volkov <andrey.volkov@nexvision.fr> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-11net: dsa: handle non-existing PHYs on switch internal busFlorian Fainelli
In case there is no PHY at the designated address on the internal switch, we would basically de-reference a null pointer here: dsa_slave_phy_setup(...) { p->phy = ds->slave_mii_bus->phy_map[p->port]; phy_connect_direct(slave_dev, p->phy, dsa_slave_adjust_link, ^------ This can be triggered when the platform configuration (platform_data or Device Tree) indicates there should be a PHY device at this address, but the HW is non-responsive, such that we cannot attach a PHY device at this specific location. Fix this by checking the return value prior to calling phy_connect_direct(). CC: Andrew Lunn <andrew@lunn.ch> Fixes: b31f65fb4383 ("net: dsa: slave: Fix autoneg for phys on switch MDIO bus") Reported-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Andrey Volkov <andrey.volkov@nexvision.fr> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-16net: dsa: replace count*size kzalloc by kcallocFabian Frederick
kcalloc manages count*sizeof overflow. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-16net: dsa: replace count*size kmalloc by kmalloc_arrayFabian Frederick
kmalloc_array manages count*sizeof overflow. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-11dsa: Use netdev_<level> instead of printkJoe Perches
Neaten and standardize the logging output. Other miscellanea: o Use pr_notice_once instead of a guard flag. o Convert existing pr_<level> uses too. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2014-11-06net: dsa: slave: Fix autoneg for phys on switch MDIO busAndrew Lunn
When the ports phys are connected to the switches internal MDIO bus, we need to connect the phy to the slave netdev, otherwise auto-negotiation etc, does not work. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-03Merge branch 'platform/remove_owner' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux into driver-core-next Remove all .owner fields from platform drivers
2014-11-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/phy/marvell.c Simple overlapping changes in drivers/net/phy/marvell.c Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-30net: dsa: Add support for reading switch registers with ethtoolGuenter Roeck
Add support for reading switch registers with 'ethtool -d'. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-30net: dsa: Add support for switch EEPROM accessGuenter Roeck
On some chips it is possible to access the switch eeprom. Add infrastructure support for it. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-30net: dsa: Add support for reporting switch chip temperaturesGuenter Roeck
Some switches provide chip temperature data. Add support for reporting it through the hwmon subsystem. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-30net: dsa: Don't set skb->protocol on outgoing tagged packetsGuenter Roeck
Setting skb->protocol to a private protocol type may result in warning messages such as e1000e 0000:00:19.0 em1: checksum_partial proto=dada! This happens if the L3 protocol is IP or IPv6 and skb->ip_summed is set to CHECKSUM_PARTIAL. Looking through the code, it appears that changing skb->protocol for transmitted packets is not necessary and may actually be harmful. For example, it prevents purposely unmodified (from a DSA perspective) network drivers from properly setting up their transmit checksum offload pointers since they inspect skb->protocol to set up the IPv4 header or IPv6 header pointers. So don't unnecessarily change the protocol field. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-28net: dsa: Error out on tagging protocol mismatchesAndrew Lunn
If there is a mismatch between enabled tagging protocols and the protocol the switch supports, error out, rather than continue with a situation which is unlikely to work. Signed-off-by: Andrew Lunn <andrew@lunn.ch> cc: alexander.h.duyck@intel.com Acked-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-20net: dsa: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
