path: root/net/decnet/sysctl_net_decnet.c
2010-11-10net: avoid limits overflowEric Dumazet
Robin Holt tried to boot a 16TB machine and found some limits were reached : sysctl_tcp_mem[2], sysctl_udp_mem[2] We can switch infrastructure to use long "instead" of "int", now atomic_long_t primitives are available for free. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Reported-by: Robin Holt <holt@sgi.com> Reviewed-by: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-12sysctl net: Remove unused binary sysctl codeEric W. Biederman
Now that sys_sysctl is a compatiblity wrapper around /proc/sys all sysctl strategy routines, and all ctl_name and strategy entries in the sysctl tables are unused, and can be revmoed. In addition neigh_sysctl_register has been modified to no longer take a strategy argument and it's callers have been modified not to pass one. Cc: "David Miller" <davem@davemloft.net> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: netdev@vger.kernel.org Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-09-24sysctl: remove "struct file *" argument of ->proc_handlerAlexey Dobriyan
It's unused. It isn't needed -- read or write flag is already passed and sysctl shouldn't care about the rest. It _was_ used in two places at arch/frv for some reason. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: David Howells <dhowells@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-26decnet: fix sparse warnings: symbol shadows an earlier oneHannes Eder
Impact: Remove redundant variable declarations, resp. rename inner scope variable. Fix this sparse warnings: net/decnet/af_decnet.c:1252:40: warning: symbol 'skb' shadows an earlier one net/decnet/af_decnet.c:1223:24: originally declared here net/decnet/af_decnet.c:1582:29: warning: symbol 'val' shadows an earlier one net/decnet/af_decnet.c:1527:22: originally declared here net/decnet/dn_dev.c:687:21: warning: symbol 'err' shadows an earlier one net/decnet/dn_dev.c:670:13: originally declared here net/decnet/sysctl_net_decnet.c:182:21: warning: symbol 'len' shadows an earlier one net/decnet/sysctl_net_decnet.c:173:16: originally declared here Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-27decnet: remove private wrappers of endian helpersHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Reviewed-by: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03net: '&' reduxAlexey Dobriyan
I want to compile out proc_* and sysctl_* handlers totally and stub them to NULL depending on config options, however usage of & will prevent this, since taking adress of NULL pointer will break compilation. So, drop & in front of every ->proc_handler and every ->strategy handler, it was never needed in fact. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-16sysctl: simplify ->strategyAlexey Dobriyan
name and nlen parameters passed to ->strategy hook are unused, remove them. In general ->strategy hook should know what it's doing, and don't do something tricky for which, say, pointer to original userspace array may be needed (name). Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> [ networking bits ] Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: Matt Mackall <mpm@selenic.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-28[DECNET]: Switch to using ctl_paths.Pavel Emelyanov
The decnet includes two places to patch. The first one is the net/decnet table itself, and it is patched just like other subsystems in the first patch in this series. The second place is a bit more complex - it is the net/decnet/conf/xxx entries,. similar to those in ipv4/devinet.c and ipv6/addrconf.c. This code is made similar to those in ipv[46]. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make the device list and device lookups per namespace.Eric W. Biederman
This patch makes most of the generic device layer network namespace safe. This patch makes dev_base_head a network namespace variable, and then it picks up a few associated variables. The functions: dev_getbyhwaddr dev_getfirsthwbytype dev_get_by_flags dev_get_by_name __dev_get_by_name dev_get_by_index __dev_get_by_index dev_ioctl dev_ethtool dev_load wireless_process_ioctl were modified to take a network namespace argument, and deal with it. vlan_ioctl_set and brioctl_set were modified so their hooks will receive a network namespace argument. So basically anthing in the core of the network stack that was affected to by the change of dev_base was modified to handle multiple network namespaces. The rest of the network stack was simply modified to explicitly use &init_net the initial network namespace. This can be fixed when those components of the network stack are modified to handle multiple network namespaces. For now the ifindex generator is left global. Fundametally ifindex numbers are per namespace, or else we will have corner case problems with migration when we get that far. At the same time there are assumptions in the network stack that the ifindex of a network device won't change. Making the ifindex number global seems a good compromise until the network stack can cope with ifindex changes when you change namespaces, and the like. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-14[PATCH] sysctl: remove insert_at_head from register_sysctlEric W. Biederman
The semantic effect of insert_at_head is that it would allow new registered sysctl entries to override existing sysctl entries of the same name. Which is pain for caching and the proc interface never implemented. I have done an audit and discovered that none of the current users of register_sysctl care as (excpet for directories) they do not register duplicate sysctl entries. So this patch simply removes the support for overriding existing entries in the sys_sysctl interface since no one uses it or cares and it makes future enhancments harder. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Howells <dhowells@redhat.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Andi Kleen <ak@muc.de> Cc: Jens Axboe <axboe@kernel.dk> Cc: Corey Minyard <minyard@acm.org> Cc: Neil Brown <neilb@suse.de> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Jan Kara <jack@ucw.cz> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: David Chinner <dgc@sgi.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: decnet: remove unnecessary insert_at_head flagEric W. Biederman
The sysctl numbers used are unique so setting the insert_at_head flag does not succeed in overriding any sysctls, and is just confusing because it doesn't. Clear the flag. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Patrick Caulfield <patrick@tykepenguin.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-10[NET] DECNET: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-10[PATCH] sysctl: remove unused "context" paramAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Andi Kleen <ak@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: David Howells <dhowells@redhat.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-20[DECnet]: Endian annotation and fixes for DECnet.Steven Whitehouse
The typedef for dn_address has been removed in favour of using __le16 or __u16 directly as appropriate. All the DECnet header files are updated accordingly. The byte ordering of dn_eth2dn() and dn_dn2eth() are both changed since just about all their callers wanted network order rather than host order, so the conversion is now done in the functions themselves. Several missed endianess conversions have been picked up during the conversion process. The nh_gw field in struct dn_fib_info has been changed from a 32 bit field to 16 bits as it ought to be. One or two cases of using htons rather than dn_htons in the routing code have been found and fixed. There are still a few warnings to fix, but this patch deals with the important cases. Signed-off-by: Steven Whitehouse <steve@chygwyn.com> Signed-off-by: Patrick Caulfield <patrick@tykepenguin.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-12-05[DECNET]: add memory buffer settings Steven Whitehouse
The patch (originally from Steve) simply adds memory buffer settings to DECnet similar to those in TCP. Signed-off-by: Patrick Caulfield <patrick@tykepenguin.com> Signed-off-by: David S. Miller <davem@davemloft.net>
