path: root/net/core/pktgen.c
2008-05-20pktgen: make sure that pktgen_thread_worker has been executedDenis V. Lunev
The following courruption can happen during pktgen stop: list_del corruption. prev->next should be ffff81007e8a5e70, but was 6b6b6b6b6b6b6b6b kernel BUG at lib/list_debug.c:67! :pktgen:pktgen_thread_worker+0x374/0x10b0 ? autoremove_wake_function+0x0/0x40 ? _spin_unlock_irqrestore+0x42/0x80 ? :pktgen:pktgen_thread_worker+0x0/0x10b0 kthread+0x4d/0x80 child_rip+0xa/0x12 ? restore_args+0x0/0x30 ? kthread+0x0/0x80 ? child_rip+0x0/0x12 RIP list_del+0x48/0x70 The problem is that pktgen_thread_worker can not be executed if kthread_stop has been called too early. Insert a completion on the normal initialization path to make sure that pktgen_thread_worker will gain the control for sure. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Alexey Dobriyan <adobriyan@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-02net: assign PDE->data before gluing PDE into /proc treeDenis V. Lunev
Simply replace proc_create and further data assigned with proc_create_data. Additionally, there is no need to assign NULL to PDE->data after creation, /proc generic has already done this for us. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26[NET] NETNS: Omit net_device->nd_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-net_device inlines: dev_net(), dev_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-02-28[PKTGEN]: Use proc_create() to setup ->proc_fops firstWang Chen
Use proc_create() to make sure that ->proc_fops be setup before gluing PDE to main tree. Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[PKTGEN]: pktgen should not print info that it is spinningJesse Brandeburg
when using pktgen to send delay packets the module prints repeatedly to the kernel log: sleeping for X sleeping for X ... This is probably just a debugging item left in and should not be enabled for regular use of the module. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[PKTGEN]: Remove an unused definition in pktgen.c.Rami Rosen
- Remove an unused definition (LAT_BUCKETS_MAX) in net/core/pktgen.c. - Remove the corresponding comment. - The LAT_BUCKETS_MAX seems to have to do with a patch from a long time ago which was not applied (Ben Greear), which dealt with latency counters. See, for example : http://oss.sgi.com/archives/netdev/2002-09/msg00184.html Signed-off-by: Rami Rosen <ramirose@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPV4]: Enable use of 240/4 address space.Jan Engelhardt
This short patch modifies the IPv4 networking to enable use of the 240.0.0.0/4 (aka "class-E") address space as propsed in the internet draft draft-fuller-240space-00.txt. Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[PKTGEN]: uninline getCurUsIlpo Järvinen
net/core/pktgen.c: pktgen_stop_device | -50 pktgen_run | -105 pktgen_if_show | -37 pktgen_thread_worker | -702 4 functions changed, 894 bytes removed, diff: -894 net/core/pktgen.c: getCurUs | +36 1 function changed, 36 bytes added, diff: +36 net/core/pktgen.o: 5 functions changed, 36 bytes added, 894 bytes removed, diff: -858 Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[PKTGEN]: Kill dead static inlinesIlpo Järvinen
2008-01-28[IPV4] net/core: Use ipv4_is_<type>Joe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-19[PKTGEN]: Fix double unlock of xfrm_state->lockPavel Emelyanov
The pktgen_output_ipsec() function can unlock this lock twice due to merged error and plain paths. Remove one of the calls to spin_unlock. Other possible solution would be to place "return 0" right after the first unlock, but at this place the err is known to be 0, so these solutions are the same except for this one makes the code shorter. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-22[NET]: Hide the queue_mapping field inside netif_subqueue_stoppedPavel Emelyanov
Many places get the queue_mapping field from skb to pass it to the netif_subqueue_stopped() which will be 0 in any case. Make the helper that works with sk_buff Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-22[NET]: Use the skb_set_queue_mapping where appropriatePavel Emelyanov
There's already such a helper to initialize this field. Use it. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-19Convert files to UTF-8 and some cleanupsJan Engelhardt
* Convert files to UTF-8. * Also correct some people's names (one example is Eißfeldt, which was found in a source file. Given that the author used an ß at all in a source file indicates that the real name has in fact a 'ß' and not an 'ss', which is commonly used as a substitute for 'ß' when limited to 7bit.) * Correct town names (Goettingen -> Göttingen) * Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313) Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Use helpers to obtain task pid in printksPavel Emelyanov
The task_struct->pid member is going to be deprecated, so start using the helpers (task_pid_nr/task_pid_vnr/task_pid_nr_ns) in the kernel. The first thing to start with is the pid, printed to dmesg - in this case we may safely use task_pid_nr(). Besides, printks produce more (much more) than a half of all the explicit pid usage. [akpm@linux-foundation.org: git-drm went and changed lots of stuff] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19remove asm/bitops.h includesJiri Slaby
remove asm/bitops.h includes including asm/bitops directly may cause compile errors. don't include it and include linux/bitops instead. next patch will deny including asm header directly. Cc: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17[IPSEC]: Rename mode to outer_mode and add inner_modeHerbert Xu
This patch adds a new field to xfrm states called inner_mode. The existing mode object is renamed to outer_mode. This is the first part of an attempt to fix inter-family transforms. As it is we always use the outer family when determining which mode to use. As a result we may end up shoving IPv4 packets into netfilter6 and vice versa. What we really want is to use the inner family for the first part of outbound processing and the outer family for the second part. For inbound processing we'd use the opposite pairing. I've also added a check to prevent silly combinations such as transport mode with inter-family transforms. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: sparse warning fixesStephen Hemminger
Fix a bunch of sparse warnings. Mostly about 0 used as NULL pointer, and shadowed variable declarations. One notable case was that hash size should have been unsigned. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make the device list and device lookups per namespace.Eric W. Biederman
This patch makes most of the generic device layer network namespace safe. This patch makes dev_base_head a network namespace variable, and then it picks up a few associated variables. The functions: dev_getbyhwaddr dev_getfirsthwbytype dev_get_by_flags dev_get_by_name __dev_get_by_name dev_get_by_index __dev_get_by_index dev_ioctl dev_ethtool dev_load wireless_process_ioctl were modified to take a network namespace argument, and deal with it. vlan_ioctl_set and brioctl_set were modified so their hooks will receive a network namespace argument. So basically anthing in the core of the network stack that was affected to by the change of dev_base was modified to handle multiple network namespaces. The rest of the network stack was simply modified to explicitly use &init_net the initial network namespace. This can be fixed when those components of the network stack are modified to handle multiple network namespaces. For now the ifindex generator is left global. Fundametally ifindex numbers are per namespace, or else we will have corner case problems with migration when we get that far. At the same time there are assumptions in the network stack that the ifindex of a network device won't change. Making the ifindex number global seems a good compromise until the network stack can cope with ifindex changes when you change namespaces, and the like. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make device event notification network namespace safeEric W. Biederman
Every user of the network device notifiers is either a protocol stack or a pseudo device. If a protocol stack that does not have support for multiple network namespaces receives an event for a device that is not in the initial network namespace it quite possibly can get confused and do the wrong thing. To avoid problems until all of the protocol stacks are converted this patch modifies all netdev event handlers to ignore events on devices that are not in the initial network namespace. As the rest of the code is made network namespace aware these checks can be removed. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make /proc/net per network namespaceEric W. Biederman
This patch makes /proc/net per network namespace. It modifies the global variables proc_net and proc_net_stat to be per network namespace. The proc_net file helpers are modified to take a network namespace argument, and all of their callers are fixed to pass &init_net for that argument. This ensures that all of the /proc/net files are only visible and usable in the initial network namespace until the code behind them has been updated to be handle multiple network namespaces. Making /proc/net per namespace is necessary as at least some files in /proc/net depend upon the set of network devices which is per network namespace, and even more files in /proc/net have contents that are relevant to a single network namespace. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[PKTGEN]: Remove softirq scheduling.Robert Olsson
It's not a job for pktgen. Signed-off-by: Robert Olsson <robert.olsson@its.uu.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[PKTGEN]: Multiqueue support.Robert Olsson
Below some pktgen support to send into different TX queues. This can of course be feed into input queues on other machines Signed-off-by: Robert Olsson <robert.olsson@its.uu.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-16[PKTGEN]: srcmac fixAdit Ranadive
From: Adit Ranadive <adit.262@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-08-30[PKTGEN]: Remove write-only variable.Pavel Emelyanov
The pktgen_thread.pid is set to current->pid and is never used after this. So remove this at all. Found during isolating the explicit pid/tgid usage. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-08-28[PKTGEN]: Fix multiqueue oops.Robert Olsson
Initially pkt_dev can be NULL this causes netif_subqueue_stopped to oops. The patch below should cure it. But maybe the pktgen TX logic should be reworked to better support the new multiqueue support. Signed-off-by: Robert Olsson <robert.olsson@its.uu.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-31[PKTGEN]: make get_ipsec_sa() static and non-inlineAdrian Bunk
Non-static inline code usually doesn't makes sense. In this case making is static and non-inline is the correct solution. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-31[PKTGEN]: Add missing KERN_* tags to printk()s.David S. Miller
2007-07-17Freezer: make kernel threads nonfreezable by defaultRafael J. Wysocki
Currently, the freezer treats all tasks as freezable, except for the kernel threads that explicitly set the PF_NOFREEZE flag for themselves. This approach is problematic, since it requires every kernel thread to either set PF_NOFREEZE explicitly, or call try_to_freeze(), even if it doesn't care for the freezing of tasks at all. It seems better to only require the kernel threads that want to or need to be frozen to use some freezer-related code and to remove any freezer-related code from the other (nonfreezable) kernel threads, which is done in this patch. The patch causes all kernel threads to be nonfreezable by default (ie. to have PF_NOFREEZE set by default) and introduces the set_freezable() function that should be called by the freezable kernel threads in order to unset PF_NOFREEZE. It also makes all of the currently freezable kernel threads call set_freezable(), so it shouldn't cause any (intentional) change of behaviour to appear. Additionally, it updates documentation to describe the freezing of tasks more accurately. [akpm@linux-foundation.org: build fixes] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Nigel Cunningham <nigel@nigel.suspend2.net> Cc: Pavel Machek <pavel@ucw.cz> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10[PKTGEN]: IPSEC supportJamal Hadi Salim
Added transport mode ESP support for starters. I will send more of these modes and types once i have resolved the tunnel mode isses. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: Robert Olsson <robert.olsson@its.uu.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[PKTGEN]: Introduce sequential flowsJamal Hadi Salim
By default all flows in pktgen are randomly selected. This patch introduces ability to have all defined flows to be sent sequentially. Robert defined randomness to be the default behavior. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: Robert Olsson <robert.olsson@its.uu.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[PKTGEN]: Centralize packet overhead trackingJamal Hadi Salim
Track the extra packet overhead for VLAN tags, MPLS, IPSEC etc Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: Robert Olsson <robert.olsson@its.uu.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[CORE] Stack changes to add multiqueue hardware support APIPeter P Waskiewicz Jr
Add the multiqueue hardware device support API to the core network stack. Allow drivers to allocate multiple queues and manage them at the netdev level if they choose to do so. Added a new field to sk_buff, namely queue_mapping, for drivers to know which tx_ring to select based on OS classification of the flow. Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: cleanup extra semicolonsStephen Hemminger
Spring cleaning time... There seems to be a lot of places in the network code that have extra bogus semicolons after conditionals. Most commonly is a bogus semicolon after: switch() { } Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Convert skb->tail to sk_buff_data_tArnaldo Carvalho de Melo
So that it is also an offset from skb->head, reduces its size from 8 to 4 bytes on 64bit architectures, allowing us to combine the 4 bytes hole left by the layer headers conversion, reducing struct sk_buff size to 256 bytes, i.e. 4 64byte cachelines, and since the sk_buff slab cache is SLAB_HWCACHE_ALIGN... :-) Many calculations that previously required that skb->{transport,network, mac}_header be first converted to a pointer now can be done directly, being meaningful as offsets or pointers. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: unions of just one member don't get anything done, kill themArnaldo Carvalho de Melo
Renaming skb->h to skb->transport_header, skb->nh to skb->network_header and skb->mac to skb->mac_header, to match the names of the associated helpers (skb[_[re]set]_{transport,network,mac}_header). Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Some more layer header conversionsArnaldo Carvalho de Melo
2007-04-25[SK_BUFF]: Introduce udp_hdr(), remove skb->h.uhArnaldo Carvalho de Melo
2007-04-25[SK_BUFF]: Introduce ipv6_hdr(), remove skb->nh.ipv6hArnaldo Carvalho de Melo
Now the skb->nh union has just one member, .raw, i.e. it is just like the skb->mac union, strange, no? I'm just leaving it like that till the transport layer is done with, when we'll rename skb->mac.raw to skb->mac_header (or ->mac_header_offset?), ditto for ->{h,nh}. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce ip_hdr(), remove skb->nh.iphArnaldo Carvalho de Melo
2007-04-25[NET] core: whitespace cleanupStephen Hemminger
Fix whitespace around keywords. Fix indentation especially of switch statements. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[PKTGEN]: fix device name handlingStephen Hemminger
Since devices can change name and other wierdness, don't hold onto a copy of device name, instead use pointer to output device. Fix a couple of leaks in error handling path as well. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Robert Olsson <robert.olsson@its.uu.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[PKTGEN]: don't use __constant_htonl()Stephen Hemminger
The existing htonl() macro is smart enough to do the same code as using __constant_htonl() and it looks cleaner. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Robert Olsson <robert.olsson@its.uu.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[PKTGEN]: use random32Stephen Hemminger
Can use random32() now. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Robert Olsson <robert.olsson@its.uu.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[PKTGEN]: use pr_debugStephen Hemminger
Remove private debug macro and replace with standard version Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Robert Olsson <robert.olsson@its.uu.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-12[PKTGEN]: Add try_to_freeze()Andrew Morton
The pktgen module prevents suspend-to-disk. Fix. Acked-by: "Michal Piotrowski" <michal.k.k.piotrowski@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-12[PATCH] mark struct file_operations const 7Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-10[NET] CORE: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
