On Sun, 9 Apr 2006 21:56:59 +0400,
Sergey Vlasov <vsu@altlinux.ru> wrote:
> However, show_address() does not output anything unless
> dev->reg_state == NETREG_REGISTERED - and this state is set by
> netdev_run_todo() only after netdev_register_sysfs() returns, so in
> the meantime (while netdev_register_sysfs() is busy adding the
> "statistics" attribute group) some process may see an empty "address"
> attribute.
I've tried the attached patch, suggested by Sergey Vlasov on
hotplug-devel@, and as far as i can test it works just fine.
Signed-off-by: Alexander Patrakov <patrakov@ums.usu.ru>
Signed-off-by: David Miller <davem@davemloft.net>
percpu_data blindly allocates bootmem memory to store NR_CPUS instances of
cpudata, instead of allocating memory only for possible cpus.
As a preparation for changing that, we need to convert various 0 -> NR_CPUS
loops to use for_each_cpu().
(The above only applies to users of asm-generic/percpu.h. powerpc has gone it
alone and is presently only allocating memory for present CPUs, so it's
currently corrupting memory).
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: Jens Axboe <axboe@suse.de>
Acked-by: William Irwin <wli@holomorphy.com>
Cc: Andi Kleen <ak@muc.de>
This information is already available via /proc/net/bonding/*
therefore it doesn't make sense to require CAP_NET_ADMIN
privileges.
Original patch by Laurent Deniel <laurent.deniel@free.fr>
Signed-off-by: Thomas Graf <tgraf@suug.ch>
net: Use <linux/capability.h> where capable() is used.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
This changes some simple "if (x) BUG();" statements to "BUG_ON(x);"
Signed-off-by: Kris Katterjohn <kjak@users.sourceforge.net>
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
Currently all network protocols need to call dev_ioctl as the default
fallback in their ioctl implementations. This patch adds a fallback
to dev_ioctl to sock_ioctl if the protocol returned -ENOIOCTLCMD.
This way all the procotol ioctl handlers can be simplified and we don't
need to export dev_ioctl.
The problem I was seeing turned out to be that skb->dev is NULL when
the checksum is being completed in user context. This happens because
the reference to the device is dropped (to allow it to be released
when packets are in the queue).
Because skb->dev was NULL, the netdev_rx_csum_fault was panicing on
deref of dev->name. How about this?
Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
dev_valid_name() is a useful function. Make it public.
Signed-off-by: Mitch Williams <mitch.a.williams@intel.com>
Acked-by: Jay Vosburgh <fubar@us.ibm.com>
Here is the patch that introduces the generic skb_checksum_complete
which also checks for hardware RX checksum faults. If that happens,
it'll call netdev_rx_csum_fault which currently prints out a stack
trace with the device name. In future it can turn off RX checksum.
I've converted every spot under net/ that does RX checksum checks to
use skb_checksum_complete or __skb_checksum_complete with the
exceptions of:
* Those places where checksums are done bit by bit. These will call
netdev_rx_csum_fault directly.
* The following have not been completely checked/converted:
ipmr
ip_vs
netfilter
dccp
This patch is based on patches and suggestions from Stephen Hemminger
and David S. Miller.
Attached is kernel patch for UDP Fragmentation Offload (UFO) feature.
1. This patch incorporate the review comments by Jeff Garzik.
2. Renamed USO as UFO (UDP Fragmentation Offload)
3. udp sendfile support with UFO
This patches uses scatter-gather feature of skb to generate large UDP
datagram. Below is a "how-to" on changes required in network device
driver to use the UFO interface.
UDP Fragmentation Offload (UFO) Interface:
UFO is a feature wherein the Linux kernel network stack will offload the
IP fragmentation functionality of large UDP datagram to hardware. This
will reduce the overhead of stack in fragmenting the large UDP datagram to
MTU sized packets
1) Drivers indicate their capability of UFO using
dev->features |= NETIF_F_UFO | NETIF_F_HW_CSUM | NETIF_F_SG
NETIF_F_HW_CSUM is required for UFO over ipv6.
2) UFO packet will be submitted for transmission using driver xmit routine.
UFO packet will have a non-zero value for
"skb_shinfo(skb)->ufo_size"
skb_shinfo(skb)->ufo_size will indicate the length of data part in each IP
fragment going out of the adapter after IP fragmentation by hardware.
skb->data will contain MAC/IP/UDP header and skb_shinfo(skb)->frags[]
contains the data payload. The skb->ip_summed will be set to CHECKSUM_HW
indicating that hardware has to do checksum calculation. Hardware should
compute the UDP checksum of complete datagram and also ip header checksum of
each fragmented IP packet.
For IPV6 the UFO provides the fragment identification-id in
skb_shinfo(skb)->ip6_frag_id. The adapter should use this ID for generating
IPv6 fragments.
Signed-off-by: Ananda Raju <ananda.raju@neterion.com>
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (forwarded)
Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
- added typedef unsigned int __nocast gfp_t;
- replaced __nocast uses for gfp flags with gfp_t - it gives exactly
the same warnings as far as sparse is concerned, doesn't change
generated code (from gcc point of view we replaced unsigned int with
typedef) and documents what's going on far better.
We know the lock is going to be taken.
Signed-off-by: Jochen Friedrich <jochen@scram.de>
Of this type, mostly:
CHECK net/ipv6/netfilter.c
net/ipv6/netfilter.c:96:12: warning: symbol 'ipv6_netfilter_init' was not declared. Should it be static?
net/ipv6/netfilter.c:101:6: warning: symbol 'ipv6_netfilter_fini' was not declared. Should it be static?
Reduces skb size by 8 bytes on 64-bit.
Instead, set it in one place, namely the beginning of
netif_receive_skb().
Based upon suggestions from Jamal Hadi Salim.
Bonding just wants the device before the skb_bond()
decapsulation occurs, so simply pass that original
device into packet_type->func() as an argument.
It remains to be seen whether we can use this same
exact thing to get rid of skb->input_dev as well.
This fixes a race during initialization with the NAPI softirq
processing by using an RCU approach.
This race was discovered when refill_skbs() was added to
the setup code.
Signed-off-by: Matt Mackall <mpm@selenic.com>
If the current task has signal_pending(), the loop we have
to wait for the __LINK_STATE_RX_SCHED bit to clear becomes
a pure busy-loop.
Fixed by using msleep() instead of the hand-crafted version.
Noticed by Andrew Morton.
Fix the sparse warning "implicit cast to nocast type"
Signed-off-by: Victor Fusco <victor@cetuc.puc-rio.br>
Signed-off-by: Domen Puncer <domen@coderock.org>
A trivial patch to improve the readability of dev_set_promiscuity()
in net/core/dev.c. New code does exactly the same thing as original
code.
Signed-off-by: David Chau <ddcc@mit.edu>
Separate out the two uses of netdev_max_backlog. One controls the
upper bound on packets processed per softirq, the new name for this is
netdev_budget; the other controls the limit on packets queued via
netif_rx.
Increase the max_backlog default to account for faster processors.
Eliminate the throttling behaviour when the netif receive queue fills
because it behaves badly when using high speed networks under load.
The throttling cause multiple packet drops that cause TCP to go into
slow start mode. The same effective patch has been part of BIC TCP and
H-TCP as well as part of Web100.
The existing code drops 100's of packets when the queue fills;
this changes it to individual packet drop-tail.
Signed-off-by: Stephen Hemmminger <shemminger@osdl.org>
Remove the congestion sensing mechanism from netif_rx, and always
return either full or empty. Almost no driver checks the return value
from netif_rx, and those that do only use it for debug messages.
The original design of netif_rx was to do flow control based on the
receive queue, but NAPI has supplanted this and no driver uses the
feedback.
Remove last vestiages of fastroute code that is no longer used.
Changing the sysctl net.core.dev_weight has no effect because the weight
of the backlog devices is set during initialization and never changed.
This patch propagates any changes to the global value affected by sysctl
to the per-cpu devices. It is done every time the packet handler
function is run.
Resend of earlier patch (no changes) from Catalin used to provide
device feature change notification.
Signed-off-by: Catalin BOIE <catab at umbrella.ro>
Acked-by: Stephen Hemminger <shemminger@osdl.org>
Ross moved. Remove the bad email address so people will find the correct
one in ./CREDITS.
Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk>
This patch changes calls to synchronize_kernel(), deprecated in the earlier
"Deprecate synchronize_kernel, GPL replacement" patch to instead call the new
synchronize_rcu() and synchronize_sched() APIs.
Signed-off-by: Paul E. McKenney <paulmck@us.ibm.com>
infrastructure for it.
Let it rip!
