path: root/net/ceph/crypto.c
2013-02-25libceph: eliminate sparse warningsAlex Elder
Eliminate most of the problems in the libceph code that cause sparse to issue warnings. - Convert functions that are never referenced externally to have static scope. - Pass NULL rather than 0 for a pointer argument in one spot in ceph_monc_delete_snapid() This partially resolves: http://tracker.ceph.com/issues/4184 Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Alex Elder <elder@inktank.com> Reviewed-by: Josh Durgin <josh.durgin@inktank.com>
2012-10-08KEYS: Add payload preparsing opportunity prior to key instantiate or updateDavid Howells
Give the key type the opportunity to preparse the payload prior to the instantiation and update routines being called. This is done with the provision of two new key type operations: int (*preparse)(struct key_preparsed_payload *prep); void (*free_preparse)(struct key_preparsed_payload *prep); If the first operation is present, then it is called before key creation (in the add/update case) or before the key semaphore is taken (in the update and instantiate cases). The second operation is called to clean up if the first was called. preparse() is given the opportunity to fill in the following structure: struct key_preparsed_payload { char *description; void *type_data[2]; void *payload; const void *data; size_t datalen; size_t quotalen; }; Before the preparser is called, the first three fields will have been cleared, the payload pointer and size will be stored in data and datalen and the default quota size from the key_type struct will be stored into quotalen. The preparser may parse the payload in any way it likes and may store data in the type_data[] and payload fields for use by the instantiate() and update() ops. The preparser may also propose a description for the key by attaching it as a string to the description field. This can be used by passing a NULL or "" description to the add_key() system call or the key_create_or_update() function. This cannot work with request_key() as that required the description to tell the upcall about the key to be created. This, for example permits keys that store PGP public keys to generate their own name from the user ID and public key fingerprint in the key. The instantiate() and update() operations are then modified to look like this: int (*instantiate)(struct key *key, struct key_preparsed_payload *prep); int (*update)(struct key *key, struct key_preparsed_payload *prep); and the new payload data is passed in *prep, whether or not it was preparsed. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-08-02libceph: fix crypto key null deref, memory leakSylvain Munaut
Avoid crashing if the crypto key payload was NULL, as when it was not correctly allocated and initialized. Also, avoid leaking it. Signed-off-by: Sylvain Munaut <tnt@246tNt.com> Signed-off-by: Sage Weil <sage@inktank.com> Reviewed-by: Alex Elder <elder@inktank.com>
2012-01-10ceph: Use kmemdup rather than duplicating its implementationThomas Meyer
Use kmemdup rather than duplicating its implementation The semantic patch that makes this change is available in scripts/coccinelle/api/memdup.cocci. Signed-off-by: Thomas Meyer <thomas@m3y3r.de> Signed-off-by: Sage Weil <sage@newdream.net>
2011-06-16net: Remove casts of void *Joe Perches
Unnecessary casts of void * clutter the code. These are the remainder casts after several specific patches to remove netdev_priv and dev_priv. Done via coccinelle script: $ cat cast_void_pointer.cocci @@ type T; T *pt; void *pv; @@ - pt = (T *)pv; + pt = pv; Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@conan.davemloft.net>
2011-03-29libceph: Create a new key type "ceph".Tommi Virtanen
This allows us to use existence of the key type as a feature test, from userspace. Signed-off-by: Tommi Virtanen <tommi.virtanen@dreamhost.com> Signed-off-by: Sage Weil <sage@newdream.net>
2011-03-29ceph: Move secret key parsing earlier.Tommi Virtanen
This makes the base64 logic be contained in mount option parsing, and prepares us for replacing the homebew key management with the kernel key retention service. Signed-off-by: Tommi Virtanen <tommi.virtanen@dreamhost.com> Signed-off-by: Sage Weil <sage@newdream.net>
2010-10-20ceph: factor out libceph from Ceph file systemYehuda Sadeh
This factors out protocol and low-level storage parts of ceph into a separate libceph module living in net/ceph and include/linux/ceph. This is mostly a matter of moving files around. However, a few key pieces of the interface change as well: - ceph_client becomes ceph_fs_client and ceph_client, where the latter captures the mon and osd clients, and the fs_client gets the mds client and file system specific pieces. - Mount option parsing and debugfs setup is correspondingly broken into two pieces. - The mon client gets a generic handler callback for otherwise unknown messages (mds map, in this case). - The basic supported/required feature bits can be expanded (and are by ceph_fs_client). No functional change, aside from some subtle error handling cases that got cleaned up in the refactoring process. Signed-off-by: Sage Weil <sage@newdream.net>
