path: root/net/bridge
2012-05-17ipv6: correct the ipv6 option name - Pad0 to Pad1Eldad Zack
The padding destination or hop-by-hop option is called Pad1 and not Pad0. See RFC2460 (4.2) or the IANA ipv6-parameters registry: http://www.iana.org/assignments/ipv6-parameters/ipv6-parameters.xml Signed-off-by: Eldad Zack <eldad@fogrefinery.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-09bridge: Convert compare_ether_addr to ether_addr_equalJoe Perches
Use the new bool function ether_addr_equal to add some clarity and reduce the likelihood for misuse of compare_ether_addr for sorting. Done via cocci script: $ cat compare_ether_addr.cocci @@ expression a,b; @@ - !compare_ether_addr(a, b) + ether_addr_equal(a, b) @@ expression a,b; @@ - compare_ether_addr(a, b) + !ether_addr_equal(a, b) @@ expression a,b; @@ - !ether_addr_equal(a, b) == 0 + ether_addr_equal(a, b) @@ expression a,b; @@ - !ether_addr_equal(a, b) != 0 + !ether_addr_equal(a, b) @@ expression a,b; @@ - ether_addr_equal(a, b) == 0 + !ether_addr_equal(a, b) @@ expression a,b; @@ - ether_addr_equal(a, b) != 0 + ether_addr_equal(a, b) @@ expression a,b; @@ - !!ether_addr_equal(a, b) + ether_addr_equal(a, b) Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-09bridge: netfilter: Convert compare_ether_addr to ether_addr_equalJoe Perches
Use the new bool function ether_addr_equal to add some clarity and reduce the likelihood for misuse of compare_ether_addr for sorting. Done via cocci script: $ cat compare_ether_addr.cocci @@ expression a,b; @@ - !compare_ether_addr(a, b) + ether_addr_equal(a, b) @@ expression a,b; @@ - compare_ether_addr(a, b) + !ether_addr_equal(a, b) @@ expression a,b; @@ - !ether_addr_equal(a, b) == 0 + ether_addr_equal(a, b) @@ expression a,b; @@ - !ether_addr_equal(a, b) != 0 + !ether_addr_equal(a, b) @@ expression a,b; @@ - ether_addr_equal(a, b) == 0 + !ether_addr_equal(a, b) @@ expression a,b; @@ - ether_addr_equal(a, b) != 0 + ether_addr_equal(a, b) @@ expression a,b; @@ - !!ether_addr_equal(a, b) + ether_addr_equal(a, b) Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-08netfilter: bridge: optionally set indev to vlanPablo Neira Ayuso
if net.bridge.bridge-nf-filter-vlan-tagged sysctl is enabled, bridge netfilter removes the vlan header temporarily and then feeds the packet to ip(6)tables. When the new "bridge-nf-pass-vlan-input-device" sysctl is on (default off), then bridge netfilter will also set the in-interface to the vlan interface; if such an interface exists. This is needed to make iptables REDIRECT target work with "vlan-on-top-of-bridge" setups and to allow use of "iptables -i" to match the vlan device name. Also update Documentation with current brnf default settings. Signed-off-by: Florian Westphal <fw@strlen.de> Acked-by: Bart De Schuymer <bdschuym@pandora.be> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2012-05-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/intel/e1000e/param.c drivers/net/wireless/iwlwifi/iwl-agn-rx.c drivers/net/wireless/iwlwifi/iwl-trans-pcie-rx.c drivers/net/wireless/iwlwifi/iwl-trans.h Resolved the iwlwifi conflict with mainline using 3-way diff posted by John Linville and Stephen Rothwell. In 'net' we added a bug fix to make iwlwifi report a more accurate skb->truesize but this conflicted with RX path changes that happened meanwhile in net-next. In e1000e a conflict arose in the validation code for settings of adapter->itr. 'net-next' had more sophisticated logic so that logic was used. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-30bridge: Fix fatal typo in setup of multicast_querier_expiredHerbert Xu
Unfortunately it seems that I didn't properly test the case of an expired external querier in the recent multicast bridge series. The setup of the timer in that case is completely broken and leads to a NULL-pointer dereference. This patch fixes it. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-24set fake_rtable's dst to NULL to avoid kernel OopsPeter Huang (Peng)
bridge: set fake_rtable's dst to NULL to avoid kernel Oops when bridge is deleted before tap/vif device's delete, kernel may encounter an oops because of NULL reference to fake_rtable's dst. Set fake_rtable's dst to NULL before sending packets out can solve this problem. v4 reformat, change br_drop_fake_rtable(skb) to {} v3 enrich commit header v2 introducing new flag DST_FAKE_RTABLE to dst_entry struct. [ Use "do { } while (0)" for nop br_drop_fake_rtable() implementation -DaveM ] Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Peter Huang <peter.huangpeng@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-20net: Convert all sysctl registrations to register_net_sysctlEric W. Biederman
This results in code with less boiler plate that is a bit easier to read. Additionally stops us from using compatibility code in the sysctl core, hastening the day when the compatibility code can be removed. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-20net: Move all of the network sysctls without a namespace into init_net.Eric W. Biederman
This makes it clearer which sysctls are relative to your current network namespace. This makes it a little less error prone by not exposing sysctls for the initial network namespace in other namespaces. This is the same way we handle all of our other network interfaces to userspace and I can't honestly remember why we didn't do this for sysctls right from the start. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-15net: add generic PF_BRIDGE:RTM_ FDB hooksJohn Fastabend
This adds two new flags NTF_MASTER and NTF_SELF that can now be used to specify where PF_BRIDGE netlink commands should be sent. NTF_MASTER sends the commands to the 'dev->master' device for parsing. Typically this will be the linux net/bridge, or open-vswitch devices. Also without any flags set the command will be handled by the master device as well so that current user space tools continue to work as expected. The NTF_SELF flag will push the PF_BRIDGE commands to the device. In the basic example below the commands are then parsed and programmed in the embedded bridge. Note if both NTF_SELF and NTF_MASTER bits are set then the command will be sent to both 'dev->master' and 'dev' this allows user space to easily keep the embedded bridge and software bridge in sync. There is a slight complication in the case with both flags set when an error occurs. To resolve this the rtnl handler clears the NTF_ flag in the netlink ack to indicate which sets completed successfully. The add/del handlers will abort as soon as any error occurs. To support this new net device ops were added to call into the device and the existing bridging code was refactored to use these. There should be no required changes in user space to support the current bridge behavior. A basic setup with a SR-IOV enabled NIC looks like this, veth0 veth2 | | ------------ | bridge0 | <---- software bridging ------------ / / ethx.y ethx VF PF \ \ <---- propagate FDB entries to HW \ \ -------------------- | Embedded Bridge | <---- hardware offloaded switching -------------------- In this case the embedded bridge must be managed to allow 'veth0' to communicate with 'ethx.y' correctly. At present drivers managing the embedded bridge either send frames onto the network which then get dropped by the switch OR the embedded bridge will flood these frames. With this patch we have a mechanism to manage the embedded bridge correctly from user space. This example is specific to SR-IOV but replacing the VF with another PF or dropping this into the DSA framework generates similar management issues. Examples session using the 'br'[1] tool to add, dump and then delete a mac address with a new "embedded" option and enabled ixgbe driver: # br fdb add 22:35:19:ac:60:59 dev eth3 # br fdb port mac addr flags veth0 22:35:19:ac:60:58 static veth0 9a:5f:81:f7:f6:ec local eth3 00:1b:21:55:23:59 local eth3 22:35:19:ac:60:59 static veth0 22:35:19:ac:60:57 static #br fdb add 22:35:19:ac:60:59 embedded dev eth3 #br fdb port mac addr flags veth0 22:35:19:ac:60:58 static veth0 9a:5f:81:f7:f6:ec local eth3 00:1b:21:55:23:59 local eth3 22:35:19:ac:60:59 static veth0 22:35:19:ac:60:57 static eth3 22:35:19:ac:60:59 local embedded #br fdb del 22:35:19:ac:60:59 embedded dev eth3 I added a couple lines to 'br' to set the flags correctly is all. It is my opinion that the merit of this patch is now embedded and SW bridges can both be modeled correctly in user space using very nearly the same message passing. [1] 'br' tool was published as an RFC here and will be renamed 'bridge' http://patchwork.ozlabs.org/patch/117664/ Thanks to Jamal Hadi Salim, Stephen Hemminger and Ben Hutchings for valuable feedback, suggestions, and review. v2: fixed api descriptions and error case with both NTF_SELF and NTF_MASTER set plus updated patch description. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-15bridge: Add multicast_querier toggle and disable queries by defaultHerbert Xu
Sending general queries was implemented as an optimisation to speed up convergence on start-up. In order to prevent interference with multicast routers a zero source address has to be used. Unfortunately these packets appear to cause some multicast-aware switches to misbehave, e.g., by disrupting multicast packets to us. Since the multicast snooping feature still functions without sending our own queries, this patch will change the default to not send queries. For those that need queries in order to speed up convergence on start-up, a toggle is provided to restore the previous behaviour. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-15bridge: Restart queries when last querier expiresHerbert Xu
As it stands when we discover that a real querier (one that queries with a non-zero source address) we stop querying. However, even after said querier has fallen off the edge of the earth, we will never restart querying (unless the bridge itself is restarted). This patch fixes this by kicking our own querier into gear when the timer for other queriers expire. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-15bridge: Add br_multicast_start_querierHerbert Xu
This patch adds the helper br_multicast_start_querier so that the code which starts the queriers in br_multicast_toggle can be reused elsewhere. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-15net: cleanup unsigned to unsigned intEric Dumazet
Use of "unsigned int" is preferred to bare "unsigned" in net tree. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2012-04-11bridge: Do not send queries on multicast group leavesHerbert Xu
As it stands the bridge IGMP snooping system will respond to group leave messages with queries for remaining membership. This is both unnecessary and undesirable. First of all any multicast routers present should be doing this rather than us. What's more the queries that we send may end up upsetting other multicast snooping swithces in the system that are buggy. In fact, we can simply remove the code that send these queries because the existing membership expiry mechanism doesn't rely on them anyway. So this patch simply removes all code associated with group queries in response to group leave messages. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-02bridge: Stop using NLA_PUT*().David S. Miller
These macros contain a hidden goto, and are thus extremely error prone and make code hard to audit. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2012-03-08bridge: fix state reporting when port is disabledPaulius Zaleckas
Now we have: eth0: link *down* br0: port 1(eth0) entered *forwarding* state br_log_state(p) should be called *after* p->state is set to BR_STATE_DISABLED. Reported-by: Zilvinas Valinskas <zilvinas@wilibox.com> Signed-off-by: Paulius Zaleckas <paulius.zaleckas@gmail.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-08bridge: br_log_state() s/entering/entered/Paulius Zaleckas
When br_log_state() is reporting state it should say "entered" istead of "entering" since state at this point is already changed. Signed-off-by: Paulius Zaleckas <paulius.zaleckas@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-06bridge: netfilter: don't call iptables on vlan packets if sysctl is offFlorian Westphal
When net.bridge.bridge-nf-filter-vlan-tagged is 0 (default), vlan packets arriving should not be sent to ip(6)tables by bridge netfilter. However, it turns out that we currently always send VLAN packets to netfilter, if .. a), CONFIG_VLAN_8021Q is enabled ; or b), CONFIG_VLAN_8021Q is not set but rx vlan offload is enabled on the bridge port. This is because bridge netfilter treats skb with skb->protocol == ETH_P_IP{V6} as "non-vlan packet". With rx vlan offload on or CONFIG_VLAN_8021Q=y, the vlan header has already been removed here, and we cannot rely on skb->protocol alone. Fix this by only using skb->protocol if the skb has no vlan tag, or if a vlan tag is present and filter-vlan-tagged bridge netfilter sysctl is enabled. We cannot remove the skb->protocol == htons(ETH_P_8021Q) test because the vlan tag is still around in the CONFIG_VLAN_8021Q=n && "ethtool -K $itf rxvlan off" case. reproducer: iptables -t raw -I PREROUTING -i br0 iptables -t raw -I PREROUTING -i br0.1 Then send packets to an ip address configured on br0.1 interface. Even with net.bridge.bridge-nf-filter-vlan-tagged=0, the 1st rule will match instead of the 2nd one. With this patch applied, the 2nd rule will match instead. In the non-local address case, netfilter won't be consulted after this patch unless the sysctl is switched on. Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-06netfilter: bridge: fix wrong pointer dereferencePablo Neira Ayuso
In adf7ff8, a invalid dereference was added in ebt_make_names. CC [M] net/bridge/netfilter/ebtables.o net/bridge/netfilter/ebtables.c: In function `ebt_make_names': net/bridge/netfilter/ebtables.c:1371:20: warning: `t' may be used uninitialized in this function [-Wuninitialized] Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-06netfilter: ebtables: fix wrong name length while copying to user-spaceSantosh Nayak
user-space ebtables expects 32 bytes-long names, but xt_match names use 29 bytes. We have to copy less 29 bytes and then, make sure we fill the remaining bytes with zeroes. Signed-off-by: Santosh Nayak <santoshprasadnayak@gmail.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/vmxnet3/vmxnet3_drv.c Small vmxnet3 conflict with header size bug fix in 'net'. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-05bridge: check return value of ipv6_dev_get_saddr()Ulrich Weber
otherwise source IPv6 address of ICMPV6_MGM_QUERY packet might be random junk if IPv6 is disabled on interface or link-local address is not yet ready (DAD). Signed-off-by: Ulrich Weber <ulrich.weber@sophos.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-04bridge: message age needs to increase, not decrease.Joakim Tjernlund
commit bridge: send proper message_age in config BPDU added this gem: bpdu.message_age = (jiffies - root->designated_age) p->designated_age = jiffies + bpdu->message_age; Notice how bpdu->message_age is negated when reassigned to bpdu.message_age. This causes message age to decrease breaking the STP protocol. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-04bridge: Adjust min age inc for HZ > 256Joakim Tjernlund
min age increment needs to round up its min age tick for all HZ values to guarantee message age is increasing. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/broadcom/tg3.c Conflicts in the statistics regression bug fix from 'net', but happily Matt Carlson originally posted the fix against 'net-next' so I used that to resolve this. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-25netfilter: bridge: fix module autoload in compat caseFlorian Westphal
We expected 0 if module doesn't exist, which is no longer the case (42046e2e45c109ba703993c510401a11f716c8df, netfilter: x_tables: return -ENOENT for non-existant matches/targets). Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2012-02-23br_device: unify return value of .ndo_set_mac_address if address is invalidDanny Kukawka
Unify return value of .ndo_set_mac_address if the given address isn't valid. Return -EADDRNOTAVAIL as eth_mac_addr() already does if is_valid_ether_addr() fails. Signed-off-by: Danny Kukawka <danny.kukawka@bisect.de> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-15net: use eth_hw_addr_random() and reset addr_assign_typeDanny Kukawka
Use eth_hw_addr_random() instead of calling random_ether_addr() to set addr_assign_type correctly to NET_ADDR_RANDOM. Reset the state to NET_ADDR_PERM as soon as the MAC get changed via .ndo_set_mac_address. v2: adapt to renamed eth_hw_addr_random() Signed-off-by: Danny Kukawka <danny.kukawka@bisect.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-17bridge: BH already disabled in br_fdb_cleanup()Eric Dumazet
br_fdb_cleanup() is run from timer interrupt, BH already masked. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Stephen Hemminger <shemminger@vyatta.com> CC: Štefan Gula <steweg@gmail.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: net/bluetooth/l2cap_core.c Just two overlapping changes, one added an initialization of a local variable, and another change added a new local variable. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-22net: introduce DST_NOPEER dst flagEric Dumazet
Chris Boot reported crashes occurring in ipv6_select_ident(). [ 461.457562] RIP: 0010:[<ffffffff812dde61>] [<ffffffff812dde61>] ipv6_select_ident+0x31/0xa7 [ 461.578229] Call Trace: [ 461.580742] <IRQ> [ 461.582870] [<ffffffff812efa7f>] ? udp6_ufo_fragment+0x124/0x1a2 [ 461.589054] [<ffffffff812dbfe0>] ? ipv6_gso_segment+0xc0/0x155 [ 461.595140] [<ffffffff812700c6>] ? skb_gso_segment+0x208/0x28b [ 461.601198] [<ffffffffa03f236b>] ? ipv6_confirm+0x146/0x15e [nf_conntrack_ipv6] [ 461.608786] [<ffffffff81291c4d>] ? nf_iterate+0x41/0x77 [ 461.614227] [<ffffffff81271d64>] ? dev_hard_start_xmit+0x357/0x543 [ 461.620659] [<ffffffff81291cf6>] ? nf_hook_slow+0x73/0x111 [ 461.626440] [<ffffffffa0379745>] ? br_parse_ip_options+0x19a/0x19a [bridge] [ 461.633581] [<ffffffff812722ff>] ? dev_queue_xmit+0x3af/0x459 [ 461.639577] [<ffffffffa03747d2>] ? br_dev_queue_push_xmit+0x72/0x76 [bridge] [ 461.646887] [<ffffffffa03791e3>] ? br_nf_post_routing+0x17d/0x18f [bridge] [ 461.653997] [<ffffffff81291c4d>] ? nf_iterate+0x41/0x77 [ 461.659473] [<ffffffffa0374760>] ? br_flood+0xfa/0xfa [bridge] [ 461.665485] [<ffffffff81291cf6>] ? nf_hook_slow+0x73/0x111 [ 461.671234] [<ffffffffa0374760>] ? br_flood+0xfa/0xfa [bridge] [ 461.677299] [<ffffffffa0379215>] ? nf_bridge_update_protocol+0x20/0x20 [bridge] [ 461.684891] [<ffffffffa03bb0e5>] ? nf_ct_zone+0xa/0x17 [nf_conntrack] [ 461.691520] [<ffffffffa0374760>] ? br_flood+0xfa/0xfa [bridge] [ 461.697572] [<ffffffffa0374812>] ? NF_HOOK.constprop.8+0x3c/0x56 [bridge] [ 461.704616] [<ffffffffa0379031>] ? nf_bridge_push_encap_header+0x1c/0x26 [bridge] [ 461.712329] [<ffffffffa037929f>] ? br_nf_forward_finish+0x8a/0x95 [bridge] [ 461.719490] [<ffffffffa037900a>] ? nf_bridge_pull_encap_header+0x1c/0x27 [bridge] [ 461.727223] [<ffffffffa0379974>] ? br_nf_forward_ip+0x1c0/0x1d4 [bridge] [ 461.734292] [<ffffffff81291c4d>] ? nf_iterate+0x41/0x77 [ 461.739758] [<ffffffffa03748cc>] ? __br_deliver+0xa0/0xa0 [bridge] [ 461.746203] [<ffffffff81291cf6>] ? nf_hook_slow+0x73/0x111 [ 461.751950] [<ffffffffa03748cc>] ? __br_deliver+0xa0/0xa0 [bridge] [ 461.758378] [<ffffffffa037533a>] ? NF_HOOK.constprop.4+0x56/0x56 [bridge] This is caused by bridge netfilter special dst_entry (fake_rtable), a special shared entry, where attaching an inetpeer makes no sense. Problem is present since commit 87c48fa3b46 (ipv6: make fragment identifications less predictable) Introduce DST_NOPEER dst flag and make sure ipv6_select_ident() and __ip_select_ident() fallback to the 'no peer attached' handling. Reported-by: Chris Boot <bootc@bootc.net> Tested-by: Chris Boot <bootc@bootc.net> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-22bridge: provide a mtu() method for fake_dst_opsEric Dumazet
Commit 618f9bc74a039da76 (net: Move mtu handling down to the protocol depended handlers) forgot the bridge netfilter case, adding a NULL dereference in ip_fragment(). Reported-by: Chris Boot <bootc@bootc.net> CC: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-16net:bridge: use IS_ENABLEDIgor Maravić
Use IS_ENABLED(CONFIG_FOO) instead of defined(CONFIG_FOO) || defined (CONFIG_FOO_MODULE) Signed-off-by: Igor Maravić <igorm@etf.rs> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-11net: use IS_ENABLED(CONFIG_IPV6)Eric Dumazet
Instead of testing defined(CONFIG_IPV6) || defined(CONFIG_IPV6_MODULE) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-08bridge: add local MAC address to forwarding table (v2)stephen hemminger
If user has configured a MAC address that is not one of the existing ports of the bridge, then we need to add a special entry in the forwarding table. This forwarding table entry has no outgoing port so it has to be treated a little differently. The special entry is reported by the netlink interface with ifindex of bridge, but ignored by the old interface since there is no usable way to put it in the ABI. Reported-by: Koki Sanagi <sanagi.koki@jp.fujitsu.com> Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-08bridge: rearrange fdb notifications (v2)stephen hemminger
Pass bridge to fdb_notify so it can determine correct namespace based on namespace of bridge rather than namespace of destination port. Also makes next patch easier. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-08bridge: refactor fdb_notifystephen hemminger
Move fdb_notify outside of fdb_create. This fixes the problem that notification of local entries are not flagged correctly. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-05net: Rename dst_get_neighbour{, _raw} to dst_get_neighbour_noref{, _raw}.David Miller
To reflect the fact that a refrence is not obtained to the resulting neighbour entry. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Roland Dreier <roland@purestorage.com>
2011-12-03ipv6: Add fragment reporting to ipv6_skip_exthdr().Jesse Gross
While parsing through IPv6 extension headers, fragment headers are skipped making them invisible to the caller. This reports the fragment offset of the last header in order to make it possible to determine whether the packet is fragmented and, if so whether it is a first or last fragment. Signed-off-by: Jesse Gross <jesse@nicira.com>
2011-12-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2011-12-01bridge: master device stuck in no-carrier state forever when in user-stp modeVitalii Demianets
When in user-stp mode, bridge master do not follow state of its slaves, so after the following sequence of events it can stuck forever in no-carrier state: 1) turn stp off 2) put all slaves down - master device will follow their state and also go in no-carrier state 3) turn stp on with bridge-stp script returning 0 (go to the user-stp mode) Now bridge master won't follow slaves' state and will never reach running state. This patch solves the problem by making user-stp and kernel-stp behavior similar regarding master following slaves' states. Signed-off-by: Vitalii Demianets <vitas@nppfactor.kiev.ua> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-22net: remove ipv6_addr_copy()Alexey Dobriyan
C assignment can handle struct in6_addr copying. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
The forcedeth changes had a conflict with the conversion over to atomic u64 statistics in net-next. The libertas cfg.c code had a conflict with the bss reference counting fix by John Linville in net-next. Conflicts: drivers/net/ethernet/nvidia/forcedeth.c drivers/net/wireless/libertas/cfg.c
2011-11-16net: remove NETIF_F_NO_CSUM feature bitMichał Mirosław
Only distinct use is checking if NETIF_F_NOCACHE_COPY should be enabled by default. The check heuristics is altered a bit here, so it hits other people than before. The default shouldn't be trusted for performance-critical cases anyway. For all other uses NETIF_F_NO_CSUM is equivalent to NETIF_F_HW_CSUM. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-16net: introduce and use netdev_features_t for device features setsMichał Mirosław
v2: add couple missing conversions in drivers split unexporting netdev_fix_features() implemented %pNF convert sock::sk_route_(no?)caps Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-16bridge: correct IPv6 checksum after pullstephen hemminger
Bridge multicast snooping of ICMPv6 would incorrectly report a checksum problem when used with Ethernet devices like sky2 that use CHECKSUM_COMPLETE. When bytes are removed from skb, the computed checksum needs to be adjusted. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Tested-by: Martin Volf <martin.volf.42@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-14bridge: add NTF_USE supportstephen hemminger
More changes to the recent code to support control of forwarding database via netlink. * Support NTF_USE like neighbour table * Validate state bits from application * Only send notifications (and change bits) if new entry is different. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
