path: root/net/bridge
2010-08-02Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/e1000e/hw.h net/bridge/br_device.c net/bridge/br_input.c
2010-07-30bridge: Allow multicast snooping to be disabled before ifupHerbert Xu
Currently you cannot disable multicast snooping while a device is down. There is no good reason for this restriction and this patch removes it. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-30bridge: Fix skb leak when multicast parsing fails on TXHerbert Xu
On the bridge TX path we're leaking an skb when br_multicast_rcv returns an error. Reported-by: David Lamparter <equinox@diac24.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-28bridge: add rcu_read_lock on transmitstephen hemminger
Long ago, when bridge was converted to RCU, rcu lock was equivalent to having preempt disabled. RCU has changed a lot since then and bridge code was still assuming the since transmit was called with bottom half disabled, it was RCU safe. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Tested-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-19bridge: Partially disable netpoll supportHerbert Xu
The new netpoll code in bridging contains use-after-free bugs that are non-trivial to fix. This patch fixes this by removing the code that uses skbs after they're freed. As a consequence, this means that we can no longer call bridge from the netpoll path, so this patch also removes the controller function in order to disable netpoll. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Thanks, Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-15net: bridge: fix sign bugKulikov Vasiliy
ipv6_skip_exthdr() can return error code that is below zero. 'offset' is unsigned, so it makes no sense. ipv6_skip_exthdr() returns 'int' so we can painlessly change type of offset to int. Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-07Merge branch 'master' of ↵David S. Miller
2010-07-07net: fix 64 bit counters on 32 bit archesEric Dumazet
There is a small possibility that a reader gets incorrect values on 32 bit arches. SNMP applications could catch incorrect counters when a 32bit high part is changed by another stats consumer/provider. One way to solve this is to add a rtnl_link_stats64 param to all ndo_get_stats64() methods, and also add such a parameter to dev_get_stats(). Rule is that we are not allowed to use dev->stats64 as a temporary storage for 64bit stats, but a caller provided area (usually on stack) Old drivers (only providing get_stats() method) need no changes. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-07bridge: Clear IPCB before possible entry into IP stackHerbert Xu
The bridge protocol lives dangerously by having incestuous relations with the IP stack. In this instance an abomination has been created where a bogus IPCB area from a bridged packet leads to a crash in the IP stack because it's interpreted as IP options. This patch papers over the problem by clearing the IPCB area in that particular spot. To fix this properly we'd also need to parse any IP options if present but I'm way too lazy for that. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Cheers, Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-05bridge br_multicast: BUG: unable to handle kernel NULL pointer dereferenceHerbert Xu
On Tue, Jul 06, 2010 at 08:48:35AM +0800, Herbert Xu wrote: > > bridge: Restore NULL check in br_mdb_ip_get Resend with proper attribution. bridge: Restore NULL check in br_mdb_ip_get Somewhere along the line the NULL check in br_mdb_ip_get went AWOL, causing crashes when we receive an IGMP packet with no multicast table allocated. This patch restores it and ensures all br_mdb_*_get functions use it. Reported-by: Frank Arnold <frank.arnold@amd.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Thanks, Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-02Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-next-2.6
2010-07-02bridge: add per bridge device controls for invoking iptablesPatrick McHardy
Support more fine grained control of bridge netfilter iptables invocation by adding seperate brnf_call_*tables parameters for each device using the sysfs interface. Packets are passed to layer 3 netfilter when either the global parameter or the per bridge parameter is enabled. Acked-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-06-23Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/ipv4/ip_output.c
2010-06-23bridge: 64bit rx/tx countersEric Dumazet
Use u64_stats_sync infrastructure to provide 64bit rx/tx counters even on 32bit hosts. It is safe to use a single u64_stats_sync for rx and tx, because BH is disabled on both, and we use per_cpu data. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-17bridge: fdb cleanup runs too oftenstephen hemminger
It is common in end-node, non STP bridges to set forwarding delay to zero; which causes the forwarding database cleanup to run every clock tick. Change to run only as soon as needed or at next ageing timer interval which ever is sooner. Use round_jiffies_up macro rather than attempting round up by changing value. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-15bridge: Add const to dummy br_netpoll_send_skbHerbert Xu
The version of br_netpoll_send_skb used when netpoll is off is missing a const thus causing a warning. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-15bridge: Fix OOM crash in deliver_cloneHerbert Xu
The bridge multicast patches introduced an OOM crash in the forward path, when deliver_clone fails to clone the skb. Reported-by: Mark Wagner <mwagner@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-15Merge branch 'master' of ↵David S. Miller
2010-06-15bridge: use rx_handler_data pointer to store net_bridge_port pointerJiri Pirko
Register net_bridge_port pointer as rx_handler data pointer. As br_port is removed from struct net_device, another netdev priv_flag is added to indicate the device serves as a bridge port. Also rcuized pointers are now correctly dereferenced in br_fdb.c and in netfilter parts. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-15net: add rx_handler data pointerJiri Pirko
Add possibility to register rx_handler data pointer along with a rx_handler. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-15bridge: Fix netpoll supportHerbert Xu
There are multiple problems with the newly added netpoll support: 1) Use-after-free on each netpoll packet. 2) Invoking unsafe code on netpoll/IRQ path. 3) Breaks when netpoll is enabled on the underlying device. This patch fixes all of these problems. In particular, we now allocate proper netpoll structures for each underlying device. We only allow netpoll to be enabled on the bridge when all the devices underneath it support netpoll. Once it is enabled, we do not allow non-netpoll devices to join the bridge (until netpoll is disabled again). This allows us to do away with the npinfo juggling that caused problem number 1. Incidentally this patch fixes number 2 by bypassing unsafe code such as multicast snooping and netfilter. Reported-by: Qianfeng Zhang <frzhang@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-15bridge: Remove redundant npinfo NULL settingHerbert Xu
Now that netpoll always zaps npinfo we no longer need to do it in bridge. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-15Merge branch 'master' of /repos/git/net-next-2.6Patrick McHardy
Conflicts: include/net/netfilter/xt_rateest.h net/bridge/br_netfilter.c net/netfilter/nf_conntrack_core.c Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-06-10net-next: remove useless union keywordChangli Gao
remove useless union keyword in rtable, rt6_info and dn_route. Since there is only one member in a union, the union keyword isn't useful. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-02net: replace hooks in __netif_receive_skb V5Jiri Pirko
What this patch does is it removes two receive frame hooks (for bridge and for macvlan) from __netif_receive_skb. These are replaced them with a single hook for both. It only supports one hook per device because it makes no sense to do bridging and macvlan on the same device. Then a network driver (of virtual netdev like macvlan or bridge) can register an rx_handler for needed net device. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-01netfilter: br_netfilter: use skb_set_noref()Eric Dumazet
Avoid dirtying bridge_parent_rtable refcount, using new dst noref infrastructure. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-05-21sysfs: add struct file* to bin_attr callbacksChris Wright
This allows bin_attr->read,write,mmap callbacks to check file specific data (such as inode owner) as part of any privilege validation. Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-18bridge: fix build for CONFIG_SYSFS disabledRandy Dunlap
Fix build when CONFIG_SYSFS is not enabled: net/bridge/br_if.c:136: error: 'struct net_bridge_port' has no member named 'sysfs_name' Note: dev->name == sysfs_name except when change name is in progress, and we are protected from that by RTNL mutex. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-15bridge: update sysfs link names if port device names have changedSimon Arlott
Links for each port are created in sysfs using the device name, but this could be changed after being added to the bridge. As well as being unable to remove interfaces after this occurs (because userspace tools don't recognise the new name, and the kernel won't recognise the old name), adding another interface with the old name to the bridge will cause an error trying to create the sysfs link. This fixes the problem by listening for NETDEV_CHANGENAME notifications and renaming the link. https://bugzilla.kernel.org/show_bug.cgi?id=12743 Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-15bridge: change console message interfacestephen hemminger
Use one set of macro's for all bridge messages. Note: can't use netdev_XXX macro's because bridge is purely virtual and has no device parent. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-15bridge: netpoll cleanupstephen hemminger
Move code around so that the ifdef for NETPOLL_CONTROLLER don't have to show up in main code path. The control functions should be in helpers that are only compiled if needed. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-13netfilter: bridge-netfilter: fix crash in br_nf_forward_finish()Bart De Schuymer
[ 4593.956206] BUG: unable to handle kernel NULL pointer dereference at 0000000000000018 [ 4593.956219] IP: [<ffffffffa03357a4>] br_nf_forward_finish+0x154/0x170 [bridge] [ 4593.956232] PGD 195ece067 PUD 1ba005067 PMD 0 [ 4593.956241] Oops: 0000 [#1] SMP [ 4593.956248] last sysfs file: /sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:08/ATK0110:00/hwmon/hwmon0/temp2_label [ 4593.956253] CPU 3 ... [ 4593.956380] Pid: 29512, comm: kvm Not tainted 2.6.34-rc7-net #195 P6T DELUXE/System Product Name [ 4593.956384] RIP: 0010:[<ffffffffa03357a4>] [<ffffffffa03357a4>] br_nf_forward_finish+0x154/0x170 [bridge] [ 4593.956395] RSP: 0018:ffff880001e63b78 EFLAGS: 00010246 [ 4593.956399] RAX: 0000000000000608 RBX: ffff880057181700 RCX: ffff8801b813d000 [ 4593.956402] RDX: 0000000000000000 RSI: 0000000000000002 RDI: ffff880057181700 [ 4593.956406] RBP: ffff880001e63ba8 R08: ffff8801b9d97000 R09: ffffffffa0335650 [ 4593.956410] R10: 0000000000000000 R11: 0000000000000000 R12: ffff8801b813d000 [ 4593.956413] R13: ffffffff81ab3940 R14: ffff880057181700 R15: 0000000000000002 [ 4593.956418] FS: 00007fc40d380710(0000) GS:ffff880001e60000(0000) knlGS:0000000000000000 [ 4593.956422] CS: 0010 DS: 002b ES: 002b CR0: 000000008005003b [ 4593.956426] CR2: 0000000000000018 CR3: 00000001ba1d7000 CR4: 00000000000026e0 [ 4593.956429] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 4593.956433] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 4593.956437] Process kvm (pid: 29512, threadinfo ffff8801ba566000, task ffff8801b8003870) [ 4593.956441] Stack: [ 4593.956443] 0000000100000020 ffff880001e63ba0 ffff880001e63ba0 ffff880057181700 [ 4593.956451] <0> ffffffffa0335650 ffffffff81ab3940 ffff880001e63bd8 ffffffffa03350e6 [ 4593.956462] <0> ffff880001e63c40 000000000000024d ffff880057181700 0000000080000000 [ 4593.956474] Call Trace: [ 4593.956478] <IRQ> [ 4593.956488] [<ffffffffa0335650>] ? br_nf_forward_finish+0x0/0x170 [bridge] [ 4593.956496] [<ffffffffa03350e6>] NF_HOOK_THRESH+0x56/0x60 [bridge] [ 4593.956504] [<ffffffffa0335282>] br_nf_forward_arp+0x112/0x120 [bridge] [ 4593.956511] [<ffffffff813f7184>] nf_iterate+0x64/0xa0 [ 4593.956519] [<ffffffffa032f920>] ? br_forward_finish+0x0/0x60 [bridge] [ 4593.956524] [<ffffffff813f722c>] nf_hook_slow+0x6c/0x100 [ 4593.956531] [<ffffffffa032f920>] ? br_forward_finish+0x0/0x60 [bridge] [ 4593.956538] [<ffffffffa032f800>] ? __br_forward+0x0/0xc0 [bridge] [ 4593.956545] [<ffffffffa032f86d>] __br_forward+0x6d/0xc0 [bridge] [ 4593.956550] [<ffffffff813c5d8e>] ? skb_clone+0x3e/0x70 [ 4593.956557] [<ffffffffa032f462>] deliver_clone+0x32/0x60 [bridge] [ 4593.956564] [<ffffffffa032f6b6>] br_flood+0xa6/0xe0 [bridge] [ 4593.956571] [<ffffffffa032f800>] ? __br_forward+0x0/0xc0 [bridge] Don't call nf_bridge_update_protocol() for ARP traffic as skb->nf_bridge isn't used in the ARP case. Reported-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Bart De Schuymer <bdschuym@pandora.be> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-05-11Merge branch 'master' of git://dev.medozas.de/linuxPatrick McHardy
2010-05-11netfilter: xtables: change hotdrop pointer to direct modificationJan Engelhardt
Since xt_action_param is writable, let's use it. The pointer to 'bool hotdrop' always worried (8 bytes (64-bit) to write 1 byte!). Surprisingly results in a reduction in size: text data bss filename 5457066 692730 357892 vmlinux.o-prev 5456554 692730 357892 vmlinux.o Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2010-05-11netfilter: xtables: deconstify struct xt_action_param for matchesJan Engelhardt
In future, layer-3 matches will be an xt module of their own, and need to set the fragoff and thoff fields. Adding more pointers would needlessy increase memory requirements (esp. so for 64-bit, where pointers are wider). Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2010-05-11netfilter: xtables: substitute temporary defines by final nameJan Engelhardt
2010-05-11netfilter: xtables: combine struct xt_match_param and xt_target_paramJan Engelhardt
The structures carried - besides match/target - almost the same data. It is possible to combine them, as extensions are evaluated serially, and so, the callers end up a little smaller. text data bss filename -15318 740 104 net/ipv4/netfilter/ip_tables.o +15286 740 104 net/ipv4/netfilter/ip_tables.o -15333 540 152 net/ipv6/netfilter/ip6_tables.o +15269 540 152 net/ipv6/netfilter/ip6_tables.o Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2010-05-10Merge branch 'master' of /repos/git/net-next-2.6Patrick McHardy
Conflicts: net/bridge/br_device.c net/bridge/br_forward.c Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-05-06bridge: make bridge support netpollWANG Cong
Based on the previous patch, make bridge support netpoll by: 1) implement the 2 methods to support netpoll for bridge; 2) modify netpoll during forwarding packets via bridge; 3) disable netpoll support of bridge when a netpoll-unabled device is added to bridge; 4) enable netpoll support when all underlying devices support netpoll. Cc: David Miller <davem@davemloft.net> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Stephen Hemminger <shemminger@linux-foundation.org> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: WANG Cong <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27bridge: multicast_flood cleanupstephen hemminger
Move some declarations around to make it clearer which variables are being used inside loop. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27bridge: multicast port group RCU fixstephen hemminger
The recently introduced bridge mulitcast port group list was only partially using RCU correctly. It was missing rcu_dereference() and missing the necessary barrier on deletion. The code should have used one of the standard list methods (list or hlist) instead of open coding a RCU based link list. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27bridge: multicast floodstephen hemminger
Fix unsafe usage of RCU. Would never work on Alpha SMP because of lack of rcu_dereference() Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27bridge: simplify multicast_add_routerstephen hemminger
By coding slightly differently, there are only two cases to deal with: add at head and add after previous entry. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27Revert "bridge: Use hlist_for_each_entry_rcu() in br_multicast_add_router()"David S. Miller
This reverts commit ff65e8275f6c96a5eda57493bd84c4555decf7b3. As explained by Stephen Hemminger, the traversal doesn't require RCU handling as we hold a lock. The list addition et al. calls, on the other hand, do. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27bridge: Use hlist_for_each_entry_rcu() in br_multicast_add_router()David S. Miller
Noticed by Michał Mirosław. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27bridge: multicast router list manipulationstephen hemminger
I prefer that the hlist be only accessed through the hlist macro objects. Explicit twiddling of links (especially with RCU) exposes the code to future bugs. Compile tested only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27bridge: use is_multicast_ether_addrstephen hemminger
Use existing inline function. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27bridge: Fix build of ipv6 multicast code.David S. Miller
Based upon a report from Stephen Rothwell: -------------------- net/bridge/br_multicast.c: In function 'br_ip6_multicast_alloc_query': net/bridge/br_multicast.c:469: error: implicit declaration of function 'csum_ipv6_magic' Introduced by commit 08b202b6726459626c73ecfa08fcdc8c3efc76c2 ("bridge br_multicast: IPv6 MLD support") from the net tree. csum_ipv6_magic is declared in net/ip6_checksum.h ... -------------------- Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-26bridge br_multicast: Ensure to initialize BR_INPUT_SKB_CB(skb)->mrouters_only.YOSHIFUJI Hideaki / 吉藤英明
Even with commit 32dec5dd0233ebffa9cae25ce7ba6daeb7df4467 ("bridge br_multicast: Don't refer to BR_INPUT_SKB_CB(skb)->mrouters_only without IGMP snooping."), BR_INPUT_SKB_CB(skb)->mrouters_only is not appropriately initialized if IGMP/MLD snooping support is compiled and disabled, so we can see garbage. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-23bridge br_multicast: IPv6 MLD support.YOSHIFUJI Hideaki
