path: root/net/bridge/br_sysfs_br.c
2011-10-06bridge: allow forwarding some link local framesstephen hemminger
This is based on an earlier patch by Nick Carter with comments by David Lamparter but with some refinements. Thanks for their patience this is a confusing area with overlap of standards, user requirements, and compatibility with earlier releases. It adds a new sysfs attribute /sys/class/net/brX/bridge/group_fwd_mask that controls forwarding of frames with address of: 01-80-C2-00-00-0X The default setting has no forwarding to retain compatibility. One change from earlier releases is that forwarding of group addresses is not dependent on STP being enabled or disabled. This choice was made based on interpretation of tie 802.1 standards. I expect complaints will arise because of this, but better to follow the standard than continue acting incorrectly by default. The filtering mask is writeable, but only values that don't forward known control frames are allowed. It intentionally blocks attempts to filter control protocols. For example: writing a 8 allows forwarding 802.1X PAE addresses which is the most common request. Reported-by: David Lamparter <equinox@diac24.net> Original-patch-by: Nick Carter <ncarter100@gmail.com> Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Tested-by: Benjamin Poirier <benjamin.poirier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-04bridge: range check STP parametersstephen hemminger
Apply restrictions on STP parameters based 802.1D 1998 standard. * Fixes missing locking in set path cost ioctl * Uses common code for both ioctl and sysfs This is based on an earlier patch Sasikanth V but with overhaul. Note: 1. It does NOT enforce the restriction on the relationship max_age and forward delay or hello time because in existing implementation these are set as independant operations. 2. If STP is disabled, there is no restriction on forward delay 3. No restriction on holding time because users use Linux code to act as hub or be sticky. 4. Although standard allow 0-255, Linux only allows 0-63 for port priority because more bits are reserved for port number. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-02bridge: add per bridge device controls for invoking iptablesPatrick McHardy
Support more fine grained control of bridge netfilter iptables invocation by adding seperate brnf_call_*tables parameters for each device using the sysfs interface. Packets are passed to layer 3 netfilter when either the global parameter or the per bridge parameter is enabled. Acked-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-05-21sysfs: add struct file* to bin_attr callbacksChris Wright
This allows bin_attr->read,write,mmap callbacks to check file specific data (such as inode owner) as part of any privilege validation. Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-02-28bridge: Add multicast count/interval sysfs entriesHerbert Xu
This patch allows the user to the IGMP parameters related to the snooping function of the bridge. This includes various time values and retransmission limits. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-28bridge: Add hash elasticity/max sysfs entriesHerbert Xu
This patch allows the user to control the hash elasticity/max parameters. The elasticity setting does not take effect until the next new multicast group is added. At which point it is checked and if after rehashing it still can't be satisfied then snooping will be disabled. The max setting on the other hand takes effect immediately. It must be a power of two and cannot be set to a value less than the current number of multicast group entries. This is the only way to shrink the multicast hash. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-28bridge: Add multicast_snooping sysfs toggleHerbert Xu
This patch allows the user to disable IGMP snooping completely through a sysfs toggle. It also allows the user to reenable snooping when it has been automatically disabled due to hash collisions. If the collisions have not been resolved however the system will refuse to reenable snooping. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-28bridge: Add multicast_router sysfs entriesHerbert Xu
This patch allows the user to forcibly enable/disable ports as having multicast routers attached. A port with a multicast router will receive all multicast traffic. The value 0 disables it completely. The default is 1 which lets the system automatically detect the presence of routers (currently this is limited to picking up queries), and 2 means that the port will always receive all multicast traffic. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29net: Move && and || to end of previous lineJoe Perches
Not including net/atm/ Compiled tested x86 allyesconfig only Added a > 80 column line or two, which I ignored. Existing checkpatch plaints willfully, cheerfully ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-18net: Fix bridgeing sysfs handling of rtnl_lockEric W. Biederman
Holding rtnl_lock when we are unregistering the sysfs files can deadlock if we unconditionally take rtnl_lock in a sysfs file. So fix it with the now familiar patter of: rtnl_trylock and syscall_restart() Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-12netdevice: safe convert to netdev_priv() #part-4Wang Chen
We have some reasons to kill netdev->priv: 1. netdev->priv is equal to netdev_priv(). 2. netdev_priv() wraps the calculation of netdev->priv's offset, obviously netdev_priv() is more flexible than netdev->priv. But we cann't kill netdev->priv, because so many drivers reference to it directly. This patch is a safe convert for netdev->priv to netdev_priv(netdev). Since all of the netdev->priv is only for read. But it is too big to be sent in one mail. I split it to 4 parts and make every part smaller than 100,000 bytes, which is max size allowed by vger. Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-08bridge: don't allow setting hello time to zeroStephen Hemminger
Dushan Tcholich reports that on his system ksoftirqd can consume between %6 to %10 of cpu time, and cause ~200 context switches per second. He then correlated this with a report by bdupree@techfinesse.com: http://marc.info/?l=linux-kernel&m=119613299024398&w=2 and the culprit cause seems to be starting the bridge interface. In particular, when starting the bridge interface, his scripts are specifying a hello timer interval of "0". The bridge hello time can't be safely set to values less than 1 second, otherwise it is possible to end up with a runaway timer. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-05net: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-24Kobject: convert remaining kobject_unregister() to kobject_put()Greg Kroah-Hartman
There is no need for kobject_unregister() anymore, thanks to Kay's kobject cleanup changes, so replace all instances of it with kobject_put(). Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24Kobject: change net/bridge to use kobject_create_and_addGreg Kroah-Hartman
The kobject in the bridge code is only used for registering with sysfs, not for any lifespan rules. This patch changes it to be only a pointer and use the simpler api for this kind of thing. Cc: Stephen Hemminger <shemminger@linux-foundation.org> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12kobjects: fix up improper use of the kobject name fieldGreg Kroah-Hartman
A number of different drivers incorrect access the kobject name field directly. This is not correct as the name might not be in the array. Use the proper accessor function instead.
2007-08-19missing return in bridge sysfs codeAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-14[BRIDGE]: sysfs locking fix.Stephen Hemminger
The stp change code generates "sleeping function called from invalid context" because rtnl_lock() called with BH disabled. This fixes it by not acquiring then dropping the bridge lock. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-11sysfs: add parameter "struct bin_attribute *" in .read/.write methods for ↵Zhang Rui
sysfs binary attributes Well, first of all, I don't want to change so many files either. What I do: Adding a new parameter "struct bin_attribute *" in the .read/.write methods for the sysfs binary attributes. In fact, only the four lines change in fs/sysfs/bin.c and include/linux/sysfs.h do the real work. But I have to update all the files that use binary attributes to make them compatible with the new .read and .write methods. I'm not sure if I missed any. :( Why I do this: For a sysfs attribute, we can get a pointer pointing to the struct attribute in the .show/.store method, while we can't do this for the binary attributes. I don't know why this is different, but this does make it not so handy to use the binary attributes as the regular ones. So I think this patch is reasonable. :) Who benefits from it: The patch that exposes ACPI tables in sysfs requires such an improvement. All the table binary attributes share the same .read method. Parameter "struct bin_attribute *" is used to get the table signature and instance number which are used to distinguish different ACPI table binary attributes. Without this parameter, we need to offer different .read methods for different ACPI table binary attributes. This is impossible as there are various ACPI tables on different platforms, and we don't know what they are until they are loaded. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-11sysfs: kill unnecessary attribute->ownerTejun Heo
sysfs is now completely out of driver/module lifetime game. After deletion, a sysfs node doesn't access anything outside sysfs proper, so there's no reason to hold onto the attribute owners. Note that often the wrong modules were accounted for as owners leading to accessing removed modules. This patch kills now unnecessary attribute->owner. Note that with this change, userland holding a sysfs node does not prevent the backing module from being unloaded. For more info regarding lifetime rule cleanup, please read the following message. http://article.gmane.org/gmane.linux.kernel/510293 (tweaked by Greg to not delete the field just yet, to make it easier to merge things properly.) Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-25[BRIDGE]: Missing rtnl.Stephen Hemminger
Writing to /sys/class/net/brX/bridge/stp_state causes a warning because RTNL is not held when call br_stp_if.c Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25bridge: add support for user mode STPStephen Hemminger
This patchset based on work by Aji_Srinivas@emc.com provides allows spanning tree to be controled from userspace. Like hotplug, it uses call_usermodehelper when spanning tree is enabled so there is no visible API change. If call to start usermode STP fails it falls back to existing kernel STP. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
2007-04-25bridge: add sysfs hook to flush forwarding tableStephen Hemminger
The RSTP daemon needs to be able to flush all dynamic forwarding entries in the case of topology change. This is a temporary interface. It will change to a netlink interface before RSTP daemon is officially released. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
2007-02-10[NET] BRIDGE: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-07Network: convert network devices to use struct device instead of class_deviceGreg Kroah-Hartman
This lets the network core have the ability to handle suspend/resume issues, if it wants to. Thanks to Frederik Deweerdt <frederik.deweerdt@gmail.com> for the arm driver fixes. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-25[BRIDGE]: correct print message typoRandy Dunlap
Correct message typo/spello. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[BRIDGE]: allow show/store of group multicast addressStephen Hemminger
Bridge's communicate with each other using Spanning Tree Protocol over a standard multicast address. There are times when testing or layering bridges over existing topologies or tunnels, when it is useful to use alternative multicast addresses for STP packets. The 802.1d standard has some unused addresses, that can be used for this. This patch is restrictive in that it only allows one of the possible addresses in the standard. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-11[PATCH] capable/capability.h (net/)Randy Dunlap
net: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
