2019-05-30 | treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 152 | Thomas Gleixner | |
Based on 1 normalized pattern(s): this program is free software you can redistribute it and or modify it under the terms of the gnu general public license as published by the free software foundation either version 2 of the license or at your option any later version extracted by the scancode license scanner the SPDX license identifier GPL-2.0-or-later has been chosen to replace the boilerplate/reference in 3029 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Allison Randal <allison@lohutok.net> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190527070032.746973796@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> | |||
2019-04-27 | netlink: make validation more configurable for future strictness | Johannes Berg | |
We currently have two levels of strict validation: 1) liberal (default) - undefined (type >= max) & NLA_UNSPEC attributes accepted - attribute length >= expected accepted - garbage at end of message accepted 2) strict (opt-in) - NLA_UNSPEC attributes accepted - attribute length >= expected accepted Split out parsing strictness into four different options: * TRAILING - check that there's no trailing data after parsing attributes (in message or nested) * MAXTYPE - reject attrs > max known type * UNSPEC - reject attributes with NLA_UNSPEC policy entries * STRICT_ATTRS - strictly validate attribute size The default for future things should be *everything*. The current *_strict() is a combination of TRAILING and MAXTYPE, and is renamed to _deprecated_strict(). The current regular parsing has none of this, and is renamed to *_parse_deprecated(). Additionally it allows us to selectively set one of the new flags even on old policies. Notably, the UNSPEC flag could be useful in this case, since it can be arranged (by filling in the policy) to not be an incompatible userspace ABI change, but would then going forward prevent forgetting attribute entries. Similar can apply to the POLICY flag. We end up with the following renames: * nla_parse -> nla_parse_deprecated * nla_parse_strict -> nla_parse_deprecated_strict * nlmsg_parse -> nlmsg_parse_deprecated * nlmsg_parse_strict -> nlmsg_parse_deprecated_strict * nla_parse_nested -> nla_parse_nested_deprecated * nla_validate_nested -> nla_validate_nested_deprecated Using spatch, of course: @@ expression TB, MAX, HEAD, LEN, POL, EXT; @@ -nla_parse(TB, MAX, HEAD, LEN, POL, EXT) +nla_parse_deprecated(TB, MAX, HEAD, LEN, POL, EXT) @@ expression NLH, HDRLEN, TB, MAX, POL, EXT; @@ -nlmsg_parse(NLH, HDRLEN, TB, MAX, POL, EXT) +nlmsg_parse_deprecated(NLH, HDRLEN, TB, MAX, POL, EXT) @@ expression NLH, HDRLEN, TB, MAX, POL, EXT; @@ -nlmsg_parse_strict(NLH, HDRLEN, TB, MAX, POL, EXT) +nlmsg_parse_deprecated_strict(NLH, HDRLEN, TB, MAX, POL, EXT) @@ expression TB, MAX, NLA, POL, EXT; @@ -nla_parse_nested(TB, MAX, NLA, POL, EXT) +nla_parse_nested_deprecated(TB, MAX, NLA, POL, EXT) @@ expression START, MAX, POL, EXT; @@ -nla_validate_nested(START, MAX, POL, EXT) +nla_validate_nested_deprecated(START, MAX, POL, EXT) @@ expression NLH, HDRLEN, MAX, POL, EXT; @@ -nlmsg_validate(NLH, HDRLEN, MAX, POL, EXT) +nlmsg_validate_deprecated(NLH, HDRLEN, MAX, POL, EXT) For this patch, don't actually add the strict, non-renamed versions yet so that it breaks compile if I get it wrong. Also, while at it, make nla_validate and nla_parse go down to a common __nla_validate_parse() function to avoid code duplication. Ultimately, this allows us to have very strict validation for every new caller of nla_parse()/nlmsg_parse() etc as re-introduced in the next patch, while existing things will continue to work as is. In effect then, this adds fully strict validation for any new command. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> | |||
2019-04-27 | netlink: make nla_nest_start() add NLA_F_NESTED flag | Michal Kubecek | |
Even if the NLA_F_NESTED flag was introduced more than 11 years ago, most netlink based interfaces (including recently added ones) are still not setting it in kernel generated messages. Without the flag, message parsers not aware of attribute semantics (e.g. wireshark dissector or libmnl's mnl_nlmsg_fprintf()) cannot recognize nested attributes and won't display the structure of their contents. Unfortunately we cannot just add the flag everywhere as there may be userspace applications which check nlattr::nla_type directly rather than through a helper masking out the flags. Therefore the patch renames nla_nest_start() to nla_nest_start_noflag() and introduces nla_nest_start() as a wrapper adding NLA_F_NESTED. The calls which add NLA_F_NESTED manually are rewritten to use nla_nest_start(). Except for changes in include/net/netlink.h, the patch was generated using this semantic patch: @@ expression E1, E2; @@ -nla_nest_start(E1, E2) +nla_nest_start_noflag(E1, E2) @@ expression E1, E2; @@ -nla_nest_start_noflag(E1, E2 | NLA_F_NESTED) +nla_nest_start(E1, E2) Signed-off-by: Michal Kubecek <mkubecek@suse.cz> Acked-by: Jiri Pirko <jiri@mellanox.com> Acked-by: David Ahern <dsahern@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> | |||
2017-10-29 | bridge: netlink: make setlink/dellink notifications more accurate | Nikolay Aleksandrov | |
Before this patch we had cases that either sent notifications when there were in fact no changes (e.g. non-existent vlan delete) or didn't send notifications when there were changes (e.g. vlan add range with an error in the middle, port flags change + vlan update error). This patch sends down a boolean to the functions setlink/dellink use and if there is even a single configuration change (port flag, vlan add/del, port state) then we always send a notification. This is all done to keep backwards compatibility with the opportunistic vlan delete, where one could specify a vlan range that has missing vlans inside and still everything in that range will be cleared, this is mostly used to clear the whole vlan config with a single call, i.e. range 1-4094. Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com> Acked-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: David S. Miller <davem@davemloft.net> | |||
2017-04-13 | netlink: pass extended ACK struct to parsing functions | Johannes Berg | |
Pass the new extended ACK reporting struct to all of the generic netlink parsing functions. For now, pass NULL in almost all callers (except for some in the core.) Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> | |||
2017-02-08 | bridge: vlan tunnel id info range fill size calc cleanups | Roopa Prabhu | |
This fixes a bug and cleans up tunnelid range size calculation code by using consistent variable names and checks in size calculation and fill functions. tested for a few cases of vlan-vni range mappings: (output from patched iproute2): $bridge vlan showtunnel port vid tunid vxlan0 100-105 1000-1005 200 2000 210 2100 211-213 2100-2102 214 2104 216-217 2108-2109 219 2119 Fixes: efa5356b0d97 ("bridge: per vlan dst_metadata netlink support") Reported-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Roopa Prabhu <roopa@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net> | |||
2017-02-07 | bridge: remove unnecessary check for vtbegin in br_fill_vlan_tinfo_range | Roopa Prabhu | |
vtbegin should not be NULL in this function, Its already checked by the caller. this should silence the below smatch complaint: net/bridge/br_netlink_tunnel.c:144 br_fill_vlan_tinfo_range() error: we previously assumed 'vtbegin' could be null (see line 130) net/bridge/br_netlink_tunnel.c 129 130 if (vtbegin && vtend && (vtend->vid - vtbegin->vid) > 0) { ^^^^^^^ Check for NULL. Fixes: efa5356b0d97 ("bridge: per vlan dst_metadata netlink support") Reported-By: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Roopa Prabhu <roopa@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net> | |||
2017-02-07 | bridge: tunnel: fix attribute checks in br_parse_vlan_tunnel_info | Nikolay Aleksandrov | |
These checks should go after the attributes have been parsed otherwise we're using tb uninitialized. Fixes: efa5356b0d97 ("bridge: per vlan dst_metadata netlink support") Reported-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net> | |||
2017-02-03 | bridge: per vlan dst_metadata netlink support | Roopa Prabhu | |
This patch adds support to attach per vlan tunnel info dst metadata. This enables bridge driver to map vlan to tunnel_info at ingress and egress. It uses the kernel dst_metadata infrastructure. The initial use case is vlan to vni bridging, but the api is generic to extend to any tunnel_info in the future: - Uapi to configure/unconfigure/dump per vlan tunnel data - netlink functions to configure vlan and tunnel_info mapping - Introduces bridge port flag BR_LWT_VLAN to enable attach/detach dst_metadata to bridged packets on ports. off by default. - changes to existing code is mainly refactor some existing vlan handling netlink code + hooks for new vlan tunnel code - I have kept the vlan tunnel code isolated in separate files. - most of the netlink vlan tunnel code is handling of vlan-tunid ranges (follows the vlan range handling code). To conserve space vlan-tunid by default are always dumped in ranges if applicable. Use case: example use for this is a vxlan bridging gateway or vtep which maps vlans to vn-segments (or vnis). iproute2 example (patched and pruned iproute2 output to just show relevant fdb entries): example shows same host mac learnt on two vni's and vlan 100 maps to vni 1000, vlan 101 maps to vni 1001 before (netdev per vni): $bridge fdb show | grep "00:02:00:00:00:03" 00:02:00:00:00:03 dev vxlan1001 vlan 101 master bridge 00:02:00:00:00:03 dev vxlan1001 dst 12.0.0.8 self 00:02:00:00:00:03 dev vxlan1000 vlan 100 master bridge 00:02:00:00:00:03 dev vxlan1000 dst 12.0.0.8 self after this patch with collect metdata in bridged mode (single netdev): $bridge fdb show | grep "00:02:00:00:00:03" 00:02:00:00:00:03 dev vxlan0 vlan 101 master bridge 00:02:00:00:00:03 dev vxlan0 src_vni 1001 dst 12.0.0.8 self 00:02:00:00:00:03 dev vxlan0 vlan 100 master bridge 00:02:00:00:00:03 dev vxlan0 src_vni 1000 dst 12.0.0.8 self CC: Nikolay Aleksandrov <nikolay@cumulusnetworks.com> Signed-off-by: Roopa Prabhu <roopa@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net> |
