[ Upstream commit e166e4fdaced850bee3d5ee12a5740258fb30587 ]
Since Commit 21d1196a35f5 ("ipv4: set transport header earlier"),
skb->transport_header has been always set before entering INET
netfilter. This patch is to set skb->transport_header for bridge
before entering INET netfilter by bridge-nf-call-iptables.
It also fixes an issue that sctp_error() couldn't compute a right
csum due to unset skb->transport_header.
Fixes: e6d8b64b34aa ("net: sctp: fix and consolidate SCTP checksumming code")
Reported-by: Li Shuang <shuali@redhat.com>
Suggested-by: Pablo Neira Ayuso <pablo@netfilter.org>
Signed-off-by: Xin Long <lucien.xin@gmail.com>
Acked-by: Florian Westphal <fw@strlen.de>
Signed-off-by: Sasha Levin (Microsoft) <sashal@kernel.org>
[ Upstream commit 8e2f311a68494a6677c1724bdcb10bada21af37c ]
Following command:
iptables -D FORWARD -m physdev ...
causes connectivity loss in some setups.
Reason is that iptables userspace will probe kernel for the module revision
of the physdev patch, and physdev has an artificial dependency on
br_netfilter (xt_physdev use makes no sense unless a br_netfilter module
is loaded).
This causes the "phydev" module to be loaded, which in turn enables the
"call-iptables" infrastructure.
bridged packets might then get dropped by the iptables ruleset.
The better fix would be to change the "call-iptables" defaults to 0 and
enforce explicit setting to 1, but that breaks backwards compatibility.
This does the next best thing: add a request_module call to checkentry.
This was a stray '-D ... -m physdev' won't activate br_netfilter
anymore.
state
[ Upstream commit 4c84edc11b76590859b1e45dd676074c59602dc4 ]
When handling DNAT'ed packets on a bridge device, the neighbour cache entry
from lookup was used without checking its state. It means that a cache entry
in the NUD_STALE state will be used directly instead of entering the NUD_DELAY
state to confirm the reachability of the neighbor.
This problem becomes worse after commit 2724680bceee ("neigh: Keep neighbour
cache entries if number of them is small enough."), since all neighbour cache
entries in the NUD_STALE state will be kept in the neighbour table as long as
the number of cache entries does not exceed the value specified in gc_thresh1.
This commit validates the state of a neighbour cache entry before using
the entry.
Signed-off-by: JianJhen Chen <kchen@synology.com>
Reviewed-by: JinLin Chen <jlchen@synology.com>
For starters, the bridge netfilter code registers operations that
are invoked any time nh_hook is called. Specifically, ip_sabotage_in
watches for nested calls for NF_INET_PRE_ROUTING when a bridge is in
the stack.
Packet wise, the bridge netfilter hook runs first. br_nf_pre_routing
allocates nf_bridge, sets in_prerouting to 1 and calls NF_HOOK for
NF_INET_PRE_ROUTING. It's finish function, br_nf_pre_routing_finish,
then resets in_prerouting flag to 0 and the packet continues up the
stack. The packet eventually makes it to the VRF driver and it invokes
nf_hook for NF_INET_PRE_ROUTING in case any rules have been added against
the vrf device.
Because of the registered operations the call to nf_hook causes
ip_sabotage_in to be invoked. That function sees the nf_bridge on the
skb and that in_prerouting is not set. Thinking it is an invalid nested
call it steals (drops) the packet.
Update ip_sabotage_in to recognize that the bridge or one of its upper
devices (e.g., vlan) can be enslaved to a VRF (L3 master device) and
allow the packet to go through the nf_hook a second time.
Fixes: 73e20b761acf ("net: vrf: Add support for PREROUTING rules on vrf device")
Reported-by: D'Souza, Nelson <ndsouza@ciena.com>
Signed-off-by: David Ahern <dsahern@gmail.com>
Netfilter exposes standard hook priorities in case of ipv4, ipv6 and
arp but not in case of bridge.
This patch exposes the hook priority values of the bridge family (which are
different from the formerly mentioned) via uapi so that they can be used by
user-space applications just like the others.
Signed-off-by: Máté Eckl <ecklm94@gmail.com>
In the ip_rcv, IPSTATS_MIB_CSUMERRORS is increased when
checksum error is occurred.
bridge netfilter routine should increase IPSTATS_MIB_CSUMERRORS.
Signed-off-by: Taehee Yoo <ap420073@gmail.com>
struct net contains:
struct nf_hook_entries __rcu *hooks[NFPROTO_NUMPROTO][NF_MAX_HOOKS];
which store the hook entry point locations for the various protocol
families and the hooks.
Using array results in compact c code when doing accesses, i.e.
x = rcu_dereference(net->nf.hooks[pf][hook]);
but its also wasting a lot of memory, as most families are
not used.
So split the array into those families that are used, which
are only 5 (instead of 13). In most cases, the 'pf' argument is
constant, i.e. gcc removes switch statement.
struct net before:
/* size: 5184, cachelines: 81, members: 46 */
after:
/* size: 4672, cachelines: 73, members: 46 */
This converts the storage and layout of netfilter hook entries from a
linked list to an array. After this commit, hook entries will be
stored adjacent in memory. The next pointer is no longer required.
The ops pointers are stored at the end of the array as they are only
used in the register/unregister path and in the legacy br_netfilter code.
nf_unregister_net_hooks() is slower than needed as it just calls
nf_unregister_net_hook in a loop (i.e. at least n synchronize_net()
calls), this will be addressed in followup patch.
Test setup:
- ixgbe 10gbit
- netperf UDP_STREAM, 64 byte packets
- 5 hooks: (raw + mangle prerouting, mangle+filter input, inet filter):
empty mangle and raw prerouting, mangle and filter input hooks:
353.9
this patch:
364.2
Signed-off-by: Aaron Conole <aconole@bytheb.org>
We no longer place these on a list so they can be const.
refcount_t type and corresponding API should be
used instead of atomic_t when the variable is used as
a reference counter. This allows to avoid accidental
refcounter overflows that might lead to use-after-free
situations.
Signed-off-by: Elena Reshetova <elena.reshetova@intel.com>
Signed-off-by: Hans Liljestrand <ishkamiel@gmail.com>
Signed-off-by: David Windsor <dwindsor@gmail.com>
drivers/net/ethernet/broadcom/genet/bcmmii.c
drivers/net/hyperv/netvsc.c
kernel/bpf/hashtab.c
Almost entirely overlapping changes.
Pablo Neira Ayuso says:
Netfilter/IPVS updates for net-next
The following patchset contains Netfilter/IPVS updates for your
net-next tree. A couple of new features for nf_tables, and unsorted
cleanups and incremental updates for the Netfilter tree. More
specifically, they are:
1) Allow to check for TCP option presence via nft_exthdr, patch
from Phil Sutter.
2) Add symmetric hash support to nft_hash, from Laura Garcia Liebana.
3) Use pr_cont() in ebt_log, from Joe Perches.
4) Remove some dead code in arp_tables reported via static analysis
tool, from Colin Ian King.
5) Consolidate nf_tables expression validation, from Liping Zhang.
6) Consolidate set lookup via nft_set_lookup().
7) Remove unnecessary rcu read lock side in bridge netfilter, from
Florian Westphal.
8) Remove unused variable in nf_reject_ipv4, from Tahee Yoo.
9) Pass nft_ctx struct to object initialization indirections, from
Florian Westphal.
10) Add code to integrate conntrack helper into nf_tables, also from
Florian.
11) Allow to check if interface index or name exists via
NFTA_FIB_F_PRESENT, from Phil Sutter.
12) Simplify resolve_normal_ct(), from Florian.
13) Use per-limit spinlock in nft_limit and xt_limit, from Liping Zhang.
14) Use rwlock in nft_set_rbtree set, also from Liping Zhang.
15) One patch to remove a useless printk at netns init path in ipvs,
and several patches to document IPVS knobs.
16) Use refcount_t for reference counter in the Netfilter/IPVS code,
from Elena Reshetova.
Netfilter fixes for net
The following patchset contains Netfilter fixes for your net tree, a
rather large batch of fixes targeted to nf_tables, conntrack and bridge
netfilter. More specifically, they are:
1) Don't track fragmented packets if the socket option IP_NODEFRAG is set.
From Florian Westphal.
2) SCTP protocol tracker assumes that ICMP error messages contain the
checksum field, what results in packet drops. From Ying Xue.
3) Fix inconsistent handling of AH traffic from nf_tables.
4) Fix new bitmap set representation with big endian. Fix mismatches in
nf_tables due to incorrect big endian handling too. Both patches
from Liping Zhang.
5) Bridge netfilter doesn't honor maximum fragment size field, cap to
largest fragment seen. From Florian Westphal.
6) Fake conntrack entry needs to be aligned to 8 bytes since the 3 LSB
bits are now used to store the ctinfo. From Steven Rostedt.
7) Fix element comments with the bitmap set type. Revert the flush
field in the nft_set_iter structure, not required anymore after
fixing up element comments.
8) Missing error on invalid conntrack direction from nft_ct, also from
Liping Zhang.
Andreas reports kernel oops during rmmod of the br_netfilter module.
Hannes debugged the oops down to a NULL rt6info->rt6i_indev.
Problem is that br_netfilter has the nasty concept of adding a fake
rtable to skb->dst; this happens in a br_netfilter prerouting hook.
A second hook (in bridge LOCAL_IN) is supposed to remove these again
before the skb is handed up the stack.
However, on module unload hooks get unregistered which means an
skb could traverse the prerouting hook that attaches the fake_rtable,
while the 'fake rtable remove' hook gets removed from the hooklist
immediately after.
Fixes: 34666d467cbf1e2e3c7 ("netfilter: bridge: move br_netfilter out of the core")
Reported-by: Andreas Karis <akaris@redhat.com>
Debugged-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Acked-by: Pablo Neira Ayuso <pablo@netfilter.org>
consider a bridge with mtu 9000, but end host sending smaller
packets to another host with mtu < 9000.
In this case, after reassembly, bridge+defrag would refragment,
and then attempt to send the reassembled packet as long as it
was below 9k.
Instead we have to cap by the largest fragment size seen.
as comment says, the function is always called with rcu read lock held.
The following patchset contains accumulated Netfilter fixes for your
net tree:
1) Ensure quota dump and reset happens iff we can deliver numbers to
userspace.
2) Silence splat on incorrect use of smp_processor_id() from nft_queue.
3) Fix an out-of-bound access reported by KASAN in
nf_tables_rule_destroy(), patch from Florian Westphal.
4) Fix layer 4 checksum mangling in the nf_tables payload expression
with IPv6.
5) Fix a race in the CLUSTERIP target from control plane path when two
threads run to add a new configuration object. Serialize invocations
of clusterip_config_init() using spin_lock. From Xin Long.
6) Call br_nf_pre_routing_finish_bridge_finish() once we are done with
the br_nf_pre_routing_finish() hook. From Artur Molchanov.
Problem:
br_nf_pre_routing_finish() calls itself instead of
br_nf_pre_routing_finish_bridge(). Due to this bug reverse path filter drops
packets that go through bridge interface.
User impact:
Local docker containers with bridge network can not communicate with each
other.
Fixes: c5136b15ea36 ("netfilter: bridge: add and use br_nf_hook_thresh")
Signed-off-by: Artur Molchanov <artur.molchanov@synesis.ru>
This was entirely automated, using the script by Al:
PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>'
sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \
$(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h)
to do the replacement at the end of the merge window.
Requested-by: Al Viro <viro@zeniv.linux.org.uk>
This is to facilitate converting from a singly-linked list to an array
of elements.
This allows easier future refactoring.
Make struct pernet_operations::id unsigned.
There are 2 reasons to do so:
1)
This field is really an index into an zero based array and
thus is unsigned entity. Using negative value is out-of-bound
access by definition.
2)
On x86_64 unsigned 32-bit data which are mixed with pointers
via array indexing or offsets added or subtracted to pointers
are preffered to signed 32-bit data.
"int" being used as an array index needs to be sign-extended
to 64-bit before being used.
void f(long *p, int i)
g(p[i]);
roughly translates to
movsx rsi, esi
mov rdi, [rsi+...]
call g
MOVSX is 3 byte instruction which isn't necessary if the variable is
unsigned because x86_64 is zero extending by default.
Now, there is net_generic() function which, you guessed it right, uses
"int" as an array index:
static inline void *net_generic(const struct net *net, int id)
ptr = ng->ptr[id - 1];
And this function is used a lot, so those sign extensions add up.
Patch snipes ~1730 bytes on allyesconfig kernel (without all junk
messing with code generation):
add/remove: 0/0 grow/shrink: 70/598 up/down: 396/-2126 (-1730)
Unfortunately some functions actually grow bigger.
This is a semmingly random artefact of code generation with register
allocator being used differently. gcc decides that some variable
needs to live in new r8+ registers and every access now requires REX
prefix. Or it is shifted into r12, so [r12+0] addressing mode has to be
used which is longer than [r8]
However, overall balance is in negative direction:
function old new delta
nfsd4_lock 3886 3959 +73
tipc_link_build_proto_msg 1096 1140 +44
mac80211_hwsim_new_radio 2776 2808 +32
tipc_mon_rcv 1032 1058 +26
svcauth_gss_legacy_init 1413 1429 +16
tipc_bcbase_select_primary 379 392 +13
nfsd4_exchange_id 1247 1260 +13
nfsd4_setclientid_confirm 782 793 +11
put_client_renew_locked 494 480 -14
ip_set_sockfn_get 730 716 -14
geneve_sock_add 829 813 -16
nfsd4_sequence_done 721 703 -18
nlmclnt_lookup_host 708 686 -22
nfsd4_lockt 1085 1063 -22
nfs_get_client 1077 1050 -27
tcf_bpf_init 1106 1076 -30
nfsd4_encode_fattr 5997 5930 -67
Total: Before=154856051, After=154854321, chg -0.00%
This field is only useful for nf_queue, so store it in the
nf_queue_entry structure instead, away from the core path. Pass
hook_head to nf_hook_slow().
Since we always have a valid entry on the first iteration in
nf_iterate(), we can use 'do { ... } while (entry)' loop instead.
NF_STOP is only used by br_netfilter these days, and it can be emulated
with a combination of NF_STOLEN plus explicit call to the ->okfn()
function as Florian suggests.
To retain binary compatibility with userspace nf_queue application, we
have to keep NF_STOP around, so libnetfilter_queue userspace userspace
applications still work if they use NF_STOP for some exotic reason.
Out of tree modules using NF_STOP would break, but we don't care about
those.
Patch c5136b15ea36 ("netfilter: bridge: add and use br_nf_hook_thresh")
introduced br_nf_hook_thresh().
Replace NF_HOOK_THRESH() by br_nf_hook_thresh from
br_nf_forward_finish(), so we have no more callers for this macro.
As a result, state->thresh and explicit thresh parameter in the hook
state structure is not required anymore. And we can get rid of
skip-hook-under-thresh loop in nf_iterate() in the core path that is
only used by br_netfilter to search for the filter hook.
Suggested-by: Florian Westphal <fw@strlen.de>
The netfilter hook list never uses the prev pointer, and so can be trimmed to
be a simple singly-linked list.
In addition to having a more light weight structure for hook traversal,
struct net becomes 5568 bytes (down from 6400) and struct net_device becomes
2176 bytes (down from 2240).
This replaces the last uses of NF_HOOK_THRESH().
Followup patch will remove it and rename nf_hook_thresh.
The reason is that inet (non-bridge) netfilter no longer invokes the
hooks from hooks, so we do no longer need the thresh value to skip hooks
with a lower priority.
The bridge netfilter however may need to do this. br_nf_hook_thresh is a
wrapper that is supposed to do this, i.e. only call hooks with a
priority that exceeds NF_BR_PRI_BRNF.
It's used only in the recursion cases of br_netfilter. It invokes
nf_hook_slow while holding an rcu read-side critical section to make a
future cleanup simpler.
ip_skb_dst_mtu uses skb->sk, assuming it is an AF_INET socket (e.g. it
calls ip_sk_use_pmtu which casts sk as an inet_sk).
However, in the case of UDP tunneling, the skb->sk is not necessarily an
inet socket (could be AF_PACKET socket, or AF_UNSPEC if arriving from
tun/tap).
OTOH, the sk passed as an argument throughout IP stack's output path is
the one which is of PMTU interest:
- In case of local sockets, sk is same as skb->sk;
- In case of a udp tunnel, sk is the tunneling socket.
Fix, by passing ip_finish_output's sk to ip_skb_dst_mtu.
This augments 7026b1ddb6 'netfilter: Pass socket pointer down through okfn().'
Signed-off-by: Shmulik Ladkani <shmulik.ladkani@gmail.com>
Reviewed-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Rename IP_INC_STATS_BH() to __IP_INC_STATS(), to
better express this is used in non preemptible context.
This moves bridge hooks to a register-when-needed scheme.
We use a device notifier to register the 'call-iptables' netfilter hooks
only once a bridge gets added.
This means that if the initial namespace uses a bridge, newly created
network namespaces no longer get the PRE_ROUTING ipt_sabotage hook.
It will registered in that network namespace once a bridge is created
within that namespace.
A few modules still use global hooks:
- conntrack
- bridge PF_BRIDGE hooks
- IPVS
- CLUSTER match (deprecated)
- SYNPROXY
As long as these modules are not loaded/used, a new network namespace has
empty hook list and NF_HOOK() will boil down to single list_empty test even
if initial namespace does stateless packet filtering.
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next
This merge resolves conflicts with 75aec9df3a78 ("bridge: Remove
br_nf_push_frag_xmit_sk") as part of Eric Biederman's effort to improve
netns support in the network stack that reached upstream via David's
net-next tree.
net/bridge/br_netfilter_hooks.c
since commit 8405a8fff3f8 ("netfilter: nf_qeueue: Drop queue entries on
nf_unregister_hook") all pending queued entries are discarded.
So we can simply remove all of the owner handling -- when module is
removed it also needs to unregister all its hooks.
With the ARM mini2440_defconfig, the bridge netfilter code gets
built with both CONFIG_NF_DEFRAG_IPV4 and CONFIG_NF_DEFRAG_IPV6
disabled, which leads to a harmless gcc warning:
net/bridge/br_netfilter_hooks.c: In function 'br_nf_dev_queue_xmit':
net/bridge/br_netfilter_hooks.c:792:2: warning: label 'drop' defined but not used [-Wunused-label]
This gets rid of the warning by cleaning up the code to avoid
the respective #ifdefs causing this problem, and replacing them
with if(IS_ENABLED()) checks. I have verified that the resulting
object code is unchanged, and an additional advantage is that
we now get compile coverage of the unused functions in more
configurations.
Fixes: dd302b59bde0 ("netfilter: bridge: don't leak skb in error paths")
Reviewed-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
Now that this compatability function no longer has any callers remove it.
The network namespace is easiliy available in state->net so use it.
Only pass the void *priv parameter out of the nf_hook_ops. That is
all any of the functions are interested now, and by limiting what is
passed it becomes simpler to change implementation details.
This is immediately motivated by the bridge code that chains functions that
call into netfilter. Without passing net into the okfns the bridge code would
need to guess about the best expression for the network namespace to process
packets in.
As net is frequently one of the first things computed in continuation functions
after netfilter has done it's job passing in the desired network namespace is in
many cases a code simplification.
To support this change the function dst_output_okfn is introduced to
simplify passing dst_output as an okfn. For the moment dst_output_okfn
just silently drops the struct net.
Pass a network namespace parameter into the netfilter hooks. At the
call site of the netfilter hooks the path a packet is taking through
the network stack is well known which allows the network namespace to
be easily and reliabily.
This allows the replacement of magic code like
"dev_net(state->in?:state->out)" that appears at the start of most
netfilter hooks with "state->net".
In almost all cases the network namespace passed in is derived
from the first network device passed in, guaranteeing those
paths will not see any changes in practice.
The exceptions are:
xfrm/xfrm_output.c:xfrm_output_resume() xs_net(skb_dst(skb)->xfrm)
ipvs/ip_vs_xmit.c:ip_vs_nat_send_or_cont() ip_vs_conn_net(cp)
ipvs/ip_vs_xmit.c:ip_vs_send_or_cont() ip_vs_conn_net(cp)
ipv4/raw.c:raw_send_hdrinc() sock_net(sk)
ipv6/ip6_output.c:ip6_xmit() sock_net(sk)
ipv6/ndisc.c:ndisc_send_skb() dev_net(skb->dev) not dev_net(dst->dev)
ipv6/raw.c:raw6_send_hdrinc() sock_net(sk)
br_netfilter_hooks.c:br_nf_pre_routing_finish() dev_net(skb->dev) before skb->dev is set to nf_bridge->physindev
In all cases these exceptions seem to be a better expression for the
network namespace the packet is being processed in then the historic
"dev_net(in?in:out)". I am documenting them in case something odd
pops up and someone starts trying to track down what happened.
This is prep work for passing net to the netfilter hooks.
When struct net starts being passed through the ipv4 and ipv6 fragment
routines br_nf_push_frag_xmit will need to take a net parameter.
Prepare br_nf_push_frag_xmit before that is needed and introduce
br_nf_push_frag_xmit_sk for the call sites that still need the old
calling conventions.
This is a prep work for passing struct net through ip_do_fragment and
later the netfilter okfn. Doing this independently makes the later
code changes clearer.
Fix checkpatch.pl "ERROR: do not initialise statics to 0 or NULL" for
all statics explicitly initialized to 0.
Signed-off-by: Bernhard Thaler <bernhard.thaler@wvnet.at>
We can use union for most of the temporary cruft (original ipv4/ipv6
address, source mac, physoutdev) since they're used during different
stages of br netfilter traversal.
Also get rid of the last two ->mask users.
Shrinks struct from 48 to 32 on 64bit arch.
br_nf_dev_queue_xmit must free skb in its error path.
NF_DROP is misleading -- its an okfn, not a netfilter hook.
Fixes: 462fb2af9788a ("bridge : Sanitize skb before it enters the IP stack")
Fixes: efb6de9b4ba00 ("netfilter: bridge: forward IPv6 fragmented packets")
br_nf_ip_fragment() is not needed when neither CONFIG_NF_DEFRAG_IPV4 nor
CONFIG_NF_DEFRAG_IPV6 is set.
struct brnf_frag_data must be available if either CONFIG_NF_DEFRAG_IPV4
or CONFIG_NF_DEFRAG_IPV6 is set.
Fixes: efb6de9b4ba0 ("netfilter: bridge: forward IPv6 fragmented packets")
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Resolve compilation breakage when CONFIG_IPV6 is not set by moving the IPv6
code into a separated br_netfilter_ipv6.c file.
To prepare separation of the IPv6 code into different file.
