Replace all the occurrences of FIELD_SIZEOF() with sizeof_field() except
at places where these are defined. Later patches will remove the unused
definition of FIELD_SIZEOF().
This patch is generated using following script:
EXCLUDE_FILES="include/linux/stddef.h|include/linux/kernel.h"
git grep -l -e "\bFIELD_SIZEOF\b" | while read file;
do
if [[ "$file" =~ $EXCLUDE_FILES ]]; then
continue
fi
sed -i -e 's/\bFIELD_SIZEOF\b/sizeof_field/g' $file;
done
Signed-off-by: Pankaj Bharadiya <pankaj.laxminarayan.bharadiya@intel.com>
Link: https://lore.kernel.org/r/20190924105839.110713-3-pankaj.laxminarayan.bharadiya@intel.com
Co-developed-by: Kees Cook <keescook@chromium.org>
Acked-by: David Miller <davem@davemloft.net> # for net
Most of the bridge device's vlan init bugs come from the fact that its
default pvid is created at the wrong time, way too early in ndo_init()
before the device is even assigned an ifindex. It introduces a bug when the
bridge's dev_addr is added as fdb during the initial default pvid creation
the notification has ifindex/NDA_MASTER both equal to 0 (see example below)
which really makes no sense for user-space[0] and is wrong.
Usually user-space software would ignore such entries, but they are
actually valid and will eventually have all necessary attributes.
It makes much more sense to send a notification *after* the device has
registered and has a proper ifindex allocated rather than before when
there's a chance that the registration might still fail or to receive
it with ifindex/NDA_MASTER == 0. Note that we can remove the fdb flush
from br_vlan_flush() since that case can no longer happen. At
NETDEV_REGISTER br->default_pvid is always == 1 as it's initialized by
br_vlan_init() before that and at NETDEV_UNREGISTER it can be anything
depending why it was called (if called due to NETDEV_REGISTER error
it'll still be == 1, otherwise it could be any value changed during the
device life time).
For the demonstration below a small change to iproute2 for printing all fdb
notifications is added, because it contained a workaround not to show
entries with ifindex == 0.
Command executed while monitoring: $ ip l add br0 type bridge
Before (both ifindex and master == 0):
$ bridge monitor fdb
36:7e:8a:b3:56:ba dev * vlan 1 master * permanent
After (proper br0 ifindex):
e6:2a:ae:7a:b7:48 dev br0 vlan 1 master br0 permanent
v4: move only the default pvid init/deinit to NETDEV_REGISTER/UNREGISTER
v3: send the correct v2 patch with all changes (stub should return 0)
v2: on error in br_vlan_init set br->vlgrp to NULL and return 0 in
the br_vlan_bridge_event stub when bridge vlans are disabled
[0] https://bugzilla.kernel.org/show_bug.cgi?id=204389
Reported-by: michael-dev <michael-dev@fami-braun.de>
Fixes: 5be5a2df40f0 ("bridge: Add filtering support for default_pvid")
Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
Acked-by: Roopa Prabhu <roopa@cumulusnetworks.com>
Based on 1 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license as published by
the free software foundation either version 2 of the license or at
your option any later version
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 3029 file(s).
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190527070032.746973796@linutronix.de
When a bridge port is being deleted, do not dereference it later in
br_vlan_port_event() as it can result in a use-after-free [1] if the RCU
callback was executed before invoking the function.
[1]
[ 129.638551] ==================================================================
[ 129.646904] BUG: KASAN: use-after-free in br_vlan_port_event+0x53c/0x5fd
[ 129.654406] Read of size 8 at addr ffff8881e4aa1ae8 by task ip/483
[ 129.663008] CPU: 0 PID: 483 Comm: ip Not tainted 5.1.0-rc5-custom-02265-ga946bd73daac #1383
[ 129.672359] Hardware name: Mellanox Technologies Ltd. MSN2100-CB2FO/SA001017, BIOS 5.6.5 06/07/2016
[ 129.682484] Call Trace:
[ 129.685242] dump_stack+0xa9/0x10e
[ 129.689068] print_address_description.cold.2+0x9/0x25e
[ 129.694930] kasan_report.cold.3+0x78/0x9d
[ 129.704420] br_vlan_port_event+0x53c/0x5fd
[ 129.728300] br_device_event+0x2c7/0x7a0
[ 129.741505] notifier_call_chain+0xb5/0x1c0
[ 129.746202] rollback_registered_many+0x895/0xe90
[ 129.793119] unregister_netdevice_many+0x48/0x210
[ 129.803384] rtnl_delete_link+0xe1/0x140
[ 129.815906] rtnl_dellink+0x2a3/0x820
[ 129.844166] rtnetlink_rcv_msg+0x397/0x910
[ 129.868517] netlink_rcv_skb+0x137/0x3a0
[ 129.882013] netlink_unicast+0x49b/0x660
[ 129.900019] netlink_sendmsg+0x755/0xc90
[ 129.915758] ___sys_sendmsg+0x761/0x8e0
[ 129.966315] __sys_sendmsg+0xf0/0x1c0
[ 129.988918] do_syscall_64+0xa4/0x470
[ 129.993032] entry_SYSCALL_64_after_hwframe+0x49/0xbe
[ 129.998696] RIP: 0033:0x7ff578104b58
[ 130.073811] Allocated by task 479:
[ 130.077633] __kasan_kmalloc.constprop.5+0xc1/0xd0
[ 130.083008] kmem_cache_alloc_trace+0x152/0x320
[ 130.088090] br_add_if+0x39c/0x1580
[ 130.092005] do_set_master+0x1aa/0x210
[ 130.096211] do_setlink+0x985/0x3100
[ 130.100224] __rtnl_newlink+0xc52/0x1380
[ 130.104625] rtnl_newlink+0x6b/0xa0
[ 130.108541] rtnetlink_rcv_msg+0x397/0x910
[ 130.113136] netlink_rcv_skb+0x137/0x3a0
[ 130.117538] netlink_unicast+0x49b/0x660
[ 130.121939] netlink_sendmsg+0x755/0xc90
[ 130.126340] ___sys_sendmsg+0x761/0x8e0
[ 130.130645] __sys_sendmsg+0xf0/0x1c0
[ 130.134753] do_syscall_64+0xa4/0x470
[ 130.138864] entry_SYSCALL_64_after_hwframe+0x49/0xbe
[ 130.146195] Freed by task 0:
[ 130.149421] __kasan_slab_free+0x125/0x170
[ 130.154016] kfree+0xf3/0x310
[ 130.157349] kobject_put+0x1a8/0x4c0
[ 130.161363] rcu_core+0x859/0x19b0
[ 130.165175] __do_softirq+0x250/0xa26
[ 130.170956] The buggy address belongs to the object at ffff8881e4aa1ae8
which belongs to the cache kmalloc-1k of size 1024
[ 130.184972] The buggy address is located 0 bytes inside of
1024-byte region [ffff8881e4aa1ae8, ffff8881e4aa1ee8)
Fixes: 9c0ec2e7182a ("bridge: support binding vlan dev link state to vlan member bridge ports")
Signed-off-by: Ido Schimmel <idosch@mellanox.com>
Cc: Mike Manning <mmanning@vyatta.att-mail.com>
Acked-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
Acked-by: Mike Manning <mmanning@vyatta.att-mail.com>
In the case of vlan filtering on bridges, the bridge may also have the
corresponding vlan devices as upper devices. A vlan bridge binding mode
is added to allow the link state of the vlan device to track only the
state of the subset of bridge ports that are also members of the vlan,
rather than that of all bridge ports. This mode is set with a vlan flag
rather than a bridge sysfs so that the 8021q module is aware that it
should not set the link state for the vlan device.
If bridge vlan is configured, the bridge device event handling results
in the link state for an upper device being set, if it is a vlan device
with the vlan bridge binding mode enabled. This also sets a
vlan_bridge_binding flag so that subsequent UP/DOWN/CHANGE events for
the ports in that bridge result in a link state update of the vlan
device if required.
The link state of the vlan device is up if there is at least one bridge
port that is a vlan member that is admin & oper up, otherwise its oper
state is IF_OPER_LOWERLAYERDOWN.
Signed-off-by: Mike Manning <mmanning@vyatta.att-mail.com>
When a port device seeks approval of a potential new MAC address, make
sure that should the bridge device end up using this address, all
interested parties would agree with it.
Signed-off-by: Petr Machata <petrm@mellanox.com>
Acked-by: Jiri Pirko <jiri@mellanox.com>
Reviewed-by: Ido Schimmel <idosch@mellanox.com>
Now that we have at least one bool option, we can export all of the
supported bool options via optmask when dumping them.
v2: new patch
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
Use the new boolopt API to add an option which disables learning from
link-local packets. The default is kept as before and learning is
enabled. This is a simple map from a boolopt bit to a bridge private
flag that is tested before learning.
v2: pass NULL for extack via sysfs
We have been adding many new bridge options, a big number of which are
boolean but still take up netlink attribute ids and waste space in the skb.
Recently we discussed learning from link-local packets[1] and decided
yet another new boolean option will be needed, thus introducing this API
to save some bridge nl space.
The API supports changing the value of multiple boolean options at once
via the br_boolopt_multi struct which has an optmask (which options to
set, bit per opt) and optval (options' new values). Future boolean
options will only be added to the br_boolopt_id enum and then will have
to be handled in br_boolopt_toggle/get. The API will automatically
add the ability to change and export them via netlink, sysfs can use the
single boolopt function versions to do the same. The behaviour with
failing/succeeding is the same as with normal netlink option changing.
If an option requires mapping to internal kernel flag or needs special
configuration to be enabled then it should be handled in
br_boolopt_toggle. It should also be able to retrieve an option's current
state via br_boolopt_get.
v2: WARN_ON() on unsupported option as that shouldn't be possible and
also will help catch people who add new options without handling
them for both set and get. Pass down extack so if an option desires
it could set it on error and be more user-friendly.
[1] https://www.spinics.net/lists/netdev/msg532698.html
Currently, an FDB entry only ceases being offloaded when it is deleted.
This changes with VxLAN encapsulation.
Devices capable of performing VxLAN encapsulation usually have only one
FDB table, unlike the software data path which has two - one in the
bridge driver and another in the VxLAN driver.
Therefore, bridge FDB entries pointing to a VxLAN device are only
offloaded if there is a corresponding entry in the VxLAN FDB.
Allow clearing the offload indication in case the corresponding entry
was deleted from the VxLAN FDB.
Reviewed-by: Petr Machata <petrm@mellanox.com>
Bridge options have usually been added as separate fields all over the
net_bridge struct taking up space and ending up in different cache lines.
Let's move them to a single bitfield to save up space and speedup lookups.
This patch adds a simple API for option modifying and retrieving using
bitops and converts the first user of the API - the bridge vlan options
(vlan_enabled and vlan_stats_enabled).
Reviewed-by: Stephen Hemminger <stephen@networkplumber.org>
Do not automatically bail out on sending notifications about activity on
non-user-added FDB entries. Instead, notify about this activity except
for cases where the activity itself originates in a notification, to
avoid sending duplicate notifications.
Acked-by: Ivan Vecera <ivecera@redhat.com>
While handling netdevice events, br_device_event() sometimes uses
br_stp_(disable|enable)_port which unconditionally send a notification,
but then a second notification for the same event is sent at the end of
the br_device_event() function. To avoid sending duplicate notifications
in such cases, check if one has already been sent (i.e.
br_stp_enable/disable_port have been called).
The patch is based on a change by Satish Ashok.
As Roopa noted today the biggest source of problems when configuring
bridge and ports is that the bridge MTU keeps changing automatically on
port events (add/del/changemtu). That leads to inconsistent behaviour
and network config software needs to chase the MTU and fix it on each
such event. Let's improve on that situation and allow for the user to
set any MTU within ETH_MIN/MAX limits, but once manually configured it
is the user's responsibility to keep it correct afterwards.
In case the MTU isn't manually set - the behaviour reverts to the
previous and the bridge follows the minimum MTU.
Recently the bridge was changed to automatically set maximum MTU on port
events (add/del/changemtu) when vlan filtering is enabled, but that
actually changes behaviour in a way which breaks some setups and can lead
to packet drops. In order to still allow that maximum to be set while being
compatible, we add the ability for the user to tune the bridge MTU up to
the maximum when vlan filtering is enabled, but that has to be done
explicitly and all port events (add/del/changemtu) lead to resetting that
MTU to the minimum as before.
Suggested-by: Roopa Prabhu <roopa@cumulusnetworks.com>
Synchronous pernet_operations are not allowed anymore.
All are asynchronous. So, drop the structure member.
Signed-off-by: Kirill Tkhai <ktkhai@virtuozzo.com>
If the bridge is allowing multiple VLANs, some VLANs may have
different MTUs. Instead of choosing the minimum MTU for the
bridge interface, choose the maximum MTU of the bridge members.
With this the user only needs to set a larger MTU on the member
ports that are participating in the large MTU VLANS.
Signed-off-by: Chas Williams <3chas3@gmail.com>
Reviewed-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
These pernet_operations are similar to bond_net_ops. Exit method
unregisters all net bridge devices, and it looks like another
pernet_operations are not interested in foreign net bridge list.
So, it's possible to mark them async.
Currently the bridge device doesn't generate any notifications upon vlan
modifications on itself because it doesn't use the generic bridge
notifications.
With the recent changes we know if anything was modified in the vlan config
thus we can generate a notification when necessary for the bridge device
so add support to br_ifinfo_notify() similar to how other combined
functions are done - if port is present it takes precedence, otherwise
notify about the bridge. I've explicitly marked the locations where the
notification should be always for the port by setting bridge to NULL.
I've also taken the liberty to rearrange each modified function's local
variables in reverse xmas tree as well.
When a new static FDB is added to the bridge a notification is sent to
the driver for offload. In case of successful offload the driver should
notify the bridge back, which in turn should mark the FDB as offloaded.
Currently, externally learned is equivalent for being offloaded which is
not correct due to the fact that FDBs which are added from user-space are
also marked as externally learned. In order to specify if an FDB was
successfully offloaded a new flag is introduced.
Signed-off-by: Arkadi Sharshevsky <arkadis@mellanox.com>
Signed-off-by: Jiri Pirko <jiri@mellanox.com>
Currently the bridge doesn't notify the underlying devices about new
FDBs learned. The FDB sync is placed on the switchdev notifier chain
because devices may potentially learn FDB that are not directly related
to their ports, for example:
1. Mixed SW/HW bridge - FDBs that point to the ASICs external devices
should be offloaded as CPU traps in order to
perform forwarding in slow path.
2. EVPN - Externally learned FDBs for the vtep device.
Notification is sent only about static FDB add/del. This is done due
to fact that currently this is the only scenario supported by switch
drivers.
Reviewed-by: Ivan Vecera <ivecera@redhat.com>
This is done as a preparation to moving the switchdev notifier chain
to be atomic. The FDB external learning should be called under rtnl
or rcu.
When using bridge without bridge netfilter enabled the message
displayed is rather confusing and leads to belive that a deprecated
feature is in use. Use IS_MODULE to be explicit that the message only
affects users which use bridge netfilter as module and reword the
message.
Signed-off-by: Stefan Agner <stefan@agner.ch>
Acked-by: Florian Westphal <fw@strlen.de>
When switchdev drivers process FDB notifications from the underlying
device they resolve the netdev to which the entry points to and notify
the bridge using the switchdev notifier.
However, since the RTNL mutex is not held there is nothing preventing
the netdev from disappearing in the middle, which will cause
br_switchdev_event() to dereference a non-existing netdev.
Make switchdev drivers hold the lock at the beginning of the
notification processing session and release it once it ends, after
notifying the bridge.
Also, remove switchdev_mutex and fdb_lock, as they are no longer needed
when RTNL mutex is held.
Fixes: 03bf0c281234 ("switchdev: introduce switchdev notifier")
Turned out that "switchdev" sticks. So just unify all related terms to use
this prefix.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
Signed-off-by: Scott Feldman <sfeldma@gmail.com>
Acked-by: Andy Gospodarek <gospo@cumulusnetworks.com>
make build fail if structure no longer fits into ->cb storage.
This patch benefits from newly introduced switchdev notifier and uses it
to propagate fdb learn events from rocker driver to bridge. That avoids
direct function calls and possible use by other listeners (ovs).
Suggested-by: Thomas Graf <tgraf@suug.ch>
Jesper reported that br_netfilter always registers the hooks since
this is part of the bridge core. This harms performance for people that
don't need this.
This patch modularizes br_netfilter so it can be rmmod'ed, thus,
the hooks can be unregistered. I think the bridge netfilter should have
been a separated module since the beginning, Patrick agreed on that.
Note that this is breaking compatibility for users that expect that
bridge netfilter is going to be available after explicitly 'modprobe
bridge' or via automatic load through brctl.
However, the damage can be easily undone by modprobing br_netfilter.
The bridge core also spots a message to provide a clue to people that
didn't notice that this has been deprecated.
On top of that, the plan is that nftables will not rely on this software
layer, but integrate the connection tracking into the bridge layer to
enable stateful filtering and NAT, which is was bridge netfilter users
seem to require.
This patch still keeps the fake_dst_ops in the bridge core, since this
is required by when the bridge port is initialized. So we can safely
modprobe/rmmod br_netfilter anytime.
Merge net/bridge/br_notify.c into net/bridge/br.c,
since it has only br_device_event() and br.c is small.
Cc: Stephen Hemminger <stephen@networkplumber.org>
And it can become static.
Use IS_ENABLED(CONFIG_FOO)
instead of defined(CONFIG_FOO) || defined (CONFIG_FOO_MODULE)
Signed-off-by: Igor Maravić <igorm@etf.rs>
Add netlink device ops to allow creating bridge device via netlink.
This works in a manner similar to vlan, macvlan and bonding.
Example:
# ip link add link dev br0 type bridge
# ip link del dev br0
The change required rearranging initializtion code to deal with
being called by create link. Most of the initialization happens
in br_dev_setup, but allocation of stats is done in ndo_init callback
to deal with allocation failure. Sysfs setup has to wait until
after the network device kobject is registered.
Add br_should_route_hook_t typedef, this is the only way we can
get a clean RCU implementation for function pointer.
Move route_hook to location where it is used.
What this patch does is it removes two receive frame hooks (for bridge and for
macvlan) from __netif_receive_skb. These are replaced them with a single
hook for both. It only supports one hook per device because it makes no
sense to do bridging and macvlan on the same device.
Then a network driver (of virtual netdev like macvlan or bridge) can register
an rx_handler for needed net device.
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
Use one set of macro's for all bridge messages.
Note: can't use netdev_XXX macro's because bridge is purely
virtual and has no device parent.
When unloading modules that uses call_rcu() callbacks, then we must
use rcu_barrier(). This module uses syncronize_net() which is not
enough to be sure that all callback has been completed.
Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk>
This patch changes FDB entry check for ATM LANE bridge integration.
There's no point in holding a FDB entry around SKB building.
br_fdb_get()/br_fdb_put() pair are changed into single br_fdb_test_addr()
hook that checks if the addr has FDB entry pointing to other port
to the one the request arrived on.
FDB entry refcounting is removed as it's not used anywhere else.
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
Acked-by: Stephen Hemminger <shemminger@vyatta.com>
Acked-by: Stephen Hemminger <shemming@vyatta.com>
Use the STP demux layer for receiving STP PDUs instead of directly
registering with LLC.
This patch removes CVS keywords that weren't updated for a long time
from comments.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
There is a race condition when unloading bridge and netfilter.
The problem happens if __fake_rtable is in use by a skb
coming in, while someone starts to unload bridge.ko.
br_netfilter_fini() is called at the beginning of unload
in br_deinit() while skbs still are being forwarded and
transferred to local ip stack. Thus there is a possibility
of the __fake_rtable pointer not being removed in a skb that
goes up to ip stack. This results in a kernel panic, as
ip_rcv() calls the input-function of __fake_rtable, which
is NULL.
Moving the call of br_netfilter_fini() to the end of
br_deinit() solves the problem.
Signed-off-by: Bodo Stroesser <bstroesser@fujitsu-siemens.com>
Signed-off-by: Stephen Hemminger <stephen.hemminger@vyatta.com>
In case the br_netfilter_init() (or any subsequent call)
fails, the br_fdb_fini() must be called to free the allocated
in br_fdb_init() br_fdb_cache kmem cache.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
With all the users of the double pointers removed, this patch mops up by
finally replacing all occurances of sk_buff ** in the netfilter API by
sk_buff *.
This patch checks kmem_cache_create() error and aborts loading module
on failure.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
Signed-off-by: Thomas Graf <tgraf@suug.ch>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Add basic netlink support to the Ethernet bridge. Including:
* dump interfaces in bridges
* monitor link status changes
* change state of bridge port
For some demo programs see:
http://developer.osdl.org/shemminger/prototypes/brnl.tar.gz
These are to allow building a daemon that does alternative
implementations of Spanning Tree Protocol.
Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
Return address in use, if some other kernel code has the SAP.
Propogate out error codes from netfilter registration and unwind.
Bridge will OOPS on removal if other application has the SAP open.
The bridge SAP might be shared with other usages, so need
to do reference counting on module removal rather than explicit
close/delete.
Since packet might arrive after or during removal, need to clear
the receive function handle, so LLC only hands it to user (if any).
Use LLC for the receive path of Spanning Tree Protocol packets.
This allows link local multicast packets to be received by
other protocols (if they care), and uses the existing LLC
code to get STP packets back into bridge code.
The bridge multicast address is also checked, so bridges using
other link local multicast addresses are ignored. This allows
for use of different multicast addresses to define separate STP
domains.
