git://git.kernel.org/pub/scm/linux/kernel/git/bluetooth/bluetooth-next
Johan Hedberg says:
pull request: bluetooth-next 2015-03-02
Here's the first bluetooth-next pull request targeting the 4.1 kernel:
- ieee802154/6lowpan cleanups
- SCO routing to host interface support for the btmrvl driver
- AMP code cleanups
- Fixes to AMP HCI init sequence
- Refactoring of the HCI callback mechanism
- Added shutdown routine for Intel controllers in the btusb driver
- New config option to enable/disable Bluetooth debugfs information
- Fix for early data reception on L2CAP fixed channels
Please let me know if there are any issues pulling. Thanks.
After TIPC doesn't depend on iocb argument in its internal
implementations of sendmsg() and recvmsg() hooks defined in proto
structure, no any user is using iocb argument in them at all now.
Then we can drop the redundant iocb argument completely from kinds of
implementations of both sendmsg() and recvmsg() in the entire
networking stack.
Suggested-by: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Ying Xue <ying.xue@windriver.com>
As part of an effort to move skb->dropcount to skb->cb[] use a common
macro in protocol families using skb->cb[] for ancillary data to
validate available room in skb->cb[].
Signed-off-by: Eyal Birger <eyal.birger@gmail.com>
fields
Convert boolean fields incoming and req_start to bit fields and move
force_active in order save space in bt_skb_cb in an effort to use
a portion of skb->cb[] for storing skb->dropcount.
struct hci_req_ctrl is never used outside of struct bt_skb_cb;
Inlining it frees 8 bytes on a 64 bit system in skb->cb[] allowing
the addition of more ancillary data.
Reviewed-by: Shmulik Ladkani <shmulik.ladkani@gmail.com>
gcc5 warns about passing a const array to hci_test_bit which takes a
non-const pointer:
net/bluetooth/hci_sock.c: In function ‘hci_sock_sendmsg’:
net/bluetooth/hci_sock.c:955:8: warning: passing argument 2 of ‘hci_test_bit’ discards ‘const’ qualifier from pointer target type [-Wdiscarded-array-qualifiers]
&hci_sec_filter.ocf_mask[ogf])) &&
net/bluetooth/hci_sock.c:49:19: note: expected ‘void *’ but argument is of type ‘const __u32 (*)[4] {aka const unsigned int (*)[4]}’
static inline int hci_test_bit(int nr, void *addr)
So make 'addr' 'const void *'.
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Cc: Gustavo Padovan <gustavo@padovan.org>
Cc: Johan Hedberg <johan.hedberg@gmail.com>
The 'master' parameter of the New CSRK event was recently renamed to
'type', with the old values kept for backwards compatibility as
unauthenticated local/remote keys. This patch updates the code to take
into account the two new (authenticated) values and ensures they get
used based on the security level of the connection that the respective
keys get distributed over.
Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
Now that there's the general purpose hci_send_to_channel() API it will
do the exact same thing as queue_monitor_skb() when passed the monitor
HCI channel. This patch removes queue_monitor_skb() and replaces any
users of it with calls to hci_send_to_channel().
The hci_send_to_control() can be made more general purpose with a small
change of passing the desired HCI channel as a parameter to it. This
allows using it for the monitor channel as well as e.g. 6lowpan in the
future.
The only reason the SMP code is essentially duplicating the
hci_copy_identity_addr() function is that the helper returns the address
type in the HCI format rather than the three-value format expected by
l2cap_chan. This patch converts the SMP code to use the helper and then
do a simple conversion from one address type to another.
Changing the HS setting requires that SSP is enabled, however so far the
code only checked for the SSP flag but not a potentially ongoing Set SSP
operation. This patch adds a check for a pending Set SSP command in the
Set HS handler, and returns a 'busy' error if one is found.
The command handler for Set HS doesn't use mgmt_pending_add() so we can
never have a pending Set HS command that mgmt_pending_find() would
return. This patch removes an unnecessary lookup for it in the set_ssp()
handler function.
This patch moves all the disconn_cfm callbacks to be based on the hci_cb
list. This means making l2cap_disconn_cfm private to l2cap_core.c and
sco_conn_cb private to sco.c respectively. Since the hci_conn type
filtering isn't done any more on the wrapper level the callbacks
themselves need to check that they were passed a relevant type of
connection.
This patch moves all the connect_cfm callbacks to be based on the hci_cb
list. This means making l2cap_connect_cfm private to l2cap_core.c and
sco_connect_cb private to sco.c respectively. Since the hci_conn type
connection.
There's no reason to have the custom hci_proto_auth/encrypt_cfm helpers
when the hci_cb list works equally well. This patch adds L2CAP to the
hci_cb list and makes l2cap_security_cfm a private function of
l2cap_core.c.
We'll soon need to be able to sleep inside the loops that iterate the
hci_cb list, so neither a spinlock, rwlock or rcu are usable. This patch
changes the lock to a mutex which permits sleeping while holding the
lock.
When processing hci_cb entries we want first registered callbacks to be
called first and later ones later. This is because eventually the L2CAP
callbacks that are part of the core will use this list and get
registered first. To keep the same order of calling L2CAP callbacks
before e.g. RFCOMM the order of elements needs to be this way.
Some AMP controllers do not support the Read Local Features HCI commands
(even though according to the spec they should). Luckily they at least
correctly omit this from the supported commands bitmask, so we can work
around the issue by creating a second AMP init phase and issuing the HCI
command conditionally there.
On BR/EDR the L2CAP channel instances for fixed channels have so far
been marked as ready only once the L2CAP information req/rsp procedure
is complete and we have the fixed channel mask. This could however lead
to data being dropped if we receive it on the channel before knowing the
remote mask.
Since it is valid for a remote to send data this early, simply assume
that the channel is supported when we receive data on it. So far this
hasn't been noticed much because of limited use of fixed channels on
BR/EDR, but e.g. with SMP over BR/EDR this is already now visible with
automated tests failing randomly.
The Bluetooth controllers can export extensive information about
internal states via debugfs. This patch provides an option to
choose if these information are provided or not.
For backwards compatibility with existing kernel configuration,
this option defaults to yes.
The __next_ident function is a local function and so do not export it
and make it static.
The a2mp_send function is a local function and so do not export it
and make it static.
The amp_mgr_lookup_by_state function does not need to be exported. So
just move it to a different location and make it static.
There is no reason to have amp_mgr_list and amp_mgr_list_lock exported
from a2mp.c and thus make both of them static.
The A2MP_FEAT_EXT declaration has a single user in a2mp.c and thus
just move it there.
This callback allows a vendor to send the vendor specific commands
before cloing the hci interface.
Signed-off-by: Tedd Ho-Jeong An <tedd.an@intel.com>
If user space is trying to pair on not enabled transport
MGMT_STATUS_REJECT will be returned.
If user space is trying to pair on transport which controller does not
support, MGMT_STATUS_NOT_SUPPORTED will be returned.
Having separate error code for that scenario might be useful for
debugging at least.
Signed-off-by: Lukasz Rymanowski <lukasz.rymanowski@tieto.com>
With this patch -EOPNOTSUPP will be returned by hci_connect_acl for LE
only controllers. If it is dual device with disabled BREDR -ECONNREFUSED
will be returned
Kernel gives possibility to enable/disable LE host support.
There is flag HCI_LE_ENABLED which is set when this support is enabled
and some parts of the code checks this flag e.g. SMP
However it is still possible to make LE connection if LE Host support is
disabled, what might be confused for remote device.
This patch makes sure that kernel will not send HCI LE Create Connection
if LE HOST support is not enabled.
The bnep_get_device function may be triggered by an ioctl just after a
connection has gone down. In such a case the respective L2CAP chan->conn
pointer will get set to NULL (by l2cap_chan_del). This patch adds a
missing NULL check for this case in the bnep_get_device() function.
Reported-by: Patrik Flykt <patrik.flykt@linux.intel.com>
This extended return parameters struct conflicts with the new Read Local
OOB Extended Data command definition. To avoid the conflict simply
rename the old "extended" version to the normal one and update the code
appropriately to take into account the two possible response PDU sizes.
When using LE_SCAN_FILTER_DUP_ENABLE, some controllers would send
advertising report from each LE device only once. That means that we
don't get any updates on RSSI value, and makes Service Discovery very
slow. This patch adds restarting scan when in Service Discovery, and
device with filtered uuid is found, but it's not in RSSI range to send
event yet. This way if device moves into range, we will quickly get RSSI
update.
Signed-off-by: Jakub Pawlowski <jpawlowski@google.com>
Currently there is no way to restart le scan, and it's needed in
service scan method. The way it work: it disable, and then enable le
scan on controller.
During the restart, we must remember when the scan was started, and
it's duration, to later re-schedule the le_scan_disable work, that was
stopped during the stop scan phase.
When using Secure Connections Only mode, then only P-256 OOB data is
valid and should be provided. In case userspace provides P-192 and P-256
OOB data, then the P-192 values will be set to zero. However the present
value of the IO capability exchange still mentioned that both values
would be available. Fix this by telling the controller clearly that only
the P-256 OOB data is present.
For debugging purposes it is good to know which OOB data is actually
currently loaded for each controller. So expose that list via debugfs.
When the Hardware Error event is send by the controller, the Bluetooth
core stores the error code. Expose it via debugfs so it can be retrieved
later on.
To allow easier debugging when debug keys are generated, provide debugfs
entry for checking the setting of debug keys usage.
When the HCI Write Simple Pairing Debug Mode command has been issued,
the result needs to be tracked and stored. The hdev->ssp_debug_mode
variable is already present, but was never updated when the mode in
the controller was actually changed.
The value of the ssp_debug_mode should be accessible via debugfs to be
able to determine if a BR/EDR controller generates debugs keys or not.
In case the remote only provided P-192 or P-256 data for OOB pairing,
then make sure that the data value pointers are correctly set. That way
the core can provide correct information when remote OOB data present
information have to be communicated.
Before setting the OOB data present flag with SMP pairing, check the
newly introduced present tracking that actual OOB data values have
been provided. The existence of remote OOB data structure does not
actually mean that the correct data values are available.
When BR/EDR Secure Connections has been enabled, the OOB data present
value can take 2 additional values. The host has to clearly provide
details about if P-192 OOB data, P-256 OOB data or a combination of
P-192 and P-256 OOB data is present.
In case BR/EDR Secure Connections is not enabled or not supported,
then check that P-192 OOB data is actually present and return the
correct value based on that.
Instead of doing complex calculation every time the OOB data is used,
just calculate the OOB data present value and store it with the OOB
data raw values.
This command should only be used if remote device reports that it
supports extended features. Otherwise command will fail and connection
will be dropped.
Some devices support SSP but don't support extended features so
current check for SSP support is not enought.
Instead of checking for SSP support just check if both ends support
Extended Feature.
< HCI Command: Create Connection (0x01|0x0005) plen 13
Address: D0:9C:30:00:19:6F (Foster Electric Company, Limited)
Packet type: 0xcc18
DM1 may be used
DH1 may be used
DM3 may be used
DH3 may be used
DM5 may be used
DH5 may be used
Page scan repetition mode: R1 (0x01)
Page scan mode: Mandatory (0x00)
Clock offset: 0x94c8
Role switch: Allow slave (0x01)
> HCI Event: Command Status (0x0f) plen 4
Create Connection (0x01|0x0005) ncmd 1
Status: Success (0x00)
> HCI Event: Connect Complete (0x03) plen 11
Handle: 5
Link type: ACL (0x01)
Encryption: Disabled (0x00)
< HCI Command: Read Remote Supported Features (0x01|0x001b) plen 2
Handle: 5
Read Remote Supported Features (0x01|0x001b) ncmd 1
> HCI Event: Page Scan Repetition Mode Change (0x20) plen 7
> HCI Event: Read Remote Supported Features (0x0b) plen 11
Handle: 5
Features: 0xff 0xff 0x8f 0xfe 0xdb 0xff 0x5b 0x07
3 slot packets
5 slot packets
Encryption
Slot offset
Timing accuracy
Role switch
Hold mode
Sniff mode
Park state
Power control requests
Channel quality driven data rate (CQDDR)
SCO link
HV2 packets
HV3 packets
u-law log synchronous data
A-law log synchronous data
CVSD synchronous data
Paging parameter negotiation
Power control
Transparent synchronous data
Broadcast Encryption
Enhanced Data Rate ACL 2 Mbps mode
Enhanced Data Rate ACL 3 Mbps mode
Enhanced inquiry scan
Interlaced inquiry scan
Interlaced page scan
RSSI with inquiry results
Extended SCO link (EV3 packets)
EV4 packets
EV5 packets
AFH capable slave
AFH classification slave
LE Supported (Controller)
3-slot Enhanced Data Rate ACL packets
5-slot Enhanced Data Rate ACL packets
Sniff subrating
Pause encryption
AFH capable master
AFH classification master
Enhanced Data Rate eSCO 2 Mbps mode
Enhanced Data Rate eSCO 3 Mbps mode
3-slot Enhanced Data Rate eSCO packets
Extended Inquiry Response
Simultaneous LE and BR/EDR (Controller)
Secure Simple Pairing
Encapsulated PDU
Non-flushable Packet Boundary Flag
Link Supervision Timeout Changed Event
Inquiry TX Power Level
Enhanced Power Control
< HCI Command: Read Remote Extended Features (0x01|0x001c) plen 3
Handle: 5
Page: 1
Read Remote Extended Features (0x01|0x001c) ncmd 1
Status: Command Disallowed (0x0c)
< HCI Command: Read Clock Offset (0x01|0x001f) plen 2
Handle: 5
Read Clock Offset (0x01|0x001f) ncmd 1
< HCI Command: Disconnect (0x01|0x0006) plen 3
Handle: 5
Reason: Remote User Terminated Connection (0x13)
Signed-off-by: Szymon Janc <szymon.janc@tieto.com>
The smp_unregister() function needs to be called every time the
controller is powered down. There are multiple entry points when
this can happen. One is "hciconfig hci0 reset" which will throw
a WARN_ON when LE support has been enabled.
[ 78.564620] WARNING: CPU: 0 PID: 148 at net/bluetooth/smp.c:3075 smp_register+0xf1/0x170()
[ 78.564622] Modules linked in:
[ 78.564628] CPU: 0 PID: 148 Comm: kworker/u3:1 Not tainted 3.19.0-rc4-devel+ #404
[ 78.564629] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS
[ 78.564635] Workqueue: hci0 hci_rx_work
[ 78.564638] ffffffff81b4a7a2 ffff88001cb2fb38 ffffffff8161d881 0000000080000000
[ 78.564642] 0000000000000000 ffff88001cb2fb78 ffffffff8103b870 696e55206e6f6f6d
[ 78.564645] ffff88001d965000 0000000000000000 0000000000000000 ffff88001d965000
[ 78.564648] Call Trace:
[ 78.564655] [<ffffffff8161d881>] dump_stack+0x4f/0x7b
[ 78.564662] [<ffffffff8103b870>] warn_slowpath_common+0x80/0xc0
[ 78.564667] [<ffffffff81544b00>] ? add_uuid+0x1f0/0x1f0
[ 78.564671] [<ffffffff8103b955>] warn_slowpath_null+0x15/0x20
[ 78.564674] [<ffffffff81562d81>] smp_register+0xf1/0x170
[ 78.564680] [<ffffffff81081236>] ? lock_timer_base.isra.30+0x26/0x50
[ 78.564683] [<ffffffff81544bf0>] powered_complete+0xf0/0x120
[ 78.564688] [<ffffffff8152e622>] hci_req_cmd_complete+0x82/0x260
[ 78.564692] [<ffffffff8153554f>] hci_cmd_complete_evt+0x6cf/0x2e20
[ 78.564697] [<ffffffff81623e43>] ? _raw_spin_unlock_irqrestore+0x13/0x30
[ 78.564701] [<ffffffff8106b0af>] ? __wake_up_sync_key+0x4f/0x60
[ 78.564705] [<ffffffff8153a2ab>] hci_event_packet+0xbcb/0x2e70
[ 78.564709] [<ffffffff814094d3>] ? skb_release_all+0x23/0x30
[ 78.564711] [<ffffffff81409529>] ? kfree_skb+0x29/0x40
[ 78.564715] [<ffffffff815296c8>] hci_rx_work+0x1c8/0x3f0
[ 78.564719] [<ffffffff8105bd91>] ? get_parent_ip+0x11/0x50
[ 78.564722] [<ffffffff8105be25>] ? preempt_count_add+0x55/0xb0
[ 78.564727] [<ffffffff8104f65f>] process_one_work+0x12f/0x360
[ 78.564731] [<ffffffff8104ff9b>] worker_thread+0x6b/0x4b0
[ 78.564735] [<ffffffff8104ff30>] ? cancel_delayed_work_sync+0x10/0x10
[ 78.564738] [<ffffffff810542fa>] kthread+0xea/0x100
[ 78.564742] [<ffffffff81620000>] ? __schedule+0x3e0/0x980
[ 78.564745] [<ffffffff81054210>] ? kthread_create_on_node+0x180/0x180
[ 78.564749] [<ffffffff816246ec>] ret_from_fork+0x7c/0xb0
[ 78.564752] [<ffffffff81054210>] ? kthread_create_on_node+0x180/0x180
[ 78.564755] ---[ end trace 8b0d943af76d3736 ]---
This warning is not critical and has only been placed in the code to
actually catch this exact situation. To avoid triggering it move
the smp_unregister() into hci_dev_do_close() which will now also
take care of remove the SMP channel. It is safe to call this function
since it only remove the channel if it has been previously registered.
When receiving a HCI Hardware Error event, the controller should be
assumed to be non-functional until issuing a HCI Reset command.
The Bluetooth hardware errors are vendor specific and so add a
new hdev->hw_error callback that drivers can provide to run extra
code to handle the hardware error.
After completing the vendor specific error handling perform a full
reset of the Bluetooth stack by closing and re-opening the transport.
Based-on-patch-by: Johan Hedberg <johan.hedberg@intel.com>
Split the hci_dev_reset ioctl handling into using hci_dev_do_reset
helper function. Similar to what has been done with hci_dev_do_open
and hci_dev_do_close.
The discovery state should be set to stopped when the HCI device is
powered off. This patch adds the appropriate call to the
hci_discovery_set_state() function from hci_dev_do_close() which is
responsible for the power-off procedure.
When HCI_Reset is issued the discovery state is assumed to be stopped.
The hci_cc_reset() handler was trying to set the state but it was doing
it without using the hci_discovery_set_state() function. Because of this
e.g. the mgmt Discovering event could go without being sent. This patch
fixes the code to use the hci_discovery_set_state() function instead of
just blindly setting the state value.
There's a check in set_secure_conn() that's supposed to ensure that SSP
is enabled before we try to request the controller to enable SC (since
SSP is a pre-requisite for it). However, this check only makes sense for
controllers actually supporting BR/EDR SC. If we have a 4.0 controller
we're only interested in the LE part of SC and should therefore not be
requiring SSP to be enabled. This patch adds an additional condition to
check for lmp_sc_capable(hdev) before requiring SSP to be enabled.
