- added typedef unsigned int __nocast gfp_t;
- replaced __nocast uses for gfp flags with gfp_t - it gives exactly
the same warnings as far as sparse is concerned, doesn't change
generated code (from gcc point of view we replaced unsigned int with
typedef) and documents what's going on far better.
This patch fixes the sparse warnings "implicit cast to nocast type"
for the priority or gfp_mask parameters of the memory allocations.
Signed-off-by: Victor Fusco <victor@cetuc.puc-rio.br>
Signed-off-by: Domen Puncer <domen@coderock.org>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
This patch implements the remote port negotiation (RPN) of the RFCOMM
protocol for Bluetooth.
Signed-off-by: J. Suter <jsuter@hardwave.de>
The RFCOMM layer does not handle properly the de-assertation
of CD signal. It should call tty_hangup() to work properly.
Signed-off-by: Timo Teräs <ext-timo.teras@nokia.com>
This is part of the grand scheme to eliminate the qlen
member of skb_queue_head, and subsequently remove the
'list' member of sk_buff.
Most users of skb_queue_len() want to know if the queue is
empty or not, and that's trivially done with skb_queue_empty()
which doesn't use the skb_queue_head->qlen member and instead
uses the queue list emptyness as the test.
infrastructure for it.
Let it rip!
