To enable controller specific logging, the userspace daemon has to have
the ability to log per controller. To facilitate this support, provide
a dedicated logging channel. Messages in this channel will be included
in the monitor queue and with that also forwarded to monitoring tools
along with the actual hardware traces.
All messages from the logging channel are timestamped and with that
allow an easy correlation between userspace messages and hardware
events. This will increase the ability to debug problems faster.
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
The monitor channel can be used to send generic system notes as text
strings for debugging purposes. This adds the system note monitor code
and uses it for including kernel and subsystem version into traces.
The HCI sockets code has still some old casting coding style. Fix this
to match with the rest of the code.
When HCI commands are injected via the raw socket, the core was not
including the decoded opcode value. So ensure that it is actually set.
We can reduce the size of the hci_ctrl struct by converting
'bool req_start' to 'u8 req_flags' and making the two function
pointers a union (since only one is ever set at a time).
The new hci_skb_pkt_* wrappers only help if they are used consistently
in the Bluetooth subsystem. So first convert the core packet handling.
The SKB context buffer for HCI request is really not just for requests,
information in their are preserved for the whole HCI layer. So it makes
more sense to actually rename it into bt_cb()->hci and also call it then
struct hci_ctrl.
In addition that allows moving the decoded opcode for outgoing packets
into that struct. So far it was just consuming valuable space from the
main shared items. And opcode are not valid for L2CAP packets.
There are two checks that are still using (MSG_OOB) instead of just
MSG_OOB and so lets just fix them.
Before the vendor specific setup stage is triggered call back into the
core to trigger an internal notification event. That event is used to
send an index update to the monitor interface. With that specific event
it is possible to update userspace with manufacturer information before
any HCI command has been executed. This is useful for early stage
debugging of vendor specific initialization sequences.
When using the HCI_CHANNEL_RAW, restrict the packet types to valid ones
from the Bluetooth specification.
The HCI_VENDOR_PKT quirk was needed for BPA-100/105 devices that send
these messages. Now that there is support for proper diagnostic channel
this quirk is no longer needed.
Introduce hci_recv_diag function for HCI drivers to allow sending vendor
specific diagnostic messages into the Bluetooth core stack. The messages
are not processed, but they are forwarded to the monitor channel and can
be retrieved by user space diagnostic tools.
The Bluetooth public device address might change during controller setup
and it makes it a lot simpler for monitoring tools if they just get told
what the new address is. In addition include the manufacturer / company
information of the controller. That allows for easy vendor specific HCI
command and event handling.
When the core starts or shuts down the actual HCI transport, send a new
monitor event that indicates that this is happening. These new events
correspond to HCI_DEV_OPEN and HCI_DEV_CLOSE events.
The stack internal events that are exposed to userspace should be
limited to HCI_DEV_REG, HCI_DEV_UNREG, HCI_DEV_UP and HCI_DEV_DOWN.
With 9380f9eacfbbee701daa416edd6625efcd3e29e1 the order of unsetting
the HCI_USER_CHANNEL flag of the HCI device was reverted to ensure
the device is first closed before making it available again.
Due to hci_dev_close checking for HCI_USER_CHANNEL being set on the
device it was never really closed and was kept opened. We're now
calling hci_dev_do_close directly to make sure the device is correctly
closed and we keep the correct order to unset the flag on our device
object.
Signed-off-by: Simon Fels <simon.fels@canonical.com>
During the initial setup stage of a controller, the low-level transport
is actually active. This means that HCI_UP is true. To avoid toggling
the transport off and back on again for normal operation the kernel
holds a grace period with HCI_AUTO_OFF that will turn the low-level
transport off in case no user is present.
The idea of the grace period is important to avoid having to initialize
all of the controller twice. So legacy ioctl and the new management
interface knows how to clear this grace period and then start normal
operation.
For the user channel operation this grace period has not been taken into
account which results in the problem that HCI_UP and HCI_AUTO_OFF are
set and the kernel will return EBUSY. However from a system point of
view the controller is ready to be grabbed by either the ioctl, the
management interface or the user channel.
This patch brings the user channel to the same level as the other two
entries for operating a controller.
Cc: stable@vger.kernel.org
The hci close method needs to know if we are in user channel context.
Only add the index to mgmt once close is performed.
Signed-off-by: Loic Poulain <loic.poulain@intel.com>
In preparation for changing how struct net is refcounted
on kernel sockets pass the knowledge that we are creating
a kernel socket from sock_create_kern through to sk_alloc.
In order to shrink the size of bt_skb_cb, this patch moves the HCI
request related variables into their own req_ctrl struct. Additionall
the L2CAP and HCI request structs are placed inside the same union since
they will never be used at the same time for the same skb.
The mgmt.c file should be reserved purely for HCI_CHANNEL_CONTROL. The
mgmt_control() function in it is already completely generic and has a
single user in hci_sock.c. This patch moves the function there and
renames it a bit more appropriately to hci_mgmt_cmd() (as it's a command
dispatcher).
We'll need to have access to which HCI channel a socket is bound to, in
order to manage pending mgmt commands in clean way. This patch adds a
helper for the purpose.
Changes to the global configuration updates like settings, class of
device, name etc. can be received by every user. They are allowed to
read them in the first place so provide the updates via events as
well. Otherwise untrusted users start polling for updates and that
is not a desired behavior.
Until now the management interface was restricted to CAP_NET_ADMIN. With
this change every user can open the management socket. However the list
of commands is heavily restricted to getting basic information about the
attached controllers. No access for configuration or other operation is
provided. The events are also limited. This is done so that no keys can
leak or untrusted users can mess with the Bluetooth configuration.
The management interface will need access to the socket flags and so
provide a helper function for checking them.
With the introduction of trusted socket flag for control and monitor
channels, it is now possible to use a single function for sending
packets to these sockets. And with that consolidate the handling.
Providing a global trusted flag for management control sockets provides
an easy way for identifying sockets and imposing restriction on it. For
now all management sockets are trusted since they require CAP_NET_ADMIN.
For sending Index Added, Index Removed, Unconfigured Index Added and
Unconfigured Index Removed managment events the new helper functions
allows taking into account if these events are enabled for a certain
management socket or not.
The hci_send_to_flagged_channel helper function can be used to send
packets to all channels that have a certain HCI socket flag set.
This is especially useful for managment events that are limited to
sockets that have first enabled certain functionality. This allows
for filtering of events without confusing existing users.
To filter out certain actions for certain HCI sockets introcuce a flags
field that allows to configure specific settings on individual sockets.
Since the hci_pinfo structure is private in hci_sock.c, provide helper
functions for setting and clearing a given flag.
Instead of manually coding test_and_set_bit on hdev->dev_flags all the
time, use hci_dev_test_and_set_flag helper macro.
Instead of manually coding clear_bit on hdev->dev_flags all the time,
use hci_dev_clear_flag helper macro.
Instead of manually coding test_bit on hdev->dev_flags all the time,
use hci_dev_test_flag helper macro.
This patch converts the existing mgmt code to use the newly introduced
generic API for registering HCI channels with mgmt-like semantics.
This patch adds an API for registering HCI channels with mgmt-like
semantics. For now the only user will be HCI_CHANNEL_CONTROL, but e.g.
6lowpan is intended to use this as well in the future.
git://git.kernel.org/pub/scm/linux/kernel/git/bluetooth/bluetooth-next
Johan Hedberg says:
pull request: bluetooth-next 2015-03-02
Here's the first bluetooth-next pull request targeting the 4.1 kernel:
- ieee802154/6lowpan cleanups
- SCO routing to host interface support for the btmrvl driver
- AMP code cleanups
- Fixes to AMP HCI init sequence
- Refactoring of the HCI callback mechanism
- Added shutdown routine for Intel controllers in the btusb driver
- New config option to enable/disable Bluetooth debugfs information
- Fix for early data reception on L2CAP fixed channels
Please let me know if there are any issues pulling. Thanks.
After TIPC doesn't depend on iocb argument in its internal
implementations of sendmsg() and recvmsg() hooks defined in proto
structure, no any user is using iocb argument in them at all now.
Then we can drop the redundant iocb argument completely from kinds of
implementations of both sendmsg() and recvmsg() in the entire
networking stack.
Suggested-by: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Ying Xue <ying.xue@windriver.com>
fields
Convert boolean fields incoming and req_start to bit fields and move
force_active in order save space in bt_skb_cb in an effort to use
a portion of skb->cb[] for storing skb->dropcount.
Signed-off-by: Eyal Birger <eyal.birger@gmail.com>
struct hci_req_ctrl is never used outside of struct bt_skb_cb;
Inlining it frees 8 bytes on a 64 bit system in skb->cb[] allowing
the addition of more ancillary data.
Reviewed-by: Shmulik Ladkani <shmulik.ladkani@gmail.com>
gcc5 warns about passing a const array to hci_test_bit which takes a
non-const pointer:
net/bluetooth/hci_sock.c: In function ‘hci_sock_sendmsg’:
net/bluetooth/hci_sock.c:955:8: warning: passing argument 2 of ‘hci_test_bit’ discards ‘const’ qualifier from pointer target type [-Wdiscarded-array-qualifiers]
&hci_sec_filter.ocf_mask[ogf])) &&
net/bluetooth/hci_sock.c:49:19: note: expected ‘void *’ but argument is of type ‘const __u32 (*)[4] {aka const unsigned int (*)[4]}’
static inline int hci_test_bit(int nr, void *addr)
So make 'addr' 'const void *'.
Cc: Gustavo Padovan <gustavo@padovan.org>
Cc: Johan Hedberg <johan.hedberg@gmail.com>
Now that there's the general purpose hci_send_to_channel() API it will
do the exact same thing as queue_monitor_skb() when passed the monitor
HCI channel. This patch removes queue_monitor_skb() and replaces any
users of it with calls to hci_send_to_channel().
The hci_send_to_control() can be made more general purpose with a small
change of passing the desired HCI channel as a parameter to it. This
allows using it for the monitor channel as well as e.g. 6lowpan in the
future.
The send_monitor_event function is essentially the same as the newly
introduced queue_monitor_skb. So instead of having duplicated code,
replace send_monitor_event with queue_monitor_skb.
The hci_send_to_monitor function contains generic code for queueing the
packet into the receive queue of every monitor client. To avoid code
duplication, create a generic queue_monitor_skb function to interate
over all monitor sockets.
Within the monitor functionality, the global atomic variable called
monitor_promisc ensures that no memory allocation happend when there
is actually no client listening. This means it is safe to just create
a copy of the skb since it is guaranteed that at least one client
exists. No extra checks needed.
This adds an extra check for ensuring that the size of sockaddr_hci
does not grow larger than sockaddr.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next
John W. Linville says:
pull request: wireless-next 2014-11-07
Please pull this batch of updates intended for the 3.19 stream!
For the mac80211 bits, Johannes says:
"This relatively large batch of changes is comprised of the following:
* large mac80211-hwsim changes from Ben, Jukka and a bit myself
* OCB/WAVE/11p support from Rostislav on behalf of the Czech Technical
University in Prague and Volkswagen Group Research
* minstrel VHT work from Karl
* more CSA work from Luca
* WMM admission control support in mac80211 (myself)
* various smaller fixes, spelling corrections, and minor API additions"
For the Bluetooth bits, Johan says:
"Here's the first bluetooth-next pull request for 3.19. The vast majority
of patches are for ieee802154 from Alexander Aring with various fixes
and cleanups. There are also several LE/SMP fixes as well as improved
support for handling LE devices that have lost their pairing information
(the patches from Alfonso). Jukka provides a couple of stability fixes
for 6lowpan and Szymon conformance fixes for RFCOMM. For the HCI drivers
we have one new USB ID for an Acer controller as well as a reset
handling fix for H5."
For the Atheros bits, Kalle says:
"Major changes are:
o ethtool support (Ben)
o print dev string prefix with debug hex buffers dump (Michal)
o debugfs file to read calibration data from the firmware verification
purposes (me)
o fix fw_stats debugfs file, now results are more reliable (Michal)
o firmware crash counters via debugfs (Ben&me)
o various tracing points to debug firmware (Rajkumar)
o make it possible to provide firmware calibration data via a file (me)
And we have quite a lot of smaller fixes and clean up."
For the iwlwifi bits, Emmanuel says:
"The big new thing here is netdetect which allows the
firmware to wake up the platform when a specific network
is detected. Along with that I have fixes for d3 operation.
The usual amount of rate scaling stuff - we now support STBC.
The other commit that stands out is Johannes's work on
devcoredump. He basically starts to use the standard
infrastructure he built."
Along with that are the usual sort of updates and such for ath9k,
brcmfmac, wil6210, and a handful of other bits here and there...
Please let me know if there are problems!
This encapsulates all of the skb_copy_datagram_iovec() callers
with call argument signature "skb, offset, msghdr->msg_iov, length".
When we move to iov_iters in the networking, the iov_iter object will
sit in the msghdr.
Having a helper like this means there will be less places to touch
during that transformation.
Based upon descriptions and patch from Al Viro.
Fix spelling errors in comments.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
