path: root/net/bluetooth/af_bluetooth.c
2011-02-25Bluetooth: remove unnecessary call to hci_sock_cleanupAnand Gadiyar
hci_sock_cleanup is already called after the sock_err label. It appears that we can drop this call. Signed-off-by: Anand Gadiyar <gadiyar@ti.com> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2011-02-17Bluetooth: fix checkpatch errors in af_bluetooth.cGustavo F. Padovan
2011-02-14Bluetooth: Merge L2CAP and SCO modules into bluetooth.koGustavo F. Padovan
Actually doesn't make sense have these modules built separately. The L2CAP layer is needed by almost all Bluetooth protocols and profiles. There isn't any real use case without having L2CAP loaded. SCO is only essential for Audio transfers, but it is so small that we can have it loaded always in bluetooth.ko without problems. If you really doesn't want it you can disable SCO in the kernel config. Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2011-02-08Bluetooth: fix crash by disabling tasklet in sock acceptAndrei Emeltchenko
Crash can happen when tasklet handling connect/disconnect requests preempts socket accept. Can be reproduced with "l2test -r" on one side and several "l2test -c -b 1000 -i hci0 -P 10 <bdaddr>" on the other side. disable taskets in socket accept and change lock_sock and release_sock to bh_lock_sock and bh_unlock_sock since we have to use spinlocks and there is no need to mark sock as owned by user. ... [ 3555.897247] Unable to handle kernel NULL pointer dereference at virtual address 000000bc [ 3555.915039] pgd = cab9c000 [ 3555.917785] [000000bc] *pgd=8bf3d031, *pte=00000000, *ppte=00000000 [ 3555.928314] Internal error: Oops: 17 [#1] PREEMPT [ 3555.999786] CPU: 0 Not tainted (2.6.32.21-13874-g67918ef #65) ... [ 3556.005981] PC is at bt_accept_unlink+0x20/0x58 [bluetooth] [ 3556.011627] LR is at bt_accept_dequeue+0x3c/0xe8 [bluetooth] ... [ 3556.161285] [<bf0007fc>] (bt_accept_unlink+0x20/0x58 [bluetooth]) from [<bf000870>] (bt_accept_dequeue+0x3c/0xe8 [bluetooth]) [ 3556.172729] [<bf000870>] (bt_accept_dequeue+0x3c/0xe8 [bluetooth]) from [<bf324df8>] (l2cap_sock_accept+0x100/0x15c [l2cap]) [ 3556.184082] [<bf324df8>] (l2cap_sock_accept+0x100/0x15c [l2cap]) from [<c026a0a8>] (sys_accept4+0x120/0x1e0) [ 3556.193969] [<c026a0a8>] (sys_accept4+0x120/0x1e0) from [<c002c9a0>] (ret_fast_syscall+0x0/0x2c) [ 3556.202819] Code: e5813000 e5901164 e580c160 e580c15c (e1d13bbc) ... Signed-off-by: Andrei Emeltchenko <andrei.emeltchenko@nokia.com> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2011-02-08Bluetooth: Do not use assignments in IF conditionsAndrei Emeltchenko
Fix checkpatch warnings concerning assignments in if conditions. Signed-off-by: Andrei Emeltchenko <andrei.emeltchenko@nokia.com> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2010-10-12Bluetooth: Add common code for stream-oriented recvmsg()Mat Martineau
This commit adds a bt_sock_stream_recvmsg() function for use by any Bluetooth code that uses SOCK_STREAM sockets. This code is copied from rfcomm_sock_recvmsg() with minimal modifications to remove RFCOMM-specific functionality and improve readability. L2CAP (with the SOCK_STREAM socket type) and RFCOMM have common needs when it comes to reading data. Proper stream read semantics require that applications can read from a stream one byte at a time and not lose any data. The RFCOMM code already operated on and pulled data from the underlying L2CAP socket, so very few changes were required to make the code more generic for use with non-RFCOMM data over L2CAP. Applications that need more awareness of L2CAP frame boundaries are still free to use SOCK_SEQPACKET sockets, and may verify that they connection did not fall back to basic mode by calling getsockopt(). Signed-off-by: Mat Martineau <mathewm@codeaurora.org> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2010-09-06net: poll() optimizationsEric Dumazet
No need to test twice sk->sk_shutdown & RCV_SHUTDOWN Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-20net: sk_sleep() helperEric Dumazet
Define a new function to return the waitqueue of a "struct sock". static inline wait_queue_head_t *sk_sleep(struct sock *sk) { return sk->sk_sleep; } Change all read occurrences of sk_sleep by a call to this function. Needed for a future RCU conversion. sk_sleep wont be a field directly available. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-11-05net: pass kern to net_proto_family create functionEric Paris
The generic __sock_create function has a kern argument which allows the security system to make decisions based on if a socket is being created by the kernel or by userspace. This patch passes that flag to the net_proto_family specific create function, so it can do the same thing. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-12net: Generalize socket rx gap / receive queue overflow cmsgNeil Horman
Create a new socket level option to report number of queue overflows Recently I augmented the AF_PACKET protocol to report the number of frames lost on the socket receive queue between any two enqueued frames. This value was exported via a SOL_PACKET level cmsg. AFter I completed that work it was requested that this feature be generalized so that any datagram oriented socket could make use of this option. As such I've created this patch, It creates a new SOL_SOCKET level option called SO_RXQ_OVFL, which when enabled exports a SOL_SOCKET level cmsg that reports the nubmer of times the sk_receive_queue overflowed between any two given frames. It also augments the AF_PACKET protocol to take advantage of this new feature (as it previously did not touch sk->sk_drops, which this patch uses to record the overflow count). Tested successfully by me. Notes: 1) Unlike my previous patch, this patch simply records the sk_drops value, which is not a number of drops between packets, but rather a total number of drops. Deltas must be computed in user space. 2) While this patch currently works with datagram oriented protocols, it will also be accepted by non-datagram oriented protocols. I'm not sure if thats agreeable to everyone, but my argument in favor of doing so is that, for those protocols which aren't applicable to this option, sk_drops will always be zero, and reporting no drops on a receive queue that isn't used for those non-participating protocols seems reasonable to me. This also saves us having to code in a per-protocol opt in mechanism. 3) This applies cleanly to net-next assuming that commit 977750076d98c7ff6cbda51858bb5a5894a9d9ab (my af packet cmsg patch) is reverted Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-07net: mark net_proto_ops as constStephen Hemminger
All usages of structure net_proto_ops should be declared const. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-05net: mark read-only arrays as constJan Engelhardt
String literals are constant, and usually, we can also tag the array of pointers const too, moving it to the .rodata section. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-18net: correct off-by-one write allocations reportsEric Dumazet
commit 2b85a34e911bf483c27cfdd124aeb1605145dc80 (net: No more expensive sock_hold()/sock_put() on each tx) changed initial sk_wmem_alloc value. We need to take into account this offset when reporting sk_wmem_alloc to user, in PROC_FS files or various ioctls (SIOCOUTQ/TIOCOUTQ) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-27Bluetooth: Fix poll() misbehavior when using BT_DEFER_SETUPMarcel Holtmann
When BT_DEFER_SETUP has been enabled on a Bluetooth socket it keeps signaling POLLIN all the time. This is a wrong behavior. The POLLIN should only be signaled if the client socket is in BT_CONNECT2 state and the parent has been BT_DEFER_SETUP enabled. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-02-27Bluetooth: Remove CONFIG_DEBUG_LOCK_ALLOC ifdefsDave Young
Due to lockdep changes, the CONFIG_DEBUG_LOCK_ALLOC ifdef is not needed now. So just remove it here. The following commit fixed the !lockdep build warnings: commit e8f6fbf62de37cbc2e179176ac7010d5f4396b67 Author: Ingo Molnar <mingo@elte.hu> Date: Wed Nov 12 01:38:36 2008 +0000 lockdep: include/linux/lockdep.h - fix warning in net/bluetooth/af_bluetooth.c Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-02-27Bluetooth: Update version numbersMarcel Holtmann
With the support for the enhanced security model and the support for deferring connection setup, it is a good idea to increase various version numbers. This is purely cosmetic and has no effect on the behavior, but can be really helpful when debugging problems in different kernel versions. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-02-27Bluetooth: Add global deferred socket parameterMarcel Holtmann
The L2CAP and RFCOMM applications require support for authorization and the ability of rejecting incoming connection requests. The socket interface is not really able to support this. This patch does the ground work for a socket option to defer connection setup. Setting this option allows calling of accept() and then the first read() will trigger the final connection setup. Calling close() would reject the connection. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2008-11-30Bluetooth: Enable per-module dynamic debug messagesMarcel Holtmann
With the introduction of CONFIG_DYNAMIC_PRINTK_DEBUG it is possible to allow debugging without having to recompile the kernel. This patch turns all BT_DBG() calls into pr_debug() to support dynamic debug messages. As a side effect all CONFIG_BT_*_DEBUG statements are now removed and some broken debug entries have been fixed. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2008-11-30Bluetooth: Send HCI Reset command by default on device initializationMarcel Holtmann
The Bluetooth subsystem was not using the HCI Reset command when doing device initialization. The Bluetooth 1.0b specification was ambiguous on how the device firmware was suppose to handle it. Almost every device was triggering a transport reset at the same time. In case of USB this ended up in disconnects from the bus. All modern Bluetooth dongles handle this perfectly fine and a lot of them actually require that HCI Reset is sent. If not then they are either stuck in their HID Proxy mode or their internal structures for inquiry and paging are not correctly setup. To handle old and new devices smoothly the Bluetooth subsystem contains a quirk to force the HCI Reset on initialization. However maintaining such a quirk becomes more and more complicated. This patch turns the logic around and lets the old devices disable the HCI Reset command. The only device where the HCI_QUIRK_NO_RESET is still needed are the original Digianswer devices and dongles with an early CSR firmware. CSR reported that they fixed this for version 12 firmware. The last official release of version 11 firmware is build ID 115. The first version 12 candidate was build ID 117. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2008-11-30Bluetooth: Fix warnings for bt_key_strings and bt_slock_key_stringsMarcel Holtmann
After adding proper lockdep annotations for Bluetooth protocols the case when lockdep is disabled produced two compiler warnings: net/bluetooth/af_bluetooth.c:60: warning: ‘bt_key_strings’ defined but not used net/bluetooth/af_bluetooth.c:71: warning: ‘bt_slock_key_strings’ defined but not used Fix both of them by adding a CONFIG_DEBUG_LOCK_ALLOC conditional around them and re-arranging the code a little bit. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2008-10-16net: Remove CONFIG_KMOD from net/ (towards removing CONFIG_KMOD entirely)Johannes Berg
Some code here depends on CONFIG_KMOD to not try to load protocol modules or similar, replace by CONFIG_MODULES where more than just request_module depends on CONFIG_KMOD and and also use try_then_request_module in ebtables. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-09[Bluetooth] Reject L2CAP connections on an insecure ACL linkMarcel Holtmann
The Security Mode 4 of the Bluetooth 2.1 specification has strict authentication and encryption requirements. It is the initiators job to create a secure ACL link. However in case of malicious devices, the acceptor has to make sure that the ACL is encrypted before allowing any kind of L2CAP connection. The only exception here is the PSM 1 for the service discovery protocol, because that is allowed to run on an insecure ACL link. Previously it was enough to reject a L2CAP connection during the connection setup phase, but with Bluetooth 2.1 it is forbidden to do any L2CAP protocol exchange on an insecure link (except SDP). The new hci_conn_check_link_mode() function can be used to check the integrity of an ACL link. This functions also takes care of the cases where Security Mode 4 is disabled or one of the devices is based on an older specification. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2008-08-18[Bluetooth] Consolidate maintainers informationMarcel Holtmann
The Bluetooth entries for the MAINTAINERS file are a little bit too much. Consolidate them into two entries. One for Bluetooth drivers and another one for the Bluetooth subsystem. Also the MODULE_AUTHOR should indicate the current maintainer of the module and actually not the original author. Fix all Bluetooth modules to provide current maintainer information. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2008-07-14[Bluetooth] Update Bluetooth core version numberMarcel Holtmann
With all the Bluetooth 2.1 changes and the support for Simple Pairing, it is important to update the Bluetooth core version number. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2008-07-14[Bluetooth] Add support for TIOCOUTQ and TIOCINQ ioctlsMarcel Holtmann
Almost every protocol family supports the TIOCOUTQ and TIOCINQ ioctls and even Bluetooth could make use of them. When implementing audio streaming and integration with GStreamer or PulseAudio they will allow a better timing and synchronization. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2008-07-14[Bluetooth] Add timestamp support to L2CAP, RFCOMM and SCOMarcel Holtmann
Enable the common timestamp functionality that the network subsystem provides for L2CAP, RFCOMM and SCO sockets. It is possible to either use SO_TIMESTAMP or the IOCTLs to retrieve the timestamp of the current packet. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2008-04-01bluetooth : use lockdep sub-classes for diffrent bluetooth protocolDave Young
'rfcomm connect' will trigger lockdep warnings which is caused by locking diffrent kinds of bluetooth sockets at the same time. So using sub-classes per AF_BLUETOOTH sub-type for lockdep. Thanks for the hints from dave jones. --- > From: Dave Jones <davej@codemonkey.org.uk> > Date: Thu, 27 Mar 2008 12:21:56 -0400 > > > Mar 27 08:10:57 localhost kernel: Pid: 3611, comm: obex-data-serve Not tainted 2.6.25-0.121.rc5.git4.fc9 #1 > > Mar 27 08:10:57 localhost kernel: [__lock_acquire+2287/3089] __lock_acquire+0x8ef/0xc11 > > Mar 27 08:10:57 localhost kernel: [sched_clock+8/11] ? sched_clock+0x8/0xb > > Mar 27 08:10:57 localhost kernel: [lock_acquire+106/144] lock_acquire+0x6a/0x90 > > Mar 27 08:10:57 localhost kernel: [<f8bd9321>] ? l2cap_sock_bind+0x29/0x108 [l2cap] > > Mar 27 08:10:57 localhost kernel: [lock_sock_nested+182/198] lock_sock_nested+0xb6/0xc6 > > Mar 27 08:10:57 localhost kernel: [<f8bd9321>] ? l2cap_sock_bind+0x29/0x108 [l2cap] > > Mar 27 08:10:57 localhost kernel: [security_socket_post_create+22/27] ? security_socket_post_create+0x16/0x1b > > Mar 27 08:10:57 localhost kernel: [__sock_create+388/472] ? __sock_create+0x184/0x1d8 > > Mar 27 08:10:57 localhost kernel: [<f8bd9321>] l2cap_sock_bind+0x29/0x108 [l2cap] > > Mar 27 08:10:57 localhost kernel: [kernel_bind+10/13] kernel_bind+0xa/0xd > > Mar 27 08:10:57 localhost kernel: [<f8dad3d7>] rfcomm_dlc_open+0xc8/0x294 [rfcomm] > > Mar 27 08:10:57 localhost kernel: [lock_sock_nested+187/198] ? lock_sock_nested+0xbb/0xc6 > > Mar 27 08:10:57 localhost kernel: [<f8dae18c>] rfcomm_sock_connect+0x8b/0xc2 [rfcomm] > > Mar 27 08:10:57 localhost kernel: [sys_connect+96/125] sys_connect+0x60/0x7d > > Mar 27 08:10:57 localhost kernel: [__lock_acquire+1370/3089] ? __lock_acquire+0x55a/0xc11 > > Mar 27 08:10:57 localhost kernel: [sys_socketcall+140/392] sys_socketcall+0x8c/0x188 > > Mar 27 08:10:57 localhost kernel: [syscall_call+7/11] syscall_call+0x7/0xb --- Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make socket creation namespace safe.Eric W. Biederman
This patch passes in the namespace a new socket should be created in and has the socket code do the appropriate reference counting. By virtue of this all socket create methods are touched. In addition the socket create methods are modified so that they will fail if you attempt to create a socket in a non-default network namespace. Failing if we attempt to create a socket outside of the default network namespace ensures that as we incrementally make the network stack network namespace aware we will not export functionality that someone has not audited and made certain is network namespace safe. Allowing us to partially enable network namespaces before all of the exotic protocols are supported. Any protocol layers I have missed will fail to compile because I now pass an extra parameter into the socket creation code. [ Integrated AF_IUCV build fixes from Andrew Morton... -DaveM ] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_reset_transport_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->h.raw = skb->data' operation, so that we can later turn skb->h.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple cases: skb->h.raw = skb->data; skb->h.raw = {skb_push|[__]skb_pull}() The next ones will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] BLUETOOTH: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-15[Bluetooth] Add locking for bt_proto array manipulationMarcel Holtmann
The bt_proto array needs to be protected by some kind of locking to prevent a race condition between bt_sock_create and bt_sock_register. And in addition all calls to sk_alloc need to be made GFP_ATOMIC now. Signed-off-by: Masatake YAMATO <jet@gyve.org> Signed-off-by: Frederik Deweerdt <frederik.deweerdt@gmail.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-10-15[Bluetooth] Support concurrent connect requestsMarcel Holtmann
Most Bluetooth chips don't support concurrent connect requests, because this would involve a multiple baseband page with only one radio. In the case an upper layer like L2CAP requests a concurrent connect these chips return the error "Command Disallowed" for the second request. If this happens it the responsibility of the Bluetooth core to queue the request and try again after the previous connect attempt has been completed. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-09-28[Bluetooth] Return EINPROGRESS for non-blocking socket callsMarcel Holtmann
In case of non-blocking socket calls we should return EINPROGRESS and not EAGAIN. Signed-off-by: Ulisses Furquim <ulissesf@gmail.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-07-03[Bluetooth] Add platform device for virtual and serial devicesMarcel Holtmann
This patch adds a generic Bluetooth platform device that can be used as parent device by virtual and serial devices. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-07-03[Bluetooth] Add automatic sniff mode supportMarcel Holtmann
This patch introduces the automatic sniff mode feature. This allows the host to switch idle connections into sniff mode to safe power. Signed-off-by: Ulisses Furquim <ulissesf@gmail.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-03-25[PATCH] POLLRDHUP/EPOLLRDHUP handling for half-closed devices notificationsDavide Libenzi
Implement the half-closed devices notifiation, by adding a new POLLRDHUP (and its alias EPOLLRDHUP) bit to the existing poll/select sets. Since the existing POLLHUP handling, that does not report correctly half-closed devices, was feared to be changed, this implementation leaves the current POLLHUP reporting unchanged and simply add a new bit that is set in the few places where it makes sense. The same thing was discussed and conceptually agreed quite some time ago: http://lkml.org/lkml/2003/7/12/116 Since this new event bit is added to the existing Linux poll infrastruture, even the existing poll/select system calls will be able to use it. As far as the existing POLLHUP handling, the patch leaves it as is. The pollrdhup-2.6.16.rc5-0.10.diff defines the POLLRDHUP for all the existing archs and sets the bit in the six relevant files. The other attached diff is the simple change required to sys/epoll.h to add the EPOLLRDHUP definition. There is "a stupid program" to test POLLRDHUP delivery here: http://www.xmailserver.org/pollrdhup-test.c It tests poll(2), but since the delivery is same epoll(2) will work equally. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03[NET]: Avoid atomic xchg() for non-error caseBenjamin LaHaise
It also looks like there were 2 places where the test on sk_err was missing from the event wait logic (in sk_stream_wait_connect and sk_stream_wait_memory), while the rest of the sock_error() users look to be doing the right thing. This version of the patch fixes those, and cleans up a few places that were testing ->sk_err directly. Signed-off-by: Benjamin LaHaise <benjamin.c.lahaise@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-08[Bluetooth]: Remove the usage of /proc completelyMarcel Holtmann
This patch removes all relics of the /proc usage from the Bluetooth subsystem core and its upper layers. All the previous information are now available via /sys/class/bluetooth through appropriate functions. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-28[Bluetooth] Make more functions staticMarcel Holtmann
This patch makes another bunch of functions static. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2005-04-25[PATCH] kill gratitious includes of major.h under net/*Al Viro
A lot of places in there are including major.h for no reason whatsoever. Removed. And yes, it still builds. The history of that stuff is often amusing. E.g. for net/core/sock.c the story looks so, as far as I've been able to reconstruct it: we used to need major.h in net/socket.c circa 1.1.early. In 1.1.13 that need had disappeared, along with register_chrdev(SOCKET_MAJOR, "socket", &net_fops) in sock_init(). Include had not. When 1.2 -> 1.3 reorg of net/* had moved a lot of stuff from net/socket.c to net/core/sock.c, this crap had followed... Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
