netdev->dev_addr will be constant soon, make sure
the qualifier is propagated thru batman-adv.
Signed-off-by: Jakub Kicinski <kuba@kernel.org>
Acked-by: Sven Eckelmann <sven@narfation.org>
The check if a batman-adv related object is NULL or not is now directly in
the batadv_*_put functions. It is not needed anymore to perform this check
outside these function:
The changes were generated using a coccinelle semantic patch:
expression E;
- if (likely(E != NULL))
batadv_backbone_gw_put
batadv_claim_put
batadv_dat_entry_put
batadv_gw_node_put
batadv_hardif_neigh_put
batadv_hardif_put
batadv_nc_node_put
batadv_nc_path_put
batadv_neigh_ifinfo_put
batadv_neigh_node_put
batadv_orig_ifinfo_put
batadv_orig_node_put
batadv_orig_node_vlan_put
batadv_softif_vlan_put
batadv_tp_vars_put
batadv_tt_global_entry_put
batadv_tt_local_entry_put
batadv_tt_orig_list_entry_put
batadv_tt_req_node_put
batadv_tvlv_container_put
batadv_tvlv_handler_put
)(E);
Signed-off-by: Sven Eckelmann <sven@narfation.org>
Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
The commit b37a46683739 ("netdevice: add the case if dev is NULL") changed
the way how the NULL check for net_devices have to be handled when trying
to reduce its reference counter. Before this commit, it was the
responsibility of the caller to check whether the object is NULL or not.
But it was changed to behave more like kfree. Now the callee has to handle
the NULL-case.
The batman-adv code was scanned via cocinelle for similar places. These
were changed to use the paradigm
identifier E, T, R, C;
identifier put;
void put(struct T *E)
+ if (!E)
+ return;
kref_put(&E->C, R);
Functions which were used in other sources files were moved to the header
to allow the compiler to inline the NULL check and the kref_put call.
The batman-adv source code was using the year of publication (to net-next)
as "last" year for the copyright statement. The whole source code mentioned
in the MAINTAINERS "BATMAN ADVANCED" section was handled as a single entity
regarding the publishing year.
This avoided having outdated (in sense of year information - not copyright
holder) publishing information inside several files. But since the simple
"update copyright year" commit (without other changes) in the file was not
well received in the upstream kernel, the option to not have a copyright
year (for initial and last publication) in the files are chosen instead.
More detailed information about the years can still be retrieved from the
SCM system.
Acked-by: Marek Lindner <mareklindner@neomailbox.ch>
All files got a SPDX-License-Identifier with commit 7db7d9f369a4
("batman-adv: Add SPDX license identifier above copyright header"). All the
required information about the license conditions can be found in
LICENSES/.
The function batadv_tvlv_handler_register is responsible for adding new
tvlv_handler to the handler_list. It first checks whether the entry
already is in the list or not. If it is, then the creation of a new entry
is aborted.
But the lock for the list is only held when the list is really modified.
This could lead to duplicated entries because another context could create
an entry with the same key between the check and the list manipulation.
The check and the manipulation of the list must therefore be in the same
locked code section.
Fixes: ef26157747d4 ("batman-adv: tvlv - basic infrastructure")
The header file is used by different userspace programs to inject packets
or to decode sniffed packets. It should therefore be available to them as
userspace header.
Also other components in the kernel (like the flow dissector) require
access to the packet definitions to be able to decode ETH_P_BATMAN ethernet
packets.
Signed-off-by: Sven Eckelmann <sven.eckelmann@openmesh.com>
The documentation describing kernel-doc comments for functions ("How to
format kernel-doc comments") uses parentheses at the end of the function
name. Using this format allows to use a consistent style when adding
documentation to a function and when referencing this function in a
different kernel-doc section.
The linux/gfp.h provides the GFP_ATOMIC and GFP_KERNEL define. It should
therefore be included instead of linux/fs.h.
The "Linux kernel licensing rules" require that each file has a SPDX
license identifier as first line (and sometimes as second line).
The FSFE REUSE practices [1] would also require the same tags but have no
restrictions on the placement in the source file. Using the "Linux kernel
licensing rules" is therefore also fulfilling the FSFE REUSE practices
requirements at the same time.
[1] https://reuse.software/practices/
Sending functions in Linux consume the supplied skbuff. Doing the same in
batadv_send_skb_to_orig avoids the hack of returning -1 (-EPERM) to signal
the caller that he is responsible for cleaning up the skb.
It is hard to understand why the refcnt is increased when it isn't done
near the actual place the new reference is used. So using kref_get right
before the place which requires the reference and in the same function
helps to avoid accidental problems caused by incorrect reference counting.
Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch>
Return the proper netdev TX status along the TX path so that the tp_meter
can understand when the queue is full and should stop sending packets.
Signed-off-by: Antonio Quartulli <antonio.quartulli@open-mesh.com>
Signed-off-by: Sven Eckelmann <sven.eckelmann@open-mesh.com>
The tvlv functionality in main.c is mostly unrelated to the rest of the
content. It still takes up a large portion of this source file (~45%, 588
lines). Moving it to a separate file makes it better visible as a main
component of the batman-adv implementation and hides it less in the other
helper functions in main.c
Signed-off-by: Markus Pargmann <mpa@pengutronix.de>
[sven@narfation.org: fix conflicts with current version, fix includes,
rewrote commit message]
