path: root/net/ax25/ax25_out.c
2005-04-24[AX25] Introduce ax25_type_transArnaldo Carvalho de Melo
Replacing the open coded equivalents and making ax25 look more like a linux network protocol, i.e. more similar to inet. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-21[AX25]: make ax25_queue_xmit a net_device parameterArnaldo Carvalho de Melo
I.e. not using skb->dev as a way to pass the parameter used to fill... skb->dev :-) Also to get the _type_trans open coded sequence grouped, next changesets will introduce ax25_type_trans. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
