Stanse found that mpc_push frees skb and then it dereferences it. It
is a typo, new_skb should be dereferenced there.
This patch removes from net/ (but not any netfilter files)
all the unnecessary return; statements that precede the
last closing brace of void functions.
It does not remove the returns that are immediately
preceded by a label as gcc doesn't like that.
Done via:
$ grep -rP --include=*.[ch] -l "return;\n}" net/ | \
xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }'
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Move "mpoa:%s: ", __func__/__FILE__ to #defines
Remove mpoa __func__/__FILE__ from dprintk uses
Add and use #define dprint_cont where appropriate
Convert #include <asm... to #include <linux...
Add printk argument verification to dprintk and ddprintk
Spacing cleanups
Mostly 80 column wrapped.
printk->pr_info and pr_cont
Moved labels to column 1
Move trailing statements to new lines
switch/case cleanups
remove unnecessary breaks after returns
Remove unnecessary braces around single line statements
Add #define pr_fmt(fmt) KBUILD_MODNAME ":%s: " fmt, __func__
Remove function names from output
Use single line pr_debug instead of broken multiple uses without newline
This patch converts the remaining occurences of raw return values to their
symbolic counterparts in ndo_start_xmit() functions that were missed by the
previous automatic conversion.
Additionally code that assumed the symbolic value of NETDEV_TX_OK to be zero
is changed to explicitly use NETDEV_TX_OK.
This converts the mpc device to using new netdevice_ops.
Compile tested only, needs more than usual review since
device was swaping pointers around etc.
Acked-by: Chas Williams <chas@cmf.nrl.navy.mil>
This is the last shoot of this series.
After I removing all directly reference of netdev->priv, I am killing
"priv" of "struct net_device" and fixing relative comments/docs.
Anyone will not be allowed to reference netdev->priv directly.
If you want to reference the memory of private data, use netdev_priv()
instead.
If the private data is not allocted when alloc_netdev(), use
netdev->ml_priv to point that memory after you creating that private
data.
Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com>
We have some reasons to kill netdev->priv:
1. netdev->priv is equal to netdev_priv().
2. netdev_priv() wraps the calculation of netdev->priv's offset, obviously
netdev_priv() is more flexible than netdev->priv.
But we cann't kill netdev->priv, because so many drivers reference to it
directly.
This patch is a safe convert for netdev->priv to netdev_priv(netdev).
Since all of the netdev->priv is only for read.
But it is too big to be sent in one mail.
I split it to 4 parts and make every part smaller than 100,000 bytes,
which is max size allowed by vger.
Using NIPQUAD() with NIPQUAD_FMT, %d.%d.%d.%d or %u.%u.%u.%u
can be replaced with %pI4
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Fix const assignment/discard warnings in the ATM networking driver.
The lane2_assoc_ind() function needed its arguments changing to match changes
in the lane2_ops struct (patch 61c33e012964ce358b42d2a1e9cd309af5dab02b
"atm: use const where reasonable").
Without CONFIG_NET_NS, namespace is always &init_net.
Compiler will be able to omit namespace comparisons with this patch.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Introduce per-net_device inlines: dev_net(), dev_net_set().
Without CONFIG_NET_NS, no namespace other than &init_net exists.
Let's explicitly define them to help compiler optimizations.
Al went through the ip_fast_csum callers and found this piece of code
that did not validate the IP header. While root crashing the machine
by sending bogus packets through raw or AF_PACKET sockets isn't that
serious, it is still nice to react gracefully.
This patch ensures that the skb has enough data for an IP header and
that the header length field is valid.
This patch makes most of the generic device layer network
namespace safe. This patch makes dev_base_head a
network namespace variable, and then it picks up
a few associated variables. The functions:
dev_getbyhwaddr
dev_getfirsthwbytype
dev_get_by_flags
dev_get_by_name
__dev_get_by_name
dev_get_by_index
__dev_get_by_index
dev_ioctl
dev_ethtool
dev_load
wireless_process_ioctl
were modified to take a network namespace argument, and
deal with it.
vlan_ioctl_set and brioctl_set were modified so their
hooks will receive a network namespace argument.
So basically anthing in the core of the network stack that was
affected to by the change of dev_base was modified to handle
multiple network namespaces. The rest of the network stack was
simply modified to explicitly use &init_net the initial network
namespace. This can be fixed when those components of the network
stack are modified to handle multiple network namespaces.
For now the ifindex generator is left global.
Fundametally ifindex numbers are per namespace, or else
we will have corner case problems with migration when
we get that far.
At the same time there are assumptions in the network stack
that the ifindex of a network device won't change. Making
the ifindex number global seems a good compromise until
the network stack can cope with ifindex changes when
you change namespaces, and the like.
Every user of the network device notifiers is either a protocol
stack or a pseudo device. If a protocol stack that does not have
support for multiple network namespaces receives an event for a
device that is not in the initial network namespace it quite possibly
can get confused and do the wrong thing.
To avoid problems until all of the protocol stacks are converted
this patch modifies all netdev event handlers to ignore events on
devices that are not in the initial network namespace.
As the rest of the code is made network namespace aware these
checks can be removed.
SPIN_LOCK_UNLOCKED cleanup,use __SPIN_LOCK_UNLOCKED instead
Signed-off-by: Milind Arun Choudhary <milindchoudhary@gmail.com>
To clearly state the intent of copying to linear sk_buffs, _offset being a
overly long variant but interesting for the sake of saving some bytes.
Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
For the common, open coded 'skb->nh.raw = skb->data' operation, so that we can
later turn skb->nh.raw into a offset, reducing the size of struct sk_buff in
64bit land while possibly keeping it as a pointer on 32bit.
This one touches just the most simple case, next will handle the slightly more
"complex" cases.
Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil>
Signed-off-by: Panagiotis Issaris <takis@issaris.org>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
net/atm/mpc.c: In function 'MPOA_res_reply_rcvd':
net/atm/mpc.c:1116: warning: unused variable 'ip'
NIPQUAD expects an l-value of type __be32, _NOT_ a pointer to __be32.
net: Use <linux/capability.h> where capable() is used.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
This changes some memcmp(one,two,ETH_ALEN) to compare_ether_addr(one,two).
Signed-off-by: Kris Katterjohn <kjak@users.sourceforge.net>
Clean up timer initialization by introducing DEFINE_TIMER a'la
DEFINE_SPINLOCK. Build and boot-tested on x86. A similar patch has been
been in the -RT tree for some time.
infrastructure for it.
Let it rip!
