path: root/net/atm/clip.c
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2012-02-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/sfc/rx.c Overlapping changes in drivers/net/ethernet/sfc/rx.c, one to change the rx_buf->is_page boolean into a set of u16 flags, and another to adjust how ->ip_summed is initialized. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-22atm: clip: remove clip_tblEric Dumazet
Commit 32092ecf0644 (atm: clip: Use device neigh support on top of "arp_tbl".) introduced a bug since clip_tbl is zeroed : Crash occurs in __neigh_for_each_release() idle_timer_check() must use instead arp_tbl and neigh_check_cb() should ignore non clip neighbours. Idea from David Miller. Reported-by: Meelis Roos <mroos@linux.ee> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Tested-by: Meelis Roos <mroos@linux.ee> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-01atm: clip: Convert over to dst_neigh_lookup().David S. Miller
CLIP only support ipv4, and this is evidenced by the fact that it is a device specific extension of arp_tbl, so this conversion is pretty straightforward. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-05net: Rename dst_get_neighbour{, _raw} to dst_get_neighbour_noref{, _raw}.David Miller
To reflect the fact that a refrence is not obtained to the resulting neighbour entry. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Roland Dreier <roland@purestorage.com>
2011-12-02atm: clip: Remove code commented out since eternity.David S. Miller
2011-11-30atm: clip: Use device neigh support on top of "arp_tbl".David Miller
Instead of instantiating an entire new neigh_table instance just for ATM handling, use the neigh device private facility. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-30atm: clip: Convert over to neighbour_priv()David Miller
2011-11-30neigh: Do not set tbl->entry_size in ipv4/ipv6 neigh tables.David Miller
Let the core self-size the neigh entry based upon the key length. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-30neigh: Add infrastructure for allocating device neigh privates.David Miller
netdev->neigh_priv_len records the private area length. This will trigger for neigh_table objects which set tbl->entry_size to zero, and the first instances of this will be forthcoming. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-22atm: Introduce vcc_process_recv_queueJorge Boncompte [DTI2]
This function moves the implementation found in the clip and br2684 modules to common code, correctly unlinks the skb from the queue before pushing it and makes pppoatm use it. Signed-off-by: Jorge Boncompte [DTI2] <jorge@dti2.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-22atm: clip: move clip_devs check to clip_pushJorge Boncompte [DTI2]
This will allow further cleanup. Signed-off-by: Jorge Boncompte [DTI2] <jorge@dti2.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-22atm: clip: Don't move counters backwardsJorge Boncompte [DTI2]
I don't see the point on substracting the skb len from the netdev stats. Signed-off-by: Jorge Boncompte [DTI2] <jorge@dti2.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-14neigh: new unresolved queue limitsEric Dumazet
Le mercredi 09 novembre 2011 à 16:21 -0500, David Miller a écrit : > From: David Miller <davem@davemloft.net> > Date: Wed, 09 Nov 2011 16:16:44 -0500 (EST) > > > From: Eric Dumazet <eric.dumazet@gmail.com> > > Date: Wed, 09 Nov 2011 12:14:09 +0100 > > > >> unres_qlen is the number of frames we are able to queue per unresolved > >> neighbour. Its default value (3) was never changed and is responsible > >> for strange drops, especially if IP fragments are used, or multiple > >> sessions start in parallel. Even a single tcp flow can hit this limit. > > ... > > > > Ok, I've applied this, let's see what happens :-) > > Early answer, build fails. > > Please test build this patch with DECNET enabled and resubmit. The > decnet neigh layer still refers to the removed ->queue_len member. > > Thanks. Ouch, this was fixed on one machine yesterday, but not the other one I used this morning, sorry. [PATCH V5 net-next] neigh: new unresolved queue limits unres_qlen is the number of frames we are able to queue per unresolved neighbour. Its default value (3) was never changed and is responsible for strange drops, especially if IP fragments are used, or multiple sessions start in parallel. Even a single tcp flow can hit this limit. $ arp -d 192.168.20.108 ; ping -c 2 -s 8000 192.168.20.108 PING 192.168.20.108 (192.168.20.108) 8000(8028) bytes of data. 8008 bytes from 192.168.20.108: icmp_seq=2 ttl=64 time=0.322 ms Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-17net: Abstract dst->neighbour accesses behind helpers.David S. Miller
dst_{get,set}_neighbour() Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-17neigh: Pass neighbour entry to output ops.David S. Miller
This will get us closer to being able to do "neigh stuff" completely independent of the underlying dst_entry for protocols (ipv4/ipv6) that wish to do so. We will also be able to make dst entries neigh-less. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-16neigh: Kill ndisc_ops->queue_xmitDavid S. Miller
It is always dev_queue_xmit(). Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-16neigh: Kill neigh_ops->hh_outputDavid S. Miller
It's always dev_queue_xmit(). Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-12ipv4: Create and use route lookup helpers.David S. Miller
The idea here is this minimizes the number of places one has to edit in order to make changes to how flows are defined and used. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-02ipv4: Make output route lookup return rtable directly.David S. Miller
Instead of on the stack. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-17net: use the macros defined for the members of flowiChangli Gao
Use the macros defined for the members of flowi to clean the code up. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-05net neigh: RCU conversion of neigh hash tableEric Dumazet
David This is the first step for RCU conversion of neigh code. Next patches will convert hash_buckets[] and "struct neighbour" to RCU protected objects. Thanks [PATCH net-next] net neigh: RCU conversion of neigh hash table Instead of storing hash_buckets, hash_mask and hash_rnd in "struct neigh_table", a new structure is defined : struct neigh_hash_table { struct neighbour **hash_buckets; unsigned int hash_mask; __u32 hash_rnd; struct rcu_head rcu; }; And "struct neigh_table" has an RCU protected pointer to such a neigh_hash_table. This means the signature of (*hash)() function changed: We need to add a third parameter with the actual hash_rnd value, since this is not anymore a neigh_table field. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-10net-next: remove useless union keywordChangli Gao
remove useless union keyword in rtable, rt6_info and dn_route. Since there is only one member in a union, the union keyword isn't useful. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-01-26net/atm/clip.c: checkpatch cleanupsJoe Perches
Convert #include <asm... to #include <linux... Spacing cleanups Move labels to column 1 Move logical continuation tests to end of previous line Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-26net/atm: Convert printk to pr_<level>Joe Perches
Add #define pr_fmt(fmt) KBUILD_MODNAME ":%s: " fmt, __func__ Remove function names from output Use single line pr_debug instead of broken multiple uses without newline Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01net: make neigh_ops constantStephen Hemminger
These tables are never modified at runtime. Move to read-only section. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01convert ATM drivers to netdev_tx_tStephen Hemminger
2009-07-05net: use NETDEV_TX_OK instead of 0 in ndo_start_xmit() functionsPatrick McHardy
This patch is the result of an automatic spatch transformation to convert all ndo_start_xmit() return values of 0 to NETDEV_TX_OK. Some occurences are missed by the automatic conversion, those will be handled in a seperate patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-03net: skb->dst accessorsEric Dumazet
Define three accessors to get/set dst attached to a skb struct dst_entry *skb_dst(const struct sk_buff *skb) void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst) void skb_dst_drop(struct sk_buff *skb) This one should replace occurrences of : dst_release(skb->dst) skb->dst = NULL; Delete skb->dst field Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-29atm: unset IFF_XMIT_DST_RELEASE in clip_setup()Eric Dumazet
clip_start_xmit() needs skb->dst so tell dev_hard_start_xmit() to no release it. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-28atm: Use SKB queue and list helpers instead of doing it by-hand.David S. Miller
2009-03-21atm: convert clip driver to net_device_opsStephen Hemminger
2009-01-21clip: convert to internal network_device_statsStephen Hemminger
2008-10-31net: replace NIPQUAD() in net/*/Harvey Harrison
Using NIPQUAD() with NIPQUAD_FMT, %d.%d.%d.%d or %u.%u.%u.%u can be replaced with %pI4 Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-19netns: Use net_eq() to compare net-namespaces for optimization.YOSHIFUJI Hideaki
Without CONFIG_NET_NS, namespace is always &init_net. Compiler will be able to omit namespace comparisons with this patch. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26[NET] NETNS: Omit net_device->nd_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-net_device inlines: dev_net(), dev_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-23Merge branch 'master' of ../net-2.6/David S. Miller
Conflicts: net/ipv6/ndisc.c
2008-03-23[ATM]: When proc_create() fails, do some error handling work and return -ENOMEM.Wang Chen
Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28[IPV4]: Remove check for ifa->ifa_dev != NULL.Denis V. Lunev
This is a callback registered to inet address notifier chain. The check is useless as: - ifa->ifa_dev is always != NULL - similar checks are abscent in all other notifiers. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28[ATM]: Use proc_create() to setup ->proc_fops firstWang Chen
Use proc_create() to make sure that ->proc_fops be setup before gluing PDE to main tree. Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Add namespace parameter to ip_route_output_key.Denis V. Lunev
Needed to propagate it down to the ip_route_output_flow. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[ATM]: Simplify /proc/net/atm/arp openingDenis V. Lunev
The iterator state->ns.neigh_sub_iter initialization is moved from arp_seq_open to clip_seq_start for convinience. This should not be a problem as the iterator will be used only after the seq_start callback. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Add netns parameter to inet_(dev_)add_type.Eric W. Biederman
The patch extends the inet_addr_type and inet_dev_addr_type with the network namespace pointer. That allows to access the different tables relatively to the network namespace. The modification of the signature function is reported in all the callers of the inet_addr_type using the pointer to the well known init_net. Acked-by: Benjamin Thery <benjamin.thery@bull.net> Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Modify the neighbour table code so it handles multiple network ↵Eric W. Biederman
namespaces I'm actually surprised at how much was involved. At first glance it appears that the neighbour table data structures are already split by network device so all that should be needed is to modify the user interface commands to filter the set of neighbours by the network namespace of their devices. However a couple things turned up while I was reading through the code. The proxy neighbour table allows entries with no network device, and the neighbour parms are per network device (except for the defaults) so they now need a per network namespace default. So I updated the two structures (which surprised me) with their very own network namespace parameter. Updated the relevant lookup and destroy routines with a network namespace parameter and modified the code that interacts with users to filter out neighbour table entries for devices of other namespaces. I'm a little concerned that we can modify and display the global table configuration and from all network namespaces. But this appears good enough for now. I keep thinking modifying the neighbour table to have per network namespace instances of each table type would should be cleaner. The hash table is already dynamically sized so there are it is not a limiter. The default parameter would be straight forward to take care of. However when I look at the how the network table is built and used I still find some assumptions that there is only a single neighbour table for each type of table in the kernel. The netlink operations, neigh_seq_start, the non-core network users that call neigh_lookup. So while it might be doable it would require more refactoring than my current approach of just doing a little extra filtering in the code. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make device event notification network namespace safeEric W. Biederman
Every user of the network device notifiers is either a protocol stack or a pseudo device. If a protocol stack that does not have support for multiple network namespaces receives an event for a device that is not in the initial network namespace it quite possibly can get confused and do the wrong thing. To avoid problems until all of the protocol stacks are converted this patch modifies all netdev event handlers to ignore events on devices that are not in the initial network namespace. As the rest of the code is made network namespace aware these checks can be removed. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[ATM]: Replace DPRINTK() with pr_debug().Stephen Hemminger
Get rid of using DPRINTK macro in ATM and use pr_debug (in kernel.h). Using the standard macro is cleaner and forces code to check for bad arguments and formatting. Fixes from Thomas Graf. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NET]: Make all initialized struct seq_operations const.Philippe De Muyter
Make all initialized struct seq_operations in net/ const Signed-off-by: Philippe De Muyter <phdm@macqel.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[NET]: SPIN_LOCK_UNLOCKED cleanup in drivers/atm, netMilind Arun Choudhary
SPIN_LOCK_UNLOCKED cleanup,use __SPIN_LOCK_UNLOCKED instead Signed-off-by: Milind Arun Choudhary <milindchoudhary@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
