[ Upstream commit 39935dccb21c60f9bbf1bb72d22ab6fd14ae7705 ]
If a DDP broadcast packet is sent out to a non-gateway target, it is
also looped back. There is a potential for the loopback device to have a
longer hardware header length than the original target route's device,
which can result in the skb not being created with enough room for the
loopback device's hardware header. This patch fixes the issue by
determining that a loopback will be necessary prior to allocating the
skb, and if so, ensuring the skb has enough room.
This was discovered while testing a new driver that creates a LocalTalk
network interface (LTALK_HLEN = 1). It caused an skb_under_panic.
Signed-off-by: Doug Brown <doug@schmorgal.com>
[ Upstream commit d0f6ba2ef2c1c95069509e71402e7d6d43452512 ]
Add a missing return statement to atalk_proc_init so it doesn't return
-ENOMEM when successful. This allows the appletalk module to load
properly.
Fixes: e2bcd8b0ce6e ("appletalk: use remove_proc_subtree to simplify procfs code")
Link: https://www.downtowndougbrown.com/2020/08/hacking-up-a-fix-for-the-broken-appletalk-kernel-module-in-linux-5-1-and-newer/
Reported-by: Christopher KOBAYASHI <chris@disavowed.jp>
Reported-by: Doug Brown <doug@downtowndougbrown.com>
Signed-off-by: Vincent Duvert <vincent.ldev@duvert.net>
[lukas: add missing tags]
Signed-off-by: Lukas Wunner <lukas@wunner.de>
Cc: stable@vger.kernel.org # v5.1+
Cc: Yue Haibing <yuehaibing@huawei.com>
When creating a raw AF_APPLETALK socket, CAP_NET_RAW needs to be checked
first.
Signed-off-by: Ori Nimron <orinimron123@gmail.com>
Use accessor functions for skb fragment's page_offset instead
of direct references, in preparation for bvec conversion.
Signed-off-by: Jonathan Lemon <jonathan.lemon@gmail.com>
Based on 1 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license as published by
the free software foundation version 2
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 135 file(s).
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190531081036.435762997@linutronix.de
the free software foundation either version 2 of the license or at
your option any later version
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 3029 file(s).
Link: https://lkml.kernel.org/r/20190527070032.746973796@linutronix.de
Add SPDX license identifiers to all Make/Kconfig files which:
- Have no license information of any form
These files fall under the project license, GPL v2 only. The resulting SPDX
license identifier is:
GPL-2.0-only
Three trivial overlapping conflicts.
If register_snap_client fails in atalk_init,
error code should be set, otherwise it will
triggers NULL pointer dereference while unloading
module.
Fixes: 9804501fa122 ("appletalk: Fix potential NULL pointer dereference in unregister_snap_client")
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
The SIOCGSTAMP/SIOCGSTAMPNS ioctl commands are implemented by many
socket protocol handlers, and all of those end up calling the same
sock_get_timestamp()/sock_get_timestampns() helper functions, which
results in a lot of duplicate code.
With the introduction of 64-bit time_t on 32-bit architectures, this
gets worse, as we then need four different ioctl commands in each
socket protocol implementation.
To simplify that, let's add a new .gettstamp() operation in
struct proto_ops, and move ioctl implementation into the common
sock_ioctl()/compat_sock_ioctl_trans() functions that these all go
through.
We can reuse the sock_get_timestamp() implementation, but generalize
it so it can deal with both native and compat mode, as well as
timeval and timespec structures.
Acked-by: Stefan Schmidt <stefan@datenfreihafen.org>
Acked-by: Marc Kleine-Budde <mkl@pengutronix.de>
Link: https://lore.kernel.org/lkml/CAK8P3a038aDQQotzua_QtKGhq8O9n+rdiz2=WDCp82ys8eUT+A@mail.gmail.com/
Acked-by: Willem de Bruijn <willemb@google.com>
register_snap_client may return NULL, all the callers
check it, but only print a warning. This will result in
NULL pointer dereference in unregister_snap_client and other
places.
It has always been used like this since v2.6
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
KASAN report this:
BUG: KASAN: use-after-free in pde_subdir_find+0x12d/0x150 fs/proc/generic.c:71
Read of size 8 at addr ffff8881f41fe5b0 by task syz-executor.0/2806
CPU: 0 PID: 2806 Comm: syz-executor.0 Not tainted 5.0.0-rc7+ #45
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1ubuntu1 04/01/2014
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0xfa/0x1ce lib/dump_stack.c:113
print_address_description+0x65/0x270 mm/kasan/report.c:187
kasan_report+0x149/0x18d mm/kasan/report.c:317
remove_proc_entry+0xe8/0x420 fs/proc/generic.c:667
atalk_proc_exit+0x18/0x820 [appletalk]
atalk_exit+0xf/0x5a [appletalk]
__do_sys_delete_module kernel/module.c:1018 [inline]
__se_sys_delete_module kernel/module.c:961 [inline]
__x64_sys_delete_module+0x3dc/0x5e0 kernel/module.c:961
do_syscall_64+0x147/0x600 arch/x86/entry/common.c:290
entry_SYSCALL_64_after_hwframe+0x49/0xbe
RIP: 0033:0x462e99
Code: f7 d8 64 89 02 b8 ff ff ff ff c3 66 0f 1f 44 00 00 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 c7 c1 bc ff ff ff f7 d8 64 89 01 48
RSP: 002b:00007fb2de6b9c58 EFLAGS: 00000246 ORIG_RAX: 00000000000000b0
RAX: ffffffffffffffda RBX: 000000000073bf00 RCX: 0000000000462e99
RDX: 0000000000000000 RSI: 0000000000000000 RDI: 00000000200001c0
RBP: 0000000000000002 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000246 R12: 00007fb2de6ba6bc
R13: 00000000004bccaa R14: 00000000006f6bc8 R15: 00000000ffffffff
Allocated by task 2806:
set_track mm/kasan/common.c:85 [inline]
__kasan_kmalloc.constprop.3+0xa0/0xd0 mm/kasan/common.c:496
slab_post_alloc_hook mm/slab.h:444 [inline]
slab_alloc_node mm/slub.c:2739 [inline]
slab_alloc mm/slub.c:2747 [inline]
kmem_cache_alloc+0xcf/0x250 mm/slub.c:2752
kmem_cache_zalloc include/linux/slab.h:730 [inline]
__proc_create+0x30f/0xa20 fs/proc/generic.c:408
proc_mkdir_data+0x47/0x190 fs/proc/generic.c:469
0xffffffffc10c01bb
0xffffffffc10c0166
do_one_initcall+0xfa/0x5ca init/main.c:887
do_init_module+0x204/0x5f6 kernel/module.c:3460
load_module+0x66b2/0x8570 kernel/module.c:3808
__do_sys_finit_module+0x238/0x2a0 kernel/module.c:3902
Freed by task 2806:
__kasan_slab_free+0x130/0x180 mm/kasan/common.c:458
slab_free_hook mm/slub.c:1409 [inline]
slab_free_freelist_hook mm/slub.c:1436 [inline]
slab_free mm/slub.c:2986 [inline]
kmem_cache_free+0xa6/0x2a0 mm/slub.c:3002
pde_put+0x6e/0x80 fs/proc/generic.c:647
remove_proc_entry+0x1d3/0x420 fs/proc/generic.c:684
0xffffffffc10c031c
0xffffffffc10c0166
The buggy address belongs to the object at ffff8881f41fe500
which belongs to the cache proc_dir_entry of size 256
The buggy address is located 176 bytes inside of
256-byte region [ffff8881f41fe500, ffff8881f41fe600)
The buggy address belongs to the page:
page:ffffea0007d07f80 count:1 mapcount:0 mapping:ffff8881f6e69a00 index:0x0
flags: 0x2fffc0000000200(slab)
raw: 02fffc0000000200 dead000000000100 dead000000000200 ffff8881f6e69a00
raw: 0000000000000000 00000000800c000c 00000001ffffffff 0000000000000000
page dumped because: kasan: bad access detected
Memory state around the buggy address:
ffff8881f41fe480: fb fb fb fb fb fb fb fb fc fc fc fc fc fc fc fc
ffff8881f41fe500: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
>ffff8881f41fe580: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff8881f41fe600: fc fc fc fc fc fc fc fc fb fb fb fb fb fb fb fb
ffff8881f41fe680: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
It should check the return value of atalk_proc_init fails,
otherwise atalk_exit will trgger use-after-free in pde_subdir_find
while unload the module.This patch fix error cleanup path of atalk_init
Use remove_proc_subtree to remove the whole subtree
on cleanup.Also do some cleanup.
The poll() changes were not well thought out, and completely
unexplained. They also caused a huge performance regression, because
"->poll()" was no longer a trivial file operation that just called down
to the underlying file operations, but instead did at least two indirect
calls.
Indirect calls are sadly slow now with the Spectre mitigation, but the
performance problem could at least be largely mitigated by changing the
"->get_poll_head()" operation to just have a per-file-descriptor pointer
to the poll head instead. That gets rid of one of the new indirections.
But that doesn't fix the new complexity that is completely unwarranted
for the regular case. The (undocumented) reason for the poll() changes
was some alleged AIO poll race fixing, but we don't make the common case
slower and more complex for some uncommon special case, so this all
really needs way more explanations and most likely a fundamental
redesign.
[ This revert is a revert of about 30 different commits, not reverted
individually because that would just be unnecessarily messy - Linus ]
Pull aio updates from Al Viro:
"Majority of AIO stuff this cycle. aio-fsync and aio-poll, mostly.
The only thing I'm holding back for a day or so is Adam's aio ioprio -
his last-minute fixup is trivial (missing stub in !CONFIG_BLOCK case),
but let it sit in -next for decency sake..."
* 'work.aio-1' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits)
aio: sanitize the limit checking in io_submit(2)
aio: fold do_io_submit() into callers
aio: shift copyin of iocb into io_submit_one()
aio_read_events_ring(): make a bit more readable
aio: all callers of aio_{read,write,fsync,poll} treat 0 and -EIOCBQUEUED the same way
aio: take list removal to (some) callers of aio_complete()
aio: add missing break for the IOCB_CMD_FDSYNC case
random: convert to ->poll_mask
timerfd: convert to ->poll_mask
eventfd: switch to ->poll_mask
pipe: convert to ->poll_mask
crypto: af_alg: convert to ->poll_mask
net/rxrpc: convert to ->poll_mask
net/iucv: convert to ->poll_mask
net/phonet: convert to ->poll_mask
net/nfc: convert to ->poll_mask
net/caif: convert to ->poll_mask
net/bluetooth: convert to ->poll_mask
net/sctp: convert to ->poll_mask
net/tipc: convert to ->poll_mask
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Variant of proc_create_data that directly take a struct seq_operations
argument + a private state size and drastically reduces the boilerplate
code in the callers.
All trivial callers converted over.
Variants of proc_create{,_data} that directly take a struct seq_operations
argument and drastically reduces the boilerplate code in the callers.
Prefer the direct use of octal for permissions.
Done with checkpatch -f --types=SYMBOLIC_PERMS --fix-inplace
and some typing.
Miscellanea:
o Whitespace neatening around these conversions.
Changes since v1:
Added changes in these files:
drivers/infiniband/hw/usnic/usnic_transport.c
drivers/staging/lustre/lnet/lnet/lib-socket.c
drivers/target/iscsi/iscsi_target_login.c
drivers/vhost/net.c
fs/dlm/lowcomms.c
fs/ocfs2/cluster/tcp.c
security/tomoyo/network.c
Before:
All these functions either return a negative error indicator,
or store length of sockaddr into "int *socklen" parameter
and return zero on success.
"int *socklen" parameter is awkward. For example, if caller does not
care, it still needs to provide on-stack storage for the value
it does not need.
None of the many FOO_getname() functions of various protocols
ever used old value of *socklen. They always just overwrite it.
This change drops this parameter, and makes all these functions, on success,
return length of sockaddr. It's always >= 0 and can be differentiated
from an error.
Tests in callers are changed from "if (err)" to "if (err < 0)", where needed.
rpc_sockname() lost "int buflen" parameter, since its only use was
to be passed to kernel_getsockname() as &buflen and subsequently
not used in any way.
Userspace API is not changed.
30108430 2633624 873672 33615726 200ef6e vmlinux.before.o
30108109 2633612 873672 33615393 200ee21 vmlinux.o
Signed-off-by: Denys Vlasenko <dvlasenk@redhat.com>
CC: David S. Miller <davem@davemloft.net>
CC: linux-kernel@vger.kernel.org
CC: netdev@vger.kernel.org
CC: linux-bluetooth@vger.kernel.org
CC: linux-decnet-user@lists.sourceforge.net
CC: linux-wireless@vger.kernel.org
CC: linux-rdma@vger.kernel.org
CC: linux-sctp@vger.kernel.org
CC: linux-nfs@vger.kernel.org
CC: linux-x25@vger.kernel.org
/proc has been ignoring struct file_operations::owner field for 10 years.
Specifically, it started with commit 786d7e1612f0b0adb6046f19b906609e4fe8b1ba
("Fix rmmod/read/write races in /proc entries"). Notice the chunk where
inode->i_fop is initialized with proxy struct file_operations for
regular files:
- if (de->proc_fops)
- inode->i_fop = de->proc_fops;
+ if (de->proc_fops) {
+ if (S_ISREG(inode->i_mode))
+ inode->i_fop = &proc_reg_file_ops;
+ else
+ inode->i_fop = de->proc_fops;
VFS stopped pinning module at this point.
This converts all remaining cases of the old setup_timer() API into using
timer_setup(), where the callback argument is the structure already
holding the struct timer_list. These should have no behavioral changes,
since they just change which pointer is passed into the callback with
the same available pointers after conversion. It handles the following
examples, in addition to some other variations.
Casting from unsigned long:
void my_callback(unsigned long data)
struct something *ptr = (struct something *)data;
setup_timer(&ptr->my_timer, my_callback, ptr);
and forced object casts:
void my_callback(struct something *ptr)
setup_timer(&ptr->my_timer, my_callback, (unsigned long)ptr);
become:
void my_callback(struct timer_list *t)
struct something *ptr = from_timer(ptr, t, my_timer);
timer_setup(&ptr->my_timer, my_callback, 0);
Direct function assignments:
ptr->my_timer.function = my_callback;
have a temporary cast added, along with converting the args:
ptr->my_timer.function = (TIMER_FUNC_TYPE)my_callback;
And finally, callbacks without a data assignment:
setup_timer(&ptr->my_timer, my_callback, 0);
have their argument renamed to verify they're unused during conversion:
void my_callback(struct timer_list *unused)
The conversion is done with the following Coccinelle script:
spatch --very-quiet --all-includes --include-headers \
-I ./arch/x86/include -I ./arch/x86/include/generated \
-I ./include -I ./arch/x86/include/uapi \
-I ./arch/x86/include/generated/uapi -I ./include/uapi \
-I ./include/generated/uapi --include ./include/linux/kconfig.h \
--dir . \
--cocci-file ~/src/data/timer_setup.cocci
@fix_address_of@
expression e;
setup_timer(
-&(e)
+&e
// Update any raw setup_timer() usages that have a NULL callback, but
// would otherwise match change_timer_function_usage, since the latter
// will update all function assignments done in the face of a NULL
// function initialization in setup_timer().
@change_timer_function_usage_NULL@
expression _E;
identifier _timer;
type _cast_data;
-setup_timer(&_E->_timer, NULL, _E);
+timer_setup(&_E->_timer, NULL, 0);
-setup_timer(&_E->_timer, NULL, (_cast_data)_E);
-setup_timer(&_E._timer, NULL, &_E);
+timer_setup(&_E._timer, NULL, 0);
-setup_timer(&_E._timer, NULL, (_cast_data)&_E);
@change_timer_function_usage@
expression _E;
identifier _timer;
struct timer_list _stl;
identifier _callback;
type _cast_func, _cast_data;
-setup_timer(&_E->_timer, _callback, _E);
+timer_setup(&_E->_timer, _callback, 0);
-setup_timer(&_E->_timer, &_callback, _E);
-setup_timer(&_E->_timer, _callback, (_cast_data)_E);
-setup_timer(&_E->_timer, &_callback, (_cast_data)_E);
-setup_timer(&_E->_timer, (_cast_func)_callback, _E);
-setup_timer(&_E->_timer, (_cast_func)&_callback, _E);
-setup_timer(&_E->_timer, (_cast_func)_callback, (_cast_data)_E);
-setup_timer(&_E->_timer, (_cast_func)&_callback, (_cast_data)_E);
-setup_timer(&_E._timer, _callback, (_cast_data)_E);
+timer_setup(&_E._timer, _callback, 0);
-setup_timer(&_E._timer, _callback, (_cast_data)&_E);
-setup_timer(&_E._timer, &_callback, (_cast_data)_E);
-setup_timer(&_E._timer, &_callback, (_cast_data)&_E);
-setup_timer(&_E._timer, (_cast_func)_callback, (_cast_data)_E);
-setup_timer(&_E._timer, (_cast_func)_callback, (_cast_data)&_E);
-setup_timer(&_E._timer, (_cast_func)&_callback, (_cast_data)_E);
-setup_timer(&_E._timer, (_cast_func)&_callback, (_cast_data)&_E);
_E->_timer@_stl.function = _callback;
_E->_timer@_stl.function = &_callback;
_E->_timer@_stl.function = (_cast_func)_callback;
_E->_timer@_stl.function = (_cast_func)&_callback;
_E._timer@_stl.function = _callback;
_E._timer@_stl.function = &_callback;
_E._timer@_stl.function = (_cast_func)_callback;
_E._timer@_stl.function = (_cast_func)&_callback;
// callback(unsigned long arg)
@change_callback_handle_cast
depends on change_timer_function_usage@
identifier change_timer_function_usage._callback;
identifier change_timer_function_usage._timer;
type _origtype;
identifier _origarg;
type _handletype;
identifier _handle;
void _callback(
-_origtype _origarg
+struct timer_list *t
... when != _origarg
_handletype *_handle =
-(_handletype *)_origarg;
+from_timer(_handle, t, _timer);
-(void *)_origarg;
_handletype *_handle;
... when != _handle
_handle =
... when != _handle
_handle =
-(void *)_origarg;
// callback(unsigned long arg) without existing variable
@change_callback_handle_cast_no_arg
depends on change_timer_function_usage &&
!change_callback_handle_cast@
type _origtype;
type _handletype;
void _callback(
-_origtype _origarg
+ _handletype *_origarg = from_timer(_origarg, t, _timer);
- (_handletype *)_origarg
+ _origarg
// Avoid already converted callbacks.
@match_callback_converted
!change_callback_handle_cast &&
!change_callback_handle_cast_no_arg@
identifier t;
void _callback(struct timer_list *t)
// callback(struct something *handle)
@change_callback_handle_arg
!match_callback_converted &&
type _handletype;
identifier _handle;
void _callback(
-_handletype *_handle
+ _handletype *_handle = from_timer(_handle, t, _timer);
// If change_callback_handle_arg ran on an empty function, remove
// the added handler.
@unchange_callback_handle_arg
change_callback_handle_arg@
type _handletype;
identifier _handle;
identifier t;
- _handletype *_handle = from_timer(_handle, t, _timer);
// We only want to refactor the setup_timer() data argument if we've found
// the matching callback. This undoes changes in change_timer_function_usage.
@unchange_timer_function_usage
!change_callback_handle_cast_no_arg &&
!change_callback_handle_arg@
expression change_timer_function_usage._E;
type change_timer_function_usage._cast_data;
-timer_setup(&_E->_timer, _callback, 0);
+setup_timer(&_E->_timer, _callback, (_cast_data)_E);
-timer_setup(&_E._timer, _callback, 0);
+setup_timer(&_E._timer, _callback, (_cast_data)&_E);
// If we fixed a callback from a .function assignment, fix the
// assignment cast now.
@change_timer_function_assignment
(change_callback_handle_cast ||
change_callback_handle_cast_no_arg ||
change_callback_handle_arg)@
type _cast_func;
typedef TIMER_FUNC_TYPE;
_E->_timer.function =
-_callback
+(TIMER_FUNC_TYPE)_callback
-&_callback
-(_cast_func)_callback;
-(_cast_func)&_callback
_E._timer.function =
-_callback
-&_callback;
// Sometimes timer functions are called directly. Replace matched args.
@change_timer_function_calls
expression _E;
type _cast_data;
_callback(
-(_cast_data)_E
+&_E->_timer
-(_cast_data)&_E
+&_E._timer
-_E
+&_E->_timer
// If a timer has been configured without a data argument, it can be
// converted without regard to the callback argument, since it is unused.
@match_timer_function_unused_data@
expression _E;
identifier _timer;
-setup_timer(&_E->_timer, _callback, 0);
-setup_timer(&_E->_timer, _callback, 0L);
-setup_timer(&_E->_timer, _callback, 0UL);
-setup_timer(&_E._timer, _callback, 0);
-setup_timer(&_E._timer, _callback, 0L);
-setup_timer(&_E._timer, _callback, 0UL);
-setup_timer(&_timer, _callback, 0);
+timer_setup(&_timer, _callback, 0);
-setup_timer(&_timer, _callback, 0L);
-setup_timer(&_timer, _callback, 0UL);
-setup_timer(_timer, _callback, 0);
+timer_setup(_timer, _callback, 0);
-setup_timer(_timer, _callback, 0L);
-setup_timer(_timer, _callback, 0UL);
@change_callback_unused_data
depends on match_timer_function_unused_data@
identifier match_timer_function_unused_data._callback;
type _origtype;
void _callback(
-_origtype _origarg
+struct timer_list *unused
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
It seems like a historic accident that these return unsigned char *,
and in many places that means casts are required, more often than not.
Make these functions return void * and remove all the casts across
the tree, adding a (u8 *) cast only where the unsigned char pointer
was used directly, all done with the following spatch:
expression SKB, LEN;
typedef u8;
identifier fn = { skb_push, __skb_push, skb_push_rcsum };
- *(fn(SKB, LEN))
+ *(u8 *)fn(SKB, LEN)
expression E, SKB, LEN;
type T;
- E = ((T *)(fn(SKB, LEN)))
+ E = fn(SKB, LEN)
- fn(SKB, LEN)[0]
Note that the last part there converts from push(...)[0] to the
more idiomatic *(u8 *)push(...).
Make these functions (skb_put, __skb_put and pskb_put) return void *
and remove all the casts across the tree, adding a (u8 *) cast only
where the unsigned char pointer was used directly, all done with the
following spatch:
typedef u8;
identifier fn = { skb_put, __skb_put };
- *(fn(SKB, LEN))
type T;
+ E = fn(SKB, LEN)
which actually doesn't cover pskb_put since there are only three
users overall.
A handful of stragglers were converted manually, notably a macro in
drivers/isdn/i4l/isdn_bsdcomp.c and, oddly enough, one of the many
instances in net/bluetooth/hci_sock.c. In the former file, I also
had to fix one whitespace problem spatch introduced.
Now that %z is standartised in C99 there is no reason to support %Z.
Unlike %L it doesn't even make format strings smaller.
Use BUILD_BUG_ON in a couple ATM drivers.
In case anyone didn't notice lib/vsprintf.o is about half of SLUB which
is in my opinion is quite an achievement. Hopefully this patch inspires
someone else to trim vsprintf.c more.
Link: http://lkml.kernel.org/r/20170103230126.GA30170@avx2
Cc: Andy Shevchenko <andy.shevchenko@gmail.com>
Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk>
The IS_ENABLED() macro checks if a Kconfig symbol has been enabled either
built-in or as a module, use that macro instead of open coding the same.
Using the macro makes the code more readable by helping abstract away some
of the Kconfig built-in and module enable details.
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
The atalk_sendmsg() function might return wrong value ENETUNREACH
instead of -ENETUNREACH.
Signed-off-by: Anton Protopopov <a.s.protopopov@gmail.com>
In preparation for changing how struct net is refcounted
on kernel sockets pass the knowledge that we are creating
a kernel socket from sock_create_kern through to sk_alloc.
Use the built-in function instead of memset.
After TIPC doesn't depend on iocb argument in its internal
implementations of sendmsg() and recvmsg() hooks defined in proto
structure, no any user is using iocb argument in them at all now.
Then we can drop the redundant iocb argument completely from kinds of
implementations of both sendmsg() and recvmsg() in the entire
networking stack.
Suggested-by: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Ying Xue <ying.xue@windriver.com>
This encapsulates all of the skb_copy_datagram_iovec() callers
with call argument signature "skb, offset, msghdr->msg_iov, length".
When we move to iov_iters in the networking, the iov_iter object will
sit in the msghdr.
Having a helper like this means there will be less places to touch
during that transformation.
Based upon descriptions and patch from Al Viro.
Extend alloc_netdev{,_mq{,s}}() to take name_assign_type as argument, and convert
all users to pass NET_NAME_UNKNOWN.
Coccinelle patch:
expression sizeof_priv, name, setup, txqs, rxqs, count;
-alloc_netdev_mqs(sizeof_priv, name, setup, txqs, rxqs)
+alloc_netdev_mqs(sizeof_priv, name, NET_NAME_UNKNOWN, setup, txqs, rxqs)
-alloc_netdev_mq(sizeof_priv, name, setup, count)
+alloc_netdev_mq(sizeof_priv, name, NET_NAME_UNKNOWN, setup, count)
-alloc_netdev(sizeof_priv, name, setup)
+alloc_netdev(sizeof_priv, name, NET_NAME_UNKNOWN, setup)
v9: move comments here from the wrong commit
Signed-off-by: Tom Gundersen <teg@jklm.no>
Reviewed-by: David Herrmann <dh.herrmann@gmail.com>
Setting just skb->sk without taking its reference and setting a
destructor is invalid. However, in the places where this was done, skb
is used in a way not requiring skb->sk setting. So dropping the setting
of skb->sk.
Thanks to Eric Dumazet <eric.dumazet@gmail.com> for correct solution.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=79441
Reported-by: Ed Martin <edman007@edman007.com>
Signed-off-by: Andrey Utkin <andrey.krieger.utkin@gmail.com>
This warning is introduced by commit 7b30600cc6 ("appletalk:
fix checkpatch error with indent"), So fix it.
Signed-off-by: Wang Weidong <wangweidong1@huawei.com>
Define separate fields in the sock structure for configuring disabling
checksums in both TX and RX-- sk_no_check_tx and sk_no_check_rx.
The SO_NO_CHECK socket option only affects sk_no_check_tx. Also,
removed UDP_CSUM_* defines since they are no longer necessary.
Signed-off-by: Tom Herbert <therbert@google.com>
checkpatch error: switch and case should be at the same indent.
fix checkpatch errors below:
ERROR: "foo* bar" should be "foo *bar"
ERROR: "foo * bar" should be "foo *bar"
fix checkpatch errors while the space is required or prohibited
net/appletalk/aarp.c: In function ‘__aarp_send_query’:
net/appletalk/aarp.c:137:2: error: implicit declaration of function ‘ether_addr_copy’ [-Werror=implicit-function-declaration]
net/atm/lec.c: In function ‘send_to_lecd’:
net/atm/lec.c:524:3: warning: passing argument 1 of ‘ether_addr_copy’ from incompatible pointer type [enabled by default]
In file included from net/atm/lec.c:17:0:
include/linux/etherdevice.h:227:20: note: expected ‘u8 *’ but argument is of type ‘unsigned char (*)[6]’
net/caif/caif_usb.c: In function ‘cfusbl_create’:
net/caif/caif_usb.c:108:2: error: implicit declaration of function ‘ether_addr_copy’ [-Werror=implicit-function-declaration]
Use ether_addr_copy instead of memcpy(a, b, ETH_ALEN) to
save some cycles on arm and powerpc.
Convert struct aarp_entry.hwaddr[6] to hwaddr[ETH_ALEN].
This is a follow-up patch to f3d3342602f8bc ("net: rework recvmsg
handler msg_name and msg_namelen logic").
DECLARE_SOCKADDR validates that the structure we use for writing the
name information to is not larger than the buffer which is reserved
for msg->msg_name (which is 128 bytes). Also use DECLARE_SOCKADDR
consistently in sendmsg code paths.
Signed-off-by: Steffen Hurrle <steffen@hurrle.net>
Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must
set msg_namelen to the proper size <= sizeof(struct sockaddr_storage)
to return msg_name to the user.
This prevents numerous uninitialized memory leaks we had in the
recvmsg handlers and makes it harder for new code to accidentally leak
uninitialized memory.
Optimize for the case recvfrom is called with NULL as address. We don't
need to copy the address at all, so set it to NULL before invoking the
recvmsg handler. We can do so, because all the recvmsg handlers must
cope with the case a plain read() is called on them. read() also sets
msg_name to NULL.
Also document these changes in include/linux/net.h as suggested by David
Miller.
Changes since RFC:
Set msg->msg_name = NULL if user specified a NULL in msg_name but had a
non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't
affect sendto as it would bail out earlier while trying to copy-in the
address. It also more naturally reflects the logic by the callers of
verify_iovec.
With this change in place I could remove "
if (!uaddr || msg_sys->msg_namelen == 0)
This change does not alter the user visible error logic as we ignore
msg_namelen as long as msg_name is NULL.
Also remove two unnecessary curly brackets in ___sys_recvmsg and change
comments to netdev style.
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
UIDs are printed in the proc_fs as signed int, whereas
they are unsigned int.
Signed-off-by: Francesco Fusco <ffusco@redhat.com>
So far, only net_device * could be passed along with netdevice notifier
event. This patch provides a possibility to pass custom structure
able to provide info that event listener needs to know.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
v2->v3: fix typo on simeth
shortened dev_getter
shortened notifier_info struct name
v1->v2: fix notifier_call parameter in call_netdevice_notifier()
There is a one byte hole between ->sat_port and ->sat_addr.
I'm not sure why, but the hlist for each entry iterators were conceived
list_for_each_entry(pos, head, member)
The hlist ones were greedy and wanted an extra parameter:
hlist_for_each_entry(tpos, pos, head, member)
Why did they need an extra pos parameter? I'm not quite sure. Not only
they don't really need it, it also prevents the iterator from looking
exactly like the list iterator, which is unfortunate.
Besides the semantic patch, there was some manual work required:
- Fix up the actual hlist iterators in linux/list.h
- Fix up the declaration of other iterators based on the hlist ones.
- A very small amount of places were using the 'node' parameter, this
was modified to use 'obj->member' instead.
- Coccinelle didn't handle the hlist_for_each_entry_safe iterator
properly, so those had to be fixed up manually.
The semantic patch which is mostly the work of Peter Senna Tschudin is here:
iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host;
type T;
expression a,c,d,e;
identifier b;
statement S;
-T b;
<+... when != b
hlist_for_each_entry(a,
- b,
c, d) S
hlist_for_each_entry_continue(a,
- b,
c) S
hlist_for_each_entry_from(a,
- b,
c) S
hlist_for_each_entry_rcu(a,
- b,
c, d) S
hlist_for_each_entry_rcu_bh(a,
- b,
c, d) S
hlist_for_each_entry_continue_rcu_bh(a,
- b,
c) S
for_each_busy_worker(a, c,
- b,
d) S
ax25_uid_for_each(a,
- b,
c) S
ax25_for_each(a,
- b,
c) S
inet_bind_bucket_for_each(a,
- b,
c) S
sctp_for_each_hentry(a,
- b,
c) S
sk_for_each(a,
- b,
c) S
sk_for_each_rcu(a,
- b,
c) S
sk_for_each_from
-(a, b)
+(a)
S
+ sk_for_each_from(a) S
sk_for_each_safe(a,
- b,
c, d) S
sk_for_each_bound(a,
- b,
c) S
hlist_for_each_entry_safe(a,
- b,
c, d, e) S
hlist_for_each_entry_continue_rcu(a,
- b,
c) S
nr_neigh_for_each(a,
- b,
c) S
nr_neigh_for_each_safe(a,
- b,
c, d) S
nr_node_for_each(a,
- b,
c) S
nr_node_for_each_safe(a,
- b,
c, d) S
- for_each_gfn_sp(a, c, d, b) S
+ for_each_gfn_sp(a, c, d) S
- for_each_gfn_indirect_valid_sp(a, c, d, b) S
+ for_each_gfn_indirect_valid_sp(a, c, d) S
for_each_host(a,
- b,
c) S
for_each_host_safe(a,
- b,
c, d) S
for_each_mesh_entry(a,
- b,
c, d) S
[akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c]
[akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c]
[akpm@linux-foundation.org: checkpatch fixes]
[akpm@linux-foundation.org: fix warnings]
[akpm@linux-foudnation.org: redo intrusive kvm changes]
Tested-by: Peter Senna Tschudin <peter.senna@gmail.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Gleb Natapov <gleb@redhat.com>
Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Cc: Sridhar Samudrala <sri@us.ibm.com>
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
