path: root/net/Kconfig
2015-05-14net: add CONFIG_NET_INGRESS to enable ingress filteringPablo Neira
This new config switch enables the ingress filtering infrastructure that is controlled through the ingress_needed static key. This prepares the introduction of the Netfilter ingress hook that resides under this unique static key. Note that CONFIG_SCH_INGRESS automatically selects this, that should be no problem since this also depends on CONFIG_NET_CLS_ACT. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Acked-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-07kconfig: use bool instead of boolean for type definition attributesChristoph Jaeger
Support for keyword 'boolean' will be dropped later on. No functional change. Reference: http://lkml.kernel.org/r/cover.1418003065.git.cj@linux.com Signed-off-by: Christoph Jaeger <cj@linux.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-12-02net: introduce generic switch devices supportJiri Pirko
The goal of this is to provide a possibility to support various switch chips. Drivers should implement relevant ndos to do so. Now there is only one ndo defined: - for getting physical switch id is in place. Note that user can use random port netdevice to access the switch. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Reviewed-by: Thomas Graf <tgraf@suug.ch> Acked-by: Andy Gospodarek <gospo@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-27bpf: split eBPF out of NETAlexei Starovoitov
introduce two configs: - hidden CONFIG_BPF to select eBPF interpreter that classic socket filters depend on - visible CONFIG_BPF_SYSCALL (default off) that tracing and sockets can use that solves several problems: - tracing and others that wish to use eBPF don't need to depend on NET. They can use BPF_SYSCALL to allow loading from userspace or select BPF to use it directly from kernel in NET-less configs. - in 3.18 programs cannot be attached to events yet, so don't force it on - when the rest of eBPF infra is there in 3.19+, it's still useful to switch it off to minimize kernel size bloat-o-meter on x64 shows: add/remove: 0/60 grow/shrink: 0/2 up/down: 0/-15601 (-15601) tested with many different config combinations. Hopefully didn't miss anything. Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Acked-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-10net: bpf: fix bpf syscall dependence on anon_inodesAlexei Starovoitov
minimal configurations where EPOLL, PERF_EVENTS, etc are disabled, but NET is enabled, are failing to build with link error: kernel/built-in.o: In function `bpf_prog_load': syscall.c:(.text+0x3b728): undefined reference to `anon_inode_getfd' fix it by selecting ANON_INODES when NET is enabled Reported-by: Michal Sojka <sojkam1@fel.cvut.cz> Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-30netfilter: bridge: build br_nf_core only if requiredFlorian Westphal
Eric reports build failure with CONFIG_BRIDGE_NETFILTER=n We insist to build br_nf_core.o unconditionally, but we must only do so if br_netfilter was enabled, else it fails to build due to functions being defined to empty stubs (and some structure members being defined out). Also, BRIDGE_NETFILTER=y|m makes no sense when BRIDGE=n. Fixes: 34666d467 (netfilter: bridge: move br_netfilter out of the core) Reported-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-26netfilter: bridge: move br_netfilter out of the corePablo Neira Ayuso
Jesper reported that br_netfilter always registers the hooks since this is part of the bridge core. This harms performance for people that don't need this. This patch modularizes br_netfilter so it can be rmmod'ed, thus, the hooks can be unregistered. I think the bridge netfilter should have been a separated module since the beginning, Patrick agreed on that. Note that this is breaking compatibility for users that expect that bridge netfilter is going to be available after explicitly 'modprobe bridge' or via automatic load through brctl. However, the damage can be easily undone by modprobing br_netfilter. The bridge core also spots a message to provide a clue to people that didn't notice that this has been deprecated. On top of that, the plan is that nftables will not rely on this software layer, but integrate the connection tracking into the bridge layer to enable stateful filtering and NAT, which is was bridge netfilter users seem to require. This patch still keeps the fake_dst_ops in the bridge core, since this is required by when the bridge port is initialized. So we can safely modprobe/rmmod br_netfilter anytime. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Acked-by: Florian Westphal <fw@strlen.de>
2014-07-126lowpan: introduce new net/6lowpan directoryAlexander Aring
This patch moves generic code which is used by bluetooth and ieee802154 6lowpan to a new net/6lowpan directory. This directory contains generic 6LoWPAN code which is shared between bluetooth and ieee802154 MAC-Layer. This is the IPHC - "IPv6 Header Compression" format at the moment. Which is described by RFC 6282 [0]. The BLTE 6LoWPAN draft describes that the IPHC is the same format like IEEE 802.15.4, see [1]. Futuremore we can put more code into this directory which is shared between BLTE and IEEE 802.15.4 6LoWPAN like RFC 6775 or the routing protocol RPL RFC 6550. To avoid naming conflicts I renamed 6lowpan-y to ieee802154_6lowpan-y in net/ieee802154/Makefile. [0] http://tools.ietf.org/html/rfc6282 [1] http://tools.ietf.org/html/draft-ietf-6lowpan-btle-12#section-3.2 [2] http://tools.ietf.org/html/rfc6775 [3] http://tools.ietf.org/html/rfc6550 Signed-off-by: Alexander Aring <alex.aring@gmail.com> Acked-by: Jukka Rissanen <jukka.rissanen@linux.intel.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2014-04-03Merge branch 'for-3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup updates from Tejun Heo: "A lot updates for cgroup: - The biggest one is cgroup's conversion to kernfs. cgroup took after the long abandoned vfs-entangled sysfs implementation and made it even more convoluted over time. cgroup's internal objects were fused with vfs objects which also brought in vfs locking and object lifetime rules. Naturally, there are places where vfs rules don't fit and nasty hacks, such as credential switching or lock dance interleaving inode mutex and cgroup_mutex with object serial number comparison thrown in to decide whether the operation is actually necessary, needed to be employed. After conversion to kernfs, internal object lifetime and locking rules are mostly isolated from vfs interactions allowing shedding of several nasty hacks and overall simplification. This will also allow implmentation of operations which may affect multiple cgroups which weren't possible before as it would have required nesting i_mutexes. - Various simplifications including dropping of module support, easier cgroup name/path handling, simplified cgroup file type handling and task_cg_lists optimization. - Prepatory changes for the planned unified hierarchy, which is still a patchset away from being actually operational. The dummy hierarchy is updated to serve as the default unified hierarchy. Controllers which aren't claimed by other hierarchies are associated with it, which BTW was what the dummy hierarchy was for anyway. - Various fixes from Li and others. This pull request includes some patches to add missing slab.h to various subsystems. This was triggered xattr.h include removal from cgroup.h. cgroup.h indirectly got included a lot of files which brought in xattr.h which brought in slab.h. There are several merge commits - one to pull in kernfs updates necessary for converting cgroup (already in upstream through driver-core), others for interfering changes in the fixes branch" * 'for-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (74 commits) cgroup: remove useless argument from cgroup_exit() cgroup: fix spurious lockdep warning in cgroup_exit() cgroup: Use RCU_INIT_POINTER(x, NULL) in cgroup.c cgroup: break kernfs active_ref protection in cgroup directory operations cgroup: fix cgroup_taskset walking order cgroup: implement CFTYPE_ONLY_ON_DFL cgroup: make cgrp_dfl_root mountable cgroup: drop const from @buffer of cftype->write_string() cgroup: rename cgroup_dummy_root and related names cgroup: move ->subsys_mask from cgroupfs_root to cgroup cgroup: treat cgroup_dummy_root as an equivalent hierarchy during rebinding cgroup: remove NULL checks from [pr_cont_]cgroup_{name|path}() cgroup: use cgroup_setup_root() to initialize cgroup_dummy_root cgroup: reorganize cgroup bootstrapping cgroup: relocate setting of CGRP_DEAD cpuset: use rcu_read_lock() to protect task_cs() cgroup_freezer: document freezer_fork() subtleties cgroup: update cgroup_transfer_tasks() to either succeed or fail cgroup: drop task_lock() protection around task->cgroups cgroup: update how a newly forked task gets associated with css_set ...
2014-04-01net: ptp: move PTP classifier in its own fileDaniel Borkmann
This commit fixes a build error reported by Fengguang, that is triggered when CONFIG_NETWORK_PHY_TIMESTAMPING is not set: ERROR: "ptp_classify_raw" [drivers/net/ethernet/oki-semi/pch_gbe/pch_gbe.ko] undefined! The fix is to introduce its own file for the PTP BPF classifier, so that PTP_1588_CLOCK and/or NETWORK_PHY_TIMESTAMPING can select it independently from each other. IXP4xx driver on ARM needs to select it as well since it does not seem to select PTP_1588_CLOCK or similar that would pull it in automatically. This also allows for hiding all of the internals of the BPF PTP program inside that file, and only exporting relevant API bits to drivers. This patch also adds a kdoc documentation of ptp_classify_raw() API to make it clear that it can return PTP_CLASS_* defines. Also, the BPF program has been translated into bpf_asm code, so that it can be more easily read and altered (extensively documented in [1]). In the kernel tree under tools/net/ we have bpf_asm and bpf_dbg tools, so the commented program can simply be translated via `./bpf_asm -c prog` where prog is a file that contains the commented code. This makes it easily readable/verifiable and when there's a need to change something, jump offsets etc do not need to be replaced manually which can be very error prone. Instead, a newly translated version via bpf_asm can simply replace the old code. I have checked opcode diffs before/after and it's the very same filter. [1] Documentation/networking/filter.txt Fixes: 164d8c666521 ("net: ptp: do not reimplement PTP/BPF classifier") Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Cc: Richard Cochran <richardcochran@gmail.com> Cc: Jiri Benc <jbenc@redhat.com> Acked-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-08cgroup: make CONFIG_CGROUP_NET_PRIO bool and drop unnecessary ↵Tejun Heo
init_netclassid_cgroup() net_prio is the only cgroup which is allowed to be built as a module. The savings from allowing one controller to be built as a module are tiny especially given that cgroup module support itself adds quite a bit of complexity. Given that none of other controllers has much chance of being made a module and that we're unlikely to add new modular controllers, the added complexity is simply not justifiable. As a first step to drop cgroup module support, this patch changes the config option to bool from tristate and drops module related code from it. Also, while an earlier commit fe1217c4f3f7 ("net: net_cls: move cgroupfs classid handling into core") dropped module support from net_cls cgroup, it retained a call to cgroup_load_subsys(), which is noop for built-in controllers. Drop it along with init_netclassid_cgroup(). v2: Removed modular version of task_netprioidx() in include/net/netprio_cgroup.h as suggested by Li Zefan. v3: Rebased on top of fe1217c4f3f7 ("net: net_cls: move cgroupfs classid handling into core"). net_cls cgroup part is mostly dropped except for removal of init_netclassid_cgroup(). Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: "David S. Miller" <davem@davemloft.net> Acked-by: Li Zefan <lizefan@huawei.com> Cc: Thomas Graf <tgraf@suug.ch>
2014-01-03net: netprio: rename config to be more consistent with cgroup configsDaniel Borkmann
While we're at it and introduced CGROUP_NET_CLASSID, lets also make NETPRIO_CGROUP more consistent with the rest of cgroups and rename it into CONFIG_CGROUP_NET_PRIO so that for networking, we now have CONFIG_CGROUP_NET_{PRIO,CLASSID}. This not only makes the CONFIG option consistent among networking cgroups, but also among cgroups CONFIG conventions in general as the vast majority has a prefix of CONFIG_CGROUP_<SUBSYS>. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Cc: Zefan Li <lizefan@huawei.com> Cc: cgroups@vger.kernel.org Acked-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2014-01-03net: net_cls: move cgroupfs classid handling into coreDaniel Borkmann
Zefan Li requested [1] to perform the following cleanup/refactoring: - Split cgroupfs classid handling into net core to better express a possible more generic use. - Disable module support for cgroupfs bits as the majority of other cgroupfs subsystems do not have that, and seems to be not wished from cgroup side. Zefan probably might want to follow-up for netprio later on. - By this, code can be further reduced which previously took care of functionality built when compiled as module. cgroupfs bits are being placed under net/core/netclassid_cgroup.c, so that we are consistent with {netclassid,netprio}_cgroup naming that is under net/core/ as suggested by Zefan. No change in functionality, but only code refactoring that is being done here. [1] http://patchwork.ozlabs.org/patch/304825/ Suggested-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Cc: Zefan Li <lizefan@huawei.com> Cc: Thomas Graf <tgraf@suug.ch> Cc: cgroups@vger.kernel.org Acked-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2013-11-21kernel: remove CONFIG_USE_GENERIC_SMP_HELPERS cleanlyYuanhan Liu
Remove CONFIG_USE_GENERIC_SMP_HELPERS left by commit 0a06ff068f12 ("kernel: remove CONFIG_USE_GENERIC_SMP_HELPERS"). Signed-off-by: Yuanhan Liu <yuanhan.liu@linux.intel.com> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-03net/hsr: Add support for the High-availability Seamless Redundancy protocol ↵Arvid Brodin
(HSRv0) High-availability Seamless Redundancy ("HSR") provides instant failover redundancy for Ethernet networks. It requires a special network topology where all nodes are connected in a ring (each node having two physical network interfaces). It is suited for applications that demand high availability and very short reaction time. HSR acts on the Ethernet layer, using a registered Ethernet protocol type to send special HSR frames in both directions over the ring. The driver creates virtual network interfaces that can be used just like any ordinary Linux network interface, for IP/TCP/UDP traffic etc. All nodes in the network ring must be HSR capable. This code is a "best effort" to comply with the HSR standard as described in IEC 62439-3:2010 (HSRv0). Signed-off-by: Arvid Brodin <arvid.brodin@xdin.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-13Remove GENERIC_HARDIRQ config optionMartin Schwidefsky
After the last architecture switched to generic hard irqs the config options HAVE_GENERIC_HARDIRQS & GENERIC_HARDIRQS and the related code for !CONFIG_GENERIC_HARDIRQS can be removed. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-08-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Merge net into net-next to setup some infrastructure Eric Dumazet needs for usbnet changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-01net: rename CONFIG_NET_LL_RX_POLL to CONFIG_NET_RX_BUSY_POLLCong Wang
Eliezer renames several *ll_poll to *busy_poll, but forgets CONFIG_NET_LL_RX_POLL, so in case of confusion, rename it too. Cc: Eliezer Tamir <eliezer.tamir@linux.intel.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-30pktgen: Require CONFIG_INET due to use of IPv4 checksum functionThomas Graf
Unlike for IPv6, the IPv4 checksum functions are only available if CONFIG_INET is set. Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "This is a re-do of the net-next pull request for the current merge window. The only difference from the one I made the other day is that this has Eliezer's interface renames and the timeout handling changes made based upon your feedback, as well as a few bug fixes that have trickeled in. Highlights: 1) Low latency device polling, eliminating the cost of interrupt handling and context switches. Allows direct polling of a network device from socket operations, such as recvmsg() and poll(). Currently ixgbe, mlx4, and bnx2x support this feature. Full high level description, performance numbers, and design in commit 0a4db187a999 ("Merge branch 'll_poll'") From Eliezer Tamir. 2) With the routing cache removed, ip_check_mc_rcu() gets exercised more than ever before in the case where we have lots of multicast addresses. Use a hash table instead of a simple linked list, from Eric Dumazet. 3) Add driver for Atheros CQA98xx 802.11ac wireless devices, from Bartosz Markowski, Janusz Dziedzic, Kalle Valo, Marek Kwaczynski, Marek Puzyniak, Michal Kazior, and Sujith Manoharan. 4) Support reporting the TUN device persist flag to userspace, from Pavel Emelyanov. 5) Allow controlling network device VF link state using netlink, from Rony Efraim. 6) Support GRE tunneling in openvswitch, from Pravin B Shelar. 7) Adjust SOCK_MIN_RCVBUF and SOCK_MIN_SNDBUF for modern times, from Daniel Borkmann and Eric Dumazet. 8) Allow controlling of TCP quickack behavior on a per-route basis, from Cong Wang. 9) Several bug fixes and improvements to vxlan from Stephen Hemminger, Pravin B Shelar, and Mike Rapoport. In particular, support receiving on multiple UDP ports. 10) Major cleanups, particular in the area of debugging and cookie lifetime handline, to the SCTP protocol code. From Daniel Borkmann. 11) Allow packets to cross network namespaces when traversing tunnel devices. From Nicolas Dichtel. 12) Allow monitoring netlink traffic via AF_PACKET sockets, in a manner akin to how we monitor real network traffic via ptype_all. From Daniel Borkmann. 13) Several bug fixes and improvements for the new alx device driver, from Johannes Berg. 14) Fix scalability issues in the netem packet scheduler's time queue, by using an rbtree. From Eric Dumazet. 15) Several bug fixes in TCP loss recovery handling, from Yuchung Cheng. 16) Add support for GSO segmentation of MPLS packets, from Simon Horman. 17) Make network notifiers have a real data type for the opaque pointer that's passed into them. Use this to properly handle network device flag changes in arp_netdev_event(). From Jiri Pirko and Timo Teräs. 18) Convert several drivers over to module_pci_driver(), from Peter Huewe. 19) tcp_fixup_rcvbuf() can loop 500 times over loopback, just use a O(1) calculation instead. From Eric Dumazet. 20) Support setting of explicit tunnel peer addresses in ipv6, just like ipv4. From Nicolas Dichtel. 21) Protect x86 BPF JIT against spraying attacks, from Eric Dumazet. 22) Prevent a single high rate flow from overruning an individual cpu during RX packet processing via selective flow shedding. From Willem de Bruijn. 23) Don't use spinlocks in TCP md5 signing fast paths, from Eric Dumazet. 24) Don't just drop GSO packets which are above the TBF scheduler's burst limit, chop them up so they are in-bounds instead. Also from Eric Dumazet. 25) VLAN offloads are missed when configured on top of a bridge, fix from Vlad Yasevich. 26) Support IPV6 in ping sockets. From Lorenzo Colitti. 27) Receive flow steering targets should be updated at poll() time too, from David Majnemer. 28) Fix several corner case regressions in PMTU/redirect handling due to the routing cache removal, from Timo Teräs. 29) We have to be mindful of ipv4 mapped ipv6 sockets in upd_v6_push_pending_frames(). From Hannes Frederic Sowa. 30) Fix L2TP sequence number handling bugs, from James Chapman." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1214 commits) drivers/net: caif: fix wrong rtnl_is_locked() usage drivers/net: enic: release rtnl_lock on error-path vhost-net: fix use-after-free in vhost_net_flush net: mv643xx_eth: do not use port number as platform device id net: sctp: confirm route during forward progress virtio_net: fix race in RX VQ processing virtio: support unlocked queue poll net/cadence/macb: fix bug/typo in extracting gem_irq_read_clear bit Documentation: Fix references to defunct linux-net@vger.kernel.org net/fs: change busy poll time accounting net: rename low latency sockets functions to busy poll bridge: fix some kernel warning in multicast timer sfc: Fix memory leak when discarding scattered packets sit: fix tunnel update via netlink dt:net:stmmac: Add dt specific phy reset callback support. dt:net:stmmac: Add support to dwmac version 3.610 and 3.710 dt:net:stmmac: Allocate platform data only if its NULL. net:stmmac: fix memleak in the open method ipv6: rt6_check_neigh should successfully verify neigh if no NUD information are available net: ipv6: fix wrong ping_v6_sendmsg return value ...
2013-06-17net: remove NET_LL_RX_POLL config menueEliezer Tamir
Remove NET_LL_RX_POLL from the config menu. Change default to y. Busy polling still needs to be enabled at run time. Signed-off-by: Eliezer Tamir <eliezer.tamir@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-17net: convert low latency sockets to sched_clock()Eliezer Tamir
Use sched_clock() instead of get_cycles(). We can use sched_clock() because we don't care much about accuracy. Remove the dependency on X86_TSC Signed-off-by: Eliezer Tamir <eliezer.tamir@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-10net: add low latency socket pollEliezer Tamir
Adds an ndo_ll_poll method and the code that supports it. This method can be used by low latency applications to busy-poll Ethernet device queues directly from the socket code. sysctl_net_ll_poll controls how many microseconds to poll. Default is zero (disabled). Individual protocol support will be added by subsequent patches. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Eliezer Tamir <eliezer.tamir@linux.intel.com> Acked-by: Eric Dumazet <edumazet@google.com> Tested-by: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-05net: core: move mac_pton() to lib/net_utils.cAndy Shevchenko
Since we have at least one user of this function outside of CONFIG_NET scope, we have to provide this function independently. The proposed solution is to move it under lib/net_utils.c with corresponding configuration variable and select wherever it is needed. Signed-off-by: Andy Shevchenko <andy.shevchenko@gmail.com> Reported-by: Arnd Bergmann <arnd@arndb.de> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-27MPLS: Add limited GSO supportSimon Horman
In the case where a non-MPLS packet is received and an MPLS stack is added it may well be the case that the original skb is GSO but the NIC used for transmit does not support GSO of MPLS packets. The aim of this code is to provide GSO in software for MPLS packets whose skbs are GSO. SKB Usage: When an implementation adds an MPLS stack to a non-MPLS packet it should do the following to skb metadata: * Set skb->inner_protocol to the old non-MPLS ethertype of the packet. skb->inner_protocol is added by this patch. * Set skb->protocol to the new MPLS ethertype of the packet. * Set skb->network_header to correspond to the end of the L3 header, including the MPLS label stack. I have posted a patch, "[PATCH v3.29] datapath: Add basic MPLS support to kernel" which adds MPLS support to the kernel datapath of Open vSwtich. That patch sets the above requirements in datapath/actions.c:push_mpls() and was used to exercise this code. The datapath patch is against the Open vSwtich tree but it is intended that it be added to the Open vSwtich code present in the mainline Linux kernel at some point. Features: I believe that the approach that I have taken is at least partially consistent with the handling of other protocols. Jesse, I understand that you have some ideas here. I am more than happy to change my implementation. This patch adds dev->mpls_features which may be used by devices to advertise features supported for MPLS packets. A new NETIF_F_MPLS_GSO feature is added for devices which support hardware MPLS GSO offload. Currently no devices support this and MPLS GSO always falls back to software. Alternate Implementation: One possible alternate implementation is to teach netif_skb_features() and skb_network_protocol() about MPLS, in a similar way to their understanding of VLANs. I believe this would avoid the need for net/mpls/mpls_gso.c and in particular the calls to __skb_push() and __skb_push() in mpls_gso_segment(). I have decided on the implementation in this patch as it should not introduce any overhead in the case where mpls_gso is not compiled into the kernel or inserted as a module. MPLS GSO suggested by Jesse Gross. Based in part on "v4 GRE: Add TCP segmentation offload for GRE" by Pravin B Shelar. Cc: Jesse Gross <jesse@nicira.com> Cc: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-20rps: selective flow shedding during softnet overflowWillem de Bruijn
A cpu executing the network receive path sheds packets when its input queue grows to netdev_max_backlog. A single high rate flow (such as a spoofed source DoS) can exceed a single cpu processing rate and will degrade throughput of other flows hashed onto the same cpu. This patch adds a more fine grained hashtable. If the netdev backlog is above a threshold, IRQ cpus track the ratio of total traffic of each flow (using 4096 buckets, configurable). The ratio is measured by counting the number of packets per flow over the last 256 packets from the source cpu. Any flow that occupies a large fraction of this (set at 50%) will see packet drop while above the threshold. Tested: Setup is a muli-threaded UDP echo server with network rx IRQ on cpu0, kernel receive (RPS) on cpu0 and application threads on cpus 2--7 each handling 20k req/s. Throughput halves when hit with a 400 kpps antagonist storm. With this patch applied, antagonist overload is dropped and the server processes its complete load. The patch is effective when kernel receive processing is the bottleneck. The above RPS scenario is a extreme, but the same is reached with RFS and sufficient kernel processing (iptables, packet socket tap, ..). Signed-off-by: Willem de Bruijn <willemb@google.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-01netlink: kconfig: move mmap i/o into netlink kconfigDaniel Borkmann
Currently, in menuconfig, Netlink's new mmaped IO is the very first entry under the ``Networking support'' item and comes even before ``Networking options'': [ ] Netlink: mmaped IO Networking options ---> ... Lets move this into ``Networking options'' under netlink's Kconfig, since this might be more appropriate. Introduced by commit ccdfcc398 (``netlink: mmaped netlink: ring setup''). Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-19netlink: mmaped netlink: ring setupPatrick McHardy
Add support for mmap'ed RX and TX ring setup and teardown based on the af_packet.c code. The following patches will use this to add the real mmap'ed receive and transmit functionality. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-21netlink: Diag core and basic socket info dumping (v2)Andrey Vagin
The netlink_diag can be built as a module, just like it's done in unix sockets. The core dumping message carries the basic info about netlink sockets: family, type and protocol, portis, dst_group, dst_portid, state. Groups can be received as an optional parameter NETLINK_DIAG_GROUPS. Netlink sockets cab be filtered by protocols. The socket inode number and cookie is reserved for future per-socket info retrieving. The per-protocol filtering is also reserved for future by requiring the sdiag_protocol to be zero. The file /proc/net/netlink doesn't provide enough information for dumping netlink sockets. It doesn't provide dst_group, dst_portid, groups above 32. v2: fix NETLINK_DIAG_MAX. Now it's equal to the last constant. Acked-by: Pavel Emelyanov <xemul@parallels.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Eric Dumazet <edumazet@google.com> Cc: Pablo Neira Ayuso <pablo@netfilter.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Gao feng <gaofeng@cn.fujitsu.com> Cc: Thomas Graf <tgraf@suug.ch> Signed-off-by: Andrey Vagin <avagin@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-21Merge tag 'driver-core-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core patches from Greg Kroah-Hartman: "Here is the big driver core merge for 3.9-rc1 There are two major series here, both of which touch lots of drivers all over the kernel, and will cause you some merge conflicts: - add a new function called devm_ioremap_resource() to properly be able to check return values. - remove CONFIG_EXPERIMENTAL Other than those patches, there's not much here, some minor fixes and updates" Fix up trivial conflicts * tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits) base: memory: fix soft/hard_offline_page permissions drivercore: Fix ordering between deferred_probe and exiting initcalls backlight: fix class_find_device() arguments TTY: mark tty_get_device call with the proper const values driver-core: constify data for class_find_device() firmware: Ignore abort check when no user-helper is used firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER firmware: Make user-mode helper optional firmware: Refactoring for splitting user-mode helper code Driver core: treat unregistered bus_types as having no devices watchdog: Convert to devm_ioremap_resource() thermal: Convert to devm_ioremap_resource() spi: Convert to devm_ioremap_resource() power: Convert to devm_ioremap_resource() mtd: Convert to devm_ioremap_resource() mmc: Convert to devm_ioremap_resource() mfd: Convert to devm_ioremap_resource() media: Convert to devm_ioremap_resource() iommu: Convert to devm_ioremap_resource() drm: Convert to devm_ioremap_resource() ...
2013-02-10VSOCK: Introduce VM SocketsAndy King
VM Sockets allows communication between virtual machines and the hypervisor. User level applications both in a virtual machine and on the host can use the VM Sockets API, which facilitates fast and efficient communication between guest virtual machines and their host. A socket address family, designed to be compatible with UDP and TCP at the interface level, is provided. Today, VM Sockets is used by various VMware Tools components inside the guest for zero-config, network-less access to VMware host services. In addition to this, VMware's users are using VM Sockets for various applications, where network access of the virtual machine is restricted or non-existent. Examples of this are VMs communicating with device proxies for proprietary hardware running as host applications and automated testing of applications running within virtual machines. The VMware VM Sockets are similar to other socket types, like Berkeley UNIX socket interface. The VM Sockets module supports both connection-oriented stream sockets like TCP, and connectionless datagram sockets like UDP. The VM Sockets protocol family is defined as "AF_VSOCK" and the socket operations split for SOCK_DGRAM and SOCK_STREAM. For additional information about the use of VM Sockets, please refer to the VM Sockets Programming Guide available at: https://www.vmware.com/support/developer/vmci-sdk/ Signed-off-by: George Zhang <georgezhang@vmware.com> Signed-off-by: Dmitry Torokhov <dtor@vmware.com> Signed-off-by: Andy king <acking@vmware.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-31wanrouter: completely decouple obsolete code from kernel.Paul Gortmaker
The original suggestion to delete wanrouter started earlier with the mainline commit f0d1b3c2bcc5de8a17af5f2274f7fcde8292b5fc ("net/wanrouter: Deprecate and schedule for removal") in May 2012. More importantly, Dan Carpenter found[1] that the driver had a fundamental breakage introduced back in 2008, with commit 7be6065b39c3 ("netdevice wanrouter: Convert directly reference of netdev->priv"). So we know with certainty that the code hasn't been used by anyone willing to at least take the effort to send an e-mail report of breakage for at least 4 years. This commit does a decouple of the wanrouter subsystem, by going after the Makefile/Kconfig and similar files, so that these mainline files that we are keeping do not have the big wanrouter file/driver deletion commit tied into their history. Once this commit is in place, we then can remove the obsolete cyclomx drivers and similar that have a dependency on CONFIG_WAN_ROUTER_DRIVERS. [1] http://www.spinics.net/lists/netdev/msg218670.html Originally-by: Joe Perches <joe@perches.com> Cc: Dan Carpenter <dan.carpenter@oracle.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2013-01-11net: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. CC: "David S. Miller" <davem@davemloft.net> Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: David S. Miller <davem@davemloft.net>
2013-01-10net: Add support for XPS without sysfs being definedAlexander Duyck
This patch makes it so that we can support transmit packet steering without sysfs needing to be enabled. The reason for making this change is to make it so that a driver can make use of the XPS even while the sysfs portion of the interface is not present. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-04net: Add INET dependency on aes crypto for the sake of TCP fastopen.David S. Miller
Stephen Rothwell says: ==================== After merging the final tree, today's linux-next build (powerpc ppc44x_defconfig) failed like this: net/built-in.o: In function `tcp_fastopen_ctx_free': tcp_fastopen.c:(.text+0x5cc5c): undefined reference to `crypto_destroy_tfm' net/built-in.o: In function `tcp_fastopen_reset_cipher': (.text+0x5cccc): undefined reference to `crypto_alloc_base' net/built-in.o: In function `tcp_fastopen_reset_cipher': (.text+0x5cd6c): undefined reference to `crypto_destroy_tfm' Presumably caused by commit 104671636897 ("tcp: TCP Fast Open Server - header & support functions") from the net-next tree. I assume that some dependency on the CRYPTO infrastructure is missing. I have reverted commit 1bed966cc3bd ("Merge branch 'tcp_fastopen_server'") for today. ==================== Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-21net: drop NET dependency from HAVE_BPF_JITSam Ravnborg
There is no point having the NET dependency on the select target, as it forces all users to depend on NET to tell they support BPF_JIT. Move the config option to the bottom of the file - this could be a nice place also for future "selectable" config symbols. Fix up all users to drop the dependency on NET now that it is not required to supress warnings for non-NET builds. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: David Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-18econet: remove ancient bug ridden protocolStephen Hemminger
More spring cleaning! The ancient Econet protocol should go. Most of the bug fixes in recent years have been fixing security vulnerabilities. The hardware hasn't been made since the 90s, it is only interesting as an archeological curiosity. For the truly curious, or insomniac, go read up on it. http://en.wikipedia.org/wiki/Econet Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-17drop_monitor: convert to modular buildingNeil Horman
When I first wrote drop monitor I wrote it to just build monolithically. There is no reason it can't be built modularly as well, so lets give it that flexibiity. I've tested this by building it as both a module and monolithically, and it seems to work quite well Change notes: v2) * fixed for_each_present_cpu loops to be more correct as per Eric D. * Converted exit path failures to BUG_ON as per Ben H. v3) * Converted del_timer to del_timer_sync to close race noted by Ben H. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> CC: "David S. Miller" <davem@davemloft.net> CC: Eric Dumazet <eric.dumazet@gmail.com> CC: Ben Hutchings <bhutchings@solarflare.com> Reviewed-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-16mac802154: allocation of ieee802154 devicealex.bluesman.smirnov@gmail.com
An interface to allocate and register ieee802154 compatible device. The allocated device has the following representation in memory: +-----------------------+ | struct wpan_phy | +-----------------------+ | struct mac802154_priv | +-----------------------+ | driver's private data | +-----------------------+ Used by device drivers to register new instance in the stack. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-03net: Add Open vSwitch kernel components.Jesse Gross
Open vSwitch is a multilayer Ethernet switch targeted at virtualized environments. In addition to supporting a variety of features expected in a traditional hardware switch, it enables fine-grained programmatic extension and flow-based control of the network. This control is useful in a wide variety of applications but is particularly important in multi-server virtualization deployments, which are often characterized by highly dynamic endpoints and the need to maintain logical abstractions for multiple tenants. The Open vSwitch datapath provides an in-kernel fast path for packet forwarding. It is complemented by a userspace daemon, ovs-vswitchd, which is able to accept configuration from a variety of sources and translate it into packet processing rules. See http://openvswitch.org for more information and userspace utilities. Signed-off-by: Jesse Gross <jesse@nicira.com>
2011-11-29bql: Byte queue limitsTom Herbert
Networking stack support for byte queue limits, uses dynamic queue limits library. Byte queue limits are maintained per transmit queue, and a dql structure has been added to netdev_queue structure for this purpose. Configuration of bql is in the tx-<n> sysfs directory for the queue under the byte_queue_limits directory. Configuration includes: limit_min, bql minimum limit limit_max, bql maximum limit hold_time, bql slack hold time Also under the directory are: limit, current byte limit inflight, current number of bytes on the queue Signed-off-by: Tom Herbert <therbert@google.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-22net: add network priority cgroup infrastructure (v4)Neil Horman
This patch adds in the infrastructure code to create the network priority cgroup. The cgroup, in addition to the standard processes file creates two control files: 1) prioidx - This is a read-only file that exports the index of this cgroup. This is a value that is both arbitrary and unique to a cgroup in this subsystem, and is used to index the per-device priority map 2) priomap - This is a writeable file. On read it reports a table of 2-tuples <name:priority> where name is the name of a network interface and priority is indicates the priority assigned to frames egresessing on the named interface and originating from a pid in this cgroup This cgroup allows for skb priority to be set prior to a root qdisc getting selected. This is benenficial for DCB enabled systems, in that it allows for any application to use dcb configured priorities so without application modification Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: John Fastabend <john.r.fastabend@intel.com> CC: Robert Love <robert.w.love@intel.com> CC: "David S. Miller" <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-05NFC: add nfc subsystem coreLauro Ramos Venancio
The NFC subsystem core is responsible for providing the device driver interface. It is also responsible for providing an interface to the control operations and data exchange. Signed-off-by: Lauro Ramos Venancio <lauro.venancio@openbossa.org> Signed-off-by: Aloisio Almeida Jr <aloisio.almeida@openbossa.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-29bpf: depends on MODULESEric Dumazet
module_alloc() and module_free() are available only if CONFIG_MODULES=y Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-27net: filter: Just In Time compiler for x86-64Eric Dumazet
In order to speedup packet filtering, here is an implementation of a JIT compiler for x86_64 It is disabled by default, and must be enabled by the admin. echo 1 >/proc/sys/net/core/bpf_jit_enable It uses module_alloc() and module_free() to get memory in the 2GB text kernel range since we call helpers functions from the generated code. EAX : BPF A accumulator EBX : BPF X accumulator RDI : pointer to skb (first argument given to JIT function) RBP : frame pointer (even if CONFIG_FRAME_POINTER=n) r9d : skb->len - skb->data_len (headlen) r8 : skb->data To get a trace of generated code, use : echo 2 >/proc/sys/net/core/bpf_jit_enable Example of generated code : # tcpdump -p -n -s 0 -i eth1 host 192.168.20.0/24 flen=18 proglen=147 pass=3 image=ffffffffa00b5000 JIT code: ffffffffa00b5000: 55 48 89 e5 48 83 ec 60 48 89 5d f8 44 8b 4f 60 JIT code: ffffffffa00b5010: 44 2b 4f 64 4c 8b 87 b8 00 00 00 be 0c 00 00 00 JIT code: ffffffffa00b5020: e8 24 7b f7 e0 3d 00 08 00 00 75 28 be 1a 00 00 JIT code: ffffffffa00b5030: 00 e8 fe 7a f7 e0 24 00 3d 00 14 a8 c0 74 49 be JIT code: ffffffffa00b5040: 1e 00 00 00 e8 eb 7a f7 e0 24 00 3d 00 14 a8 c0 JIT code: ffffffffa00b5050: 74 36 eb 3b 3d 06 08 00 00 74 07 3d 35 80 00 00 JIT code: ffffffffa00b5060: 75 2d be 1c 00 00 00 e8 c8 7a f7 e0 24 00 3d 00 JIT code: ffffffffa00b5070: 14 a8 c0 74 13 be 26 00 00 00 e8 b5 7a f7 e0 24 JIT code: ffffffffa00b5080: 00 3d 00 14 a8 c0 75 07 b8 ff ff 00 00 eb 02 31 JIT code: ffffffffa00b5090: c0 c9 c3 BPF program is 144 bytes long, so native program is almost same size ;) (000) ldh [12] (001) jeq #0x800 jt 2 jf 8 (002) ld [26] (003) and #0xffffff00 (004) jeq #0xc0a81400 jt 16 jf 5 (005) ld [30] (006) and #0xffffff00 (007) jeq #0xc0a81400 jt 16 jf 17 (008) jeq #0x806 jt 10 jf 9 (009) jeq #0x8035 jt 10 jf 17 (010) ld [28] (011) and #0xffffff00 (012) jeq #0xc0a81400 jt 16 jf 13 (013) ld [38] (014) and #0xffffff00 (015) jeq #0xc0a81400 jt 16 jf 17 (016) ret #65535 (017) ret #0 Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@infradead.org> Cc: Ben Hutchings <bhutchings@solarflare.com> Cc: Hagen Paul Pfeifer <hagen@jauu.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-24net: RPS: Enable hardware acceleration of RFSBen Hutchings
Allow drivers for multiqueue hardware with flow filter tables to accelerate RFS. The driver must: 1. Set net_device::rx_cpu_rmap to a cpu_rmap of the RX completion IRQs (in queue order). This will provide a mapping from CPUs to the queues for which completions are handled nearest to them. 2. Implement net_device_ops::ndo_rx_flow_steer. This operation adds or replaces a filter steering the given flow to the given RX queue, if possible. 3. Periodically remove filters for which rps_may_expire_flow() returns true. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) Documentation/trace/events.txt: Remove obsolete sched_signal_send. writeback: fix global_dirty_limits comment runtime -> real-time ppc: fix comment typo singal -> signal drivers: fix comment typo diable -> disable. m68k: fix comment typo diable -> disable. wireless: comment typo fix diable -> disable. media: comment typo fix diable -> disable. remove doc for obsolete dynamic-printk kernel-parameter remove extraneous 'is' from Documentation/iostats.txt Fix spelling milisec -> ms in snd_ps3 module parameter description Fix spelling mistakes in comments Revert conflicting V4L changes i7core_edac: fix typos in comments mm/rmap.c: fix comment sound, ca0106: Fix assignment to 'channel'. hrtimer: fix a typo in comment init/Kconfig: fix typo anon_inodes: fix wrong function name in comment fix comment typos concerning "consistent" poll: fix a typo in comment ... Fix up trivial conflicts in: - drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c) - fs/ext4/ext4.h Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
2010-12-16net: Add batman-adv meshing protocolSven Eckelmann
B.A.T.M.A.N. (better approach to mobile ad-hoc networking) is a routing protocol for multi-hop ad-hoc mesh networks. The networks may be wired or wireless. See http://www.open-mesh.org/ for more information and user space tools. Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-28xps: Add CONFIG_XPSTom Herbert
This patch adds XPS_CONFIG option to enable and disable XPS. This is done in the same manner as RPS_CONFIG. This is also fixes build failure in XPS code when SMP is not enabled. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-15Docs/Kconfig: Update: osdl.org -> linuxfoundation.orgMichael Witten
Some of the documentation refers to web pages under the domain `osdl.org'. However, `osdl.org' now redirects to `linuxfoundation.org'. Rather than rely on redirections, this patch updates the addresses appropriately; for the most part, only documentation that is meant to be current has been updated. The patch should be pretty quick to scan and check; each new web-page url was gotten by trying out the original URL in a browser and then simply copying the the redirected URL (formatting as necessary). There is some conflict as to which one of these domain names is preferred: linuxfoundation.org linux-foundation.org So, I wrote: info@linuxfoundation.org and got this reply: Message-ID: <4CE17EE6.9040807@linuxfoundation.org> Date: Mon, 15 Nov 2010 10:41:42 -0800 From: David Ames <david@linuxfoundation.org> ... linuxfoundation.org is preferred. The canonical name for our web site is www.linuxfoundation.org. Our list site is actually lists.linux-foundation.org. Regarding email linuxfoundation.org is preferred there are a few people who choose to use linux-foundation.org for their own reasons. Consequently, I used `linuxfoundation.org' for web pages and `lists.linux-foundation.org' for mailing-list web pages and email addresses; the only personal email address I updated from `@osdl.org' was that of Andrew Morton, who prefers `linux-foundation.org' according `git log'. Signed-off-by: Michael Witten <mfwitten@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
