path: root/net/9p
2013-11-15Merge tag 'virtio-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull virtio updates from Rusty Russell: "Nothing really exciting: some groundwork for changing virtio endian, and some robustness fixes for broken virtio devices, plus minor tweaks" * tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: virtio_scsi: verify if queue is broken after virtqueue_get_buf() x86, asmlinkage, lguest: Pass in globals into assembler statement virtio: mmio: fix signature checking for BE guests virtio_ring: adapt to notify() returning bool virtio_net: verify if queue is broken after virtqueue_get_buf() virtio_console: verify if queue is broken after virtqueue_get_buf() virtio_blk: verify if queue is broken after virtqueue_get_buf() virtio_ring: add new function virtqueue_is_broken() virtio_test: verify if virtqueue_kick() succeeded virtio_net: verify if virtqueue_kick() succeeded virtio_ring: let virtqueue_{kick()/notify()} return a bool virtio_ring: change host notification API virtio_config: remove virtio_config_val virtio: use size-based config accessors. virtio_config: introduce size-based accessors. virtio_ring: plug kmemleak false positive. virtio: pm: use CONFIG_PM_SLEEP instead of CONFIG_PM
2013-10-24file->f_op is never NULL...Al Viro
2013-10-17virtio: use size-based config accessors.Rusty Russell
This lets the transport do endian conversion if necessary, and insulates the drivers from the difference. Most drivers can use the simple helpers virtio_cread() and virtio_cwrite(). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-09-11Merge tag 'for-linus-3.12-merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs Pull 9p updates from Eric Van Hensbergen: "Minor 9p fixes and tweaks for 3.12 merge window The first fixes namespace issues which causes a kernel NULL pointer dereference, the second fixes uevent handling to work better with udev, and the third switches some code to use srlcpy instead of strncpy in order to be safer. All changes have been baking in for-next for at least 2 weeks" * tag 'for-linus-3.12-merge' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs: fs/9p: avoid accessing utsname after namespace has been torn down 9p: send uevent after adding/removing mount_tag attribute fs: 9p: use strlcpy instead of strncpy
2013-08-26fs/9p: avoid accessing utsname after namespace has been torn downWill Deacon
During trinity fuzzing in a kvmtool guest, I stumbled across the following: Unable to handle kernel NULL pointer dereference at virtual address 00000004 PC is at v9fs_file_do_lock+0xc8/0x1a0 LR is at v9fs_file_do_lock+0x48/0x1a0 [<c01e2ed0>] (v9fs_file_do_lock+0xc8/0x1a0) from [<c0119154>] (locks_remove_flock+0x8c/0x124) [<c0119154>] (locks_remove_flock+0x8c/0x124) from [<c00d9bf0>] (__fput+0x58/0x1e4) [<c00d9bf0>] (__fput+0x58/0x1e4) from [<c0044340>] (task_work_run+0xac/0xe8) [<c0044340>] (task_work_run+0xac/0xe8) from [<c002e36c>] (do_exit+0x6bc/0x8d8) [<c002e36c>] (do_exit+0x6bc/0x8d8) from [<c002e674>] (do_group_exit+0x3c/0xb0) [<c002e674>] (do_group_exit+0x3c/0xb0) from [<c002e6f8>] (__wake_up_parent+0x0/0x18) I believe this is due to an attempt to access utsname()->nodename, after exit_task_namespaces() has been called, leaving current->nsproxy->uts_ns as NULL and causing the above dereference. A similar issue was fixed for lockd in 9a1b6bf818e7 ("LOCKD: Don't call utsname()->nodename from nlmclnt_setlockargs"), so this patch attempts something similar for 9pfs. Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Ron Minnich <rminnich@sandia.gov> Cc: Latchesar Ionkov <lucho@ionkov.net> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2013-08-269p: send uevent after adding/removing mount_tag attributeMichael Marineau
This driver adds an attribute to the existing virtio device so a CHANGE event is required in order udev rules to make use of it. The ADD event happens before this driver is probed and unlike a more typical driver like a block device there isn't a higher level device to watch for. Signed-off-by: Michael Marineau <michael.marineau@coreos.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2013-07-309p: client: remove unused code and any reference to "cancelled" functionAndi Shyti
This patch reverts commit 80b45261a0b263536b043c5ccfc4ba4fc27c2acc which was implementing a 'cancelled' functionality to notify that a cancelled request will not be replied. This implementation was not used anywhere and therefore removed. Signed-off-by: Andi Shyti <andi@etezian.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-24net: trans_rdma: remove unused functionAndi Shyti
This patch gets rid of the following warning: net/9p/trans_rdma.c:594:12: warning: ‘rdma_cancelled’ defined but not used [-Wunused-function] static int rdma_cancelled(struct p9_client *client, struct p9_req_t *req) The rdma_cancelled function is not called anywhere in the kernel Signed-off-by: Andi Shyti <andi@etezian.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "Just a bunch of small fixes and tidy ups: 1) Finish the "busy_poll" renames, from Eliezer Tamir. 2) Fix RCU stalls in IFB driver, from Ding Tianhong. 3) Linearize buffers properly in tun/macvtap zerocopy code. 4) Don't crash on rmmod in vxlan, from Pravin B Shelar. 5) Spinlock used before init in alx driver, from Maarten Lankhorst. 6) A sparse warning fix in bnx2x broke TSO checksums, fix from Dmitry Kravkov. 7) Dummy and ifb driver load failure paths can oops, fixes from Tan Xiaojun and Ding Tianhong. 8) Correct MTU calculations in IP tunnels, from Alexander Duyck. 9) Account all TCP retransmits in SNMP stats properly, from Yuchung Cheng. 10) atl1e and via-rhine do not handle DMA mapping failures properly, from Neil Horman. 11) Various equal-cost multipath route fixes in ipv6 from Hannes Frederic Sowa" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (36 commits) ipv6: only static routes qualify for equal cost multipathing via-rhine: fix dma mapping errors atl1e: fix dma mapping warnings tcp: account all retransmit failures usb/net/r815x: fix cast to restricted __le32 usb/net/r8152: fix integer overflow in expression net: access page->private by using page_private net: strict_strtoul is obsolete, use kstrtoul instead drivers/net/ieee802154: don't use devm_pinctrl_get_select_default() in probe drivers/net/ethernet/cadence: don't use devm_pinctrl_get_select_default() in probe drivers/net/can/c_can: don't use devm_pinctrl_get_select_default() in probe net/usb: add relative mii functions for r815x net/tipc: use %*phC to dump small buffers in hex form qlcnic: Adding Maintainers. gre: Fix MTU sizing check for gretap tunnels pkt_sched: sch_qfq: remove forward declaration of qfq_update_agg_ts pkt_sched: sch_qfq: improve efficiency of make_eligible gso: Update tunnel segmentation to support Tx checksum offload inet: fix spacing in assignment ifb: fix oops when loading the ifb failed ...
2013-07-119p: fix off by one causing access violations and memory corruptionSasha Levin
p9_release_pages() would attempt to dereference one value past the end of pages[]. This would cause the following crashes: [ 6293.171817] BUG: unable to handle kernel paging request at ffff8807c96f3000 [ 6293.174146] IP: [<ffffffff8412793b>] p9_release_pages+0x3b/0x60 [ 6293.176447] PGD 79c5067 PUD 82c1e3067 PMD 82c197067 PTE 80000007c96f3060 [ 6293.180060] Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC [ 6293.180060] Modules linked in: [ 6293.180060] CPU: 62 PID: 174043 Comm: modprobe Tainted: G W 3.10.0-next-20130710-sasha #3954 [ 6293.180060] task: ffff8807b803b000 ti: ffff880787dde000 task.ti: ffff880787dde000 [ 6293.180060] RIP: 0010:[<ffffffff8412793b>] [<ffffffff8412793b>] p9_release_pages+0x3b/0x60 [ 6293.214316] RSP: 0000:ffff880787ddfc28 EFLAGS: 00010202 [ 6293.214316] RAX: 0000000000000001 RBX: ffff8807c96f2ff8 RCX: 0000000000000000 [ 6293.222017] RDX: ffff8807b803b000 RSI: 0000000000000001 RDI: ffffea001c7e3d40 [ 6293.222017] RBP: ffff880787ddfc48 R08: 0000000000000000 R09: 0000000000000000 [ 6293.222017] R10: 0000000000000001 R11: 0000000000000000 R12: 0000000000000001 [ 6293.222017] R13: 0000000000000001 R14: ffff8807cc50c070 R15: ffff8807cc50c070 [ 6293.222017] FS: 00007f572641d700(0000) GS:ffff8807f3600000(0000) knlGS:0000000000000000 [ 6293.256784] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [ 6293.256784] CR2: ffff8807c96f3000 CR3: 00000007c8e81000 CR4: 00000000000006e0 [ 6293.256784] Stack: [ 6293.256784] ffff880787ddfcc8 ffff880787ddfcc8 0000000000000000 ffff880787ddfcc8 [ 6293.256784] ffff880787ddfd48 ffffffff84128be8 ffff880700000002 0000000000000001 [ 6293.256784] ffff8807b803b000 ffff880787ddfce0 0000100000000000 0000000000000000 [ 6293.256784] Call Trace: [ 6293.256784] [<ffffffff84128be8>] p9_virtio_zc_request+0x598/0x630 [ 6293.256784] [<ffffffff8115c610>] ? wake_up_bit+0x40/0x40 [ 6293.256784] [<ffffffff841209b1>] p9_client_zc_rpc+0x111/0x3a0 [ 6293.256784] [<ffffffff81174b78>] ? sched_clock_cpu+0x108/0x120 [ 6293.256784] [<ffffffff84122a21>] p9_client_read+0xe1/0x2c0 [ 6293.256784] [<ffffffff81708a90>] v9fs_file_read+0x90/0xc0 [ 6293.256784] [<ffffffff812bd073>] vfs_read+0xc3/0x130 [ 6293.256784] [<ffffffff811a78bd>] ? trace_hardirqs_on+0xd/0x10 [ 6293.256784] [<ffffffff812bd5a2>] SyS_read+0x62/0xa0 [ 6293.256784] [<ffffffff841a1a00>] tracesys+0xdd/0xe2 [ 6293.256784] Code: 66 90 48 89 fb 41 89 f5 48 8b 3f 48 85 ff 74 29 85 f6 74 25 45 31 e4 66 0f 1f 84 00 00 00 00 00 e8 eb 14 12 fd 41 ff c4 49 63 c4 <48> 8b 3c c3 48 85 ff 74 05 45 39 e5 75 e7 48 83 c4 08 5b 41 5c [ 6293.256784] RIP [<ffffffff8412793b>] p9_release_pages+0x3b/0x60 [ 6293.256784] RSP <ffff880787ddfc28> [ 6293.256784] CR2: ffff8807c96f3000 [ 6293.256784] ---[ end trace 50822ee72cd360fc ]--- Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-11Merge tag 'for-linus-3.11-merge-window-part-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs Pull second round of 9p patches from Eric Van Hensbergen: "Several of these patches were rebased in order to correct style issues. Only stylistic changes were made versus the patches which were in linux-next for two weeks. The rebases have been in linux-next for 3 days and have passed my regressions. The bulk of these are RDMA fixes and improvements. There's also some additions on the extended attributes front to support some additional namespaces and a new option for TCP to force allocation of mount requests from a priviledged port" * tag 'for-linus-3.11-merge-window-part-2' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs: fs/9p: Remove the unused variable "err" in v9fs_vfs_getattr() 9P: Add cancelled() to the transport functions. 9P/RDMA: count posted buffers without a pending request 9P/RDMA: Improve error handling in rdma_request 9P/RDMA: Do not free req->rc in error handling in rdma_request() 9P/RDMA: Use a semaphore to protect the RQ 9P/RDMA: Protect against duplicate replies 9P/RDMA: increase P9_RDMA_MAXSIZE to 1MB 9pnet: refactor struct p9_fcall alloc code 9P/RDMA: rdma_request() needs not allocate req->rc 9P: Fix fcall allocation for rdma fs/9p: xattr: add trusted and security namespaces net/9p: add privport option to 9p tcp transport
2013-07-09Merge tag 'for-linus-3.11-merge-window-part-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs Pull 9p update from Eric Van Hensbergen: "Grab bag of little fixes and enhancements: - optional security enhancements - fix path coverage in MAINTAINERS - switch to using most used protocol and transport as default - clean up buffer dumps in trace code Held off on RDMA patches as they need to be cleaned up a bit, but will try to get the cleaned, checked, and pushed by mid-week" * tag 'for-linus-3.11-merge-window-part-1' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs: 9p: Add rest of 9p files to MAINTAINERS entry 9p: trace: use %*ph to dump buffer net/9p: Handle error in zero copy request correctly for 9p2000.u net/9p: Use virtio transpart as the default transport net/9p: Make 9P2000.L the default protocol for 9p file system
2013-07-079P: Add cancelled() to the transport functions.Simon Derr
RDMA needs to post a buffer for each incoming reply. Hence it needs to keep count of these and needs to be aware of whether a flushed request has received a reply or not. This patch adds the cancelled() callback to the transport modules. It is called when RFLUSH has been received and that the corresponding request will never receive a reply. Signed-off-by: Simon Derr <simon.derr@bull.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2013-07-079P/RDMA: count posted buffers without a pending requestSimon Derr
In rdma_request(): If an error occurs between posting the recv and the send, there will be a reply context posted without a pending request. Since there is no way to "un-post" it, we remember it and skip post_recv() for the next request. Signed-off-by: Simon Derr <simon.derr@bull.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2013-07-079P/RDMA: Improve error handling in rdma_requestSimon Derr
Most importantly: - do not free the recv context (rpl_context) after a successful post_recv() - but do free the send context (c) after a failed send. Signed-off-by: Simon Derr <simon.derr@bull.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2013-07-079P/RDMA: Do not free req->rc in error handling in rdma_request()Simon Derr
rdma_request() should never be in charge of freeing rc. When an error occurs: * Either the rc buffer has been recv_post()'ed. then kfree()'ing it certainly is a bad idea. * Or is has not, and in that case req->rc still points to it, hence it needs not be freed. Signed-off-by: Simon Derr <simon.derr@bull.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2013-07-079P/RDMA: Use a semaphore to protect the RQSimon Derr
The current code keeps track of the number of buffers posted in the RQ, and will prevent it from overflowing. But it does so by simply dropping post requests (And leaking memory in the process). When this happens there will actually be too few buffers posted, and soon the 9P server will complain about 'RNR retry counter exceeded' errors. Instead, use a semaphore, and block until the RQ is ready for another buffer to be posted. Signed-off-by: Simon Derr <simon.derr@bull.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2013-07-079P/RDMA: Protect against duplicate repliesSimon Derr
A well-behaved server would not send twice the reply to a request. But if it ever happens... This additional check prevents the kernel from leaking memory and possibly more nasty consequences in that unlikely event. Signed-off-by: Simon Derr <simon.derr@bull.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2013-07-079P/RDMA: increase P9_RDMA_MAXSIZE to 1MBSimon Derr
The current value is too low to get good performance. Signed-off-by: Simon Derr <simon.derr@bull.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2013-07-079pnet: refactor struct p9_fcall alloc codeSimon Derr
2013-07-079P/RDMA: rdma_request() needs not allocate req->rcSimon Derr
p9_tag_alloc() takes care of that. Signed-off-by: Simon Derr <simon.derr@bull.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2013-07-079P: Fix fcall allocation for rdmaSimon Derr
The current code assumes that when a request in the request array does have a tc, it also has a rc. This is normally true, but not always : when using RDMA, req->rc will temporarily be set to NULL after the request has been sent. That is usually OK though, as when the reply arrives, req->rc will be reassigned to a sane value before the request is recycled. But there is a catch : if the request is flushed, the reply will never arrive, and req->rc will be NULL, but not req->tc. This patch fixes p9_tag_alloc to take this into account. Signed-off-by: Simon Derr <simon.derr@bull.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2013-07-07net/9p: add privport option to 9p tcp transportJim Garlick
If the privport option is specified, the tcp transport binds local address to a reserved port before connecting to the 9p server. In some cases when 9P AUTH cannot be implemented, this is better than nothing. Signed-off-by: Jim Garlick <garlick@llnl.gov> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2013-06-10Merge tag '9p-3.10-bug-fix-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs Pull net/9p bug fix from Eric Van Hensbergen: "zero copy error fix" * tag '9p-3.10-bug-fix-1' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs: net/9p: Handle error in zero copy request correctly for 9p2000.u
2013-05-28net/9p: Handle error in zero copy request correctly for 9p2000.uAneesh Kumar K.V
For zero copy request, error will be encoded in the user space buffer. So copy the error code correctly using copy_from_user. Here we use the extra bytes we allocate for zero copy request. If total error details are more than P9_ZC_HDR_SZ - 7 bytes, we return -EFAULT. The patch also avoid a memory allocation in the error path. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2013-05-28net/9p: Use virtio transpart as the default transportAneesh Kumar K.V
Make the default 9p experience better by defaulting to virtio transport if present. These days most of the users are using 9p in a virtualized setup Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2013-05-28net/9p: Make 9P2000.L the default protocol for 9p file systemAneesh Kumar K.V
If we dont' specify a protocol version default to 9P2000.L. 9P2000.L have better support for posix semantic and is where all the recent development is happening. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2013-05-02Merge tag 'virtio-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull virtio & lguest updates from Rusty Russell: "Lots of virtio work which wasn't quite ready for last merge window. Plus I dived into lguest again, reworking the pagetable code so we can move the switcher page: our fixmaps sometimes take more than 2MB now..." Ugh. Annoying conflicts with the tcm_vhost -> vhost_scsi rename. Hopefully correctly resolved. * tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (57 commits) caif_virtio: Remove bouncing email addresses lguest: improve code readability in lg_cpu_start. virtio-net: fill only rx queues which are being used lguest: map Switcher below fixmap. lguest: cache last cpu we ran on. lguest: map Switcher text whenever we allocate a new pagetable. lguest: don't share Switcher PTE pages between guests. lguest: expost switcher_pages array (as lg_switcher_pages). lguest: extract shadow PTE walking / allocating. lguest: make check_gpte et. al return bool. lguest: assume Switcher text is a single page. lguest: rename switcher_page to switcher_pages. lguest: remove RESERVE_MEM constant. lguest: check vaddr not pgd for Switcher protection. lguest: prepare to make SWITCHER_ADDR a variable. virtio: console: replace EMFILE with EBUSY for already-open port virtio-scsi: reset virtqueue affinity when doing cpu hotplug virtio-scsi: introduce multiqueue support virtio-scsi: push vq lock/unlock into virtscsi_vq_done virtio-scsi: pass struct virtio_scsi to virtqueue completion function ...
2013-03-209p/trans_virtio.c: use virtio_add_sgs[]Rusty Russell
virtio_add_buf() is going away, replaced with virtio_add_sgs() which takes multiple terminated scatterlists. Cc: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-03-08Revert parts of "hlist: drop the node parameter from iterators"Arnd Bergmann
Commit b67bfe0d42ca ("hlist: drop the node parameter from iterators") did a lot of nice changes but also contains two small hunks that seem to have slipped in accidentally and have no apparent connection to the intent of the patch. This reverts the two extraneous changes. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Peter Senna Tschudin <peter.senna@gmail.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-27net/9p: convert to idr_alloc()Tejun Heo
Convert to the much saner new idr interface. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Ron Minnich <rminnich@sandia.gov> Cc: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace and namespace infrastructure changes from Eric W Biederman: "This set of changes starts with a few small enhnacements to the user namespace. reboot support, allowing more arbitrary mappings, and support for mounting devpts, ramfs, tmpfs, and mqueuefs as just the user namespace root. I do my best to document that if you care about limiting your unprivileged users that when you have the user namespace support enabled you will need to enable memory control groups. There is a minor bug fix to prevent overflowing the stack if someone creates way too many user namespaces. The bulk of the changes are a continuation of the kuid/kgid push down work through the filesystems. These changes make using uids and gids typesafe which ensures that these filesystems are safe to use when multiple user namespaces are in use. The filesystems converted for 3.9 are ceph, 9p, afs, ocfs2, gfs2, ncpfs, nfs, nfsd, and cifs. The changes for these filesystems were a little more involved so I split the changes into smaller hopefully obviously correct changes. XFS is the only filesystem that remains. I was hoping I could get that in this release so that user namespace support would be enabled with an allyesconfig or an allmodconfig but it looks like the xfs changes need another couple of days before it they are ready." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (93 commits) cifs: Enable building with user namespaces enabled. cifs: Convert struct cifs_ses to use a kuid_t and a kgid_t cifs: Convert struct cifs_sb_info to use kuids and kgids cifs: Modify struct smb_vol to use kuids and kgids cifs: Convert struct cifsFileInfo to use a kuid cifs: Convert struct cifs_fattr to use kuid and kgids cifs: Convert struct tcon_link to use a kuid. cifs: Modify struct cifs_unix_set_info_args to hold a kuid_t and a kgid_t cifs: Convert from a kuid before printing current_fsuid cifs: Use kuids and kgids SID to uid/gid mapping cifs: Pass GLOBAL_ROOT_UID and GLOBAL_ROOT_GID to keyring_alloc cifs: Use BUILD_BUG_ON to validate uids and gids are the same size cifs: Override unmappable incoming uids and gids nfsd: Enable building with user namespaces enabled. nfsd: Properly compare and initialize kuids and kgids nfsd: Store ex_anon_uid and ex_anon_gid as kuids and kgids nfsd: Modify nfsd4_cb_sec to use kuids and kgids nfsd: Handle kuids and kgids in the nfs4acl to posix_acl conversion nfsd: Convert nfsxdr to use kuids and kgids nfsd: Convert nfs3xdr to use kuids and kgids ...
2013-02-23net: change type of virtio_chan->p9_max_pagesZhang Yanfei
This member of struct virtio_chan is calculated from nr_free_buffer_pages so change its type to unsigned long in case of overflow. Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Cc: David Miller <davem@davemloft.net> Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Ron Minnich <rminnich@sandia.gov> Cc: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-129p: Modify the stat structures to use kuid_t and kgid_tEric W. Biederman
9p has thre strucrtures that can encode inode stat information. Modify all of those structures to contain kuid_t and kgid_t values. Modify he wire encoders and decoders of those structures to use 'u' and 'g' instead of 'd' in the format string where uids and gids are present. This results in all kuid and kgid conversion to and from on the wire values being performed by the same code in protocol.c where the client is known at the time of the conversion. Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Ron Minnich <rminnich@gmail.com> Cc: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2013-02-129p: Transmit kuid and kgid valuesEric W. Biederman
Modify the p9_client_rpc format specifiers of every function that directly transmits a uid or a gid from 'd' to 'u' or 'g' as appropriate. Modify those same functions to take kuid_t and kgid_t parameters instead of uid_t and gid_t parameters. Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Ron Minnich <rminnich@gmail.com> Cc: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2013-02-129p: Add 'u' and 'g' format specifies for kuids and kgidsEric W. Biederman
This allows concentrating all of the conversion to and from kuids and kgids into the format needed by the 9p protocol into one location. Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Ron Minnich <rminnich@gmail.com> Cc: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-01-11net/9p: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. CC: "David S. Miller" <davem@davemloft.net> Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: David S. Miller <davem@davemloft.net>
2012-10-22virtio: 9p: correctly pass physical address to userspace for high pagesWill Deacon
When using a virtio transport, the 9p net device may pass the physical address of a kernel buffer to userspace via a scatterlist inside a virtqueue. If the kernel buffer is mapped outside of the linear mapping (e.g. highmem), then virt_to_page will return a bogus value and we will populate the scatterlist with junk. This patch uses kmap_to_page when populating the page array for a kernel buffer. Cc: stable@kernel.org Cc: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-12Merge tag 'for-linus-merge-3.7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs Pull v9fs update from Eric Van Hensbergen. * tag 'for-linus-merge-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs: 9P: Fix race between p9_write_work() and p9_fd_request() 9P: Fix race in p9_write_work() 9P: fix test at the end of p9_write_work() 9P: Fix race in p9_read_work() 9p: don't use __getname/__putname for uname/aname net/9p: Check errno validity fs/9p: avoid debug OOPS when reading a long symlink
2012-10-119P: Fix race between p9_write_work() and p9_fd_request()Simon Derr
Race scenario: thread A thread B p9_write_work() p9_fd_request() if (list_empty (&m->unsent_req_list)) ... spin_lock(&client->lock); req->status = REQ_STATUS_UNSENT; list_add_tail(..., &m->unsent_req_list); spin_unlock(&client->lock); .... if (n & POLLOUT && !test_and_set_bit(Wworksched, &m->wsched) schedule_work(&m->wq); --> not done because Wworksched is set clear_bit(Wworksched, &m->wsched); return; --> nobody will take care of sending the new request. This is not very likely to happen though, because p9_write_work() being called with an empty unsent_req_list is not frequent. But this also means that taking the lock earlier will not be costly. Signed-off-by: Simon Derr <simon.derr@bull.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2012-10-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs update from Al Viro: - big one - consolidation of descriptor-related logics; almost all of that is moved to fs/file.c (BTW, I'm seriously tempted to rename the result to fd.c. As it is, we have a situation when file_table.c is about handling of struct file and file.c is about handling of descriptor tables; the reasons are historical - file_table.c used to be about a static array of struct file we used to have way back). A lot of stray ends got cleaned up and converted to saner primitives, disgusting mess in android/binder.c is still disgusting, but at least doesn't poke so much in descriptor table guts anymore. A bunch of relatively minor races got fixed in process, plus an ext4 struct file leak. - related thing - fget_light() partially unuglified; see fdget() in there (and yes, it generates the code as good as we used to have). - also related - bits of Cyrill's procfs stuff that got entangled into that work; _not_ all of it, just the initial move to fs/proc/fd.c and switch of fdinfo to seq_file. - Alex's fs/coredump.c spiltoff - the same story, had been easier to take that commit than mess with conflicts. The rest is a separate pile, this was just a mechanical code movement. - a few misc patches all over the place. Not all for this cycle, there'll be more (and quite a few currently sit in akpm's tree)." Fix up trivial conflicts in the android binder driver, and some fairly simple conflicts due to two different changes to the sock_alloc_file() interface ("take descriptor handling from sock_alloc_file() to callers" vs "net: Providing protocol type via system.sockprotoname xattr of /proc/PID/fd entries" adding a dentry name to the socket) * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (72 commits) MAX_LFS_FILESIZE should be a loff_t compat: fs: Generic compat_sys_sendfile implementation fs: push rcu_barrier() from deactivate_locked_super() to filesystems btrfs: reada_extent doesn't need kref for refcount coredump: move core dump functionality into its own file coredump: prevent double-free on an error path in core dumper usb/gadget: fix misannotations fcntl: fix misannotations ceph: don't abuse d_delete() on failure exits hypfs: ->d_parent is never NULL or negative vfs: delete surplus inode NULL check switch simple cases of fget_light to fdget new helpers: fdget()/fdput() switch o2hb_region_dev_write() to fget_light() proc_map_files_readdir(): don't bother with grabbing files make get_file() return its argument vhost_set_vring(): turn pollstart/pollstop into bool switch prctl_set_mm_exe_file() to fget_light() switch xfs_find_handle() to fget_light() switch xfs_swapext() to fget_light() ...
2012-09-26unexport sock_map_fd(), switch to sock_alloc_file()Al Viro
Both modular callers of sock_map_fd() had been buggy; sctp one leaks descriptor and file if copy_to_user() fails, 9p one shouldn't be exposing file in the descriptor table at all. Switch both to sock_alloc_file(), export it, unexport sock_map_fd() and make it static. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-09-179P: Fix race in p9_write_work()Simon Derr
See previous commit about p9_read_work() for details. This fixes a similar race between p9_write_work() and p9_poll_mux() Signed-off-by: Simon Derr <simon.derr@bull.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2012-09-179P: fix test at the end of p9_write_work()Simon Derr
At the end of p9_write_work() we want to test if there is still data to send. This means: - either the current request still has data to send (wsize != 0) - or there are requests in the unsent queue Signed-off-by: Simon Derr <simon.derr@bull.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2012-09-179P: Fix race in p9_read_work()Simon Derr
Race scenario between p9_read_work() and p9_poll_mux() Data arrive, Rworksched is set, p9_read_work() is called. thread A thread B p9_read_work() . reads data . checks if new data ready. No. . gets preempted . More data arrive, p9_poll_mux() is called. . . . p9_poll_mux() . . if (!test_and_set_bit(Rworksched, . &m->wsched)) { . schedule_work(&m->rq); . } . . -> does not schedule work because . Rworksched is set . . clear_bit(Rworksched, &m->wsched); return; No work has been scheduled, and yet data are waiting. Currently p9_read_work() checks if there is data to read, and if not, it clears Rworksched. I think it should clear Rworksched first, and then check if there is data to read. Signed-off-by: Simon Derr <simon.derr@bull.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2012-09-06net/9p: Check errno validitySimon Derr
While working on a modified server I had the Linux clients crash a few times. This lead me to find this: Some error codes are directly extracted from the server replies. A malformed server reply could contain an invalid error code, with a very large value. If this value is then passed to ERR_PTR() it will not be properly detected as an error code by IS_ERR() and as a result the kernel will dereference an invalid pointer. This patch tries to avoid this. Signed-off-by: Simon Derr <simon.derr@bull.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2012-08-20workqueue: deprecate flush[_delayed]_work_sync()Tejun Heo
flush[_delayed]_work_sync() are now spurious. Mark them deprecated and convert all users to flush[_delayed]_work(). If you're cc'd and wondering what's going on: Now all workqueues are non-reentrant and the regular flushes guarantee that the work item is not pending or running on any CPU on return, so there's no reason to use the sync flushes at all and they're going away. This patch doesn't make any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Ian Campbell <ian.campbell@citrix.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Mattia Dongili <malattia@linux.it> Cc: Kent Yoder <key@linux.vnet.ibm.com> Cc: David Airlie <airlied@linux.ie> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Karsten Keil <isdn@linux-pingi.de> Cc: Bryan Wu <bryan.wu@canonical.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Alasdair Kergon <agk@redhat.com> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: David Woodhouse <dwmw2@infradead.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: linux-wireless@vger.kernel.org Cc: Anton Vorontsov <cbou@mail.ru> Cc: Sangbeom Kim <sbkim73@samsung.com> Cc: "James E.J. Bottomley" <James.Bottomley@HansenPartnership.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Takashi Iwai <tiwai@suse.de> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Petr Vandrovec <petr@vandrovec.name> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Avi Kivity <avi@redhat.com>
2012-07-10net: Fix (nearly-)kernel-doc comments for various functionsBen Hutchings
Fix incorrect start markers, wrapped summary lines, missing section breaks, incorrect separators, and some name mismatches. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
