path: root/net/802
2008-01-13[TOKENRING]: rif_timer not initialized properlyEric Dumazet
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Move hardware header operations out of netdevice.Stephen Hemminger
Since hardware header operations are part of the protocol class not the device instance, make them into a separate object and save memory. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Wrap netdevice hardware header creation.Stephen Hemminger
Add inline for common usage of hardware header creation, and fix bug in IPV6 mcast where the assumption about negative return is an errno. Negative return from hard_header means not enough space was available,(ie -N bytes). Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make the device list and device lookups per namespace.Eric W. Biederman
This patch makes most of the generic device layer network namespace safe. This patch makes dev_base_head a network namespace variable, and then it picks up a few associated variables. The functions: dev_getbyhwaddr dev_getfirsthwbytype dev_get_by_flags dev_get_by_name __dev_get_by_name dev_get_by_index __dev_get_by_index dev_ioctl dev_ethtool dev_load wireless_process_ioctl were modified to take a network namespace argument, and deal with it. vlan_ioctl_set and brioctl_set were modified so their hooks will receive a network namespace argument. So basically anthing in the core of the network stack that was affected to by the change of dev_base was modified to handle multiple network namespaces. The rest of the network stack was simply modified to explicitly use &init_net the initial network namespace. This can be fixed when those components of the network stack are modified to handle multiple network namespaces. For now the ifindex generator is left global. Fundametally ifindex numbers are per namespace, or else we will have corner case problems with migration when we get that far. At the same time there are assumptions in the network stack that the ifindex of a network device won't change. Making the ifindex number global seems a good compromise until the network stack can cope with ifindex changes when you change namespaces, and the like. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make /proc/net per network namespaceEric W. Biederman
This patch makes /proc/net per network namespace. It modifies the global variables proc_net and proc_net_stat to be per network namespace. The proc_net file helpers are modified to take a network namespace argument, and all of their callers are fixed to pass &init_net for that argument. This ensures that all of the /proc/net files are only visible and usable in the initial network namespace until the code behind them has been updated to be handle multiple network namespaces. Making /proc/net per namespace is necessary as at least some files in /proc/net depend upon the set of network devices which is per network namespace, and even more files in /proc/net have contents that are relevant to a single network namespace. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-08-21[SNAP]: Check packet length before readingHerbert Xu
The snap_rcv code reads 5 bytes so we should make sure that we have 5 bytes in the head before proceeding. Based on diagnosis and fix by Evgeniy Polyakov, reported by Alan J. Wylie. Patch also kills the skb->sk assignment before kfree_skb since it's redundant. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NET]: Make all initialized struct seq_operations const.Philippe De Muyter
Make all initialized struct seq_operations in net/ const Signed-off-by: Philippe De Muyter <phdm@macqel.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: cleanup extra semicolonsStephen Hemminger
Spring cleaning time... There seems to be a lot of places in the network code that have extra bogus semicolons after conditionals. Most commonly is a bogus semicolon after: switch() { } Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: unions of just one member don't get anything done, kill themArnaldo Carvalho de Melo
Renaming skb->h to skb->transport_header, skb->nh to skb->network_header and skb->mac to skb->mac_header, to match the names of the associated helpers (skb[_[re]set]_{transport,network,mac}_header). Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_transport_header(skb)Arnaldo Carvalho de Melo
For the places where we need a pointer to the transport header, it is still legal to touch skb->h.raw directly if just adding to, subtracting from or setting it to another layer header. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_mac_header()Arnaldo Carvalho de Melo
For the places where we need a pointer to the mac header, it is still legal to touch skb->mac.raw directly if just adding to, subtracting from or setting it to another layer header. This one also converts some more cases to skb_reset_mac_header() that my regex missed as it had no spaces before nor after '=', ugh. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_reset_mac_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->mac.raw = skb->data' operation, so that we can later turn skb->mac.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple case, next will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[HIPPI/FDDI]: Make {hippi,fddi}_type_trans set skb->devArnaldo Carvalho de Melo
Now all the _type_trans routines are consistent in this regard. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[TR]: Make tr_type_trans set skb->devArnaldo Carvalho de Melo
2007-04-25[TR]: Use tr_hdr() were appropriateArnaldo Carvalho de Melo
2007-04-25[NET] 802: Use hton{s,l}() where appropriate.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-12[PATCH] mark struct file_operations const 7Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-10[NET] 802: Fix whitespace errors.YOSHIFUJI Hideaki
2006-12-02[NET]: Kill direct includes of asm/checksum.hAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[TR]: endiannness annotationsAl Viro
2006-05-16[TR]: Remove an unused export.Adrian Bunk
This patch removes the unused EXPORT_SYMBOL(tr_source_route). (Note, the usage in net/llc/llc_output.c can't be modular.) Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SNAP]: Remove leftover unused hdr variableArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[NET]: Replace skb_pull/skb_postpull_rcsum with skb_pull_rcsumHerbert Xu
We're now starting to have quite a number of places that do skb_pull followed immediately by an skb_postpull_rcsum. We can merge these two operations into one function with skb_pull_rcsum. This makes sense since most pull operations on receive skb's need to update the checksum. I've decided to make this out-of-line since it is fairly big and the fast path where hardware checksums are enabled need to call csum_partial anyway. Since this is a brand new function we get to add an extra check on the len argument. As it is most callers of skb_pull ignore its return value which essentially means that there is no check on the len argument. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-13[P8023]: Fix tainting of kernel.Dave Jones
Missing license tag. I've assumed this is GPL. (It could also use a MODULE_AUTHOR) Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-02[NET] snap: needs hardware checksum fixStephen Hemminger
The SNAP code pops off it's 5 byte header, but doesn't adjust the checksum. This would cause problems when using device that does IP over SNAP and hardware receive checksums. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-08[PATCH] tiny: Trim non-IPX buildsMatt Mackall
trivial: drop unused 802.3 code if we compile without IPX (originally from http://wohnheim.fh-wedel.de/~joern/software/kernel/je/25/) Signed-off-by: Matt Mackall <mpm@selenic.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Arnaldo Carvalho de Melo <acme@conectiva.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-08[NET]: kfree cleanupJesper Juhl
From: Jesper Juhl <jesper.juhl@gmail.com> This is the net/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in net/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Arnaldo Carvalho de Melo <acme@conectiva.com.br> Acked-by: Marcel Holtmann <marcel@holtmann.org> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Andrew Morton <akpm@osdl.org>
2005-10-25[TR]: Preserve RIF flag even for 2 byte RIF fields.Jochen Friedrich
Signed-off-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-09-22[TR]: Set correct frame type for SNAP packetsJochen Friedrich
2005-09-22[LLC]: Use refcounting with struct llc_sapArnaldo Carvalho de Melo
2005-08-29[NET]: net/802: more endian annotationsAlexey Dobriyan
The rest of endian warnings now belongs to tr.c exclusively. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Fix sparse warningsArnaldo Carvalho de Melo
Of this type, mostly: CHECK net/ipv6/netfilter.c net/ipv6/netfilter.c:96:12: warning: symbol 'ipv6_netfilter_init' was not declared. Should it be static? net/ipv6/netfilter.c:101:6: warning: symbol 'ipv6_netfilter_fini' was not declared. Should it be static? Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Kill skb->real_devDavid S. Miller
Bonding just wants the device before the skb_bond() decapsulation occurs, so simply pass that original device into packet_type->func() as an argument. It remains to be seen whether we can use this same exact thing to get rid of skb->input_dev as well. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Remove HIPPI private from skbuff.hStephen Hemminger
This removes the private element from skbuff, that is only used by HIPPI. Instead it uses skb->cb[] to hold the additional data that is needed in the output path from hard_header to device driver. PS: The only qdisc that might potentially corrupt this cb[] is if netem was used over HIPPI. I will take care of that by fixing netem to use skb->stamp. I don't expect many users of netem over HIPPI Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-18[TOKENRING]: Use interrupt-safe locking with rif_lock.Jay Vosburgh
Change operations on rif_lock from spin_{un}lock_bh to spin_{un}lock_irq{save,restore} equivalents. Some of the rif_lock critical sections are called from interrupt context via tr_type_trans->tr_add_rif_info. The TR NIC drivers call tr_type_trans from their packet receive handlers. Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-12[NET]: __be'ify *_type_trans()Alexey Dobriyan
tr_type_trans(), hippi_type_trans() left as-is. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-26[TOKENRING]: net/802/tr.c: s/struct rif_cache_s/struct rif_cache/Alexey Dobriyan
"_s" suffix is certainly of hungarian origin. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-26[TOKENRING]: be'ify trh_hdr, trllc, rif_cache_sAlexey Dobriyan
2005-05-05[PATCH] update Ross Biro bouncing email addressJesper Juhl
Ross moved. Remove the bad email address so people will find the correct one in ./CREDITS. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
