path: root/net/8021q
2007-10-10[8021Q]: transfer dev_id from real deviceUrsula Braun
A net_device struct provides field dev_id. It is used for unique ipv6 generation in case of shared network cards (as for the OSA network cards of IBM System z). If VLAN devices are built on top of such shared network cards, this dev_id information needs to be transferred to the VLAN device. Signed-off-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Move hardware header operations out of netdevice.Stephen Hemminger
Since hardware header operations are part of the protocol class not the device instance, make them into a separate object and save memory. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Wrap netdevice hardware header creation.Stephen Hemminger
Add inline for common usage of hardware header creation, and fix bug in IPV6 mcast where the assumption about negative return is an errno. Negative return from hard_header means not enough space was available,(ie -N bytes). Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make the device list and device lookups per namespace.Eric W. Biederman
This patch makes most of the generic device layer network namespace safe. This patch makes dev_base_head a network namespace variable, and then it picks up a few associated variables. The functions: dev_getbyhwaddr dev_getfirsthwbytype dev_get_by_flags dev_get_by_name __dev_get_by_name dev_get_by_index __dev_get_by_index dev_ioctl dev_ethtool dev_load wireless_process_ioctl were modified to take a network namespace argument, and deal with it. vlan_ioctl_set and brioctl_set were modified so their hooks will receive a network namespace argument. So basically anthing in the core of the network stack that was affected to by the change of dev_base was modified to handle multiple network namespaces. The rest of the network stack was simply modified to explicitly use &init_net the initial network namespace. This can be fixed when those components of the network stack are modified to handle multiple network namespaces. For now the ifindex generator is left global. Fundametally ifindex numbers are per namespace, or else we will have corner case problems with migration when we get that far. At the same time there are assumptions in the network stack that the ifindex of a network device won't change. Making the ifindex number global seems a good compromise until the network stack can cope with ifindex changes when you change namespaces, and the like. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make device event notification network namespace safeEric W. Biederman
Every user of the network device notifiers is either a protocol stack or a pseudo device. If a protocol stack that does not have support for multiple network namespaces receives an event for a device that is not in the initial network namespace it quite possibly can get confused and do the wrong thing. To avoid problems until all of the protocol stacks are converted this patch modifies all netdev event handlers to ignore events on devices that are not in the initial network namespace. As the rest of the code is made network namespace aware these checks can be removed. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make packet reception network namespace safeEric W. Biederman
This patch modifies every packet receive function registered with dev_add_pack() to drop packets if they are not from the initial network namespace. This should ensure that the various network stacks do not receive packets in a anything but the initial network namespace until the code has been converted and is ready for them. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make /proc/net per network namespaceEric W. Biederman
This patch makes /proc/net per network namespace. It modifies the global variables proc_net and proc_net_stat to be per network namespace. The proc_net file helpers are modified to take a network namespace argument, and all of their callers are fixed to pass &init_net for that argument. This ensures that all of the /proc/net files are only visible and usable in the initial network namespace until the code behind them has been updated to be handle multiple network namespaces. Making /proc/net per namespace is necessary as at least some files in /proc/net depend upon the set of network devices which is per network namespace, and even more files in /proc/net have contents that are relevant to a single network namespace. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-16[VLAN]: Fix net_device leak.Al Viro
In "[VLAN]: Move device registation to seperate function" (commit e89fe42cd03c8fd3686df82d8390a235717a66de), a pile of code got moved to register_vlan_dev(), including grabbing a reference to underlying device. However, original dev_hold() had been left behind, so we leak a reference to net_device now... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-08-26[VLAN/BRIDGE]: Fix "skb_pull_rcsum - Fatal exception in interrupt"Evgeniy Polyakov
I tried to preserve bridging code as it was before, but logic is quite strange - I think we should free skb on error, since it is already unshared and thus will just leak. Herbert Xu states: > + if ((skb = skb_share_check(skb, GFP_ATOMIC)) == NULL) > + goto out; If this happens it'll be a double-free on skb since we'll return NF_DROP which makes the caller free it too. We could return NF_STOLEN to prevent that but I'm not sure whether that's correct netfilter semantics. Patrick, could you please make a call on this? Patrick McHardy states: NF_STOLEN should work fine here. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-08-14[VLAN] net/8021q/vlanproc.c: fix check-after-useAdrian Bunk
The Coverity checker spotted that we'd have already oops'ed if "vlandev" was NULL. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-31[NET]: ethtool ops are the only wayMatthew Wilcox
During the transition to the ethtool_ops way of doing things, we supported calling the device's ->do_ioctl method to allow unconverted drivers to continue working. Those days are long behind us, all in-tree drivers use the ethtool_ops way, and so we no longer need to support this. The bonding driver is the biggest beneficiary of this; it no longer needs to call ioctl() as a fallback if ethtool_ops aren't supported. Also put a proper copyright statement on ethtool.c. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-24[8021Q]: vlan_ioctl_handler: fix return valueAndrew Morton
net/8021q/vlan.c: In function 'vlan_ioctl_handler': net/8021q/vlan.c:700: warning: 'err' may be used uninitialized in this function The warning is incorrect, but from my reading this ioctl will return -EINVAL on success. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-14[VLAN]: Fix memset lengthPatrick McHardy
Fix sizeof(ETH_ALEN) Introduced by my rtnl_link patches. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-14[VLAN]: Use multicast list synchronization helpersPatrick McHardy
2007-07-14[VLAN]: Fix promiscous/allmulti synchronization racesPatrick McHardy
The set_multicast_list function may be called without holding the rtnl mutex, resulting in races when changing the underlying device's promiscous and allmulti state. Use the change_rx_mode hook, which is always invoked under the rtnl. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-11[RTNETLINK]: rtnl_link: allow specifying initial device addressPatrick McHardy
Drivers need to validate the initial addresses in their netlink attribute validation function or manually reject them if they can't support this. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-11[RTNETLINK]: rtnl_link API simplificationPatrick McHardy
All drivers need to unregister their devices in the module unload function. While doing so they must hold the rtnl and atomically unregister the rtnl_link ops as well. This makes the rtnl_link_unregister function that takes the rtnl itself completely useless. Provide default newlink/dellink functions, make __rtnl_link_unregister and rtnl_link_unregister unregister all devices with matching rtnl_link_ops and change the existing users to take advantage of that. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-11[VLAN]: Fix MAC address handlingPatrick McHardy
The VLAN MAC address handling is broken in multiple ways. When the address differs when setting it, the real device is put in promiscous mode twice, but never taken out again. Additionally it doesn't resync when the real device's address is changed and needlessly puts it in promiscous mode when the vlan device is still down. Fix by moving address handling to vlan_dev_open/vlan_dev_stop and properly deal with address changes in the device notifier. Also switch to dev_unicast_add (which needs the exact same handling). Since the set_mac_address handler is identical to the generic ethernet one with these changes, kill it and use ether_setup(). Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NET]: Make all initialized struct seq_operations const.Philippe De Muyter
Make all initialized struct seq_operations in net/ const Signed-off-by: Philippe De Muyter <phdm@macqel.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[VLAN]: Use rtnl_link APIPatrick McHardy
2007-07-10[VLAN]: Introduce symbolic constants for flag valuesPatrick McHardy
2007-07-10[VLAN]: Keep track of number of QoS mappingsPatrick McHardy
Keep track of the number of configured ingress/egress QoS mappings to avoid iteration while calculating the netlink attribute size. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[VLAN]: Use 32 bit value for skb->priority mappingPatrick McHardy
skb->priority has only 32 bits and even VLAN uses 32 bit values in its API. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[VLAN]: Return proper error codes in register_vlan_devicePatrick McHardy
The returned device is unused, return proper error codes instead and avoid having the ioctl handler guess the error. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[VLAN]: Move device registation to seperate functionPatrick McHardy
Move device registration and configuration of the underlying device to a seperate function. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[VLAN]: Split up device checksPatrick McHardy
Move the checks of the underlying device to a seperate function. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[VLAN]: Move vlan_group allocation to seperate functionPatrick McHardy
Move group allocation to a seperate function to clean up the code a bit and allocate groups before registering the device. Device registration is globally visible and causes netlink events, so we shouldn't fail afterwards. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[VLAN]: Move some device intialization code to dev->init callbackPatrick McHardy
Move some device initialization code to new dev->init callback to make it shareable with netlink. Additionally this fixes a minor bug, dev->iflink is set after registration, which causes an incorrect value in the initial netlink message. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[VLAN]: Convert name-based configuration functions to struct netdevice *Patrick McHardy
Move the device lookup and checks to the ioctl handler under the RTNL and change all name-based interfaces to take a struct net_device * instead. This allows to use them from a netlink interface, which identifies devices based on ifindex not name. It also avoids races between the ioctl interface and the (upcoming) netlink interface since now all changes happen under the RTNL. As a nice side effect this greatly simplifies error handling in the helper functions and fixes a number of incorrect error codes like -EINVAL for device not found. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-03[NET]: Fix comparisons of unsigned < 0.Bill Nottingham
Recent gcc versions emit warnings when unsigned variables are compared < 0 or >= 0. Signed-off-by: Bill Nottingham <notting@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-03VLAN: kill_vid is only useful for VLAN filtering devicesStephen Hemminger
The interface for network device VLAN extension was confusing. The kill_vid function is only really useful for devices that do hardware filtering. Devices that only do VLAN receiption without filtering were being forced to provide the hook, and there were bugs in those devices. Many drivers had kill_vid routine that called vlan_group_set_device, with NULL, but that is done already. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-03[NET]: Rework dev_base via list_head (v3)Pavel Emelianov
Cleanup of dev_base list use, with the aim to simplify making device list per-namespace. In almost every occasion, use of dev_base variable and dev->next pointer could be easily replaced by for_each_netdev loop. A few most complicated places were converted to using first_netdev()/next_netdev(). Signed-off-by: Pavel Emelianov <xemul@openvz.org> Acked-by: Kirill Korotaev <dev@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: cleanup extra semicolonsStephen Hemminger
Spring cleaning time... There seems to be a lot of places in the network code that have extra bogus semicolons after conditionals. Most commonly is a bogus semicolon after: switch() { } Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[VLAN] vlan_dev: Use skb_reset_network_header().David S. Miller
2007-04-25[SK_BUFF]: unions of just one member don't get anything done, kill themArnaldo Carvalho de Melo
Renaming skb->h to skb->transport_header, skb->nh to skb->network_header and skb->mac to skb->mac_header, to match the names of the associated helpers (skb[_[re]set]_{transport,network,mac}_header). Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET] 8021Q: Use htons() where appropriate.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-13[VLAN]: Allow VLAN interface on top of bridge interfaceJerome Borsboom
When a VLAN interface is created on top of a bridge interface and netfilter is enabled to see the bridged packets, the packets can be corrupted when passing through the netfilter code. This is caused by the VLAN driver not setting the 'protocol' and 'nh' members of the sk_buff structure. In general, this is no problem as the VLAN interface is mostly connected to a physical ethernet interface which does not use the 'protocol' and 'nh' members. For a bridge interface, however, these members do matter. Signed-off-by: Jerome Borsboom <j.borsboom@erasmusmc.nl> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-02[VLAN]: Avoid a 4-order allocation.Dan Aloni
This patch splits the vlan_group struct into a multi-allocated struct. On x86_64, the size of the original struct is a little more than 32KB, causing a 4-order allocation, which is prune to problems caused by buddy-system external fragmentation conditions. I couldn't just use vmalloc() because vfree() cannot be called in the softirq context of the RCU callback. Signed-off-by: Dan Aloni <da-x@monatomic.org> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-12[PATCH] mark struct file_operations const 7Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-10[NET] 8021Q: Fix whitespace errors.YOSHIFUJI Hideaki
2006-10-10[PATCH] Finish annotations of struct vlan_ethhdrAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-24[VLAN]: Fix link state propagationStefan Rompf
When the queue of the underlying device is stopped at initialization time or the device is marked "not present", the state will be propagated to the vlan device and never change. Based on an analysis by Patrick McHardy. Signed-off-by: Stefan Rompf <stefan@loplof.de> ACKed-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-21[NET]: Conversions from kmalloc+memset to k(z|c)alloc.Panagiotis Issaris
Signed-off-by: Panagiotis Issaris <takis@issaris.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-03[PATCH] lockdep: annotate vlan net device as being a special classArjan van de Ven
vlan network devices have devices nesting below it, and are a special "super class" of normal network devices; split their locks off into a separate class since they always nest. [deweerdt@free.fr: fix possible null-pointer deref] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Frederik Deweerdt <frederik.deweerdt@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-20[NET]: Replace skb_pull/skb_postpull_rcsum with skb_pull_rcsumHerbert Xu
We're now starting to have quite a number of places that do skb_pull followed immediately by an skb_postpull_rcsum. We can merge these two operations into one function with skb_pull_rcsum. This makes sense since most pull operations on receive skb's need to update the checksum. I've decided to make this out-of-line since it is fairly big and the fast path where hardware checksums are enabled need to call csum_partial anyway. Since this is a brand new function we get to add an extra check on the len argument. As it is most callers of skb_pull ignore its return value which essentially means that there is no check on the len argument. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[VLAN]: translate IF_OPER_DORMANT to netif_dormant_on()Stefan Rompf
this patch adds support to the VLAN driver to translate IF_OPER_DORMANT of the underlying device to netif_dormant_on(). Beside clean state forwarding, this allows running independant userspace supplicants on both the real device and the stacked VLAN. It depends on my RFC2863 patch. Signed-off-by: Stefan Rompf <stefan@loplof.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-11[PATCH] capable/capability.h (net/)Randy Dunlap
net: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[NET]: Change memcmp(,,ETH_ALEN) to compare_ether_addr()Kris Katterjohn
This changes some memcmp(one,two,ETH_ALEN) to compare_ether_addr(one,two). Signed-off-by: Kris Katterjohn <kjak@users.sourceforge.net> Signed-off-by: David S. Miller <davem@davemloft.net>
