path: root/net/8021q/vlan.h
2011-12-08vlan: add 802.1q netpoll supportBenjamin LaHaise
Add netpoll support to 802.1q vlan devices. Based on the netpoll support in the bridging code. Tested on a forced_eth device with netconsole. Signed-off-by: Benjamin LaHaise <bcrl@kvack.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-08vlan: introduce vid list with reference countingJiri Pirko
This allows to keep track of vids needed to be in rx vlan filters of devices even if they are used in bond/team etc. vlan_info as well as vlan_group previously was, is allocated when first vid is added and dealocated whan last vid is deleted. vlan_group definition is moved to private header. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-08vlan: rename vlan_dev_info to vlan_dev_privJiri Pirko
As this structure is priv, name it approprietely. Also for pointer to it use name "vlan". Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-21vlan: move vlan_group_[gs]et_device to public headerJiri Pirko
there are no users outside vlan code Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-17net: vlan, qlcnic: make vlan_find_dev privateDavid Lamparter
there is only one user of vlan_find_dev outside of the actual vlan code: qlcnic uses it to iterate over some VLANs it knows. let's just make vlan_find_dev private to the VLAN code and have the iteration in qlcnic be a bit more direct. (a few rcu dereferences less too) Signed-off-by: David Lamparter <equinox@diac24.net> Cc: Patrick McHardy <kaber@trash.net> Cc: Amit Kumar Salecha <amit.salecha@qlogic.com> Cc: Anirban Chakraborty <anirban.chakraborty@qlogic.com> Cc: linux-driver@qlogic.com Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-25net: move is_vlan_dev into public header file (v2)Neil Horman
Migrate is_vlan_dev() to if_vlan.h so that core networkig can use it Signed-off-by: Neil Horman <nhorman@tuxdriver.com> CC: davem@davemloft.net CC: bhutchings@solarflare.com Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-12net: vlan: make non-hw-accel rx path similar to hw-accelJiri Pirko
Now there are 2 paths for rx vlan frames. When rx-vlan-hw-accel is enabled, skb is untagged by NIC, vlan_tci is set and the skb gets into vlan code in __netif_receive_skb - vlan_hwaccel_do_receive. For non-rx-vlan-hw-accel however, tagged skb goes thru whole __netif_receive_skb, it's untagged in ptype_base hander and reinjected This incosistency is fixed by this patch. Vlan untagging happens early in __netif_receive_skb so the rest of code (ptype_all handlers, rx_handlers) see the skb like it was untagged by hw. Signed-off-by: Jiri Pirko <jpirko@redhat.com> v1->v2: remove "inline" from vlan_core.c functions Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-16vlan: lockless transmit pathEric Dumazet
vlan is a stacked device, like tunnels. We should use the lockless mechanism we are using in tunnels and loopback. This patch completely removes locking in TX path. tx stat counters are added into existing percpu stat structure, renamed from vlan_rx_stats to vlan_pcpu_stats. Note : this partially reverts commit 2e59af3dcbdf (vlan: multiqueue vlan device) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-15net: consolidate 8021q taggingJohn Fastabend
Now that VLAN packets are tagged in dev_hard_start_xmit() at the bottom of the stack we no longer need to tag them in the 8021Q module (Except in the !VLAN_FLAG_REORDER_HDR case). This allows the accel path and non accel paths to be consolidated. Here the vlan_tci in the skb is always set and we allow the stack to add the actual tag in dev_hard_start_xmit(). Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Acked-by: Jesse Gross <jesse@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-21vlan: Avoid hash table lookup to find group.Jesse Gross
A struct net_device always maps to zero or one vlan groups and we always know the device when we are looking up a group. We currently do a hash table lookup on the device to find the group but it is much simpler to just store a pointer. Signed-off-by: Jesse Gross <jesse@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-05net: add a core netdev->rx_dropped counterEric Dumazet
In various situations, a device provides a packet to our stack and we drop it before it enters protocol stack : - softnet backlog full (accounted in /proc/net/softnet_stat) - bad vlan tag (not accounted) - unknown/unregistered protocol (not accounted) We can handle a per-device counter of such dropped frames at core level, and automatically adds it to the device provided stats (rx_dropped), so that standard tools can be used (ifconfig, ip link, cat /proc/net/dev) This is a generalization of commit 8990f468a (net: rx_dropped accounting), thus reverting it. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-20net: rx_dropped accountingEric Dumazet
Under load, netif_rx() can drop incoming packets but administrators dont have a chance to spot which device needs some tuning (RPS activation for example) This patch adds rx_dropped accounting in vlans and tunnels. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-28vlan: 64 bit rx countersEric Dumazet
Use u64_stats_sync infrastructure to implement 64bit rx stats. (tx stats are addressed later) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16percpu: add __percpu sparse annotations to netTejun Heo
Add __percpu sparse annotations to net. These annotations are to make sparse consider percpu variables to be in a different address space and warn if accessed without going through percpu accessors. This patch doesn't affect normal builds. The macro and type tricks around snmp stats make things a bit interesting. DEFINE/DECLARE_SNMP_STAT() macros mark the target field as __percpu and SNMP_UPD_PO_STATS() macro is updated accordingly. All snmp_mib_*() users which used to cast the argument to (void **) are updated to cast it to (void __percpu **). Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: Vlad Yasevich <vladislav.yasevich@hp.com> Cc: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-17vlan: Precise RX stats accountingEric Dumazet
With multi queue devices, its possible that several cpus call vlan RX routines simultaneously for the same vlan device. We update RX stats counter without any locking, so we can get slightly wrong counters. One possible fix is to use percpu counters, to get precise accounting and also get guarantee of no cache line ping pongs between cpus. Note: this adds 16 bytes (32 bytes on 64bit arches) of percpu data per vlan device. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-28net: add a list_head parameter to dellink() methodEric Dumazet
Adding a list_head parameter to rtnl_link_ops->dellink() methods allow us to queue devices on a list, in order to dismantle them all at once. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-27vlan: allow null VLAN ID to be usedEric Dumazet
We currently use a 16 bit field (vlan_tci) to store VLAN ID/PRIO on a skb. Null value is used as a special value, meaning vlan tagging not enabled. This forbids use of null vlan ID. As pointed by David, some drivers use the 3 high order bits (PRIO) As VLAN ID is 12 bits, we can use the remaining bit (CFI) as a flag, and allow null VLAN ID. In case future code really wants to use VLAN_CFI_MASK, we'll have to use a bit outside of vlan_tci. #define VLAN_PRIO_MASK 0xe000 /* Priority Code Point */ #define VLAN_PRIO_SHIFT 13 #define VLAN_CFI_MASK 0x1000 /* Canonical Format Indicator */ #define VLAN_TAG_PRESENT VLAN_CFI_MASK #define VLAN_VID_MASK 0x0fff /* VLAN Identifier */ Reported-by: Gertjan Hofman <gertjan_hofman@yahoo.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-28vlan: propogate ethtool speed valuesStephen Hemminger
This enables more ethtool information. The speed and settings of the underlying device are propagated up. This makes services like SNMP that use ethtool to get speed setting, work when managing a vlan, without adding silly heurtistics into SNMP daemon. For the driver info, just use existing driver strings. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08vlan: TCI related type and naming cleanupsPatrick McHardy
The VLAN code contains multiple spots that use tag, id and tci as identifiers for arguments and variables incorrectly and they actually contain or are expected to contain something different. Additionally types are used inconsistently (unsigned short vs u16) and identifiers are sometimes capitalized. - consistently use u16 for storing TCI, ID or QoS values - consistently use vlan_id and vlan_tci for storing the respective values - remove capitalization - add kdoc comment to netif_hwaccel_{rx,receive_skb} Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08vlan: move struct vlan_dev_info to private headerPatrick McHardy
Hide struct vlan_dev_info from drivers to prevent them from growing more creative ways to use it. Provide accessors for the two drivers that currently use it. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08vlan: uninline __vlan_hwaccel_rxPatrick McHardy
The function is huge and included at least once in every VLAN acceleration capable driver. Uninline it; to avoid having drivers depend on the VLAN module, the function is always built in statically when VLAN is enabled. With all VLAN acceleration capable drivers that build on x86_64 enabled, this results in: text data bss dec hex filename 6515227 854044 343968 7713239 75b1d7 vmlinux.inlined 6505637 854044 343968 7703649 758c61 vmlinux.uninlined ---------------------------------------------------------- -9590 Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-05vlan: Add GVRP supportPatrick McHardy
Add GVRP support for dynamically registering VLANs with switches. By default GVRP is disabled because we only support the applicant-only participant model, which means it should not be enabled on vlans that are members of a bridge. Since there is currently no way to cleanly determine that, the user is responsible for enabling it. The code is pretty small and low impact, its wrapped in a config option though because it depends on the GARP implementation and the STP core. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-05vlan: Change vlan_dev_set_vlan_flag() to handle multiple flags at oncePatrick McHardy
Change vlan_dev_set_vlan_flag() to handle multiple flags at once and rename to vlan_dev_change_flags(). This allows to to use it from the netlink interface, which in turn allows to handle necessary adjustments when changing flags centrally. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-16[VLAN]: Make the vlan_name_type per-net.Pavel Emelyanov
This includes moving one on the struct vlan_net and s/vlan_name_type/vn->name_type/ over the code. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-16[VLAN]: Create proc entries in the proper net.Pavel Emelyanov
The proc_vlan_dir and proc_vlan_conf migrate on the struct vlan_net and their creation uses the struct net. The devices' entries use the corresponding device's net. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-16[VLAN]: Introduce the vlan_net structure and init/exit net ops.Pavel Emelyanov
Unlike TUN, it is empty from the very beginning, and will be eventually populated later. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-02[VLAN]: Proc entry is not renamed when vlan device name changes.Pavel Emelyanov
This may lead to situations, when each of two proc entries produce data for the other's device. Looks like a BUG, so this patch is for net-2.6. It will not apply to net-2.6.26 since dev->nd_net access is replaced with dev_net(dev) one. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[VLAN]: checkpatch cleanupsPatrick McHardy
Checkpatch cleanups, consisting mainly of overly long lines and missing spaces. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[VLAN]: Simplify vlan unregistrationPatrick McHardy
Keep track of the number of VLAN devices in a vlan group. This allows to have the caller sense when the group is going to be destroyed and stop using it, which in turn allows to remove the wrapper around unregister_vlan_dev for the NETDEV_UNREGISTER notifier and avoid iterating over all possible VLAN ids whenever a device in unregistered. Also fix what looks like a use-after-free (but is actually safe since we're holding the RTNL), the real_dev reference should not be dropped while we still use it. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[VLAN]: Clean up debugging and printksPatrick McHardy
- use pr_* functions and common prefix for non-device related messages - remove VLAN_ printk levels - kill lots of useless debugging statements - remove a few unnecessary printks like for double VID registration (already returns -EEXIST) and kill of a number of unnecessary checks in vlan_proc_{add,rem}_dev() that are already performed by the caller Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[VLAN]: Move device setup to vlan_dev.cPatrick McHardy
Move device setup to vlan_dev.c and make all the VLAN device methods static. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-10[VLAN]: Allow setting mac address while device is upPatrick McHardy
2007-10-10[NET]: Move hardware header operations out of netdevice.Stephen Hemminger
Since hardware header operations are part of the protocol class not the device instance, make them into a separate object and save memory. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-14[VLAN]: Fix promiscous/allmulti synchronization racesPatrick McHardy
The set_multicast_list function may be called without holding the rtnl mutex, resulting in races when changing the underlying device's promiscous and allmulti state. Use the change_rx_mode hook, which is always invoked under the rtnl. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-11[VLAN]: Fix MAC address handlingPatrick McHardy
The VLAN MAC address handling is broken in multiple ways. When the address differs when setting it, the real device is put in promiscous mode twice, but never taken out again. Additionally it doesn't resync when the real device's address is changed and needlessly puts it in promiscous mode when the vlan device is still down. Fix by moving address handling to vlan_dev_open/vlan_dev_stop and properly deal with address changes in the device notifier. Also switch to dev_unicast_add (which needs the exact same handling). Since the set_mac_address handler is identical to the generic ethernet one with these changes, kill it and use ether_setup(). Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[VLAN]: Use rtnl_link APIPatrick McHardy
2007-07-10[VLAN]: Convert name-based configuration functions to struct netdevice *Patrick McHardy
Move the device lookup and checks to the ioctl handler under the RTNL and change all name-based interfaces to take a struct net_device * instead. This allows to use them from a netlink interface, which identifies devices based on ifindex not name. It also avoids races between the ioctl interface and the (upcoming) netlink interface since now all changes happen under the RTNL. As a nice side effect this greatly simplifies error handling in the helper functions and fixes a number of incorrect error codes like -EINVAL for device not found. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] 8021Q: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Kill skb->real_devDavid S. Miller
Bonding just wants the device before the skb_bond() decapsulation occurs, so simply pass that original device into packet_type->func() as an argument. It remains to be seen whether we can use this same exact thing to get rid of skb->input_dev as well. Signed-off-by: David S. Miller <davem@davemloft.net>
