path: root/net/802/psnap.c
2007-08-21[SNAP]: Check packet length before readingHerbert Xu
The snap_rcv code reads 5 bytes so we should make sure that we have 5 bytes in the head before proceeding. Based on diagnosis and fix by Evgeniy Polyakov, reported by Alan J. Wylie. Patch also kills the skb->sk assignment before kfree_skb since it's redundant. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: unions of just one member don't get anything done, kill themArnaldo Carvalho de Melo
Renaming skb->h to skb->transport_header, skb->nh to skb->network_header and skb->mac to skb->mac_header, to match the names of the associated helpers (skb[_[re]set]_{transport,network,mac}_header). Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_transport_header(skb)Arnaldo Carvalho de Melo
For the places where we need a pointer to the transport header, it is still legal to touch skb->h.raw directly if just adding to, subtracting from or setting it to another layer header. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] 802: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SNAP]: Remove leftover unused hdr variableArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[NET]: Replace skb_pull/skb_postpull_rcsum with skb_pull_rcsumHerbert Xu
We're now starting to have quite a number of places that do skb_pull followed immediately by an skb_postpull_rcsum. We can merge these two operations into one function with skb_pull_rcsum. This makes sense since most pull operations on receive skb's need to update the checksum. I've decided to make this out-of-line since it is fairly big and the fast path where hardware checksums are enabled need to call csum_partial anyway. Since this is a brand new function we get to add an extra check on the len argument. As it is most callers of skb_pull ignore its return value which essentially means that there is no check on the len argument. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-02[NET] snap: needs hardware checksum fixStephen Hemminger
The SNAP code pops off it's 5 byte header, but doesn't adjust the checksum. This would cause problems when using device that does IP over SNAP and hardware receive checksums. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-22[LLC]: Use refcounting with struct llc_sapArnaldo Carvalho de Melo
Signed-off-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-08-29[NET]: Kill skb->real_devDavid S. Miller
Bonding just wants the device before the skb_bond() decapsulation occurs, so simply pass that original device into packet_type->func() as an argument. It remains to be seen whether we can use this same exact thing to get rid of skb->input_dev as well. Signed-off-by: David S. Miller <davem@davemloft.net>
