Remove an extraneous no_printk() in mm/nommu.c that got missed when the
function got generalised from several things that used it in commit
12fdff3fc248 ("Add a dummy printk function for the maintenance of unused
printks").
Without this, the following error is observed:
mm/nommu.c:41: error: conflicting types for 'no_printk'
include/linux/kernel.h:314: error: previous definition of 'no_printk' was here
Reported-by: Michal Simek <monstr@monstr.eu>
.. which didn't show up in my tests because it's a no-op on x86-64 and
most other architectures. But we enter the function with the last-level
page table mapped, and should unmap it at exit.
This is a rather minimally invasive patch to solve the problem of the
user stack growing into a memory mapped area below it. Whenever we fill
the first page of the stack segment, expand the segment down by one
page.
Now, admittedly some odd application might _want_ the stack to grow down
into the preceding memory mapping, and so we may at some point need to
make this a process tunable (some people might also want to have more
than a single page of guarding), but let's try the minimal approach
first.
Tested with trivial application that maps a single page just below the
stack, and then starts recursing. Without this, we will get a SIGSEGV
_after_ the stack has smashed the mapping. With this patch, we'll get a
nice SIGBUS just as the stack touches the page just above the mapping.
Requested-by: Keith Packard <keithp@keithp.com>
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6
* 'hwpoison' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6:
hugetlb: add missing unlock in avoidcopy path in hugetlb_cow()
hwpoison: rename CONFIG
HWPOISON, hugetlb: support hwpoison injection for hugepage
HWPOISON, hugetlb: detect hwpoison in hugetlb code
HWPOISON, hugetlb: isolate corrupted hugepage
HWPOISON, hugetlb: maintain mce_bad_pages in handling hugepage error
HWPOISON, hugetlb: set/clear PG_hwpoison bits on hugepage
HWPOISON, hugetlb: enable error handling path for hugepage
hugetlb, rmap: add reverse mapping for hugepage
hugetlb: move definition of is_vm_hugetlb_page() to hugepage_inline.h
Fix up trivial conflicts in mm/memory-failure.c
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen
* 'stable/xen-swiotlb-0.8.6' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
x86: Detect whether we should use Xen SWIOTLB.
pci-swiotlb-xen: Add glue code to setup dma_ops utilizing xen_swiotlb_* functions.
swiotlb-xen: SWIOTLB library for Xen PV guest with PCI passthrough.
xen/mmu: inhibit vmap aliases rather than trying to clear them out
vmap: add flag to allow lazy unmap to be disabled at runtime
xen: Add xen_create_contiguous_region
xen: Rename the balloon lock
xen: Allow unprivileged Xen domains to create iomap pages
xen: use _PAGE_IOMAP in ioremap to do machine mappings
Fix up trivial conflicts (adding both xen swiotlb and xen pci platform
driver setup close to each other) in drivers/xen/{Kconfig,Makefile} and
include/xen/xen-ops.h
Document global_dirty_limits() and bdi_dirty_limit().
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
Split get_dirty_limits() into global_dirty_limits()+bdi_dirty_limit(), so
that the latter can be avoided when under global dirty background
threshold (which is the normal state for most systems).
Reducing the number of times balance_dirty_pages calls global_page_state
reduces the cache references and so improves write performance on a
variety of workloads.
'perf stats' of simple fio write tests shows the reduction in cache
access. Where the test is fio 'write,mmap,600Mb,pre_read' on AMD AthlonX2
with 3Gb memory (dirty_threshold approx 600 Mb) running each test 10
times, dropping the fasted & slowest values then taking the average &
standard deviation
average (s.d.) in millions (10^6)
2.6.31-rc8 648.6 (14.6)
+patch 620.1 (16.5)
Achieving this reduction is by dropping clip_bdi_dirty_limit as it rereads
the counters to apply the dirty_threshold and moving this check up into
balance_dirty_pages where it has already read the counters.
Also by rearrange the for loop to only contain one copy of the limit tests
allows the pdflush test after the loop to use the local copies of the
counters rather than rereading them.
In the common case with no throttling it now calls global_page_state 5
fewer times and bdi_stat 2 fewer.
Fengguang:
This patch slightly changes behavior by replacing clip_bdi_dirty_limit()
with the explicit check (nr_reclaimable + nr_writeback >= dirty_thresh) to
avoid exceeding the dirty limit. Since the bdi dirty limit is mostly
accurate we don't need to do routinely clip. A simple dirty limit check
would be enough.
The check is necessary because, in principle we should throttle everything
calling balance_dirty_pages() when we're over the total limit, as said by
Peter.
We now set and clear dirty_exceeded not only based on bdi dirty limits,
but also on the global dirty limit. The global limit check is added in
place of clip_bdi_dirty_limit() for safety and not intended as a behavior
change. The bdi limits should be tight enough to keep all dirty pages
under the global limit at most time; occasional small exceeding should be
OK though. The change makes the logic more obvious: the global limit is
the ultimate goal and shall be always imposed.
We may now start background writeback work based on outdated conditions.
That's safe because the bdi flush thread will (and have to) double check
the states. It reduces overall overheads because the test based on old
states still have good chance to be right.
[akpm@linux-foundation.org] fix uninitialized dirty_exceeded
Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk>
Cc: Jan Kara <jack@suse.cz>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Fix a fatal kernel-doc error due to a #define coming between a function's
kernel-doc notation and the function signature. (kernel-doc cannot handle
this)
We have zone_to_nid(). this patch convert all existing users of
zone->zone_pgdat->node_id.
Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Cc: Nishimura Daisuke <d-nishimura@mtf.biglobe.ne.jp>
mem_cgroup_soft_limit_reclaim() has zone, nid and zid argument. but nid
and zid can be calculated from zone. So remove it.
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Acked-by: Mel Gorman <mel@csn.ul.ie>
Cc: Balbir Singh <balbir@in.ibm.com>
Currently mem_cgroup_shrink_node_zone() call shrink_zone() directly. thus
it doesn't need to initialize sc.nodemask because shrink_zone() doesn't
use it at all.
sc.nr_reclaimed and sc.nr_scanned have already been initialized few lines
above "struct scan_control sc = {}" statement.
So, This patch remove this unnecessary code.
Currently, mem_cgroup_shrink_node_zone() initialize sc.nr_to_reclaim as 0.
It mean shrink_zone() only scan 32 pages and immediately return even if
it doesn't reclaim any pages.
This patch fixes it.
Now, memory cgroup increments css(cgroup subsys state)'s reference count
per a charged page. And the reference count is kept until the page is
uncharged. But this has 2 bad effect.
1. Because css_get/put calls atomic_inc()/dec, heavy call of them
on large smp will not scale well.
2. Because css's refcnt cannot be in a state as "ready-to-release",
cgroup's notify_on_release handler can't work with memcg.
3. css's refcnt is atomic_t, it means smaller than 32bit. Maybe too small.
This has been a problem since the 1st merge of memcg.
This is a trial to remove css's refcnt per a page. Even if we remove
refcnt, pre_destroy() does enough synchronization as
- check res->usage == 0.
- check no pages on LRU.
This patch removes css's refcnt per page. Even after this patch, at the
1st look, it seems css_get() is still called in try_charge().
But the logic is.
- If a memcg of mm->owner is cached one, consume_stock() will work.
At success, return immediately.
- If consume_stock returns false, css_get() is called and go to
slow path which may be blocked. At the end of slow path,
css_put() is called and restart from the start if necessary.
So, in the fast path, we don't call css_get() and can avoid access to
shared counter. This patch can make the most possible case fast.
Here is a result of multi-threaded page fault benchmark.
[Before]
25.32% multi-fault-all [kernel.kallsyms] [k] clear_page_c
9.30% multi-fault-all [kernel.kallsyms] [k] _raw_spin_lock_irqsave
8.02% multi-fault-all [kernel.kallsyms] [k] try_get_mem_cgroup_from_mm <=====(*)
7.83% multi-fault-all [kernel.kallsyms] [k] down_read_trylock
5.38% multi-fault-all [kernel.kallsyms] [k] __css_put
5.29% multi-fault-all [kernel.kallsyms] [k] __alloc_pages_nodemask
4.92% multi-fault-all [kernel.kallsyms] [k] _raw_spin_lock_irq
4.24% multi-fault-all [kernel.kallsyms] [k] up_read
3.53% multi-fault-all [kernel.kallsyms] [k] css_put
2.11% multi-fault-all [kernel.kallsyms] [k] handle_mm_fault
1.76% multi-fault-all [kernel.kallsyms] [k] __rmqueue
1.64% multi-fault-all [kernel.kallsyms] [k] __mem_cgroup_commit_charge
[After]
28.41% multi-fault-all [kernel.kallsyms] [k] clear_page_c
10.08% multi-fault-all [kernel.kallsyms] [k] _raw_spin_lock_irq
9.58% multi-fault-all [kernel.kallsyms] [k] down_read_trylock
9.38% multi-fault-all [kernel.kallsyms] [k] _raw_spin_lock_irqsave
5.86% multi-fault-all [kernel.kallsyms] [k] __alloc_pages_nodemask
5.65% multi-fault-all [kernel.kallsyms] [k] up_read
2.82% multi-fault-all [kernel.kallsyms] [k] handle_mm_fault
2.64% multi-fault-all [kernel.kallsyms] [k] mem_cgroup_add_lru_list
2.48% multi-fault-all [kernel.kallsyms] [k] __mem_cgroup_commit_charge
Then, 8.02% of try_get_mem_cgroup_from_mm() disappears because this patch
removes css_tryget() in it. (But yes, this is an extreme case.)
Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
When the OOM killer scans task, it check a task is under memcg or
not when it's called via memcg's context.
But, as Oleg pointed out, a thread group leader may have NULL ->mm
and task_in_mem_cgroup() may do wrong decision. We have to use
find_lock_task_mm() in memcg as generic OOM-Killer does.
Cc: Balbir Singh <balbir@linux.vnet.ibm.com>
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
mem_cgroup_charge_common() is always called with @mem = NULL, so it's
meaningless. This patch removes it.
- try_get_mem_cgroup_from_mm() calls rcu_read_lock/unlock by itself, so we
don't have to call them in task_in_mem_cgroup().
- *mz is not used in __mem_cgroup_uncharge_common().
- we don't have to call lookup_page_cgroup() in mem_cgroup_end_migration()
after we've cleared PCG_MIGRATION of @oldpage.
- remove empty comment.
- remove redundant empty line in mem_cgroup_cache_charge().
Now, for checking a memcg is under task-account-moving, we do css_tryget()
against mc.to and mc.from. But this is just complicating things. This
patch makes the check easier.
This patch adds a spinlock to move_charge_struct and guard modification of
mc.to and mc.from. By this, we don't have to think about complicated
races arount this not-critical path.
[balbir@linux.vnet.ibm.com: don't crash on a null memcg being passed]
Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com>
mem_cgroup_try_charge() has a big loop in it and seems to be hard to read.
Most of routines are for slow path. This patch moves codes out from the
loop and make it clear what's done.
Summary:
- refactoring a function to detect a memcg is under acccount move or not.
- refactoring a function to wait for the end of moving task acct.
- refactoring a main loop('s slow path) as a function and make it clear
why we retry or quit by return code.
- add fatal_signal_pending() check for bypassing charge loops.
This patch fixes possible deadlock in hugepage lock_page()
by adding missing unlock_page().
libhugetlbfs test will hit this bug when the next patch in this
patchset ("hugetlb, HWPOISON: move PG_HWPoison bit check") is applied.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com>
Acked-by: Fengguang Wu <fengguang.wu@intel.com>
CONFIG_HUGETLBFS controls hugetlbfs interface code.
OTOH, CONFIG_HUGETLB_PAGE controls hugepage management code.
So we should use CONFIG_HUGETLB_PAGE here.
This patch enables hwpoison injection through debug/hwpoison interfaces,
with which we can test memory error handling for free or reserved
hugepages (which cannot be tested by madvise() injector).
[AK: Export PageHuge too for the injection module]
This patch enables to block access to hwpoisoned hugepage and
also enables to block unmapping for it.
Dependency:
"HWPOISON, hugetlb: enable error handling path for hugepage"
If error hugepage is not in-use, we can fully recovery from error
by dequeuing it from freelist, so return RECOVERY.
Otherwise whether or not we can recovery depends on user processes,
so return DELAYED.
Dependency:
For now all pages in the error hugepage are considered as hwpoisoned,
so count all of them in mce_bad_pages.
Dependency:
To avoid race condition between concurrent memory errors on identified
hugepage, we atomically test and set PG_hwpoison bit on the head page.
All pages in the error hugepage are considered as hwpoisoned
for now, so set and clear all PG_hwpoison bits in the hugepage
with page lock of the head page held.
Dependency:
This patch just enables handling path. Real containing and
recovering operation will be implemented in following patches.
Dependency:
"hugetlb, rmap: add reverse mapping for hugepage."
This patch adds reverse mapping feature for hugepage by introducing
mapcount for shared/private-mapped hugepage and anon_vma for
private-mapped hugepage.
While hugepage is not currently swappable, reverse mapping can be useful
for memory error handler.
Without this patch, memory error handler cannot identify processes
using the bad hugepage nor unmap it from them. That is:
- for shared hugepage:
we can collect processes using a hugepage through pagecache,
but can not unmap the hugepage because of the lack of mapcount.
- for privately mapped hugepage:
we can neither collect processes nor unmap the hugepage.
This patch solves these problems.
This patch include the bug fix given by commit 23be7468e8, so reverts it.
Dependency:
"hugetlb: move definition of is_vm_hugetlb_page() to hugepage_inline.h"
ChangeLog since May 24.
- create hugetlb_inline.h and move is_vm_hugetlb_index() in it.
- move functions setting up anon_vma for hugepage into mm/rmap.c.
ChangeLog since May 13.
- rebased to 2.6.34
- fix logic error (in case that private mapping and shared mapping coexist)
- move is_vm_hugetlb_page() into include/linux/mm.h to use this function
from linear_page_index()
- define and use linear_hugepage_index() instead of compound_order()
- use page_move_anon_rmap() in hugetlb_cow()
- copy exclusive switch of __set_page_anon_rmap() into hugepage counterpart.
- revert commit 24be7468 completely
Cc: Larry Woodman <lwoodman@redhat.com>
* 'for-2.6.36' of git://git.kernel.dk/linux-2.6-block: (149 commits)
block: make sure that REQ_* types are seen even with CONFIG_BLOCK=n
xen-blkfront: fix missing out label
blkdev: fix blkdev_issue_zeroout return value
block: update request stacking methods to support discards
block: fix missing export of blk_types.h
writeback: fix bad _bh spinlock nesting
drbd: revert "delay probes", feature is being re-implemented differently
drbd: Initialize all members of sync_conf to their defaults [Bugz 315]
drbd: Disable delay probes for the upcomming release
writeback: cleanup bdi_register
writeback: add new tracepoints
writeback: remove unnecessary init_timer call
writeback: optimize periodic bdi thread wakeups
writeback: prevent unnecessary bdi threads wakeups
writeback: move bdi threads exiting logic to the forker thread
writeback: restructure bdi forker loop a little
writeback: move last_active to bdi
writeback: do not remove bdi from bdi_list
writeback: simplify bdi code a little
writeback: do not lose wake-ups in bdi threads
Fixed up pretty trivial conflicts in drivers/block/virtio_blk.c and
drivers/scsi/scsi_error.c as per Jens.
git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-2.6-cm
* 'kmemleak' of git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-2.6-cm:
kmemleak: Fix typo in the comment
lib/scatterlist: Hook sg_kmalloc into kmemleak (v2)
kmemleak: Add DocBook style comments to kmemleak.c
kmemleak: Introduce a default off mode for kmemleak
kmemleak: Show more information for objects found by alias
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (96 commits)
no need for list_for_each_entry_safe()/resetting with superblock list
Fix sget() race with failing mount
vfs: don't hold s_umount over close_bdev_exclusive() call
sysv: do not mark superblock dirty on remount
sysv: do not mark superblock dirty on mount
btrfs: remove junk sb_dirt change
BFS: clean up the superblock usage
AFFS: wait for sb synchronization when needed
AFFS: clean up dirty flag usage
cifs: truncate fallout
mbcache: fix shrinker function return value
mbcache: Remove unused features
add f_flags to struct statfs(64)
pass a struct path to vfs_statfs
update VFS documentation for method changes.
All filesystems that need invalidate_inode_buffers() are doing that explicitly
convert remaining ->clear_inode() to ->evict_inode()
Make ->drop_inode() just return whether inode needs to be dropped
fs/inode.c:clear_inode() is gone
fs/inode.c:evict() doesn't care about delete vs. non-delete paths now
Fix up trivial conflicts in fs/nilfs2/super.c
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc:
powerpc: fix build with make 3.82
Revert "Input: appletouch - fix integer overflow issue"
memblock: Fix memblock_is_region_reserved() to return a boolean
powerpc: Trim defconfigs
powerpc: fix i8042 module build error
sound/soc: mpc5200_psc_ac97: Use gpio pins for cold reset
powerpc/5200: add mpc5200_psc_ac97_gpio_reset
When taking a memory snapshot in hibernate_snapshot(), all (directly
called) memory allocations use GFP_ATOMIC. Hence swap misusage during
hibernation never occurs.
But from a pessimistic point of view, there is no guarantee that no page
allcation has __GFP_WAIT. It is better to have a global indication "we
enter hibernation, don't use swap!".
This patch tries to freeze new-swap-allocation during hibernation. (All
user processes are frozenm so swapin is not a concern).
This way, no updates will happen to swap_map[] between
hibernate_snapshot() and save_image(). Swap is thawed when swsusp_free()
is called. We can be assured that swap corruption will not occur.
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Ondrej Zary <linux@rainbow-software.org>
Since 2.6.31, swap_map[]'s refcounting was changed to show that a used
swap entry is just for swap-cache, can be reused. Then, while scanning
free entry in swap_map[], a swap entry may be able to be reclaimed and
reused. It was caused by commit c9e444103b5e7a5 ("mm: reuse unused swap
entry if necessary").
But this caused deta corruption at resume. The scenario is
- Assume a clean-swap cache, but mapped.
- at hibernation_snapshot[], clean-swap-cache is saved as
clean-swap-cache and swap_map[] is marked as SWAP_HAS_CACHE.
- then, save_image() is called. And reuse SWAP_HAS_CACHE entry to save
image, and break the contents.
After resume:
- the memory reclaim runs and finds clean-not-referenced-swap-cache and
discards it because it's marked as clean. But here, the contents on
disk and swap-cache is inconsistent.
Hance memory is corrupted.
This patch avoids the bug by not reclaiming swap-entry during hibernation.
This is a quick fix for backporting.
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Reported-by: Ondreg Zary <linux@rainbow-software.org>
Tested-by: Ondreg Zary <linux@rainbow-software.org>
Tested-by: Andrea Gelmini <andrea.gelmini@gmail.com>
Cc: <stable@kernel.org>
Use compile-allocated memory instead of dynamic allocated memory for
mm_slots_hash.
Use hash_ptr() instead divisions for bucket calculation.
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Signed-off-by: Izik Eidus <ieidus@redhat.com>
Cc: Avi Kivity <avi@redhat.com>
Fix "system goes unresponsive under memory pressure and lots of
dirty/writeback pages" bug.
http://lkml.org/lkml/2010/4/4/86
In the above thread, Andreas Mohr described that
Invoking any command locked up for minutes (note that I'm
talking about attempted additional I/O to the _other_,
_unaffected_ main system HDD - such as loading some shell
binaries -, NOT the external SSD18M!!).
This happens when the two conditions are both meet:
- under memory pressure
- writing heavily to a slow device
OOM also happens in Andreas' system. The OOM trace shows that 3 processes
are stuck in wait_on_page_writeback() in the direct reclaim path. One in
do_fork() and the other two in unix_stream_sendmsg(). They are blocked on
this condition:
(sc->order && priority < DEF_PRIORITY - 2)
which was introduced in commit 78dc583d (vmscan: low order lumpy reclaim
also should use PAGEOUT_IO_SYNC) one year ago. That condition may be too
permissive. In Andreas' case, 512MB/1024 = 512KB. If the direct reclaim
for the order-1 fork() allocation runs into a range of 512KB
hard-to-reclaim LRU pages, it will be stalled.
It's a severe problem in three ways.
Firstly, it can easily happen in daily desktop usage. vmscan priority can
easily go below (DEF_PRIORITY - 2) on _local_ memory pressure. Even if
the system has 50% globally reclaimable pages, it still has good
opportunity to have 0.1% sized hard-to-reclaim ranges. For example, a
simple dd can easily create a big range (up to 20%) of dirty pages in the
LRU lists. And order-1 to order-3 allocations are more than common with
SLUB. Try "grep -v '1 :' /proc/slabinfo" to get the list of high order
slab caches. For example, the order-1 radix_tree_node slab cache may
stall applications at swap-in time; the order-3 inode cache on most
filesystems may stall applications when trying to read some file; the
order-2 proc_inode_cache may stall applications when trying to open a
/proc file.
Secondly, once triggered, it will stall unrelated processes (not doing IO
at all) in the system. This "one slow USB device stalls the whole system"
avalanching effect is very bad.
Thirdly, once stalled, the stall time could be intolerable long for the
users. When there are 20MB queued writeback pages and USB 1.1 is writing
them in 1MB/s, wait_on_page_writeback() will stuck for up to 20 seconds.
Not to mention it may be called multiple times.
So raise the bar to only enable PAGEOUT_IO_SYNC when priority goes below
DEF_PRIORITY/3, or 6.25% LRU size. As the default dirty throttle ratio is
20%, it will hardly be triggered by pure dirty pages. We'd better treat
PAGEOUT_IO_SYNC as some last resort workaround -- its stall time is so
uncomfortably long (easily goes beyond 1s).
The bar is only raised for (order < PAGE_ALLOC_COSTLY_ORDER) allocations,
which are easy to satisfy in 1TB memory boxes. So, although 6.25% of
memory could be an awful lot of pages to scan on a system with 1TB of
memory, it won't really have to busy scan that much.
Andreas tested an older version of this patch and reported that it mostly
fixed his problem. Mel Gorman helped improve it and KOSAKI Motohiro will
fix it further in the next patch.
Reported-by: Andreas Mohr <andi@lisas.de>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
kmalloc() may fail, if so return -ENOMEM.
Signed-off-by: Kulikov Vasiliy <segooon@gmail.com>
Acked-by: Pekka Enberg <penberg@cs.helsinki.fi>
Memcg also need to trace page isolation information as global reclaim.
This patch does it.
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Memcg also need to trace reclaim progress as direct reclaim. This patch
add it.
Presently shrink_slab() has the following scanning equation.
lru_scanned max_pass
basic_scan_objects = 4 x ------------- x -----------------------------
lru_pages shrinker->seeks (default:2)
scan_objects = min(basic_scan_objects, max_pass * 2)
If we pass very small value as lru_pages instead real number of lru pages,
shrink_slab() drop much objects rather than necessary. And now,
__zone_reclaim() pass 'order' as lru_pages by mistake. That produces a
bad result.
For example, if we receive very low memory pressure (scan = 32, order =
0), shrink_slab() via zone_reclaim() always drop _all_ icache/dcache
objects. (see above equation, very small lru_pages make very big
scan_objects result).
[akpm@linux-foundation.org: fix layout, typos]
Acked-by: Christoph Lameter <cl@linux-foundation.org>
It is not appropriate for apply_to_page_range() to directly call any mmu
notifiers, because it is a general purpose function whose effect depends
on what context it is called in and what the callback function does.
In particular, if it is being used as part of an mmu notifier
implementation, the recursive calls can be particularly problematic.
It is up to apply_to_page_range's caller to do any notifier calls if
necessary. It does not affect any in-tree users because they all operate
on init_mm, and mmu notifiers only pertain to usermode mappings.
[stefano.stabellini@eu.citrix.com: remove unused local `start']
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Cc: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Cc: Avi Kivity <avi@qumranet.com>
Rik van Riel pointed out reading reclaim_stat should be protected
lru_lock, otherwise vmscan might sweep 2x much pages.
This fault was introduced by
commit 4f98a2fee8acdb4ac84545df98cccecfd130f8db
Author: Rik van Riel <riel@redhat.com>
Date: Sat Oct 18 20:26:32 2008 -0700
vmscan: split LRU lists into anon & file sets
'slab_reclaimable' and 'nr_pages' are unsigned. Subtraction is unsafe
because negative results would be misinterpreted.
Set the flag if do_swap_page is decowing the page the same way do_wp_page
would too.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
On swapin it is fairly common for a page to be owned exclusively by one
process. In that case we want to add the page to the anon_vma of that
process's VMA, instead of to the root anon_vma.
This will reduce the amount of rmap searching that the swapout code needs
to do.
Signed-off-by: Rik van Riel <riel@redhat.com>
This a complete rewrite of the oom killer's badness() heuristic which is
used to determine which task to kill in oom conditions. The goal is to
make it as simple and predictable as possible so the results are better
understood and we end up killing the task which will lead to the most
memory freeing while still respecting the fine-tuning from userspace.
Instead of basing the heuristic on mm->total_vm for each task, the task's
rss and swap space is used instead. This is a better indication of the
amount of memory that will be freeable if the oom killed task is chosen
and subsequently exits. This helps specifically in cases where KDE or
GNOME is chosen for oom kill on desktop systems instead of a memory
hogging task.
The baseline for the heuristic is a proportion of memory that each task is
currently using in memory plus swap compared to the amount of "allowable"
memory. "Allowable," in this sense, means the system-wide resources for
unconstrained oom conditions, the set of mempolicy nodes, the mems
attached to current's cpuset, or a memory controller's limit. The
proportion is given on a scale of 0 (never kill) to 1000 (always kill),
roughly meaning that if a task has a badness() score of 500 that the task
consumes approximately 50% of allowable memory resident in RAM or in swap
space.
The proportion is always relative to the amount of "allowable" memory and
not the total amount of RAM systemwide so that mempolicies and cpusets may
operate in isolation; they shall not need to know the true size of the
machine on which they are running if they are bound to a specific set of
nodes or mems, respectively.
Root tasks are given 3% extra memory just like __vm_enough_memory()
provides in LSMs. In the event of two tasks consuming similar amounts of
memory, it is generally better to save root's task.
Because of the change in the badness() heuristic's baseline, it is also
necessary to introduce a new user interface to tune it. It's not possible
to redefine the meaning of /proc/pid/oom_adj with a new scale since the
ABI cannot be changed for backward compatability. Instead, a new tunable,
/proc/pid/oom_score_adj, is added that ranges from -1000 to +1000. It may
be used to polarize the heuristic such that certain tasks are never
considered for oom kill while others may always be considered. The value
is added directly into the badness() score so a value of -500, for
example, means to discount 50% of its memory consumption in comparison to
other tasks either on the system, bound to the mempolicy, in the cpuset,
or sharing the same memory controller.
/proc/pid/oom_adj is changed so that its meaning is rescaled into the
units used by /proc/pid/oom_score_adj, and vice versa. Changing one of
these per-task tunables will rescale the value of the other to an
equivalent meaning. Although /proc/pid/oom_adj was originally defined as
a bitshift on the badness score, it now shares the same linear growth as
/proc/pid/oom_score_adj but with different granularity. This is required
so the ABI is not broken with userspace applications and allows oom_adj to
be deprecated for future removal.
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Nick Piggin <npiggin@suse.de>
Oleg pointed out current PF_EXITING check is wrong. Because PF_EXITING
is per-thread flag, not per-process flag. He said,
Two threads, group-leader L and its sub-thread T. T dumps the code.
In this case both threads have ->mm != NULL, L has PF_EXITING.
The first problem is, select_bad_process() always return -1 in this
case (even if the caller is T, this doesn't matter).
The second problem is that we should add TIF_MEMDIE to T, not L.
I think we can remove this dubious PF_EXITING check. but as first step,
This patch add the protection of multi threaded issue.
Cc: Minchan Kim <minchan.kim@gmail.com>
In a system under heavy load it was observed that even after the
oom-killer selects a task to die, the task may take a long time to die.
Right after sending a SIGKILL to the task selected by the oom-killer this
task has its priority increased so that it can exit() soon, freeing
memory. That is accomplished by:
* We give our sacrificial lamb high priority and access to
* all the memory it needs. That way it should be able to
* exit() and clear out its resources quickly...
p->rt.time_slice = HZ;
set_tsk_thread_flag(p, TIF_MEMDIE);
It sounds plausible giving the dying task an even higher priority to be
sure it will be scheduled sooner and free the desired memory. It was
suggested on LKML using SCHED_FIFO:1, the lowest RT priority so that this
task won't interfere with any running RT task.
If the dying task is already an RT task, leave it untouched. Another good
suggestion, implemented here, was to avoid boosting the dying task
priority in case of mem_cgroup OOM.
Signed-off-by: Luis Claudio R. Goncalves <lclaudio@uudg.org>
The current "child->mm == p->mm" check prevents selection of vfork()ed
task. But we don't have any reason to don't consider vfork().
Removed.
