The list_lru infrastructure already keeps per-node LRU lists in its
node-specific list_lru_node arrays and provide us with a per-node API, and
the shrinkers are properly equiped with node information. This means that
we can now focus our shrinking effort in a single node, but the work that
is deferred from one run to another is kept global at nr_in_batch. Work
can be deferred, for instance, during direct reclaim under a GFP_NOFS
allocation, where situation, all the filesystem shrinkers will be
prevented from running and accumulate in nr_in_batch the amount of work
they should have done, but could not.
This creates an impedance problem, where upon node pressure, work deferred
will accumulate and end up being flushed in other nodes. The problem we
describe is particularly harmful in big machines, where many nodes can
accumulate at the same time, all adding to the global counter nr_in_batch.
As we accumulate more and more, we start to ask for the caches to flush
even bigger numbers. The result is that the caches are depleted and do
not stabilize. To achieve stable steady state behavior, we need to tackle
it differently.
In this patch we keep the deferred count per-node, in the new array
nr_deferred[] (the name is also a bit more descriptive) and will never
accumulate that to other nodes.
Signed-off-by: Glauber Costa <glommer@openvz.org>
Cc: Dave Chinner <dchinner@redhat.com>
Cc: "Theodore Ts'o" <tytso@mit.edu>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
Cc: Arve Hjønnevåg <arve@android.com>
Cc: Carlos Maiolino <cmaiolino@redhat.com>
Cc: Chuck Lever <chuck.lever@oracle.com>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Gleb Natapov <gleb@redhat.com>
Cc: J. Bruce Fields <bfields@redhat.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Jerome Glisse <jglisse@redhat.com>
Cc: John Stultz <john.stultz@linaro.org>
Cc: Kent Overstreet <koverstreet@google.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Thomas Hellstrom <thellstrom@vmware.com>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
Pass the node of the current zone being reclaimed to shrink_slab(),
allowing the shrinker control nodemask to be set appropriately for node
aware shrinkers.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
The list_lru implementation has one function, list_lru_dispose_all, with
only one user (the dentry code). At first, such function appears to make
sense because we are really not interested in the result of isolating each
dentry separately - all of them are going away anyway. However, it's
implementation is buggy in the following way:
When we call list_lru_dispose_all in fs/dcache.c, we scan all dentries
marking them with DCACHE_SHRINK_LIST. However, this is done without the
nlru->lock taken. The imediate result of that is that someone else may
add or remove the dentry from the LRU at the same time. When list_lru_del
happens in that scenario we will see an element that is not yet marked
with DCACHE_SHRINK_LIST (even though it will be in the future) and
obviously remove it from an lru where the element no longer is. Since
list_lru_dispose_all will in effect count down nlru's nr_items and
list_lru_del will do the same, this will lead to an imbalance.
The solution for this would not be so simple: we can obviously just keep
the lru_lock taken, but then we have no guarantees that we will be able to
acquire the dentry lock (dentry->d_lock). To properly solve this, we need
a communication mechanism between the lru and dentry code, so they can
coordinate this with each other.
Such mechanism already exists in the form of the list_lru_walk_cb
callback. So it is possible to construct a dcache-side prune function
that does the right thing only by calling list_lru_walk in a loop until no
more dentries are available.
With only one user, plus the fact that a sane solution for the problem
would involve boucing between dcache and list_lru anyway, I see little
justification to keep the special case list_lru_dispose_all in tree.
Acked-by: Dave Chinner <dchinner@redhat.com>
This patch adapts the list_lru API to accept an optional node argument, to
be used by NUMA aware shrinking functions. Code that does not care about
the NUMA placement of objects can still call into the very same functions
as before. They will simply iterate over all nodes.
The LRU_RETRY code assumes that the list traversal status after we have
dropped and regained the list lock. Unfortunately, this is not a valid
assumption, and that can lead to racing traversals isolating objects that
the other traversal expects to be the next item on the list.
This is causing problems with the inode cache shrinker isolation, with
races resulting in an inode on a dispose list being "isolated" because a
racing traversal still thinks it is on the LRU. The inode is then never
reclaimed and that causes hangs if a subsequent lookup on that inode
occurs.
Fix it by always restarting the list walk on a LRU_RETRY return from the
isolate callback. Avoid the possibility of livelocks the current code was
trying to avoid by always decrementing the nr_to_walk counter on retries
so that even if we keep hitting the same item on the list we'll eventually
stop trying to walk and exit out of the situation causing the problem.
Reported-by: Michal Hocko <mhocko@suse.cz>
Cc: Glauber Costa <glommer@gmail.com>
Now that we have an LRU list API, we can start to enhance the
implementation. This splits the single LRU list into per-node lists and
locks to enhance scalability. Items are placed on lists according to the
node the memory belongs to. To make scanning the lists efficient, also
track whether the per-node lists have entries in them in a active
nodemask.
Note: We use a fixed-size array for the node LRU, this struct can be very
big if MAX_NUMNODES is big. If this becomes a problem this is fixable by
turning this into a pointer and dynamically allocating this to
nr_node_ids. This quantity is firwmare-provided, and still would provide
room for all nodes at the cost of a pointer lookup and an extra
allocation. Because that allocation will most likely come from a may very
well fail.
[glommer@openvz.org: fix warnings, added note about node lru]
Reviewed-by: Greg Thelen <gthelen@google.com>
Several subsystems use the same construct for LRU lists - a list head, a
spin lock and and item count. They also use exactly the same code for
adding and removing items from the LRU. Create a generic type for these
LRU lists.
This is the beginning of generic, node aware LRUs for shrinkers to work
with.
[glommer@openvz.org: enum defined constants for lru. Suggested by gthelen, don't relock over retry]
The current shrinker callout API uses an a single shrinker call for
multiple functions. To determine the function, a special magical value is
passed in a parameter to change the behaviour. This complicates the
implementation and return value specification for the different
behaviours.
Separate the two different behaviours into separate operations, one to
return a count of freeable objects in the cache, and another to scan a
certain number of objects in the cache for freeing. In defining these new
operations, ensure the return values and resultant behaviours are clearly
defined and documented.
Modify shrink_slab() to use the new API and implement the callouts for all
the existing shrinkers.
Signed-off-by: Glauber Costa <glommer@parallels.com>
Pull trivial tree from Jiri Kosina:
"The usual trivial updates all over the tree -- mostly typo fixes and
documentation updates"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (52 commits)
doc: Documentation/cputopology.txt fix typo
treewide: Convert retrun typos to return
Fix comment typo for init_cma_reserved_pageblock
Documentation/trace: Correcting and extending tracepoint documentation
mm/hotplug: fix a typo in Documentation/memory-hotplug.txt
power: Documentation: Update s2ram link
doc: fix a typo in Documentation/00-INDEX
Documentation/printk-formats.txt: No casts needed for u64/s64
doc: Fix typo "is is" in Documentations
treewide: Fix printks with 0x%#
zram: doc fixes
Documentation/kmemcheck: update kmemcheck documentation
doc: documentation/hwspinlock.txt fix typo
PM / Hibernate: add section for resume options
doc: filesystems : Fix typo in Documentations/filesystems
scsi/megaraid fixed several typos in comments
ppc: init_32: Fix error typo "CONFIG_START_KERNEL"
treewide: Add __GFP_NOWARN to k.alloc calls with v.alloc fallbacks
page_isolation: Fix a comment typo in test_pages_isolated()
doc: fix a typo about irq affinity
Pull vfs pile 1 from Al Viro:
"Unfortunately, this merge window it'll have a be a lot of small piles -
my fault, actually, for not keeping #for-next in anything that would
resemble a sane shape ;-/
This pile: assorted fixes (the first 3 are -stable fodder, IMO) and
cleanups + %pd/%pD formats (dentry/file pathname, up to 4 last
components) + several long-standing patches from various folks.
There definitely will be a lot more (starting with Miklos'
check_submount_and_drop() series)"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (26 commits)
direct-io: Handle O_(D)SYNC AIO
direct-io: Implement generic deferred AIO completions
add formats for dentry/file pathnames
kvm eventfd: switch to fdget
powerpc kvm: use fdget
switch fchmod() to fdget
switch epoll_ctl() to fdget
switch copy_module_from_fd() to fdget
git simplify nilfs check for busy subtree
ibmasmfs: don't bother passing superblock when not needed
don't pass superblock to hypfs_{mkdir,create*}
don't pass superblock to hypfs_diag_create_files
don't pass superblock to hypfs_vm_create_files()
oprofile: get rid of pointless forward declarations of struct super_block
oprofilefs_create_...() do not need superblock argument
oprofilefs_mkdir() doesn't need superblock argument
don't bother with passing superblock to oprofile_create_stats_files()
oprofile: don't bother with passing superblock to ->create_files()
don't bother passing sb to oprofile_create_files()
coh901318: don't open-code simple_read_from_buffer()
Pull KVM updates from Gleb Natapov:
"The highlights of the release are nested EPT and pv-ticketlocks
support (hypervisor part, guest part, which is most of the code, goes
through tip tree). Apart of that there are many fixes for all arches"
Fix up semantic conflicts as discussed in the pull request thread..
* 'next' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (88 commits)
ARM: KVM: Add newlines to panic strings
ARM: KVM: Work around older compiler bug
ARM: KVM: Simplify tracepoint text
ARM: KVM: Fix kvm_set_pte assignment
ARM: KVM: vgic: Bump VGIC_NR_IRQS to 256
ARM: KVM: Bugfix: vgic_bytemap_get_reg per cpu regs
ARM: KVM: vgic: fix GICD_ICFGRn access
ARM: KVM: vgic: simplify vgic_get_target_reg
KVM: MMU: remove unused parameter
KVM: PPC: Book3S PR: Rework kvmppc_mmu_book3s_64_xlate()
KVM: PPC: Book3S PR: Make instruction fetch fallback work for system calls
KVM: PPC: Book3S PR: Don't corrupt guest state when kernel uses VMX
KVM: x86: update masterclock when kvmclock_offset is calculated (v2)
KVM: PPC: Book3S: Fix compile error in XICS emulation
KVM: PPC: Book3S PR: return appropriate error when allocation fails
arch: powerpc: kvm: add signed type cast for comparation
KVM: x86: add comments where MMIO does not return to the emulator
KVM: vmx: count exits to userspace during invalid guest emulation
KVM: rename __kvm_io_bus_sort_cmp to kvm_io_bus_cmp
kvm: optimize away THP checks in kvm_is_mmio_pfn()
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull PTR_RET() removal patches from Rusty Russell:
"PTR_RET() is a weird name, and led to some confusing usage. We ended
up with PTR_ERR_OR_ZERO(), and replacing or fixing all the usages.
This has been sitting in linux-next for a whole cycle"
[ There are still some PTR_RET users scattered about, with some of them
possibly being new, but most of them existing in Rusty's tree too. We
have that
#define PTR_RET(p) PTR_ERR_OR_ZERO(p)
thing in <linux/err.h>, so they continue to work for now - Linus ]
* tag 'PTR_RET-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
GFS2: Replace PTR_RET with PTR_ERR_OR_ZERO
Btrfs: volume: Replace PTR_RET with PTR_ERR_OR_ZERO
drm/cma: Replace PTR_RET with PTR_ERR_OR_ZERO
sh_veu: Replace PTR_RET with PTR_ERR_OR_ZERO
dma-buf: Replace PTR_RET with PTR_ERR_OR_ZERO
drivers/rtc: Replace PTR_RET with PTR_ERR_OR_ZERO
mm/oom_kill: remove weird use of ERR_PTR()/PTR_ERR().
staging/zcache: don't use PTR_RET().
remoteproc: don't use PTR_RET().
pinctrl: don't use PTR_RET().
acpi: Replace weird use of PTR_RET.
s390: Replace weird use of PTR_RET.
PTR_RET is now PTR_ERR_OR_ZERO(): Replace most.
Pull x86 RAS changes from Ingo Molnar:
"[ The reason for drivers/ updates is that Boris asked for the
drivers/edac/ changes to go via x86/ras in this cycle ]
Main changes:
- AMD CPUs:
. Add ECC event decoding support for new F15h models
. Various erratum fixes
. Fix single-channel on dual-channel-controllers bug.
- Intel CPUs:
. UC uncorrectable memory error parsing fix
. Add support for CMC (Corrected Machine Check) 'FF' (Firmware
First) flag in the APEI HEST
- Various cleanups and fixes"
* 'x86-ras-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
amd64_edac: Fix incorrect wraparounds
amd64_edac: Correct erratum 505 range
cpc925_edac: Use proper array termination
x86/mce, acpi/apei: Only disable banks listed in HEST if mce is configured
amd64_edac: Get rid of boot_cpu_data accesses
amd64_edac: Add ECC decoding support for newer F15h models
x86, amd_nb: Clarify F15h, model 30h GART and L3 support
pci_ids: Add PCI device ID functions 3 and 4 for newer F15h models.
x38_edac: Make a local function static
i3200_edac: Make a local function static
x86/mce: Pay no attention to 'F' bit in MCACOD when parsing 'UC' errors
APEI/ERST: Fix error message formatting
amd64_edac: Fix single-channel setups
EDAC: Replace strict_strtol() with kstrtol()
mce: acpi/apei: Soft-offline a page on firmware GHES notification
mce: acpi/apei: Add a boot option to disable ff mode for corrected errors
mce: acpi/apei: Honour Firmware First for MCA banks listed in APEI HEST CMC
Call generic_write_sync() from the deferred I/O completion handler if
O_DSYNC is set for a write request. Also make sure various callers
don't call generic_write_sync if the direct I/O code returns
-EIOCBQUEUED.
Based on an earlier patch from Jan Kara <jack@suse.cz> with updates from
Jeff Moyer <jmoyer@redhat.com> and Darrick J. Wong <darrick.wong@oracle.com>.
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull cgroup updates from Tejun Heo:
"A lot of activities on the cgroup front. Most changes aren't visible
to userland at all at this point and are laying foundation for the
planned unified hierarchy.
- The biggest change is decoupling the lifetime management of css
(cgroup_subsys_state) from that of cgroup's. Because controllers
(cpu, memory, block and so on) will need to be dynamically enabled
and disabled, css which is the association point between a cgroup
and a controller may come and go dynamically across the lifetime of
a cgroup. Till now, css's were created when the associated cgroup
was created and stayed till the cgroup got destroyed.
Assumptions around this tight coupling permeated through cgroup
core and controllers. These assumptions are gradually removed,
which consists bulk of patches, and css destruction path is
completely decoupled from cgroup destruction path. Note that
decoupling of creation path is relatively easy on top of these
changes and the patchset is pending for the next window.
- cgroup has its own event mechanism cgroup.event_control, which is
only used by memcg. It is overly complex trying to achieve high
flexibility whose benefits seem dubious at best. Going forward,
new events will simply generate file modified event and the
existing mechanism is being made specific to memcg. This pull
request contains prepatory patches for such change.
- Various fixes and cleanups"
Fixed up conflict in kernel/cgroup.c as per Tejun.
* 'for-3.12' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (69 commits)
cgroup: fix cgroup_css() invocation in css_from_id()
cgroup: make cgroup_write_event_control() use css_from_dir() instead of __d_cgrp()
cgroup: make cgroup_event hold onto cgroup_subsys_state instead of cgroup
cgroup: implement CFTYPE_NO_PREFIX
cgroup: make cgroup_css() take cgroup_subsys * instead and allow NULL subsys
cgroup: rename cgroup_css_from_dir() to css_from_dir() and update its syntax
cgroup: fix cgroup_write_event_control()
cgroup: fix subsystem file accesses on the root cgroup
cgroup: change cgroup_from_id() to css_from_id()
cgroup: use css_get() in cgroup_create() to check CSS_ROOT
cpuset: remove an unncessary forward declaration
cgroup: RCU protect each cgroup_subsys_state release
cgroup: move subsys file removal to kill_css()
cgroup: factor out kill_css()
cgroup: decouple cgroup_subsys_state destruction from cgroup destruction
cgroup: replace cgroup->css_kill_cnt with ->nr_css
cgroup: bounce cgroup_subsys_state ref kill confirmation to a work item
cgroup: move cgroup->subsys[] assignment to online_css()
cgroup: reorganize css init / exit paths
cgroup: add __rcu modifier to cgroup->subsys[]
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core patches from Greg KH:
"Here's the big driver core pull request for 3.12-rc1.
Lots of tiny changes here fixing up the way sysfs attributes are
created, to try to make drivers simpler, and fix a whole class race
conditions with creations of device attributes after the device was
announced to userspace.
All the various pieces are acked by the different subsystem
maintainers"
* tag 'driver-core-3.12-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (119 commits)
firmware loader: fix pending_fw_head list corruption
drivers/base/memory.c: introduce help macro to_memory_block
dynamic debug: line queries failing due to uninitialized local variable
sysfs: sysfs_create_groups returns a value.
debugfs: provide debugfs_create_x64() when disabled
rbd: convert bus code to use bus_groups
firmware: dcdbas: use binary attribute groups
sysfs: add sysfs_create/remove_groups for when SYSFS is not enabled
driver core: add #include <linux/sysfs.h> to core files.
HID: convert bus code to use dev_groups
Input: serio: convert bus code to use drv_groups
Input: gameport: convert bus code to use drv_groups
driver core: firmware: use __ATTR_RW()
driver core: core: use DEVICE_ATTR_RO
driver core: bus: use DRIVER_ATTR_WO()
driver core: create write-only attribute macros for devices and drivers
sysfs: create __ATTR_WO()
driver-core: platform: convert bus code to use dev_groups
workqueue: convert bus code to use dev_groups
MEI: convert bus code to use dev_groups
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc patches from Greg KH:
"Here is the big char/misc driver pull request for 3.12-rc1
Lots of driver updates all over the char/misc tree, full details in
the shortlog"
* tag 'char-misc-3.12-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (62 commits)
drivers: uio: Kconfig: add MMU dependancy for UIO
drivers: uio: Add driver for Humusoft MF624 DAQ PCI card
drivers: uio_pdrv_genirq: use dev_get_platdata()
drivers: uio_pruss: use dev_get_platdata()
drivers: uio_dmem_genirq: use dev_get_platdata()
drivers: parport: Kconfig: exclude h8300 for PARPORT_PC
drivers: misc: ti-st: fix potential race if st_kim_start fails
Drivers: hv: vmbus: Do not attempt to negoatiate a new version prematurely
misc: vmw_balloon: Remove braces to fix build for clang.
Drivers: hv: vmbus: Fix a bug in the handling of channel offers
vme: vme_ca91cx42.c: fix to pass correct device identity to free_irq()
VMCI: Add support for virtual IOMMU
VMCI: Remove non-blocking/pinned queuepair support
uio: uio_pruss: remove unnecessary platform_set_drvdata()
parport: amiga: remove unnecessary platform_set_drvdata()
vme: vme_vmivme7805.c: add missing __iomem annotation
vme: vme_ca91cx42.c: add missing __iomem annotation
vme: vme_tsi148.c: add missing __iomem annotation
drivers/misc/hpilo: Correct panic when an AUX iLO is detected
uio: drop unused vma_count member in uio_device struct
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull first batch of s390 updates from Martin Schwidefsky:
"The most interesting change is that Martin converted s390 to generic
hardirqs. Which means that all current architectures have been
converted and that CONFIG_GENERIC_HARDIRQS can be removed. Martin
prepared a patch for that already (see genirq branch), but the best
time to merge that is probably at the end of the merge window / begin
of -rc1.
Another patch converts s390 to software referenced bits instead of
relying on the reference bit in the storage key. Therefore s390
doesn't use storage keys anymore, except for kvm.
Besides that we have improvements, cleanups and fixes in PCI, DASD and
all over the place."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (32 commits)
s390/pci: use virtual memory for iommu bitmap
s390/cio: fix unlocked access of global bitmap
s390/pci: update function handle after resume from hibernate
s390/pci: try harder to modify a function
s390/pci: split lpf
s390/hibernate: add early resume function
s390/pci: add recover sysfs knob
s390/pci: use claim_resource
s390/pci/hotplug: convert to be builtin only
s390/mm: implement software referenced bits
s390/dasd: fix statistics for recovered requests
s390/tx: allow program interruption filtering in user space
s390/pgtable: fix mprotect for single-threaded KVM guests
s390/time: return with irqs disabled from psw_idle
s390/kprobes: add support for compare and branch instructions
s390/switch_to: fix save_access_regs() / restore_access_regs()
s390/bitops: fix inline assembly constraints
s390/dasd: enable raw_track_access reads without direct I/O
s390/mm: introduce ptep_flush_lazy helper
s390/time: clock comparator revalidation
The last remaining use for the storage key of the s390 architecture
is reference counting. The alternative is to make page table entries
invalid while they are old. On access the fault handler marks the
pte/pmd as young which makes the pte/pmd valid if the access rights
allow read access. The pte/pmd invalidations required for software
managed reference bits cost a bit of performance, on the other hand
the RRBE/RRBM instructions to read and reset the referenced bits are
quite expensive as well.
Reviewed-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
If the system had a few memory groups and all of them were destroyed,
memcg_limited_groups_array_size has non-zero value, but all new caches
are created without memcg_params, because memcg_kmem_enabled() returns
false.
We try to enumirate child caches in a few places and all of them are
potentially dangerous.
For example my kernel is compiled with CONFIG_SLAB and it crashed when I
tryed to mount a NFS share after a few experiments with kmemcg.
BUG: unable to handle kernel NULL pointer dereference at 0000000000000008
IP: [<ffffffff8118166a>] do_tune_cpucache+0x8a/0xd0
PGD b942a067 PUD b999f067 PMD 0
Oops: 0000 [#1] SMP
Modules linked in: fscache(+) ip6table_filter ip6_tables iptable_filter ip_tables i2c_piix4 pcspkr virtio_net virtio_balloon i2c_core floppy
CPU: 0 PID: 357 Comm: modprobe Not tainted 3.11.0-rc7+ #59
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
task: ffff8800b9f98240 ti: ffff8800ba32e000 task.ti: ffff8800ba32e000
RIP: 0010:[<ffffffff8118166a>] [<ffffffff8118166a>] do_tune_cpucache+0x8a/0xd0
RSP: 0018:ffff8800ba32fb70 EFLAGS: 00010246
RAX: 0000000000000000 RBX: 0000000000000000 RCX: 0000000000000006
RDX: 0000000000000000 RSI: ffff8800b9f98910 RDI: 0000000000000246
RBP: ffff8800ba32fba0 R08: 0000000000000002 R09: 0000000000000004
R10: 0000000000000001 R11: 0000000000000001 R12: 0000000000000010
R13: 0000000000000008 R14: 00000000000000d0 R15: ffff8800375d0200
FS: 00007f55f1378740(0000) GS:ffff8800bfa00000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 00007f24feba57a0 CR3: 0000000037b51000 CR4: 00000000000006f0
Call Trace:
enable_cpucache+0x49/0x100
setup_cpu_cache+0x215/0x280
__kmem_cache_create+0x2fa/0x450
kmem_cache_create_memcg+0x214/0x350
kmem_cache_create+0x2b/0x30
fscache_init+0x19b/0x230 [fscache]
do_one_initcall+0xfa/0x1b0
load_module+0x1c41/0x26d0
SyS_finit_module+0x86/0xb0
system_call_fastpath+0x16/0x1b
Signed-off-by: Andrey Vagin <avagin@openvz.org>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Christoph Lameter <cl@linux.com>
Cc: Glauber Costa <glommer@openvz.org>
Cc: Joonsoo Kim <js1304@gmail.com>
Cc: <stable@vger.kernel.org>
mm/Kconfig
CMA DMA split and ZSWAP introduction were conflicting, fix up manually.
Dave reported corrupted swap entries
| [ 4588.541886] swap_free: Unused swap offset entry 00002d15
| [ 4588.541952] BUG: Bad page map in process trinity-kid12 pte:005a2a80 pmd:22c01f067
and Hugh pointed that in move_ptes _PAGE_SOFT_DIRTY bit set regardless
the type of entry pte consists of. The trick here is that when we carry
soft dirty status in swap entries we are to use _PAGE_SWP_SOFT_DIRTY
instead, because this is the only place in pte which can be used for own
needs without intersecting with bits owned by swap entry type/offset.
Reported-and-tested-by: Dave Jones <davej@redhat.com>
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Pavel Emelyanov <xemul@parallels.com>
Analyzed-by: Hugh Dickins <hughd@google.com>
Cc: Hillf Danton <dhillf@gmail.com>
It seems the "it's" should be "its" here.
Signed-off-by: Li Zhong <zhong@linux.vnet.ibm.com>
Using 0x%# emits 0x0x. Only one is necessary.
Acked-by: Takashi Iwai <tiwai@suse.de>
Pull vfs fixes from Al Viro:
"Assorted fixes from the last week or so"
VFS: collect_mounts() should return an ERR_PTR
bfs: iget_locked() doesn't return an ERR_PTR
efs: iget_locked() doesn't return an ERR_PTR()
proc: kill the extra proc_readfd_common()->dir_emit_dots()
cope with potentially long ->d_dname() output for shmem/hugetlb
dynamic_dname() is both too much and too little for those - the
output may be well in excess of 64 bytes dynamic_dname() assumes
to be enough (thanks to ashmem feeding really long names to
shmem_file_setup()) and vsnprintf() is an overkill for those
guys.
The swapaccount kernel parameter without any values has been removed by
commit a2c8990aed5a ("memsw: remove noswapaccount kernel parameter") but
it seems that we didn't get rid of all the left overs.
Make sure that menuconfig help text and kernel-parameters.txt are clear
about value for the paramter and remove the stalled comment which is not
very much useful on its own.
Reported-by: Gergely Risko <gergely@risko.hu>
pageblock_nr_page should be pageblock_nr_pages, and fist is
a typo of first.
Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com>
The dev_attrs field of struct class is going away soon, dev_groups
should be used instead. This converts the backing device class code to
use the correct field.
Cc: Tejun Heo <tj@kernel.org>
We want these fixes in this tree.
Ben Tebulin reported:
"Since v3.7.2 on two independent machines a very specific Git
repository fails in 9/10 cases on git-fsck due to an SHA1/memory
failures. This only occurs on a very specific repository and can be
reproduced stably on two independent laptops. Git mailing list ran
out of ideas and for me this looks like some very exotic kernel issue"
and bisected the failure to the backport of commit 53a59fc67f97 ("mm:
limit mmu_gather batching to fix soft lockups on !CONFIG_PREEMPT").
That commit itself is not actually buggy, but what it does is to make it
much more likely to hit the partial TLB invalidation case, since it
introduces a new case in tlb_next_batch() that previously only ever
happened when running out of memory.
The real bug is that the TLB gather virtual memory range setup is subtly
buggered. It was introduced in commit 597e1c3580b7 ("mm/mmu_gather:
enable tlb flush range in generic mmu_gather"), and the range handling
was already fixed at least once in commit e6c495a96ce0 ("mm: fix the TLB
range flushed when __tlb_remove_page() runs out of slots"), but that fix
was not complete.
The problem with the TLB gather virtual address range is that it isn't
set up by the initial tlb_gather_mmu() initialization (which didn't get
the TLB range information), but it is set up ad-hoc later by the
functions that actually flush the TLB. And so any such case that forgot
to update the TLB range entries would potentially miss TLB invalidates.
Rather than try to figure out exactly which particular ad-hoc range
setup was missing (I personally suspect it's the hugetlb case in
zap_huge_pmd(), which didn't have the same logic as zap_pte_range()
did), this patch just gets rid of the problem at the source: make the
TLB range information available to tlb_gather_mmu(), and initialize it
when initializing all the other tlb gather fields.
This makes the patch larger, but conceptually much simpler. And the end
result is much more understandable; even if you want to play games with
partial ranges when invalidating the TLB contents in chunks, now the
range information is always there, and anybody who doesn't want to
bother with it won't introduce subtle bugs.
Ben verified that this fixes his problem.
Reported-bisected-and-tested-by: Ben Tebulin <tebulin@googlemail.com>
Build-testing-by: Stephen Rothwell <sfr@canb.auug.org.au>
Build-testing-by: Richard Weinberger <richard.weinberger@gmail.com>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Acked-by: Peter Zijlstra <peterz@infradead.org>
Cc: stable@vger.kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp into x86/ras
Pull AMD F15h, model 0x30 and later enablement stuff, more specifically EDAC
support, from Borislav Petkov.
Andy reported that if file page get reclaimed we lose the soft-dirty bit
if it was there, so save _PAGE_BIT_SOFT_DIRTY bit when page address get
encoded into pte entry. Thus when #pf happens on such non-present pte
we can restore it back.
Reported-by: Andy Lutomirski <luto@amacapital.net>
Acked-by: Pavel Emelyanov <xemul@parallels.com>
Cc: Matt Mackall <mpm@selenic.com>
Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com>
Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com>
Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com>
Andy Lutomirski reported that if a page with _PAGE_SOFT_DIRTY bit set
get swapped out, the bit is getting lost and no longer available when
pte read back.
To resolve this we introduce _PTE_SWP_SOFT_DIRTY bit which is saved in
pte entry for the page being swapped out. When such page is to be read
back from a swap cache we check for bit presence and if it's there we
clear it and restore the former _PAGE_SOFT_DIRTY bit back.
One of the problem was to find a place in pte entry where we can save
the _PTE_SWP_SOFT_DIRTY bit while page is in swap. The _PAGE_PSE was
chosen for that, it doesn't intersect with swap entry format stored in
pte.
Reviewed-by: Minchan Kim <minchan@kernel.org>
Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com>
struct memcg_cache_params has a union. Different parts of this union
are used for root and non-root caches. A part with destroying work is
used only for non-root caches.
I fixed the same problem in another place v3.9-rc1-16204-gf101a94, but
didn't notice this one.
This patch fixes the kernel panic:
[ 46.848187] BUG: unable to handle kernel paging request at 000000fffffffeb8
[ 46.849026] IP: [<ffffffff811a484c>] kmem_cache_destroy_memcg_children+0x6c/0xc0
[ 46.849092] PGD 0
[ 46.849092] Oops: 0000 [#1] SMP
Acked-by: Michal Hocko <mhocko@suse.cz>
Cc: Balbir Singh <bsingharora@gmail.com>
Cc: Konstantin Khlebnikov <khlebnikov@openvz.org>
Cc: <stable@vger.kernel.org> [3.9.x]
In the next commit this function will be used in the uio subsystem
git://git.kernel.org/pub/scm/linux/kernel/git/ras/ras into x86/ras
Pull MCE-uncorrected-error fix from Tony Luck:
"Bit 12 may or may not be set in MCi_STATUS.MCACOD when
an uncorrected error is reported. Ignore it when checking
error signatures."
Pursue a single RAS/MCE topic branch on x86.
the iteration
Previously, all css descendant iterators didn't include the origin
(root of subtree) css in the iteration. The reasons were maintaining
consistency with css_for_each_child() and that at the time of
introduction more use cases needed skipping the origin anyway;
however, given that css_is_descendant() considers self to be a
descendant, omitting the origin css has become more confusing and
looking at the accumulated use cases rather clearly indicates that
including origin would result in simpler code overall.
While this is a change which can easily lead to subtle bugs, cgroup
API including the iterators has recently gone through major
restructuring and no out-of-tree changes will be applicable without
adjustments making this a relatively acceptable opportunity for this
type of change.
The conversions are mostly straight-forward. If the iteration block
had explicit origin handling before or after, it's moved inside the
iteration. If not, if (pos == origin) continue; is added. Some
conversions add extra reference get/put around origin handling by
consolidating origin handling and the rest. While the extra ref
operations aren't strictly necessary, this shouldn't cause any
noticeable difference.
Acked-by: Li Zefan <lizefan@huawei.com>
Acked-by: Vivek Goyal <vgoyal@redhat.com>
Acked-by: Aristeu Rozanski <aris@redhat.com>
Cc: Matt Helsley <matthltc@us.ibm.com>
instead of cgroup
cgroup is in the process of converting to css (cgroup_subsys_state)
from cgroup as the principal subsystem interface handle. This is
mostly to prepare for the unified hierarchy support where css's will
be created and destroyed dynamically but also helps cleaning up
subsystem implementations as css is usually what they are interested
in anyway.
cftype->[un]register_event() is among the remaining couple interfaces
which still use struct cgroup. Convert it to cgroup_subsys_state.
The conversion is mostly mechanical and removes the last users of
mem_cgroup_from_cont() and cg_to_vmpressure(), which are removed.
v2: indentation update as suggested by Li Zefan.
in anyway.
This patch converts task iterators to deal with css instead of cgroup.
Note that under unified hierarchy, different sets of tasks will be
considered belonging to a given cgroup depending on the subsystem in
question and making the iterators deal with css instead cgroup
provides them with enough information about the iteration.
While at it, fix several function comment formats in cpuset.c.
This patch doesn't introduce any behavior differences.
Currently all cgroup_task_iter functions require @cgrp to be passed
in, which is superflous and increases chance of usage error. Make
cgroup_task_iter remember the cgroup being iterated and drop @cgrp
argument from next and end functions.
cgroup now has multiple iterators and it's quite confusing to have
something which walks over tasks of a single cgroup named cgroup_iter.
Let's rename it to cgroup_task_iter.
While at it, reformat / update comments and replace the overview
comment above the interface function decls with proper function
comments. Such overview can be useful but function comments should be
more than enough here.
This is pure rename and doesn't introduce any functional changes.
cgroup is currently in the process of transitioning to using css
(cgroup_subsys_state) as the primary handle instead of cgroup in
subsystem API. For hierarchy iterators, this is beneficial because
* In most cases, css is the only thing subsystems care about anyway.
* On the planned unified hierarchy, iterations for different
subsystems will need to skip over different subtrees of the
hierarchy depending on which subsystems are enabled on each cgroup.
Passing around css makes it unnecessary to explicitly specify the
subsystem in question as css is intersection between cgroup and
subsystem
* For the planned unified hierarchy, css's would need to be created
and destroyed dynamically independent from cgroup hierarchy. Having
cgroup core manage css iteration makes enforcing deref rules a lot
easier.
Most subsystem conversions are straight-forward. Noteworthy changes
are
* blkio: cgroup_to_blkcg() is no longer used. Removed.
* freezer: cgroup_freezer() is no longer used. Removed.
* devices: cgroup_to_devcgroup() is no longer used. Removed.
cgroup is currently in the process of transitioning to using struct
cgroup_subsys_state * as the primary handle instead of struct cgroup.
Please see the previous commit which converts the subsystem methods
for rationale.
This patch converts all cftype file operations to take @css instead of
@cgroup. cftypes for the cgroup core files don't have their subsytem
pointer set. These will automatically use the dummy_css added by the
previous patch and can be converted the same way.
Most subsystem conversions are straight forwards but there are some
interesting ones.
* freezer: update_if_frozen() is also converted to take @css instead
of @cgroup for consistency. This will make the code look simpler
too once iterators are converted to use css.
* memory/vmpressure: mem_cgroup_from_css() needs to be exported to
vmpressure while mem_cgroup_from_cont() can be made static.
Updated accordingly.
* cpu: cgroup_tg() doesn't have any user left. Removed.
* cpuacct: cgroup_ca() doesn't have any user left. Removed.
* hugetlb: hugetlb_cgroup_form_cgroup() doesn't have any user left.
Removed.
* net_cls: cgrp_cls_state() doesn't have any user left. Removed.
Acked-by: Daniel Wagner <daniel.wagner@bmw-carit.de>
cgroup_subsys_state * as the primary handle instead of struct cgroup *
in subsystem implementations for the following reasons.
* With unified hierarchy, subsystems will be dynamically bound and
unbound from cgroups and thus css's (cgroup_subsys_state) may be
created and destroyed dynamically over the lifetime of a cgroup,
which is different from the current state where all css's are
allocated and destroyed together with the associated cgroup. This
in turn means that cgroup_css() should be synchronized and may
return NULL, making it more cumbersome to use.
* Differing levels of per-subsystem granularity in the unified
hierarchy means that the task and descendant iterators should behave
differently depending on the specific subsystem the iteration is
being performed for.
* In majority of the cases, subsystems only care about its part in the
cgroup hierarchy - ie. the hierarchy of css's. Subsystem methods
often obtain the matching css pointer from the cgroup and don't
bother with the cgroup pointer itself. Passing around css fits
much better.
This patch converts all cgroup_subsys methods to take @css instead of
@cgroup. The conversions are mostly straight-forward. A few
noteworthy changes are
* ->css_alloc() now takes css of the parent cgroup rather than the
pointer to the new cgroup as the css for the new cgroup doesn't
exist yet. Knowing the parent css is enough for all the existing
subsystems.
* In kernel/cgroup.c::offline_css(), unnecessary open coded css
dereference is replaced with local variable access.
This patch shouldn't cause any behavior differences.
v2: Unnecessary explicit cgrp->subsys[] deref in css_online() replaced
with local variable @css as suggested by Li Zefan.
Rebased on top of new for-3.12 which includes for-3.11-fixes so
that ->css_free() invocation added by da0a12caff ("cgroup: fix a
leak when percpu_ref_init() fails") is converted too. Suggested
by Li Zefan.
Currently, controllers have to explicitly follow the cgroup hierarchy
to find the parent of a given css. cgroup is moving towards using
cgroup_subsys_state as the main controller interface construct, so
let's provide a way to climb the hierarchy using just csses.
This patch implements css_parent() which, given a css, returns its
parent. The function is guarnateed to valid non-NULL parent css as
long as the target css is not at the top of the hierarchy.
freezer, cpuset, cpu, cpuacct, hugetlb, memory, net_cls and devices
are converted to use css_parent() instead of accessing cgroup->parent
directly.
* __parent_ca() is dropped from cpuacct and its usage is replaced with
parent_ca(). The only difference between the two was NULL test on
cgroup->parent which is now embedded in css_parent() making the
distinction moot. Note that eventually a css->parent field will be
added to css and the NULL check in css_parent() will go away.
css (cgroup_subsys_state) is usually embedded in a subsys specific
data structure. Subsystems either use container_of() directly to cast
from css to such data structure or has an accessor function wrapping
such cast. As cgroup as whole is moving towards using css as the main
interface handle, add and update such accessors to ease dealing with
css's.
All accessors explicitly handle NULL input and return NULL in those
cases. While this looks like an extra branch in the code, as all
controllers specific data structures have css as the first field, the
casting doesn't involve any offsetting and the compiler can trivially
optimize out the branch.
* blkio, freezer, cpuset, cpu, cpuacct and net_cls didn't have such
accessor. Added.
* memory, hugetlb and devices already had one but didn't explicitly
handle NULL input. Updated.
cgroup controller API will be converted to primarily use struct
cgroup_subsys_state instead of struct cgroup. In preparation, make
hugetlb_cgroup functions pass around struct hugetlb_cgroup instead of
struct cgroup.
Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
