path: root/mm
2012-06-01take security_mmap_file() outside of ->mmap_semAl Viro
2012-05-31split ->file_mmap() into ->mmap_addr()/->mmap_file()Al Viro
... i.e. file-dependent and address-dependent checks. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-30unexport do_mmap()Al Viro
2012-05-30merge do_mremap() into sys_mremap()Al Viro
2012-05-30fs: move file_remove_suid() to fs/inode.cCong Wang
file_remove_suid() is a generic function operates on struct file, it almost has no relations with file mapping, so move it to fs/inode.c. Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-29->encode_fh() API changeAl Viro
pass inode + parent's inode or NULL instead of dentry + bool saying whether we want the parent or not. NOTE: that needs ceph fix folded in. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-28Merge tag 'writeback' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linuxLinus Torvalds
Pull writeback tree from Wu Fengguang: "Mainly from Jan Kara to avoid iput() in the flusher threads." * tag 'writeback' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux: writeback: Avoid iput() from flusher thread vfs: Rename end_writeback() to clear_inode() vfs: Move waiting for inode writeback from end_writeback() to evict_inode() writeback: Refactor writeback_single_inode() writeback: Remove wb->list_lock from writeback_single_inode() writeback: Separate inode requeueing after writeback writeback: Move I_DIRTY_PAGES handling writeback: Move requeueing when I_SYNC set to writeback_sb_inodes() writeback: Move clearing of I_SYNC into inode_sync_complete() writeback: initialize global_dirty_limit fs: remove 8 bytes of padding from struct writeback_control on 64 bit builds mm: page-writeback.c: local functions should not be exposed globally
2012-05-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
Pull tile updates from Chris Metcalf: "These changes cover a range of new arch/tile features and optimizations. They've been through LKML review and on linux-next for a month or so. There's also one bug-fix that just missed 3.4, which I've marked for stable." Fixed up trivial conflict in arch/tile/Kconfig (new added tile Kconfig entries clashing with the generic timer/clockevents changes). * git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: tile: default to tilegx_defconfig for ARCH=tile tile: fix bug where fls(0) was not returning 0 arch/tile: mark TILEGX as not EXPERIMENTAL tile/mm/fault.c: Port OOM changes to handle_page_fault arch/tile: add descriptive text if the kernel reports a bad trap arch/tile: allow querying cpu module information from the hypervisor arch/tile: fix hardwall for tilegx and generalize for idn and ipi arch/tile: support multiple huge page sizes dynamically mm: add new arch_make_huge_pte() method for tile support arch/tile: support kexec() for tilegx arch/tile: support <asm/cachectl.h> header for cacheflush() syscall arch/tile: Allow tilegx to build with either 16K or 64K page size arch/tile: optimize get_user/put_user and friends arch/tile: support building big-endian kernel arch/tile: allow building Linux with transparent huge pages enabled arch/tile: use interrupt critical sections less
2012-05-25mm: add new arch_make_huge_pte() method for tile supportChris Metcalf
The tile support for multiple-size huge pages requires tagging the hugetlb PTE with a "super" bit for PTEs that are multiples of the basic size of a pagetable span. To set that bit properly we need to tweak the PTe in make_huge_pte() based on the vma. This change provides the API for a subsequent tile-specific change to use. Reviewed-by: Hillf Danton <dhillf@gmail.com> Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2012-05-25arch/tile: allow building Linux with transparent huge pages enabledChris Metcalf
The change adds some infrastructure for managing tile pmd's more generally, using pte_pmd() and pmd_pte() methods to translate pmd values to and from ptes, since on TILEPro a pmd is really just a nested structure holding a pgd (aka pte). Several existing pmd methods are moved into this framework, and a whole raft of additional pmd accessors are defined that are used by the transparent hugepage framework. The tile PTE now has a "client2" bit. The bit is used to indicate a transparent huge page is in the process of being split into subpages. This change also fixes a generic bug where the return value of the generic pmdp_splitting_flush() was incorrect. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2012-05-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.linaro.org/people/mszyprowski/linux-dma-mapping Pull CMA and ARM DMA-mapping updates from Marek Szyprowski: "These patches contain two major updates for DMA mapping subsystem (mainly for ARM architecture). First one is Contiguous Memory Allocator (CMA) which makes it possible for device drivers to allocate big contiguous chunks of memory after the system has booted. The main difference from the similar frameworks is the fact that CMA allows to transparently reuse the memory region reserved for the big chunk allocation as a system memory, so no memory is wasted when no big chunk is allocated. Once the alloc request is issued, the framework migrates system pages to create space for the required big chunk of physically contiguous memory. For more information one can refer to nice LWN articles: - 'A reworked contiguous memory allocator': http://lwn.net/Articles/447405/ - 'CMA and ARM': http://lwn.net/Articles/450286/ - 'A deep dive into CMA': http://lwn.net/Articles/486301/ - and the following thread with the patches and links to all previous versions: https://lkml.org/lkml/2012/4/3/204 The main client for this new framework is ARM DMA-mapping subsystem. The second part provides a complete redesign in ARM DMA-mapping subsystem. The core implementation has been changed to use common struct dma_map_ops based infrastructure with the recent updates for new dma attributes merged in v3.4-rc2. This allows to use more than one implementation of dma-mapping calls and change/select them on the struct device basis. The first client of this new infractructure is dmabounce implementation which has been completely cut out of the core, common code. The last patch of this redesign update introduces a new, experimental implementation of dma-mapping calls on top of generic IOMMU framework. This lets ARM sub-platform to transparently use IOMMU for DMA-mapping calls if one provides required IOMMU hardware. For more information please refer to the following thread: http://www.spinics.net/lists/arm-kernel/msg175729.html The last patch merges changes from both updates and provides a resolution for the conflicts which cannot be avoided when patches have been applied on the same files (mainly arch/arm/mm/dma-mapping.c)." Acked by Andrew Morton <akpm@linux-foundation.org>: "Yup, this one please. It's had much work, plenty of review and I think even Russell is happy with it." * 'for-linus' of git://git.linaro.org/people/mszyprowski/linux-dma-mapping: (28 commits) ARM: dma-mapping: use PMD size for section unmap cma: fix migration mode ARM: integrate CMA with DMA-mapping subsystem X86: integrate CMA with DMA-mapping subsystem drivers: add Contiguous Memory Allocator mm: trigger page reclaim in alloc_contig_range() to stabilise watermarks mm: extract reclaim code from __alloc_pages_direct_reclaim() mm: Serialize access to min_free_kbytes mm: page_isolation: MIGRATE_CMA isolation functions added mm: mmzone: MIGRATE_CMA migration type added mm: page_alloc: change fallbacks array handling mm: page_alloc: introduce alloc_contig_range() mm: compaction: export some of the functions mm: compaction: introduce isolate_freepages_range() mm: compaction: introduce map_pages() mm: compaction: introduce isolate_migratepages_range() mm: page_alloc: remove trailing whitespace ARM: dma-mapping: add support for IOMMU mapper ARM: dma-mapping: use alloc, mmap, free from dma_ops ARM: dma-mapping: remove redundant code and do the cleanup ... Conflicts: arch/x86/include/asm/dma-mapping.h
2012-05-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull more networking updates from David Miller: "Ok, everything from here on out will be bug fixes." 1) One final sync of wireless and bluetooth stuff from John Linville. These changes have all been in his tree for more than a week, and therefore have had the necessary -next exposure. John was just away on a trip and didn't have a change to send the pull request until a day or two ago. 2) Put back some defines in user exposed header file areas that were removed during the tokenring purge. From Stephen Hemminger and Paul Gortmaker. 3) A bug fix for UDP hash table allocation got lost in the pile due to one of those "you got it.. no I've got it.." situations. :-) From Tim Bird. 4) SKB coalescing in TCP needs to have stricter checks, otherwise we'll try to coalesce overlapping frags and crash. Fix from Eric Dumazet. 5) RCU routing table lookups can race with free_fib_info(), causing crashes when we deref the device pointers in the route. Fix by releasing the net device in the RCU callback. From Yanmin Zhang. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (293 commits) tcp: take care of overlaps in tcp_try_coalesce() ipv4: fix the rcu race between free_fib_info and ip_route_output_slow mm: add a low limit to alloc_large_system_hash ipx: restore token ring define to include/linux/ipx.h if: restore token ring ARP type to header xen: do not disable netfront in dom0 phy/micrel: Fix ID of KSZ9021 mISDN: Add X-Tensions USB ISDN TA XC-525 gianfar:don't add FCB length to hard_header_len Bluetooth: Report proper error number in disconnection Bluetooth: Create flags for bt_sk() Bluetooth: report the right security level in getsockopt Bluetooth: Lock the L2CAP channel when sending Bluetooth: Restore locking semantics when looking up L2CAP channels Bluetooth: Fix a redundant and problematic incoming MTU check Bluetooth: Add support for Foxconn/Hon Hai AR5BBU22 0489:E03C Bluetooth: Fix EIR data generation for mgmt_device_found Bluetooth: Fix Inquiry with RSSI event mask Bluetooth: improve readability of l2cap_seq_list code Bluetooth: Fix skb length calculation ...
2012-05-24Merge branch 'perf-uprobes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull user-space probe instrumentation from Ingo Molnar: "The uprobes code originates from SystemTap and has been used for years in Fedora and RHEL kernels. This version is much rewritten, reviews from PeterZ, Oleg and myself shaped the end result. This tree includes uprobes support in 'perf probe' - but SystemTap (and other tools) can take advantage of user probe points as well. Sample usage of uprobes via perf, for example to profile malloc() calls without modifying user-space binaries. First boot a new kernel with CONFIG_UPROBE_EVENT=y enabled. If you don't know which function you want to probe you can pick one from 'perf top' or can get a list all functions that can be probed within libc (binaries can be specified as well): $ perf probe -F -x /lib/libc.so.6 To probe libc's malloc(): $ perf probe -x /lib64/libc.so.6 malloc Added new event: probe_libc:malloc (on 0x7eac0) You can now use it in all perf tools, such as: perf record -e probe_libc:malloc -aR sleep 1 Make use of it to create a call graph (as the flat profile is going to look very boring): $ perf record -e probe_libc:malloc -gR make [ perf record: Woken up 173 times to write data ] [ perf record: Captured and wrote 44.190 MB perf.data (~1930712 $ perf report | less 32.03% git libc-2.15.so [.] malloc | --- malloc 29.49% cc1 libc-2.15.so [.] malloc | --- malloc | |--0.95%-- 0x208eb1000000000 | |--0.63%-- htab_traverse_noresize 11.04% as libc-2.15.so [.] malloc | --- malloc | 7.15% ld libc-2.15.so [.] malloc | --- malloc | 5.07% sh libc-2.15.so [.] malloc | --- malloc | 4.99% python-config libc-2.15.so [.] malloc | --- malloc | 4.54% make libc-2.15.so [.] malloc | --- malloc | |--7.34%-- glob | | | |--93.18%-- 0x41588f | | | --6.82%-- glob | 0x41588f ... Or: $ perf report -g flat | less # Overhead Command Shared Object Symbol # ........ ............. ............. .......... # 32.03% git libc-2.15.so [.] malloc 27.19% malloc 29.49% cc1 libc-2.15.so [.] malloc 24.77% malloc 11.04% as libc-2.15.so [.] malloc 11.02% malloc 7.15% ld libc-2.15.so [.] malloc 6.57% malloc ... The core uprobes design is fairly straightforward: uprobes probe points register themselves at (inode:offset) addresses of libraries/binaries, after which all existing (or new) vmas that map that address will have a software breakpoint injected at that address. vmas are COW-ed to preserve original content. The probe points are kept in an rbtree. If user-space executes the probed inode:offset instruction address then an event is generated which can be recovered from the regular perf event channels and mmap-ed ring-buffer. Multiple probes at the same address are supported, they create a dynamic callback list of event consumers. The basic model is further complicated by the XOL speedup: the original instruction that is probed is copied (in an architecture specific fashion) and executed out of line when the probe triggers. The XOL area is a single vma per process, with a fixed number of entries (which limits probe execution parallelism). The API: uprobes are installed/removed via /sys/kernel/debug/tracing/uprobe_events, the API is integrated to align with the kprobes interface as much as possible, but is separate to it. Injecting a probe point is privileged operation, which can be relaxed by setting perf_paranoid to -1. You can use multiple probes as well and mix them with kprobes and regular PMU events or tracepoints, when instrumenting a task." Fix up trivial conflicts in mm/memory.c due to previous cleanup of unmap_single_vma(). * 'perf-uprobes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (21 commits) perf probe: Detect probe target when m/x options are absent perf probe: Provide perf interface for uprobes tracing: Fix kconfig warning due to a typo tracing: Provide trace events interface for uprobes tracing: Extract out common code for kprobes/uprobes trace events tracing: Modify is_delete, is_return from int to bool uprobes/core: Decrement uprobe count before the pages are unmapped uprobes/core: Make background page replacement logic account for rss_stat counters uprobes/core: Optimize probe hits with the help of a counter uprobes/core: Allocate XOL slots for uprobes use uprobes/core: Handle breakpoint and singlestep exceptions uprobes/core: Rename bkpt to swbp uprobes/core: Make order of function parameters consistent across functions uprobes/core: Make macro names consistent uprobes: Update copyright notices uprobes/core: Move insn to arch specific structure uprobes/core: Remove uprobe_opcode_sz uprobes/core: Make instruction tables volatile uprobes: Move to kernel/events/ uprobes/core: Clean up, refactor and improve the code ...
2012-05-24mm: add a low limit to alloc_large_system_hashTim Bird
UDP stack needs a minimum hash size value for proper operation and also uses alloc_large_system_hash() for proper NUMA distribution of its hash tables and automatic sizing depending on available system memory. On some low memory situations, udp_table_init() must ignore the alloc_large_system_hash() result and reallocs a bigger memory area. As we cannot easily free old hash table, we leak it and kmemleak can issue a warning. This patch adds a low limit parameter to alloc_large_system_hash() to solve this problem. We then specify UDP_HTABLE_SIZE_MIN for UDP/UDPLite hash table allocation. Reported-by: Mark Asselstine <mark.asselstine@windriver.com> Reported-by: Tim Bird <tim.bird@am.sony.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-23mm: mempolicy: Let vma_merge and vma_split handle vma->vm_policy linkagesMel Gorman
Dave Jones' system call fuzz testing tool "trinity" triggered the following bug error with slab debugging enabled ============================================================================= BUG numa_policy (Not tainted): Poison overwritten ----------------------------------------------------------------------------- INFO: 0xffff880146498250-0xffff880146498250. First byte 0x6a instead of 0x6b INFO: Allocated in mpol_new+0xa3/0x140 age=46310 cpu=6 pid=32154 __slab_alloc+0x3d3/0x445 kmem_cache_alloc+0x29d/0x2b0 mpol_new+0xa3/0x140 sys_mbind+0x142/0x620 system_call_fastpath+0x16/0x1b INFO: Freed in __mpol_put+0x27/0x30 age=46268 cpu=6 pid=32154 __slab_free+0x2e/0x1de kmem_cache_free+0x25a/0x260 __mpol_put+0x27/0x30 remove_vma+0x68/0x90 exit_mmap+0x118/0x140 mmput+0x73/0x110 exit_mm+0x108/0x130 do_exit+0x162/0xb90 do_group_exit+0x4f/0xc0 sys_exit_group+0x17/0x20 system_call_fastpath+0x16/0x1b INFO: Slab 0xffffea0005192600 objects=27 used=27 fp=0x (null) flags=0x20000000004080 INFO: Object 0xffff880146498250 @offset=592 fp=0xffff88014649b9d0 This implied a reference counting bug and the problem happened during mbind(). mbind() applies a new memory policy to a range and uses mbind_range() to merge existing VMAs or split them as necessary. In the event of splits, mpol_dup() will allocate a new struct mempolicy and maintain existing reference counts whose rules are documented in Documentation/vm/numa_memory_policy.txt . The problem occurs with shared memory policies. The vm_op->set_policy increments the reference count if necessary and split_vma() and vma_merge() have already handled the existing reference counts. However, policy_vma() screws it up by replacing an existing vma->vm_policy with one that potentially has the wrong reference count leading to a premature free. This patch removes the damage caused by policy_vma(). With this patch applied Dave's trinity tool runs an mbind test for 5 minutes without error. /proc/slabinfo reported that there are no numa_policy or shared_policy_node objects allocated after the test completed and the shared memory region was deleted. Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Dave Jones <davej@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Stephen Wilson <wilsons@start.ca> Cc: Christoph Lameter <cl@linux.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: <stable@vger.kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace enhancements from Eric Biederman: "This is a course correction for the user namespace, so that we can reach an inexpensive, maintainable, and reasonably complete implementation. Highlights: - Config guards make it impossible to enable the user namespace and code that has not been converted to be user namespace safe. - Use of the new kuid_t type ensures the if you somehow get past the config guards the kernel will encounter type errors if you enable user namespaces and attempt to compile in code whose permission checks have not been updated to be user namespace safe. - All uids from child user namespaces are mapped into the initial user namespace before they are processed. Removing the need to add an additional check to see if the user namespace of the compared uids remains the same. - With the user namespaces compiled out the performance is as good or better than it is today. - For most operations absolutely nothing changes performance or operationally with the user namespace enabled. - The worst case performance I could come up with was timing 1 billion cache cold stat operations with the user namespace code enabled. This went from 156s to 164s on my laptop (or 156ns to 164ns per stat operation). - (uid_t)-1 and (gid_t)-1 are reserved as an internal error value. Most uid/gid setting system calls treat these value specially anyway so attempting to use -1 as a uid would likely cause entertaining failures in userspace. - If setuid is called with a uid that can not be mapped setuid fails. I have looked at sendmail, login, ssh and every other program I could think of that would call setuid and they all check for and handle the case where setuid fails. - If stat or a similar system call is called from a context in which we can not map a uid we lie and return overflowuid. The LFS experience suggests not lying and returning an error code might be better, but the historical precedent with uids is different and I can not think of anything that would break by lying about a uid we can't map. - Capabilities are localized to the current user namespace making it safe to give the initial user in a user namespace all capabilities. My git tree covers all of the modifications needed to convert the core kernel and enough changes to make a system bootable to runlevel 1." Fix up trivial conflicts due to nearby independent changes in fs/stat.c * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (46 commits) userns: Silence silly gcc warning. cred: use correct cred accessor with regards to rcu read lock userns: Convert the move_pages, and migrate_pages permission checks to use uid_eq userns: Convert cgroup permission checks to use uid_eq userns: Convert tmpfs to use kuid and kgid where appropriate userns: Convert sysfs to use kgid/kuid where appropriate userns: Convert sysctl permission checks to use kuid and kgids. userns: Convert proc to use kuid/kgid where appropriate userns: Convert ext4 to user kuid/kgid where appropriate userns: Convert ext3 to use kuid/kgid where appropriate userns: Convert ext2 to use kuid/kgid where appropriate. userns: Convert devpts to use kuid/kgid where appropriate userns: Convert binary formats to use kuid/kgid where appropriate userns: Add negative depends on entries to avoid building code that is userns unsafe userns: signal remove unnecessary map_cred_ns userns: Teach inode_capable to understand inodes whose uids map to other namespaces. userns: Fail exec for suid and sgid binaries with ids outside our user namespace. userns: Convert stat to return values mapped from kuids and kgids userns: Convert user specfied uids and gids in chown into kuids and kgid userns: Use uid_eq gid_eq helpers when comparing kuids and kgids in the vfs ...
2012-05-22Merge branch 'for-3.5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup updates from Tejun Heo: "cgroup file type addition / removal is updated so that file types are added and removed instead of individual files so that dynamic file type addition / removal can be implemented by cgroup and used by controllers. blkio controller changes which will come through block tree are dependent on this. Other changes include res_counter cleanup and disallowing kthread / PF_THREAD_BOUND threads to be attached to non-root cgroups. There's a reported bug with the file type addition / removal handling which can lead to oops on cgroup umount. The issue is being looked into. It shouldn't cause problems for most setups and isn't a security concern." Fix up trivial conflict in Documentation/feature-removal-schedule.txt * 'for-3.5' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (21 commits) res_counter: Account max_usage when calling res_counter_charge_nofail() res_counter: Merge res_counter_charge and res_counter_charge_nofail cgroups: disallow attaching kthreadd or PF_THREAD_BOUND threads cgroup: remove cgroup_subsys->populate() cgroup: get rid of populate for memcg cgroup: pass struct mem_cgroup instead of struct cgroup to socket memcg cgroup: make css->refcnt clearing on cgroup removal optional cgroup: use negative bias on css->refcnt to block css_tryget() cgroup: implement cgroup_rm_cftypes() cgroup: introduce struct cfent cgroup: relocate __d_cgrp() and __d_cft() cgroup: remove cgroup_add_file[s]() cgroup: convert memcg controller to the new cftype interface memcg: always create memsw files if CONFIG_CGROUP_MEM_RES_CTLR_SWAP cgroup: convert all non-memcg controllers to the new cftype interface cgroup: relocate cftype and cgroup_subsys definitions in controllers cgroup: merge cft_release_agent cftype array into the base files array cgroup: implement cgroup_add_cftypes() and friends cgroup: build list of all cgroups under a given cgroupfs_root cgroup: move cgroup_clear_directory() call out of cgroup_populate_dir() ...
2012-05-22Merge tag 'driver-core-3.5-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg Kroah-Hartman: "Here's the driver core, and other driver subsystems, pull request for the 3.5-rc1 merge window. Outside of a few minor driver core changes, we ended up with the following different subsystem and core changes as well, due to interdependancies on the driver core: - hyperv driver updates - drivers/memory being created and some drivers moved into it - extcon driver subsystem created out of the old Android staging switch driver code - dynamic debug updates - printk rework, and /dev/kmsg changes All of this has been tested in the linux-next releases for a few weeks with no reported problems. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fix up conflicts in drivers/extcon/extcon-max8997.c where git noticed that a patch to the deleted drivers/misc/max8997-muic.c driver needs to be applied to this one. * tag 'driver-core-3.5-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (90 commits) uio_pdrv_genirq: get irq through platform resource if not set otherwise memory: tegra{20,30}-mc: Remove empty *_remove() printk() - isolate KERN_CONT users from ordinary complete lines sysfs: get rid of some lockdep false positives Drivers: hv: util: Properly handle version negotiations. Drivers: hv: Get rid of an unnecessary check in vmbus_prep_negotiate_resp() memory: tegra{20,30}-mc: Use dev_err_ratelimited() driver core: Add dev_*_ratelimited() family Driver Core: don't oops with unregistered driver in driver_find_device() printk() - restore prefix/timestamp printing for multi-newline strings printk: add stub for prepend_timestamp() ARM: tegra30: Make MC optional in Kconfig ARM: tegra20: Make MC optional in Kconfig ARM: tegra30: MC: Remove unnecessary BUG*() ARM: tegra20: MC: Remove unnecessary BUG*() printk: correctly align __log_buf ARM: tegra30: Add Tegra Memory Controller(MC) driver ARM: tegra20: Add Tegra Memory Controller(MC) driver printk() - restore timestamp printing at console output printk() - do not merge continuation lines of different threads ...
2012-05-21Merge branch 'vm-cleanups' (unmap_vma() interface cleanup)Linus Torvalds
This series sanitizes the interface to unmap_vma(). The crazy interface annoyed me no end when I was looking at unmap_single_vma(), which we can spend quite a lot of time in (especially with loads that have a lot of small fork/exec's: shell scripts etc). Moving the nr_accounted calculations to where they belong at least clarifies things a little. I hope to come back to look at the performance of this later, but if/when I get back to it I at least don't have to see the crazy interfaces any more. * vm-cleanups: vm: remove 'nr_accounted' calculations from the unmap_vmas() interfaces vm: simplify unmap_vmas() calling convention
2012-05-21cma: fix migration modeMinchan Kim
__alloc_contig_migrate_range calls migrate_pages with wrong argument for migrate_mode. Fix it. Cc: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Minchan Kim <minchan@kernel.org> Acked-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com>
2012-05-21mm: trigger page reclaim in alloc_contig_range() to stabilise watermarksMarek Szyprowski
alloc_contig_range() performs memory allocation so it also should keep track on keeping the correct level of memory watermarks. This commit adds a call to *_slowpath style reclaim to grab enough pages to make sure that the final collection of contiguous pages from freelists will not starve the system. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> CC: Michal Nazarewicz <mina86@mina86.com> Tested-by: Rob Clark <rob.clark@linaro.org> Tested-by: Ohad Ben-Cohen <ohad@wizery.com> Tested-by: Benjamin Gaignard <benjamin.gaignard@linaro.org> Tested-by: Robert Nelson <robertcnelson@gmail.com> Tested-by: Barry Song <Baohua.Song@csr.com>
2012-05-21mm: extract reclaim code from __alloc_pages_direct_reclaim()Marek Szyprowski
This patch extracts common reclaim code from __alloc_pages_direct_reclaim() function to separate function: __perform_reclaim() which can be later used by alloc_contig_range(). Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Michal Nazarewicz <mina86@mina86.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Tested-by: Rob Clark <rob.clark@linaro.org> Tested-by: Ohad Ben-Cohen <ohad@wizery.com> Tested-by: Benjamin Gaignard <benjamin.gaignard@linaro.org> Tested-by: Robert Nelson <robertcnelson@gmail.com> Tested-by: Barry Song <Baohua.Song@csr.com>
2012-05-21mm: Serialize access to min_free_kbytesMel Gorman
There is a race between the min_free_kbytes sysctl, memory hotplug and transparent hugepage support enablement. Memory hotplug uses a zonelists_mutex to avoid a race when building zonelists. Reuse it to serialise watermark updates. [a.p.zijlstra@chello.nl: Older patch fixed the race with spinlock] Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Tested-by: Barry Song <Baohua.Song@csr.com>
2012-05-21mm: page_isolation: MIGRATE_CMA isolation functions addedMichal Nazarewicz
This commit changes various functions that change pages and pageblocks migrate type between MIGRATE_ISOLATE and MIGRATE_MOVABLE in such a way as to allow to work with MIGRATE_CMA migrate type. Signed-off-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Tested-by: Rob Clark <rob.clark@linaro.org> Tested-by: Ohad Ben-Cohen <ohad@wizery.com> Tested-by: Benjamin Gaignard <benjamin.gaignard@linaro.org> Tested-by: Robert Nelson <robertcnelson@gmail.com> Tested-by: Barry Song <Baohua.Song@csr.com>
2012-05-21mm: mmzone: MIGRATE_CMA migration type addedMichal Nazarewicz
The MIGRATE_CMA migration type has two main characteristics: (i) only movable pages can be allocated from MIGRATE_CMA pageblocks and (ii) page allocator will never change migration type of MIGRATE_CMA pageblocks. This guarantees (to some degree) that page in a MIGRATE_CMA page block can always be migrated somewhere else (unless there's no memory left in the system). It is designed to be used for allocating big chunks (eg. 10MiB) of physically contiguous memory. Once driver requests contiguous memory, pages from MIGRATE_CMA pageblocks may be migrated away to create a contiguous block. To minimise number of migrations, MIGRATE_CMA migration type is the last type tried when page allocator falls back to other migration types when requested. Signed-off-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Tested-by: Rob Clark <rob.clark@linaro.org> Tested-by: Ohad Ben-Cohen <ohad@wizery.com> Tested-by: Benjamin Gaignard <benjamin.gaignard@linaro.org> Tested-by: Robert Nelson <robertcnelson@gmail.com> Tested-by: Barry Song <Baohua.Song@csr.com>
2012-05-21mm: page_alloc: change fallbacks array handlingMichal Nazarewicz
This commit adds a row for MIGRATE_ISOLATE type to the fallbacks array which was missing from it. It also, changes the array traversal logic a little making MIGRATE_RESERVE an end marker. The letter change, removes the implicit MIGRATE_UNMOVABLE from the end of each row which was read by __rmqueue_fallback() function. Signed-off-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Tested-by: Rob Clark <rob.clark@linaro.org> Tested-by: Ohad Ben-Cohen <ohad@wizery.com> Tested-by: Benjamin Gaignard <benjamin.gaignard@linaro.org> Tested-by: Robert Nelson <robertcnelson@gmail.com> Tested-by: Barry Song <Baohua.Song@csr.com>
2012-05-21mm: page_alloc: introduce alloc_contig_range()Michal Nazarewicz
This commit adds the alloc_contig_range() function which tries to allocate given range of pages. It tries to migrate all already allocated pages that fall in the range thus freeing them. Once all pages in the range are freed they are removed from the buddy system thus allocated for the caller to use. Signed-off-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Tested-by: Rob Clark <rob.clark@linaro.org> Tested-by: Ohad Ben-Cohen <ohad@wizery.com> Tested-by: Benjamin Gaignard <benjamin.gaignard@linaro.org> Tested-by: Robert Nelson <robertcnelson@gmail.com> Tested-by: Barry Song <Baohua.Song@csr.com>
2012-05-21mm: compaction: export some of the functionsMichal Nazarewicz
This commit exports some of the functions from compaction.c file outside of it adding their declaration into internal.h header file so that other mm related code can use them. This forced compaction.c to always be compiled (as opposed to being compiled only if CONFIG_COMPACTION is defined) but as to avoid introducing code that user did not ask for, part of the compaction.c is now wrapped in on #ifdef. Signed-off-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Tested-by: Rob Clark <rob.clark@linaro.org> Tested-by: Ohad Ben-Cohen <ohad@wizery.com> Tested-by: Benjamin Gaignard <benjamin.gaignard@linaro.org> Tested-by: Robert Nelson <robertcnelson@gmail.com> Tested-by: Barry Song <Baohua.Song@csr.com>
2012-05-21mm: compaction: introduce isolate_freepages_range()Michal Nazarewicz
This commit introduces isolate_freepages_range() function which generalises isolate_freepages_block() so that it can be used on arbitrary PFN ranges. isolate_freepages_block() is left with only minor changes. Signed-off-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Tested-by: Rob Clark <rob.clark@linaro.org> Tested-by: Ohad Ben-Cohen <ohad@wizery.com> Tested-by: Benjamin Gaignard <benjamin.gaignard@linaro.org> Tested-by: Robert Nelson <robertcnelson@gmail.com> Tested-by: Barry Song <Baohua.Song@csr.com>
2012-05-21mm: compaction: introduce map_pages()Michal Nazarewicz
This commit creates a map_pages() function which map pages freed using split_free_pages(). This merely moves some code from isolate_freepages() so that it can be reused in other places. Signed-off-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Tested-by: Robert Nelson <robertcnelson@gmail.com> Tested-by: Barry Song <Baohua.Song@csr.com>
2012-05-21mm: compaction: introduce isolate_migratepages_range()Michal Nazarewicz
This commit introduces isolate_migratepages_range() function which extracts functionality from isolate_migratepages() so that it can be used on arbitrary PFN ranges. isolate_migratepages() function is implemented as a simple wrapper around isolate_migratepages_range(). Signed-off-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Tested-by: Rob Clark <rob.clark@linaro.org> Tested-by: Ohad Ben-Cohen <ohad@wizery.com> Tested-by: Benjamin Gaignard <benjamin.gaignard@linaro.org> Tested-by: Robert Nelson <robertcnelson@gmail.com> Tested-by: Barry Song <Baohua.Song@csr.com>
2012-05-21mm: page_alloc: remove trailing whitespaceMichal Nazarewicz
2012-05-19memcg,thp: fix res_counter:96 regressionHugh Dickins
Occasionally, testing memcg's move_charge_at_immigrate on rc7 shows a flurry of hundreds of warnings at kernel/res_counter.c:96, where res_counter_uncharge_locked() does WARN_ON(counter->usage < val). The first trace of each flurry implicates __mem_cgroup_cancel_charge() of mc.precharge, and an audit of mc.precharge handling points to mem_cgroup_move_charge_pte_range()'s THP handling in commit 12724850e806 ("memcg: avoid THP split in task migration"). Checking !mc.precharge is good everywhere else, when a single page is to be charged; but here the "mc.precharge -= HPAGE_PMD_NR" likely to follow, is liable to result in underflow (a lot can change since the precharge was estimated). Simply check against HPAGE_PMD_NR: there's probably a better alternative, trying precharge for more, splitting if unsuccessful; but this one-liner is safer for now - no kernel/res_counter.c:96 warnings seen in 26 hours. Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-17slub: missing test for partial pages flush work in flush_all()majianpeng
I found some kernel messages such as: SLUB raid5-md127: kmem_cache_destroy called for cache that still has objects. Pid: 6143, comm: mdadm Tainted: G O 3.4.0-rc6+ #75 Call Trace: kmem_cache_destroy+0x328/0x400 free_conf+0x2d/0xf0 [raid456] stop+0x41/0x60 [raid456] md_stop+0x1a/0x60 [md_mod] do_md_stop+0x74/0x470 [md_mod] md_ioctl+0xff/0x11f0 [md_mod] blkdev_ioctl+0xd8/0x7a0 block_ioctl+0x3b/0x40 do_vfs_ioctl+0x96/0x560 sys_ioctl+0x91/0xa0 system_call_fastpath+0x16/0x1b Then using kmemleak I found these messages: unreferenced object 0xffff8800b6db7380 (size 112): comm "mdadm", pid 5783, jiffies 4294810749 (age 90.589s) hex dump (first 32 bytes): 01 01 db b6 ad 4e ad de ff ff ff ff ff ff ff ff .....N.......... ff ff ff ff ff ff ff ff 98 40 4a 82 ff ff ff ff .........@J..... backtrace: kmemleak_alloc+0x21/0x50 kmem_cache_alloc+0xeb/0x1b0 kmem_cache_open+0x2f1/0x430 kmem_cache_create+0x158/0x320 setup_conf+0x649/0x770 [raid456] run+0x68b/0x840 [raid456] md_run+0x529/0x940 [md_mod] do_md_run+0x18/0xc0 [md_mod] md_ioctl+0xba8/0x11f0 [md_mod] blkdev_ioctl+0xd8/0x7a0 block_ioctl+0x3b/0x40 do_vfs_ioctl+0x96/0x560 sys_ioctl+0x91/0xa0 system_call_fastpath+0x16/0x1b This bug was introduced by commit a8364d5555b ("slub: only IPI CPUs that have per cpu obj to flush"), which did not include checks for per cpu partial pages being present on a cpu. Signed-off-by: majianpeng <majianpeng@gmail.com> Cc: Gilad Ben-Yossef <gilad@benyossef.com> Acked-by: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Tested-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-15userns: Convert the move_pages, and migrate_pages permission checks to use ↵Eric W. Biederman
uid_eq Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-05-15userns: Convert tmpfs to use kuid and kgid where appropriateEric W. Biederman
2012-05-14Merge branch 'perf/uprobes' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/uprobes
2012-05-11mm: raise MemFree by reverting percpu_pagelist_fraction to 0Hugh Dickins
Why is there less MemFree than there used to be? It perturbed a test, so I've just been bisecting linux-next, and now find the offender went upstream yesterday. Commit 93278814d359 "mm: fix division by 0 in percpu_pagelist_fraction()" mistakenly initialized percpu_pagelist_fraction to the sysctl's minimum 8, which leaves 1/8th of memory on percpu lists (on each cpu??); but most of us expect it to be left unset at 0 (and it's not then used as a divisor). MemTotal: 8061476kB 8061476kB 8061476kB 8061476kB 8061476kB 8061476kB Repetitive test with percpu_pagelist_fraction 8: MemFree: 6948420kB 6237172kB 6949696kB 6840692kB 6949048kB 6862984kB Same test with percpu_pagelist_fraction back to 0: MemFree: 7945000kB 7944908kB 7948568kB 7949060kB 7948796kB 7948812kB Signed-off-by: Hugh Dickins <hughd@google.com> [ We really should fix the crazy sysctl interface too, but that's a separate thing - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-10Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge misc fixes from Andrew Morton. * emailed from Andrew Morton <akpm@linux-foundation.org>: (8 patches) MAINTAINERS: add maintainer for LED subsystem mm: nobootmem: fix sign extend problem in __free_pages_memory() drivers/leds: correct __devexit annotations memcg: free spare array to avoid memory leak namespaces, pid_ns: fix leakage on fork() failure hugetlb: prevent BUG_ON in hugetlb_fault() -> hugetlb_cow() mm: fix division by 0 in percpu_pagelist_fraction() proc/pid/pagemap: correctly report non-present ptes and holes between vmas
2012-05-10mm: nobootmem: fix sign extend problem in __free_pages_memory()Russ Anderson
Systems with 8 TBytes of memory or greater can hit a problem where only the the first 8 TB of memory shows up. This is due to "int i" being smaller than "unsigned long start_aligned", causing the high bits to be dropped. The fix is to change `i' to unsigned long to match start_aligned and end_aligned. Thanks to Jack Steiner for assistance tracking this down. Signed-off-by: Russ Anderson <rja@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Tejun Heo <tj@kernel.org> Cc: David S. Miller <davem@davemloft.net> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Gavin Shan <shangw@linux.vnet.ibm.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-10memcg: free spare array to avoid memory leakSha Zhengju
When the last event is unregistered, there is no need to keep the spare array anymore. So free it to avoid memory leak. Signed-off-by: Sha Zhengju <handai.szj@taobao.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-10hugetlb: prevent BUG_ON in hugetlb_fault() -> hugetlb_cow()Chris Metcalf
Commit 66aebce747eaf ("hugetlb: fix race condition in hugetlb_fault()") added code to avoid a race condition by elevating the page refcount in hugetlb_fault() while calling hugetlb_cow(). However, one code path in hugetlb_cow() includes an assertion that the page count is 1, whereas it may now also have the value 2 in this path. The consensus is that this BUG_ON has served its purpose, so rather than extending it to cover both cases, we just remove it. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Hillf Danton <dhillf@gmail.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: <stable@vger.kernel.org> [3.0.29+, 3.2.16+, 3.3.3+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-10mm: fix division by 0 in percpu_pagelist_fraction()Sasha Levin
percpu_pagelist_fraction_sysctl_handler() has only considered -EINVAL as a possible error from proc_dointvec_minmax(). If any other error is returned, it would proceed to divide by zero since percpu_pagelist_fraction wasn't getting initialized at any point. For example, writing 0 bytes into the proc file would trigger the issue. Signed-off-by: Sasha Levin <levinsasha928@gmail.com> Reviewed-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-09kmemleak: Fix the kmemleak tracking of the percpu areas with !SMPCatalin Marinas
Kmemleak tracks the percpu allocations via a specific API and the originally allocated areas must be removed from kmemleak (via kmemleak_free). The code was already doing this for SMP systems. Reported-by: Sami Liedes <sami.liedes@iki.fi> Cc: Tejun Heo <tj@kernel.org> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2012-05-09percpu: pcpu_embed_first_chunk() should free unused parts after all allocs ↵Tejun Heo
are complete pcpu_embed_first_chunk() allocates memory for each node, copies percpu data and frees unused portions of it before proceeding to the next group. This assumes that allocations for different nodes doesn't overlap; however, depending on memory topology, the bootmem allocator may end up allocating memory from a different node than the requested one which may overlap with the portion freed from one of the previous percpu areas. This leads to percpu groups for different nodes overlapping which is a serious bug. This patch separates out copy & partial free from the allocation loop such that all allocations are complete before partial frees happen. This also fixes overlapping frees which could happen on allocation failure path - out_free_areas path frees whole groups but the groups could have portions freed at that point. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org Reported-by: "Pavel V. Panteleev" <pp_84@mail.ru> Tested-by: "Pavel V. Panteleev" <pp_84@mail.ru> LKML-Reference: <E1SNhwY-0007ui-V7.pp_84-mail-ru@f220.mail.ru>
2012-05-08Merge branch 'for-3.4-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu Pull two percpu fixes from Tejun Heo: "One adds missing KERN_CONT on split printk()s and the other makes the percpu allocator avoid using PMD_SIZE as atom_size on x86_32. Using PMD_SIZE led to vmalloc area exhaustion on certain configurations (x86_32 android) and the only cost of using PAGE_SIZE instead is static percpu area not being aligned to large page mapping." * 'for-3.4-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu, x86: don't use PMD_SIZE as embedded atom_size on 32bit percpu: use KERN_CONT in pcpu_dump_alloc_info()
2012-05-08mm: use KERN_CONT in printk() continuation linesKay Sievers
Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Kay Sievers <kay@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-06vm: remove 'nr_accounted' calculations from the unmap_vmas() interfacesLinus Torvalds
The VM accounting makes no sense at this level, and half of the callers didn't ever actually use the end result. The only time we want to unaccount the memory is when we actually remove the vma, so do the accounting at that point instead. This simplifies the interfaces (no need to pass down that silly page counter to functions that really don't care), and also makes it much more obvious what is actually going on: we do vm_[un]acct_memory() when adding or removing the vma, not on random page walking. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-06vm: simplify unmap_vmas() calling conventionLinus Torvalds
None of the callers want to pass in 'zap_details', and it doesn't even make sense for the case of actually unmapping vma's. So remove the argument, and clean up the interface. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-06vfs: Rename end_writeback() to clear_inode()Jan Kara
After we moved inode_sync_wait() from end_writeback() it doesn't make sense to call the function end_writeback() anymore. Rename it to clear_inode() which well says what the function really does - set I_CLEAR flag. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
