Dave noticed that unprivileged process can allocate significant amount of
memory -- >500 MiB on x86_64 -- and stay unnoticed by oom-killer and
memory cgroup. The trick is to allocate a lot of PMD page tables. Linux
kernel doesn't account PMD tables to the process, only PTE.
The use-cases below use few tricks to allocate a lot of PMD page tables
while keeping VmRSS and VmPTE low. oom_score for the process will be 0.
#include <errno.h>
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <sys/mman.h>
#include <sys/prctl.h>
#define PUD_SIZE (1UL << 30)
#define PMD_SIZE (1UL << 21)
#define NR_PUD 130000
int main(void)
char *addr = NULL;
unsigned long i;
prctl(PR_SET_THP_DISABLE);
for (i = 0; i < NR_PUD ; i++) {
addr = mmap(addr + PUD_SIZE, PUD_SIZE, PROT_WRITE|PROT_READ,
MAP_ANONYMOUS|MAP_PRIVATE, -1, 0);
if (addr == MAP_FAILED) {
perror("mmap");
break;
*addr = 'x';
munmap(addr, PMD_SIZE);
mmap(addr, PMD_SIZE, PROT_WRITE|PROT_READ,
MAP_ANONYMOUS|MAP_PRIVATE|MAP_FIXED, -1, 0);
perror("re-mmap"), exit(1);
printf("PID %d consumed %lu KiB in PMD page tables\n",
getpid(), i * 4096 >> 10);
return pause();
The patch addresses the issue by account PMD tables to the process the
same way we account PTE.
The main place where PMD tables is accounted is __pmd_alloc() and
free_pmd_range(). But there're few corner cases:
- HugeTLB can share PMD page tables. The patch handles by accounting
the table to all processes who share it.
- x86 PAE pre-allocates few PMD tables on fork.
- Architectures with FIRST_USER_ADDRESS > 0. We need to adjust sanity
check on exit(2).
Accounting only happens on configuration where PMD page table's level is
present (PMD is not folded). As with nr_ptes we use per-mm counter. The
counter value is used to calculate baseline for badness score by
oom-killer.
Reported-by: Dave Hansen <dave.hansen@linux.intel.com>
Reviewed-by: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Pavel Emelyanov <xemul@openvz.org>
Tested-by: Sedat Dilek <sedat.dilek@gmail.com>
The swap controller code is scattered all over the file. Gather all
the code that isn't directly needed by the memory controller at the
end of the file in its own CONFIG_MEMCG_SWAP section.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reviewed-by: Vladimir Davydov <vdavydov@parallels.com>
The initialization code for the per-cpu charge stock and the soft
limit tree is compact enough to inline it into mem_cgroup_init().
Acked-by: Michal Hocko <mhocko@suse.cz>
- No need to test the node for N_MEMORY. node_online() is enough for
node fallback to work in slab, use NUMA_NO_NODE for everything else.
- Remove the BUG_ON() for allocation failure. A NULL pointer crash is
just as descriptive, and the absent return value check is obvious.
- Move local variables to the inner-most blocks.
- Point to the tree structure after its initialized, not before, it's
just more logical that way.
Cc: Vladimir Davydov <vdavydov@parallels.com>
The totalcma_pages variable is not updated to account for CMA regions
defined via device tree reserved-memory sub-nodes. Fix this omission by
moving the calculation of totalcma_pages into cma_init_reserved_mem()
instead of cma_declare_contiguous() such that it will include reserved
memory used by all CMA regions.
Signed-off-by: George G. Davis <george_davis@mentor.com>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
Acked-by: Michal Nazarewicz <mina86@mina86.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
Cc: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Commit 5695be142e20 ("OOM, PM: OOM killed task shouldn't escape PM
suspend") has left a race window when OOM killer manages to
note_oom_kill after freeze_processes checks the counter. The race
window is quite small and really unlikely and partial solution deemed
sufficient at the time of submission.
Tejun wasn't happy about this partial solution though and insisted on a
full solution. That requires the full OOM and freezer's task freezing
exclusion, though. This is done by this patch which introduces oom_sem
RW lock and turns oom_killer_disable() into a full OOM barrier.
oom_killer_disabled check is moved from the allocation path to the OOM
level and we take oom_sem for reading for both the check and the whole
OOM invocation.
oom_killer_disable() takes oom_sem for writing so it waits for all
currently running OOM killer invocations. Then it disable all the further
OOMs by setting oom_killer_disabled and checks for any oom victims.
Victims are counted via mark_tsk_oom_victim resp. unmark_oom_victim. The
last victim wakes up all waiters enqueued by oom_killer_disable().
Therefore this function acts as the full OOM barrier.
The page fault path is covered now as well although it was assumed to be
safe before. As per Tejun, "We used to have freezing points deep in file
system code which may be reacheable from page fault." so it would be
better and more robust to not rely on freezing points here. Same applies
to the memcg OOM killer.
out_of_memory tells the caller whether the OOM was allowed to trigger and
the callers are supposed to handle the situation. The page allocation
path simply fails the allocation same as before. The page fault path will
retry the fault (more on that later) and Sysrq OOM trigger will simply
complain to the log.
Normally there wouldn't be any unfrozen user tasks after
try_to_freeze_tasks so the function will not block. But if there was an
OOM killer racing with try_to_freeze_tasks and the OOM victim didn't
finish yet then we have to wait for it. This should complete in a finite
time, though, because
- the victim cannot loop in the page fault handler (it would die
on the way out from the exception)
- it cannot loop in the page allocator because all the further
allocation would fail and __GFP_NOFAIL allocations are not
acceptable at this stage
- it shouldn't be blocked on any locks held by frozen tasks
(try_to_freeze expects lockless context) and kernel threads and
work queues are not frozen yet
Suggested-by: Tejun Heo <tj@kernel.org>
Cc: Cong Wang <xiyou.wangcong@gmail.com>
Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net>
oom_kill_process only sets TIF_MEMDIE flag and sends a signal to the
victim. This is basically noop when the task is frozen though because the
task sleeps in the uninterruptible sleep. The victim is eventually thawed
later when oom_scan_process_thread meets the task again in a later OOM
invocation so the OOM killer doesn't live lock. But this is less than
optimal.
Let's add __thaw_task into mark_tsk_oom_victim after we set TIF_MEMDIE to
the victim. We are not checking whether the task is frozen because that
would be racy and __thaw_task does that already. oom_scan_process_thread
doesn't need to care about freezer anymore as TIF_MEMDIE and freezer are
excluded completely now.
Cc: Tejun Heo <tj@kernel.org>
This patchset addresses a race which was described in the changelog for
5695be142e20 ("OOM, PM: OOM killed task shouldn't escape PM suspend"):
: PM freezer relies on having all tasks frozen by the time devices are
: getting frozen so that no task will touch them while they are getting
: frozen. But OOM killer is allowed to kill an already frozen task in order
: to handle OOM situtation. In order to protect from late wake ups OOM
: killer is disabled after all tasks are frozen. This, however, still keeps
: a window open when a killed task didn't manage to die by the time
: freeze_processes finishes.
The original patch hasn't closed the race window completely because that
would require a more complex solution as it can be seen by this patchset.
The primary motivation was to close the race condition between OOM killer
and PM freezer _completely_. As Tejun pointed out, even though the race
condition is unlikely the harder it would be to debug weird bugs deep in
the PM freezer when the debugging options are reduced considerably. I can
only speculate what might happen when a task is still runnable
unexpectedly.
On a plus side and as a side effect the oom enable/disable has a better
(full barrier) semantic without polluting hot paths.
I have tested the series in KVM with 100M RAM:
- many small tasks (20M anon mmap) which are triggering OOM continually
- s2ram which resumes automatically is triggered in a loop
echo processors > /sys/power/pm_test
while true
do
echo mem > /sys/power/state
sleep 1s
done
- simple module which allocates and frees 20M in 8K chunks. If it sees
freezing(current) then it tries another round of allocation before calling
try_to_freeze
- debugging messages of PM stages and OOM killer enable/disable/fail added
and unmark_oom_victim is delayed by 1s after it clears TIF_MEMDIE and before
it wakes up waiters.
- rebased on top of the current mmotm which means some necessary updates
in mm/oom_kill.c. mark_tsk_oom_victim is now called under task_lock but
I think this should be OK because __thaw_task shouldn't interfere with any
locking down wake_up_process. Oleg?
As expected there are no OOM killed tasks after oom is disabled and
allocations requested by the kernel thread are failing after all the tasks
are frozen and OOM disabled. I wasn't able to catch a race where
oom_killer_disable would really have to wait but I kinda expected the race
is really unlikely.
[ 242.609330] Killed process 2992 (mem_eater) total-vm:24412kB, anon-rss:2164kB, file-rss:4kB
[ 243.628071] Unmarking 2992 OOM victim. oom_victims: 1
[ 243.636072] (elapsed 2.837 seconds) done.
[ 243.641985] Trying to disable OOM killer
[ 243.643032] Waiting for concurent OOM victims
[ 243.644342] OOM killer disabled
[ 243.645447] Freezing remaining freezable tasks ... (elapsed 0.005 seconds) done.
[ 243.652983] Suspending console(s) (use no_console_suspend to debug)
[ 243.903299] kmem_eater: page allocation failure: order:1, mode:0x204010
[ 243.992600] PM: suspend of devices complete after 336.667 msecs
[ 243.993264] PM: late suspend of devices complete after 0.660 msecs
[ 243.994713] PM: noirq suspend of devices complete after 1.446 msecs
[ 243.994717] ACPI: Preparing to enter system sleep state S3
[ 243.994795] PM: Saving platform NVS memory
[ 243.994796] Disabling non-boot CPUs ...
The first 2 patches are simple cleanups for OOM. They should go in
regardless the rest IMO.
Patches 3 and 4 are trivial printk -> pr_info conversion and they should
go in ditto.
The main patch is the last one and I would appreciate acks from Tejun and
Rafael. I think the OOM part should be OK (except for __thaw_task vs.
task_lock where a look from Oleg would appreciated) but I am not so sure I
haven't screwed anything in the freezer code. I have found several
surprises there.
This patch (of 5):
This patch is just a preparatory and it doesn't introduce any functional
change.
Note:
I am utterly unhappy about lowmemory killer abusing TIF_MEMDIE just to
wait for the oom victim and to prevent from new killing. This is
just a side effect of the flag. The primary meaning is to give the oom
victim access to the memory reserves and that shouldn't be necessary
here.
Turn the move type enum into flags and give the flags field a shorter
name. Once that is done, move_anon() and move_file() are simple enough to
just fold them into the callsites.
[akpm@linux-foundation.org: tweak MOVE_MASK definition, per Michal]
Introduce the basic control files to account, partition, and limit
memory using cgroups in default hierarchy mode.
This interface versioning allows us to address fundamental design
issues in the existing memory cgroup interface, further explained
below. The old interface will be maintained indefinitely, but a
clearer model and improved workload performance should encourage
existing users to switch over to the new one eventually.
The control files are thus:
- memory.current shows the current consumption of the cgroup and its
descendants, in bytes.
- memory.low configures the lower end of the cgroup's expected
memory consumption range. The kernel considers memory below that
boundary to be a reserve - the minimum that the workload needs in
order to make forward progress - and generally avoids reclaiming
it, unless there is an imminent risk of entering an OOM situation.
- memory.high configures the upper end of the cgroup's expected
memory consumption range. A cgroup whose consumption grows beyond
this threshold is forced into direct reclaim, to work off the
excess and to throttle new allocations heavily, but is generally
allowed to continue and the OOM killer is not invoked.
- memory.max configures the hard maximum amount of memory that the
cgroup is allowed to consume before the OOM killer is invoked.
- memory.events shows event counters that indicate how often the
cgroup was reclaimed while below memory.low, how often it was
forced to reclaim excess beyond memory.high, how often it hit
memory.max, and how often it entered OOM due to memory.max. This
allows users to identify configuration problems when observing a
degradation in workload performance. An overcommitted system will
have an increased rate of low boundary breaches, whereas increased
rates of high limit breaches, maximum hits, or even OOM situations
will indicate internally overcommitted cgroups.
For existing users of memory cgroups, the following deviations from
the current interface are worth pointing out and explaining:
- The original lower boundary, the soft limit, is defined as a limit
that is per default unset. As a result, the set of cgroups that
global reclaim prefers is opt-in, rather than opt-out. The costs
for optimizing these mostly negative lookups are so high that the
implementation, despite its enormous size, does not even provide
the basic desirable behavior. First off, the soft limit has no
hierarchical meaning. All configured groups are organized in a
global rbtree and treated like equal peers, regardless where they
are located in the hierarchy. This makes subtree delegation
impossible. Second, the soft limit reclaim pass is so aggressive
that it not just introduces high allocation latencies into the
system, but also impacts system performance due to overreclaim, to
the point where the feature becomes self-defeating.
The memory.low boundary on the other hand is a top-down allocated
reserve. A cgroup enjoys reclaim protection when it and all its
ancestors are below their low boundaries, which makes delegation
of subtrees possible. Secondly, new cgroups have no reserve per
default and in the common case most cgroups are eligible for the
preferred reclaim pass. This allows the new low boundary to be
efficiently implemented with just a minor addition to the generic
reclaim code, without the need for out-of-band data structures and
reclaim passes. Because the generic reclaim code considers all
cgroups except for the ones running low in the preferred first
reclaim pass, overreclaim of individual groups is eliminated as
well, resulting in much better overall workload performance.
- The original high boundary, the hard limit, is defined as a strict
limit that can not budge, even if the OOM killer has to be called.
But this generally goes against the goal of making the most out of
the available memory. The memory consumption of workloads varies
during runtime, and that requires users to overcommit. But doing
that with a strict upper limit requires either a fairly accurate
prediction of the working set size or adding slack to the limit.
Since working set size estimation is hard and error prone, and
getting it wrong results in OOM kills, most users tend to err on
the side of a looser limit and end up wasting precious resources.
The memory.high boundary on the other hand can be set much more
conservatively. When hit, it throttles allocations by forcing
them into direct reclaim to work off the excess, but it never
invokes the OOM killer. As a result, a high boundary that is
chosen too aggressively will not terminate the processes, but
instead it will lead to gradual performance degradation. The user
can monitor this and make corrections until the minimal memory
footprint that still gives acceptable performance is found.
In extreme cases, with many concurrent allocations and a complete
breakdown of reclaim progress within the group, the high boundary
can be exceeded. But even then it's mostly better to satisfy the
allocation from the slack available in other groups or the rest of
the system than killing the group. Otherwise, memory.max is there
to limit this type of spillover and ultimately contain buggy or
even malicious applications.
- The original control file names are unwieldy and inconsistent in
many different ways. For example, the upper boundary hit count is
exported in the memory.failcnt file, but an OOM event count has to
be manually counted by listening to memory.oom_control events, and
lower boundary / soft limit events have to be counted by first
setting a threshold for that value and then counting those events.
Also, usage and limit files encode their units in the filename.
That makes the filenames very long, even though this is not
information that a user needs to be reminded of every time they
type out those names.
To address these naming issues, as well as to signal clearly that
the new interface carries a new configuration model, the naming
conventions in it necessarily differ from the old interface.
- The original limit files indicate the state of an unset limit with
a very high number, and a configured limit can be unset by echoing
-1 into those files. But that very high number is implementation
and architecture dependent and not very descriptive. And while -1
can be understood as an underflow into the highest possible value,
-2 or -10M etc. do not work, so it's not inconsistent.
memory.low, memory.high, and memory.max will use the string
"infinity" to indicate and set the highest possible value.
[akpm@linux-foundation.org: use seq_puts() for basic strings]
The unified hierarchy interface for memory cgroups will no longer use "-1"
to mean maximum possible resource value. In preparation for this, make
the string an argument and let the caller supply it.
Especially on 32 bit kernels memory node ranges are printed with 32 bit
wide addresses only. Use u64 types and %llx specifiers to print full
width of addresses.
Signed-off-by: Juergen Gross <jgross@suse.com>
Use BUILD_BUG_ON() to compile assert that memcg string tables are in sync
with corresponding enums. There aren't currently any issues with these
tables. This is just defensive.
Signed-off-by: Greg Thelen <gthelen@google.com>
Since commit b2052564e66d ("mm: memcontrol: continue cache reclaim from
offlined groups") pages charged to a memory cgroup are not reparented when
the cgroup is removed. Instead, they are supposed to be reclaimed in a
regular way, along with pages accounted to online memory cgroups.
However, an lruvec of an offline memory cgroup will sooner or later get so
small that it will be scanned only at low scan priorities (see
get_scan_count()). Therefore, if there are enough reclaimable pages in
big lruvecs, pages accounted to offline memory cgroups will never be
scanned at all, wasting memory.
Fix this by unconditionally forcing scanning dead lruvecs from kswapd.
[akpm@linux-foundation.org: fix build]
Signed-off-by: Vladimir Davydov <vdavydov@parallels.com>
Although it was not called, destroy_compound_page() did some potentially
useful checks. Let's re-introduce them in free_pages_prepare(), where
they can be actually triggered when CONFIG_DEBUG_VM=y.
compound_order() assert is already in free_pages_prepare(). We have few
checks for tail pages left.
The only caller is __free_one_page(). By the time we should have
page->flags to be cleared already:
- for 0-order pages though PCP list:
free_hot_cold_page()
free_pages_check()
page->flags &= ~PAGE_FLAGS_CHECK_AT_PREP;
<put the page to PCP list>
free_pcppages_bulk()
page = <withdraw pages from PCP list>
__free_one_page(page)
- for non-0-order pages:
__free_pages_ok()
free_pages_check()
free_one_page()
__free_one_page()
So there's no way PageCompound() will return true in __free_one_page().
Let's remove dead destroy_compound_page() and put assert for page->flags
there instead.
next_zones_zonelist() returns a zoneref pointer, as well as a zone pointer
via extra parameter. Since the latter can be trivially obtained by
dereferencing the former, the overhead of the extra parameter is
unjustified.
This patch thus removes the zone parameter from next_zones_zonelist().
Both callers happen to be in the same header file, so it's simple to add
the zoneref dereference inline. We save some bytes of code size.
add/remove: 0/0 grow/shrink: 0/3 up/down: 0/-105 (-105)
function old new delta
nr_free_zone_pages 129 115 -14
__alloc_pages_nodemask 2300 2285 -15
get_page_from_freelist 2652 2576 -76
add/remove: 0/0 grow/shrink: 1/0 up/down: 10/0 (10)
try_to_compact_pages 569 579 +10
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
Expand the usage of the struct alloc_context introduced in the previous
patch also for calling try_to_compact_pages(), to reduce the number of its
parameters. Since the function is in different compilation unit, we need
to move alloc_context definition in the shared mm/internal.h header.
With this change we get simpler code and small savings of code size and stack
usage:
add/remove: 0/0 grow/shrink: 0/1 up/down: 0/-27 (-27)
__alloc_pages_direct_compact 283 256 -27
add/remove: 0/0 grow/shrink: 0/1 up/down: 0/-13 (-13)
try_to_compact_pages 582 569 -13
Stack usage of __alloc_pages_direct_compact goes from 24 to none (per
scripts/checkstack.pl).
Introduce struct alloc_context to accumulate the numerous parameters
passed between the alloc_pages* family of functions and
get_page_from_freelist(). This excludes gfp_flags and alloc_info, which
mutate too much along the way, and allocation order, which is conceptually
different.
The result is shorter function signatures, as well as overal code size and
stack usage reductions.
bloat-o-meter:
add/remove: 0/0 grow/shrink: 1/2 up/down: 127/-310 (-183)
get_page_from_freelist 2525 2652 +127
__alloc_pages_direct_compact 329 283 -46
__alloc_pages_nodemask 2564 2300 -264
checkstack.pl:
function old new
__alloc_pages_nodemask 248 200
get_page_from_freelist 168 184
__alloc_pages_direct_compact 40 24
The possibility of replacing the numerous parameters of alloc_pages*
functions with a single structure has been discussed when Minchan proposed
to expand the x86 kernel stack [1]. This series implements the change,
along with few more cleanups/microoptimizations.
The series is based on next-20150108 and I used gcc 4.8.3 20140627 on
openSUSE 13.2 for compiling. Config includess NUMA and COMPACTION.
The core change is the introduction of a new struct alloc_context, which looks
like this:
struct alloc_context {
struct zonelist *zonelist;
nodemask_t *nodemask;
struct zone *preferred_zone;
int classzone_idx;
int migratetype;
enum zone_type high_zoneidx;
All the contents is mostly constant, except that __alloc_pages_slowpath()
changes preferred_zone, classzone_idx and potentially zonelist. But
that's not a problem in case control returns to retry_cpuset: in
__alloc_pages_nodemask(), those will be reset to initial values again
(although it's a bit subtle). On the other hand, gfp_flags and alloc_info
mutate so much that it doesn't make sense to put them into alloc_context.
Still, the result is one parameter instead of up to 7. This is all in
Patch 2.
Patch 3 is a step to expand alloc_context usage out of page_alloc.c
itself. The function try_to_compact_pages() can also much benefit from
the parameter reduction, but it means the struct definition has to be
moved to a shared header.
Patch 1 should IMHO be included even if the rest is deemed not useful
enough. It improves maintainability and also has some code/stack
reduction. Patch 4 is OTOH a tiny optimization.
Overall bloat-o-meter results:
add/remove: 0/0 grow/shrink: 0/4 up/down: 0/-460 (-460)
__alloc_pages_direct_compact 329 256 -73
get_page_from_freelist 2670 2576 -94
__alloc_pages_nodemask 2564 2285 -279
try_to_compact_pages 582 579 -3
Overall stack sizes per ./scripts/checkstack.pl:
old new delta
get_page_from_freelist: 184 184 0
__alloc_pages_nodemask 248 200 -48
__alloc_pages_direct_c 40 - -40
try_to_compact_pages 72 72 0
-88
[1] http://marc.info/?l=linux-mm&m=140142462528257&w=2
This patch (of 4):
prep_new_page() sets almost everything in the struct page of the page
being allocated, except page->pfmemalloc. This is not obvious and has at
least once led to a bug where page->pfmemalloc was forgotten to be set
correctly, see commit 8fb74b9fb2b1 ("mm: compaction: partially revert
capture of suitable high-order page").
This patch moves the pfmemalloc setting to prep_new_page(), which means it
needs to gain alloc_flags parameter. The call to prep_new_page is moved
from buffered_rmqueue() to get_page_from_freelist(), which also leads to
simpler code. An obsolete comment for buffered_rmqueue() is replaced.
In addition to better maintainability there is a small reduction of code
and stack usage for get_page_from_freelist(), which inlines the other
functions involved.
add/remove: 0/0 grow/shrink: 0/1 up/down: 0/-145 (-145)
get_page_from_freelist 2670 2525 -145
Stack usage is reduced from 184 to 168 bytes.
If __unmap_hugepage_range() tries to unmap the address range over which
hugepage migration is on the way, we get the wrong page because pte_page()
doesn't work for migration entries. This patch simply clears the pte for
migration entries as we do for hwpoison entries.
Fixes: 290408d4a2 ("hugetlb: hugepage migration core")
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Luiz Capitulino <lcapitulino@redhat.com>
Cc: Nishanth Aravamudan <nacc@linux.vnet.ibm.com>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: Steve Capper <steve.capper@linaro.org>
Cc: <stable@vger.kernel.org> [2.6.36+]
There is a race condition between hugepage migration and
change_protection(), where hugetlb_change_protection() doesn't care about
migration entries and wrongly overwrites them. That causes unexpected
results like kernel crash. HWPoison entries also can cause the same
problem.
This patch adds is_hugetlb_entry_(migration|hwpoisoned) check in this
function to do proper actions.
When running the test which causes the race as shown in the previous patch,
we can hit the BUG "get_page() on refcount 0 page" in hugetlb_fault().
This race happens when pte turns into migration entry just after the first
check of is_hugetlb_entry_migration() in hugetlb_fault() passed with false.
To fix this, we need to check pte_present() again after huge_ptep_get().
This patch also reorders taking ptl and doing pte_page(), because
pte_page() should be done in ptl. Due to this reordering, we need use
trylock_page() in page != pagecache_page case to respect locking order.
Fixes: 66aebce747ea ("hugetlb: fix race condition in hugetlb_fault()")
Cc: <stable@vger.kernel.org> [3.2+]
We have a race condition between move_pages() and freeing hugepages, where
move_pages() calls follow_page(FOLL_GET) for hugepages internally and
tries to get its refcount without preventing concurrent freeing. This
race crashes the kernel, so this patch fixes it by moving FOLL_GET code
for hugepages into follow_huge_pmd() with taking the page table lock.
This patch intentionally removes page==NULL check after pte_page.
This is justified because pte_page() never returns NULL for any
architectures or configurations.
This patch changes the behavior of follow_huge_pmd() for tail pages and
then tail pages can be pinned/returned. So the caller must be changed to
properly handle the returned tail pages.
We could have a choice to add the similar locking to
follow_huge_(addr|pud) for consistency, but it's not necessary because
currently these functions don't support FOLL_GET flag, so let's leave it
for future development.
Here is the reproducer:
$ cat movepages.c
#include <stdio.h>
#include <stdlib.h>
#include <numaif.h>
#define ADDR_INPUT 0x700000000000UL
#define HPS 0x200000
#define PS 0x1000
int main(int argc, char *argv[]) {
int i;
int nr_hp = strtol(argv[1], NULL, 0);
int nr_p = nr_hp * HPS / PS;
int ret;
void **addrs;
int *status;
int *nodes;
pid_t pid;
pid = strtol(argv[2], NULL, 0);
addrs = malloc(sizeof(char *) * nr_p + 1);
status = malloc(sizeof(char *) * nr_p + 1);
nodes = malloc(sizeof(char *) * nr_p + 1);
while (1) {
for (i = 0; i < nr_p; i++) {
addrs[i] = (void *)ADDR_INPUT + i * PS;
nodes[i] = 1;
status[i] = 0;
ret = numa_move_pages(pid, nr_p, addrs, nodes, status,
MPOL_MF_MOVE_ALL);
if (ret == -1)
err("move_pages");
nodes[i] = 0;
status[i] = 0;
MPOL_MF_MOVE_ALL);
if (ret == -1)
err("move_pages");
return 0;
$ cat hugepage.c
#include <stdio.h>
#include <string.h>
char *p;
while (1) {
p = mmap((void *)ADDR_INPUT, nr_hp * HPS, PROT_READ | PROT_WRITE,
MAP_PRIVATE | MAP_ANONYMOUS | MAP_HUGETLB, -1, 0);
if (p != (void *)ADDR_INPUT) {
perror("mmap");
break;
memset(p, 0, nr_hp * HPS);
munmap(p, nr_hp * HPS);
$ sysctl vm.nr_hugepages=40
$ ./hugepage 10 &
$ ./movepages 10 $(pgrep -f hugepage)
Fixes: e632a938d914 ("mm: migrate: add hugepage migration code to move_pages()")
Reported-by: Hugh Dickins <hughd@google.com>
Cc: <stable@vger.kernel.org> [3.12+]
Migrating hugepages and hwpoisoned hugepages are considered as non-present
hugepages, and they are referenced via migration entries and hwpoison
entries in their page table slots.
This behavior causes race condition because pmd_huge() doesn't tell
non-huge pages from migrating/hwpoisoned hugepages. follow_page_mask() is
one example where the kernel would call follow_page_pte() for such
hugepage while this function is supposed to handle only normal pages.
To avoid this, this patch makes pmd_huge() return true when pmd_none() is
true *and* pmd_present() is false. We don't have to worry about mixing up
non-present pmd entry with normal pmd (pointing to leaf level pte entry)
because pmd_present() is true in normal pmd.
The same race condition could happen in (x86-specific) gup_pmd_range(),
where this patch simply adds pmd_present() check instead of pmd_huge().
This is because gup_pmd_range() is fast path. If we have non-present
hugepage in this function, we will go into gup_huge_pmd(), then return 0
at flag mask check, and finally fall back to the slow path.
Currently we have many duplicates in definitions around
follow_huge_addr(), follow_huge_pmd(), and follow_huge_pud(), so this
patch tries to remove the m. The basic idea is to put the default
implementation for these functions in mm/hugetlb.c as weak symbols
(regardless of CONFIG_ARCH_WANT_GENERAL_HUGETL B), and to implement
arch-specific code only when the arch needs it.
For follow_huge_addr(), only powerpc and ia64 have their own
implementation, and in all other architectures this function just returns
ERR_PTR(-EINVAL). So this patch sets returning ERR_PTR(-EINVAL) as
default.
As for follow_huge_(pmd|pud)(), if (pmd|pud)_huge() is implemented to
always return 0 in your architecture (like in ia64 or sparc,) it's never
called (the callsite is optimized away) no matter how implemented it is.
So in such architectures, we don't need arch-specific implementation.
In some architecture (like mips, s390 and tile,) their current
arch-specific follow_huge_(pmd|pud)() are effectively identical with the
common code, so this patch lets these architecture use the common code.
One exception is metag, where pmd_huge() could return non-zero but it
expects follow_huge_pmd() to always return NULL. This means that we need
arch-specific implementation which returns NULL. This behavior looks
strange to me (because non-zero pmd_huge() implies that the architecture
supports PMD-based hugepage, so follow_huge_pmd() can/should return some
relevant value,) but that's beyond this cleanup patch, so let's keep it.
Justification of non-trivial changes:
- in s390, follow_huge_pmd() checks !MACHINE_HAS_HPAGE at first, and this
patch removes the check. This is OK because we can assume MACHINE_HAS_HPAGE
is true when follow_huge_pmd() can be called (note that pmd_huge() has
the same check and always returns 0 for !MACHINE_HAS_HPAGE.)
- in s390 and mips, we use HPAGE_MASK instead of PMD_MASK as done in common
code. This patch forces these archs use PMD_MASK, but it's OK because
they are identical in both archs.
In s390, both of HPAGE_SHIFT and PMD_SHIFT are 20.
In mips, HPAGE_SHIFT is defined as (PAGE_SHIFT + PAGE_SHIFT - 3) and
PMD_SHIFT is define as (PAGE_SHIFT + PAGE_SHIFT + PTE_ORDER - 3), but
PTE_ORDER is always 0, so these are identical.
Kswapd in balance_pgdate() currently uses wake_up() on processes waiting
in throttle_direct_reclaim(), which only wakes up a single process. This
might leave processes waiting for longer than necessary, until the check
is reached in the next loop iteration. Processes might also be left
waiting if zone was fully balanced in single iteration. Note that the
comment in balance_pgdat() also says "Wake them", so waking up a single
process does not seem intentional.
Thus, replace wake_up() with wake_up_all().
Now kmemcheck_pagealloc_alloc() is only called by __alloc_pages_slowpath().
And the page will not be tracked by kmemcheck in the following path.
So move kmemcheck_pagealloc_alloc() into __alloc_pages_nodemask(),
like this:
if (!page)
Signed-off-by: Xishi Qiu <qiuxishi@huawei.com>
Cc: Vegard Nossum <vegard.nossum@oracle.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Li Zefan <lizefan@huawei.com>
__alloc_pages_nodemask() strips __GFP_IO when retrying the page
allocation. But it does this by altering the function-wide variable
gfp_mask. This will cause subsequent allocation attempts to inadvertently
use the modified gfp_mask.
Also, pass the correct mask (the mask we actually used) into
trace_mm_page_alloc().
Cc: Ming Lei <ming.lei@canonical.com>
Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
The complexity of memcg page stat synchronization is currently leaking
into the callsites, forcing them to keep track of the move_lock state and
the IRQ flags. Simplify the API by tracking it in the memcg.
Cc: Wu Fengguang <fengguang.wu@intel.com>
The body of this function was removed by commit 0a31bc97c80c ("mm:
memcontrol: rewrite uncharge API").
OOM killer tries to exclude tasks which do not have mm_struct associated
because killing such a task wouldn't help much. The OOM victim gets
TIF_MEMDIE set to disable OOM killer while the current victim releases the
memory and then enables the OOM killer again by dropping the flag.
oom_kill_process is currently prone to a race condition when the OOM
victim is already exiting and TIF_MEMDIE is set after the task releases
its address space. This might theoretically lead to OOM livelock if the
OOM victim blocks on an allocation later during exiting because it
wouldn't kill any other process and the exiting one won't be able to exit.
The situation is highly unlikely because the OOM victim is expected to
release some memory which should help to sort out OOM situation.
Fix this by checking task->mm and setting TIF_MEMDIE flag under task_lock
which will serialize the OOM killer with exit_mm which sets task->mm to
NULL. Setting the flag for current is not necessary because check and set
is not racy.
Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
out_of_memory() doesn't trigger the OOM killer if the current task is
already exiting or it has fatal signals pending, and gives the task
access to memory reserves instead. However, doing so is wrong if
out_of_memory() is called by an allocation (e.g. from exit_task_work())
after the current task has already released its memory and cleared
TIF_MEMDIE at exit_mm(). If we again set TIF_MEMDIE to post-exit_mm()
current task, the OOM killer will be blocked by the task sitting in the
final schedule() waiting for its parent to reap it. It will trigger an
OOM livelock if its parent is unable to reap it due to doing an
allocation and waiting for the OOM killer to kill it.
Add KPF_ZERO_PAGE flag for zero_page, so that userspace processes can
detect zero_page in /proc/kpageflags, and then do memory analysis more
accurately.
Signed-off-by: Yalin Wang <yalin.wang@sonymobile.com>
Acked-by: Kirill A. Shutemov <kirill@shutemov.name>
Cc: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Pull trivial tree changes from Jiri Kosina:
"Patches from trivial.git that keep the world turning around.
Mostly documentation and comment fixes, and a two corner-case code
fixes from Alan Cox"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial:
kexec, Kconfig: spell "architecture" properly
mm: fix cleancache debugfs directory path
blackfin: mach-common: ints-priority: remove unused function
doubletalk: probe failure causes OOPS
ARM: cache-l2x0.c: Make it clear that cache-l2x0 handles L310 cache controller
msdos_fs.h: fix 'fields' in comment
scsi: aic7xxx: fix comment
ARM: l2c: fix comment
ibmraid: fix writeable attribute with no store method
dynamic_debug: fix comment
doc: usbmon: fix spelling s/unpriviledged/unprivileged/
x86: init_mem_mapping(): use capital BIOS in comment
Merge misc updates from Andrew Morton:
"Bite-sized chunks this time, to avoid the MTA ratelimiting woes.
- fs/notify updates
- ocfs2
- some of MM"
That laconic "some MM" is mainly the removal of remap_file_pages(),
which is a big simplification of the VM, and which gets rid of a *lot*
of random cruft and special cases because we no longer support the
non-linear mappings that it used.
From a user interface perspective, nothing has changed, because the
remap_file_pages() syscall still exists, it's just done by emulating the
old behavior by creating a lot of individual small mappings instead of
one non-linear one.
The emulation is slower than the old "native" non-linear mappings, but
nobody really uses or cares about remap_file_pages(), and simplifying
the VM is a big advantage.
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (78 commits)
memcg: zap memcg_slab_caches and memcg_slab_mutex
memcg: zap memcg_name argument of memcg_create_kmem_cache
memcg: zap __memcg_{charge,uncharge}_slab
mm/page_alloc.c: place zone_id check before VM_BUG_ON_PAGE check
mm: hugetlb: fix type of hugetlb_treat_as_movable variable
mm, hugetlb: remove unnecessary lower bound on sysctl handlers"?
mm: memory: merge shared-writable dirtying branches in do_wp_page()
mm: memory: remove ->vm_file check on shared writable vmas
xtensa: drop _PAGE_FILE and pte_file()-related helpers
x86: drop _PAGE_FILE and pte_file()-related helpers
unicore32: drop pte_file()-related helpers
um: drop _PAGE_FILE and pte_file()-related helpers
tile: drop pte_file()-related helpers
sparc: drop pte_file()-related helpers
sh: drop _PAGE_FILE and pte_file()-related helpers
score: drop _PAGE_FILE and pte_file()-related helpers
s390: drop pte_file()-related helpers
parisc: drop _PAGE_FILE and pte_file()-related helpers
openrisc: drop _PAGE_FILE and pte_file()-related helpers
nios2: drop _PAGE_FILE and pte_file()-related helpers
mem_cgroup->memcg_slab_caches is a list of kmem caches corresponding to
the given cgroup. Currently, it is only used on css free in order to
destroy all caches corresponding to the memory cgroup being freed. The
list is protected by memcg_slab_mutex. The mutex is also used to protect
kmem_cache->memcg_params->memcg_caches arrays and synchronizes
kmem_cache_destroy vs memcg_unregister_all_caches.
However, we can perfectly get on without these two. To destroy all caches
corresponding to a memory cgroup, we can walk over the global list of kmem
caches, slab_caches, and we can do all the synchronization stuff using the
slab_mutex instead of the memcg_slab_mutex. This patch therefore gets rid
of the memcg_slab_caches and memcg_slab_mutex.
Apart from this nice cleanup, it also:
- assures that rcu_barrier() is called once at max when a root cache is
destroyed or a memory cgroup is freed, no matter how many caches have
SLAB_DESTROY_BY_RCU flag set;
- fixes the race between kmem_cache_destroy and kmem_cache_create that
exists, because memcg_cleanup_cache_params, which is called from
kmem_cache_destroy after checking that kmem_cache->refcount=0,
releases the slab_mutex, which gives kmem_cache_create a chance to
make an alias to a cache doomed to be destroyed.
Acked-by: Christoph Lameter <cl@linux.com>
Instead of passing the name of the memory cgroup which the cache is
created for in the memcg_name_argument, let's obtain it immediately in
memcg_create_kmem_cache.
They are simple wrappers around memcg_{charge,uncharge}_kmem, so let's
zap them and call these functions directly.
If the freeing page and its buddy page are not at the same zone, the
current holding zone->lock for the freeing page cann't prevent buddy page
getting allocated, this could trigger VM_BUG_ON_PAGE in page_is_buddy() at
a very tiny chance, such as:
cpu 0: cpu 1:
hold zone_1 lock
check page and it buddy
PageBuddy(buddy) is true hold zone_2 lock
page_order(buddy) == order is true alloc buddy
trigger VM_BUG_ON_PAGE(page_count(buddy) != 0)
zone_1->lock prevents the freeing page getting allocated
zone_2->lock prevents the buddy page getting allocated
they are not the same zone->lock.
If we can't remove the zone_id check statement, it's better handle this
rare race. This patch fixes this by placing the zone_id check before the
VM_BUG_ON_PAGE check.
Signed-off-by: Weijie Yang <weijie.yang@samsung.com>
hugetlb_treat_as_movable declared as unsigned long, but
proc_dointvec() used for parsing it:
static struct ctl_table vm_table[] = {
.procname = "hugepages_treat_as_movable",
.data = &hugepages_treat_as_movable,
.maxlen = sizeof(int),
.mode = 0644,
.proc_handler = proc_dointvec,
This seems harmless, but it's better to use int type here.
Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Manfred Spraul <manfred@colorfullife.com>
Acked-by: David Rientjes <rientjes@google.com>
Whether there is a vm_ops->page_mkwrite or not, the page dirtying is
pretty much the same. Make sure the page references are the same in both
cases, then merge the two branches.
It's tempting to go even further and page-lock the !page_mkwrite case, to
get it in line with everybody else setting the page table and thus further
simplify the model. But that's not quite compelling enough to justify
dropping the pte lock, then relocking and verifying the entry for
filesystems without ->page_mkwrite, which notably includes tmpfs. Leave
it for now and lock the page late in the !page_mkwrite case.
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Shared anonymous mmaps are implemented with shmem files, so all VMAs with
shared writable semantics also have an underlying backing file.
One bit in ->vm_flags is unused now!
Cc: Dan Carpenter <dan.carpenter@oracle.com>
After removing vma->shared.nonlinear we have only one member of
vma->shared union, which doesn't make much sense.
This patch drops the union and move struct vma->shared.linear to
vma->shared.
We don't create non-linear mappings anymore. Let's drop code which
handles them in rmap.
Nobody uses it anymore.
[akpm@linux-foundation.org: fix filemap_xip.c]
handles them on page fault.
We have remap_file_pages(2) emulation in -mm tree for few release cycles
and we plan to have it mainline in v3.20. This patchset removes rest of
VM_NONLINEAR infrastructure.
Patches 1-8 take care about generic code. They are pretty
straight-forward and can be applied without other of patches.
Rest patches removes pte_file()-related stuff from architecture-specific
code. It usually frees up one bit in non-present pte. I've tried to reuse
that bit for swap offset, where I was able to figure out how to do that.
For obvious reason I cannot test all that arch-specific code and would
like to see acks from maintainers.
In total, remap_file_pages(2) required about 1.4K lines of not-so-trivial
kernel code. That's too much for functionality nobody uses.
Tested-by: Felipe Balbi <balbi@ti.com>
This patch (of 38):
handles them on unmap/zap.
remap_file_pages(2) was invented to be able efficiently map parts of
huge file into limited 32-bit virtual address space such as in database
workloads.
Nonlinear mappings are pain to support and it seems there's no
legitimate use-cases nowadays since 64-bit systems are widely available.
Let's drop it and get rid of all these special-cased code.
The patch replaces the syscall with emulation which creates new VMA on
each remap_file_pages(), unless they it can be merged with an adjacent
one.
I didn't find *any* real code that uses remap_file_pages(2) to test
emulation impact on. I've checked Debian code search and source of all
packages in ALT Linux. No real users: libc wrappers, mentions in
strace, gdb, valgrind and this kind of stuff.
There are few basic tests in LTP for the syscall. They work just fine
with emulation.
To test performance impact, I've written small test case which
demonstrate pretty much worst case scenario: map 4G shmfs file, write to
begin of every page pgoff of the page, remap pages in reverse order,
read every page.
The test creates 1 million of VMAs if emulation is in use, so I had to
set vm.max_map_count to 1100000 to avoid -ENOMEM.
Before: 23.3 ( +- 4.31% ) seconds
After: 43.9 ( +- 0.85% ) seconds
Slowdown: 1.88x
I believe we can live with that.
Test case:
#define _GNU_SOURCE
#include <assert.h>
#include <stdlib.h>
#include <stdio.h>
#define MB (1024UL * 1024)
#define SIZE (4096 * MB)
int main(int argc, char **argv)
unsigned long *p;
long i, pass;
for (pass = 0; pass < 10; pass++) {
p = mmap(NULL, SIZE, PROT_READ|PROT_WRITE,
MAP_SHARED | MAP_ANONYMOUS, -1, 0);
if (p == MAP_FAILED) {
perror("mmap");
return -1;
for (i = 0; i < SIZE / 4096; i++)
p[i * 4096 / sizeof(*p)] = i;
for (i = 0; i < SIZE / 4096; i++) {
if (remap_file_pages(p + i * 4096 / sizeof(*p), 4096,
0, (SIZE - 4096 * (i + 1)) >> 12, 0)) {
perror("remap_file_pages");
return -1;
for (i = SIZE / 4096 - 1; i >= 0; i--)
assert(p[i * 4096 / sizeof(*p)] == SIZE / 4096 - i - 1);
munmap(p, SIZE);
return 0;
[akpm@linux-foundation.org: fix spello]
[sasha.levin@oracle.com: initialize populate before usage]
[sasha.levin@oracle.com: grab file ref to prevent race while mmaping]
Signed-off-by: "Kirill A. Shutemov" <kirill@shutemov.name>
Cc: Dave Jones <davej@redhat.com>
Cc: Armin Rigo <arigo@tunes.org>
