Patch series "userfaultfd: non-cooperative: better tracking for mapping
changes", v2.
These patches try to address issues I've encountered during integration
of userfaultfd with CRIU.
Previously added userfaultfd events for fork(), madvise() and mremap()
unfortunately do not cover all possible changes to a process virtual
memory layout required for uffd monitor.
When one or more VMAs is removed from the process mm, the external uffd
monitor has no way to detect those changes and will attempt to fill the
removed regions with userfaultfd_copy.
Another problematic event is the exit() of the process. Here again, the
external uffd monitor will try to use userfaultfd_copy, although mm
owning the memory has already gone.
The first patch in the series is a minor cleanup and it's not strictly
related to the rest of the series.
The patches 2 and 3 below add UFFD_EVENT_UNMAP and UFFD_EVENT_EXIT to
allow the uffd monitor track changes in the memory layout of a process.
The patches 4 and 5 amend error codes returned by userfaultfd_copy to
make the uffd monitor able to cope with races that might occur between
delivery of unmap and exit events and outstanding userfaultfd_copy's.
This patch (of 5):
Commit dc0ef0df7b6a ("mm: make mmap_sem for write waits killable for mm
syscalls") replaced call to vm_munmap in munmap syscall with open coded
version to allow different waits on mmap_sem in munmap syscall and
vm_munmap.
Now both functions use down_write_killable, so we can restore the call
to vm_munmap from the munmap system call.
Link: http://lkml.kernel.org/r/1485542673-24387-2-git-send-email-rppt@linux.vnet.ibm.com
Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com>
Acked-by: Hillf Danton <hillf.zj@alibaba-inc.com>
Cc: "Dr. David Alan Gilbert" <dgilbert@redhat.com>
Cc: Mike Kravetz <mike.kravetz@oracle.com>
Cc: Pavel Emelyanov <xemul@virtuozzo.com>
remove_migration_pte() also can easily be converted to
page_vma_mapped_walk().
Link: http://lkml.kernel.org/r/20170129173858.45174-13-kirill.shutemov@linux.intel.com
Cc: Hillf Danton <hillf.zj@alibaba-inc.com>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Cc: Vladimir Davydov <vdavydov.dev@gmail.com>
All users are gone. Let's drop them.
Link: http://lkml.kernel.org/r/20170129173858.45174-12-kirill.shutemov@linux.intel.com
For consistency, it worth converting all page_check_address() to
page_vma_mapped_walk(), so we could drop the former.
Link: http://lkml.kernel.org/r/20170129173858.45174-11-kirill.shutemov@linux.intel.com
Link: http://lkml.kernel.org/r/20170129173858.45174-9-kirill.shutemov@linux.intel.com
It also makes freeze_page() as we walk though rmap only once.
Link: http://lkml.kernel.org/r/20170129173858.45174-8-kirill.shutemov@linux.intel.com
PMD handling here is future-proofing, we don't have users yet. ext4
with huge pages will be the first.
Link: http://lkml.kernel.org/r/20170129173858.45174-7-kirill.shutemov@linux.intel.com
Current rmap code can miss a VMA that maps PTE-mapped THP if the first
suppage of the THP was unmapped from the VMA.
We need to walk rmap for the whole range of offsets that THP covers, not
only the first one.
vma_address() also need to be corrected to check the range instead of
the first subpage.
Link: http://lkml.kernel.org/r/20170129173858.45174-6-kirill.shutemov@linux.intel.com
For PTE-mapped THP page_check_address_transhuge() is not adequate: it
cannot find all relevant PTEs, only the first one.i
Let's switch it to page_vma_mapped_walk().
I don't think it's subject for stable@: it's not fatal.
Link: http://lkml.kernel.org/r/20170129173858.45174-5-kirill.shutemov@linux.intel.com
cannot find all relevant PTEs, only the first one. It means we can miss
some references of the page and it can result in suboptimal decisions by
vmscan.
I don't think it's subject for stable@: it's not fatal. The only side
effect is that THP can be swapped out when it shouldn't.
Link: http://lkml.kernel.org/r/20170129173858.45174-4-kirill.shutemov@linux.intel.com
Introduce a new interface to check if a page is mapped into a vma. It
aims to address shortcomings of page_check_address{,_transhuge}.
Existing interface is not able to handle PTE-mapped THPs: it only finds
the first PTE. The rest lefted unnoticed.
page_vma_mapped_walk() iterates over all possible mapping of the page in
the vma.
Link: http://lkml.kernel.org/r/20170129173858.45174-3-kirill.shutemov@linux.intel.com
We had considered all of the non-lru pages as unmovable before commit
bda807d44454 ("mm: migrate: support non-lru movable page migration").
But now some of non-lru pages like zsmalloc, virtio-balloon pages also
become movable. So we can offline such blocks by using non-lru page
migration.
This patch straightforwardly adds non-lru migration code, which means
adding non-lru related code to the functions which scan over pfn and
collect pages to be migrated and isolate them before migration.
Signed-off-by: Yisheng Xie <xieyisheng1@huawei.com>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Hanjun Guo <guohanjun@huawei.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Mel Gorman <mgorman@techsingularity.net>
Cc: Reza Arbab <arbab@linux.vnet.ibm.com>
Cc: Taku Izumi <izumi.taku@jp.fujitsu.com>
Cc: Vitaly Kuznetsov <vkuznets@redhat.com>
Cc: Xishi Qiu <qiuxishi@huawei.com>
Cc: Yisheng Xie <xieyisheng1@huawei.com>
Extend soft offlining framework to support non-lru page, which already
support migration after commit bda807d44454 ("mm: migrate: support
When memory corrected errors occur on a non-lru movable page, we can
choose to stop using it by migrating data onto another page and disable
the original (maybe half-broken) one.
Link: http://lkml.kernel.org/r/1485867981-16037-4-git-send-email-ysxie@foxmail.com
Suggested-by: Michal Hocko <mhocko@kernel.org>
Suggested-by: Minchan Kim <minchan@kernel.org>
Reviewed-by: Minchan Kim <minchan@kernel.org>
Acked-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Patch series "HWPOISON: soft offlining for non-lru movable page", v6.
After Minchan's commit bda807d44454 ("mm: migrate: support non-lru
movable page migration"), some type of non-lru page like zsmalloc and
virtio-balloon page also support migration.
Therefore, we can:
1) soft offlining no-lru movable pages, which means when memory
corrected errors occur on a non-lru movable page, we can stop to use
it by migrating data onto another page and disable the original
2) enable memory hotplug for non-lru movable pages, i.e. we may offline
blocks, which include such pages, by using non-lru page migration.
This patchset is heavily dependent on non-lru movable page migration.
This patch (of 4):
Change the return type of isolate_movable_page() from bool to int. It
will return 0 when isolate movable page successfully, and return -EBUSY
when it isolates failed.
There is no functional change within this patch but prepare for later
patch.
[xieyisheng1@huawei.com: v6]
Link: http://lkml.kernel.org/r/1486108770-630-2-git-send-email-xieyisheng1@huawei.com
Link: http://lkml.kernel.org/r/1485867981-16037-2-git-send-email-ysxie@foxmail.com
Acked-by: Minchan Kim <minchan@kernel.org>
With both coming and already present locking optimizations, introducing
kref to reference-count z3fold objects is the right thing to do.
Moreover, it makes buddied list no longer necessary, and allows for a
simpler handling of headless pages.
Link: http://lkml.kernel.org/r/20170131214650.8ea78033d91ded233f552bc0@gmail.com
Signed-off-by: Vitaly Wool <vitalywool@gmail.com>
Reviewed-by: Dan Streetman <ddstreet@ieee.org>
Most of z3fold operations are in-page, such as modifying z3fold page
header or moving z3fold objects within a page. Taking per-pool spinlock
to protect per-page objects is therefore suboptimal, and the idea of
having a per-page spinlock (or rwlock) has been around for some time.
This patch implements spinlock-based per-page locking mechanism which is
lightweight enough to normally fit ok into the z3fold header.
Link: http://lkml.kernel.org/r/20170131214438.433e0a5fda908337b63206d3@gmail.com
z3fold_compact_page() currently only handles the situation when there's
a single middle chunk within the z3fold page. However it may be worth
it to move middle chunk closer to either first or last chunk, whichever
is there, if the gap between them is big enough.
This patch adds the relevant code, using BIG_CHUNK_GAP define as a
threshold for middle chunk to be worth moving.
Link: http://lkml.kernel.org/r/20170131214334.c4f3eac9a477af0fa9a22c46@gmail.com
Currently the whole kernel build will be stopped if the size of struct
z3fold_header is greater than the size of one chunk, which is 64 bytes
by default. This patch instead defines the offset for z3fold objects as
the size of the z3fold header in chunks.
Fixed also are the calculation of num_free_chunks() and the address to
move the middle chunk to in case of in-page compaction in
z3fold_compact_page().
Link: http://lkml.kernel.org/r/20170131214057.d98677032bc7b1c6c59a80c9@gmail.com
Convert pages_nr per-pool counter to atomic64_t.
Link: http://lkml.kernel.org/r/20170131213946.b828676ab17bbea42022c213@gmail.com
Since the introduction of FAULT_FLAG_SIZE to the vm_fault flag, it has
been somewhat painful with getting the flags set and removed at the
correct locations. More than one kernel oops was introduced due to
difficulties of getting the placement correctly.
Remove the flag values and introduce an input parameter to huge_fault
that indicates the size of the page entry. This makes the code easier
to trace and should avoid the issues we see with the fault flags where
removal of the flag was necessary in the fallback paths.
Link: http://lkml.kernel.org/r/148615748258.43180.1690152053774975329.stgit@djiang5-desk3.ch.intel.com
Signed-off-by: Dave Jiang <dave.jiang@intel.com>
Tested-by: Dan Williams <dan.j.williams@intel.com>
Cc: Matthew Wilcox <mawilcox@microsoft.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Nilesh Choudhury <nilesh.choudhury@oracle.com>
The current transparent hugepage code only supports PMDs. This patch
adds support for transparent use of PUDs with DAX. It does not include
support for anonymous pages. x86 support code also added.
Most of this patch simply parallels the work that was done for huge
PMDs. The only major difference is how the new ->pud_entry method in
mm_walk works. The ->pmd_entry method replaces the ->pte_entry method,
whereas the ->pud_entry method works along with either ->pmd_entry or
->pte_entry. The pagewalk code takes care of locking the PUD before
calling ->pud_walk, so handlers do not need to worry whether the PUD is
stable.
[dave.jiang@intel.com: fix SMP x86 32bit build for native_pud_clear()]
Link: http://lkml.kernel.org/r/148719066814.31111.3239231168815337012.stgit@djiang5-desk3.ch.intel.com
[dave.jiang@intel.com: native_pud_clear missing on i386 build]
Link: http://lkml.kernel.org/r/148640375195.69754.3315433724330910314.stgit@djiang5-desk3.ch.intel.com
Link: http://lkml.kernel.org/r/148545059381.17912.8602162635537598445.stgit@djiang5-desk3.ch.intel.com
Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com>
Tested-by: Alexander Kapshuk <alexander.kapshuk@gmail.com>
Cc: Jan Kara <jack@suse.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Patch series "1G transparent hugepage support for device dax", v2.
The following series implements support for 1G trasparent hugepage on
x86 for device dax. The bulk of the code was written by Mathew Wilcox a
while back supporting transparent 1G hugepage for fs DAX. I have
forward ported the relevant bits to 4.10-rc. The current submission has
only the necessary code to support device DAX.
Comments from Dan Williams: So the motivation and intended user of this
functionality mirrors the motivation and users of 1GB page support in
hugetlbfs. Given expected capacities of persistent memory devices an
in-memory database may want to reduce tlb pressure beyond what they can
already achieve with 2MB mappings of a device-dax file. We have
customer feedback to that effect as Willy mentioned in his previous
version of these patches [1].
[1]: https://lkml.org/lkml/2016/1/31/52
Comments from Nilesh @ Oracle:
There are applications which have a process model; and if you assume
10,000 processes attempting to mmap all the 6TB memory available on a
server; we are looking at the following:
processes : 10,000
memory : 6TB
pte @ 4k page size: 8 bytes / 4K of memory * #processes = 6TB / 4k * 8 * 10000 = 1.5GB * 80000 = 120,000GB
pmd @ 2M page size: 120,000 / 512 = ~240GB
pud @ 1G page size: 240GB / 512 = ~480MB
As you can see with 2M pages, this system will use up an exorbitant
amount of DRAM to hold the page tables; but the 1G pages finally brings
it down to a reasonable level. Memory sizes will keep increasing; so
this number will keep increasing.
An argument can be made to convert the applications from process model
to thread model, but in the real world that may not be always practical.
Hopefully this helps explain the use case where this is valuable.
This patch (of 3):
In preparation for adding the ability to handle PUD pages, convert
vm_operations_struct.pmd_fault to vm_operations_struct.huge_fault. The
vm_fault structure is extended to include a union of the different page
table pointers that may be needed, and three flag bits are reserved to
indicate which type of pointer is in the union.
[ross.zwisler@linux.intel.com: remove unused function ext4_dax_huge_fault()]
Link: http://lkml.kernel.org/r/1485813172-7284-1-git-send-email-ross.zwisler@linux.intel.com
[dave.jiang@intel.com: clear PMD or PUD size flags when in fall through path]
Link: http://lkml.kernel.org/r/148589842696.5820.16078080610311444794.stgit@djiang5-desk3.ch.intel.com
Link: http://lkml.kernel.org/r/148545058784.17912.6353162518188733642.stgit@djiang5-desk3.ch.intel.com
Signed-off-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Cc: Dave Jiang <dave.jiang@intel.com>
As suggested by Vlastimil Babka and Tejun Heo, this patch uses a static
work_struct to co-ordinate the draining of per-cpu pages on the
workqueue. Only one task can drain at a time but this is better than
the previous scheme that allowed multiple tasks to send IPIs at a time.
One consideration is whether parallel requests should synchronise
against each other. This patch does not synchronise for a global drain
as the common case for such callers is expected to be multiple parallel
direct reclaimers competing for pages when the watermark is close to
min. Draining the per-cpu list is unlikely to make much progress and
serialising the drain is of dubious merit. Drains are synchonrised for
callers such as memory hotplug and CMA that care about the drain being
complete when the function returns.
Link: http://lkml.kernel.org/r/20170125083038.rzb5f43nptmk7aed@techsingularity.net
Signed-off-by: Mel Gorman <mgorman@techsingularity.net>
Suggested-by: Tejun Heo <tj@kernel.org>
Suggested-by: Vlastimil Babka <vbabka@suse.cz>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Jesper Dangaard Brouer <brouer@redhat.com>
Since commit 682a3385e773 ("mm, page_alloc: inline the fast path of the
zonelist iterator") we replace a NULL nodemask with
cpuset_current_mems_allowed in the fast path, so that
get_page_from_freelist() filters nodes allowed by the cpuset via
for_next_zone_zonelist_nodemask().
In that case it's pointless to additionaly check __cpuset_zone_allowed()
in each iteration, which we can avoid by not adding ALLOC_CPUSET to
alloc_flags in that scenario.
This saves some cycles in the allocator fast path on systems with one or
more non-root cpuset configured. In the slow path, ALLOC_CPUSET is
reset according to __alloc_pages_slowpath(). Without configured
cpusets, this code is disabled by a static key.
Link: http://lkml.kernel.org/r/20170124150511.5710-2-vbabka@suse.cz
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
Reviewed-by: Anshuman Khandual <khandual@linux.vnet.ibm.com>
Cc: Anshuman Khandual <khandual@linux.vnet.ibm.com>
The allocation fast path contains two similar checks for zoneref->zone
being NULL, where zoneref points either to the first zone in the
zonelist, or to the preferred zone. These can be NULL either due to
empty zonelist, or no zone being compatible with given nodemask or
task's cpuset.
These checks are unnecessary, because the zonelist walks in
first_zones_zonelist() and get_page_from_freelist() handle a NULL
starting zoneref->zone or preferred_zoneref->zone safely. It's safe to
fallback to __alloc_pages_slowpath() where we also have the check early
enough.
Link: http://lkml.kernel.org/r/20170124150511.5710-1-vbabka@suse.cz
mmap_init() is no longer associated with VMA slab. So fix it.
Link: http://lkml.kernel.org/r/1485182601-9294-1-git-send-email-iamyooon@gmail.com
Signed-off-by: seokhoon.yoon <iamyooon@gmail.com>
->fault(), ->page_mkwrite(), and ->pfn_mkwrite() calls do not need to
take a vma and vmf parameter when the vma already resides in vmf.
Remove the vma parameter to simplify things.
[arnd@arndb.de: fix ARM build]
Link: http://lkml.kernel.org/r/20170125223558.1451224-1-arnd@arndb.de
Link: http://lkml.kernel.org/r/148521301778.19116.10840599906674778980.stgit@djiang5-desk3.ch.intel.com
Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Darrick J. Wong <darrick.wong@oracle.com>
Many workloads that allocate pages are not handling an interrupt at a
time. As allocation requests may be from IRQ context, it's necessary to
disable/enable IRQs for every page allocation. This cost is the bulk of
the free path but also a significant percentage of the allocation path.
This patch alters the locking and checks such that only irq-safe
allocation requests use the per-cpu allocator. All others acquire the
irq-safe zone->lock and allocate from the buddy allocator. It relies on
disabling preemption to safely access the per-cpu structures. It could
be slightly modified to avoid soft IRQs using it but it's not clear it's
worthwhile.
This modification may slow allocations from IRQ context slightly but the
main gain from the per-cpu allocator is that it scales better for
allocations from multiple contexts. There is an implicit assumption
that intensive allocations from IRQ contexts on multiple CPUs from a
single NUMA node are rare and that the fast majority of scaling issues
are encountered in !IRQ contexts such as page faulting. It's worth
noting that this patch is not required for a bulk page allocator but it
significantly reduces the overhead.
The following is results from a page allocator micro-benchmark. Only
order-0 is interesting as higher orders do not use the per-cpu allocator
4.10.0-rc2 4.10.0-rc2
vanilla irqsafe-v1r5
Amean alloc-odr0-1 287.15 ( 0.00%) 219.00 ( 23.73%)
Amean alloc-odr0-2 221.23 ( 0.00%) 183.23 ( 17.18%)
Amean alloc-odr0-4 187.00 ( 0.00%) 151.38 ( 19.05%)
Amean alloc-odr0-8 167.54 ( 0.00%) 132.77 ( 20.75%)
Amean alloc-odr0-16 156.00 ( 0.00%) 123.00 ( 21.15%)
Amean alloc-odr0-32 149.00 ( 0.00%) 118.31 ( 20.60%)
Amean alloc-odr0-64 138.77 ( 0.00%) 116.00 ( 16.41%)
Amean alloc-odr0-128 145.00 ( 0.00%) 118.00 ( 18.62%)
Amean alloc-odr0-256 136.15 ( 0.00%) 125.00 ( 8.19%)
Amean alloc-odr0-512 147.92 ( 0.00%) 121.77 ( 17.68%)
Amean alloc-odr0-1024 147.23 ( 0.00%) 126.15 ( 14.32%)
Amean alloc-odr0-2048 155.15 ( 0.00%) 129.92 ( 16.26%)
Amean alloc-odr0-4096 164.00 ( 0.00%) 136.77 ( 16.60%)
Amean alloc-odr0-8192 166.92 ( 0.00%) 138.08 ( 17.28%)
Amean alloc-odr0-16384 159.00 ( 0.00%) 138.00 ( 13.21%)
Amean free-odr0-1 165.00 ( 0.00%) 89.00 ( 46.06%)
Amean free-odr0-2 113.00 ( 0.00%) 63.00 ( 44.25%)
Amean free-odr0-4 99.00 ( 0.00%) 54.00 ( 45.45%)
Amean free-odr0-8 88.00 ( 0.00%) 47.38 ( 46.15%)
Amean free-odr0-16 83.00 ( 0.00%) 46.00 ( 44.58%)
Amean free-odr0-32 80.00 ( 0.00%) 44.38 ( 44.52%)
Amean free-odr0-64 72.62 ( 0.00%) 43.00 ( 40.78%)
Amean free-odr0-128 78.00 ( 0.00%) 42.00 ( 46.15%)
Amean free-odr0-256 80.46 ( 0.00%) 57.00 ( 29.16%)
Amean free-odr0-512 96.38 ( 0.00%) 64.69 ( 32.88%)
Amean free-odr0-1024 107.31 ( 0.00%) 72.54 ( 32.40%)
Amean free-odr0-2048 108.92 ( 0.00%) 78.08 ( 28.32%)
Amean free-odr0-4096 113.38 ( 0.00%) 82.23 ( 27.48%)
Amean free-odr0-8192 112.08 ( 0.00%) 82.85 ( 26.08%)
Amean free-odr0-16384 110.38 ( 0.00%) 81.92 ( 25.78%)
Amean total-odr0-1 452.15 ( 0.00%) 308.00 ( 31.88%)
Amean total-odr0-2 334.23 ( 0.00%) 246.23 ( 26.33%)
Amean total-odr0-4 286.00 ( 0.00%) 205.38 ( 28.19%)
Amean total-odr0-8 255.54 ( 0.00%) 180.15 ( 29.50%)
Amean total-odr0-16 239.00 ( 0.00%) 169.00 ( 29.29%)
Amean total-odr0-32 229.00 ( 0.00%) 162.69 ( 28.96%)
Amean total-odr0-64 211.38 ( 0.00%) 159.00 ( 24.78%)
Amean total-odr0-128 223.00 ( 0.00%) 160.00 ( 28.25%)
Amean total-odr0-256 216.62 ( 0.00%) 182.00 ( 15.98%)
Amean total-odr0-512 244.31 ( 0.00%) 186.46 ( 23.68%)
Amean total-odr0-1024 254.54 ( 0.00%) 198.69 ( 21.94%)
Amean total-odr0-2048 264.08 ( 0.00%) 208.00 ( 21.24%)
Amean total-odr0-4096 277.38 ( 0.00%) 219.00 ( 21.05%)
Amean total-odr0-8192 279.00 ( 0.00%) 220.92 ( 20.82%)
Amean total-odr0-16384 269.38 ( 0.00%) 219.92 ( 18.36%)
This is the alloc, free and total overhead of allocating order-0 pages
in batches of 1 page up to 16384 pages. Avoiding disabling/enabling
overhead massively reduces overhead. Alloc overhead is roughly reduced
by 14-20% in most cases. The free path is reduced by 26-46% and the
total reduction is significant.
Many users require zeroing of pages from the page allocator which is the
vast cost of allocation. Hence, the impact on a basic page faulting
benchmark is not that significant
Hmean page_test 656632.98 ( 0.00%) 675536.13 ( 2.88%)
Hmean brk_test 3845502.67 ( 0.00%) 3867186.94 ( 0.56%)
Stddev page_test 10543.29 ( 0.00%) 4104.07 ( 61.07%)
Stddev brk_test 33472.36 ( 0.00%) 15538.39 ( 53.58%)
CoeffVar page_test 1.61 ( 0.00%) 0.61 ( 62.15%)
CoeffVar brk_test 0.87 ( 0.00%) 0.40 ( 53.84%)
Max page_test 666513.33 ( 0.00%) 678640.00 ( 1.82%)
Max brk_test 3882800.00 ( 0.00%) 3887008.66 ( 0.11%)
This is from aim9 and the most notable outcome is that fault variability
is reduced by the patch. The headline improvement is small as the
overall fault cost, zeroing, page table insertion etc dominate relative
to disabling/enabling IRQs in the per-cpu allocator.
Similarly, little benefit was seen on networking benchmarks both
localhost and between physical server/clients where other costs
dominate. It's possible that this will only be noticable on very high
speed networks.
Jesper Dangaard Brouer independently tested this with a separate
microbenchmark from
https://github.com/netoptimizer/prototype-kernel/tree/master/kernel/mm/bench
Micro-benchmarked with [1] page_bench02:
modprobe page_bench02 page_order=0 run_flags=$((2#010)) loops=$((10**8)); \
rmmod page_bench02 ; dmesg --notime | tail -n 4
Compared to baseline: 213 cycles(tsc) 53.417 ns
- against this : 184 cycles(tsc) 46.056 ns
- Saving : -29 cycles
- Very close to expected 27 cycles saving [see below [2]]
Micro benchmarking via time_bench_sample[3], we get the cost of these
operations:
time_bench: Type:for_loop Per elem: 0 cycles(tsc) 0.232 ns (step:0)
time_bench: Type:spin_lock_unlock Per elem: 33 cycles(tsc) 8.334 ns (step:0)
time_bench: Type:spin_lock_unlock_irqsave Per elem: 62 cycles(tsc) 15.607 ns (step:0)
time_bench: Type:irqsave_before_lock Per elem: 57 cycles(tsc) 14.344 ns (step:0)
time_bench: Type:spin_lock_unlock_irq Per elem: 34 cycles(tsc) 8.560 ns (step:0)
time_bench: Type:simple_irq_disable_before_lock Per elem: 37 cycles(tsc) 9.289 ns (step:0)
time_bench: Type:local_BH_disable_enable Per elem: 19 cycles(tsc) 4.920 ns (step:0)
time_bench: Type:local_IRQ_disable_enable Per elem: 7 cycles(tsc) 1.864 ns (step:0)
time_bench: Type:local_irq_save_restore Per elem: 38 cycles(tsc) 9.665 ns (step:0)
[Mel's patch removes a ^^^^^^^^^^^^^^^^] ^^^^^^^^^ expected saving - preempt cost
time_bench: Type:preempt_disable_enable Per elem: 11 cycles(tsc) 2.794 ns (step:0)
[adds a preempt ^^^^^^^^^^^^^^^^^^^^^^] ^^^^^^^^^ adds this cost
time_bench: Type:funcion_call_cost Per elem: 6 cycles(tsc) 1.689 ns (step:0)
time_bench: Type:func_ptr_call_cost Per elem: 11 cycles(tsc) 2.767 ns (step:0)
time_bench: Type:page_alloc_put Per elem: 211 cycles(tsc) 52.803 ns (step:0)
Thus, expected improvement is: 38-11 = 27 cycles.
[mgorman@techsingularity.net: s/preempt_enable_no_resched/preempt_enable/]
Link: http://lkml.kernel.org/r/20170208143128.25ahymqlyspjcixu@techsingularity.net
Link: http://lkml.kernel.org/r/20170123153906.3122-5-mgorman@techsingularity.net
Acked-by: Jesper Dangaard Brouer <brouer@redhat.com>
Dmitry has reported the following lockdep splat
lock_acquire+0x2a1/0x630 kernel/locking/lockdep.c:3753
__mutex_lock_common kernel/locking/mutex.c:521 [inline]
mutex_lock_nested+0x24e/0xff0 kernel/locking/mutex.c:621
pcpu_alloc+0xbda/0x1280 mm/percpu.c:896
__alloc_percpu+0x24/0x30 mm/percpu.c:1075
smpcfd_prepare_cpu+0x73/0xd0 kernel/smp.c:44
cpuhp_invoke_callback+0x254/0x1480 kernel/cpu.c:136
cpuhp_up_callbacks+0x81/0x2a0 kernel/cpu.c:493
_cpu_up+0x1e3/0x2a0 kernel/cpu.c:1057
do_cpu_up+0x73/0xa0 kernel/cpu.c:1087
cpu_up+0x18/0x20 kernel/cpu.c:1095
smp_init+0xe9/0xee kernel/smp.c:564
kernel_init_freeable+0x439/0x690 init/main.c:1010
kernel_init+0x13/0x180 init/main.c:941
ret_from_fork+0x2a/0x40 arch/x86/entry/entry_64.S:433
cpu_hotplug_begin
cpu_hotplug.lock
pcpu_alloc
pcpu_alloc_mutex
get_online_cpus+0x62/0x90 kernel/cpu.c:248
drain_all_pages+0xf8/0x710 mm/page_alloc.c:2385
__alloc_pages_direct_reclaim mm/page_alloc.c:3440 [inline]
__alloc_pages_slowpath+0x8fd/0x2370 mm/page_alloc.c:3778
__alloc_pages_nodemask+0x8f5/0xc60 mm/page_alloc.c:3980
__alloc_pages include/linux/gfp.h:426 [inline]
__alloc_pages_node include/linux/gfp.h:439 [inline]
alloc_pages_node include/linux/gfp.h:453 [inline]
pcpu_alloc_pages mm/percpu-vm.c:93 [inline]
pcpu_populate_chunk+0x1e1/0x900 mm/percpu-vm.c:282
pcpu_alloc+0xe01/0x1280 mm/percpu.c:998
__alloc_percpu_gfp+0x27/0x30 mm/percpu.c:1062
bpf_array_alloc_percpu kernel/bpf/arraymap.c:34 [inline]
array_map_alloc+0x532/0x710 kernel/bpf/arraymap.c:99
find_and_alloc_map kernel/bpf/syscall.c:34 [inline]
map_create kernel/bpf/syscall.c:188 [inline]
SYSC_bpf kernel/bpf/syscall.c:870 [inline]
SyS_bpf+0xd64/0x2500 kernel/bpf/syscall.c:827
entry_SYSCALL_64_fastpath+0x1f/0xc2
pcpu_alloc
pcpu_alloc_mutex
drain_all_pages
get_online_cpus
cpu_hotplug.lock
cpu_hotplug_begin+0x206/0x2e0 kernel/cpu.c:304
_cpu_up+0xca/0x2a0 kernel/cpu.c:1011
cpu_hotplug_begin
cpu_hotplug.lock
Pulling cpu hotplug locks inside the page allocator is just too
dangerous. Let's remove the dependency by dropping get_online_cpus()
from drain_all_pages. This is not so simple though because now we do
not have a protection against cpu hotplug which means 2 things:
- the work item might be executed on a different cpu in worker from
unbound pool so it doesn't run on pinned on the cpu
- we have to make sure that we do not race with page_alloc_cpu_dead
calling drain_pages_zone
Disabling preemption in drain_local_pages_wq will solve the first
problem drain_local_pages will determine its local CPU from the WQ
context which will be stable after that point, page_alloc_cpu_dead is
pinned to the CPU already. The later condition is achieved by disabling
IRQs in drain_pages_zone.
Fixes: mm, page_alloc: drain per-cpu pages from workqueue context
Link: http://lkml.kernel.org/r/20170207201950.20482-1-mhocko@kernel.org
Signed-off-by: Michal Hocko <mhocko@suse.com>
Acked-by: Tejun Heo <tj@kernel.org>
Acked-by: Mel Gorman <mgorman@techsingularity.net>
The per-cpu page allocator can be drained immediately via
drain_all_pages() which sends IPIs to every CPU. In the next patch, the
per-cpu allocator will only be used for interrupt-safe allocations which
prevents draining it from IPI context. This patch uses workqueues to
drain the per-cpu lists instead.
This is slower but no slowdown during intensive reclaim was measured and
the paths that use drain_all_pages() are not that sensitive to
performance. This is particularly true as the path would only be
triggered when reclaim is failing. It also makes a some sense to avoid
storming a machine with IPIs when it's under memory pressure. Arguably,
it should be further adjusted so that only one caller at a time is
draining pages but it's beyond the scope of the current patch.
Link: http://lkml.kernel.org/r/20170123153906.3122-4-mgorman@techsingularity.net
Cc: Tejun Heo <tj@kernel.org>
alloc_pages_nodemask does a number of preperation steps that determine
what zones can be used for the allocation depending on a variety of
factors. This is fine but a hypothetical caller that wanted multiple
order-0 pages has to do the preparation steps multiple times. This
patch structures __alloc_pages_nodemask such that it's relatively easy
to build a bulk order-0 page allocator. There is no functional change.
Link: http://lkml.kernel.org/r/20170123153906.3122-3-mgorman@techsingularity.net
Patch series "Use per-cpu allocator for !irq requests and prepare for a
bulk allocator", v5.
This series is motivated by a conversation led by Jesper Dangaard Brouer
at the last LSF/MM proposing a generic page pool for DMA-coherent pages.
Part of his motivation was due to the overhead of allocating multiple
order-0 that led some drivers to use high-order allocations and
splitting them. This is very slow in some cases.
The first two patches in this series restructure the page allocator such
that it is relatively easy to introduce an order-0 bulk page allocator.
A patch exists to do that and has been handed over to Jesper until an
in-kernel users is created. The third patch prevents the per-cpu
allocator being drained from IPI context as that can potentially corrupt
the list after patch four is merged. The final patch alters the per-cpu
alloctor to make it exclusive to !irq requests. This cuts
allocation/free overhead by roughly 30%.
Performance tests from both Jesper and me are included in the patch.
This patch (of 4):
buffered_rmqueue removes a page from a given zone and uses the per-cpu
list for order-0. This is fine but a hypothetical caller that wanted
multiple order-0 pages has to disable/reenable interrupts multiple
times. This patch structures buffere_rmqueue such that it's relatively
easy to build a bulk order-0 page allocator. There is no functional
change.
[mgorman@techsingularity.net: failed per-cpu refill may blow up]
Link: http://lkml.kernel.org/r/20170124112723.mshmgwq2ihxku2um@techsingularity.net
Link: http://lkml.kernel.org/r/20170123153906.3122-2-mgorman@techsingularity.net
We noticed a performance regression when moving hadoop workloads from
3.10 kernels to 4.0 and 4.6. This is accompanied by increased pageout
activity initiated by kswapd as well as frequent bursts of allocation
stalls and direct reclaim scans. Even lowering the dirty ratios to the
equivalent of less than 1% of memory would not eliminate the issue,
suggesting that dirty pages concentrate where the scanner is looking.
This can be traced back to recent efforts of thrash avoidance. Where
3.10 would not detect refaulting pages and continuously supply clean
cache to the inactive list, a thrashing workload on 4.0+ will detect and
activate refaulting pages right away, distilling used-once pages on the
inactive list much more effectively. This is by design, and it makes
sense for clean cache. But for the most part our workload's cache
faults are refaults and its use-once cache is from streaming writes. We
end up with most of the inactive list dirty, and we don't go after the
active cache as long as we have use-once pages around.
But waiting for writes to avoid reclaiming clean cache that *might*
refault is a bad trade-off. Even if the refaults happen, reads are
faster than writes. Before getting bogged down on writeback, reclaim
should first look at *all* cache in the system, even active cache.
To accomplish this, activate pages that are dirty or under writeback
when they reach the end of the inactive LRU. The pages are marked for
immediate reclaim, meaning they'll get moved back to the inactive LRU
tail as soon as they're written back and become reclaimable. But in the
meantime, by reducing the inactive list to only immediately reclaimable
pages, we allow the scanner to deactivate and refill the inactive list
with clean cache from the active list tail to guarantee forward
progress.
[hannes@cmpxchg.org: update comment]
Link: http://lkml.kernel.org/r/20170202191957.22872-8-hannes@cmpxchg.org
Link: http://lkml.kernel.org/r/20170123181641.23938-6-hannes@cmpxchg.org
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Dirty pages can easily reach the end of the LRU while there are still
clean pages to reclaim around. Don't let kswapd write them back just
because there are a lot of them. It costs more CPU to find the clean
pages, but that's almost certainly better than to disrupt writeback from
the flushers with LRU-order single-page writes from reclaim. And the
flushers have been woken up by that point, so we spend IO capacity on
flushing and CPU capacity on finding the clean cache.
Only start writing dirty pages if they have cycled around the LRU twice
now and STILL haven't been queued on the IO device. It's possible that
the dirty pages are so sparsely distributed across different bdis,
inodes, memory cgroups, that the flushers take forever to get to the
ones we want reclaimed. Once we see them twice on the LRU, we know
that's the quicker way to find them, so do LRU writeback.
Link: http://lkml.kernel.org/r/20170123181641.23938-5-hannes@cmpxchg.org
Direct reclaim has been replaced by kswapd reclaim in pretty much all
common memory pressure situations, so this code most likely doesn't
accomplish the described effect anymore. The previous patch wakes up
flushers for all reclaimers when we encounter dirty pages at the tail
end of the LRU. Remove the crufty old direct reclaim invocation.
Link: http://lkml.kernel.org/r/20170123181641.23938-4-hannes@cmpxchg.org
Memory pressure can put dirty pages at the end of the LRU without
anybody running into dirty limits. Don't start writing individual pages
from kswapd while the flushers might be asleep.
Unlike the old direct reclaim flusher wakeup (removed in the next patch)
that flushes the number of pages just scanned, this patch wakes the
flushers for all outstanding dirty pages. That seemed to perform better
in a synthetic test that pushes dirty pages to the end of the LRU and
into reclaim, because we know LRU aging outstrips writeback already, and
this way we give younger dirty pages a headstart rather than wait until
reclaim runs into them as well. It also means less plugging and risk of
exhausting the struct request pool from reclaim.
There is a concern that this will cause temporary files that used to get
dirtied and truncated before writeback to now get written to disk under
memory pressure. If this turns out to be a real problem, we'll have to
revisit this and tame the reclaim flusher wakeups.
[hannes@cmpxchg.org: mention dirty expiration as a condition]
Link: http://lkml.kernel.org/r/20170126174739.GA30636@cmpxchg.org
Link: http://lkml.kernel.org/r/20170123181641.23938-3-hannes@cmpxchg.org
Patch series "mm: vmscan: fix kswapd writeback regression".
We noticed a regression on multiple hadoop workloads when moving from
3.10 to 4.0 and 4.6, which involves kswapd getting tangled up in page
writeout, causing direct reclaim herds that also don't make progress.
I tracked it down to the thrash avoidance efforts after 3.10 that make
the kernel better at keeping use-once cache and use-many cache sorted on
the inactive and active list, with more aggressive protection of the
active list as long as there is inactive cache. Unfortunately, our
workload's use-once cache is mostly from streaming writes. Waiting for
writes to avoid potential reloads in the future is not a good tradeoff.
These patches do the following:
1. Wake the flushers when kswapd sees a lump of dirty pages. It's
possible to be below the dirty background limit and still have cache
velocity push them through the LRU. So start a-flushin'.
2. Let kswapd only write pages that have been rotated twice. This makes
sure we really tried to get all the clean pages on the inactive list
before resorting to horrible LRU-order writeback.
3. Move rotating dirty pages off the inactive list. Instead of churning
or waiting on page writeback, we'll go after clean active cache. This
might lead to thrashing, but in this state memory demand outstrips IO
speed anyway, and reads are faster than writes.
Mel backported the series to 4.10-rc5 with one minor conflict and ran a
couple of tests on it. Mix of read/write random workload didn't show
anything interesting. Write-only database didn't show much difference
in performance but there were slight reductions in IO -- probably in the
noise.
simoop did show big differences although not as big as Mel expected.
This is Chris Mason's workload that similate the VM activity of hadoop.
Mel won't go through the full details but over the samples measured
during an hour it reported
4.10.0-rc5 4.10.0-rc5
vanilla johannes-v1r1
Amean p50-Read 21346531.56 ( 0.00%) 21697513.24 ( -1.64%)
Amean p95-Read 24700518.40 ( 0.00%) 25743268.98 ( -4.22%)
Amean p99-Read 27959842.13 ( 0.00%) 28963271.11 ( -3.59%)
Amean p50-Write 1138.04 ( 0.00%) 989.82 ( 13.02%)
Amean p95-Write 1106643.48 ( 0.00%) 12104.00 ( 98.91%)
Amean p99-Write 1569213.22 ( 0.00%) 36343.38 ( 97.68%)
Amean p50-Allocation 85159.82 ( 0.00%) 79120.70 ( 7.09%)
Amean p95-Allocation 204222.58 ( 0.00%) 129018.43 ( 36.82%)
Amean p99-Allocation 278070.04 ( 0.00%) 183354.43 ( 34.06%)
Amean final-p50-Read 21266432.00 ( 0.00%) 21921792.00 ( -3.08%)
Amean final-p95-Read 24870912.00 ( 0.00%) 26116096.00 ( -5.01%)
Amean final-p99-Read 28147712.00 ( 0.00%) 29523968.00 ( -4.89%)
Amean final-p50-Write 1130.00 ( 0.00%) 977.00 ( 13.54%)
Amean final-p95-Write 1033216.00 ( 0.00%) 2980.00 ( 99.71%)
Amean final-p99-Write 1517568.00 ( 0.00%) 32672.00 ( 97.85%)
Amean final-p50-Allocation 86656.00 ( 0.00%) 78464.00 ( 9.45%)
Amean final-p95-Allocation 211712.00 ( 0.00%) 116608.00 ( 44.92%)
Amean final-p99-Allocation 287232.00 ( 0.00%) 168704.00 ( 41.27%)
The latencies are actually completely horrific in comparison to 4.4 (and
4.10-rc5 is worse than 4.9 according to historical data for reasons Mel
hasn't analysed yet).
Still, 95% of write latency (p95-write) is halved by the series and
allocation latency is way down. Direct reclaim activity is one fifth of
what it was according to vmstats. Kswapd activity is higher but this is
not necessarily surprising. Kswapd efficiency is unchanged at 99% (99%
of pages scanned were reclaimed) but direct reclaim efficiency went from
77% to 99%
In the vanilla kernel, 627MB of data was written back from reclaim
context. With the series, no data was written back. With or without
the patch, pages are being immediately reclaimed after writeback
completes. However, with the patch, only 1/8th of the pages are
reclaimed like this.
This patch (of 5):
We have an elaborate dirty/writeback throttling mechanism inside the
reclaim scanner, but for that to work the pages have to go through
shrink_page_list() and get counted for what they are. Otherwise, we
mess up the LRU order and don't match reclaim speed to writeback.
Especially during deactivation, there is never a reason to skip dirty
pages; nothing is even trying to write them out from there. Don't mess
up the LRU order for nothing, shuffle these pages along.
Link: http://lkml.kernel.org/r/20170123181641.23938-2-hannes@cmpxchg.org
When a page is removed from a shared mapping, the uffd reader should be
notified, so that it won't attempt to handle #PF events for the removed
pages.
We can reuse the UFFD_EVENT_REMOVE because from the uffd monitor point
of view, the semantices of madvise(MADV_DONTNEED) and
madvise(MADV_REMOVE) is exactly the same.
Link: http://lkml.kernel.org/r/1484814154-1557-3-git-send-email-rppt@linux.vnet.ibm.com
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
Acked-by: Pavel Emelyanov <xemul@virtuozzo.com>
Patch series "userfaultfd: non-cooperative: add madvise() event for
MADV_REMOVE request".
These patches add notification of madvise(MADV_REMOVE) event to
non-cooperative userfaultfd monitor.
The first pacth renames EVENT_MADVDONTNEED to EVENT_REMOVE along with
relevant functions and structures. Using _REMOVE instead of
_MADVDONTNEED describes the event semantics more clearly and I hope it's
not too late for such change in the ABI.
This patch (of 3):
The UFFD_EVENT_MADVDONTNEED purpose is to notify uffd monitor about
removal of certain range from address space tracked by userfaultfd.
Hence, UFFD_EVENT_REMOVE seems to better reflect the operation
semantics. Respectively, 'madv_dn' field of uffd_msg is renamed to
'remove' and the madvise_userfault_dontneed callback is renamed to
userfaultfd_remove.
Link: http://lkml.kernel.org/r/1484814154-1557-2-git-send-email-rppt@linux.vnet.ibm.com
Provide the name of each memblock type with struct memblock_type. This
allows to get rid of the function memblock_type_name() and duplicating
the type names in __memblock_dump_all().
The only memblock_type usage out of mm/memblock.c seems to be
arch/s390/kernel/crash_dump.c. While at it, give it a name.
Link: http://lkml.kernel.org/r/20170120123456.46508-4-heiko.carstens@de.ibm.com
Cc: Philipp Hachtmann <phacht@linux.vnet.ibm.com>
Since commit 70210ed950b5 ("mm/memblock: add physical memory list") the
memblock structure knows about a physical memory list.
The physical memory list should also be dumped if memblock_dump_all() is
called in case memblock_debug is switched on. This makes debugging a
bit easier.
Link: http://lkml.kernel.org/r/20170120123456.46508-3-heiko.carstens@de.ibm.com
memblock_type_name() should return "physmem" instead of "unknown" if the
name of the physmem memblock_type is being asked for.
Link: http://lkml.kernel.org/r/20170120123456.46508-2-heiko.carstens@de.ibm.com
It has no modular callers.
mem_hotplug_begin() assumes that it can set mem_hotplug.active_writer
and run the hotplug process without racing another thread. Validate
this assumption with a lockdep assertion.
Link: http://lkml.kernel.org/r/148693886229.16345.1770484669403334689.stgit@dwillia2-desk3.amr.corp.intel.com
Reported-by: Ben Hutchings <ben@decadent.org.uk>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Toshi Kani <toshi.kani@hpe.com>
Cc: Logan Gunthorpe <logang@deltatee.com>
Cc: Masayoshi Mizuma <m.mizuma@jp.fujitsu.com>
Commit 82e7d3abec86 ("oom: print nodemask in the oom report") implicitly
sets the allocation nodemask to cpuset_current_mems_allowed when there
is no effective mempolicy. cpuset_current_mems_allowed is only
effective when cpusets are enabled, which is also printed by
dump_header(), so setting the nodemask to cpuset_current_mems_allowed is
redundant and prevents debugging issues where ac->nodemask is not set
properly in the page allocator.
This provides better debugging output since
cpuset_print_current_mems_allowed() is already provided.
[rientjes@google.com: newline per Hillf]
Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1701200158300.88321@chino.kir.corp.google.com
Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1701191454470.2381@chino.kir.corp.google.com
Signed-off-by: David Rientjes <rientjes@google.com>
Some architectures have a set of zero pages (coloured zero pages)
instead of only one zero page, in order to improve the cache
performance. In those cases, the kernel samepage merger (KSM) would
merge all the allocated pages that happen to be filled with zeroes to
the same deduplicated page, thus losing all the advantages of coloured
zero pages.
This behaviour is noticeable when a process accesses large arrays of
allocated pages containing zeroes. A test I conducted on s390 shows
that there is a speed penalty when KSM merges such pages, compared to
not merging them or using actual zero pages from the start without
breaking the COW.
This patch fixes this behaviour. When coloured zero pages are present,
the checksum of a zero page is calculated during initialisation, and
compared with the checksum of the current canditate during merging. In
case of a match, the normal merging routine is used to merge the page
with the correct coloured zero page, which ensures the candidate page is
checked to be equal to the target zero page.
A sysfs entry is also added to toggle this behaviour, since it can
potentially introduce performance regressions, especially on
architectures without coloured zero pages. The default value is
disabled, for backwards compatibility.
With this patch, the performance with KSM is the same as with non
COW-broken actual zero pages, which is also the same as without KSM.
[akpm@linux-foundation.org: make zero_checksum and ksm_use_zero_pages __read_mostly, per Andrea]
[imbrenda@linux.vnet.ibm.com: documentation for coloured zero pages deduplication]
Link: http://lkml.kernel.org/r/1484927522-1964-1-git-send-email-imbrenda@linux.vnet.ibm.com
Link: http://lkml.kernel.org/r/1484850953-23941-1-git-send-email-imbrenda@linux.vnet.ibm.com
Signed-off-by: Claudio Imbrenda <imbrenda@linux.vnet.ibm.com>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
At present, Tying the first_num size to NCHUNKS_ORDER is confusing. the
number of chunks is completely unrelated to the number of buddies.
The patch limits the first_num to actual range of possible buddy indexes.
and that is more reasonable and obvious without functional change.
Link: http://lkml.kernel.org/r/1476776569-29504-1-git-send-email-zhongjiang@huawei.com
Signed-off-by: zhong jiang <zhongjiang@huawei.com>
Suggested-by: Dan Streetman <ddstreet@ieee.org>
Acked-by: Dan Streetman <ddstreet@ieee.org>
Acked-by: Vitaly Wool <vitalywool@gmail.com>
There is no variable named flags in memblock_add() and
memblock_reserve() so remove it from the log messages.
This patch also cleans up the type casting for phys_addr_t by using %pa
to print them.
Link: http://lkml.kernel.org/r/1484720165-25403-1-git-send-email-miles.chen@mediatek.com
Signed-off-by: Miles Chen <miles.chen@mediatek.com>
Logic on whether we can reap pages from the VMA should match what we
have in madvise_dontneed(). In particular, we should skip, VM_PFNMAP
VMAs, but we don't now.
Let's just extract condition on which we can shoot down pagesi from a
VMA with MADV_DONTNEED into separate function and use it in both places.
Link: http://lkml.kernel.org/r/20170118122429.43661-4-kirill.shutemov@linux.intel.com
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
There's no users of zap_page_range() who wants non-NULL 'details'.
Let's drop it.
Link: http://lkml.kernel.org/r/20170118122429.43661-3-kirill.shutemov@linux.intel.com
