path: root/mm
2007-10-20small documentation fixesPhilipp Marek
Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-20Typo fixes retrun -> returnGabriel Craciunescu
Typo fixes retrun -> return Signed-off-by: Gabriel Craciunescu <nix.or.die@googlemail.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-20spelling fixes: mm/Simon Arlott
Spelling fixes in mm/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Explain clearly why kmalloc() can't use __GFP_HIGHMEM.Robert P. J. Day
Fix the wishy-washy comment to clearly explain why kmalloc() can't use the __GFP_HIGHMEM zone modifier. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Use helpers to obtain task pid in printksPavel Emelyanov
The task_struct->pid member is going to be deprecated, so start using the helpers (task_pid_nr/task_pid_vnr/task_pid_nr_ns) in the kernel. The first thing to start with is the pid, printed to dmesg - in this case we may safely use task_pid_nr(). Besides, printks produce more (much more) than a half of all the explicit pid usage. [akpm@linux-foundation.org: git-drm went and changed lots of stuff] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Isolate some explicit usage of task->tgidPavel Emelyanov
With pid namespaces this field is now dangerous to use explicitly, so hide it behind the helpers. Also the pid and pgrp fields o task_struct and signal_struct are to be deprecated. Unfortunately this patch cannot be sent right now as this leads to tons of warnings, so start isolating them, and deprecate later. Actually the p->tgid == pid has to be changed to has_group_leader_pid(), but Oleg pointed out that in case of posix cpu timers this is the same, and thread_group_leader() is more preferable. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Uninline find_task_by_xxx set of functionsPavel Emelyanov
The find_task_by_something is a set of macros are used to find task by pid depending on what kind of pid is proposed - global or virtual one. All of them are wrappers above the most generic one - find_task_by_pid_type_ns() - and just substitute some args for it. It turned out, that dereferencing the current->nsproxy->pid_ns construction and pushing one more argument on the stack inline cause kernel text size to grow. This patch moves all this stuff out-of-line into kernel/pid.c. Together with the next patch it saves a bit less than 400 bytes from the .text section. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Paul Menage <menage@google.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: changes to show virtual ids to userPavel Emelyanov
This is the largest patch in the set. Make all (I hope) the places where the pid is shown to or get from user operate on the virtual pids. The idea is: - all in-kernel data structures must store either struct pid itself or the pid's global nr, obtained with pid_nr() call; - when seeking the task from kernel code with the stored id one should use find_task_by_pid() call that works with global pids; - when showing pid's numerical value to the user the virtual one should be used, but however when one shows task's pid outside this task's namespace the global one is to be used; - when getting the pid from userspace one need to consider this as the virtual one and use appropriate task/pid-searching functions. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: nuther build fix] [akpm@linux-foundation.org: yet nuther build fix] [akpm@linux-foundation.org: remove unneeded casts] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Paul Menage <menage@google.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19mm/oom_kill.c: Use list_for_each_entry instead of list_for_eachMatthias Kaehlcke
mm/oom_kill.c: Convert list_for_each to list_for_each_entry in oom_kill_process() Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: define is_global_init() and is_container_init()Serge E. Hallyn
is_init() is an ambiguous name for the pid==1 check. Split it into is_global_init() and is_container_init(). A cgroup init has it's tsk->pid == 1. A global init also has it's tsk->pid == 1 and it's active pid namespace is the init_pid_ns. But rather than check the active pid namespace, compare the task structure with 'init_pid_ns.child_reaper', which is initialized during boot to the /sbin/init process and never changes. Changelog: 2.6.22-rc4-mm2-pidns1: - Use 'init_pid_ns.child_reaper' to determine if a given task is the global init (/sbin/init) process. This would improve performance and remove dependence on the task_pid(). 2.6.21-mm2-pidns2: - [Sukadev Bhattiprolu] Changed is_container_init() calls in {powerpc, ppc,avr32}/traps.c for the _exception() call to is_global_init(). This way, we kill only the cgroup if the cgroup's init has a bug rather than force a kernel panic. [akpm@linux-foundation.org: fix comment] [sukadev@us.ibm.com: Use is_global_init() in arch/m32r/mm/fault.c] [bunk@stusta.de: kernel/pid.c: remove unused exports] [sukadev@us.ibm.com: Fix capability.c to work with threaded init] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Acked-by: Pavel Emelianov <xemul@openvz.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Herbert Poetzel <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Task Control Groups: make cpusets a client of cgroupsPaul Menage
Remove the filesystem support logic from the cpusets system and makes cpusets a cgroup subsystem The "cpuset" filesystem becomes a dummy filesystem; attempts to mount it get passed through to the cgroup filesystem with the appropriate options to emulate the old cpuset filesystem behaviour. Signed-off-by: Paul Menage <menage@google.com> Cc: Serge E. Hallyn <serue@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Paul Jackson <pj@sgi.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19kernel-api docbook: fix content problemsRandy Dunlap
Fix kernel-api docbook contents problems. docproc: linux-2.6.23-git13/include/asm-x86/unaligned_32.h: No such file or directory Warning(linux-2.6.23-git13//include/linux/list.h:482): bad line: of list entry Warning(linux-2.6.23-git13//mm/filemap.c:864): No description found for parameter 'ra' Warning(linux-2.6.23-git13//block/ll_rw_blk.c:3760): No description found for parameter 'req' Warning(linux-2.6.23-git13//include/linux/input.h:1077): No description found for parameter 'private' Warning(linux-2.6.23-git13//include/linux/input.h:1077): No description found for parameter 'cdev' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: WU Fengguang <wfg@mail.ustc.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19setup vma->vm_page_prot by vm_get_page_prot()Coly Li
This patch uses vm_get_page_prot() to setup vma->vm_page_prot. Though inside vm_get_page_prot() the protection flags is AND with (VM_READ|VM_WRITE|VM_EXEC|VM_SHARED), it does not hurt correct code. Signed-off-by: Coly Li <coyli@suse.de> Cc: Hugh Dickins <hugh@veritas.com> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19remove unused flush_tlb_pgtablesBenjamin Herrenschmidt
Nobody uses flush_tlb_pgtables anymore, this patch removes all remaining traces of it from all archs. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18Include <linux/backing-dev.h> in mm/filemap.cLinus Torvalds
It gets it indirectly from blkdev.h when CONFIG_BLOCK is enabled, but it needs it unconditionally for the definition of mapping_cap_writeback_dirty. Noticed and bisected down to 4af3c9cc4fad54c3627e9afebf905aafde5690ed ("Drop some headers from mm.h") by Avuton Olrich. Cc: Avuton Olrich <avuton@gmail.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18sparse pointer use of zero as nullStephen Hemminger
Get rid of sparse related warnings from places that use integer as NULL pointer. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Cc: Andi Kleen <ak@suse.de> Cc: Jeff Garzik <jeff@garzik.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Ian Kent <raven@themaw.net> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18cpu hotplug: slab: fix memory leak in cpu hotplug error pathAkinobu Mita
This patch fixes memory leak in error path. In reality, we don't need to call cpuup_canceled(cpu) for now. But upcoming cpu hotplug error handling change needs this. Cc: Christoph Lameter <clameter@sgi.com> Cc: Gautham R Shenoy <ego@in.ibm.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18cpu hotplug: slab: cleanup cpuup_callback()Akinobu Mita
cpuup_callback() is too long. This patch factors out CPU_UP_CANCELLED and CPU_UP_PREPARE handlings from cpuup_callback(). Cc: Christoph Lameter <clameter@sgi.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Merge branch 'xen-upstream' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen * 'xen-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen: xfs: eagerly remove vmap mappings to avoid upsetting Xen xen: add some debug output for failed multicalls xen: fix incorrect vcpu_register_vcpu_info hypercall argument xen: ask the hypervisor how much space it needs reserved xen: lock pte pages while pinning/unpinning xen: deal with stale cr3 values when unpinning pagetables xen: add batch completion callbacks xen: yield to IPI target if necessary Clean up duplicate includes in arch/i386/xen/ remove dead code in pgtable_cache_init paravirt: clean up lazy mode handling paravirt: refactor struct paravirt_ops into smaller pv_*_ops
2007-10-17security/ cleanupsAdrian Bunk
This patch contains the following cleanups that are now possible: - remove the unused security_operations->inode_xattr_getsuffix - remove the no longer used security_operations->unregister_security - remove some no longer required exit code - remove a bunch of no longer used exports Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: James Morris <jmorris@namei.org> Cc: Chris Wright <chrisw@sous-sol.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Implement file posix capabilitiesSerge E. Hallyn
Implement file posix capabilities. This allows programs to be given a subset of root's powers regardless of who runs them, without having to use setuid and giving the binary all of root's powers. This version works with Kaigai Kohei's userspace tools, found at http://www.kaigai.gr.jp/index.php. For more information on how to use this patch, Chris Friedhoff has posted a nice page at http://www.friedhoff.org/fscaps.html. Changelog: Nov 27: Incorporate fixes from Andrew Morton (security-introduce-file-caps-tweaks and security-introduce-file-caps-warning-fix) Fix Kconfig dependency. Fix change signaling behavior when file caps are not compiled in. Nov 13: Integrate comments from Alexey: Remove CONFIG_ ifdef from capability.h, and use %zd for printing a size_t. Nov 13: Fix endianness warnings by sparse as suggested by Alexey Dobriyan. Nov 09: Address warnings of unused variables at cap_bprm_set_security when file capabilities are disabled, and simultaneously clean up the code a little, by pulling the new code into a helper function. Nov 08: For pointers to required userspace tools and how to use them, see http://www.friedhoff.org/fscaps.html. Nov 07: Fix the calculation of the highest bit checked in check_cap_sanity(). Nov 07: Allow file caps to be enabled without CONFIG_SECURITY, since capabilities are the default. Hook cap_task_setscheduler when !CONFIG_SECURITY. Move capable(TASK_KILL) to end of cap_task_kill to reduce audit messages. Nov 05: Add secondary calls in selinux/hooks.c to task_setioprio and task_setscheduler so that selinux and capabilities with file cap support can be stacked. Sep 05: As Seth Arnold points out, uid checks are out of place for capability code. Sep 01: Define task_setscheduler, task_setioprio, cap_task_kill, and task_setnice to make sure a user cannot affect a process in which they called a program with some fscaps. One remaining question is the note under task_setscheduler: are we ok with CAP_SYS_NICE being sufficient to confine a process to a cpuset? It is a semantic change, as without fsccaps, attach_task doesn't allow CAP_SYS_NICE to override the uid equivalence check. But since it uses security_task_setscheduler, which elsewhere is used where CAP_SYS_NICE can be used to override the uid equivalence check, fixing it might be tough. task_setscheduler note: this also controls cpuset:attach_task. Are we ok with CAP_SYS_NICE being used to confine to a cpuset? task_setioprio task_setnice sys_setpriority uses this (through set_one_prio) for another process. Need same checks as setrlimit Aug 21: Updated secureexec implementation to reflect the fact that euid and uid might be the same and nonzero, but the process might still have elevated caps. Aug 15: Handle endianness of xattrs. Enforce capability version match between kernel and disk. Enforce that no bits beyond the known max capability are set, else return -EPERM. With this extra processing, it may be worth reconsidering doing all the work at bprm_set_security rather than d_instantiate. Aug 10: Always call getxattr at bprm_set_security, rather than caching it at d_instantiate. [morgan@kernel.org: file-caps clean up for linux/capability.h] [bunk@kernel.org: unexport cap_inode_killpriv] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Cc: Chris Wright <chrisw@sous-sol.org> Cc: Andrew Morgan <morgan@kernel.org> Signed-off-by: Andrew Morgan <morgan@kernel.org> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17remap_file_pages: kernel-doc correctionsRandy Dunlap
Fix kernel-doc for sys_remap_file_pages() and add info to the 'prot' NOTE. Rename __prot parameter to prot. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17r/o bind mounts: filesystem helpers for custom 'struct file'sDave Hansen
Why do we need r/o bind mounts? This feature allows a read-only view into a read-write filesystem. In the process of doing that, it also provides infrastructure for keeping track of the number of writers to any given mount. This has a number of uses. It allows chroots to have parts of filesystems writable. It will be useful for containers in the future because users may have root inside a container, but should not be allowed to write to somefilesystems. This also replaces patches that vserver has had out of the tree for several years. It allows security enhancement by making sure that parts of your filesystem read-only (such as when you don't trust your FTP server), when you don't want to have entire new filesystems mounted, or when you want atime selectively updated. I've been using the following script to test that the feature is working as desired. It takes a directory and makes a regular bind and a r/o bind mount of it. It then performs some normal filesystem operations on the three directories, including ones that are expected to fail, like creating a file on the r/o mount. This patch: Some filesystems forego the vfs and may_open() and create their own 'struct file's. This patch creates a couple of helper functions which can be used by these filesystems, and will provide a unified place which the r/o bind mount code may patch. Also, rename an existing, static-scope init_file() to a less generic name. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17writeback: remove unnecessary wait in throttle_vm_writeout()Fengguang Wu
We don't want to introduce pointless delays in throttle_vm_writeout() when the writeback limits are not yet exceeded, do we? Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: Greg KH <greg@kroah.com> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17introduce I_SYNCJoern Engel
I_LOCK was used for several unrelated purposes, which caused deadlock situations in certain filesystems as a side effect. One of the purposes now uses the new I_SYNC bit. Also document the various bits and change their order from historical to logical. [bunk@stusta.de: make fs/inode.c:wake_up_inode() static] Signed-off-by: Joern Engel <joern@wohnheim.fh-wedel.de> Cc: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Cc: David Chinner <dgc@sgi.com> Cc: Anton Altaparmakov <aia21@cam.ac.uk> Cc: Al Viro <viro@ftp.linux.org.uk> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17writeback: introduce writeback_control.more_io to indicate more ioFengguang Wu
After making dirty a 100M file, the normal behavior is to start the writeback for all data after 30s delays. But sometimes the following happens instead: - after 30s: ~4M - after 5s: ~4M - after 5s: all remaining 92M Some analyze shows that the internal io dispatch queues goes like this: s_io s_more_io ------------------------- 1) 100M,1K 0 2) 1K 96M 3) 0 96M 1) initial state with a 100M file and a 1K file 2) 4M written, nr_to_write <= 0, so write more 3) 1K written, nr_to_write > 0, no more writes(BUG) nr_to_write > 0 in (3) fools the upper layer to think that data have all been written out. The big dirty file is actually still sitting in s_more_io. We cannot simply splice s_more_io back to s_io as soon as s_io becomes empty, and let the loop in generic_sync_sb_inodes() continue: this may starve newly expired inodes in s_dirty. It is also not an option to draw inodes from both s_more_io and s_dirty, an let the loop go on: this might lead to live locks, and might also starve other superblocks in sync time(well kupdate may still starve some superblocks, that's another bug). We have to return when a full scan of s_io completes. So nr_to_write > 0 does not necessarily mean that "all data are written". This patch introduces a flag writeback_control.more_io to indicate this situation. With it the big dirty file no longer has to wait for the next kupdate invocation 5s later. Cc: David Chinner <dgc@sgi.com> Cc: Ken Chen <kenchen@google.com> Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Delete gcc-2.95 compatible structure definition.Robert P. J. Day
Since nothing earlier than gcc-3.2 is supported for kernel compilation, that 2.95 hack can be removed. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Drop some headers from mm.hAlexey Dobriyan
mm.h doesn't use directly anything from mutex.h and backing-dev.h, so remove them and add them back to files which need them. Cross-compile tested on many configs and archs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17SLAB_PANIC more (proc, posix-timers, shmem)Alexey Dobriyan
These aren't modular, so SLAB_PANIC is OK. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17writeback: don't propagate AOP_WRITEPAGE_ACTIVATEAndrew Morton
This is a writeback-internal marker but we're propagating it all the way back to userspace!. Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17mm: document tree_lock->zone.lock lockorderNick Piggin
zone->lock is quite an "inner" lock and mostly constrained to page alloc as well, so like slab locks, it probably isn't something that is critically important to document here. However unlike slab locks, zone lock could be used more widely in future, and page_alloc.c might possibly have more business to do tricky things with pagecache than does slab. So... I don't think it hurts to document it. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17mm: test and set zone reclaim lock before starting reclaimDavid Rientjes
Introduces new zone flag interface for testing and setting flags: int zone_test_and_set_flag(struct zone *zone, zone_flags_t flag) Instead of setting and clearing ZONE_RECLAIM_LOCKED each time shrink_zone() is called, this flag is test and set before starting zone reclaim. Zone reclaim starts in __alloc_pages() when a zone's watermark fails and the system is in zone_reclaim_mode. If it's already in reclaim, there's no need to start again so it is simply considered full for that allocation attempt. There is a change of behavior with regard to concurrent zone shrinking. It is now possible for try_to_free_pages() or kswapd to already be shrinking a particular zone when __alloc_pages() starts zone reclaim. In this case, it is possible for two concurrent threads to invoke shrink_zone() for a single zone. This change forbids a zone to be in zone reclaim twice, which was always the behavior, but allows for concurrent try_to_free_pages() or kswapd shrinking when starting zone reclaim. Cc: Andrea Arcangeli <andrea@suse.de> Cc: Christoph Lameter <clameter@sgi.com> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17oom: convert zone_scan_lock from mutex to spinlockDavid Rientjes
There's no reason to sleep in try_set_zone_oom() or clear_zonelist_oom() if the lock can't be acquired; it will be available soon enough once the zonelist scanning is done. All other threads waiting for the OOM killer are also contingent on the exiting task being able to acquire the lock in clear_zonelist_oom() so it doesn't make sense to put it to sleep. Cc: Andrea Arcangeli <andrea@suse.de> Cc: Christoph Lameter <clameter@sgi.com> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17oom: do not take callback_mutexDavid Rientjes
Since no task descriptor's 'cpuset' field is dereferenced in the execution of the OOM killer anymore, it is no longer necessary to take callback_mutex. [akpm@linux-foundation.org: restore cpuset_lock for other patches] Cc: Andrea Arcangeli <andrea@suse.de> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17oom: compare cpuset mems_allowed instead of exclusive ancestorsDavid Rientjes
Instead of testing for overlap in the memory nodes of the the nearest exclusive ancestor of both current and the candidate task, it is better to simply test for intersection between the task's mems_allowed in their task descriptors. This does not require taking callback_mutex since it is only used as a hint in the badness scoring. Tasks that do not have an intersection in their mems_allowed with the current task are not explicitly restricted from being OOM killed because it is quite possible that the candidate task has allocated memory there before and has since changed its mems_allowed. Cc: Andrea Arcangeli <andrea@suse.de> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17oom: suppress extraneous stack and memory dumpDavid Rientjes
Suppresses the extraneous stack and memory dump when a parallel OOM killing has been found. There's no need to fill the ring buffer with this information if its already been printed and the condition that triggered the previous OOM killer has not yet been alleviated. Cc: Andrea Arcangeli <andrea@suse.de> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17oom: add oom_kill_allocating_task sysctlDavid Rientjes
Adds a new sysctl, 'oom_kill_allocating_task', which will automatically kill the OOM-triggering task instead of scanning through the tasklist to find a memory-hogging target. This is helpful for systems with an insanely large number of tasks where scanning the tasklist significantly degrades performance. Cc: Andrea Arcangeli <andrea@suse.de> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17oom: serialize out of memory callsDavid Rientjes
A final allocation attempt with a very high watermark needs to be attempted before invoking out_of_memory(). OOM killer serialization needs to occur before this final attempt, otherwise tasks attempting to OOM-lock all zones in its zonelist may spin and acquire the lock unnecessarily after the OOM condition has already been alleviated. If the final allocation does succeed, the zonelist is simply OOM-unlocked and __alloc_pages() returns the page. Otherwise, the OOM killer is invoked. If the task cannot acquire OOM-locks on all zones in its zonelist, it is put to sleep and the allocation is retried when it gets rescheduled. One of its zones is already marked as being in the OOM killer so it'll hopefully be getting some free memory soon, at least enough to satisfy a high watermark allocation attempt. This prevents needlessly killing a task when the OOM condition would have already been alleviated if it had simply been given enough time. Cc: Andrea Arcangeli <andrea@suse.de> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17oom: add per-zone lockingDavid Rientjes
OOM killer synchronization should be done with zone granularity so that memory policy and cpuset allocations may have their corresponding zones locked and allow parallel kills for other OOM conditions that may exist elsewhere in the system. DMA allocations can be targeted at the zone level, which would not be possible if locking was done in nodes or globally. Synchronization shall be done with a variation of "trylocks." The goal is to put the current task to sleep and restart the failed allocation attempt later if the trylock fails. Otherwise, the OOM killer is invoked. Each zone in the zonelist that __alloc_pages() was called with is checked for the newly-introduced ZONE_OOM_LOCKED flag. If any zone has this flag present, the "trylock" to serialize the OOM killer fails and returns zero. Otherwise, all the zones have ZONE_OOM_LOCKED set and the try_set_zone_oom() function returns non-zero. Cc: Andrea Arcangeli <andrea@suse.de> Cc: Christoph Lameter <clameter@sgi.com> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17oom: change all_unreclaimable zone member to flagsDavid Rientjes
Convert the int all_unreclaimable member of struct zone to unsigned long flags. This can now be used to specify several different zone flags such as all_unreclaimable and reclaim_in_progress, which can now be removed and converted to a per-zone flag. Flags are set and cleared as follows: zone_set_flag(struct zone *zone, zone_flags_t flag) zone_clear_flag(struct zone *zone, zone_flags_t flag) Defines the first zone flags, ZONE_ALL_UNRECLAIMABLE and ZONE_RECLAIM_LOCKED, which have the same semantics as the old zone->all_unreclaimable and zone->reclaim_in_progress, respectively. Also converts all current users that set or clear either flag to use the new interface. Helper functions are defined to test the flags: int zone_is_all_unreclaimable(const struct zone *zone) int zone_is_reclaim_locked(const struct zone *zone) All flag operators are of the atomic variety because there are currently readers that are implemented that do not take zone->lock. [akpm@linux-foundation.org: add needed include] Cc: Andrea Arcangeli <andrea@suse.de> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17oom: move constraints to enumDavid Rientjes
The OOM killer's CONSTRAINT definitions are really more appropriate in an enum, so define them in include/linux/oom.h. Cc: Andrea Arcangeli <andrea@suse.de> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17oom: move prototypes to appropriate header fileDavid Rientjes
Move the OOM killer's extern function prototypes to include/linux/oom.h and include it where necessary. [clg@fr.ibm.com: build fix] Cc: Andrea Arcangeli <andrea@suse.de> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Slab API: remove useless ctor parameter and reorder parametersChristoph Lameter
Slab constructors currently have a flags parameter that is never used. And the order of the arguments is opposite to other slab functions. The object pointer is placed before the kmem_cache pointer. Convert ctor(void *object, struct kmem_cache *s, unsigned long flags) to ctor(struct kmem_cache *s, void *object) throughout the kernel [akpm@linux-foundation.org: coupla fixes] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17SLUB: simplify IRQ off handlingChristoph Lameter
Move irq handling out of new slab into __slab_alloc. That is useful for Mathieu's cmpxchg_local patchset and also allows us to remove the crude local_irq_off in early_kmem_cache_alloc(). Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17mm: dirty balancing for tasksPeter Zijlstra
Based on ideas of Andrew: http://marc.info/?l=linux-kernel&m=102912915020543&w=2 Scale the bdi dirty limit inversly with the tasks dirty rate. This makes heavy writers have a lower dirty limit than the occasional writer. Andrea proposed something similar: http://lwn.net/Articles/152277/ The main disadvantage to his patch is that he uses an unrelated quantity to measure time, which leaves him with a workload dependant tunable. Other than that the two approaches appear quite similar. [akpm@linux-foundation.org: fix warning] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17mm: per device dirty thresholdPeter Zijlstra
Scale writeback cache per backing device, proportional to its writeout speed. By decoupling the BDI dirty thresholds a number of problems we currently have will go away, namely: - mutual interference starvation (for any number of BDIs); - deadlocks with stacked BDIs (loop, FUSE and local NFS mounts). It might be that all dirty pages are for a single BDI while other BDIs are idling. By giving each BDI a 'fair' share of the dirty limit, each one can have dirty pages outstanding and make progress. A global threshold also creates a deadlock for stacked BDIs; when A writes to B, and A generates enough dirty pages to get throttled, B will never start writeback until the dirty pages go away. Again, by giving each BDI its own 'independent' dirty limit, this problem is avoided. So the problem is to determine how to distribute the total dirty limit across the BDIs fairly and efficiently. A DBI that has a large dirty limit but does not have any dirty pages outstanding is a waste. What is done is to keep a floating proportion between the DBIs based on writeback completions. This way faster/more active devices get a larger share than slower/idle devices. [akpm@linux-foundation.org: fix warnings] [hugh@veritas.com: Fix occasional hang when a task couldn't get out of balance_dirty_pages] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17mm: count writeback pages per BDIPeter Zijlstra
Count per BDI writeback pages. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17mm: count reclaimable pages per BDIPeter Zijlstra
Count per BDI reclaimable pages; nr_reclaimable = nr_dirty + nr_unstable. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17mm: scalable bdi statistics countersPeter Zijlstra
Provide scalable per backing_dev_info statistics counters. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17mm: bdi init hooksPeter Zijlstra
provide BDI constructor/destructor hooks [akpm@linux-foundation.org: compile fix] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
