commit 424cdc14138088ada1b0e407a2195b2783c6e5ef upstream.
page_counter_memparse() returns pages for the threshold, while
mem_cgroup_usage() returns bytes for memory usage. Convert the
threshold to bytes.
Fixes: 3e32cb2e0a12b6915 ("memcg: rename cgroup_event to mem_cgroup_event").
Signed-off-by: Shaohua Li <shli@fb.com>
commit 03a2d2a3eafe4015412cf4e9675ca0e2d9204074 upstream.
Commit description is copied from the original post of this bug:
http://comments.gmane.org/gmane.linux.kernel.mm/135349
Kernels after v3.9 use kmalloc_size(INDEX_NODE + 1) to get the next
larger cache size than the size index INDEX_NODE mapping. In kernels
3.9 and earlier we used malloc_sizes[INDEX_L3 + 1].cs_size.
However, sometimes we can't get the right output we expected via
kmalloc_size(INDEX_NODE + 1), causing a BUG().
The mapping table in the latest kernel is like:
index = {0, 1, 2 , 3, 4, 5, 6, n}
size = {0, 96, 192, 8, 16, 32, 64, 2^n}
The mapping table before 3.10 is like this:
index = {0 , 1 , 2, 3, 4 , 5 , 6, n}
size = {32, 64, 96, 128, 192, 256, 512, 2^(n+3)}
The problem on my mips64 machine is as follows:
(1) When configured DEBUG_SLAB && DEBUG_PAGEALLOC && DEBUG_LOCK_ALLOC
&& DEBUG_SPINLOCK, the sizeof(struct kmem_cache_node) will be "150",
and the macro INDEX_NODE turns out to be "2": #define INDEX_NODE
kmalloc_index(sizeof(struct kmem_cache_node))
(2) Then the result of kmalloc_size(INDEX_NODE + 1) is 8.
(3) Then "if(size >= kmalloc_size(INDEX_NODE + 1)" will lead to "size
= PAGE_SIZE".
(4) Then "if ((size >= (PAGE_SIZE >> 3))" test will be satisfied and
"flags |= CFLGS_OFF_SLAB" will be covered.
(5) if (flags & CFLGS_OFF_SLAB)" test will be satisfied and will go to
"cachep->slabp_cache = kmalloc_slab(slab_size, 0u)", and the result
here may be NULL while kernel bootup.
(6) Finally,"BUG_ON(ZERO_OR_NULL_PTR(cachep->slabp_cache));" causes the
BUG info as the following shows (may be only mips64 has this problem):
This patch fixes the problem of kmalloc_size(INDEX_NODE + 1) and removes
the BUG by adding 'size >= 256' check to guarantee that all necessary
small sized slabs are initialized regardless sequence of slab size in
mapping table.
Fixes: e33660165c90 ("slab: Use common kmalloc_index/kmalloc_size...")
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Reported-by: Liuhailong <liu.hailong6@zte.com.cn>
Acked-by: Christoph Lameter <cl@linux.com>
Cc: Pekka Enberg <penberg@kernel.org>
commit 2f84a8990ebbe235c59716896e017c6b2ca1200f upstream.
SunDong reported the following on
https://bugzilla.kernel.org/show_bug.cgi?id=103841
I think I find a linux bug, I have the test cases is constructed. I
can stable recurring problems in fedora22(4.0.4) kernel version,
arch for x86_64. I construct transparent huge page, when the parent
and child process with MAP_SHARE, MAP_PRIVATE way to access the same
huge page area, it has the opportunity to lead to huge page copy on
write failure, and then it will munmap the child corresponding mmap
area, but then the child mmap area with VM_MAYSHARE attributes, child
process munmap this area can trigger VM_BUG_ON in set_vma_resv_flags
functions (vma - > vm_flags & VM_MAYSHARE).
There were a number of problems with the report (e.g. it's hugetlbfs that
triggers this, not transparent huge pages) but it was fundamentally
correct in that a VM_BUG_ON in set_vma_resv_flags() can be triggered that
looks like this
vma ffff8804651fd0d0 start 00007fc474e00000 end 00007fc475e00000
next ffff8804651fd018 prev ffff8804651fd188 mm ffff88046b1b1800
prot 8000000000000027 anon_vma (null) vm_ops ffffffff8182a7a0
pgoff 0 file ffff88106bdb9800 private_data (null)
flags: 0x84400fb(read|write|shared|mayread|maywrite|mayexec|mayshare|dontexpand|hugetlb)
kernel BUG at mm/hugetlb.c:462!
SMP
Modules linked in: xt_pkttype xt_LOG xt_limit [..]
CPU: 38 PID: 26839 Comm: map Not tainted 4.0.4-default #1
Hardware name: Dell Inc. PowerEdge R810/0TT6JF, BIOS 2.7.4 04/26/2012
set_vma_resv_flags+0x2d/0x30
The VM_BUG_ON is correct because private and shared mappings have
different reservation accounting but the warning clearly shows that the
VMA is shared.
When a private COW fails to allocate a new page then only the process
that created the VMA gets the page -- all the children unmap the page.
If the children access that data in the future then they get killed.
The problem is that the same file is mapped shared and private. During
the COW, the allocation fails, the VMAs are traversed to unmap the other
private pages but a shared VMA is found and the bug is triggered. This
patch identifies such VMAs and skips them.
Signed-off-by: Mel Gorman <mgorman@techsingularity.net>
Reported-by: SunDong <sund_sky@126.com>
Reviewed-by: Michal Hocko <mhocko@suse.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
commit 3aaa76e125c1dd58c9b599baa8c6021896874c12 upstream.
Since commit bcc54222309c ("mm: hugetlb: introduce page_huge_active")
each hugetlb page maintains its active flag to avoid a race condition
betwe= en multiple calls of isolate_huge_page(), but current kernel
doesn't set the f= lag on a hugepage allocated by migration because the
proper putback routine isn= 't called. This means that users could
still encounter the race referred to by bcc54222309c in this special
case, so this patch fixes it.
Fixes: bcc54222309c ("mm: hugetlb: introduce page_huge_active")
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
commit c54839a722a02818677bcabe57e957f0ce4f841d upstream.
reclaim_clean_pages_from_list() assumes that shrink_page_list() returns
number of pages removed from the candidate list. But shrink_page_list()
puts back mlocked pages without passing it to caller and without
counting as nr_reclaimed. This increases nr_isolated.
To fix this, this patch changes shrink_page_list() to pass unevictable
pages back to caller. Caller will take care those pages.
Minchan said:
It fixes two issues.
1. With unevictable page, cma_alloc will be successful.
Exactly speaking, cma_alloc of current kernel will fail due to
unevictable pages.
2. fix leaking of NR_ISOLATED counter of vmstat
With it, too_many_isolated works. Otherwise, it could make hang until
the process get SIGKILL.
Signed-off-by: Jaewon Kim <jaewon31.kim@samsung.com>
Acked-by: Minchan Kim <minchan@kernel.org>
Cc: Mel Gorman <mgorman@techsingularity.net>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
commit 2f064f3485cd29633ad1b3cfb00cc519509a3d72 upstream.
Commit c48a11c7ad26 ("netvm: propagate page->pfmemalloc to skb") added
checks for page->pfmemalloc to __skb_fill_page_desc():
if (page->pfmemalloc && !page->mapping)
skb->pfmemalloc = true;
It assumes page->mapping == NULL implies that page->pfmemalloc can be
trusted. However, __delete_from_page_cache() can set set page->mapping
to NULL and leave page->index value alone. Due to being in union, a
non-zero page->index will be interpreted as true page->pfmemalloc.
So the assumption is invalid if the networking code can see such a page.
And it seems it can. We have encountered this with a NFS over loopback
setup when such a page is attached to a new skbuf. There is no copying
going on in this case so the page confuses __skb_fill_page_desc which
interprets the index as pfmemalloc flag and the network stack drops
packets that have been allocated using the reserves unless they are to
be queued on sockets handling the swapping which is the case here and
that leads to hangs when the nfs client waits for a response from the
server which has been dropped and thus never arrive.
The struct page is already heavily packed so rather than finding another
hole to put it in, let's do a trick instead. We can reuse the index
again but define it to an impossible value (-1UL). This is the page
index so it should never see the value that large. Replace all direct
users of page->pfmemalloc by page_is_pfmemalloc which will hide this
nastiness from unspoiled eyes.
The information will get lost if somebody wants to use page->index
obviously but that was the case before and the original code expected
that the information should be persisted somewhere else if that is
really needed (e.g. what SLAB and SLUB do).
[akpm@linux-foundation.org: fix blooper in slub]
Fixes: c48a11c7ad26 ("netvm: propagate page->pfmemalloc to skb")
Signed-off-by: Michal Hocko <mhocko@suse.com>
Debugged-by: Vlastimil Babka <vbabka@suse.com>
Debugged-by: Jiri Bohac <jbohac@suse.com>
commit 036138080a4376e5f3e5d0cca8ac99084c5cf06e upstream.
Hugetlbfs pages will get a refcount in get_any_page() or
madvise_hwpoison() if soft offlining through madvise. The refcount which
is held by the soft offline path should be released if we fail to isolate
hugetlbfs pages.
Fix it by reducing the refcount for both isolation success and failure.
Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com>
Acked-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
commit 4f32be677b124a49459e2603321c7a5605ceb9f8 upstream.
After trying to drain pages from pagevec/pageset, we try to get reference
count of the page again, however, the reference count of the page is not
reduced if the page is still not on LRU list.
Fix it by adding the put_page() to drop the page reference which is from
__get_any_page().
commit ecf5fc6e9654cd7a268c782a523f072b2f1959f9 upstream.
Nikolay has reported a hang when a memcg reclaim got stuck with the
following backtrace:
PID: 18308 TASK: ffff883d7c9b0a30 CPU: 1 COMMAND: "rsync"
#0 __schedule at ffffffff815ab152
#1 schedule at ffffffff815ab76e
#2 schedule_timeout at ffffffff815ae5e5
#3 io_schedule_timeout at ffffffff815aad6a
#4 bit_wait_io at ffffffff815abfc6
#5 __wait_on_bit at ffffffff815abda5
#6 wait_on_page_bit at ffffffff8111fd4f
#7 shrink_page_list at ffffffff81135445
#8 shrink_inactive_list at ffffffff81135845
#9 shrink_lruvec at ffffffff81135ead
#10 shrink_zone at ffffffff811360c3
#11 shrink_zones at ffffffff81136eff
#12 do_try_to_free_pages at ffffffff8113712f
#13 try_to_free_mem_cgroup_pages at ffffffff811372be
#14 try_charge at ffffffff81189423
#15 mem_cgroup_try_charge at ffffffff8118c6f5
#16 __add_to_page_cache_locked at ffffffff8112137d
#17 add_to_page_cache_lru at ffffffff81121618
#18 pagecache_get_page at ffffffff8112170b
#19 grow_dev_page at ffffffff811c8297
#20 __getblk_slow at ffffffff811c91d6
#21 __getblk_gfp at ffffffff811c92c1
#22 ext4_ext_grow_indepth at ffffffff8124565c
#23 ext4_ext_create_new_leaf at ffffffff81246ca8
#24 ext4_ext_insert_extent at ffffffff81246f09
#25 ext4_ext_map_blocks at ffffffff8124a848
#26 ext4_map_blocks at ffffffff8121a5b7
#27 mpage_map_one_extent at ffffffff8121b1fa
#28 mpage_map_and_submit_extent at ffffffff8121f07b
#29 ext4_writepages at ffffffff8121f6d5
#30 do_writepages at ffffffff8112c490
#31 __filemap_fdatawrite_range at ffffffff81120199
#32 filemap_flush at ffffffff8112041c
#33 ext4_alloc_da_blocks at ffffffff81219da1
#34 ext4_rename at ffffffff81229b91
#35 ext4_rename2 at ffffffff81229e32
#36 vfs_rename at ffffffff811a08a5
#37 SYSC_renameat2 at ffffffff811a3ffc
#38 sys_renameat2 at ffffffff811a408e
#39 sys_rename at ffffffff8119e51e
#40 system_call_fastpath at ffffffff815afa89
Dave Chinner has properly pointed out that this is a deadlock in the
reclaim code because ext4 doesn't submit pages which are marked by
PG_writeback right away.
The heuristic was introduced by commit e62e384e9da8 ("memcg: prevent OOM
with too many dirty pages") and it was applied only when may_enter_fs
was specified. The code has been changed by c3b94f44fcb0 ("memcg:
further prevent OOM with too many dirty pages") which has removed the
__GFP_FS restriction with a reasoning that we do not get into the fs
code. But this is not sufficient apparently because the fs doesn't
necessarily submit pages marked PG_writeback for IO right away.
ext4_bio_write_page calls io_submit_add_bh but that doesn't necessarily
submit the bio. Instead it tries to map more pages into the bio and
mpage_map_one_extent might trigger memcg charge which might end up
waiting on a page which is marked PG_writeback but hasn't been submitted
yet so we would end up waiting for something that never finishes.
Fix this issue by replacing __GFP_IO by may_enter_fs check (for case 2)
before we go to wait on the writeback. The page fault path, which is
the only path that triggers memcg oom killer since 3.12, shouldn't
require GFP_NOFS and so we shouldn't reintroduce the premature OOM
killer issue which was originally addressed by the heuristic.
As per David Chinner the xfs is doing similar thing since 2.6.15 already
so ext4 is not the only affected filesystem. Moreover he notes:
: For example: IO completion might require unwritten extent conversion
: which executes filesystem transactions and GFP_NOFS allocations. The
: writeback flag on the pages can not be cleared until unwritten
: extent conversion completes. Hence memory reclaim cannot wait on
: page writeback to complete in GFP_NOFS context because it is not
: safe to do so, memcg reclaim or otherwise.
Cc: stable@vger.kernel.org # 3.9+
[tytso@mit.edu: corrected the control flow]
Fixes: c3b94f44fcb0 ("memcg: further prevent OOM with too many dirty pages")
Reported-by: Nikolay Borisov <kernel@kyup.com>
commit 6b7339f4c31ad69c8e9c0b2859276e22cf72176d upstream.
Reading page fault handler code I've noticed that under right
circumstances kernel would map anonymous pages into file mappings: if
the VMA doesn't have vm_ops->fault() and the VMA wasn't fully populated
on ->mmap(), kernel would handle page fault to not populated pte with
do_anonymous_page().
Let's change page fault handler to use do_anonymous_page() only on
anonymous VMA (->vm_ops == NULL) and make sure that the VMA is not
shared.
For file mappings without vm_ops->fault() or shred VMA without vm_ops,
page fault on pte_none() entry would lead to SIGBUS.
Acked-by: Oleg Nesterov <oleg@redhat.com>
Cc: Willy Tarreau <w@1wt.eu>
commit 641844f5616d7c6597309f560838f996466d7aac upstream.
Currently the initial value of order in dissolve_free_huge_page is 64 or
32, which leads to the following warning in static checker:
mm/hugetlb.c:1203 dissolve_free_huge_pages()
warn: potential right shift more than type allows '9,18,64'
This is a potential risk of infinite loop, because 1 << order (== 0) is used
in for-loop like this:
for (pfn =3D start_pfn; pfn < end_pfn; pfn +=3D 1 << order)
So this patch fixes it by using global minimum_order calculated at boot time.
28313 469 84236 113018 1b97a mm/hugetlb.o
28256 473 84236 112965 1b945 mm/hugetlb.o (patched)
Fixes: c8721bbbdd36 ("mm: memory-hotplug: enable memory hotplug to handle hugepage")
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
commit 0867a57c4f80a566dda1bac975b42fcd857cb489 upstream.
Since commit 077fcf116c8c ("mm/thp: allocate transparent hugepages on
local node"), we handle THP allocations on page fault in a special way -
for non-interleave memory policies, the allocation is only attempted on
the node local to the current CPU, if the policy's nodemask allows the
node.
This is motivated by the assumption that THP benefits cannot offset the
cost of remote accesses, so it's better to fallback to base pages on the
local node (which might still be available, while huge pages are not due
to fragmentation) than to allocate huge pages on a remote node.
The nodemask check prevents us from violating e.g. MPOL_BIND policies
where the local node is not among the allowed nodes. However, the
current implementation can still give surprising results for the
MPOL_PREFERRED policy when the preferred node is different than the
current CPU's local node.
In such case we should honor the preferred node and not use the local
node, which is what this patch does. If hugepage allocation on the
preferred node fails, we fall back to base pages and don't try other
nodes, with the same motivation as is done for the local node hugepage
allocations. The patch also moves the MPOL_INTERLEAVE check around to
simplify the hugepage specific test.
The difference can be demonstrated using in-tree transhuge-stress test
on the following 2-node machine where half memory on one node was
occupied to show the difference.
> numactl --hardware
available: 2 nodes (0-1)
node 0 cpus: 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 32 33 34 35
node 0 size: 7878 MB
node 0 free: 3623 MB
node 1 cpus: 12 13 14 15 16 17 18 19 20 21 22 23 36 37 38 39 40 41 42 43 44 45 46 47
node 1 size: 8045 MB
node 1 free: 7818 MB
node distances:
node 0 1
0: 10 21
1: 21 10
Before the patch:
> numactl -p0 -C0 ./transhuge-stress
transhuge-stress: 2.197 s/loop, 0.276 ms/page, 7249.168 MiB/s 7962 succeed, 0 failed, 1786 different pages
> numactl -p0 -C12 ./transhuge-stress
transhuge-stress: 2.962 s/loop, 0.372 ms/page, 5376.172 MiB/s 7962 succeed, 0 failed, 3873 different pages
Number of successful THP allocations corresponds to free memory on node 0 in
the first case and node 1 in the second case, i.e. -p parameter is ignored and
cpu binding "wins".
After the patch:
transhuge-stress: 2.183 s/loop, 0.274 ms/page, 7295.516 MiB/s 7962 succeed, 0 failed, 1760 different pages
transhuge-stress: 2.878 s/loop, 0.361 ms/page, 5533.638 MiB/s 7962 succeed, 0 failed, 1750 different pages
> numactl -p1 -C0 ./transhuge-stress
transhuge-stress: 4.628 s/loop, 0.581 ms/page, 3440.893 MiB/s 7962 succeed, 0 failed, 3918 different pages
The -p parameter is respected regardless of cpu binding.
> numactl -C0 ./transhuge-stress
transhuge-stress: 2.202 s/loop, 0.277 ms/page, 7230.003 MiB/s 7962 succeed, 0 failed, 1750 different pages
> numactl -C12 ./transhuge-stress
transhuge-stress: 3.020 s/loop, 0.379 ms/page, 5273.324 MiB/s 7962 succeed, 0 failed, 3916 different pages
Without -p parameter, hugepage restriction to CPU-local node works as before.
Fixes: 077fcf116c8c ("mm/thp: allocate transparent hugepages on local node")
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Acked-by: David Rientjes <rientjes@google.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
commit 8a8c35fadfaf55629a37ef1a8ead1b8fb32581d2 upstream.
Beginning at commit d52d3997f843 ("ipv6: Create percpu rt6_info"), the
following INFO splat is logged:
[ INFO: suspicious RCU usage. ]
4.1.0-rc7-next-20150612 #1 Not tainted
kernel/sched/core.c:7318 Illegal context switch in RCU-bh read-side critical section!
rcu_scheduler_active = 1, debug_locks = 0
3 locks held by systemd/1:
#0: (rtnl_mutex){+.+.+.}, at: [<ffffffff815f0c8f>] rtnetlink_rcv+0x1f/0x40
#1: (rcu_read_lock_bh){......}, at: [<ffffffff816a34e2>] ipv6_add_addr+0x62/0x540
#2: (addrconf_hash_lock){+...+.}, at: [<ffffffff816a3604>] ipv6_add_addr+0x184/0x540
stack backtrace:
CPU: 0 PID: 1 Comm: systemd Not tainted 4.1.0-rc7-next-20150612 #1
Hardware name: TOSHIBA TECRA A50-A/TECRA A50-A, BIOS Version 4.20 04/17/2014
Call Trace:
dump_stack+0x4c/0x6e
lockdep_rcu_suspicious+0xe7/0x120
___might_sleep+0x1d5/0x1f0
__might_sleep+0x4d/0x90
kmem_cache_alloc+0x47/0x250
create_object+0x39/0x2e0
kmemleak_alloc_percpu+0x61/0xe0
pcpu_alloc+0x370/0x630
Additional backtrace lines are truncated. In addition, the above splat
is followed by several "BUG: sleeping function called from invalid
context at mm/slub.c:1268" outputs. As suggested by Martin KaFai Lau,
these are the clue to the fix. Routine kmemleak_alloc_percpu() always
uses GFP_KERNEL for its allocations, whereas it should follow the gfp
from its callers.
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
Reviewed-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com>
Acked-by: Martin KaFai Lau <kafai@fb.com>
Cc: Martin KaFai Lau <kafai@fb.com>
Cc: Tejun Heo <tj@kernel.org>
commit c5f3b1a51a591c18c8b33983908e7fdda6ae417e upstream.
The kmemleak scanning thread can run for minutes. Callbacks like
kmemleak_free() are allowed during this time, the race being taken care
of by the object->lock spinlock. Such lock also prevents a memory block
from being freed or unmapped while it is being scanned by blocking the
kmemleak_free() -> ... -> __delete_object() function until the lock is
released in scan_object().
When a kmemleak error occurs (e.g. it fails to allocate its metadata),
kmemleak_enabled is set and __delete_object() is no longer called on
freed objects. If kmemleak_scan is running at the same time,
kmemleak_free() no longer waits for the object scanning to complete,
allowing the corresponding memory block to be freed or unmapped (in the
case of vfree()). This leads to kmemleak_scan potentially triggering a
page fault.
This patch separates the kmemleak_free() enabling/disabling from the
overall kmemleak_enabled nob so that we can defer the disabling of the
object freeing tracking until the scanning thread completed. The
kmemleak_free_part() is deliberately ignored by this patch since this is
only called during boot before the scanning thread started.
Reported-by: Vignesh Radhakrishnan <vigneshr@codeaurora.org>
Tested-by: Vignesh Radhakrishnan <vigneshr@codeaurora.org>
It appears that, at some point last year, XFS made directory handling
changes which bring it into lockdep conflict with shmem_zero_setup():
it is surprising that mmap() can clone an inode while holding mmap_sem,
but that has been so for many years.
Since those few lockdep traces that I've seen all implicated selinux,
I'm hoping that we can use the __shmem_file_setup(,,,S_PRIVATE) which
v3.13's commit c7277090927a ("security: shmem: implement kernel private
shmem inodes") introduced to avoid LSM checks on kernel-internal inodes:
the mmap("/dev/zero") cloned inode is indeed a kernel-internal detail.
This also covers the !CONFIG_SHMEM use of ramfs to support /dev/zero
(and MAP_SHARED|MAP_ANONYMOUS). I thought there were also drivers
which cloned inode in mmap(), but if so, I cannot locate them now.
Reported-and-tested-by: Prarit Bhargava <prarit@redhat.com>
Reported-and-tested-by: Daniel Wagner <wagi@monom.org>
Reported-and-tested-by: Morten Stevens <mstevens@fedoraproject.org>
If zs_create_pool()->create_handle_cache()->kmem_cache_create() or
pool->name allocation fails, zs_create_pool()->destroy_handle_cache()
will dereference the NULL pool->handle_cachep.
Modify destroy_handle_cache() to avoid this.
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Minchan Kim <minchan@kernel.org>
On -rt, the VM_BUG_ON(!irqs_disabled()) triggers inside the memcg
swapout path because the spin_lock_irq(&mapping->tree_lock) in the
caller doesn't actually disable the hardware interrupts - which is fine,
because on -rt the tophalves run in process context and so we are still
safe from preemption while updating the statistics.
Remove the VM_BUG_ON() but keep the comment of what we rely on.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reported-by: Clark Williams <williams@redhat.com>
Cc: Fernando Lopez-Lezcano <nando@ccrma.Stanford.EDU>
When trimming memcg consumption excess (see memory.high), we call
try_to_free_mem_cgroup_pages without checking if we are allowed to sleep
in the current context, which can result in a deadlock. Fix this.
Fixes: 241994ed8649 ("mm: memcontrol: default hierarchy interface for memory")
Signed-off-by: Vladimir Davydov <vdavydov@parallels.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
Izumi found the following oops when hot re-adding a node:
BUG: unable to handle kernel paging request at ffffc90008963690
IP: __wake_up_bit+0x20/0x70
Oops: 0000 [#1] SMP
CPU: 68 PID: 1237 Comm: rs:main Q:Reg Not tainted 4.1.0-rc5 #80
Hardware name: FUJITSU PRIMEQUEST2800E/SB, BIOS PRIMEQUEST 2000 Series BIOS Version 1.87 04/28/2015
task: ffff880838df8000 ti: ffff880017b94000 task.ti: ffff880017b94000
RIP: 0010:[<ffffffff810dff80>] [<ffffffff810dff80>] __wake_up_bit+0x20/0x70
RSP: 0018:ffff880017b97be8 EFLAGS: 00010246
RAX: ffffc90008963690 RBX: 00000000003c0000 RCX: 000000000000a4c9
RDX: 0000000000000000 RSI: ffffea101bffd500 RDI: ffffc90008963648
RBP: ffff880017b97c08 R08: 0000000002000020 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: ffff8a0797c73800
R13: ffffea101bffd500 R14: 0000000000000001 R15: 00000000003c0000
FS: 00007fcc7ffff700(0000) GS:ffff880874800000(0000) knlGS:0000000000000000
CR2: ffffc90008963690 CR3: 0000000836761000 CR4: 00000000001407e0
Call Trace:
unlock_page+0x6d/0x70
generic_write_end+0x53/0xb0
xfs_vm_write_end+0x29/0x80 [xfs]
generic_perform_write+0x10a/0x1e0
xfs_file_buffered_aio_write+0x14d/0x3e0 [xfs]
xfs_file_write_iter+0x79/0x120 [xfs]
__vfs_write+0xd4/0x110
vfs_write+0xac/0x1c0
SyS_write+0x58/0xd0
system_call_fastpath+0x12/0x76
Code: 5d c3 66 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 55 48 89 e5 48 83 ec 20 65 48 8b 04 25 28 00 00 00 48 89 45 f8 31 c0 48 8d 47 48 <48> 39 47 48 48 c7 45 e8 00 00 00 00 48 c7 45 f0 00 00 00 00 48
RIP [<ffffffff810dff80>] __wake_up_bit+0x20/0x70
RSP <ffff880017b97be8>
Reproduce method (re-add a node)::
Hot-add nodeA --> remove nodeA --> hot-add nodeA (panic)
This seems an use-after-free problem, and the root cause is
zone->wait_table was not set to *NULL* after free it in
try_offline_node.
When hot re-add a node, we will reuse the pgdat of it, so does the zone
struct, and when add pages to the target zone, it will init the zone
first (including the wait_table) if the zone is not initialized. The
judgement of zone initialized is based on zone->wait_table:
static inline bool zone_is_initialized(struct zone *zone)
return !!zone->wait_table;
so if we do not set the zone->wait_table to *NULL* after free it, the
memory hotplug routine will skip the init of new zone when hot re-add
the node, and the wait_table still points to the freed memory, then we
will access the invalid address when trying to wake up the waiting
people after the i/o operation with the page is done, such as mentioned
above.
Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com>
Reported-by: Taku Izumi <izumi.taku@jp.fujitsu.com>
Reviewed by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: Tang Chen <tangchen@cn.fujitsu.com>
Cc: <stable@vger.kernel.org>
bdi_unregister() now contains very little functionality.
It contains a "WARN_ON" if bdi->dev is NULL. This warning is of no
real consequence as bdi->dev isn't needed by anything else in the function,
and it triggers if
blk_cleanup_queue() -> bdi_destroy()
is called before bdi_unregister, which happens since
Commit: 6cd18e711dd8 ("block: destroy bdi before blockdev is unregistered.")
So this isn't wanted.
It also calls bdi_set_min_ratio(). This needs to be called after
writes through the bdi have all been flushed, and before the bdi is destroyed.
Calling it early is better than calling it late as it frees up a global
resource.
Calling it immediately after bdi_wb_shutdown() in bdi_destroy()
perfectly fits these requirements.
So bdi_unregister() can be discarded with the important content moved to
bdi_destroy(), as can the
writeback_bdi_unregister
event which is already not used.
Reported-by: Mike Snitzer <snitzer@redhat.com>
Cc: stable@vger.kernel.org (v4.0)
Fixes: c4db59d31e39 ("fs: don't reassign dirty inodes to default_backing_dev_info")
Fixes: 6cd18e711dd8 ("block: destroy bdi before blockdev is unregistered.")
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Acked-by: Dan Williams <dan.j.williams@intel.com>
Tested-by: Nicholas Moulin <nicholas.w.moulin@linux.intel.com>
Signed-off-by: NeilBrown <neilb@suse.de>
Signed-off-by: Jens Axboe <axboe@fb.com>
NUMA balancing is meant to be disabled by default on UMA machines but
the check is using nr_node_ids (highest node) instead of
num_online_nodes (online nodes).
The consequences are that a UMA machine with a node ID of 1 or higher
will enable NUMA balancing. This will incur useless overhead due to
minor faults with the impact depending on the workload. These are the
impact on the stats when running a kernel build on a single node machine
whose node ID happened to be 1:
vanilla patched
NUMA base PTE updates 5113158 0
NUMA huge PMD updates 643 0
NUMA page range updates 5442374 0
NUMA hint faults 2109622 0
NUMA hint local faults 2109622 0
NUMA hint local percent 100 100
NUMA pages migrated 0 0
Cc: <stable@vger.kernel.org> [3.8+]
I had an issue:
Unable to handle kernel NULL pointer dereference at virtual address 0000082a
pgd = cc970000
[0000082a] *pgd=00000000
Internal error: Oops: 5 [#1] PREEMPT SMP ARM
PC is at get_pageblock_flags_group+0x5c/0xb0
LR is at unset_migratetype_isolate+0x148/0x1b0
pc : [<c00cc9a0>] lr : [<c0109874>] psr: 80000093
sp : c7029d00 ip : 00000105 fp : c7029d1c
r10: 00000001 r9 : 0000000a r8 : 00000004
r7 : 60000013 r6 : 000000a4 r5 : c0a357e4 r4 : 00000000
r3 : 00000826 r2 : 00000002 r1 : 00000000 r0 : 0000003f
Flags: Nzcv IRQs off FIQs on Mode SVC_32 ISA ARM Segment user
Control: 10c5387d Table: 2cb7006a DAC: 00000015
Backtrace:
get_pageblock_flags_group+0x0/0xb0
unset_migratetype_isolate+0x0/0x1b0
undo_isolate_page_range+0x0/0xdc
__alloc_contig_range+0x0/0x34c
alloc_contig_range+0x0/0x18
This issue is because when calling unset_migratetype_isolate() to unset
a part of CMA memory, it try to access the buddy page to get its status:
if (order >= pageblock_order) {
page_idx = page_to_pfn(page) & ((1 << MAX_ORDER) - 1);
buddy_idx = __find_buddy_index(page_idx, order);
buddy = page + (buddy_idx - page_idx);
if (!is_migrate_isolate_page(buddy)) {
But the begin addr of this part of CMA memory is very close to a part of
memory that is reserved at boot time (not in buddy system). So add a
check before accessing it.
[akpm@linux-foundation.org: use conventional code layout]
Signed-off-by: Hui Zhu <zhuhui@xiaomi.com>
Suggested-by: Laura Abbott <labbott@redhat.com>
Suggested-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Not all kmem allocations should be accounted to memcg. The following
patch gives an example when accounting of a certain type of allocations to
memcg can effectively result in a memory leak. This patch adds the
__GFP_NOACCOUNT flag which if passed to kmalloc and friends will force the
allocation to go through the root cgroup. It will be used by the next
patch.
Note, since in case of kmemleak enabled each kmalloc implies yet another
allocation from the kmemleak_object cache, we add __GFP_NOACCOUNT to
gfp_kmemleak_mask.
Alternatively, we could introduce a per kmem cache flag disabling
accounting for all allocations of a particular kind, but (a) we would not
be able to bypass accounting for kmalloc then and (b) a kmem cache with
this flag set could not be merged with a kmem cache without this flag,
which would increase the number of global caches and therefore
fragmentation even if the memory cgroup controller is not used.
Despite its generic name, currently __GFP_NOACCOUNT disables accounting
only for kmem allocations while user page allocations are always charged.
To catch abusing of this flag, a warning is issued on an attempt of
passing it to mem_cgroup_try_charge.
Cc: Christoph Lameter <cl@linux.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: <stable@vger.kernel.org> [4.0.x]
Pull block fixes from Jens Axboe:
"A collection of fixes since the merge window;
- fix for a double elevator module release, from Chao Yu. Ancient bug.
- the splice() MORE flag fix from Christophe Leroy.
- a fix for NVMe, fixing a patch that went in in the merge window.
From Keith.
- two fixes for blk-mq CPU hotplug handling, from Ming Lei.
- bdi vs blockdev lifetime fix from Neil Brown, fixing and oops in md.
- two blk-mq fixes from Shaohua, fixing a race on queue stop and a
bad merge issue with FUA writes.
- division-by-zero fix for writeback from Tejun.
- a block bounce page accounting fix, making sure we inc/dec after
bouncing so that pre/post IO pages match up. From Wang YanQing"
* 'for-linus' of git://git.kernel.dk/linux-block:
splice: sendfile() at once fails for big files
blk-mq: don't lose requests if a stopped queue restarts
blk-mq: fix FUA request hang
block:bounce: fix call inc_|dec_zone_page_state on different pages confuse value of NR_BOUNCE
elevator: fix double release of elevator module
writeback: use |1 instead of +1 to protect against div by zero
blk-mq: fix CPU hotplug handling
blk-mq: fix race between timeout and CPU hotplug
NVMe: Fix VPD B0 max sectors translation
Hwpoison injector checks PageLRU of the raw target page to find out
whether the page is an appropriate target, but current code now filters
out thp tail pages, which prevents us from testing for such cases via this
interface. So let's check hpage instead of p.
Acked-by: Dean Nelson <dnelson@redhat.com>
Cc: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
Hwpoison injection via debugfs:hwpoison/corrupt-pfn takes a refcount of
the target page. But current code doesn't release it if the target page
is not supposed to be injected, which results in memory leak. This patch
simply adds the refcount releasing code.
If multiple soft offline events hit one free page/hugepage concurrently,
soft_offline_page() can handle the free page/hugepage multiple times,
which makes num_poisoned_pages counter increased more than once. This
patch fixes this wrong counting by checking TestSetPageHWPoison for normal
papes and by checking the return value of dequeue_hwpoisoned_huge_page()
for hugepages.
Cc: <stable@vger.kernel.org> [3.14+]
Currently memory_failure() calls shake_page() to sweep pages out from
pcplists only when the victim page is 4kB LRU page or thp head page.
But we should do this for a thp tail page too.
Consider that a memory error hits a thp tail page whose head page is on
a pcplist when memory_failure() runs. Then, the current kernel skips
shake_pages() part, so hwpoison_user_mappings() returns without calling
split_huge_page() nor try_to_unmap() because PageLRU of the thp head is
still cleared due to the skip of shake_page().
As a result, me_huge_page() runs for the thp, which is broken behavior.
One effect is a leak of the thp. And another is to fail to isolate the
memory error, so later access to the error address causes another MCE,
which kills the processes which used the thp.
This patch fixes this problem by calling shake_page() for thp tail case.
Fixes: 385de35722c9 ("thp: allow a hwpoisoned head page to be put back to LRU")
Reviewed-by: Andi Kleen <ak@linux.intel.com>
Cc: Jin Dongming <jin.dongming@np.css.fujitsu.com>
Cc: <stable@vger.kernel.org> [3.4+]
Pull fourth vfs update from Al Viro:
"d_inode() annotations from David Howells (sat in for-next since before
the beginning of merge window) + four assorted fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
RCU pathwalk breakage when running into a symlink overmounting something
fix I_DIO_WAKEUP definition
direct-io: only inc/dec inode->i_dio_count for file systems
fs/9p: fix readdir()
VFS: assorted d_backing_inode() annotations
VFS: fs/inode.c helpers: d_inode() annotations
VFS: fs/cachefiles: d_backing_inode() annotations
VFS: fs library helpers: d_inode() annotations
VFS: assorted weird filesystems: d_inode() annotations
VFS: normal filesystems (and lustre): d_inode() annotations
VFS: security/: d_inode() annotations
VFS: security/: d_backing_inode() annotations
VFS: net/: d_inode() annotations
VFS: net/unix: d_backing_inode() annotations
VFS: kernel/: d_inode() annotations
VFS: audit: d_backing_inode() annotations
VFS: Fix up some ->d_inode accesses in the chelsio driver
VFS: Cachefiles should perform fs modifications on the top layer only
VFS: AF_UNIX sockets should call mknod on the top layer only
mm/page-writeback.c has several places where 1 is added to the divisor
to prevent division by zero exceptions; however, if the original
divisor is equivalent to -1, adding 1 leads to division by zero.
There are three places where +1 is used for this purpose - one in
pos_ratio_polynom() and two in bdi_position_ratio(). The second one
in bdi_position_ratio() actually triggered div-by-zero oops on a
machine running a 3.10 kernel. The divisor is
x_intercept - bdi_setpoint + 1 == span + 1
span is confirmed to be (u32)-1. It isn't clear how it ended up that
but it could be from write bandwidth calculation underflow fixed by
c72efb658f7c ("writeback: fix possible underflow in write bandwidth
calculation").
At any rate, +1 isn't a proper protection against div-by-zero. This
patch converts all +1 protections to |1. Note that
bdi_update_dirty_ratelimit() was already using |1 before this patch.
Pull third hunk of vfs changes from Al Viro:
"This contains the ->direct_IO() changes from Omar + saner
generic_write_checks() + dealing with fcntl()/{read,write}() races
(mirroring O_APPEND/O_DIRECT into iocb->ki_flags and instead of
repeatedly looking at ->f_flags, which can be changed by fcntl(2),
check ->ki_flags - which cannot) + infrastructure bits for dhowells'
d_inode annotations + Christophs switch of /dev/loop to
vfs_iter_write()"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (30 commits)
block: loop: switch to VFS ITER_BVEC
configfs: Fix inconsistent use of file_inode() vs file->f_path.dentry->d_inode
VFS: Make pathwalk use d_is_reg() rather than S_ISREG()
VFS: Fix up debugfs to use d_is_dir() in place of S_ISDIR()
VFS: Combine inode checks with d_is_negative() and d_is_positive() in pathwalk
NFS: Don't use d_inode as a variable name
VFS: Impose ordering on accesses of d_inode and d_flags
VFS: Add owner-filesystem positive/negative dentry checks
nfs: generic_write_checks() shouldn't be done on swapout...
ocfs2: use __generic_file_write_iter()
mirror O_APPEND and O_DIRECT into iocb->ki_flags
switch generic_write_checks() to iocb and iter
ocfs2: move generic_write_checks() before the alignment checks
ocfs2_file_write_iter: stop messing with ppos
udf_file_write_iter: reorder and simplify
fuse: ->direct_IO() doesn't need generic_write_checks()
ext4_file_write_iter: move generic_write_checks() up
xfs_file_aio_write_checks: switch to iocb/iov_iter
generic_write_checks(): drop isblk argument
blkdev_write_iter: expand generic_file_checks() call in there
Merge second patchbomb from Andrew Morton:
- the rest of MM
- various misc bits
- add ability to run /sbin/reboot at reboot time
- printk/vsprintf changes
- fiddle with seq_printf() return value
* akpm: (114 commits)
parisc: remove use of seq_printf return value
lru_cache: remove use of seq_printf return value
tracing: remove use of seq_printf return value
cgroup: remove use of seq_printf return value
proc: remove use of seq_printf return value
s390: remove use of seq_printf return value
cris fasttimer: remove use of seq_printf return value
cris: remove use of seq_printf return value
openrisc: remove use of seq_printf return value
ARM: plat-pxa: remove use of seq_printf return value
nios2: cpuinfo: remove use of seq_printf return value
microblaze: mb: remove use of seq_printf return value
ipc: remove use of seq_printf return value
rtc: remove use of seq_printf return value
power: wakeup: remove use of seq_printf return value
x86: mtrr: if: remove use of seq_printf return value
linux/bitmap.h: improve BITMAP_{LAST,FIRST}_WORD_MASK
MAINTAINERS: CREDITS: remove Stefano Brivio from B43
.mailmap: add Ricardo Ribalda
CREDITS: add Ricardo Ribalda Delgado
Do not perform cond_resched() before the busy compaction loop in
__zs_compact(), because this loop does it when needed.
Cc: Nitin Gupta <ngupta@vflare.org>
There is no point in overriding the size class below. It causes fatal
corruption on the next chunk on the 3264-bytes size class, which is the
last size class that is not huge.
For example, if the requested size was exactly 3264 bytes, current
zsmalloc allocates and returns a chunk from the size class of 3264 bytes,
not 4096. User access to this chunk may overwrite head of the next
adjacent chunk.
Here is the panic log captured when freelist was corrupted due to this:
Kernel BUG at ffffffc00030659c [verbose debug info unavailable]
Internal error: Oops - BUG: 96000006 [#1] PREEMPT SMP
Modules linked in:
exynos-snapshot: core register saved(CPU:5)
CPUMERRSR: 0000000000000000, L2MERRSR: 0000000000000000
exynos-snapshot: context saved(CPU:5)
exynos-snapshot: item - log_kevents is disabled
CPU: 5 PID: 898 Comm: kswapd0 Not tainted 3.10.61-4497415-eng #1
task: ffffffc0b8783d80 ti: ffffffc0b71e8000 task.ti: ffffffc0b71e8000
PC is at obj_idx_to_offset+0x0/0x1c
LR is at obj_malloc+0x44/0xe8
pc : [<ffffffc00030659c>] lr : [<ffffffc000306604>] pstate: a0000045
sp : ffffffc0b71eb790
x29: ffffffc0b71eb790 x28: ffffffc00204c000
x27: 000000000001d96f x26: 0000000000000000
x25: ffffffc098cc3500 x24: ffffffc0a13f2810
x23: ffffffc098cc3501 x22: ffffffc0a13f2800
x21: 000011e1a02006e3 x20: ffffffc0a13f2800
x19: ffffffbc02a7e000 x18: 0000000000000000
x17: 0000000000000000 x16: 0000000000000feb
x15: 0000000000000000 x14: 00000000a01003e3
x13: 0000000000000020 x12: fffffffffffffff0
x11: ffffffc08b264000 x10: 00000000e3a01004
x9 : ffffffc08b263fea x8 : ffffffc0b1e611c0
x7 : ffffffc000307d24 x6 : 0000000000000000
x5 : 0000000000000038 x4 : 000000000000011e
x3 : ffffffbc00003e90 x2 : 0000000000000cc0
x1 : 00000000d0100371 x0 : ffffffbc00003e90
Reported-by: Sooyong Suk <s.suk@samsung.com>
Signed-off-by: Heesub Shin <heesub.shin@samsung.com>
Tested-by: Sooyong Suk <s.suk@samsung.com>
In putback_zspage, we don't need to insert a zspage into list of zspage
in size_class again to just fix fullness group. We could do directly
without reinsertion so we could save some instuctions.
Reported-by: Heesub Shin <heesub.shin@samsung.com>
Signed-off-by: Minchan Kim <minchan@kernel.org>
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Dan Streetman <ddstreet@ieee.org>
Cc: Seth Jennings <sjennings@variantweb.net>
Cc: Ganesh Mahendran <opensource.ganesh@gmail.com>
Cc: Luigi Semenzato <semenzato@google.com>
Cc: Gunho Lee <gunho.lee@lge.com>
Cc: Juneho Choi <juno.choi@lge.com>
A micro-optimization. Avoid additional branching and reduce (a bit)
registry pressure (f.e. s_off += size; d_off += size; may be calculated
twise: first for >= PAGE_SIZE check and later for offset update in "else"
clause).
scripts/bloat-o-meter shows some improvement
add/remove: 0/0 grow/shrink: 0/1 up/down: 0/-10 (-10)
function old new delta
zs_object_copy 550 540 -10
Do not synchronize rcu in zs_compact(). Neither zsmalloc not
zram use rcu.
Signed-off-by: Yinghao Xie <yinghao.xie@sumsung.com>
Suggested-by: Minchan Kim <minchan@kernel.org>
Create zsmalloc doc which explains design concept and stat information.
Cc: Jerome Marchand <jmarchan@redhat.com>
During investigating compaction, fullness information of each class is
helpful for investigating how the compaction works well. With that, we
could know how compaction works well more clear on each size class.
We store handle on header of each allocated object so it increases the
size of each object by sizeof(unsigned long).
If zram stores 4096 bytes to zsmalloc(ie, bad compression), zsmalloc needs
4104B-class to add handle.
However, 4104B-class has 1-pages_per_zspage so wasted size by internal
fragment is 8192 - 4104, which is terrible.
So this patch records the handle in page->private on such huge object(ie,
pages_per_zspage == 1 && maxobj_per_zspage == 1) instead of header of each
object so we could use 4096B-class, not 4104B-class.
Curretly, zsmalloc regards a zspage as ZS_ALMOST_EMPTY if the zspage has
under 1/4 used objects(ie, fullness_threshold_frac). It could make result
in loose packing since zsmalloc migrates only ZS_ALMOST_EMPTY zspage out.
This patch changes the rule so that zsmalloc makes zspage which has above
3/4 used object ZS_ALMOST_FULL so it could make tight packing.
This patch provides core functions for migration of zsmalloc. Migraion
policy is simple as follows.
for each size class {
while {
src_page = get zs_page from ZS_ALMOST_EMPTY
if (!src_page)
break;
dst_page = get zs_page from ZS_ALMOST_FULL
if (!dst_page)
dst_page = get zs_page from ZS_ALMOST_EMPTY
if (!dst_page)
break;
migrate(from src_page, to dst_page);
For migration, we need to identify which objects in zspage are allocated
to migrate them out. We could know it by iterating of freed objects in a
zspage because first_page of zspage keeps free objects singly-linked list
but it's not efficient. Instead, this patch adds a tag(ie,
OBJ_ALLOCATED_TAG) in header of each object(ie, handle) so we could check
whether the object is allocated easily.
This patch adds another status bit in handle to synchronize between user
access through zs_map_object and migration. During migration, we cannot
move objects user are using due to data coherency between old object and
new object.
[akpm@linux-foundation.org: zsmalloc.c needs sched.h for cond_resched()]
In later patch, migration needs some part of functions in zs_malloc and
zs_free so this patch factor out them.
Recently, we started to use zram heavily and some of issues
popped.
1) external fragmentation
I got a report from Juneho Choi that fork failed although there are plenty
of free pages in the system. His investigation revealed zram is one of
the culprit to make heavy fragmentation so there was no more contiguous
16K page for pgd to fork in the ARM.
2) non-movable pages
Other problem of zram now is that inherently, user want to use zram as
swap in small memory system so they use zRAM with CMA to use memory
efficiently. However, unfortunately, it doesn't work well because zRAM
cannot use CMA's movable pages unless it doesn't support compaction. I
got several reports about that OOM happened with zram although there are
lots of swap space and free space in CMA area.
3) internal fragmentation
zRAM has started support memory limitation feature to limit memory usage
and I sent a patchset(https://lkml.org/lkml/2014/9/21/148) for VM to be
harmonized with zram-swap to stop anonymous page reclaim if zram consumed
memory up to the limit although there are free space on the swap. One
problem for that direction is zram has no way to know any hole in memory
space zsmalloc allocated by internal fragmentation so zram would regard
swap is full although there are free space in zsmalloc. For solving the
issue, zram want to trigger compaction of zsmalloc before it decides full
or not.
This patchset is first step to support above issues. For that, it adds
indirect layer between handle and object location and supports manual
compaction to solve 3th problem first of all.
After this patchset got merged, next step is to make VM aware of zsmalloc
compaction so that generic compaction will move zsmalloced-pages
automatically in runtime.
In my imaginary experiment(ie, high compress ratio data with heavy swap
in/out on 8G zram-swap), data is as follows,
Before =
zram allocated object : 60212066 bytes
zram total used: 140103680 bytes
ratio: 42.98 percent
MemFree: 840192 kB
Compaction
After =
frag ratio after compaction
zram total used: 76185600 bytes
ratio: 79.03 percent
MemFree: 901932 kB
Juneho reported below in his real platform with small aging.
So, I think the benefit would be bigger in real aging system
for a long time.
- frag_ratio increased 3% (ie, higher is better)
- memfree increased about 6MB
- In buddy info, Normal 2^3: 4, 2^2: 1: 2^1 increased, Highmem: 2^1 21 increased
frag ratio after swap fragment
used : 156677 kbytes
total: 166092 kbytes
frag_ratio : 94
meminfo before compaction
MemFree: 83724 kB
Node 0, zone Normal 13642 1364 57 10 61 17 9 5 4 0 0
Node 0, zone HighMem 425 29 1 0 0 0 0 0 0 0 0
num_migrated : 23630
compaction done
used : 156673 kbytes
total: 160564 kbytes
frag_ratio : 97
meminfo after compaction
MemFree: 89060 kB
Node 0, zone Normal 14076 1544 67 14 61 17 9 5 4 0 0
Node 0, zone HighMem 863 50 1 0 0 0 0 0 0 0 0
This patchset adds more logics(about 480 lines) in zsmalloc but when I
tested heavy swapin/out program, the regression for swapin/out speed is
marginal because most of overheads were caused by compress/decompress and
other MM reclaim stuff.
This patch (of 7):
Currently, handle of zsmalloc encodes object's location directly so it
makes support of migration hard.
This patch decouples handle and object via adding indirect layer. For
that, it allocates handle dynamically and returns it to user. The handle
is the address allocated by slab allocation so it's unique and we could
keep object's location in the memory space allocated for handle.
With it, we can change object's position without changing handle itself.
mm/compaction.c:250:13: warning: 'suitable_migration_target' defined but not used [-Wunused-function]
Reported-by: Fengguang Wu <fengguang.wu@gmail.com>
This will allow FS that uses VM_PFNMAP | VM_MIXEDMAP (no page structs) to
get notified when access is a write to a read-only PFN.
This can happen if we mmap() a file then first mmap-read from it to
page-in a read-only PFN, than we mmap-write to the same page.
We need this functionality to fix a DAX bug, where in the scenario above
we fail to set ctime/mtime though we modified the file. An xfstest is
attached to this patchset that shows the failure and the fix. (A DAX
patch will follow)
This functionality is extra important for us, because upon dirtying of a
pmem page we also want to RDMA the page to a remote cluster node.
We define a new pfn_mkwrite and do not reuse page_mkwrite because
1 - The name ;-)
2 - But mainly because it would take a very long and tedious
audit of all page_mkwrite functions of VM_MIXEDMAP/VM_PFNMAP
users. To make sure they do not now CRASH. For example current
DAX code (which this is for) would crash.
If we would want to reuse page_mkwrite, We will need to first
patch all users, so to not-crash-on-no-page. Then enable this
patch. But even if I did that I would not sleep so well at night.
Adding a new vector is the safest thing to do, and is not that
expensive. an extra pointer at a static function vector per driver.
Also the new vector is better for performance, because else we
Will call all current Kernel vectors, so to:
check-ha-no-page-do-nothing and return.
No need to call it from do_shared_fault because do_wp_page is called to
change pte permissions anyway.
Signed-off-by: Yigal Korman <yigal@plexistor.com>
Signed-off-by: Boaz Harrosh <boaz@plexistor.com>
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Matthew Wilcox <matthew.r.wilcox@intel.com>
Cc: Jan Kara <jack@suse.cz>
A lot of filesystems use generic_file_mmap() and filemap_fault(),
f_op->mmap and vm_ops->fault aren't enough to identify filesystem.
This prints file name, vm_ops->fault, f_op->mmap and a_ops->readpage
(which is almost always implemented and filesystem-specific).
Example:
[ 23.676410] BUG: Bad page map in process sh pte:1b7e6025 pmd:19bbd067
[ 23.676887] page:ffffea00006df980 count:4 mapcount:1 mapping:ffff8800196426c0 index:0x97
[ 23.677481] flags: 0x10000000000000c(referenced|uptodate)
[ 23.677896] page dumped because: bad pte
[ 23.678205] addr:00007f52fcb17000 vm_flags:00000075 anon_vma: (null) mapping:ffff8800196426c0 index:97
[ 23.678922] file:libc-2.19.so fault:filemap_fault mmap:generic_file_readonly_mmap readpage:v9fs_vfs_readpage
[akpm@linux-foundation.org: use pr_alert, per Kirill]
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Cc: Sasha Levin <sasha.levin@oracle.com>
Acked-by: Kirill A. Shutemov <kirill@shutemov.name>
Mempools keep allocated objects in reserved for situations when ordinary
allocation may not be possible to satisfy. These objects shouldn't be
accessed before they leave the pool.
This patch poison elements when get into the pool and unpoison when they
leave it. This will let KASan to detect use-after-free of mempool's
elements.
Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com>
Tested-by: David Rientjes <rientjes@google.com>
Cc: Dmitry Chernenkov <drcheren@gmail.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Alexander Potapenko <glider@google.com>
Like EXPORT_SYMBOL(): the positioning communicates that the macro pertains
to the immediately preceding function.
Cc: Dmitry Safonov <d.safonov@partner.samsung.com>
Cc: Michal Nazarewicz <mina86@mina86.com>
Cc: Stefan Strogin <stefan.strogin@gmail.com>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
Cc: Pintu Kumar <pintu.k@samsung.com>
Cc: Weijie Yang <weijie.yang@samsung.com>
Cc: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Cc: Vyacheslav Tyrtov <v.tyrtov@samsung.com>
Cc: Aleksei Mateosian <a.mateosian@samsung.com>
