path: root/mm/zsmalloc.c
2019-08-30mm/zsmalloc.c: fix build when CONFIG_COMPACTION=nAndrew Morton
Fixes: 701d678599d0c1 ("mm/zsmalloc.c: fix race condition in zs_destroy_pool") Link: http://lkml.kernel.org/r/201908251039.5oSbEEUT%25lkp@intel.com Reported-by: kbuild test robot <lkp@intel.com> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Henry Burns <henrywolfeburns@gmail.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Shakeel Butt <shakeelb@google.com> Cc: Jonathan Adams <jwadams@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-08-24mm/zsmalloc.c: fix race condition in zs_destroy_poolHenry Burns
In zs_destroy_pool() we call flush_work(&pool->free_work). However, we have no guarantee that migration isn't happening in the background at that time. Since migration can't directly free pages, it relies on free_work being scheduled to free the pages. But there's nothing preventing an in-progress migrate from queuing the work *after* zs_unregister_migration() has called flush_work(). Which would mean pages still pointing at the inode when we free it. Since we know at destroy time all objects should be free, no new migrations can come in (since zs_page_isolate() fails for fully-free zspages). This means it is sufficient to track a "# isolated zspages" count by class, and have the destroy logic ensure all such pages have drained before proceeding. Keeping that state under the class spinlock keeps the logic straightforward. In this case a memory leak could lead to an eventual crash if compaction hits the leaked page. This crash would only occur if people are changing their zswap backend at runtime (which eventually starts destruction). Link: http://lkml.kernel.org/r/20190809181751.219326-2-henryburns@google.com Fixes: 48b4800a1c6a ("zsmalloc: page migration support") Signed-off-by: Henry Burns <henryburns@google.com> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Henry Burns <henrywolfeburns@gmail.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Shakeel Butt <shakeelb@google.com> Cc: Jonathan Adams <jwadams@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-08-24mm/zsmalloc.c: migration can leave pages in ZS_EMPTY indefinitelyHenry Burns
In zs_page_migrate() we call putback_zspage() after we have finished migrating all pages in this zspage. However, the return value is ignored. If a zs_free() races in between zs_page_isolate() and zs_page_migrate(), freeing the last object in the zspage, putback_zspage() will leave the page in ZS_EMPTY for potentially an unbounded amount of time. To fix this, we need to do the same thing as zs_page_putback() does: schedule free_work to occur. To avoid duplicated code, move the sequence to a new putback_zspage_deferred() function which both zs_page_migrate() and zs_page_putback() call. Link: http://lkml.kernel.org/r/20190809181751.219326-1-henryburns@google.com Fixes: 48b4800a1c6a ("zsmalloc: page migration support") Signed-off-by: Henry Burns <henryburns@google.com> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Henry Burns <henrywolfeburns@gmail.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Shakeel Butt <shakeelb@google.com> Cc: Jonathan Adams <jwadams@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-07-19Merge branch 'work.mount0' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs mount updates from Al Viro: "The first part of mount updates. Convert filesystems to use the new mount API" * 'work.mount0' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits) mnt_init(): call shmem_init() unconditionally constify ksys_mount() string arguments don't bother with registering rootfs init_rootfs(): don't bother with init_ramfs_fs() vfs: Convert smackfs to use the new mount API vfs: Convert selinuxfs to use the new mount API vfs: Convert securityfs to use the new mount API vfs: Convert apparmorfs to use the new mount API vfs: Convert openpromfs to use the new mount API vfs: Convert xenfs to use the new mount API vfs: Convert gadgetfs to use the new mount API vfs: Convert oprofilefs to use the new mount API vfs: Convert ibmasmfs to use the new mount API vfs: Convert qib_fs/ipathfs to use the new mount API vfs: Convert efivarfs to use the new mount API vfs: Convert configfs to use the new mount API vfs: Convert binfmt_misc to use the new mount API convenience helper: get_tree_single() convenience helper get_tree_nodev() vfs: Kill sget_userns() ...
2019-06-05mm/zsmalloc.c: remove unused variableAnders Roxell
The variable 'entry' is no longer used and the compiler rightly complains that it should be removed. ../mm/zsmalloc.c: In function `zs_pool_stat_create': ../mm/zsmalloc.c:648:17: warning: unused variable `entry' [-Wunused-variable] struct dentry *entry; ^~~~~ Rework to remove the unused variable. Link: http://lkml.kernel.org/r/20190604065826.26064-1-anders.roxell@linaro.org Fixes: 4268509a36a7 ("zsmalloc: no need to check return value of debugfs_create functions") Signed-off-by: Anders Roxell <anders.roxell@linaro.org> Cc: Minchan Kim <minchan@kernel.org> Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-06-03zsmalloc: no need to check return value of debugfs_create functionsGreg Kroah-Hartman
When calling debugfs functions, there is no need to ever check the return value. The function can work or not, but the code logic should never do something different based on this. Cc: Minchan Kim <minchan@kernel.org> Cc: Nitin Gupta <ngupta@vflare.org> Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com> Cc: linux-mm@kvack.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-25vfs: Convert zsmalloc to use the new mount APIDavid Howells
Convert the zsmalloc filesystem to the new internal mount API as the old one will be obsoleted and removed. This allows greater flexibility in communication of mount parameters between userspace, the VFS and the filesystem. See Documentation/filesystems/mount_api.txt for more information. Signed-off-by: David Howells <dhowells@redhat.com> cc: Minchan Kim <minchan@kernel.org> cc: Nitin Gupta <ngupta@vflare.org> cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com> cc: linux-mm@kvack.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2019-05-25mount_pseudo(): drop 'name' argument, switch to d_make_root()Al Viro
Once upon a time we used to set ->d_name of e.g. pipefs root so that d_path() on pipes would work. These days it's completely pointless - dentries of pipes are not even connected to pipefs root. However, mount_pseudo() had set the root dentry name (passed as the second argument) and callers kept inventing names to pass to it. Including those that didn't *have* any non-root dentries to start with... All of that had been pointless for about 8 years now; it's time to get rid of that cargo-culting... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2019-05-20zsmalloc: don't bother with dentry_operationsAl Viro
2018-10-26mm/zsmalloc.c: fix fall-through annotationGustavo A. R. Silva
Replace "fallthru" with a proper "fall through" annotation. This fix is part of the ongoing efforts to enabling -Wimplicit-fallthrough Link: http://lkml.kernel.org/r/20181003105114.GA24423@embeddedor.com Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-08-17mm/zsmalloc.c: make several functions and a struct staticColin Ian King
The functions zs_page_isolate, zs_page_migrate, zs_page_putback, lock_zspage, trylock_zspage and structure zsmalloc_aops are local to source and do not need to be in global scope, so make them static. Cleans up sparse warnings: symbol 'zs_page_isolate' was not declared. Should it be static? symbol 'zs_page_migrate' was not declared. Should it be static? symbol 'zs_page_putback' was not declared. Should it be static? symbol 'zsmalloc_aops' was not declared. Should it be static? symbol 'lock_zspage' was not declared. Should it be static? symbol 'trylock_zspage' was not declared. Should it be static? [arnd@arndb.de: hide unused lock_zspage] Link: http://lkml.kernel.org/r/20180706130924.3891230-1-arnd@arndb.de Link: http://lkml.kernel.org/r/20180624213322.13776-1-colin.king@canonical.com Signed-off-by: Colin Ian King <colin.king@canonical.com> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-06-15mm: use octal not symbolic permissionsJoe Perches
mm/*.c files use symbolic and octal styles for permissions. Using octal and not symbolic permissions is preferred by many as more readable. https://lkml.org/lkml/2016/8/2/1945 Prefer the direct use of octal for permissions. Done using $ scripts/checkpatch.pl -f --types=SYMBOLIC_PERMS --fix-inplace mm/*.c and some typing. Before: $ git grep -P -w "0[0-7]{3,3}" mm | wc -l 44 After: $ git grep -P -w "0[0-7]{3,3}" mm | wc -l 86 Miscellanea: o Whitespace neatening around these conversions. Link: http://lkml.kernel.org/r/2e032ef111eebcd4c5952bae86763b541d373469.1522102887.git.joe@perches.com Signed-off-by: Joe Perches <joe@perches.com> Acked-by: David Rientjes <rientjes@google.com> Acked-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-04-05mm: kernel-doc: add missing parameter descriptionsMike Rapoport
Link: http://lkml.kernel.org/r/1519585191-10180-4-git-send-email-rppt@linux.vnet.ibm.com Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-04-05zsmalloc: introduce zs_huge_class_size()Sergey Senozhatsky
Patch series "zsmalloc/zram: drop zram's max_zpage_size", v3. ZRAM's max_zpage_size is a bad thing. It forces zsmalloc to store normal objects as huge ones, which results in bigger zsmalloc memory usage. Drop it and use actual zsmalloc huge-class value when decide if the object is huge or not. This patch (of 2): Not every object can be share its zspage with other objects, e.g. when the object is as big as zspage or nearly as big a zspage. For such objects zsmalloc has a so called huge class - every object which belongs to huge class consumes the entire zspage (which consists of a physical page). On x86_64, PAGE_SHIFT 12 box, the first non-huge class size is 3264, so starting down from size 3264, objects can share page(-s) and thus minimize memory wastage. ZRAM, however, has its own statically defined watermark for huge objects, namely "3 * PAGE_SIZE / 4 = 3072", and forcibly stores every object larger than this watermark (3072) as a PAGE_SIZE object, in other words, to a huge class, while zsmalloc can keep some of those objects in non-huge classes. This results in increased memory consumption. zsmalloc knows better if the object is huge or not. Introduce zs_huge_class_size() function which tells if the given object can be stored in one of non-huge classes or not. This will let us to drop ZRAM's huge object watermark and fully rely on zsmalloc when we decide if the object is huge. [sergey.senozhatsky.work@gmail.com: add pool param to zs_huge_class_size()] Link: http://lkml.kernel.org/r/20180314081833.1096-2-sergey.senozhatsky@gmail.com Link: http://lkml.kernel.org/r/20180306070639.7389-2-sergey.senozhatsky@gmail.com Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Cc: Mike Rapoport <rppt@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-04-05mm: reuse DEFINE_SHOW_ATTRIBUTE() macroAndy Shevchenko
...instead of open coding file operations followed by custom ->open() callbacks per each attribute. [andriy.shevchenko@linux.intel.com: add tags, fix compilation issue] Link: http://lkml.kernel.org/r/20180217144253.58604-1-andriy.shevchenko@linux.intel.com Link: http://lkml.kernel.org/r/20180214154644.54505-1-andriy.shevchenko@linux.intel.com Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Matthew Wilcox <mawilcox@microsoft.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Christoph Lameter <cl@linux.com> Cc: Tejun Heo <tj@kernel.org> Cc: Dennis Zhou <dennisszhou@gmail.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Nitin Gupta <ngupta@vflare.org> Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-02-14mm/zsmalloc: Prepare to variable MAX_PHYSMEM_BITSKirill A. Shutemov
With boot-time switching between paging mode we will have variable MAX_PHYSMEM_BITS. Let's use the maximum variable possible for CONFIG_X86_5LEVEL=y configuration to define zsmalloc data structures. The patch introduces MAX_POSSIBLE_PHYSMEM_BITS to cover such case. It also suits well to handle PAE special case. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Reviewed-by: Nitin Gupta <ngupta@vflare.org> Acked-by: Minchan Kim <minchan@kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@suse.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-mm@kvack.org Link: http://lkml.kernel.org/r/20180214111656.88514-3-kirill.shutemov@linux.intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2018-01-31zsmalloc: use U suffix for negative literals being shiftedNick Desaulniers
Fix warning about shifting unsigned literals being undefined behavior. Link: http://lkml.kernel.org/r/1515642078-4259-1-git-send-email-nick.desaulniers@gmail.com Signed-off-by: Nick Desaulniers <nick.desaulniers@gmail.com> Suggested-by: Minchan Kim <minchan@kernel.org> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Andy Shevchenko <andy.shevchenko@gmail.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Nick Desaulniers <nick.desaulniers@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-01-31zswap: only save zswap header when necessaryYu Zhao
We waste sizeof(swp_entry_t) for zswap header when using zsmalloc as zpool driver because zsmalloc doesn't support eviction. Add zpool_evictable() to detect if zpool is potentially evictable, and use it in zswap to avoid waste memory for zswap header. [yuzhao@google.com: The zpool->" prefix is a result of copy & paste] Link: http://lkml.kernel.org/r/20180110225626.110330-1-yuzhao@google.com Link: http://lkml.kernel.org/r/20180110224741.83751-1-yuzhao@google.com Signed-off-by: Yu Zhao <yuzhao@google.com> Acked-by: Dan Streetman <ddstreet@ieee.org> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Seth Jennings <sjenning@redhat.com> Cc: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-01-31mm/zsmalloc: simplify shrinker init/destroyAliaksei Karaliou
Structure zs_pool has special flag to indicate success of shrinker initialization. unregister_shrinker() has improved and can detect by itself whether actual deinitialization should be performed or not, so extra flag becomes redundant. [akpm@linux-foundation.org: update comment (Aliaksei), remove unneeded cast] Link: http://lkml.kernel.org/r/1513680552-9798-1-git-send-email-akaraliou.dev@gmail.com Signed-off-by: Aliaksei Karaliou <akaraliou.dev@gmail.com> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Cc: Michal Hocko <mhocko@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-01-04mm/zsmalloc.c: include fs.hSergey Senozhatsky
`struct file_system_type' and alloc_anon_inode() function are defined in fs.h, include it directly. Link: http://lkml.kernel.org/r/20171219104219.3017-1-sergey.senozhatsky@gmail.com Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-11-15zsmalloc: calling zs_map_object() from irq is a bugSergey Senozhatsky
Use BUG_ON(in_interrupt()) in zs_map_object(). This is not a new BUG_ON(), it's always been there, but was recently changed to VM_BUG_ON(). There are several problems there. First, we use use per-CPU mappings both in zsmalloc and in zram, and interrupt may easily corrupt those buffers. Second, and more importantly, we believe it's possible to start leaking sensitive information. Consider the following case: -> process P swap out zram per-cpu mapping CPU1 compress page A -> IRQ swap out zram per-cpu mapping CPU1 compress page B write page from per-cpu mapping CPU1 to zsmalloc pool iret -> process P write page from per-cpu mapping CPU1 to zsmalloc pool [*] return * so we store overwritten data that actually belongs to another page (task) and potentially contains sensitive data. And when process P will page fault it's going to read (swap in) that other task's data. Link: http://lkml.kernel.org/r/20170929045140.4055-1-sergey.senozhatsky@gmail.com Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-09-08mm/zsmalloc.c: change stat type parameter to intMatthias Kaehlcke
zs_stat_inc/dec/get() uses enum zs_stat_type for the stat type, however some callers pass an enum fullness_group value. Change the type to int to reflect the actual use of the functions and get rid of 'enum-conversion' warnings Link: http://lkml.kernel.org/r/20170731175000.56538-1-mka@chromium.org Signed-off-by: Matthias Kaehlcke <mka@chromium.org> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Cc: Doug Anderson <dianders@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-09-08mm/migrate: new migrate mode MIGRATE_SYNC_NO_COPYJérôme Glisse
Introduce a new migration mode that allow to offload the copy to a device DMA engine. This changes the workflow of migration and not all address_space migratepage callback can support this. This is intended to be use by migrate_vma() which itself is use for thing like HMM (see include/linux/hmm.h). No additional per-filesystem migratepage testing is needed. I disables MIGRATE_SYNC_NO_COPY in all problematic migratepage() callback and i added comment in those to explain why (part of this patch). The commit message is unclear it should say that any callback that wish to support this new mode need to be aware of the difference in the migration flow from other mode. Some of these callbacks do extra locking while copying (aio, zsmalloc, balloon, ...) and for DMA to be effective you want to copy multiple pages in one DMA operations. But in the problematic case you can not easily hold the extra lock accross multiple call to this callback. Usual flow is: For each page { 1 - lock page 2 - call migratepage() callback 3 - (extra locking in some migratepage() callback) 4 - migrate page state (freeze refcount, update page cache, buffer head, ...) 5 - copy page 6 - (unlock any extra lock of migratepage() callback) 7 - return from migratepage() callback 8 - unlock page } The new mode MIGRATE_SYNC_NO_COPY: 1 - lock multiple pages For each page { 2 - call migratepage() callback 3 - abort in all problematic migratepage() callback 4 - migrate page state (freeze refcount, update page cache, buffer head, ...) } // finished all calls to migratepage() callback 5 - DMA copy multiple pages 6 - unlock all the pages To support MIGRATE_SYNC_NO_COPY in the problematic case we would need a new callback migratepages() (for instance) that deals with multiple pages in one transaction. Because the problematic cases are not important for current usage I did not wanted to complexify this patchset even more for no good reason. Link: http://lkml.kernel.org/r/20170817000548.32038-14-jglisse@redhat.com Signed-off-by: Jérôme Glisse <jglisse@redhat.com> Cc: Aneesh Kumar <aneesh.kumar@linux.vnet.ibm.com> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dan Williams <dan.j.williams@intel.com> Cc: David Nellans <dnellans@nvidia.com> Cc: Evgeny Baskakov <ebaskakov@nvidia.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: John Hubbard <jhubbard@nvidia.com> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Mark Hairgrove <mhairgrove@nvidia.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Sherry Cheung <SCheung@nvidia.com> Cc: Subhash Gutti <sgutti@nvidia.com> Cc: Vladimir Davydov <vdavydov.dev@gmail.com> Cc: Bob Liu <liubo95@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-09-06zsmalloc: zs_page_migrate: skip unnecessary loops but not return -EBUSY if ↵Hui Zhu
zspage is not inuse Getting -EBUSY from zs_page_migrate will make migration slow (retry) or fail (zs_page_putback will schedule_work free_work, but it cannot ensure the success). I noticed this issue because my Kernel patched (https://lkml.org/lkml/2014/5/28/113) that will remove retry in __alloc_contig_migrate_range. This retry will handle the -EBUSY because it will re-isolate the page and re-call migrate_pages. Without it will make cma_alloc fail at once with -EBUSY. According to the review from Minchan Kim in https://lkml.org/lkml/2014/5/28/113, I update the patch to skip unnecessary loops but not return -EBUSY if zspage is not inuse. Following is what I got with highalloc-performance in a vbox with 2 cpu 1G memory 512 zram as swap. And the swappiness is set to 100. ori ne orig new Minor Faults 50805113 50830235 Major Faults 43918 56530 Swap Ins 42087 55680 Swap Outs 89718 104700 Allocation stalls 0 0 DMA allocs 57787 52364 DMA32 allocs 47964599 48043563 Normal allocs 0 0 Movable allocs 0 0 Direct pages scanned 45493 23167 Kswapd pages scanned 1565222 1725078 Kswapd pages reclaimed 1342222 1503037 Direct pages reclaimed 45615 25186 Kswapd efficiency 85% 87% Kswapd velocity 1897.101 1949.042 Direct efficiency 100% 108% Direct velocity 55.139 26.175 Percentage direct scans 2% 1% Zone normal velocity 1952.240 1975.217 Zone dma32 velocity 0.000 0.000 Zone dma velocity 0.000 0.000 Page writes by reclaim 89764.000 105233.000 Page writes file 46 533 Page writes anon 89718 104700 Page reclaim immediate 21457 3699 Sector Reads 3259688 3441368 Sector Writes 3667252 3754836 Page rescued immediate 0 0 Slabs scanned 1042872 1160855 Direct inode steals 8042 10089 Kswapd inode steals 54295 29170 Kswapd skipped wait 0 0 THP fault alloc 175 154 THP collapse alloc 226 289 THP splits 0 0 THP fault fallback 11 14 THP collapse fail 3 2 Compaction stalls 536 646 Compaction success 322 358 Compaction failures 214 288 Page migrate success 119608 111063 Page migrate failure 2723 2593 Compaction pages isolated 250179 232652 Compaction migrate scanned 9131832 9942306 Compaction free scanned 2093272 2613998 Compaction cost 192 189 NUMA alloc hit 47124555 47193990 NUMA alloc miss 0 0 NUMA interleave hit 0 0 NUMA alloc local 47124555 47193990 NUMA base PTE updates 0 0 NUMA huge PMD updates 0 0 NUMA page range updates 0 0 NUMA hint faults 0 0 NUMA hint local faults 0 0 NUMA hint local percent 100 100 NUMA pages migrated 0 0 AutoNUMA cost 0% 0% [akpm@linux-foundation.org: remove newline, per Minchan] Link: http://lkml.kernel.org/r/1500889535-19648-1-git-send-email-zhuhui@xiaomi.com Signed-off-by: Hui Zhu <zhuhui@xiaomi.com> Acked-by: Minchan Kim <minchan@kernel.org> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-08-02zram: do not free pool->size_classMinchan Kim
Mike reported kernel goes oops with ltp:zram03 testcase. zram: Added device: zram0 zram0: detected capacity change from 0 to 107374182400 BUG: unable to handle kernel paging request at 0000306d61727a77 IP: zs_map_object+0xb9/0x260 PGD 0 P4D 0 Oops: 0000 [#1] SMP Dumping ftrace buffer: (ftrace buffer empty) Modules linked in: zram(E) xfs(E) libcrc32c(E) btrfs(E) xor(E) raid6_pq(E) loop(E) ebtable_filter(E) ebtables(E) ip6table_filter(E) ip6_tables(E) iptable_filter(E) ip_tables(E) x_tables(E) af_packet(E) br_netfilter(E) bridge(E) stp(E) llc(E) iscsi_ibft(E) iscsi_boot_sysfs(E) nls_iso8859_1(E) nls_cp437(E) vfat(E) fat(E) intel_powerclamp(E) coretemp(E) cdc_ether(E) kvm_intel(E) usbnet(E) mii(E) kvm(E) irqbypass(E) crct10dif_pclmul(E) crc32_pclmul(E) crc32c_intel(E) iTCO_wdt(E) ghash_clmulni_intel(E) bnx2(E) iTCO_vendor_support(E) pcbc(E) ioatdma(E) ipmi_ssif(E) aesni_intel(E) i5500_temp(E) i2c_i801(E) aes_x86_64(E) lpc_ich(E) shpchp(E) mfd_core(E) crypto_simd(E) i7core_edac(E) dca(E) glue_helper(E) cryptd(E) ipmi_si(E) button(E) acpi_cpufreq(E) ipmi_devintf(E) pcspkr(E) ipmi_msghandler(E) nfsd(E) auth_rpcgss(E) nfs_acl(E) lockd(E) grace(E) sunrpc(E) ext4(E) crc16(E) mbcache(E) jbd2(E) sd_mod(E) ata_generic(E) i2c_algo_bit(E) ata_piix(E) drm_kms_helper(E) ahci(E) syscopyarea(E) sysfillrect(E) libahci(E) sysimgblt(E) fb_sys_fops(E) uhci_hcd(E) ehci_pci(E) ttm(E) ehci_hcd(E) libata(E) drm(E) megaraid_sas(E) usbcore(E) sg(E) dm_multipath(E) dm_mod(E) scsi_dh_rdac(E) scsi_dh_emc(E) scsi_dh_alua(E) scsi_mod(E) efivarfs(E) autofs4(E) [last unloaded: zram] CPU: 6 PID: 12356 Comm: swapon Tainted: G E 4.13.0.g87b2c3f-default #194 Hardware name: IBM System x3550 M3 -[7944K3G]-/69Y5698 , BIOS -[D6E150AUS-1.10]- 12/15/2010 task: ffff880158d2c4c0 task.stack: ffffc90001680000 RIP: 0010:zs_map_object+0xb9/0x260 Call Trace: zram_bvec_rw.isra.26+0xe8/0x780 [zram] zram_rw_page+0x6e/0xa0 [zram] bdev_read_page+0x81/0xb0 do_mpage_readpage+0x51a/0x710 mpage_readpages+0x122/0x1a0 blkdev_readpages+0x1d/0x20 __do_page_cache_readahead+0x1b2/0x270 ondemand_readahead+0x180/0x2c0 page_cache_sync_readahead+0x31/0x50 generic_file_read_iter+0x7e7/0xaf0 blkdev_read_iter+0x37/0x40 __vfs_read+0xce/0x140 vfs_read+0x9e/0x150 SyS_read+0x46/0xa0 entry_SYSCALL_64_fastpath+0x1a/0xa5 Code: 81 e6 00 c0 3f 00 81 fe 00 00 16 00 0f 85 9f 01 00 00 0f b7 13 65 ff 05 5e 07 dc 7e 66 c1 ea 02 81 e2 ff 01 00 00 49 8b 54 d4 08 <8b> 4a 48 41 0f af ce 81 e1 ff 0f 00 00 41 89 c9 48 c7 c3 a0 70 RIP: zs_map_object+0xb9/0x260 RSP: ffffc90001683988 CR2: 0000306d61727a77 He bisected the problem is [1]. After commit cf8e0fedf078 ("mm/zsmalloc: simplify zs_max_alloc_size handling"), zram doesn't use double pointer for pool->size_class any more in zs_create_pool so counter function zs_destroy_pool don't need to free it, either. Otherwise, it does kfree wrong address and then, kernel goes Oops. Link: http://lkml.kernel.org/r/20170725062650.GA12134@bbox Fixes: cf8e0fedf078 ("mm/zsmalloc: simplify zs_max_alloc_size handling") Signed-off-by: Minchan Kim <minchan@kernel.org> Reported-by: Mike Galbraith <efault@gmx.de> Tested-by: Mike Galbraith <efault@gmx.de> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Jerome Marchand <jmarchan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-07-10mm/zsmalloc: simplify zs_max_alloc_size handlingJerome Marchand
Commit 40f9fb8cffc6 ("mm/zsmalloc: support allocating obj with size of ZS_MAX_ALLOC_SIZE") fixes a size calculation error that prevented zsmalloc to allocate an object of the maximal size (ZS_MAX_ALLOC_SIZE). I think however the fix is unneededly complicated. This patch replaces the dynamic calculation of zs_size_classes at init time by a compile time calculation that uses the DIV_ROUND_UP() macro already used in get_size_class_index(). [akpm@linux-foundation.org: use min_t] Link: http://lkml.kernel.org/r/20170630114859.1979-1-jmarchan@redhat.com Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Acked-by: Minchan Kim <minchan@kernel.org> Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com> Cc: Mahendran Ganesh <opensource.ganesh@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-07-10mm/zsmalloc.c: fix -Wunneeded-internal-declaration warningNick Desaulniers
is_first_page() is only called from the macro VM_BUG_ON_PAGE() which is only compiled in as a runtime check when CONFIG_DEBUG_VM is set, otherwise is checked at compile time and not actually compiled in. Fixes the following warning, found with Clang: mm/zsmalloc.c:472:12: warning: function 'is_first_page' is not needed and will not be emitted [-Wunneeded-internal-declaration] static int is_first_page(struct page *page) ^ Link: http://lkml.kernel.org/r/20170524053859.29059-1-nick.desaulniers@gmail.com Signed-off-by: Nick Desaulniers <nick.desaulniers@gmail.com> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-04-13zsmalloc: expand class bitMinchan Kim
Now 64K page system, zsamlloc has 257 classes so 8 class bit is not enough. With that, it corrupts the system when zsmalloc stores 65536byte data(ie, index number 256) so that this patch increases class bit for simple fix for stable backport. We should clean up this mess soon. index size 0 32 1 288 .. .. 204 52256 256 65536 Fixes: 3783689a1 ("zsmalloc: introduce zspage structure") Link: http://lkml.kernel.org/r/1492042622-12074-3-git-send-email-minchan@kernel.org Signed-off-by: Minchan Kim <minchan@kernel.org> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-03-02sched/headers: Prepare to remove the <linux/magic.h> include from ↵Ingo Molnar
<linux/sched/task_stack.h> Update files that depend on the magic.h inclusion. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-02-24mm/zsmalloc: fix comment in zsmallocYisheng Xie
The class index and fullness group are not encoded in (first)page->mapping any more, after commit 3783689a1aa8 ("zsmalloc: introduce zspage structure"). Instead, they are store in struct zspage. Just delete this unneeded comment. Link: http://lkml.kernel.org/r/1486620822-36826-1-git-send-email-xieyisheng1@huawei.com Signed-off-by: Yisheng Xie <xieyisheng1@huawei.com> Suggested-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Cc: Nitin Gupta <ngupta@vflare.org> Cc: Hanjun Guo <guohanjun@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-02-24mm/zsmalloc: remove redundant SetPagePrivate2 in create_page_chainYisheng Xie
We had used page->lru to link the component pages (except the first page) of a zspage, and used INIT_LIST_HEAD(&page->lru) to init it. Therefore, to get the last page's next page, which is NULL, we had to use page flag PG_Private_2 to identify it. But now, we use page->freelist to link all of the pages in zspage and init the page->freelist as NULL for last page, so no need to use PG_Private_2 anymore. This remove redundant SetPagePrivate2 in create_page_chain and ClearPagePrivate2 in reset_page(). Save a few cycles for migration of zsmalloc page :) Link: http://lkml.kernel.org/r/1487076509-49270-1-git-send-email-xieyisheng1@huawei.com Signed-off-by: Yisheng Xie <xieyisheng1@huawei.com> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-02-22mm: fix some typos in mm/zsmalloc.cXishi Qiu
Delete extra semicolon, and fix some typos. Link: http://lkml.kernel.org/r/586F1823.4050107@huawei.com Signed-off-by: Xishi Qiu <qiuxishi@huawei.com> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-12-02mm/zsmalloc: Convert to hotplug state machineSebastian Andrzej Siewior
Install the callbacks via the state machine and let the core invoke the callbacks on the already online CPUs. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com> Cc: linux-mm@kvack.org Cc: Minchan Kim <minchan@kernel.org> Cc: rt@linutronix.de Cc: Nitin Gupta <ngupta@vflare.org> Link: http://lkml.kernel.org/r/20161126231350.10321-11-bigeasy@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-07-28zsmalloc: Delete an unnecessary check before the function call "iput"Markus Elfring
iput() tests whether its argument is NULL and then returns immediately. Thus the test around the call is not needed. This issue was detected by using the Coccinelle software. Link: http://lkml.kernel.org/r/559cf499-4a01-25f9-c87f-24d906626a57@users.sourceforge.net Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-28mm/zsmalloc: use helper to clear page->flags bitGanesh Mahendran
Use ClearPagePrivate/ClearPagePrivate2 helpers to clear PG_private/PG_private_2 in page->flags Link: http://lkml.kernel.org/r/1467882338-4300-7-git-send-email-opensource.ganesh@gmail.com Signed-off-by: Ganesh Mahendran <opensource.ganesh@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-28mm/zsmalloc: add __init,__exit attributeGanesh Mahendran
Add __init,__exit attribute for function that only called in module init/exit to save memory. Link: http://lkml.kernel.org/r/1467882338-4300-6-git-send-email-opensource.ganesh@gmail.com Signed-off-by: Ganesh Mahendran <opensource.ganesh@gmail.com> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-28mm/zsmalloc: keep comments consistent with codeGanesh Mahendran
Some minor commebnt changes: 1). update zs_malloc(),zs_create_pool() function header 2). update "Usage of struct page fields" Link: http://lkml.kernel.org/r/1467882338-4300-5-git-send-email-opensource.ganesh@gmail.com Signed-off-by: Ganesh Mahendran <opensource.ganesh@gmail.com> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-28mm/zsmalloc: avoid calculate max objects of zspage twiceGanesh Mahendran
Currently, if a class can not be merged, the max objects of zspage in that class may be calculated twice. This patch calculate max objects of zspage at the begin, and pass the value to can_merge() to decide whether the class can be merged. Also this patch remove function get_maxobj_per_zspage(), as there is no other place to call this function. Link: http://lkml.kernel.org/r/1467882338-4300-4-git-send-email-opensource.ganesh@gmail.com Signed-off-by: Ganesh Mahendran <opensource.ganesh@gmail.com> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-28mm/zsmalloc: use class->objs_per_zspage to get num of max objectsGanesh Mahendran
num of max objects in zspage is stored in each size_class now. So there is no need to re-calculate it. Link: http://lkml.kernel.org/r/1467882338-4300-3-git-send-email-opensource.ganesh@gmail.com Signed-off-by: Ganesh Mahendran <opensource.ganesh@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-28mm/zsmalloc: take obj index back from find_alloced_objGanesh Mahendran
the obj index value should be updated after return from find_alloced_obj() to avoid CPU burning caused by unnecessary object scanning. Link: http://lkml.kernel.org/r/1467882338-4300-2-git-send-email-opensource.ganesh@gmail.com Signed-off-by: Ganesh Mahendran <opensource.ganesh@gmail.com> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-28mm/zsmalloc: use obj_index to keep consistent with othersGanesh Mahendran
This is a cleanup patch. Change "index" to "obj_index" to keep consistent with others in zsmalloc. Link: http://lkml.kernel.org/r/1467882338-4300-1-git-send-email-opensource.ganesh@gmail.com Signed-off-by: Ganesh Mahendran <opensource.ganesh@gmail.com> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26mm: fix build warnings in <linux/compaction.h>Minchan Kim
Randy reported below build error. > In file included from ../include/linux/balloon_compaction.h:48:0, > from ../mm/balloon_compaction.c:11: > ../include/linux/compaction.h:237:51: warning: 'struct node' declared inside parameter list [enabled by default] > static inline int compaction_register_node(struct node *node) > ../include/linux/compaction.h:237:51: warning: its scope is only this definition or declaration, which is probably not what you want [enabled by default] > ../include/linux/compaction.h:242:54: warning: 'struct node' declared inside parameter list [enabled by default] > static inline void compaction_unregister_node(struct node *node) > It was caused by non-lru page migration which needs compaction.h but compaction.h doesn't include any header to be standalone. I think proper header for non-lru page migration is migrate.h rather than compaction.h because migrate.h has already headers needed to work non-lru page migration indirectly like isolate_mode_t, migrate_mode MIGRATEPAGE_SUCCESS. [akpm@linux-foundation.org: revert mm-balloon-use-general-non-lru-movable-page-feature-fix.patch temp fix] Link: http://lkml.kernel.org/r/20160610003304.GE29779@bbox Signed-off-by: Minchan Kim <minchan@kernel.org> Reported-by: Randy Dunlap <rdunlap@infradead.org> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Gioh Kim <gi-oh.kim@profitbricks.com> Cc: Rafael Aquini <aquini@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26mm: add NR_ZSMALLOC to vmstatMinchan Kim
zram is very popular for some of the embedded world (e.g., TV, mobile phones). On those system, zsmalloc's consumed memory size is never trivial (one of example from real product system, total memory: 800M, zsmalloc consumed: 150M), so we have used this out of tree patch to monitor system memory behavior via /proc/vmstat. With zsmalloc in vmstat, it helps in tracking down system behavior due to memory usage. [minchan@kernel.org: zsmalloc: follow up zsmalloc vmstat] Link: http://lkml.kernel.org/r/20160607091737.GC23435@bbox [akpm@linux-foundation.org: fix build with CONFIG_ZSMALLOC=m] Link: http://lkml.kernel.org/r/1464919731-13255-1-git-send-email-minchan@kernel.org Signed-off-by: Minchan Kim <minchan@kernel.org> Cc: Sangseok Lee <sangseok.lee@lge.com> Cc: Chanho Min <chanho.min@lge.com> Cc: Chan Gyun Jeong <chan.jeong@lge.com> Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26zsmalloc: use OBJ_TAG_BIT for bit shifterMinchan Kim
Static check warns using tag as bit shifter. It doesn't break current working but not good for redability. Let's use OBJ_TAG_BIT as bit shifter instead of OBJ_ALLOCATED_TAG. Link: http://lkml.kernel.org/r/20160607045146.GF26230@bbox Signed-off-by: Minchan Kim <minchan@kernel.org> Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26zsmalloc: page migration supportMinchan Kim
This patch introduces run-time migration feature for zspage. For migration, VM uses page.lru field so it would be better to not use page.next field which is unified with page.lru for own purpose. For that, firstly, we can get first object offset of the page via runtime calculation instead of using page.index so we can use page.index as link for page chaining instead of page.next. In case of huge object, it stores handle to page.index instead of next link of page chaining because huge object doesn't need to next link for page chaining. So get_next_page need to identify huge object to return NULL. For it, this patch uses PG_owner_priv_1 flag of the page flag. For migration, it supports three functions * zs_page_isolate It isolates a zspage which includes a subpage VM want to migrate from class so anyone cannot allocate new object from the zspage. We could try to isolate a zspage by the number of subpage so subsequent isolation trial of other subpage of the zpsage shouldn't fail. For that, we introduce zspage.isolated count. With that, zs_page_isolate can know whether zspage is already isolated or not for migration so if it is isolated for migration, subsequent isolation trial can be successful without trying further isolation. * zs_page_migrate First of all, it holds write-side zspage->lock to prevent migrate other subpage in zspage. Then, lock all objects in the page VM want to migrate. The reason we should lock all objects in the page is due to race between zs_map_object and zs_page_migrate. zs_map_object zs_page_migrate pin_tag(handle) obj = handle_to_obj(handle) obj_to_location(obj, &page, &obj_idx); write_lock(&zspage->lock) if (!trypin_tag(handle)) goto unpin_object zspage = get_zspage(page); read_lock(&zspage->lock); If zs_page_migrate doesn't do trypin_tag, zs_map_object's page can be stale by migration so it goes crash. If it locks all of objects successfully, it copies content from old page to new one, finally, create new zspage chain with new page. And if it's last isolated subpage in the zspage, put the zspage back to class. * zs_page_putback It returns isolated zspage to right fullness_group list if it fails to migrate a page. If it find a zspage is ZS_EMPTY, it queues zspage freeing to workqueue. See below about async zspage freeing. This patch introduces asynchronous zspage free. The reason to need it is we need page_lock to clear PG_movable but unfortunately, zs_free path should be atomic so the apporach is try to grab page_lock. If it got page_lock of all of pages successfully, it can free zspage immediately. Otherwise, it queues free request and free zspage via workqueue in process context. If zs_free finds the zspage is isolated when it try to free zspage, it delays the freeing until zs_page_putback finds it so it will free free the zspage finally. In this patch, we expand fullness_list from ZS_EMPTY to ZS_FULL. First of all, it will use ZS_EMPTY list for delay freeing. And with adding ZS_FULL list, it makes to identify whether zspage is isolated or not via list_empty(&zspage->list) test. [minchan@kernel.org: zsmalloc: keep first object offset in struct page] Link: http://lkml.kernel.org/r/1465788015-23195-1-git-send-email-minchan@kernel.org [minchan@kernel.org: zsmalloc: zspage sanity check] Link: http://lkml.kernel.org/r/20160603010129.GC3304@bbox Link: http://lkml.kernel.org/r/1464736881-24886-12-git-send-email-minchan@kernel.org Signed-off-by: Minchan Kim <minchan@kernel.org> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26zsmalloc: use freeobj for indexMinchan Kim
Zsmalloc stores first free object's <PFN, obj_idx> position into freeobj in each zspage. If we change it with index from first_page instead of position, it makes page migration simple because we don't need to correct other entries for linked list if a page is migrated out. Link: http://lkml.kernel.org/r/1464736881-24886-11-git-send-email-minchan@kernel.org Signed-off-by: Minchan Kim <minchan@kernel.org> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26zsmalloc: separate free_zspage from putback_zspageMinchan Kim
Currently, putback_zspage does free zspage under class->lock if fullness become ZS_EMPTY but it makes trouble to implement locking scheme for new zspage migration. So, this patch is to separate free_zspage from putback_zspage and free zspage out of class->lock which is preparation for zspage migration. Link: http://lkml.kernel.org/r/1464736881-24886-10-git-send-email-minchan@kernel.org Signed-off-by: Minchan Kim <minchan@kernel.org> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26zsmalloc: introduce zspage structureMinchan Kim
We have squeezed meta data of zspage into first page's descriptor. So, to get meta data from subpage, we should get first page first of all. But it makes trouble to implment page migration feature of zsmalloc because any place where to get first page from subpage can be raced with first page migration. IOW, first page it got could be stale. For preventing it, I have tried several approahces but it made code complicated so finally, I concluded to separate metadata from first page. Of course, it consumes more memory. IOW, 16bytes per zspage on 32bit at the moment. It means we lost 1% at *worst case*(40B/4096B) which is not bad I think at the cost of maintenance. Link: http://lkml.kernel.org/r/1464736881-24886-9-git-send-email-minchan@kernel.org Signed-off-by: Minchan Kim <minchan@kernel.org> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26zsmalloc: factor page chain functionality outMinchan Kim
For page migration, we need to create page chain of zspage dynamically so this patch factors it out from alloc_zspage. Link: http://lkml.kernel.org/r/1464736881-24886-8-git-send-email-minchan@kernel.org Signed-off-by: Minchan Kim <minchan@kernel.org> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26zsmalloc: use accessorMinchan Kim
Upcoming patch will change how to encode zspage meta so for easy review, this patch wraps code to access metadata as accessor. Link: http://lkml.kernel.org/r/1464736881-24886-7-git-send-email-minchan@kernel.org Signed-off-by: Minchan Kim <minchan@kernel.org> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
