path: root/mm/util.c
2016-09-15proc: revert /proc/<pid>/maps [stack:TID] annotationJohannes Weiner
[ Upstream commit 65376df582174ffcec9e6471bf5b0dd79ba05e4a ] Commit b76437579d13 ("procfs: mark thread stack correctly in proc/<pid>/maps") added [stack:TID] annotation to /proc/<pid>/maps. Finding the task of a stack VMA requires walking the entire thread list, turning this into quadratic behavior: a thousand threads means a thousand stacks, so the rendering of /proc/<pid>/maps needs to look at a million combinations. The cost is not in proportion to the usefulness as described in the patch. Drop the [stack:TID] annotation to make /proc/<pid>/maps (and /proc/<pid>/numa_maps) usable again for higher thread counts. The [stack] annotation inside /proc/<pid>/task/<tid>/maps is retained, as identifying the stack VMA there is an O(1) operation. Siddesh said: "The end users needed a way to identify thread stacks programmatically and there wasn't a way to do that. I'm afraid I no longer remember (or have access to the resources that would aid my memory since I changed employers) the details of their requirement. However, I did do this on my own time because I thought it was an interesting project for me and nobody really gave any feedback then as to its utility, so as far as I am concerned you could roll back the main thread maps information since the information is available in the thread-specific files" Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Cc: Siddhesh Poyarekar <siddhesh.poyarekar@gmail.com> Cc: Shaohua Li <shli@fb.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-11-05mm/util: use offset_in_page macroAlexander Kuleshov
linux/mm.h provides offset_in_page() macro. Let's use already predefined macro instead of (addr & ~PAGE_MASK). Signed-off-by: Alexander Kuleshov <kuleshovmail@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-15mm: uninline and cleanup page-mapping related helpersKirill A. Shutemov
Most-used page->mapping helper -- page_mapping() -- has already uninlined. Let's uninline also page_rmapping() and page_anon_vma(). It saves us depending on configuration around 400 bytes in text: text data bss dec hex filename 660318 99254 410000 1169572 11d8a4 mm/built-in.o-before 659854 99254 410000 1169108 11d6d4 mm/built-in.o I also tried to make code a bit more clean. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Christoph Lameter <cl@linux.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13mm/util: add kstrdup_constAndrzej Hajda
kstrdup() is often used to duplicate strings where neither source neither destination will be ever modified. In such case we can just reuse the source instead of duplicating it. The problem is that we must be sure that the source is non-modifiable and its life-time is long enough. I suspect the good candidates for such strings are strings located in kernel .rodata section, they cannot be modifed because the section is read-only and their life-time is equal to kernel life-time. This small patchset proposes alternative version of kstrdup - kstrdup_const, which returns source string if it is located in .rodata otherwise it fallbacks to kstrdup. To verify if the source is in .rodata function checks if the address is between sentinels __start_rodata, __end_rodata. I guess it should work with all architectures. The main patch is accompanied by four patches constifying kstrdup for cases where situtation described above happens frequently. I have tested the patchset on mobile platform (exynos4210-trats) and it saves 3272 string allocations. Since minimal allocation is 32 or 64 bytes depending on Kconfig options the patchset saves respectively about 100KB or 200KB of memory. Stats from tested platform show that the main offender is sysfs: By caller: 2260 __kernfs_new_node 631 clk_register+0xc8/0x1b8 318 clk_register+0x34/0x1b8 51 kmem_cache_create 12 alloc_vfsmnt By string (with count >= 5): 883 power 876 subsystem 135 parameters 132 device 61 iommu_group ... This patch (of 5): Add an alternative version of kstrdup which returns pointer to constant char array. The function checks if input string is in persistent and read-only memory section, if yes it returns the input string, otherwise it fallbacks to kstrdup. kstrdup_const is accompanied by kfree_const performing conditional memory deallocation of the string. Signed-off-by: Andrzej Hajda <a.hajda@samsung.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Mike Turquette <mturquette@linaro.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Tejun Heo <tj@kernel.org> Cc: Greg KH <greg@kroah.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-11mm: gup: use get_user_pages_unlocked within get_user_pages_fastAndrea Arcangeli
This allows the get_user_pages_fast slow path to release the mmap_sem before blocking. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Reviewed-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Andres Lagar-Cavilla <andreslc@google.com> Cc: Peter Feiner <pfeiner@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-09proc/maps: make vm_is_stack() logic namespace-friendlyOleg Nesterov
- Rename vm_is_stack() to task_of_stack() and change it to return "struct task_struct *" rather than the global (and thus wrong in general) pid_t. - Add the new pid_of_stack() helper which calls task_of_stack() and uses the right namespace to report the correct pid_t. Unfortunately we need to define this helper twice, in task_mmu.c and in task_nommu.c. perhaps it makes sense to add fs/proc/util.c and move at least pid_of_stack/task_of_stack there to avoid the code duplication. - Change show_map_vma() and show_numa_map() to use the new helper. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Greg Ungerer <gerg@uclinux.org> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-08vm_is_stack: use for_each_thread() rather then buggy while_each_thread()Oleg Nesterov
Aleksei hit the soft lockup during reading /proc/PID/smaps. David investigated the problem and suggested the right fix. while_each_thread() is racy and should die, this patch updates vm_is_stack(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Reported-by: Aleksei Besogonov <alex.besogonov@gmail.com> Tested-by: Aleksei Besogonov <alex.besogonov@gmail.com> Suggested-by: David Rientjes <rientjes@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-06mm: move slab related stuff from util.c to slab_common.cAndrey Ryabinin
Functions krealloc(), __krealloc(), kzfree() belongs to slab API, so should be placed in slab_common.c Also move slab allocator's tracepoints defenitions to slab_common.c No functional changes here. Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Acked-by: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-05-06nick kvfree() from apparmorAl Viro
too many places open-code it Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-04-12Merge git://git.infradead.org/users/eparis/auditLinus Torvalds
Pull audit updates from Eric Paris. * git://git.infradead.org/users/eparis/audit: (28 commits) AUDIT: make audit_is_compat depend on CONFIG_AUDIT_COMPAT_GENERIC audit: renumber AUDIT_FEATURE_CHANGE into the 1300 range audit: do not cast audit_rule_data pointers pointlesly AUDIT: Allow login in non-init namespaces audit: define audit_is_compat in kernel internal header kernel: Use RCU_INIT_POINTER(x, NULL) in audit.c sched: declare pid_alive as inline audit: use uapi/linux/audit.h for AUDIT_ARCH declarations syscall_get_arch: remove useless function arguments audit: remove stray newline from audit_log_execve_info() audit_panic() call audit: remove stray newlines from audit_log_lost messages audit: include subject in login records audit: remove superfluous new- prefix in AUDIT_LOGIN messages audit: allow user processes to log from another PID namespace audit: anchor all pid references in the initial pid namespace audit: convert PPIDs to the inital PID namespace. pid: get pid_t ppid of task in init_pid_ns audit: rename the misleading audit_get_context() to audit_take_context() audit: Add generic compat syscall support audit: Add CONFIG_HAVE_ARCH_AUDITSYSCALL ...
2014-04-07mm: use macros from compiler.h instead of __attribute__((...))Gideon Israel Dsouza
To increase compiler portability there is <linux/compiler.h> which provides convenience macros for various gcc constructs. Eg: __weak for __attribute__((weak)). I've replaced all instances of gcc attributes with the right macro in the memory management (/mm) subsystem. [akpm@linux-foundation.org: while-we're-there consistency tweaks] Signed-off-by: Gideon Israel Dsouza <gidisrael@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-07mm: Create utility function for accessing a tasks commandline valueWilliam Roberts
introduce get_cmdline() for retreiving the value of a processes proc/self/cmdline value. Acked-by: David Rientjes <rientjes@google.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Acked-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: William Roberts <wroberts@tresys.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2014-01-21mm: add overcommit_kbytes sysctl variableJerome Marchand
Some applications that run on HPC clusters are designed around the availability of RAM and the overcommit ratio is fine tuned to get the maximum usage of memory without swapping. With growing memory, the 1%-of-all-RAM grain provided by overcommit_ratio has become too coarse for these workload (on a 2TB machine it represents no less than 20GB). This patch adds the new overcommit_kbytes sysctl variable that allow a much finer grain. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix nommu build] Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-15mm: fix crash when using XFS on loopbackMikulas Patocka
Commit 8456a648cf44 ("slab: use struct page for slab management") causes a crash in the LVM2 testsuite on PA-RISC (the crashing test is fsadm.sh). The testsuite doesn't crash on 3.12, crashes on 3.13-rc1 and later. Bad Address (null pointer deref?): Code=15 regs=000000413edd89a0 (Addr=000006202224647d) CPU: 3 PID: 24008 Comm: loop0 Not tainted 3.13.0-rc6 #5 task: 00000001bf3c0048 ti: 000000413edd8000 task.ti: 000000413edd8000 YZrvWESTHLNXBCVMcbcbcbcbOGFRQPDI PSW: 00001000000001101111100100001110 Not tainted r00-03 000000ff0806f90e 00000000405c8de0 000000004013e6c0 000000413edd83f0 r04-07 00000000405a95e0 0000000000000200 00000001414735f0 00000001bf349e40 r08-11 0000000010fe3d10 0000000000000001 00000040829c7778 000000413efd9000 r12-15 0000000000000000 000000004060d800 0000000010fe3000 0000000010fe3000 r16-19 000000413edd82a0 00000041078ddbc0 0000000000000010 0000000000000001 r20-23 0008f3d0d83a8000 0000000000000000 00000040829c7778 0000000000000080 r24-27 00000001bf349e40 00000001bf349e40 202d66202224640d 00000000405a95e0 r28-31 202d662022246465 000000413edd88f0 000000413edd89a0 0000000000000001 sr00-03 000000000532c000 0000000000000000 0000000000000000 000000000532c000 sr04-07 0000000000000000 0000000000000000 0000000000000000 0000000000000000 IASQ: 0000000000000000 0000000000000000 IAOQ: 00000000401fe42c 00000000401fe430 IIR: 539c0030 ISR: 00000000202d6000 IOR: 000006202224647d CPU: 3 CR30: 000000413edd8000 CR31: 0000000000000000 ORIG_R28: 00000000405a95e0 IAOQ[0]: vma_interval_tree_iter_first+0x14/0x48 IAOQ[1]: vma_interval_tree_iter_first+0x18/0x48 RP(r2): flush_dcache_page+0x128/0x388 Backtrace: flush_dcache_page+0x128/0x388 lo_splice_actor+0x90/0x148 [loop] splice_from_pipe_feed+0xc0/0x1d0 __splice_from_pipe+0xac/0xc0 lo_direct_splice_actor+0x1c/0x70 [loop] splice_direct_to_actor+0xec/0x228 lo_receive+0xe4/0x298 [loop] loop_thread+0x478/0x640 [loop] kthread+0x134/0x168 end_fault_vector+0x20/0x28 xfs_setsize_buftarg+0x0/0x90 [xfs] Kernel panic - not syncing: Bad Address (null pointer deref?) Commit 8456a648cf44 changes the page structure so that the slab subsystem reuses the page->mapping field. The crash happens in the following way: * XFS allocates some memory from slab and issues a bio to read data into it. * the bio is sent to the loopback device. * lo_receive creates an actor and calls splice_direct_to_actor. * lo_splice_actor copies data to the target page. * lo_splice_actor calls flush_dcache_page because the page may be mapped by userspace. In that case we need to flush the kernel cache. * flush_dcache_page asks for the list of userspace mappings, however that page->mapping field is reused by the slab subsystem for a different purpose. This causes the crash. Note that other architectures without coherent caches (sparc, arm, mips) also call page_mapping from flush_dcache_page, so they may crash in the same way. This patch fixes this bug by testing if the page is a slab page in page_mapping and returning NULL if it is. The patch also fixes VM_BUG_ON(PageSlab(page)) that could happen in earlier kernels in the same scenario on architectures without cache coherence when CONFIG_DEBUG_VM is enabled - so it should be backported to stable kernels. In the old kernels, the function page_mapping is placed in include/linux/mm.h, so you should modify the patch accordingly when backporting it. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Cc: John David Anglin <dave.anglin@bell.net>] Cc: Andi Kleen <ak@linux.intel.com> Cc: Christoph Lameter <cl@linux.com> Acked-by: Pekka Enberg <penberg@kernel.org> Reviewed-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Helge Deller <deller@gmx.de> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-13mm: factor commit limit calculationJerome Marchand
The same calculation is currently done in three differents places. Factor that code so future changes has to be made at only one place. [akpm@linux-foundation.org: uninline vm_commit_limit()] Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11swap: clean-up #ifdef in page_mapping()Joonsoo Kim
PageSwapCache() is always false when !CONFIG_SWAP, so compiler properly discard related code. Therefore, we don't need #ifdef explicitly. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Minchan Kim <minchan@kernel.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-10mm: remove free_area_cacheMichel Lespinasse
Since all architectures have been converted to use vm_unmapped_area(), there is no remaining use for the free_area_cache. Signed-off-by: Michel Lespinasse <walken@google.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: Helge Deller <deller@gmx.de> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-23swap: make each swap partition have one address_spaceShaohua Li
When I use several fast SSD to do swap, swapper_space.tree_lock is heavily contended. This makes each swap partition have one address_space to reduce the lock contention. There is an array of address_space for swap. The swap entry type is the index to the array. In my test with 3 SSD, this increases the swapout throughput 20%. [akpm@linux-foundation.org: revert unneeded change to __add_to_swap_cache] Signed-off-by: Shaohua Li <shli@fusionio.com> Cc: Hugh Dickins <hughd@google.com> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-23mm: don't inline page_mapping()Shaohua Li
According to akpm, this saves 1/2k text and makes things simple for the next patch. Numbers from Minchan: add/remove: 1/0 grow/shrink: 6/22 up/down: 92/-516 (-424) function old new delta page_mapping - 48 +48 do_task_stat 2292 2308 +16 page_remove_rmap 240 248 +8 load_elf_binary 4500 4508 +8 update_queue 532 536 +4 scsi_probe_and_add_lun 2892 2896 +4 lookup_fast 644 648 +4 vcs_read 1040 1036 -4 __ip_route_output_key 1904 1900 -4 ip_route_input_noref 2508 2500 -8 shmem_file_aio_read 784 772 -12 __isolate_lru_page 272 256 -16 shmem_replace_page 708 688 -20 mark_buffer_dirty 228 208 -20 __set_page_dirty_buffers 240 220 -20 __remove_mapping 276 256 -20 update_mmu_cache 500 476 -24 set_page_dirty_balance 92 68 -24 set_page_dirty 172 148 -24 page_evictable 88 64 -24 page_cache_pipe_buf_steal 248 224 -24 clear_page_dirty_for_io 340 316 -24 test_set_page_writeback 400 372 -28 test_clear_page_writeback 516 488 -28 invalidate_inode_page 156 128 -28 page_mkclean 432 400 -32 flush_dcache_page 360 328 -32 __set_page_dirty_nobuffers 324 280 -44 shrink_page_list 2412 2356 -56 Signed-off-by: Shaohua Li <shli@fusionio.com> Suggested-by: Andrew Morton <akpm@linux-foundation.org> Cc: Hugh Dickins <hughd@google.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-23mm: make do_mmap_pgoff return populate as a size in bytes, not as a boolMichel Lespinasse
do_mmap_pgoff() rounds up the desired size to the next PAGE_SIZE multiple, however there was no equivalent code in mm_populate(), which caused issues. This could be fixed by introduced the same rounding in mm_populate(), however I think it's preferable to make do_mmap_pgoff() return populate as a size rather than as a boolean, so we don't have to duplicate the size rounding logic in mm_populate(). Signed-off-by: Michel Lespinasse <walken@google.com> Acked-by: Rik van Riel <riel@redhat.com> Tested-by: Andy Lutomirski <luto@amacapital.net> Cc: Greg Ungerer <gregungerer@westnet.com.au> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-23mm: introduce mm_populate() for populating new vmasMichel Lespinasse
When creating new mappings using the MAP_POPULATE / MAP_LOCKED flags (or with MCL_FUTURE in effect), we want to populate the pages within the newly created vmas. This may take a while as we may have to read pages from disk, so ideally we want to do this outside of the write-locked mmap_sem region. This change introduces mm_populate(), which is used to defer populating such mappings until after the mmap_sem write lock has been released. This is implemented as a generalization of the former do_mlock_pages(), which accomplished the same task but was using during mlock() / mlockall(). Signed-off-by: Michel Lespinasse <walken@google.com> Reported-by: Andy Lutomirski <luto@amacapital.net> Acked-by: Rik van Riel <riel@redhat.com> Tested-by: Andy Lutomirski <luto@amacapital.net> Cc: Greg Ungerer <gregungerer@westnet.com.au> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-28Merge branch 'master' into for-nextJiri Kosina
Sync up with Linus' tree to be able to apply Cesar's patch against newer version of the code. Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-10-15krealloc: Fix kernel-doc commentBorislav Petkov
It should say "@new_size" and not "@size". Correct that. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Cc: trivial@kernel.org Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-09-04mm: Use __do_krealloc to do the krealloc jobEzequiel Garcia
Without this patch we can get (many) kmem trace events with call site at krealloc(). This happens because krealloc is calling __krealloc, which performs the allocation through kmalloc_track_caller. Since neither krealloc nor __krealloc are marked inline explicitly, the caller can be traced as being krealloc, which clearly is not the intended behavior. This patch allows to get the real caller of krealloc, by creating an always inlined function __do_krealloc, thus tracing the call site accurately. Acked-by: Christoph Lameter <cl@linux.com> Cc: Glauber Costa <glommer@parallels.com> Signed-off-by: Ezequiel Garcia <elezegarcia@gmail.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2012-06-01new helper: vm_mmap_pgoff()Al Viro
take it to mm/util.c, convert vm_mmap() to use of that one and take it to mm/util.c as well, convert both sys_mmap_pgoff() to use of vm_mmap_pgoff() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-21procfs: mark thread stack correctly in proc/<pid>/mapsSiddhesh Poyarekar
Stack for a new thread is mapped by userspace code and passed via sys_clone. This memory is currently seen as anonymous in /proc/<pid>/maps, which makes it difficult to ascertain which mappings are being used for thread stacks. This patch uses the individual task stack pointers to determine which vmas are actually thread stacks. For a multithreaded program like the following: #include <pthread.h> void *thread_main(void *foo) { while(1); } int main() { pthread_t t; pthread_create(&t, NULL, thread_main, NULL); pthread_join(t, NULL); } proc/PID/maps looks like the following: 00400000-00401000 r-xp 00000000 fd:0a 3671804 /home/siddhesh/a.out 00600000-00601000 rw-p 00000000 fd:0a 3671804 /home/siddhesh/a.out 019ef000-01a10000 rw-p 00000000 00:00 0 [heap] 7f8a44491000-7f8a44492000 ---p 00000000 00:00 0 7f8a44492000-7f8a44c92000 rw-p 00000000 00:00 0 7f8a44c92000-7f8a44e3d000 r-xp 00000000 fd:00 2097482 /lib64/libc-2.14.90.so 7f8a44e3d000-7f8a4503d000 ---p 001ab000 fd:00 2097482 /lib64/libc-2.14.90.so 7f8a4503d000-7f8a45041000 r--p 001ab000 fd:00 2097482 /lib64/libc-2.14.90.so 7f8a45041000-7f8a45043000 rw-p 001af000 fd:00 2097482 /lib64/libc-2.14.90.so 7f8a45043000-7f8a45048000 rw-p 00000000 00:00 0 7f8a45048000-7f8a4505f000 r-xp 00000000 fd:00 2099938 /lib64/libpthread-2.14.90.so 7f8a4505f000-7f8a4525e000 ---p 00017000 fd:00 2099938 /lib64/libpthread-2.14.90.so 7f8a4525e000-7f8a4525f000 r--p 00016000 fd:00 2099938 /lib64/libpthread-2.14.90.so 7f8a4525f000-7f8a45260000 rw-p 00017000 fd:00 2099938 /lib64/libpthread-2.14.90.so 7f8a45260000-7f8a45264000 rw-p 00000000 00:00 0 7f8a45264000-7f8a45286000 r-xp 00000000 fd:00 2097348 /lib64/ld-2.14.90.so 7f8a45457000-7f8a4545a000 rw-p 00000000 00:00 0 7f8a45484000-7f8a45485000 rw-p 00000000 00:00 0 7f8a45485000-7f8a45486000 r--p 00021000 fd:00 2097348 /lib64/ld-2.14.90.so 7f8a45486000-7f8a45487000 rw-p 00022000 fd:00 2097348 /lib64/ld-2.14.90.so 7f8a45487000-7f8a45488000 rw-p 00000000 00:00 0 7fff6273b000-7fff6275c000 rw-p 00000000 00:00 0 [stack] 7fff627ff000-7fff62800000 r-xp 00000000 00:00 0 [vdso] ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsyscall] Here, one could guess that 7f8a44492000-7f8a44c92000 is a stack since the earlier vma that has no permissions (7f8a44e3d000-7f8a4503d000) but that is not always a reliable way to find out which vma is a thread stack. Also, /proc/PID/maps and /proc/PID/task/TID/maps has the same content. With this patch in place, /proc/PID/task/TID/maps are treated as 'maps as the task would see it' and hence, only the vma that that task uses as stack is marked as [stack]. All other 'stack' vmas are marked as anonymous memory. /proc/PID/maps acts as a thread group level view, where all thread stack vmas are marked as [stack:TID] where TID is the process ID of the task that uses that vma as stack, while the process stack is marked as [stack]. So /proc/PID/maps will look like this: 00400000-00401000 r-xp 00000000 fd:0a 3671804 /home/siddhesh/a.out 00600000-00601000 rw-p 00000000 fd:0a 3671804 /home/siddhesh/a.out 019ef000-01a10000 rw-p 00000000 00:00 0 [heap] 7f8a44491000-7f8a44492000 ---p 00000000 00:00 0 7f8a44492000-7f8a44c92000 rw-p 00000000 00:00 0 [stack:1442] 7f8a44c92000-7f8a44e3d000 r-xp 00000000 fd:00 2097482 /lib64/libc-2.14.90.so 7f8a44e3d000-7f8a4503d000 ---p 001ab000 fd:00 2097482 /lib64/libc-2.14.90.so 7f8a4503d000-7f8a45041000 r--p 001ab000 fd:00 2097482 /lib64/libc-2.14.90.so 7f8a45041000-7f8a45043000 rw-p 001af000 fd:00 2097482 /lib64/libc-2.14.90.so 7f8a45043000-7f8a45048000 rw-p 00000000 00:00 0 7f8a45048000-7f8a4505f000 r-xp 00000000 fd:00 2099938 /lib64/libpthread-2.14.90.so 7f8a4505f000-7f8a4525e000 ---p 00017000 fd:00 2099938 /lib64/libpthread-2.14.90.so 7f8a4525e000-7f8a4525f000 r--p 00016000 fd:00 2099938 /lib64/libpthread-2.14.90.so 7f8a4525f000-7f8a45260000 rw-p 00017000 fd:00 2099938 /lib64/libpthread-2.14.90.so 7f8a45260000-7f8a45264000 rw-p 00000000 00:00 0 7f8a45264000-7f8a45286000 r-xp 00000000 fd:00 2097348 /lib64/ld-2.14.90.so 7f8a45457000-7f8a4545a000 rw-p 00000000 00:00 0 7f8a45484000-7f8a45485000 rw-p 00000000 00:00 0 7f8a45485000-7f8a45486000 r--p 00021000 fd:00 2097348 /lib64/ld-2.14.90.so 7f8a45486000-7f8a45487000 rw-p 00022000 fd:00 2097348 /lib64/ld-2.14.90.so 7f8a45487000-7f8a45488000 rw-p 00000000 00:00 0 7fff6273b000-7fff6275c000 rw-p 00000000 00:00 0 [stack] 7fff627ff000-7fff62800000 r-xp 00000000 00:00 0 [vdso] ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsyscall] Thus marking all vmas that are used as stacks by the threads in the thread group along with the process stack. The task level maps will however like this: 00400000-00401000 r-xp 00000000 fd:0a 3671804 /home/siddhesh/a.out 00600000-00601000 rw-p 00000000 fd:0a 3671804 /home/siddhesh/a.out 019ef000-01a10000 rw-p 00000000 00:00 0 [heap] 7f8a44491000-7f8a44492000 ---p 00000000 00:00 0 7f8a44492000-7f8a44c92000 rw-p 00000000 00:00 0 [stack] 7f8a44c92000-7f8a44e3d000 r-xp 00000000 fd:00 2097482 /lib64/libc-2.14.90.so 7f8a44e3d000-7f8a4503d000 ---p 001ab000 fd:00 2097482 /lib64/libc-2.14.90.so 7f8a4503d000-7f8a45041000 r--p 001ab000 fd:00 2097482 /lib64/libc-2.14.90.so 7f8a45041000-7f8a45043000 rw-p 001af000 fd:00 2097482 /lib64/libc-2.14.90.so 7f8a45043000-7f8a45048000 rw-p 00000000 00:00 0 7f8a45048000-7f8a4505f000 r-xp 00000000 fd:00 2099938 /lib64/libpthread-2.14.90.so 7f8a4505f000-7f8a4525e000 ---p 00017000 fd:00 2099938 /lib64/libpthread-2.14.90.so 7f8a4525e000-7f8a4525f000 r--p 00016000 fd:00 2099938 /lib64/libpthread-2.14.90.so 7f8a4525f000-7f8a45260000 rw-p 00017000 fd:00 2099938 /lib64/libpthread-2.14.90.so 7f8a45260000-7f8a45264000 rw-p 00000000 00:00 0 7f8a45264000-7f8a45286000 r-xp 00000000 fd:00 2097348 /lib64/ld-2.14.90.so 7f8a45457000-7f8a4545a000 rw-p 00000000 00:00 0 7f8a45484000-7f8a45485000 rw-p 00000000 00:00 0 7f8a45485000-7f8a45486000 r--p 00021000 fd:00 2097348 /lib64/ld-2.14.90.so 7f8a45486000-7f8a45487000 rw-p 00022000 fd:00 2097348 /lib64/ld-2.14.90.so 7f8a45487000-7f8a45488000 rw-p 00000000 00:00 0 7fff6273b000-7fff6275c000 rw-p 00000000 00:00 0 7fff627ff000-7fff62800000 r-xp 00000000 00:00 0 [vdso] ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsyscall] where only the vma that is being used as a stack by *that* task is marked as [stack]. Analogous changes have been made to /proc/PID/smaps, /proc/PID/numa_maps, /proc/PID/task/TID/smaps and /proc/PID/task/TID/numa_maps. Relevant snippets from smaps and numa_maps: [siddhesh@localhost ~ ]$ pgrep a.out 1441 [siddhesh@localhost ~ ]$ cat /proc/1441/smaps | grep "\[stack" 7f8a44492000-7f8a44c92000 rw-p 00000000 00:00 0 [stack:1442] 7fff6273b000-7fff6275c000 rw-p 00000000 00:00 0 [stack] [siddhesh@localhost ~ ]$ cat /proc/1441/task/1442/smaps | grep "\[stack" 7f8a44492000-7f8a44c92000 rw-p 00000000 00:00 0 [stack] [siddhesh@localhost ~ ]$ cat /proc/1441/task/1441/smaps | grep "\[stack" 7fff6273b000-7fff6275c000 rw-p 00000000 00:00 0 [stack] [siddhesh@localhost ~ ]$ cat /proc/1441/numa_maps | grep "stack" 7f8a44492000 default stack:1442 anon=2 dirty=2 N0=2 7fff6273a000 default stack anon=3 dirty=3 N0=3 [siddhesh@localhost ~ ]$ cat /proc/1441/task/1442/numa_maps | grep "stack" 7f8a44492000 default stack anon=2 dirty=2 N0=2 [siddhesh@localhost ~ ]$ cat /proc/1441/task/1441/numa_maps | grep "stack" 7fff6273a000 default stack anon=3 dirty=3 N0=3 [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix build] Signed-off-by: Siddhesh Poyarekar <siddhesh.poyarekar@gmail.com> Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Jamie Lokier <jamie@shareable.org> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Matt Mackall <mpm@selenic.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31mm: Map most files to use export.h instead of module.hPaul Gortmaker
The files changed within are only using the EXPORT_SYMBOL macro variants. They are not using core modular infrastructure and hence don't need module.h but only the export.h header. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-05-25mm: nommu: sort mm->mmap list properlyNamhyung Kim
When I was reading nommu code, I found that it handles the vma list/tree in an unusual way. IIUC, because there can be more than one identical/overrapped vmas in the list/tree, it sorts the tree more strictly and does a linear search on the tree. But it doesn't applied to the list (i.e. the list could be constructed in a different order than the tree so that we can't use the list when finding the first vma in that order). Since inserting/sorting a vma in the tree and link is done at the same time, we can easily construct both of them in the same order. And linear searching on the tree could be more costly than doing it on the list, it can be converted to use the list. Also, after the commit 297c5eee3724 ("mm: make the vma list be doubly linked") made the list be doubly linked, there were a couple of code need to be fixed to construct the list properly. Patch 1/6 is a preparation. It maintains the list sorted same as the tree and construct doubly-linked list properly. Patch 2/6 is a simple optimization for the vma deletion. Patch 3/6 and 4/6 convert tree traversal to list traversal and the rest are simple fixes and cleanups. This patch: @vma added into @mm should be sorted by start addr, end addr and VMA struct addr in that order because we may get identical VMAs in the @mm. However this was true only for the rbtree, not for the list. This patch fixes this by remembering 'rb_prev' during the tree traversal like find_vma_prepare() does and linking the @vma via __vma_link_list(). After this patch, we can iterate the whole VMAs in correct order simply by using @mm->mmap list. [akpm@linux-foundation.org: avoid duplicating __vma_link_list()] Signed-off-by: Namhyung Kim <namhyung@gmail.com> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: David Howells <dhowells@redhat.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-07kernel: kmem_ptr_validate considered harmfulNick Piggin
This is a nasty and error prone API. It is no longer used, remove it. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-10-24export __get_user_pages_fast() functionXiao Guangrong
This function is used by KVM to pin process's page in the atomic context. Define the 'weak' function to avoid other architecture not support it Acked-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-08-09mm: use memdup_userJulia Lawall
Use memdup_user when user data is immediately copied into the allocated region. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression from,to,size,flag; position p; identifier l1,l2; @@ - to = \(kmalloc@p\|kzalloc@p\)(size,flag); + to = memdup_user(from,size); if ( - to==NULL + IS_ERR(to) || ...) { <+... when != goto l1; - -ENOMEM + PTR_ERR(to) ...+> } - if (copy_from_user(to, from, size) != 0) { - <+... when != goto l2; - -EFAULT - ...+> - } // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-09slab: Generify kernel pointer validationPekka Enberg
As suggested by Linus, introduce a kern_ptr_validate() helper that does some sanity checks to make sure a pointer is a valid kernel pointer. This is a preparational step for fixing SLUB kmem_ptr_validate(). Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: David Rientjes <rientjes@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Matt Mackall <mpm@selenic.com> Cc: Nick Piggin <npiggin@suse.de> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-16nommu: don't need get_unmapped_area() for NOMMUDavid Howells
get_unmapped_area() is unnecessary for NOMMU as no-one calls it. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Greg Ungerer <gerg@snapgear.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-30mm: move sys_mmap_pgoff from util.cHugh Dickins
Move sys_mmap_pgoff() from mm/util.c to mm/mmap.c and mm/nommu.c, where we'd expect to find such code: especially now that it contains the MAP_HUGETLB handling. Revert mm/util.c to how it was in 2.6.32. This patch just ignores MAP_HUGETLB in the nommu case, as in 2.6.32, whereas 2.6.33-rc2 reported -ENOSYS. Perhaps validate_mmap_request() should reject it with -EINVAL? Add that later if necessary. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-11fix a struct file leak in do_mmap_pgoff()Al Viro
2009-12-11Unify sys_mmap*Al Viro
New helper - sys_mmap_pgoff(); switch syscalls to using it. Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-17Merge branches 'slab/documentation', 'slab/fixes', 'slob/cleanups' and ↵Pekka Enberg
'slub/fixes' into for-linus
2009-06-16mm: clean up get_user_pages_fast() documentationNick Piggin
Move more documentation for get_user_pages_fast into the new kerneldoc comment. Add some comments for get_user_pages as well. Also, move get_user_pages_fast declaration up to get_user_pages. It wasn't there initially because it was once a static inline function. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Andy Grover <andy.grover@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-01slab: document kzfree() zeroing behaviorPekka Enberg
As suggested by Alan Cox, document the fact that kzfree() can zero out a great deal more memory than the what the user requested from kmalloc(). Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-05-07Merge branch 'linus' into tracing/coreIngo Molnar
Merge reason: tracing/core was on a .30-rc1 base and was missing out on on a handful of tracing fixes present in .30-rc5-almost. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-14tracing/events: move trace point headers into include/trace/eventsSteven Rostedt
Impact: clean up Create a sub directory in include/trace called events to keep the trace point headers in their own separate directory. Only headers that declare trace points should be defined in this directory. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Zhao Lei <zhaolei@cn.fujitsu.com> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-04-14tracing: create automated trace definesSteven Rostedt
This patch lowers the number of places a developer must modify to add new tracepoints. The current method to add a new tracepoint into an existing system is to write the trace point macro in the trace header with one of the macros TRACE_EVENT, TRACE_FORMAT or DECLARE_TRACE, then they must add the same named item into the C file with the macro DEFINE_TRACE(name) and then add the trace point. This change cuts out the needing to add the DEFINE_TRACE(name). Every file that uses the tracepoint must still include the trace/<type>.h file, but the one C file must also add a define before the including of that file. #define CREATE_TRACE_POINTS #include <trace/mytrace.h> This will cause the trace/mytrace.h file to also produce the C code necessary to implement the trace point. Note, if more than one trace/<type>.h is used to create the C code it is best to list them all together. #define CREATE_TRACE_POINTS #include <trace/foo.h> #include <trace/bar.h> #include <trace/fido.h> Thanks to Mathieu Desnoyers and Christoph Hellwig for coming up with the cleaner solution of the define above the includes over my first design to have the C code include a "special" header. This patch converts sched, irq and lockdep and skb to use this new method. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Zhao Lei <zhaolei@cn.fujitsu.com> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-04-13mm: document get_user_pages_fast()Andy Grover
While better than get_user_pages(), the usage of gupf(), especially the return values and the fact that it can potentially only partially pin the range, warranted some documentation. Signed-off-by: Andy Grover <andy.grover@oracle.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-03kmemtrace: use tracepointsEduard - Gabriel Munteanu
kmemtrace now uses tracepoints instead of markers. We no longer need to use format specifiers to pass arguments. Signed-off-by: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> [ folded: Use the new TP_PROTO and TP_ARGS to fix the build. ] [ folded: fix build when CONFIG_KMEMTRACE is disabled. ] [ folded: define tracepoints when CONFIG_TRACEPOINTS is enabled. ] Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> LKML-Reference: <ae61c0f37156db8ec8dc0d5778018edde60a92e3.1237813499.git.eduard.munteanu@linux360.ro> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-01memdup_user(): introduceLi Zefan
I notice there are many places doing copy_from_user() which follows kmalloc(): dst = kmalloc(len, GFP_KERNEL); if (!dst) return -ENOMEM; if (copy_from_user(dst, src, len)) { kfree(dst); return -EFAULT } memdup_user() is a wrapper of the above code. With this new function, we don't have to write 'len' twice, which can lead to typos/mistakes. It also produces smaller code and kernel text. A quick grep shows 250+ places where memdup_user() *may* be used. I'll prepare a patchset to do this conversion. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Americo Wang <xiyou.wangcong@gmail.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-20slab: introduce kzfree()Johannes Weiner
kzfree() is a wrapper for kfree() that additionally zeroes the underlying memory before releasing it to the slab allocator. Currently there is code which memset()s the memory region of an object before releasing it back to the slab allocator to make sure security-sensitive data are really zeroed out after use. These callsites can then just use kzfree() which saves some code, makes users greppable and allows for a stupid destructor that isn't necessarily aware of the actual object size. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Matt Mackall <mpm@selenic.com> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12mm: Make generic weak get_user_pages_fast and EXPORT_GPL itRusty Russell
Out of line get_user_pages_fast fallback implementation, make it a weak symbol, get rid of CONFIG_HAVE_GET_USER_PAGES_FAST. Export the symbol to modules so lguest can use it. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-07-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: netns: fix ip_rt_frag_needed rt_is_expired netfilter: nf_conntrack_extend: avoid unnecessary "ct->ext" dereferences netfilter: fix double-free and use-after free netfilter: arptables in netns for real netfilter: ip{,6}tables_security: fix future section mismatch selinux: use nf_register_hooks() netfilter: ebtables: use nf_register_hooks() Revert "pkt_sched: sch_sfq: dump a real number of flows" qeth: use dev->ml_priv instead of dev->priv syncookies: Make sure ECN is disabled net: drop unused BUG_TRAP() net: convert BUG_TRAP to generic WARN_ON drivers/net: convert BUG_TRAP to generic WARN_ON
2008-07-26mm/util.c must #include <linux/sched.h>Adrian Bunk
mm/util.c: In function 'arch_pick_mmap_layout': mm/util.c:144: error: dereferencing pointer to incomplete type mm/util.c:145: error: 'arch_get_unmapped_area' undeclared (first use in this function) mm/util.c:145: error: (Each undeclared identifier is reported only once mm/util.c:145: error: for each function it appears in.) mm/util.c:146: error: 'arch_unmap_area' undeclared (first use in this function) Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
