path: root/mm/slub.c
2017-02-22slub: make sysfs directories for memcg sub-caches optionalTejun Heo
SLUB creates a per-cache directory under /sys/kernel/slab which hosts a bunch of debug files. Usually, there aren't that many caches on a system and this doesn't really matter; however, if memcg is in use, each cache can have per-cgroup sub-caches. SLUB creates the same directories for these sub-caches under /sys/kernel/slab/$CACHE/cgroup. Unfortunately, because there can be a lot of cgroups, active or draining, the product of the numbers of caches, cgroups and files in each directory can reach a very high number - hundreds of thousands is commonplace. Millions and beyond aren't difficult to reach either. What's under /sys/kernel/slab is primarily for debugging and the information and control on the a root cache already cover its sub-caches. While having a separate directory for each sub-cache can be helpful for development, it doesn't make much sense to pay this amount of overhead by default. This patch introduces a boot parameter slub_memcg_sysfs which determines whether to create sysfs directories for per-memcg sub-caches. It also adds CONFIG_SLUB_MEMCG_SYSFS_ON which determines the boot parameter's default value and defaults to 0. [akpm@linux-foundation.org: kset_unregister(NULL) is legal] Link: http://lkml.kernel.org/r/20170204145203.GB26958@mtj.duckdns.org Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Vladimir Davydov <vdavydov.dev@gmail.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-02-22slab: remove slub sysfs interface files early for empty memcg cachesTejun Heo
With kmem cgroup support enabled, kmem_caches can be created and destroyed frequently and a great number of near empty kmem_caches can accumulate if there are a lot of transient cgroups and the system is not under memory pressure. When memory reclaim starts under such conditions, it can lead to consecutive deactivation and destruction of many kmem_caches, easily hundreds of thousands on moderately large systems, exposing scalability issues in the current slab management code. This is one of the patches to address the issue. Each cache has a number of sysfs interface files under /sys/kernel/slab. On a system with a lot of memory and transient memcgs, the number of interface files which have to be removed once memory reclaim kicks in can reach millions. Link: http://lkml.kernel.org/r/20170117235411.9408-10-tj@kernel.org Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Jay Vana <jsvana@fb.com> Acked-by: Vladimir Davydov <vdavydov.dev@gmail.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-02-22slab: remove synchronous synchronize_sched() from memcg cache deactivation pathTejun Heo
With kmem cgroup support enabled, kmem_caches can be created and destroyed frequently and a great number of near empty kmem_caches can accumulate if there are a lot of transient cgroups and the system is not under memory pressure. When memory reclaim starts under such conditions, it can lead to consecutive deactivation and destruction of many kmem_caches, easily hundreds of thousands on moderately large systems, exposing scalability issues in the current slab management code. This is one of the patches to address the issue. slub uses synchronize_sched() to deactivate a memcg cache. synchronize_sched() is an expensive and slow operation and doesn't scale when a huge number of caches are destroyed back-to-back. While there used to be a simple batching mechanism, the batching was too restricted to be helpful. This patch implements slab_deactivate_memcg_cache_rcu_sched() which slub can use to schedule sched RCU callback instead of performing synchronize_sched() synchronously while holding cgroup_mutex. While this adds online cpus, mems and slab_mutex operations, operating on these locks back-to-back from the same kworker, which is what's gonna happen when there are many to deactivate, isn't expensive at all and this gets rid of the scalability problem completely. Link: http://lkml.kernel.org/r/20170117235411.9408-9-tj@kernel.org Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Jay Vana <jsvana@fb.com> Acked-by: Vladimir Davydov <vdavydov.dev@gmail.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-02-22slab: introduce __kmemcg_cache_deactivate()Tejun Heo
__kmem_cache_shrink() is called with %true @deactivate only for memcg caches. Remove @deactivate from __kmem_cache_shrink() and introduce __kmemcg_cache_deactivate() instead. Each memcg-supporting allocator should implement it and it should deactivate and drain the cache. This is to allow memcg cache deactivation behavior to further deviate from simple shrinking without messing up __kmem_cache_shrink(). This is pure reorganization and doesn't introduce any observable behavior changes. v2: Dropped unnecessary ifdef in mm/slab.h as suggested by Vladimir. Link: http://lkml.kernel.org/r/20170117235411.9408-8-tj@kernel.org Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Vladimir Davydov <vdavydov.dev@gmail.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-02-22slab: implement slab_root_caches listTejun Heo
With kmem cgroup support enabled, kmem_caches can be created and destroyed frequently and a great number of near empty kmem_caches can accumulate if there are a lot of transient cgroups and the system is not under memory pressure. When memory reclaim starts under such conditions, it can lead to consecutive deactivation and destruction of many kmem_caches, easily hundreds of thousands on moderately large systems, exposing scalability issues in the current slab management code. This is one of the patches to address the issue. slab_caches currently lists all caches including root and memcg ones. This is the only data structure which lists the root caches and iterating root caches can only be done by walking the list while skipping over memcg caches. As there can be a huge number of memcg caches, this can become very expensive. This also can make /proc/slabinfo behave very badly. seq_file processes reads in 4k chunks and seeks to the previous Nth position on slab_caches list to resume after each chunk. With a lot of memcg cache churns on the list, reading /proc/slabinfo can become very slow and its content often ends up with duplicate and/or missing entries. This patch adds a new list slab_root_caches which lists only the root caches. When memcg is not enabled, it becomes just an alias of slab_caches. memcg specific list operations are collected into memcg_[un]link_cache(). Link: http://lkml.kernel.org/r/20170117235411.9408-7-tj@kernel.org Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Jay Vana <jsvana@fb.com> Acked-by: Vladimir Davydov <vdavydov@tarantool.org> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-02-22slub: separate out sysfs_slab_release() from sysfs_slab_remove()Tejun Heo
Separate out slub sysfs removal and release, and call the former earlier from __kmem_cache_shutdown(). There's no reason to defer sysfs removal through RCU and this will later allow us to remove sysfs files way earlier during memory cgroup offline instead of release. Link: http://lkml.kernel.org/r/20170117235411.9408-3-tj@kernel.org Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Vladimir Davydov <vdavydov.dev@gmail.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-02-22Revert "slub: move synchronize_sched out of slab_mutex on shrink"Tejun Heo
Patch series "slab: make memcg slab destruction scalable", v3. With kmem cgroup support enabled, kmem_caches can be created and destroyed frequently and a great number of near empty kmem_caches can accumulate if there are a lot of transient cgroups and the system is not under memory pressure. When memory reclaim starts under such conditions, it can lead to consecutive deactivation and destruction of many kmem_caches, easily hundreds of thousands on moderately large systems, exposing scalability issues in the current slab management code. I've seen machines which end up with hundred thousands of caches and many millions of kernfs_nodes. The current code is O(N^2) on the total number of caches and has synchronous rcu_barrier() and synchronize_sched() in cgroup offline / release path which is executed while holding cgroup_mutex. Combined, this leads to very expensive and slow cache destruction operations which can easily keep running for half a day. This also messes up /proc/slabinfo along with other cache iterating operations. seq_file operates on 4k chunks and on each 4k boundary tries to seek to the last position in the list. With a huge number of caches on the list, this becomes very slow and very prone to the list content changing underneath it leading to a lot of missing and/or duplicate entries. This patchset addresses the scalability problem. * Add root and per-memcg lists. Update each user to use the appropriate list. * Make rcu_barrier() for SLAB_DESTROY_BY_RCU caches globally batched and asynchronous. * For dying empty slub caches, remove the sysfs files after deactivation so that we don't end up with millions of sysfs files without any useful information on them. This patchset contains the following nine patches. 0001-Revert-slub-move-synchronize_sched-out-of-slab_mutex.patch 0002-slub-separate-out-sysfs_slab_release-from-sysfs_slab.patch 0003-slab-remove-synchronous-rcu_barrier-call-in-memcg-ca.patch 0004-slab-reorganize-memcg_cache_params.patch 0005-slab-link-memcg-kmem_caches-on-their-associated-memo.patch 0006-slab-implement-slab_root_caches-list.patch 0007-slab-introduce-__kmemcg_cache_deactivate.patch 0008-slab-remove-synchronous-synchronize_sched-from-memcg.patch 0009-slab-remove-slub-sysfs-interface-files-early-for-emp.patch 0010-slab-use-memcg_kmem_cache_wq-for-slab-destruction-op.patch 0001 reverts an existing optimization to prepare for the following changes. 0002 is a prep patch. 0003 makes rcu_barrier() in release path batched and asynchronous. 0004-0006 separate out the lists. 0007-0008 replace synchronize_sched() in slub destruction path with call_rcu_sched(). 0009 removes sysfs files early for empty dying caches. 0010 makes destruction work items use a workqueue with limited concurrency. This patch (of 10): Revert 89e364db71fb5e ("slub: move synchronize_sched out of slab_mutex on shrink"). With kmem cgroup support enabled, kmem_caches can be created and destroyed frequently and a great number of near empty kmem_caches can accumulate if there are a lot of transient cgroups and the system is not under memory pressure. When memory reclaim starts under such conditions, it can lead to consecutive deactivation and destruction of many kmem_caches, easily hundreds of thousands on moderately large systems, exposing scalability issues in the current slab management code. This is one of the patches to address the issue. Moving synchronize_sched() out of slab_mutex isn't enough as it's still inside cgroup_mutex. The whole deactivation / release path will be updated to avoid all synchronous RCU operations. Revert this insufficient optimization in preparation to ease future changes. Link: http://lkml.kernel.org/r/20170117235411.9408-2-tj@kernel.org Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Jay Vana <jsvana@fb.com> Cc: Vladimir Davydov <vdavydov.dev@gmail.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-02-22mm/slub: add a dump_stack() to the unexpected GFP checkBorislav Petkov
We wish to know who is doing such a thing. slab.c does this. Link: http://lkml.kernel.org/r/20170116091643.15260-1-bp@alien8.de Signed-off-by: Borislav Petkov <bp@suse.de> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-02-08mm/slub.c: fix random_seq offset destructionSean Rees
Commit 210e7a43fa90 ("mm: SLUB freelist randomization") broke USB hub initialisation as described in https://bugzilla.kernel.org/show_bug.cgi?id=177551. Bail out early from init_cache_random_seq if s->random_seq is already initialised. This prevents destroying the previously computed random_seq offsets later in the function. If the offsets are destroyed, then shuffle_freelist will truncate page->freelist to just the first object (orphaning the rest). Fixes: 210e7a43fa90 ("mm: SLUB freelist randomization") Link: http://lkml.kernel.org/r/20170207140707.20824-1-sean@erifax.org Signed-off-by: Sean Rees <sean@erifax.org> Reported-by: <userwithuid@gmail.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Thomas Garnier <thgarnie@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-01-24mm/slub.c: trace free objects at KERN_INFODaniel Thompson
Currently when trace is enabled (e.g. slub_debug=T,kmalloc-128 ) the trace messages are mostly output at KERN_INFO. However the trace code also calls print_section() to hexdump the head of a free object. This is hard coded to use KERN_ERR, meaning the console is deluged with trace messages even if we've asked for quiet. Fix this the obvious way but adding a level parameter to print_section(), allowing calls from the trace code to use the same trace level as other trace messages. Link: http://lkml.kernel.org/r/20170113154850.518-1-daniel.thompson@linaro.org Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org> Acked-by: Christoph Lameter <cl@linux.com> Acked-by: David Rientjes <rientjes@google.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-12-12slub: avoid false-postive warningArnd Bergmann
The slub allocator gives us some incorrect warnings when CONFIG_PROFILE_ANNOTATED_BRANCHES is set, as the unlikely() macro prevents it from seeing that the return code matches what it was before: mm/slub.c: In function `kmem_cache_free_bulk': mm/slub.c:262:23: error: `df.s' may be used uninitialized in this function [-Werror=maybe-uninitialized] mm/slub.c:2943:3: error: `df.cnt' may be used uninitialized in this function [-Werror=maybe-uninitialized] mm/slub.c:2933:4470: error: `df.freelist' may be used uninitialized in this function [-Werror=maybe-uninitialized] mm/slub.c:2943:3: error: `df.tail' may be used uninitialized in this function [-Werror=maybe-uninitialized] I have not been able to come up with a perfect way for dealing with this, the three options I see are: - add a bogus initialization, which would increase the runtime overhead - replace unlikely() with unlikely_notrace() - remove the unlikely() annotation completely I checked the object code for a typical x86 configuration and the last two cases produce the same result, so I went for the last one, which is the simplest. Link: http://lkml.kernel.org/r/20161024155704.3114445-1-arnd@arndb.de Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Jesper Dangaard Brouer <brouer@redhat.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Vladimir Davydov <vdavydov.dev@gmail.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Laura Abbott <labbott@fedoraproject.org> Cc: Alexander Potapenko <glider@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-12-12slub: move synchronize_sched out of slab_mutex on shrinkVladimir Davydov
synchronize_sched() is a heavy operation and calling it per each cache owned by a memory cgroup being destroyed may take quite some time. What is worse, it's currently called under the slab_mutex, stalling all works doing cache creation/destruction. Actually, there isn't much point in calling synchronize_sched() for each cache - it's enough to call it just once - after setting cpu_partial for all caches and before shrinking them. This way, we can also move it out of the slab_mutex, which we have to hold for iterating over the slab cache list. Link: https://bugzilla.kernel.org/show_bug.cgi?id=172991 Link: http://lkml.kernel.org/r/0a10d71ecae3db00fb4421bcd3f82bcc911f4be4.1475329751.git.vdavydov.dev@gmail.com Signed-off-by: Vladimir Davydov <vdavydov.dev@gmail.com> Reported-by: Doug Smythies <dsmythies@telus.net> Acked-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@kernel.org> Cc: Pekka Enberg <penberg@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-09-06slub: Convert to hotplug state machineSebastian Andrzej Siewior
Install the callbacks via the state machine. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: linux-mm@kvack.org Cc: rt@linutronix.de Cc: David Rientjes <rientjes@google.com> Cc: Christoph Lameter <cl@linux.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Link: http://lkml.kernel.org/r/20160818125731.27256-5-bigeasy@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-08-10mm/slub.c: run free_partial() outside of the kmem_cache_node->list_lockChris Wilson
With debugobjects enabled and using SLAB_DESTROY_BY_RCU, when a kmem_cache_node is destroyed the call_rcu() may trigger a slab allocation to fill the debug object pool (__debug_object_init:fill_pool). Everywhere but during kmem_cache_destroy(), discard_slab() is performed outside of the kmem_cache_node->list_lock and avoids a lockdep warning about potential recursion: ============================================= [ INFO: possible recursive locking detected ] 4.8.0-rc1-gfxbench+ #1 Tainted: G U --------------------------------------------- rmmod/8895 is trying to acquire lock: (&(&n->list_lock)->rlock){-.-...}, at: [<ffffffff811c80d7>] get_partial_node.isra.63+0x47/0x430 but task is already holding lock: (&(&n->list_lock)->rlock){-.-...}, at: [<ffffffff811cbda4>] __kmem_cache_shutdown+0x54/0x320 other info that might help us debug this: Possible unsafe locking scenario: CPU0 ---- lock(&(&n->list_lock)->rlock); lock(&(&n->list_lock)->rlock); *** DEADLOCK *** May be due to missing lock nesting notation 5 locks held by rmmod/8895: #0: (&dev->mutex){......}, at: driver_detach+0x42/0xc0 #1: (&dev->mutex){......}, at: driver_detach+0x50/0xc0 #2: (cpu_hotplug.dep_map){++++++}, at: get_online_cpus+0x2d/0x80 #3: (slab_mutex){+.+.+.}, at: kmem_cache_destroy+0x3c/0x220 #4: (&(&n->list_lock)->rlock){-.-...}, at: __kmem_cache_shutdown+0x54/0x320 stack backtrace: CPU: 6 PID: 8895 Comm: rmmod Tainted: G U 4.8.0-rc1-gfxbench+ #1 Hardware name: Gigabyte Technology Co., Ltd. H87M-D3H/H87M-D3H, BIOS F11 08/18/2015 Call Trace: __lock_acquire+0x1646/0x1ad0 lock_acquire+0xb2/0x200 _raw_spin_lock+0x36/0x50 get_partial_node.isra.63+0x47/0x430 ___slab_alloc.constprop.67+0x1a7/0x3b0 __slab_alloc.isra.64.constprop.66+0x43/0x80 kmem_cache_alloc+0x236/0x2d0 __debug_object_init+0x2de/0x400 debug_object_activate+0x109/0x1e0 __call_rcu.constprop.63+0x32/0x2f0 call_rcu+0x12/0x20 discard_slab+0x3d/0x40 __kmem_cache_shutdown+0xdb/0x320 shutdown_cache+0x19/0x60 kmem_cache_destroy+0x1ae/0x220 i915_gem_load_cleanup+0x14/0x40 [i915] i915_driver_unload+0x151/0x180 [i915] i915_pci_remove+0x14/0x20 [i915] pci_device_remove+0x34/0xb0 __device_release_driver+0x95/0x140 driver_detach+0xb6/0xc0 bus_remove_driver+0x53/0xd0 driver_unregister+0x27/0x50 pci_unregister_driver+0x25/0x70 i915_exit+0x1a/0x1e2 [i915] SyS_delete_module+0x193/0x1f0 entry_SYSCALL_64_fastpath+0x1c/0xac Fixes: 52b4b950b507 ("mm: slab: free kmem_cache_node after destroy sysfs file") Link: http://lkml.kernel.org/r/1470759070-18743-1-git-send-email-chris@chris-wilson.co.uk Reported-by: Dave Gordon <david.s.gordon@intel.com> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Reviewed-by: Vladimir Davydov <vdavydov@virtuozzo.com> Acked-by: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Dmitry Safonov <dsafonov@virtuozzo.com> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: Dave Gordon <david.s.gordon@intel.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-08Merge tag 'usercopy-v4.8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux Pull usercopy protection from Kees Cook: "Tbhis implements HARDENED_USERCOPY verification of copy_to_user and copy_from_user bounds checking for most architectures on SLAB and SLUB" * tag 'usercopy-v4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux: mm: SLUB hardened usercopy support mm: SLAB hardened usercopy support s390/uaccess: Enable hardened usercopy sparc/uaccess: Enable hardened usercopy powerpc/uaccess: Enable hardened usercopy ia64/uaccess: Enable hardened usercopy arm64/uaccess: Enable hardened usercopy ARM: uaccess: Enable hardened usercopy x86/uaccess: Enable hardened usercopy mm: Hardened usercopy mm: Implement stack frame object validation mm: Add is_migrate_cma_page
2016-08-04slub: drop bogus inline for fixup_red_left()Geert Uytterhoeven
With m68k-linux-gnu-gcc-4.1: include/linux/slub_def.h:126: warning: `fixup_red_left' declared inline after being called include/linux/slub_def.h:126: warning: previous declaration of `fixup_red_left' was here Commit c146a2b98eb5 ("mm, kasan: account for object redzone in SLUB's nearest_obj()") made fixup_red_left() global, but forgot to remove the inline keyword. Fixes: c146a2b98eb5898e ("mm, kasan: account for object redzone in SLUB's nearest_obj()") Link: http://lkml.kernel.org/r/1470256262-1586-1-git-send-email-geert@linux-m68k.org Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Alexander Potapenko <glider@google.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02mm/kasan: get rid of ->state in struct kasan_alloc_metaAndrey Ryabinin
The state of object currently tracked in two places - shadow memory, and the ->state field in struct kasan_alloc_meta. We can get rid of the latter. The will save us a little bit of memory. Also, this allow us to move free stack into struct kasan_alloc_meta, without increasing memory consumption. So now we should always know when the last time the object was freed. This may be useful for long delayed use-after-free bugs. As a side effect this fixes following UBSAN warning: UBSAN: Undefined behaviour in mm/kasan/quarantine.c:102:13 member access within misaligned address ffff88000d1efebc for type 'struct qlist_node' which requires 8 byte alignment Link: http://lkml.kernel.org/r/1470062715-14077-5-git-send-email-aryabinin@virtuozzo.com Reported-by: kernel test robot <xiaolong.ye@intel.com> Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Alexander Potapenko <glider@google.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-28mm, kasan: switch SLUB to stackdepot, enable memory quarantine for SLUBAlexander Potapenko
For KASAN builds: - switch SLUB allocator to using stackdepot instead of storing the allocation/deallocation stacks in the objects; - change the freelist hook so that parts of the freelist can be put into the quarantine. [aryabinin@virtuozzo.com: fixes] Link: http://lkml.kernel.org/r/1468601423-28676-1-git-send-email-aryabinin@virtuozzo.com Link: http://lkml.kernel.org/r/1468347165-41906-3-git-send-email-glider@google.com Signed-off-by: Alexander Potapenko <glider@google.com> Cc: Andrey Konovalov <adech.fo@gmail.com> Cc: Christoph Lameter <cl@linux.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Steven Rostedt (Red Hat) <rostedt@goodmis.org> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Kostya Serebryany <kcc@google.com> Cc: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Kuthonuzo Luruo <kuthonuzo.luruo@hpe.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-28mm, kasan: account for object redzone in SLUB's nearest_obj()Alexander Potapenko
When looking up the nearest SLUB object for a given address, correctly calculate its offset if SLAB_RED_ZONE is enabled for that cache. Previously, when KASAN had detected an error on an object from a cache with SLAB_RED_ZONE set, the actual start address of the object was miscalculated, which led to random stacks having been reported. When looking up the nearest SLUB object for a given address, correctly calculate its offset if SLAB_RED_ZONE is enabled for that cache. Fixes: 7ed2f9e663854db ("mm, kasan: SLAB support") Link: http://lkml.kernel.org/r/1468347165-41906-2-git-send-email-glider@google.com Signed-off-by: Alexander Potapenko <glider@google.com> Cc: Andrey Konovalov <adech.fo@gmail.com> Cc: Christoph Lameter <cl@linux.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Steven Rostedt (Red Hat) <rostedt@goodmis.org> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Kostya Serebryany <kcc@google.com> Cc: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Kuthonuzo Luruo <kuthonuzo.luruo@hpe.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26mm: charge/uncharge kmemcg from generic page allocator pathsVladimir Davydov
Currently, to charge a non-slab allocation to kmemcg one has to use alloc_kmem_pages helper with __GFP_ACCOUNT flag. A page allocated with this helper should finally be freed using free_kmem_pages, otherwise it won't be uncharged. This API suits its current users fine, but it turns out to be impossible to use along with page reference counting, i.e. when an allocation is supposed to be freed with put_page, as it is the case with pipe or unix socket buffers. To overcome this limitation, this patch moves charging/uncharging to generic page allocator paths, i.e. to __alloc_pages_nodemask and free_pages_prepare, and zaps alloc/free_kmem_pages helpers. This way, one can use any of the available page allocation functions to get the allocated page charged to kmemcg - it's enough to pass __GFP_ACCOUNT, just like in case of kmalloc and friends. A charged page will be automatically uncharged on free. To make it possible, we need to mark pages charged to kmemcg somehow. To avoid introducing a new page flag, we make use of page->_mapcount for marking such pages. Since pages charged to kmemcg are not supposed to be mapped to userspace, it should work just fine. There are other (ab)users of page->_mapcount - buddy and balloon pages - but we don't conflict with them. In case kmemcg is compiled out or not used at runtime, this patch introduces no overhead to generic page allocator paths. If kmemcg is used, it will be plus one gfp flags check on alloc and plus one page->_mapcount check on free, which shouldn't hurt performance, because the data accessed are hot. Link: http://lkml.kernel.org/r/a9736d856f895bcb465d9f257b54efe32eda6f99.1464079538.git.vdavydov@virtuozzo.com Signed-off-by: Vladimir Davydov <vdavydov@virtuozzo.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@kernel.org> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26slab: do not panic on invalid gfp_maskMichal Hocko
Both SLAB and SLUB BUG() when a caller provides an invalid gfp_mask. This is a rather harsh way to announce a non-critical issue. Allocator is free to ignore invalid flags. Let's simply replace BUG() by dump_stack to tell the offender and fixup the mask to move on with the allocation request. This is an example for kmalloc(GFP_KERNEL|__GFP_HIGHMEM) from a test module: Unexpected gfp: 0x2 (__GFP_HIGHMEM). Fixing up to gfp: 0x24000c0 (GFP_KERNEL). Fix your code! CPU: 0 PID: 2916 Comm: insmod Tainted: G O 4.6.0-slabgfp2-00002-g4cdfc2ef4892-dirty #936 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Debian-1.8.2-1 04/01/2014 Call Trace: dump_stack+0x67/0x90 cache_alloc_refill+0x201/0x617 kmem_cache_alloc_trace+0xa7/0x24a ? 0xffffffffa0005000 mymodule_init+0x20/0x1000 [test_slab] do_one_initcall+0xe7/0x16c ? rcu_read_lock_sched_held+0x61/0x69 ? kmem_cache_alloc_trace+0x197/0x24a do_init_module+0x5f/0x1d9 load_module+0x1a3d/0x1f21 ? retint_kernel+0x2d/0x2d SyS_init_module+0xe8/0x10e ? SyS_init_module+0xe8/0x10e do_syscall_64+0x68/0x13f entry_SYSCALL64_slow_path+0x25/0x25 Link: http://lkml.kernel.org/r/1465548200-11384-2-git-send-email-mhocko@kernel.org Signed-off-by: Michal Hocko <mhocko@suse.com> Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26slab: make GFP_SLAB_BUG_MASK information more human readableMichal Hocko
printk offers %pGg for quite some time so let's use it to get a human readable list of invalid flags. The original output would be [ 429.191962] gfp: 2 after the change [ 429.191962] Unexpected gfp: 0x2 (__GFP_HIGHMEM) Link: http://lkml.kernel.org/r/1465548200-11384-1-git-send-email-mhocko@kernel.org Signed-off-by: Michal Hocko <mhocko@suse.com> Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26mm: SLUB freelist randomizationThomas Garnier
Implements freelist randomization for the SLUB allocator. It was previous implemented for the SLAB allocator. Both use the same configuration option (CONFIG_SLAB_FREELIST_RANDOM). The list is randomized during initialization of a new set of pages. The order on different freelist sizes is pre-computed at boot for performance. Each kmem_cache has its own randomized freelist. This security feature reduces the predictability of the kernel SLUB allocator against heap overflows rendering attacks much less stable. For example these attacks exploit the predictability of the heap: - Linux Kernel CAN SLUB overflow (https://goo.gl/oMNWkU) - Exploiting Linux Kernel Heap corruptions (http://goo.gl/EXLn95) Performance results: slab_test impact is between 3% to 4% on average for 100000 attempts without smp. It is a very focused testing, kernbench show the overall impact on the system is way lower. Before: Single thread testing ===================== 1. Kmalloc: Repeatedly allocate then free test 100000 times kmalloc(8) -> 49 cycles kfree -> 77 cycles 100000 times kmalloc(16) -> 51 cycles kfree -> 79 cycles 100000 times kmalloc(32) -> 53 cycles kfree -> 83 cycles 100000 times kmalloc(64) -> 62 cycles kfree -> 90 cycles 100000 times kmalloc(128) -> 81 cycles kfree -> 97 cycles 100000 times kmalloc(256) -> 98 cycles kfree -> 121 cycles 100000 times kmalloc(512) -> 95 cycles kfree -> 122 cycles 100000 times kmalloc(1024) -> 96 cycles kfree -> 126 cycles 100000 times kmalloc(2048) -> 115 cycles kfree -> 140 cycles 100000 times kmalloc(4096) -> 149 cycles kfree -> 171 cycles 2. Kmalloc: alloc/free test 100000 times kmalloc(8)/kfree -> 70 cycles 100000 times kmalloc(16)/kfree -> 70 cycles 100000 times kmalloc(32)/kfree -> 70 cycles 100000 times kmalloc(64)/kfree -> 70 cycles 100000 times kmalloc(128)/kfree -> 70 cycles 100000 times kmalloc(256)/kfree -> 69 cycles 100000 times kmalloc(512)/kfree -> 70 cycles 100000 times kmalloc(1024)/kfree -> 73 cycles 100000 times kmalloc(2048)/kfree -> 72 cycles 100000 times kmalloc(4096)/kfree -> 71 cycles After: Single thread testing ===================== 1. Kmalloc: Repeatedly allocate then free test 100000 times kmalloc(8) -> 57 cycles kfree -> 78 cycles 100000 times kmalloc(16) -> 61 cycles kfree -> 81 cycles 100000 times kmalloc(32) -> 76 cycles kfree -> 93 cycles 100000 times kmalloc(64) -> 83 cycles kfree -> 94 cycles 100000 times kmalloc(128) -> 106 cycles kfree -> 107 cycles 100000 times kmalloc(256) -> 118 cycles kfree -> 117 cycles 100000 times kmalloc(512) -> 114 cycles kfree -> 116 cycles 100000 times kmalloc(1024) -> 115 cycles kfree -> 118 cycles 100000 times kmalloc(2048) -> 147 cycles kfree -> 131 cycles 100000 times kmalloc(4096) -> 214 cycles kfree -> 161 cycles 2. Kmalloc: alloc/free test 100000 times kmalloc(8)/kfree -> 66 cycles 100000 times kmalloc(16)/kfree -> 66 cycles 100000 times kmalloc(32)/kfree -> 66 cycles 100000 times kmalloc(64)/kfree -> 66 cycles 100000 times kmalloc(128)/kfree -> 65 cycles 100000 times kmalloc(256)/kfree -> 67 cycles 100000 times kmalloc(512)/kfree -> 67 cycles 100000 times kmalloc(1024)/kfree -> 64 cycles 100000 times kmalloc(2048)/kfree -> 67 cycles 100000 times kmalloc(4096)/kfree -> 67 cycles Kernbench, before: Average Optimal load -j 12 Run (std deviation): Elapsed Time 101.873 (1.16069) User Time 1045.22 (1.60447) System Time 88.969 (0.559195) Percent CPU 1112.9 (13.8279) Context Switches 189140 (2282.15) Sleeps 99008.6 (768.091) After: Average Optimal load -j 12 Run (std deviation): Elapsed Time 102.47 (0.562732) User Time 1045.3 (1.34263) System Time 88.311 (0.342554) Percent CPU 1105.8 (6.49444) Context Switches 189081 (2355.78) Sleeps 99231.5 (800.358) Link: http://lkml.kernel.org/r/1464295031-26375-3-git-send-email-thgarnie@google.com Signed-off-by: Thomas Garnier <thgarnie@google.com> Reviewed-by: Kees Cook <keescook@chromium.org> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26mm: SLUB hardened usercopy supportKees Cook
Under CONFIG_HARDENED_USERCOPY, this adds object size checking to the SLUB allocator to catch any copies that may span objects. Includes a redzone handling fix discovered by Michael Ellerman. Based on code from PaX and grsecurity. Signed-off-by: Kees Cook <keescook@chromium.org> Tested-by: Michael Ellerman <mpe@ellerman.id.au> Reviwed-by: Laura Abbott <labbott@redhat.com>
2016-05-20mm, kasan: don't call kasan_krealloc() from ksize().Alexander Potapenko
Instead of calling kasan_krealloc(), which replaces the memory allocation stack ID (if stack depot is used), just unpoison the whole memory chunk. Signed-off-by: Alexander Potapenko <glider@google.com> Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Andrey Konovalov <adech.fo@gmail.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Christoph Lameter <cl@linux.com> Cc: Konstantin Serebryany <kcc@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-19mm: rename _count, field of the struct page, to _refcountJoonsoo Kim
Many developers already know that field for reference count of the struct page is _count and atomic type. They would try to handle it directly and this could break the purpose of page reference count tracepoint. To prevent direct _count modification, this patch rename it to _refcount and add warning message on the code. After that, developer who need to handle reference count will find that field should not be accessed directly. [akpm@linux-foundation.org: fix comments, per Vlastimil] [akpm@linux-foundation.org: Documentation/vm/transhuge.txt too] [sfr@canb.auug.org.au: sync ethernet driver changes] Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: "David S. Miller" <davem@davemloft.net> Cc: Sunil Goutham <sgoutham@cavium.com> Cc: Chris Metcalf <cmetcalf@mellanox.com> Cc: Manish Chopra <manish.chopra@qlogic.com> Cc: Yuval Mintz <yuval.mintz@qlogic.com> Cc: Tariq Toukan <tariqt@mellanox.com> Cc: Saeed Mahameed <saeedm@mellanox.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-19mm/slub.c: fix sysfs filename in commentLi Peng
/sys/kernel/slab/xx/defrag_ratio should be remote_node_defrag_ratio. Link: http://lkml.kernel.org/r/1463449242-5366-1-git-send-email-lip@dtdream.com Signed-off-by: Li Peng <lip@dtdream.com> Acked-by: Christoph Lameter <cl@linux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-19mm/slub.c: replace kick_all_cpus_sync() with synchronize_sched() in ↵Vladimir Davydov
kmem_cache_shrink() When we call __kmem_cache_shrink on memory cgroup removal, we need to synchronize kmem_cache->cpu_partial update with put_cpu_partial that might be running on other cpus. Currently, we achieve that by using kick_all_cpus_sync, which works as a system wide memory barrier. Though fast it is, this method has a flaw - it issues a lot of IPIs, which might hurt high performance or real-time workloads. To fix this, let's replace kick_all_cpus_sync with synchronize_sched. Although the latter one may take much longer to finish, it shouldn't be a problem in this particular case, because memory cgroups are destroyed asynchronously from a workqueue so that no user visible effects should be introduced. OTOH, it will save us from excessive IPIs when someone removes a cgroup. Anyway, even if using synchronize_sched turns out to take too long, we can always introduce a kind of __kmem_cache_shrink batching so that this method would only be called once per one cgroup destruction (not per each per memcg kmem cache as it is now). Signed-off-by: Vladimir Davydov <vdavydov@virtuozzo.com> Reported-by: Peter Zijlstra <peterz@infradead.org> Suggested-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-25mm, kasan: add GFP flags to KASAN APIAlexander Potapenko
Add GFP flags to KASAN hooks for future patches to use. This patch is based on the "mm: kasan: unified support for SLUB and SLAB allocators" patch originally prepared by Dmitry Chernenkov. Signed-off-by: Alexander Potapenko <glider@google.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Andrey Konovalov <adech.fo@gmail.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Konstantin Serebryany <kcc@google.com> Cc: Dmitry Chernenkov <dmitryc@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-17mm: coalesce split stringsJoe Perches
Kernel style prefers a single string over split strings when the string is 'user-visible'. Miscellanea: - Add a missing newline - Realign arguments Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Tejun Heo <tj@kernel.org> [percpu] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-17mm: thp: set THP defrag by default to madvise and add a stall-free defrag optionMel Gorman
THP defrag is enabled by default to direct reclaim/compact but not wake kswapd in the event of a THP allocation failure. The problem is that THP allocation requests potentially enter reclaim/compaction. This potentially incurs a severe stall that is not guaranteed to be offset by reduced TLB misses. While there has been considerable effort to reduce the impact of reclaim/compaction, it is still a high cost and workloads that should fit in memory fail to do so. Specifically, a simple anon/file streaming workload will enter direct reclaim on NUMA at least even though the working set size is 80% of RAM. It's been years and it's time to throw in the towel. First, this patch defines THP defrag as follows; madvise: A failed allocation will direct reclaim/compact if the application requests it never: Neither reclaim/compact nor wake kswapd defer: A failed allocation will wake kswapd/kcompactd always: A failed allocation will direct reclaim/compact (historical behaviour) khugepaged defrag will enter direct/reclaim but not wake kswapd. Next it sets the default defrag option to be "madvise" to only enter direct reclaim/compaction for applications that specifically requested it. Lastly, it removes a check from the page allocator slowpath that is related to __GFP_THISNODE to allow "defer" to work. The callers that really cares are slub/slab and they are updated accordingly. The slab one may be surprising because it also corrects a comment as kswapd was never woken up by that path. This means that a THP fault will no longer stall for most applications by default and the ideal for most users that get THP if they are immediately available. There are still options for users that prefer a stall at startup of a new application by either restoring historical behaviour with "always" or pick a half-way point with "defer" where kswapd does some of the work in the background and wakes kcompactd if necessary. THP defrag for khugepaged remains enabled and will enter direct/reclaim but no wakeup kswapd or kcompactd. After this patch a THP allocation failure will quickly fallback and rely on khugepaged to recover the situation at some time in the future. In some cases, this will reduce THP usage but the benefit of THP is hard to measure and not a universal win where as a stall to reclaim/compaction is definitely measurable and can be painful. The first test for this is using "usemem" to read a large file and write a large anonymous mapping (to avoid the zero page) multiple times. The total size of the mappings is 80% of RAM and the benchmark simply measures how long it takes to complete. It uses multiple threads to see if that is a factor. On UMA, the performance is almost identical so is not reported but on NUMA, we see this usemem 4.4.0 4.4.0 kcompactd-v1r1 nodefrag-v1r3 Amean System-1 102.86 ( 0.00%) 46.81 ( 54.50%) Amean System-4 37.85 ( 0.00%) 34.02 ( 10.12%) Amean System-7 48.12 ( 0.00%) 46.89 ( 2.56%) Amean System-12 51.98 ( 0.00%) 56.96 ( -9.57%) Amean System-21 80.16 ( 0.00%) 79.05 ( 1.39%) Amean System-30 110.71 ( 0.00%) 107.17 ( 3.20%) Amean System-48 127.98 ( 0.00%) 124.83 ( 2.46%) Amean Elapsd-1 185.84 ( 0.00%) 105.51 ( 43.23%) Amean Elapsd-4 26.19 ( 0.00%) 25.58 ( 2.33%) Amean Elapsd-7 21.65 ( 0.00%) 21.62 ( 0.16%) Amean Elapsd-12 18.58 ( 0.00%) 17.94 ( 3.43%) Amean Elapsd-21 17.53 ( 0.00%) 16.60 ( 5.33%) Amean Elapsd-30 17.45 ( 0.00%) 17.13 ( 1.84%) Amean Elapsd-48 15.40 ( 0.00%) 15.27 ( 0.82%) For a single thread, the benchmark completes 43.23% faster with this patch applied with smaller benefits as the thread increases. Similar, notice the large reduction in most cases in system CPU usage. The overall CPU time is 4.4.0 4.4.0 kcompactd-v1r1 nodefrag-v1r3 User 10357.65 10438.33 System 3988.88 3543.94 Elapsed 2203.01 1634.41 Which is substantial. Now, the reclaim figures 4.4.0 4.4.0 kcompactd-v1r1nodefrag-v1r3 Minor Faults 128458477 278352931 Major Faults 2174976 225 Swap Ins 16904701 0 Swap Outs 17359627 0 Allocation stalls 43611 0 DMA allocs 0 0 DMA32 allocs 19832646 19448017 Normal allocs 614488453 580941839 Movable allocs 0 0 Direct pages scanned 24163800 0 Kswapd pages scanned 0 0 Kswapd pages reclaimed 0 0 Direct pages reclaimed 20691346 0 Compaction stalls 42263 0 Compaction success 938 0 Compaction failures 41325 0 This patch eliminates almost all swapping and direct reclaim activity. There is still overhead but it's from NUMA balancing which does not identify that it's pointless trying to do anything with this workload. I also tried the thpscale benchmark which forces a corner case where compaction can be used heavily and measures the latency of whether base or huge pages were used thpscale Fault Latencies 4.4.0 4.4.0 kcompactd-v1r1 nodefrag-v1r3 Amean fault-base-1 5288.84 ( 0.00%) 2817.12 ( 46.73%) Amean fault-base-3 6365.53 ( 0.00%) 3499.11 ( 45.03%) Amean fault-base-5 6526.19 ( 0.00%) 4363.06 ( 33.15%) Amean fault-base-7 7142.25 ( 0.00%) 4858.08 ( 31.98%) Amean fault-base-12 13827.64 ( 0.00%) 10292.11 ( 25.57%) Amean fault-base-18 18235.07 ( 0.00%) 13788.84 ( 24.38%) Amean fault-base-24 21597.80 ( 0.00%) 24388.03 (-12.92%) Amean fault-base-30 26754.15 ( 0.00%) 19700.55 ( 26.36%) Amean fault-base-32 26784.94 ( 0.00%) 19513.57 ( 27.15%) Amean fault-huge-1 4223.96 ( 0.00%) 2178.57 ( 48.42%) Amean fault-huge-3 2194.77 ( 0.00%) 2149.74 ( 2.05%) Amean fault-huge-5 2569.60 ( 0.00%) 2346.95 ( 8.66%) Amean fault-huge-7 3612.69 ( 0.00%) 2997.70 ( 17.02%) Amean fault-huge-12 3301.75 ( 0.00%) 6727.02 (-103.74%) Amean fault-huge-18 6696.47 ( 0.00%) 6685.72 ( 0.16%) Amean fault-huge-24 8000.72 ( 0.00%) 9311.43 (-16.38%) Amean fault-huge-30 13305.55 ( 0.00%) 9750.45 ( 26.72%) Amean fault-huge-32 9981.71 ( 0.00%) 10316.06 ( -3.35%) The average time to fault pages is substantially reduced in the majority of caseds but with the obvious caveat that fewer THPs are actually used in this adverse workload 4.4.0 4.4.0 kcompactd-v1r1 nodefrag-v1r3 Percentage huge-1 0.71 ( 0.00%) 14.04 (1865.22%) Percentage huge-3 10.77 ( 0.00%) 33.05 (206.85%) Percentage huge-5 60.39 ( 0.00%) 38.51 (-36.23%) Percentage huge-7 45.97 ( 0.00%) 34.57 (-24.79%) Percentage huge-12 68.12 ( 0.00%) 40.07 (-41.17%) Percentage huge-18 64.93 ( 0.00%) 47.82 (-26.35%) Percentage huge-24 62.69 ( 0.00%) 44.23 (-29.44%) Percentage huge-30 43.49 ( 0.00%) 55.38 ( 27.34%) Percentage huge-32 50.72 ( 0.00%) 51.90 ( 2.35%) 4.4.0 4.4.0 kcompactd-v1r1nodefrag-v1r3 Minor Faults 37429143 47564000 Major Faults 1916 1558 Swap Ins 1466 1079 Swap Outs 2936863 149626 Allocation stalls 62510 3 DMA allocs 0 0 DMA32 allocs 6566458 6401314 Normal allocs 216361697 216538171 Movable allocs 0 0 Direct pages scanned 25977580 17998 Kswapd pages scanned 0 3638931 Kswapd pages reclaimed 0 207236 Direct pages reclaimed 8833714 88 Compaction stalls 103349 5 Compaction success 270 4 Compaction failures 103079 1 Note again that while this does swap as it's an aggressive workload, the direct relcim activity and allocation stalls is substantially reduced. There is some kswapd activity but ftrace showed that the kswapd activity was due to normal wakeups from 4K pages being allocated. Compaction-related stalls and activity are almost eliminated. I also tried the stutter benchmark. For this, I do not have figures for NUMA but it's something that does impact UMA so I'll report what is available stutter 4.4.0 4.4.0 kcompactd-v1r1 nodefrag-v1r3 Min mmap 7.3571 ( 0.00%) 7.3438 ( 0.18%) 1st-qrtle mmap 7.5278 ( 0.00%) 17.9200 (-138.05%) 2nd-qrtle mmap 7.6818 ( 0.00%) 21.6055 (-181.25%) 3rd-qrtle mmap 11.0889 ( 0.00%) 21.8881 (-97.39%) Max-90% mmap 27.8978 ( 0.00%) 22.1632 ( 20.56%) Max-93% mmap 28.3202 ( 0.00%) 22.3044 ( 21.24%) Max-95% mmap 28.5600 ( 0.00%) 22.4580 ( 21.37%) Max-99% mmap 29.6032 ( 0.00%) 25.5216 ( 13.79%) Max mmap 4109.7289 ( 0.00%) 4813.9832 (-17.14%) Mean mmap 12.4474 ( 0.00%) 19.3027 (-55.07%) This benchmark is trying to fault an anonymous mapping while there is a heavy IO load -- a scenario that desktop users used to complain about frequently. This shows a mix because the ideal case of mapping with THP is not hit as often. However, note that 99% of the mappings complete 13.79% faster. The CPU usage here is particularly interesting 4.4.0 4.4.0 kcompactd-v1r1nodefrag-v1r3 User 67.50 0.99 System 1327.88 91.30 Elapsed 2079.00 2128.98 And once again we look at the reclaim figures 4.4.0 4.4.0 kcompactd-v1r1nodefrag-v1r3 Minor Faults 335241922 1314582827 Major Faults 715 819 Swap Ins 0 0 Swap Outs 0 0 Allocation stalls 532723 0 DMA allocs 0 0 DMA32 allocs 1822364341 1177950222 Normal allocs 1815640808 1517844854 Movable allocs 0 0 Direct pages scanned 21892772 0 Kswapd pages scanned 20015890 41879484 Kswapd pages reclaimed 19961986 41822072 Direct pages reclaimed 21892741 0 Compaction stalls 1065755 0 Compaction success 514 0 Compaction failures 1065241 0 Allocation stalls and all direct reclaim activity is eliminated as well as compaction-related stalls. THP gives impressive gains in some cases but only if they are quickly available. We're not going to reach the point where they are completely free so lets take the costs out of the fast paths finally and defer the cost to kswapd, kcompactd and khugepaged where it belongs. Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-17mm/slub: query dynamic DEBUG_PAGEALLOC settingJoonsoo Kim
We can disable debug_pagealloc processing even if the code is compiled with CONFIG_DEBUG_PAGEALLOC. This patch changes the code to query whether it is enabled or not in runtime. [akpm@linux-foundation.org: clean up code, per Christian] Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: Takashi Iwai <tiwai@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-17mm: memcontrol: report slab usage in cgroup2 memory.statVladimir Davydov
Show how much memory is used for storing reclaimable and unreclaimable in-kernel data structures allocated from slab caches. Signed-off-by: Vladimir Davydov <vdavydov@virtuozzo.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-15mm, sl[au]b: print gfp_flags as strings in slab_out_of_memory()Vlastimil Babka
We can now print gfp_flags more human-readable. Make use of this in slab_out_of_memory() for SLUB and SLAB. Also convert the SLAB variant it to pr_warn() along the way. Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: David Rientjes <rientjes@google.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-15mm/slub: support left redzoneJoonsoo Kim
SLUB already has a redzone debugging feature. But it is only positioned at the end of object (aka right redzone) so it cannot catch left oob. Although current object's right redzone acts as left redzone of next object, first object in a slab cannot take advantage of this effect. This patch explicitly adds a left red zone to each object to detect left oob more precisely. Background: Someone complained to me that left OOB doesn't catch even if KASAN is enabled which does page allocation debugging. That page is out of our control so it would be allocated when left OOB happens and, in this case, we can't find OOB. Moreover, SLUB debugging feature can be enabled without page allocator debugging and, in this case, we will miss that OOB. Before trying to implement, I expected that changes would be too complex, but, it doesn't look that complex to me now. Almost changes are applied to debug specific functions so I feel okay. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-15slub: relax CMPXCHG consistency restrictionsLaura Abbott
When debug options are enabled, cmpxchg on the page is disabled. This is because the page must be locked to ensure there are no false positives when performing consistency checks. Some debug options such as poisoning and red zoning only act on the object itself. There is no need to protect other CPUs from modification on only the object. Allow cmpxchg to happen with poisoning and red zoning are set on a slab. Credit to Mathias Krause for the original work which inspired this series Signed-off-by: Laura Abbott <labbott@fedoraproject.org> Acked-by: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Kees Cook <keescook@chromium.org> Cc: Mathias Krause <minipli@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-15slub: convert SLAB_DEBUG_FREE to SLAB_CONSISTENCY_CHECKSLaura Abbott
SLAB_DEBUG_FREE allows expensive consistency checks at free to be turned on or off. Expand its use to be able to turn off all consistency checks. This gives a nice speed up if you only want features such as poisoning or tracing. Credit to Mathias Krause for the original work which inspired this series Signed-off-by: Laura Abbott <labbott@fedoraproject.org> Acked-by: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Kees Cook <keescook@chromium.org> Cc: Mathias Krause <minipli@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-15slub: fix/clean free_debug_processing return pathsLaura Abbott
Since commit 19c7ff9ecd89 ("slub: Take node lock during object free checks") check_object has been incorrectly returning success as it follows the out label which just returns the node. Thanks to refactoring, the out and fail paths are now basically the same. Combine the two into one and just use a single label. Credit to Mathias Krause for the original work which inspired this series Signed-off-by: Laura Abbott <labbott@fedoraproject.org> Acked-by: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Kees Cook <keescook@chromium.org> Cc: Mathias Krause <minipli@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-15slub: drop lock at the end of free_debug_processingLaura Abbott
This series takes the suggestion of Christoph Lameter and only focuses on optimizing the slow path where the debug processing runs. The two main optimizations in this series are letting the consistency checks be skipped and relaxing the cmpxchg restrictions when we are not doing consistency checks. With hackbench -g 20 -l 1000 averaged over 100 runs: Before slub_debug=P mean 15.607 variance .086 stdev .294 After slub_debug=P mean 10.836 variance .155 stdev .394 This still isn't as fast as what is in grsecurity unfortunately so there's still work to be done. Profiling ___slab_alloc shows that 25-50% of time is spent in deactivate_slab. I haven't looked too closely to see if this is something that can be optimized. My plan for now is to focus on getting all of this merged (if appropriate) before digging in to another task. This patch (of 4): Currently, free_debug_processing has a comment "Keep node_lock to preserve integrity until the object is actually freed". In actuallity, the lock is dropped immediately in __slab_free. Rather than wait until __slab_free and potentially throw off the unlikely marking, just drop the lock in __slab_free. This also lets free_debug_processing take its own copy of the spinlock flags rather than trying to share the ones from __slab_free. Since there is no use for the node afterwards, change the return type of free_debug_processing to return an int like alloc_debug_processing. Credit to Mathias Krause for the original work which inspired this series [akpm@linux-foundation.org: fix build] Signed-off-by: Laura Abbott <labbott@fedoraproject.org> Acked-by: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Kees Cook <keescook@chromium.org> Cc: Mathias Krause <minipli@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-15mm: new API kfree_bulk() for SLAB+SLUB allocatorsJesper Dangaard Brouer
This patch introduce a new API call kfree_bulk() for bulk freeing memory objects not bound to a single kmem_cache. Christoph pointed out that it is possible to implement freeing of objects, without knowing the kmem_cache pointer as that information is available from the object's page->slab_cache. Proposing to remove the kmem_cache argument from the bulk free API. Jesper demonstrated that these extra steps per object comes at a performance cost. It is only in the case CONFIG_MEMCG_KMEM is compiled in and activated runtime that these steps are done anyhow. The extra cost is most visible for SLAB allocator, because the SLUB allocator does the page lookup (virt_to_head_page()) anyhow. Thus, the conclusion was to keep the kmem_cache free bulk API with a kmem_cache pointer, but we can still implement a kfree_bulk() API fairly easily. Simply by handling if kmem_cache_free_bulk() gets called with a kmem_cache NULL pointer. This does increase the code size a bit, but implementing a separate kfree_bulk() call would likely increase code size even more. Below benchmarks cost of alloc+free (obj size 256 bytes) on CPU i7-4790K @ 4.00GHz, no PREEMPT and CONFIG_MEMCG_KMEM=y. Code size increase for SLAB: add/remove: 0/0 grow/shrink: 1/0 up/down: 74/0 (74) function old new delta kmem_cache_free_bulk 660 734 +74 SLAB fastpath: 87 cycles(tsc) 21.814 sz - fallback - kmem_cache_free_bulk - kfree_bulk 1 - 103 cycles 25.878 ns - 41 cycles 10.498 ns - 81 cycles 20.312 ns 2 - 94 cycles 23.673 ns - 26 cycles 6.682 ns - 42 cycles 10.649 ns 3 - 92 cycles 23.181 ns - 21 cycles 5.325 ns - 39 cycles 9.950 ns 4 - 90 cycles 22.727 ns - 18 cycles 4.673 ns - 26 cycles 6.693 ns 8 - 89 cycles 22.270 ns - 14 cycles 3.664 ns - 23 cycles 5.835 ns 16 - 88 cycles 22.038 ns - 14 cycles 3.503 ns - 22 cycles 5.543 ns 30 - 89 cycles 22.284 ns - 13 cycles 3.310 ns - 20 cycles 5.197 ns 32 - 88 cycles 22.249 ns - 13 cycles 3.420 ns - 20 cycles 5.166 ns 34 - 88 cycles 22.224 ns - 14 cycles 3.643 ns - 20 cycles 5.170 ns 48 - 88 cycles 22.088 ns - 14 cycles 3.507 ns - 20 cycles 5.203 ns 64 - 88 cycles 22.063 ns - 13 cycles 3.428 ns - 20 cycles 5.152 ns 128 - 89 cycles 22.483 ns - 15 cycles 3.891 ns - 23 cycles 5.885 ns 158 - 89 cycles 22.381 ns - 15 cycles 3.779 ns - 22 cycles 5.548 ns 250 - 91 cycles 22.798 ns - 16 cycles 4.152 ns - 23 cycles 5.967 ns SLAB when enabling MEMCG_KMEM runtime: - kmemcg fastpath: 130 cycles(tsc) 32.684 ns (step:0) 1 - 148 cycles 37.220 ns - 66 cycles 16.622 ns - 66 cycles 16.583 ns 2 - 141 cycles 35.510 ns - 51 cycles 12.820 ns - 58 cycles 14.625 ns 3 - 140 cycles 35.017 ns - 37 cycles 9.326 ns - 33 cycles 8.474 ns 4 - 137 cycles 34.507 ns - 31 cycles 7.888 ns - 33 cycles 8.300 ns 8 - 140 cycles 35.069 ns - 25 cycles 6.461 ns - 25 cycles 6.436 ns 16 - 138 cycles 34.542 ns - 23 cycles 5.945 ns - 22 cycles 5.670 ns 30 - 136 cycles 34.227 ns - 22 cycles 5.502 ns - 22 cycles 5.587 ns 32 - 136 cycles 34.253 ns - 21 cycles 5.475 ns - 21 cycles 5.324 ns 34 - 136 cycles 34.254 ns - 21 cycles 5.448 ns - 20 cycles 5.194 ns 48 - 136 cycles 34.075 ns - 21 cycles 5.458 ns - 21 cycles 5.367 ns 64 - 135 cycles 33.994 ns - 21 cycles 5.350 ns - 21 cycles 5.259 ns 128 - 137 cycles 34.446 ns - 23 cycles 5.816 ns - 22 cycles 5.688 ns 158 - 137 cycles 34.379 ns - 22 cycles 5.727 ns - 22 cycles 5.602 ns 250 - 138 cycles 34.755 ns - 24 cycles 6.093 ns - 23 cycles 5.986 ns Code size increase for SLUB: function old new delta kmem_cache_free_bulk 717 799 +82 SLUB benchmark: SLUB fastpath: 46 cycles(tsc) 11.691 ns (step:0) sz - fallback - kmem_cache_free_bulk - kfree_bulk 1 - 61 cycles 15.486 ns - 53 cycles 13.364 ns - 57 cycles 14.464 ns 2 - 54 cycles 13.703 ns - 32 cycles 8.110 ns - 33 cycles 8.482 ns 3 - 53 cycles 13.272 ns - 25 cycles 6.362 ns - 27 cycles 6.947 ns 4 - 51 cycles 12.994 ns - 24 cycles 6.087 ns - 24 cycles 6.078 ns 8 - 50 cycles 12.576 ns - 21 cycles 5.354 ns - 22 cycles 5.513 ns 16 - 49 cycles 12.368 ns - 20 cycles 5.054 ns - 20 cycles 5.042 ns 30 - 49 cycles 12.273 ns - 18 cycles 4.748 ns - 19 cycles 4.758 ns 32 - 49 cycles 12.401 ns - 19 cycles 4.821 ns - 19 cycles 4.810 ns 34 - 98 cycles 24.519 ns - 24 cycles 6.154 ns - 24 cycles 6.157 ns 48 - 83 cycles 20.833 ns - 21 cycles 5.446 ns - 21 cycles 5.429 ns 64 - 75 cycles 18.891 ns - 20 cycles 5.247 ns - 20 cycles 5.238 ns 128 - 93 cycles 23.271 ns - 27 cycles 6.856 ns - 27 cycles 6.823 ns 158 - 102 cycles 25.581 ns - 30 cycles 7.714 ns - 30 cycles 7.695 ns 250 - 107 cycles 26.917 ns - 38 cycles 9.514 ns - 38 cycles 9.506 ns SLUB when enabling MEMCG_KMEM runtime: - kmemcg fastpath: 71 cycles(tsc) 17.897 ns (step:0) 1 - 85 cycles 21.484 ns - 78 cycles 19.569 ns - 75 cycles 18.938 ns 2 - 81 cycles 20.363 ns - 45 cycles 11.258 ns - 44 cycles 11.076 ns 3 - 78 cycles 19.709 ns - 33 cycles 8.354 ns - 32 cycles 8.044 ns 4 - 77 cycles 19.430 ns - 28 cycles 7.216 ns - 28 cycles 7.003 ns 8 - 101 cycles 25.288 ns - 23 cycles 5.849 ns - 23 cycles 5.787 ns 16 - 76 cycles 19.148 ns - 20 cycles 5.162 ns - 20 cycles 5.081 ns 30 - 76 cycles 19.067 ns - 19 cycles 4.868 ns - 19 cycles 4.821 ns 32 - 76 cycles 19.052 ns - 19 cycles 4.857 ns - 19 cycles 4.815 ns 34 - 121 cycles 30.291 ns - 25 cycles 6.333 ns - 25 cycles 6.268 ns 48 - 108 cycles 27.111 ns - 21 cycles 5.498 ns - 21 cycles 5.458 ns 64 - 100 cycles 25.164 ns - 20 cycles 5.242 ns - 20 cycles 5.229 ns 128 - 155 cycles 38.976 ns - 27 cycles 6.886 ns - 27 cycles 6.892 ns 158 - 132 cycles 33.034 ns - 30 cycles 7.711 ns - 30 cycles 7.728 ns 250 - 130 cycles 32.612 ns - 38 cycles 9.560 ns - 38 cycles 9.549 ns Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Vladimir Davydov <vdavydov@virtuozzo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-15mm/slab: move SLUB alloc hooks to common mm/slab.hJesper Dangaard Brouer
First step towards sharing alloc_hook's between SLUB and SLAB allocators. Move the SLUB allocators *_alloc_hook to the common mm/slab.h for internal slab definitions. Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Vladimir Davydov <vdavydov@virtuozzo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-15slub: clean up code for kmem cgroup support to kmem_cache_free_bulkJesper Dangaard Brouer
This change is primarily an attempt to make it easier to realize the optimizations the compiler performs in-case CONFIG_MEMCG_KMEM is not enabled. Performance wise, even when CONFIG_MEMCG_KMEM is compiled in, the overhead is zero. This is because, as long as no process have enabled kmem cgroups accounting, the assignment is replaced by asm-NOP operations. This is possible because memcg_kmem_enabled() uses a static_key_false() construct. It also helps readability as it avoid accessing the p[] array like: p[size - 1] which "expose" that the array is processed backwards inside helper function build_detached_freelist(). Lastly this also makes the code more robust, in error case like passing NULL pointers in the array. Which were previously handled before commit 033745189b1b ("slub: add missing kmem cgroup support to kmem_cache_free_bulk"). Fixes: 033745189b1b ("slub: add missing kmem cgroup support to kmem_cache_free_bulk") Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Vladimir Davydov <vdavydov@virtuozzo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-02-18mm: slab: free kmem_cache_node after destroy sysfs fileDmitry Safonov
When slub_debug alloc_calls_show is enabled we will try to track location and user of slab object on each online node, kmem_cache_node structure and cpu_cache/cpu_slub shouldn't be freed till there is the last reference to sysfs file. This fixes the following panic: BUG: unable to handle kernel NULL pointer dereference at 0000000000000020 IP: list_locations+0x169/0x4e0 PGD 257304067 PUD 438456067 PMD 0 Oops: 0000 [#1] SMP CPU: 3 PID: 973074 Comm: cat ve: 0 Not tainted 3.10.0-229.7.2.ovz.9.30-00007-japdoll-dirty #2 9.30 Hardware name: DEPO Computers To Be Filled By O.E.M./H67DE3, BIOS L1.60c 07/14/2011 task: ffff88042a5dc5b0 ti: ffff88037f8d8000 task.ti: ffff88037f8d8000 RIP: list_locations+0x169/0x4e0 Call Trace: alloc_calls_show+0x1d/0x30 slab_attr_show+0x1b/0x30 sysfs_read_file+0x9a/0x1a0 vfs_read+0x9c/0x170 SyS_read+0x58/0xb0 system_call_fastpath+0x16/0x1b Code: 5e 07 12 00 b9 00 04 00 00 3d 00 04 00 00 0f 4f c1 3d 00 04 00 00 89 45 b0 0f 84 c3 00 00 00 48 63 45 b0 49 8b 9c c4 f8 00 00 00 <48> 8b 43 20 48 85 c0 74 b6 48 89 df e8 46 37 44 00 48 8b 53 10 CR2: 0000000000000020 Separated __kmem_cache_release from __kmem_cache_shutdown which now called on slab_kmem_cache_release (after the last reference to sysfs file object has dropped). Reintroduced locking in free_partial as sysfs file might access cache's partial list after shutdowning - partial revert of the commit 69cb8e6b7c29 ("slub: free slabs without holding locks"). Zap __remove_partial and use remove_partial (w/o underscores) as free_partial now takes list_lock which s partial revert for commit 1e4dd9461fab ("slub: do not assert not having lock in removing freed partial") Signed-off-by: Dmitry Safonov <dsafonov@virtuozzo.com> Suggested-by: Vladimir Davydov <vdavydov@virtuozzo.com> Acked-by: Vladimir Davydov <vdavydov@virtuozzo.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-20mm: memcontrol: move kmem accounting code to CONFIG_MEMCGJohannes Weiner
The cgroup2 memory controller will account important in-kernel memory consumers per default. Move all necessary components to CONFIG_MEMCG. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Vladimir Davydov <vdavydov@virtuozzo.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-15page-flags: define PG_locked behavior on compound pagesKirill A. Shutemov
lock_page() must operate on the whole compound page. It doesn't make much sense to lock part of compound page. Change code to use head page's PG_locked, if tail page is passed. This patch also gets rid of custom helper functions -- __set_page_locked() and __clear_page_locked(). They are replaced with helpers generated by __SETPAGEFLAG/__CLEARPAGEFLAG. Tail pages to these helper would trigger VM_BUG_ON(). SLUB uses PG_locked as a bit spin locked. IIUC, tail pages should never appear there. VM_BUG_ON() is added to make sure that this assumption is correct. [akpm@linux-foundation.org: fix fs/cifs/file.c] Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Christoph Lameter <cl@linux.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Steve Capper <steve.capper@linaro.org> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Jerome Marchand <jmarchan@redhat.com> Cc: Jérôme Glisse <jglisse@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-14slab: add SLAB_ACCOUNT flagVladimir Davydov
Currently, if we want to account all objects of a particular kmem cache, we have to pass __GFP_ACCOUNT to each kmem_cache_alloc call, which is inconvenient. This patch introduces SLAB_ACCOUNT flag which if passed to kmem_cache_create will force accounting for every allocation from this cache even if __GFP_ACCOUNT is not passed. This patch does not make any of the existing caches use this flag - it will be done later in the series. Note, a cache with SLAB_ACCOUNT cannot be merged with a cache w/o SLAB_ACCOUNT, because merged caches share the same kmem_cache struct and hence cannot have different sets of SLAB_* flags. Thus using this flag will probably reduce the number of merged slabs even if kmem accounting is not used (only compiled in). Signed-off-by: Vladimir Davydov <vdavydov@virtuozzo.com> Suggested-by: Tejun Heo <tj@kernel.org> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Greg Thelen <gthelen@google.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-22slab/slub: adjust kmem_cache_alloc_bulk APIJesper Dangaard Brouer
Adjust kmem_cache_alloc_bulk API before we have any real users. Adjust API to return type 'int' instead of previously type 'bool'. This is done to allow future extension of the bulk alloc API. A future extension could be to allow SLUB to stop at a page boundary, when specified by a flag, and then return the number of objects. The advantage of this approach, would make it easier to make bulk alloc run without local IRQs disabled. With an approach of cmpxchg "stealing" the entire c->freelist or page->freelist. To avoid overshooting we would stop processing at a slab-page boundary. Else we always end up returning some objects at the cost of another cmpxchg. To keep compatible with future users of this API linking against an older kernel when using the new flag, we need to return the number of allocated objects with this API change. Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com> Cc: Vladimir Davydov <vdavydov@virtuozzo.com> Acked-by: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-22slub: add missing kmem cgroup support to kmem_cache_free_bulkJesper Dangaard Brouer
Initial implementation missed support for kmem cgroup support in kmem_cache_free_bulk() call, add this. If CONFIG_MEMCG_KMEM is not enabled, the compiler should be smart enough to not add any asm code. Incoming bulk free objects can belong to different kmem cgroups, and object free call can happen at a later point outside memcg context. Thus, we need to keep the orig kmem_cache, to correctly verify if a memcg object match against its "root_cache" (s->memcg_params.root_cache). Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com> Reviewed-by: Vladimir Davydov <vdavydov@virtuozzo.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-22slub: fix kmem cgroup bug in kmem_cache_alloc_bulkJesper Dangaard Brouer
The call slab_pre_alloc_hook() interacts with kmemgc and is not allowed to be called several times inside the bulk alloc for loop, due to the call to memcg_kmem_get_cache(). This would result in hitting the VM_BUG_ON in __memcg_kmem_get_cache. As suggested by Vladimir Davydov, change slab_post_alloc_hook() to be able to handle an array of objects. A subtle detail is, loop iterator "i" in slab_post_alloc_hook() must have same type (size_t) as size argument. This helps the compiler to easier realize that it can remove the loop, when all debug statements inside loop evaluates to nothing. Note, this is only an issue because the kernel is compiled with GCC option: -fno-strict-overflow In slab_alloc_node() the compiler inlines and optimizes the invocation of slab_post_alloc_hook(s, flags, 1, &object) by removing the loop and access object directly. Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com> Reported-by: Vladimir Davydov <vdavydov@virtuozzo.com> Suggested-by: Vladimir Davydov <vdavydov@virtuozzo.com> Reviewed-by: Vladimir Davydov <vdavydov@virtuozzo.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-22slub: optimize bulk slowpath free by detached freelistJesper Dangaard Brouer
This change focus on improving the speed of object freeing in the "slowpath" of kmem_cache_free_bulk. The calls slab_free (fastpath) and __slab_free (slowpath) have been extended with support for bulk free, which amortize the overhead of the (locked) cmpxchg_double. To use the new bulking feature, we build what I call a detached freelist. The detached freelist takes advantage of three properties: 1) the free function call owns the object that is about to be freed, thus writing into this memory is synchronization-free. 2) many freelist's can co-exist side-by-side in the same slab-page each with a separate head pointer. 3) it is the visibility of the head pointer that needs synchronization. Given these properties, the brilliant part is that the detached freelist can be constructed without any need for synchronization. The freelist is constructed directly in the page objects, without any synchronization needed. The detached freelist is allocated on the stack of the function call kmem_cache_free_bulk. Thus, the freelist head pointer is not visible to other CPUs. All objects in a SLUB freelist must belong to the same slab-page. Thus, constructing the detached freelist is about matching objects that belong to the same slab-page. The bulk free array is scanned is a progressive manor with a limited look-ahead facility. Kmem debug support is handled in call of slab_free(). Notice kmem_cache_free_bulk no longer need to disable IRQs. This only slowed down single free bulk with approx 3 cycles. Performance data: Benchmarked[1] obj size 256 bytes on CPU i7-4790K @ 4.00GHz SLUB fastpath single object quick reuse: 47 cycles(tsc) 11.931 ns To get stable and comparable numbers, the kernel have been booted with "slab_merge" (this also improve performance for larger bulk sizes). Performance data, compared against fallback bulking: bulk - fallback bulk - improvement with this patch 1 - 62 cycles(tsc) 15.662 ns - 49 cycles(tsc) 12.407 ns- improved 21.0% 2 - 55 cycles(tsc) 13.935 ns - 30 cycles(tsc) 7.506 ns - improved 45.5% 3 - 53 cycles(tsc) 13.341 ns - 23 cycles(tsc) 5.865 ns - improved 56.6% 4 - 52 cycles(tsc) 13.081 ns - 20 cycles(tsc) 5.048 ns - improved 61.5% 8 - 50 cycles(tsc) 12.627 ns - 18 cycles(tsc) 4.659 ns - improved 64.0% 16 - 49 cycles(tsc) 12.412 ns - 17 cycles(tsc) 4.495 ns - improved 65.3% 30 - 49 cycles(tsc) 12.484 ns - 18 cycles(tsc) 4.533 ns - improved 63.3% 32 - 50 cycles(tsc) 12.627 ns - 18 cycles(tsc) 4.707 ns - improved 64.0% 34 - 96 cycles(tsc) 24.243 ns - 23 cycles(tsc) 5.976 ns - improved 76.0% 48 - 83 cycles(tsc) 20.818 ns - 21 cycles(tsc) 5.329 ns - improved 74.7% 64 - 74 cycles(tsc) 18.700 ns - 20 cycles(tsc) 5.127 ns - improved 73.0% 128 - 90 cycles(tsc) 22.734 ns - 27 cycles(tsc) 6.833 ns - improved 70.0% 158 - 99 cycles(tsc) 24.776 ns - 30 cycles(tsc) 7.583 ns - improved 69.7% 250 - 104 cycles(tsc) 26.089 ns - 37 cycles(tsc) 9.280 ns - improved 64.4% Performance data, compared current in-kernel bulking: bulk - curr in-kernel - improvement with this patch 1 - 46 cycles(tsc) - 49 cycles(tsc) - improved (cycles:-3) -6.5% 2 - 27 cycles(tsc) - 30 cycles(tsc) - improved (cycles:-3) -11.1% 3 - 21 cycles(tsc) - 23 cycles(tsc) - improved (cycles:-2) -9.5% 4 - 18 cycles(tsc) - 20 cycles(tsc) - improved (cycles:-2) -11.1% 8 - 17 cycles(tsc) - 18 cycles(tsc) - improved (cycles:-1) -5.9% 16 - 18 cycles(tsc) - 17 cycles(tsc) - improved (cycles: 1) 5.6% 30 - 18 cycles(tsc) - 18 cycles(tsc) - improved (cycles: 0) 0.0% 32 - 18 cycles(tsc) - 18 cycles(tsc) - improved (cycles: 0) 0.0% 34 - 78 cycles(tsc) - 23 cycles(tsc) - improved (cycles:55) 70.5% 48 - 60 cycles(tsc) - 21 cycles(tsc) - improved (cycles:39) 65.0% 64 - 49 cycles(tsc) - 20 cycles(tsc) - improved (cycles:29) 59.2% 128 - 69 cycles(tsc) - 27 cycles(tsc) - improved (cycles:42) 60.9% 158 - 79 cycles(tsc) - 30 cycles(tsc) - improved (cycles:49) 62.0% 250 - 86 cycles(tsc) - 37 cycles(tsc) - improved (cycles:49) 57.0% Performance with normal SLUB merging is significantly slower for larger bulking. This is believed to (primarily) be an effect of not having to share the per-CPU data-structures, as tuning per-CPU size can achieve similar performance. bulk - slab_nomerge - normal SLUB merge 1 - 49 cycles(tsc) - 49 cycles(tsc) - merge slower with cycles:0 2 - 30 cycles(tsc) - 30 cycles(tsc) - merge slower with cycles:0 3 - 23 cycles(tsc) - 23 cycles(tsc) - merge slower with cycles:0 4 - 20 cycles(tsc) - 20 cycles(tsc) - merge slower with cycles:0 8 - 18 cycles(tsc) - 18 cycles(tsc) - merge slower with cycles:0 16 - 17 cycles(tsc) - 17 cycles(tsc) - merge slower with cycles:0 30 - 18 cycles(tsc) - 23 cycles(tsc) - merge slower with cycles:5 32 - 18 cycles(tsc) - 22 cycles(tsc) - merge slower with cycles:4 34 - 23 cycles(tsc) - 22 cycles(tsc) - merge slower with cycles:-1 48 - 21 cycles(tsc) - 22 cycles(tsc) - merge slower with cycles:1 64 - 20 cycles(tsc) - 48 cycles(tsc) - merge slower with cycles:28 128 - 27 cycles(tsc) - 57 cycles(tsc) - merge slower with cycles:30 158 - 30 cycles(tsc) - 59 cycles(tsc) - merge slower with cycles:29 250 - 37 cycles(tsc) - 56 cycles(tsc) - merge slower with cycles:19 Joint work with Alexander Duyck. [1] https://github.com/netoptimizer/prototype-kernel/blob/master/kernel/mm/slab_bulk_test01.c [akpm@linux-foundation.org: BUG_ON -> WARN_ON;return] Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com> Signed-off-by: Alexander Duyck <alexander.h.duyck@redhat.com> Acked-by: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
