path: root/mm/slab.h
2013-08-28memcg: check that kmem_cache has memcg_params before accessing itAndrey Vagin
If the system had a few memory groups and all of them were destroyed, memcg_limited_groups_array_size has non-zero value, but all new caches are created without memcg_params, because memcg_kmem_enabled() returns false. We try to enumirate child caches in a few places and all of them are potentially dangerous. For example my kernel is compiled with CONFIG_SLAB and it crashed when I tryed to mount a NFS share after a few experiments with kmemcg. BUG: unable to handle kernel NULL pointer dereference at 0000000000000008 IP: [<ffffffff8118166a>] do_tune_cpucache+0x8a/0xd0 PGD b942a067 PUD b999f067 PMD 0 Oops: 0000 [#1] SMP Modules linked in: fscache(+) ip6table_filter ip6_tables iptable_filter ip_tables i2c_piix4 pcspkr virtio_net virtio_balloon i2c_core floppy CPU: 0 PID: 357 Comm: modprobe Not tainted 3.11.0-rc7+ #59 Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011 task: ffff8800b9f98240 ti: ffff8800ba32e000 task.ti: ffff8800ba32e000 RIP: 0010:[<ffffffff8118166a>] [<ffffffff8118166a>] do_tune_cpucache+0x8a/0xd0 RSP: 0018:ffff8800ba32fb70 EFLAGS: 00010246 RAX: 0000000000000000 RBX: 0000000000000000 RCX: 0000000000000006 RDX: 0000000000000000 RSI: ffff8800b9f98910 RDI: 0000000000000246 RBP: ffff8800ba32fba0 R08: 0000000000000002 R09: 0000000000000004 R10: 0000000000000001 R11: 0000000000000001 R12: 0000000000000010 R13: 0000000000000008 R14: 00000000000000d0 R15: ffff8800375d0200 FS: 00007f55f1378740(0000) GS:ffff8800bfa00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 00007f24feba57a0 CR3: 0000000037b51000 CR4: 00000000000006f0 Call Trace: enable_cpucache+0x49/0x100 setup_cpu_cache+0x215/0x280 __kmem_cache_create+0x2fa/0x450 kmem_cache_create_memcg+0x214/0x350 kmem_cache_create+0x2b/0x30 fscache_init+0x19b/0x230 [fscache] do_one_initcall+0xfa/0x1b0 load_module+0x1c41/0x26d0 SyS_finit_module+0x86/0xb0 system_call_fastpath+0x16/0x1b Signed-off-by: Andrey Vagin <avagin@openvz.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Christoph Lameter <cl@linux.com> Cc: Glauber Costa <glommer@openvz.org> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-08mm/slab: Give s_next and s_stop slab-specific namesWanpeng Li
Give s_next and s_stop slab-specific names instead of exporting "s_next" and "s_stop". Signed-off-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2013-07-07mm/slab: Sharing s_next and s_stop between slab and slubWanpeng Li
This patch shares s_next and s_stop between slab and slub. Acked-by: Christoph Lameter <cl@linux.com> Signed-off-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2013-02-01slab: Common definition for kmem_cache_nodeChristoph Lameter
Put the definitions for the kmem_cache_node structures together so that we have one structure. That will allow us to create more common fields in the future which could yield more opportunities to share code. Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2013-02-01slab: Rename list3/l3 to nodeChristoph Lameter
The list3 or l3 pointers are pointing to per node structures. Reflect that in the names of variables used. Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2013-02-01slab: Common Kmalloc cache determinationChristoph Lameter
Extract the optimized lookup functions from slub and put them into slab_common.c. Then make slab use these functions as well. Joonsoo notes that this fixes some issues with constant folding which also reduces the code size for slub. https://lkml.org/lkml/2012/10/20/82 Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2013-02-01slab: Common function to create the kmalloc arrayChristoph Lameter
The kmalloc array is created in similar ways in both SLAB and SLUB. Create a common function and have both allocators call that function. V1->V2: Whitespace cleanup Reviewed-by: Glauber Costa <glommer@parallels.com> Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2012-12-18slab: propagate tunable valuesGlauber Costa
SLAB allows us to tune a particular cache behavior with tunables. When creating a new memcg cache copy, we'd like to preserve any tunables the parent cache already had. This could be done by an explicit call to do_tune_cpucache() after the cache is created. But this is not very convenient now that the caches are created from common code, since this function is SLAB-specific. Another method of doing that is taking advantage of the fact that do_tune_cpucache() is always called from enable_cpucache(), which is called at cache initialization. We can just preset the values, and then things work as expected. It can also happen that a root cache has its tunables updated during normal system operation. In this case, we will propagate the change to all caches that are already active. This change will require us to move the assignment of root_cache in memcg_params a bit earlier. We need this to be already set - which memcg_kmem_register_cache will do - when we reach __kmem_cache_create() Signed-off-by: Glauber Costa <glommer@parallels.com> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Frederic Weisbecker <fweisbec@redhat.com> Cc: Greg Thelen <gthelen@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: JoonSoo Kim <js1304@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Michal Hocko <mhocko@suse.cz> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Rik van Riel <riel@redhat.com> Cc: Suleiman Souhlal <suleiman@google.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-18memcg: aggregate memcg cache values in slabinfoGlauber Costa
When we create caches in memcgs, we need to display their usage information somewhere. We'll adopt a scheme similar to /proc/meminfo, with aggregate totals shown in the global file, and per-group information stored in the group itself. For the time being, only reads are allowed in the per-group cache. Signed-off-by: Glauber Costa <glommer@parallels.com> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Frederic Weisbecker <fweisbec@redhat.com> Cc: Greg Thelen <gthelen@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: JoonSoo Kim <js1304@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Michal Hocko <mhocko@suse.cz> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Rik van Riel <riel@redhat.com> Cc: Suleiman Souhlal <suleiman@google.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-18memcg: destroy memcg cachesGlauber Costa
Implement destruction of memcg caches. Right now, only caches where our reference counter is the last remaining are deleted. If there are any other reference counters around, we just leave the caches lying around until they go away. When that happens, a destruction function is called from the cache code. Caches are only destroyed in process context, so we queue them up for later processing in the general case. Signed-off-by: Glauber Costa <glommer@parallels.com> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Frederic Weisbecker <fweisbec@redhat.com> Cc: Greg Thelen <gthelen@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: JoonSoo Kim <js1304@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Michal Hocko <mhocko@suse.cz> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Rik van Riel <riel@redhat.com> Cc: Suleiman Souhlal <suleiman@google.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-18sl[au]b: always get the cache from its page in kmem_cache_free()Glauber Costa
struct page already has this information. If we start chaining caches, this information will always be more trustworthy than whatever is passed into the function. Signed-off-by: Glauber Costa <glommer@parallels.com> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Frederic Weisbecker <fweisbec@redhat.com> Cc: Greg Thelen <gthelen@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: JoonSoo Kim <js1304@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Michal Hocko <mhocko@suse.cz> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Rik van Riel <riel@redhat.com> Cc: Suleiman Souhlal <suleiman@google.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-18slab/slub: consider a memcg parameter in kmem_create_cacheGlauber Costa
Allow a memcg parameter to be passed during cache creation. When the slub allocator is being used, it will only merge caches that belong to the same memcg. We'll do this by scanning the global list, and then translating the cache to a memcg-specific cache Default function is created as a wrapper, passing NULL to the memcg version. We only merge caches that belong to the same memcg. A helper is provided, memcg_css_id: because slub needs a unique cache name for sysfs. Since this is visible, but not the canonical location for slab data, the cache name is not used, the css_id should suffice. Signed-off-by: Glauber Costa <glommer@parallels.com> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Frederic Weisbecker <fweisbec@redhat.com> Cc: Greg Thelen <gthelen@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: JoonSoo Kim <js1304@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Michal Hocko <mhocko@suse.cz> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Rik van Riel <riel@redhat.com> Cc: Suleiman Souhlal <suleiman@google.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-18slab/slub: struct memcg_paramsGlauber Costa
For the kmem slab controller, we need to record some extra information in the kmem_cache structure. Signed-off-by: Glauber Costa <glommer@parallels.com> Signed-off-by: Suleiman Souhlal <suleiman@google.com> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Frederic Weisbecker <fweisbec@redhat.com> Cc: Greg Thelen <gthelen@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: JoonSoo Kim <js1304@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Michal Hocko <mhocko@suse.cz> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Rik van Riel <riel@redhat.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-11mm/sl[aou]b: Common alignment codeChristoph Lameter
Extract the code to do object alignment from the allocators. Do the alignment calculations in slab_common so that the __kmem_cache_create functions of the allocators do not have to deal with alignment. Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2012-12-11mm, sl[au]b: create common functions for boot slab creationChristoph Lameter
Use a special function to create kmalloc caches and use that function in SLAB and SLUB. Acked-by: Joonsoo Kim <js1304@gmail.com> Reviewed-by: Glauber Costa <glommer@parallels.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2012-10-31slab: Ignore internal flags in cache creationGlauber Costa
Some flags are used internally by the allocators for management purposes. One example of that is the CFLGS_OFF_SLAB flag that slab uses to mark that the metadata for that cache is stored outside of the slab. No cache should ever pass those as a creation flags. We can just ignore this bit if it happens to be passed (such as when duplicating a cache in the kmem memcg patches). Because such flags can vary from allocator to allocator, we allow them to make their own decisions on that, defining SLAB_AVAILABLE_FLAGS with all flags that are valid at creation time. Allocators that doesn't have any specific flag requirement should define that to mean all flags. Common code will mask out all flags not belonging to that set. Acked-by: Christoph Lameter <cl@linux.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Glauber Costa <glommer@parallels.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2012-10-24sl[au]b: Process slabinfo_show in common codeGlauber Costa
With all the infrastructure in place, we can now have slabinfo_show done from slab_common.c. A cache-specific function is called to grab information about the cache itself, since that is still heavily dependent on the implementation. But with the values produced by it, all the printing and handling is done from common code. Signed-off-by: Glauber Costa <glommer@parallels.com> CC: Christoph Lameter <cl@linux.com> CC: David Rientjes <rientjes@google.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2012-10-24mm/sl[au]b: Move print_slabinfo_header to slab_common.cGlauber Costa
The header format is highly similar between slab and slub. The main difference lays in the fact that slab may optionally have statistics added here in case of CONFIG_SLAB_DEBUG, while the slub will stick them somewhere else. By making sure that information conditionally lives inside a globally-visible CONFIG_DEBUG_SLAB switch, we can move the header printing to a common location. Signed-off-by: Glauber Costa <glommer@parallels.com> Acked-by: Christoph Lameter <cl@linux.com> CC: David Rientjes <rientjes@google.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2012-10-24mm/sl[au]b: Move slabinfo processing to slab_common.cGlauber Costa
This patch moves all the common machinery to slabinfo processing to slab_common.c. We can do better by noticing that the output is heavily common, and having the allocators to just provide finished information about this. But after this first step, this can be done easier. Signed-off-by: Glauber Costa <glommer@parallels.com> Acked-by: Christoph Lameter <cl@linux.com> CC: David Rientjes <rientjes@google.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2012-09-05Revert "mm/sl[aou]b: Move sysfs_slab_add to common"Pekka Enberg
This reverts commit 96d17b7be0a9849d381442030886211dbb2a7061 which caused the following errors at boot: [ 1.114885] kobject (ffff88001a802578): tried to init an initialized object, something is seriously wrong. [ 1.114885] Pid: 1, comm: swapper/0 Tainted: G W 3.6.0-rc1+ #6 [ 1.114885] Call Trace: [ 1.114885] [<ffffffff81273f37>] kobject_init+0x87/0xa0 [ 1.115555] [<ffffffff8127426a>] kobject_init_and_add+0x2a/0x90 [ 1.115555] [<ffffffff8127c870>] ? sprintf+0x40/0x50 [ 1.115555] [<ffffffff81124c60>] sysfs_slab_add+0x80/0x210 [ 1.115555] [<ffffffff81100175>] kmem_cache_create+0xa5/0x250 [ 1.115555] [<ffffffff81cf24cd>] ? md_init+0x144/0x144 [ 1.115555] [<ffffffff81cf25b6>] local_init+0xa4/0x11b [ 1.115555] [<ffffffff81cf24e1>] dm_init+0x14/0x45 [ 1.115836] [<ffffffff810001ba>] do_one_initcall+0x3a/0x160 [ 1.116834] [<ffffffff81cc2c90>] kernel_init+0x133/0x1b7 [ 1.117835] [<ffffffff81cc25c4>] ? do_early_param+0x86/0x86 [ 1.117835] [<ffffffff8171aff4>] kernel_thread_helper+0x4/0x10 [ 1.118401] [<ffffffff81cc2b5d>] ? start_kernel+0x33f/0x33f [ 1.119832] [<ffffffff8171aff0>] ? gs_change+0xb/0xb [ 1.120325] ------------[ cut here ]------------ [ 1.120835] WARNING: at fs/sysfs/dir.c:536 sysfs_add_one+0xc1/0xf0() [ 1.121437] sysfs: cannot create duplicate filename '/kernel/slab/:t-0000016' [ 1.121831] Modules linked in: [ 1.122138] Pid: 1, comm: swapper/0 Tainted: G W 3.6.0-rc1+ #6 [ 1.122831] Call Trace: [ 1.123074] [<ffffffff81195ce1>] ? sysfs_add_one+0xc1/0xf0 [ 1.123833] [<ffffffff8103adfa>] warn_slowpath_common+0x7a/0xb0 [ 1.124405] [<ffffffff8103aed1>] warn_slowpath_fmt+0x41/0x50 [ 1.124832] [<ffffffff81195ce1>] sysfs_add_one+0xc1/0xf0 [ 1.125337] [<ffffffff81195eb3>] create_dir+0x73/0xd0 [ 1.125832] [<ffffffff81196221>] sysfs_create_dir+0x81/0xe0 [ 1.126363] [<ffffffff81273d3d>] kobject_add_internal+0x9d/0x210 [ 1.126832] [<ffffffff812742a3>] kobject_init_and_add+0x63/0x90 [ 1.127406] [<ffffffff81124c60>] sysfs_slab_add+0x80/0x210 [ 1.127832] [<ffffffff81100175>] kmem_cache_create+0xa5/0x250 [ 1.128384] [<ffffffff81cf24cd>] ? md_init+0x144/0x144 [ 1.128833] [<ffffffff81cf25b6>] local_init+0xa4/0x11b [ 1.129831] [<ffffffff81cf24e1>] dm_init+0x14/0x45 [ 1.130305] [<ffffffff810001ba>] do_one_initcall+0x3a/0x160 [ 1.130831] [<ffffffff81cc2c90>] kernel_init+0x133/0x1b7 [ 1.131351] [<ffffffff81cc25c4>] ? do_early_param+0x86/0x86 [ 1.131830] [<ffffffff8171aff4>] kernel_thread_helper+0x4/0x10 [ 1.132392] [<ffffffff81cc2b5d>] ? start_kernel+0x33f/0x33f [ 1.132830] [<ffffffff8171aff0>] ? gs_change+0xb/0xb [ 1.133315] ---[ end trace 2703540871c8fab7 ]--- [ 1.133830] ------------[ cut here ]------------ [ 1.134274] WARNING: at lib/kobject.c:196 kobject_add_internal+0x1f5/0x210() [ 1.134829] kobject_add_internal failed for :t-0000016 with -EEXIST, don't try to register things with the same name in the same directory. [ 1.135829] Modules linked in: [ 1.136135] Pid: 1, comm: swapper/0 Tainted: G W 3.6.0-rc1+ #6 [ 1.136828] Call Trace: [ 1.137071] [<ffffffff81273e95>] ? kobject_add_internal+0x1f5/0x210 [ 1.137830] [<ffffffff8103adfa>] warn_slowpath_common+0x7a/0xb0 [ 1.138402] [<ffffffff8103aed1>] warn_slowpath_fmt+0x41/0x50 [ 1.138830] [<ffffffff811955a3>] ? release_sysfs_dirent+0x73/0xf0 [ 1.139419] [<ffffffff81273e95>] kobject_add_internal+0x1f5/0x210 [ 1.139830] [<ffffffff812742a3>] kobject_init_and_add+0x63/0x90 [ 1.140429] [<ffffffff81124c60>] sysfs_slab_add+0x80/0x210 [ 1.140830] [<ffffffff81100175>] kmem_cache_create+0xa5/0x250 [ 1.141829] [<ffffffff81cf24cd>] ? md_init+0x144/0x144 [ 1.142307] [<ffffffff81cf25b6>] local_init+0xa4/0x11b [ 1.142829] [<ffffffff81cf24e1>] dm_init+0x14/0x45 [ 1.143307] [<ffffffff810001ba>] do_one_initcall+0x3a/0x160 [ 1.143829] [<ffffffff81cc2c90>] kernel_init+0x133/0x1b7 [ 1.144352] [<ffffffff81cc25c4>] ? do_early_param+0x86/0x86 [ 1.144829] [<ffffffff8171aff4>] kernel_thread_helper+0x4/0x10 [ 1.145405] [<ffffffff81cc2b5d>] ? start_kernel+0x33f/0x33f [ 1.145828] [<ffffffff8171aff0>] ? gs_change+0xb/0xb [ 1.146313] ---[ end trace 2703540871c8fab8 ]--- Conflicts: mm/slub.c Signed-off-by: Pekka Enberg <penberg@kernel.org>
2012-09-05mm/sl[aou]b: Shrink __kmem_cache_create() parameter listsChristoph Lameter
Do the initial settings of the fields in common code. This will allow us to push more processing into common code later and improve readability. Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2012-09-05mm/sl[aou]b: Move kmem_cache allocations into common codeChristoph Lameter
Shift the allocations to common code. That way the allocation and freeing of the kmem_cache structures is handled by common code. Reviewed-by: Glauber Costa <glommer@parallels.com> Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2012-09-05mm/sl[aou]b: Move sysfs_slab_add to commonChristoph Lameter
Simplify locking by moving the slab_add_sysfs after all locks have been dropped. Eases the upcoming move to provide sysfs support for all allocators. Reviewed-by: Glauber Costa <glommer@parallels.com> Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2012-09-05mm/sl[aou]b: Do slab aliasing call from common codeChristoph Lameter
The slab aliasing logic causes some strange contortions in slub. So add a call to deal with aliases to slab_common.c but disable it for other slab allocators by providng stubs that fail to create aliases. Full general support for aliases will require additional cleanup passes and more standardization of fields in kmem_cache. Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2012-09-05mm/sl[aou]b: Get rid of __kmem_cache_destroyChristoph Lameter
What is done there can be done in __kmem_cache_shutdown. This affects RCU handling somewhat. On rcu free all slab allocators do not refer to other management structures than the kmem_cache structure. Therefore these other structures can be freed before the rcu deferred free to the page allocator occurs. Reviewed-by: Joonsoo Kim <js1304@gmail.com> Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2012-09-05mm/sl[aou]b: Use "kmem_cache" name for slab cache with kmem_cache structChristoph Lameter
Make all allocators use the "kmem_cache" slabname for the "kmem_cache" structure. Reviewed-by: Glauber Costa <glommer@parallels.com> Reviewed-by: Joonsoo Kim <js1304@gmail.com> Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2012-09-05mm/sl[aou]b: Extract a common function for kmem_cache_destroyChristoph Lameter
kmem_cache_destroy does basically the same in all allocators. Extract common code which is easy since we already have common mutex handling. Reviewed-by: Glauber Costa <glommer@parallels.com> Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2012-07-09mm, sl[aou]b: Use a common mutex definitionChristoph Lameter
Use the mutex definition from SLAB and make it the common way to take a sleeping lock. This has the effect of using a mutex instead of a rw semaphore for SLUB. SLOB gains the use of a mutex for kmem_cache_create serialization. Not needed now but SLOB may acquire some more features later (like slabinfo / sysfs support) through the expansion of the common code that will need this. Reviewed-by: Glauber Costa <glommer@parallels.com> Reviewed-by: Joonsoo Kim <js1304@gmail.com> Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2012-07-09mm, sl[aou]b: Common definition for boot state of the slab allocatorsChristoph Lameter
All allocators have some sort of support for the bootstrap status. Setup a common definition for the boot states and make all slab allocators use that definition. Reviewed-by: Glauber Costa <glommer@parallels.com> Reviewed-by: Joonsoo Kim <js1304@gmail.com> Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
