path: root/mm/page_alloc.c
2008-10-02mm: handle initialising compound pages at orders greater than MAX_ORDERAndy Whitcroft
When we initialise a compound page we initialise the page flags and head page pointer for all base pages spanned by that page. When we initialise a gigantic page (a page of order greater than or equal to MAX_ORDER) we have to initialise more than MAX_ORDER_NR_PAGES pages. Currently we assume that all elements of the mem_map in this page are contigious in memory. However this is only guarenteed out to MAX_ORDER_NR_PAGES pages, and with SPARSEMEM enabled they will not be contigious. This leads us to walk off the end of the first section and scribble on everything which follows, BAD. When we reach a MAX_ORDER_NR_PAGES boundary we much locate the next section of the mem_map. As gigantic pages can only be maximally aligned we know this will occur at exact multiple of MAX_ORDER_NR_PAGES pages from the start of the page. This is a bug fix for the gigantic page support in hugetlbfs. Credit to Mel Gorman for spotting the issue. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Jon Tollefson <kniht@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-02mm/bootmem: silence section mismatch warning - ↵Marcin Slusarz
contig_page_data/bootmem_node_data WARNING: vmlinux.o(.data+0x1f5c0): Section mismatch in reference from the variable contig_page_data to the variable .init.data:bootmem_node_data The variable contig_page_data references the variable __initdata bootmem_node_data If the reference is valid then annotate the variable with __init* (see linux/init.h) or name the variable: *driver, *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console, Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Johannes Weiner <hannes@saeurebad.de> Cc: Sean MacLennan <smaclennan@pikatech.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-02mm: make setup_zone_migrate_reserve() aware of overlapping nodesAdam Litke
I have gotten to the root cause of the hugetlb badness I reported back on August 15th. My system has the following memory topology (note the overlapping node): Node 0 Memory: 0x8000000-0x44000000 Node 1 Memory: 0x0-0x8000000 0x44000000-0x80000000 setup_zone_migrate_reserve() scans the address range 0x0-0x8000000 looking for a pageblock to move onto the MIGRATE_RESERVE list. Finding no candidates, it happily continues the scan into 0x8000000-0x44000000. When a pageblock is found, the pages are moved to the MIGRATE_RESERVE list on the wrong zone. Oops. setup_zone_migrate_reserve() should skip pageblocks in overlapping nodes. Signed-off-by: Adam Litke <agl@us.ibm.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Nishanth Aravamudan <nacc@us.ibm.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: <stable@kernel.org> [2.6.25.x, 2.6.26.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12page allocator: use no-panic variant of alloc_bootmem() in ↵Jan Beulich
alloc_large_system_hash() .. since a failed allocation is being (initially) handled gracefully, and panic()-ed upon failure explicitly in the function if retries with smaller sizes failed. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30mm: remove find_max_pfn_with_active_regionsYinghai Lu
It has no user now Also print out info about adding/removing active regions. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-28stop_machine: Wean existing callers off stop_machine_run()Rusty Russell
2008-07-24memory hotplug: small fixes to bootmem freeing for memory hotremoveYasunori Goto
- Change some naming * Magic -> types * MIX_INFO -> MIX_SECTION_INFO * Change definition of bootmem type from direct hex value - __free_pages_bootmem() becomes __meminit. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Badari Pulavarty <pbadari@us.ibm.com> Cc: Yinghai Lu <yhlu.kernel@gmail.com> Cc: Johannes Weiner <hannes@saeurebad.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24mm/page_alloc.c: cleanupsAdrian Bunk
This patch contains the following cleanups: - make the following needlessly global variables static: - required_kernelcore - zone_movable_pfn[] - make the following needlessly global functions static: - move_freepages() - move_freepages_block() - setup_pageset() - find_usable_zone_for_movable() - adjust_zone_range_for_zone_movable() - __absent_pages_in_range() - find_min_pfn_for_node() - find_zone_movable_pfns_for_nodes() Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24mm: add alloc_pages_exact() and free_pages_exact()Timur Tabi
alloc_pages_exact() is similar to alloc_pages(), except that it allocates the minimum number of pages to fulfill the request. This is useful if you want to allocate a very large buffer that is slightly larger than an even power-of-two number of pages. In that case, alloc_pages() will waste a lot of memory. I have a video driver that wants to allocate a 5MB buffer. alloc_pages() wiill waste 3MB of physically-contiguous memory. Signed-off-by: Timur Tabi <timur@freescale.com> Cc: Andi Kleen <andi@firstfloor.org> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24mm: export prep_compound_page to mmAndi Kleen
hugetlb will need to get compound pages from bootmem to handle the case of them being greater than or equal to MAX_ORDER. Export the constructor function needed for this. Acked-by: Adam Litke <agl@us.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24mm: drop unneeded pgdat argument from free_area_init_node()Johannes Weiner
free_area_init_node() gets passed in the node id as well as the node descriptor. This is redundant as the function can trivially get the node descriptor itself by means of NODE_DATA() and the node's id. I checked all the users and NODE_DATA() seems to be usable everywhere from where this function is called. Signed-off-by: Johannes Weiner <hannes@saeurebad.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24buddy: clarify comments describing buddy mergeAndy Whitcroft
In __free_one_page(), the comment "Move the buddy up one level" appears attached to the break and by implication when the break is taken we are moving it up one level: if (!page_is_buddy(page, buddy, order)) break; /* Move the buddy up one level. */ In reality the inverse is true, we break out when we can no longer merge this page with its buddy. Looking back into pre-history (into the full git history) it appears that these two lines accidentally got joined as part of another change. Move the comment down where it belongs below the if and clarify its language. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24page allocator: inline some __alloc_pages() wrappersKOSAKI Motohiro
Two zonelist patch series rewrote __page_alloc() largely. Now, it is just a wrapper function. Inlining them will save a function call. [akpm@linux-foundation.org: export __alloc_pages_internal] Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24mm: move bootmem descriptors definition to a single placeJohannes Weiner
There are a lot of places that define either a single bootmem descriptor or an array of them. Use only one central array with MAX_NUMNODES items instead. Signed-off-by: Johannes Weiner <hannes@saeurebad.de> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Richard Henderson <rth@twiddle.net> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Tony Luck <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Kyle McMartin <kyle@parisc-linux.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: David S. Miller <davem@davemloft.net> Cc: Yinghai Lu <yhlu.kernel@gmail.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24mm: print out the zonelists on request for manual verificationMel Gorman
This patch prints out the zonelists during boot for manual verification by the user if the mminit_loglevel is MMINIT_VERIFY or higher. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24mm: make defensive checks around PFN values registered for memory usageMel Gorman
There are a number of different views to how much memory is currently active. There is the arch-independent zone-sizing view, the bootmem allocator and memory models view. Architectures register this information at different times and is not necessarily in sync particularly with respect to some SPARSEMEM limitations. This patch introduces mminit_validate_memmodel_limits() which is able to validate and correct PFN ranges with respect to the memory model. It is only SPARSEMEM that currently validates itself. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24mm: verify the page links and memory modelMel Gorman
Print out information on how the page flags are being used if mminit_loglevel is MMINIT_VERIFY or higher and unconditionally performs sanity checks on the flags regardless of loglevel. When the page flags are updated with section, node and zone information, a check are made to ensure the values can be retrieved correctly. Finally we confirm that pfn_to_page and page_to_pfn are the correct inverse functions. [akpm@linux-foundation.org: fix printk warnings] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24mm: add a basic debugging framework for memory initialisationMel Gorman
Boot initialisation is very complex, with significant numbers of architecture-specific routines, hooks and code ordering. While significant amounts of the initialisation is architecture-independent, it trusts the data received from the architecture layer. This is a mistake, and has resulted in a number of difficult-to-diagnose bugs. This patchset adds some validation and tracing to memory initialisation. It also introduces a few basic defensive measures. The validation code can be explicitly disabled for embedded systems. This patch: Add additional debugging and verification code for memory initialisation. Once enabled, the verification checks are always run and when required additional debugging information may be outputted via a mminit_loglevel= command-line parameter. The verification code is placed in a new file mm/mm_init.c. Ideally other mm initialisation code will be moved here over time. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-15Merge branch 'generic-ipi' into generic-ipi-for-linusIngo Molnar
Conflicts: arch/powerpc/Kconfig arch/s390/kernel/time.c arch/x86/kernel/apic_32.c arch/x86/kernel/cpu/perfctr-watchdog.c arch/x86/kernel/i8259_64.c arch/x86/kernel/ldt.c arch/x86/kernel/nmi_64.c arch/x86/kernel/smpboot.c arch/x86/xen/smp.c include/asm-x86/hw_irq_32.h include/asm-x86/hw_irq_64.h include/asm-x86/mach-default/irq_vectors.h include/asm-x86/mach-voyager/irq_vectors.h include/asm-x86/smp.h kernel/Makefile Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08mm, generic, x86 boot: more tweaks to hex prints of some pfn addressesPaul Jackson
Fix some problems with (and applies on top of) a previous patch: x86 boot: show pfn addresses in hex not decimal in some kernel info printks Primarily change "0x%8lx" format, which displays with a right aligned space filled hex number (spaces between the "0x" prefix and the number), into "%0#10lx" format, which zero fills instead of space fills, and which uses the printf flag '#' to request the "0x" prefix instead of hard coding it. Also replace some other "0x%lx" formats with "%#lx", making use of the '#' printf flag again. Signed-off-by: Paul Jackson <pj@sgi.com> Cc: "Yinghai Lu" <yhlu.kernel@gmail.com> Cc: "Jack Steiner" <steiner@sgi.com> Cc: "Mike Travis" <travis@sgi.com> Cc: "Huang Cc: Ying" <ying.huang@intel.com> Cc: "Andi Kleen" <andi@firstfloor.org> Cc: "Andrew Morton" <akpm@linux-foundation.org> Cc: Paul Jackson <pj@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86 boot: more consistently use type int for node idsPaul Jackson
Everywhere I look, node id's are of type 'int', except in this one case, which has 'unsigned long'. Change this one to 'int' as well. There is nothing special about the way this variable 'nid' is used in this routine to justify using an unusual type here. Signed-off-by: Paul Jackson <pj@sgi.com> Cc: "Yinghai Lu" <yhlu.kernel@gmail.com> Cc: "Jack Steiner" <steiner@sgi.com> Cc: "Mike Travis" <travis@sgi.com> Cc: "Huang Cc: Ying" <ying.huang@intel.com> Cc: "Andi Kleen" <andi@firstfloor.org> Cc: "Andrew Morton" <akpm@linux-foundation.org> Cc: Paul Jackson <pj@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86 boot: show pfn addresses in hex not decimal in some kernel info printksPaul Jackson
Page frame numbers (the portion of physical addresses above the low order page offsets) are displayed in several kernel debug and info prints in decimal, not hex. Decimal addresse are unreadable. Use hex. Signed-off-by: Paul Jackson <pj@sgi.com> Cc: "Yinghai Lu" <yhlu.kernel@gmail.com> Cc: "Jack Steiner" <steiner@sgi.com> Cc: "Mike Travis" <travis@sgi.com> Cc: "Huang Cc: Ying" <ying.huang@intel.com> Cc: "Andi Kleen" <andi@firstfloor.org> Cc: "Andrew Morton" <akpm@linux-foundation.org> Cc: Paul Jackson <pj@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08RFC x86: try to remove arch_get_ram_rangeYinghai Lu
want to remove arch_get_ram_range, and use early_node_map instead. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86, mm: use add_highpages_with_active_regions() for high pages init v2Yinghai Lu
use early_node_map to init high pages, so we can remove page_is_ram() and page_is_reserved_early() in the big loop with add_one_highpage also remove page_is_reserved_early(), it is not needed anymore. v2: fix the build of other platforms Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86: replace shrink_active_range() with remove_active_range()Yinghai Lu
in case we have kva before ramdisk on a node, we still need to use those ranges. v2: reserve_early kva ram area, in case there are holes in highmem, to avoid those area could be treat as free high pages. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08Merge branch 'linus' into tmp.x86.mpparse.newIngo Molnar
2008-07-03Do not overwrite nr_zones on !NUMA when initialising zlcache_ptrMel Gorman
The non-NUMA case of build_zonelist_cache() would initialize the zlcache_ptr for both node_zonelists[] to NULL. Which is problematic, since non-NUMA only has a single node_zonelists[] entry, and trying to zero the non-existent second one just overwrote the nr_zones field instead. As kswapd uses this value to determine what reclaim work is necessary, the result is that kswapd never reclaims. This causes processes to stall frequently in low-memory situations as they always direct reclaim. This patch initialises zlcache_ptr correctly. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Tested-by: Dan Williams <dan.j.williams@intel.com> [ Simplified patch a bit ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-26on_each_cpu(): kill unused 'retry' parameterJens Axboe
It's not even passed on to smp_call_function() anymore, since that was removed. So kill it. Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-06-10mm, x86: shrink_active_range() should check allYinghai Lu
Now we are using register_e820_active_regions() instead of add_active_range() directly. So end_pfn could be different between the value in early_node_map to node_end_pfn. So we need to make shrink_active_range() smarter. shrink_active_range() is a generic MM function in mm/page_alloc.c but it is only used on 32-bit x86. Should we move it back to some file in arch/x86? Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-09mm: Minor clean-up of page flags in mm/page_alloc.cRuss Anderson
Minor source code cleanup of page flags in mm/page_alloc.c. Move the definition of the groups of bits to page-flags.h. The purpose of this clean up is that the next patch will conditionally add a page flag to the groups. Doing that in a header file is cleaner than adding #ifdefs to the C code. Signed-off-by: Russ Anderson <rja@sgi.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-03x86, numa, 32-bit: print out debug info on all kvasYinghai Lu
also fix the print out of node_remap_end_vaddr Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-24memory hotplug: fix early allocation handlingHeiko Carstens
Trying to add memory via add_memory() from within an initcall function results in bootmem alloc of 163840 bytes failed! Kernel panic - not syncing: Out of memory This is caused by zone_wait_table_init() which uses system_state to decide if it should use the bootmem allocator or not. When initcalls are handled the system_state is still SYSTEM_BOOTING but the bootmem allocator doesn't work anymore. So the allocation will fail. To fix this use slab_is_available() instead as indicator like we do it everywhere else. [akpm@linux-foundation.org: coding-style fix] Reviewed-by: Andy Whitcroft <apw@shadowen.org> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24zonelists: handle a node zonelist with no applicable entriesAndy Whitcroft
When booting 2.6.26-rc3 on a multi-node x86_32 numa system we are seeing panics when trying node local allocations: BUG: unable to handle kernel NULL pointer dereference at 0000034c IP: [<c1042507>] get_page_from_freelist+0x4a/0x18e *pdpt = 00000000013a7001 *pde = 0000000000000000 Oops: 0000 [#1] SMP Modules linked in: Pid: 0, comm: swapper Not tainted (2.6.26-rc3-00003-g5abc28d #82) EIP: 0060:[<c1042507>] EFLAGS: 00010282 CPU: 0 EIP is at get_page_from_freelist+0x4a/0x18e EAX: c1371ed8 EBX: 00000000 ECX: 00000000 EDX: 00000000 ESI: f7801180 EDI: 00000000 EBP: 00000000 ESP: c1371ec0 DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0068 Process swapper (pid: 0, ti=c1370000 task=c12f5b40 task.ti=c1370000) Stack: 00000000 00000000 00000000 00000000 000612d0 000412d0 00000000 000412d0 f7801180 f7c0101c f7c01018 c10426e4 f7c01018 00000001 00000044 00000000 00000001 c12f5b40 00000001 00000010 00000000 000412d0 00000286 000412d0 Call Trace: [<c10426e4>] __alloc_pages_internal+0x99/0x378 [<c10429ca>] __alloc_pages+0x7/0x9 [<c105e0e8>] kmem_getpages+0x66/0xef [<c105ec55>] cache_grow+0x8f/0x123 [<c105f117>] ____cache_alloc_node+0xb9/0xe4 [<c105f427>] kmem_cache_alloc_node+0x92/0xd2 [<c122118c>] setup_cpu_cache+0xaf/0x177 [<c105e6ca>] kmem_cache_create+0x2c8/0x353 [<c13853af>] kmem_cache_init+0x1ce/0x3ad [<c13755c5>] start_kernel+0x178/0x1ee This occurs when we are scanning the zonelists looking for a ZONE_NORMAL page. In this system there is only ZONE_DMA and ZONE_NORMAL memory on node 0, all other nodes are mapped above 4GB physical. Here is a dump of the zonelists from this system: zonelists pgdat=c1400000 0: c14006c0:2 f7c006c0:2 f7e006c0:2 c1400360:1 c1400000:0 1: c14006c0:2 c1400360:1 c1400000:0 zonelists pgdat=f7c00000 0: f7c006c0:2 f7e006c0:2 c14006c0:2 c1400360:1 c1400000:0 1: f7c006c0:2 zonelists pgdat=f7e00000 0: f7e006c0:2 c14006c0:2 f7c006c0:2 c1400360:1 c1400000:0 1: f7e006c0:2 When performing a node local allocation we call get_page_from_freelist() looking for a page. It in turn calls first_zones_zonelist() which returns a preferred_zone. Where there are no applicable zones this will be NULL. However we use this unconditionally, leading to this panic. Where there are no applicable zones there is no possibility of a successful allocation, so simply fail the allocation. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24mm: don't drop a partial page in a zone's memory map sizeJohannes Weiner
In a zone's present pages number, account for all pages occupied by the memory map, including a partial. Signed-off-by: Johannes Weiner <hannes@saeurebad.de> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-14memory_hotplug: always initialize pageblock bitmapHeiko Carstens
Trying to online a new memory section that was added via memory hotplug sometimes results in crashes when the new pages are added via __free_page. Reason for that is that the pageblock bitmap isn't initialized and hence contains random stuff. That means that get_pageblock_migratetype() returns also random stuff and therefore list_add(&page->lru, &zone->free_area[order].free_list[migratetype]); in __free_one_page() tries to do a list_add to something that isn't even necessarily a list. This happens since 86051ca5eaf5e560113ec7673462804c54284456 ("mm: fix usemap initialization") which makes sure that the pageblock bitmap gets only initialized for pages present in a zone. Unfortunately for hot-added memory the zones "grow" after the memmap and the pageblock memmap have been initialized. Which means that the new pages have an unitialized bitmap. To solve this the calls to grow_zone_span() and grow_pgdat_span() are moved to __add_zone() just before the initialization happens. The patch also moves the two functions since __add_zone() is the only caller and I didn't want to add a forward declaration. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30infrastructure to debug (dynamic) objectsThomas Gleixner
We can see an ever repeating problem pattern with objects of any kind in the kernel: 1) freeing of active objects 2) reinitialization of active objects Both problems can be hard to debug because the crash happens at a point where we have no chance to decode the root cause anymore. One problem spot are kernel timers, where the detection of the problem often happens in interrupt context and usually causes the machine to panic. While working on a timer related bug report I had to hack specialized code into the timer subsystem to get a reasonable hint for the root cause. This debug hack was fine for temporary use, but far from a mergeable solution due to the intrusiveness into the timer code. The code further lacked the ability to detect and report the root cause instantly and keep the system operational. Keeping the system operational is important to get hold of the debug information without special debugging aids like serial consoles and special knowledge of the bug reporter. The problems described above are not restricted to timers, but timers tend to expose it usually in a full system crash. Other objects are less explosive, but the symptoms caused by such mistakes can be even harder to debug. Instead of creating specialized debugging code for the timer subsystem a generic infrastructure is created which allows developers to verify their code and provides an easy to enable debug facility for users in case of trouble. The debugobjects core code keeps track of operations on static and dynamic objects by inserting them into a hashed list and sanity checking them on object operations and provides additional checks whenever kernel memory is freed. The tracked object operations are: - initializing an object - adding an object to a subsystem list - deleting an object from a subsystem list Each operation is sanity checked before the operation is executed and the subsystem specific code can provide a fixup function which allows to prevent the damage of the operation. When the sanity check triggers a warning message and a stack trace is printed. The list of operations can be extended if the need arises. For now it's limited to the requirements of the first user (timers). The core code enqueues the objects into hash buckets. The hash index is generated from the address of the object to simplify the lookup for the check on kfree/vfree. Each bucket has it's own spinlock to avoid contention on a global lock. The debug code can be compiled in without being active. The runtime overhead is minimal and could be optimized by asm alternatives. A kernel command line option enables the debugging code. Thanks to Ingo Molnar for review, suggestions and cleanup patches. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Greg KH <greg@kroah.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29page allocator: smarter retry of costly-order allocationsNishanth Aravamudan
Because of page order checks in __alloc_pages(), hugepage (and similarly large order) allocations will not retry unless explicitly marked __GFP_REPEAT. However, the current retry logic is nearly an infinite loop (or until reclaim does no progress whatsoever). For these costly allocations, that seems like overkill and could potentially never terminate. Mel observed that allowing current __GFP_REPEAT semantics for hugepage allocations essentially killed the system. I believe this is because we may continue to reclaim small orders of pages all over, but never have enough to satisfy the hugepage allocation request. This is clearly only a problem for large order allocations, of which hugepages are the most obvious (to me). Modify try_to_free_pages() to indicate how many pages were reclaimed. Use that information in __alloc_pages() to eventually fail a large __GFP_REPEAT allocation when we've reclaimed an order of pages equal to or greater than the allocation's order. This relies on lumpy reclaim functioning as advertised. Due to fragmentation, lumpy reclaim may not be able to free up the order needed in one invocation, so multiple iterations may be requred. In other words, the more fragmented memory is, the more retry attempts __GFP_REPEAT will make (particularly for higher order allocations). This changes the semantics of __GFP_REPEAT subtly, but *only* for allocations > PAGE_ALLOC_COSTLY_ORDER. With this patch, for those size allocations, we will try up to some point (at least 1<<order reclaimed pages), rather than forever (which is the case for allocations <= PAGE_ALLOC_COSTLY_ORDER). This change improves the /proc/sys/vm/nr_hugepages interface with a follow-on patch that makes pool allocations use __GFP_REPEAT. Rather than administrators repeatedly echo'ing a particular value into the sysctl, and forcing reclaim into action manually, this change allows for the sysctl to attempt a reasonable effort itself. Similarly, dynamic pool growth should be more successful under load, as lumpy reclaim can try to free up pages, rather than failing right away. Choosing to reclaim only up to the order of the requested allocation strikes a balance between not failing hugepage allocations and returning to the caller when it's unlikely to every succeed. Because of lumpy reclaim, if we have freed the order requested, hopefully it has been in big chunks and those chunks will allow our allocation to succeed. If that isn't the case after freeing up the current order, I don't think it is likely to succeed in the future, although it is possible given a particular fragmentation pattern. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: Andy Whitcroft <apw@shadowen.org> Tested-by: Mel Gorman <mel@csn.ul.ie> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29mm: fix misleading __GFP_REPEAT related commentsNishanth Aravamudan
The definition and use of __GFP_REPEAT, __GFP_NOFAIL and __GFP_NORETRY in the core VM have somewhat differing comments as to their actual semantics. Annoyingly, the flags definition has inline and header comments, which might be interpreted as not being equivalent. Just add references to the header comments in the inline ones so they don't go out of sync in the future. In their use in __alloc_pages() clarify that the current implementation treats low-order allocations and __GFP_REPEAT allocations as distinct cases. To clarify, the flags' semantics are: __GFP_NORETRY means try no harder than one run through __alloc_pages __GFP_REPEAT means __GFP_NOFAIL __GFP_NOFAIL means repeat forever order <= PAGE_ALLOC_COSTLY_ORDER means __GFP_NOFAIL Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29mm: fix usemap initializationKAMEZAWA Hiroyuki
usemap must be initialized only when pfn is within zone. If not, it corrupts memory. And this patch also reduces the number of calls to set_pageblock_migratetype() from (pfn & (pageblock_nr_pages -1) to !(pfn & (pageblock_nr_pages-1) it should be called once per pageblock. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Cc: Hugh Dickins <hugh@veritas.com> Cc: Shi Weihua <shiwh@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm/page_alloc.c: remove hand-coded get_order()Pavel Machek
Remove hand-coded get_order() from page_alloc.c. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28memory hotplug: free memmaps allocated by bootmemYasunori Goto
This patch is to free memmaps which is allocated by bootmem. Freeing usemap is not necessary. The pages of usemap may be necessary for other sections. If removing section is last section on the node, its section is the final user of usemap page. (usemaps are allocated on its section by previous patch.) But it shouldn't be freed too, because the section must be logical offline state which all pages are isolated against page allocater. If it is freed, page alloctor may use it which will be removed physically soon. It will be disaster. So, this patch keeps it as it is. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Badari Pulavarty <pbadari@us.ibm.com> Cc: Yinghai Lu <yhlu.kernel@gmail.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28pageflags: eliminate PG_xxx aliasesChristoph Lameter
Remove aliases of PG_xxx. We can easily drop those now and alias by specifying the PG_xxx flag in the macro that generates the functions. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm/page_alloc.c: fix indentationS.Caglar Onur
zlc_setup(): handle jiffies wraparound (10ed273f5016c582413dfbc468dd084957d847e1) changes tab with spaces Signed-off-by: S.Caglar Onur <caglar@pardus.org.tr> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm: filter based on a nodemask as well as a gfp_maskMel Gorman
The MPOL_BIND policy creates a zonelist that is used for allocations controlled by that mempolicy. As the per-node zonelist is already being filtered based on a zone id, this patch adds a version of __alloc_pages() that takes a nodemask for further filtering. This eliminates the need for MPOL_BIND to create a custom zonelist. A positive benefit of this is that allocations using MPOL_BIND now use the local node's distance-ordered zonelist instead of a custom node-id-ordered zonelist. I.e., pages will be allocated from the closest allowed node with available memory. [Lee.Schermerhorn@hp.com: Mempolicy: update stale documentation and comments] [Lee.Schermerhorn@hp.com: Mempolicy: make dequeue_huge_page_vma() obey MPOL_BIND nodemask] [Lee.Schermerhorn@hp.com: Mempolicy: make dequeue_huge_page_vma() obey MPOL_BIND nodemask rework] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm: have zonelist contains structs with both a zone pointer and zone_idxMel Gorman
Filtering zonelists requires very frequent use of zone_idx(). This is costly as it involves a lookup of another structure and a substraction operation. As the zone_idx is often required, it should be quickly accessible. The node idx could also be stored here if it was found that accessing zone->node is significant which may be the case on workloads where nodemasks are heavily used. This patch introduces a struct zoneref to store a zone pointer and a zone index. The zonelist then consists of an array of these struct zonerefs which are looked up as necessary. Helpers are given for accessing the zone index as well as the node index. [kamezawa.hiroyu@jp.fujitsu.com: Suggested struct zoneref instead of embedding information in pointers] [hugh@veritas.com: mm-have-zonelist: fix memcg ooms] [hugh@veritas.com: just return do_try_to_free_pages] [hugh@veritas.com: do_try_to_free_pages gfp_mask redundant] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Christoph Lameter <clameter@sgi.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Christoph Lameter <clameter@sgi.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm: use two zonelist that are filtered by GFP maskMel Gorman
Currently a node has two sets of zonelists, one for each zone type in the system and a second set for GFP_THISNODE allocations. Based on the zones allowed by a gfp mask, one of these zonelists is selected. All of these zonelists consume memory and occupy cache lines. This patch replaces the multiple zonelists per-node with two zonelists. The first contains all populated zones in the system, ordered by distance, for fallback allocations when the target/preferred node has no free pages. The second contains all populated zones in the node suitable for GFP_THISNODE allocations. An iterator macro is introduced called for_each_zone_zonelist() that interates through each zone allowed by the GFP flags in the selected zonelist. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Christoph Lameter <clameter@sgi.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm: remember what the preferred zone is for zone_statisticsMel Gorman
On NUMA, zone_statistics() is used to record events like numa hit, miss and foreign. It assumes that the first zone in a zonelist is the preferred zone. When multiple zonelists are replaced by one that is filtered, this is no longer the case. This patch records what the preferred zone is rather than assuming the first zone in the zonelist is it. This simplifies the reading of later patches in this set. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Christoph Lameter <clameter@sgi.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm: introduce node_zonelist() for accessing the zonelist for a GFP maskMel Gorman
Introduce a node_zonelist() helper function. It is used to lookup the appropriate zonelist given a node and a GFP mask. The patch on its own is a cleanup but it helps clarify parts of the two-zonelist-per-node patchset. If necessary, it can be merged with the next patch in this set without problems. Reviewed-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Christoph Lameter <clameter@sgi.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm: use zonelists instead of zones when direct reclaiming pagesMel Gorman
The following patches replace multiple zonelists per node with two zonelists that are filtered based on the GFP flags. The patches as a set fix a bug with regard to the use of MPOL_BIND and ZONE_MOVABLE. With this patchset, the MPOL_BIND will apply to the two highest zones when the highest zone is ZONE_MOVABLE. This should be considered as an alternative fix for the MPOL_BIND+ZONE_MOVABLE in 2.6.23 to the previously discussed hack that filters only custom zonelists. The first patch cleans up an inconsistency where direct reclaim uses zonelist->zones where other places use zonelist. The second patch introduces a helper function node_zonelist() for looking up the appropriate zonelist for a GFP mask which simplifies patches later in the set. The third patch defines/remembers the "preferred zone" for numa statistics, as it is no longer always the first zone in a zonelist. The forth patch replaces multiple zonelists with two zonelists that are filtered. The two zonelists are due to the fact that the memoryless patchset introduces a second set of zonelists for __GFP_THISNODE. The fifth patch introduces helper macros for retrieving the zone and node indices of entries in a zonelist. The final patch introduces filtering of the zonelists based on a nodemask. Two zonelists exist per node, one for normal allocations and one for __GFP_THISNODE. Performance results varied depending on the machine configuration. In real workloads the gain/loss will depend on how much the userspace portion of the benchmark benefits from having more cache available due to reduced referencing of zonelists. These are the range of performance losses/gains when running against 2.6.24-rc4-mm1. The set and these machines are a mix of i386, x86_64 and ppc64 both NUMA and non-NUMA. loss to gain Total CPU time on Kernbench: -0.86% to 1.13% Elapsed time on Kernbench: -0.79% to 0.76% page_test from aim9: -4.37% to 0.79% brk_test from aim9: -0.71% to 4.07% fork_test from aim9: -1.84% to 4.60% exec_test from aim9: -0.71% to 1.08% This patch: The allocator deals with zonelists which indicate the order in which zones should be targeted for an allocation. Similarly, direct reclaim of pages iterates over an array of zones. For consistency, this patch converts direct reclaim to use a zonelist. No functionality is changed by this patch. This simplifies zonelist iterators in the next patch. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Christoph Lameter <clameter@sgi.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-19nodemask: use new node_to_cpumask_ptr functionMike Travis
* Use new node_to_cpumask_ptr. This creates a pointer to the cpumask for a given node. This definition is in mm patch: asm-generic-add-node_to_cpumask_ptr-macro.patch * Use new set_cpus_allowed_ptr function. Depends on: [mm-patch]: asm-generic-add-node_to_cpumask_ptr-macro.patch [sched-devel]: sched: add new set_cpus_allowed_ptr function [x86/latest]: x86: add cpus_scnprintf function Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Greg Banks <gnb@melbourne.sgi.com> Cc: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
