path: root/mm/page_alloc.c
2012-06-03Revert "mm: compaction: handle incorrect MIGRATE_UNMOVABLE type pageblocks"Linus Torvalds
This reverts commit 5ceb9ce6fe9462a298bb2cd5c9f1ca6cb80a0199. That commit seems to be the cause of the mm compation list corruption issues that Dave Jones reported. The locking (or rather, absense there-of) is dubious, as is the use of the 'page' variable once it has been found to be outside the pageblock range. So revert it for now, we can re-visit this for 3.6. If we even need to: as Minchan Kim says, "The patch wasn't a bug fix and even test workload was very theoretical". Reported-and-tested-by: Dave Jones <davej@redhat.com> Acked-by: Hugh Dickins <hughd@google.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm: add link from struct lruvec to struct zoneKonstantin Khlebnikov
This is the first stage of struct mem_cgroup_zone removal. Further patches replace struct mem_cgroup_zone with a pointer to struct lruvec. If CONFIG_CGROUP_MEM_RES_CTLR=n lruvec_zone() is just container_of(). Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm/memcg: move reclaim_stat into lruvecHugh Dickins
With mem_cgroup_disabled() now explicit, it becomes clear that the zone_reclaim_stat structure actually belongs in lruvec, per-zone when memcg is disabled but per-memcg per-zone when it's enabled. We can delete mem_cgroup_get_reclaim_stat(), and change update_page_reclaim_stat() to update just the one set of stats, the one which get_scan_count() will actually use. Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Michal Hocko <mhocko@suse.cz> Reviewed-by: Minchan Kim <minchan@kernel.org> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: Glauber Costa <glommer@parallels.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm/page_alloc.c: cleanupsAndrew Morton
- make pageflag_names[] const - remove null termination of pageflag_names[] Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Gavin Shan <shangw@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm: page_alloc: catch out-of-date list of page flag namesJohannes Weiner
String tables with names of enum items are always prone to go out of sync with the enums themselves. Ensure during compile time that the name table of page flags has the same size as the page flags enum. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Gavin Shan <shangw@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm/buddy: dump PG_compound_lock page flagGavin Shan
The array pageflag_names[] does conversion from page flags into their corresponding names so that a meaningful representation of the corresponding page flag can be printed. This mechanism is used while dumping page frames. However, the array missed PG_compound_lock. So the PG_compound_lock page flag would be printed as a digital number instead of a meaningful string. The patch fixes that and prints "compound_lock" for the PG_compound_lock page flag. Signed-off-by: Gavin Shan <shangw@linux.vnet.ibm.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm: compaction: handle incorrect MIGRATE_UNMOVABLE type pageblocksBartlomiej Zolnierkiewicz
When MIGRATE_UNMOVABLE pages are freed from MIGRATE_UNMOVABLE type pageblock (and some MIGRATE_MOVABLE pages are left in it) waiting until an allocation takes ownership of the block may take too long. The type of the pageblock remains unchanged so the pageblock cannot be used as a migration target during compaction. Fix it by: * Adding enum compact_mode (COMPACT_ASYNC_[MOVABLE,UNMOVABLE], and COMPACT_SYNC) and then converting sync field in struct compact_control to use it. * Adding nr_pageblocks_skipped field to struct compact_control and tracking how many destination pageblocks were of MIGRATE_UNMOVABLE type. If COMPACT_ASYNC_MOVABLE mode compaction ran fully in try_to_compact_pages() (COMPACT_COMPLETE) it implies that there is not a suitable page for allocation. In this case then check how if there were enough MIGRATE_UNMOVABLE pageblocks to try a second pass in COMPACT_ASYNC_UNMOVABLE mode. * Scanning the MIGRATE_UNMOVABLE pageblocks (during COMPACT_SYNC and COMPACT_ASYNC_UNMOVABLE compaction modes) and building a count based on finding PageBuddy pages, page_count(page) == 0 or PageLRU pages. If all pages within the MIGRATE_UNMOVABLE pageblock are in one of those three sets change the whole pageblock type to MIGRATE_MOVABLE. My particular test case (on a ARM EXYNOS4 device with 512 MiB, which means 131072 standard 4KiB pages in 'Normal' zone) is to: - allocate 120000 pages for kernel's usage - free every second page (60000 pages) of memory just allocated - allocate and use 60000 pages from user space - free remaining 60000 pages of kernel memory (now we have fragmented memory occupied mostly by user space pages) - try to allocate 100 order-9 (2048 KiB) pages for kernel's usage The results: - with compaction disabled I get 11 successful allocations - with compaction enabled - 14 successful allocations - with this patch I'm able to get all 100 successful allocations NOTE: If we can make kswapd aware of order-0 request during compaction, we can enhance kswapd with changing mode to COMPACT_ASYNC_FULL (COMPACT_ASYNC_MOVABLE + COMPACT_ASYNC_UNMOVABLE). Please see the following thread: http://marc.info/?l=linux-mm&m=133552069417068&w=2 [minchan@kernel.org: minor cleanups] Cc: Mel Gorman <mgorman@suse.de> Cc: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@redhat.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm/page_alloc.c: remove pageblock_default_order()Andrew Morton
This has always been broken: one version takes an unsigned int and the other version takes no arguments. This bug was hidden because one version of set_pageblock_order() was a macro which doesn't evaluate its argument. Simplify it all and remove pageblock_default_order() altogether. Reported-by: rajman mekaco <rajman.mekaco@gmail.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Tejun Heo <tj@kernel.org> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm: print physical addresses consistently with other parts of kernelBjorn Helgaas
Print physical address info in a style consistent with the %pR style used elsewhere in the kernel. For example: -Zone PFN ranges: +Zone ranges: - DMA32 0x00000010 -> 0x00100000 + DMA32 [mem 0x00010000-0xffffffff] - Normal 0x00100000 -> 0x01080000 + Normal [mem 0x100000000-0x107fffffff] Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.linaro.org/people/mszyprowski/linux-dma-mapping Pull CMA and ARM DMA-mapping updates from Marek Szyprowski: "These patches contain two major updates for DMA mapping subsystem (mainly for ARM architecture). First one is Contiguous Memory Allocator (CMA) which makes it possible for device drivers to allocate big contiguous chunks of memory after the system has booted. The main difference from the similar frameworks is the fact that CMA allows to transparently reuse the memory region reserved for the big chunk allocation as a system memory, so no memory is wasted when no big chunk is allocated. Once the alloc request is issued, the framework migrates system pages to create space for the required big chunk of physically contiguous memory. For more information one can refer to nice LWN articles: - 'A reworked contiguous memory allocator': http://lwn.net/Articles/447405/ - 'CMA and ARM': http://lwn.net/Articles/450286/ - 'A deep dive into CMA': http://lwn.net/Articles/486301/ - and the following thread with the patches and links to all previous versions: https://lkml.org/lkml/2012/4/3/204 The main client for this new framework is ARM DMA-mapping subsystem. The second part provides a complete redesign in ARM DMA-mapping subsystem. The core implementation has been changed to use common struct dma_map_ops based infrastructure with the recent updates for new dma attributes merged in v3.4-rc2. This allows to use more than one implementation of dma-mapping calls and change/select them on the struct device basis. The first client of this new infractructure is dmabounce implementation which has been completely cut out of the core, common code. The last patch of this redesign update introduces a new, experimental implementation of dma-mapping calls on top of generic IOMMU framework. This lets ARM sub-platform to transparently use IOMMU for DMA-mapping calls if one provides required IOMMU hardware. For more information please refer to the following thread: http://www.spinics.net/lists/arm-kernel/msg175729.html The last patch merges changes from both updates and provides a resolution for the conflicts which cannot be avoided when patches have been applied on the same files (mainly arch/arm/mm/dma-mapping.c)." Acked by Andrew Morton <akpm@linux-foundation.org>: "Yup, this one please. It's had much work, plenty of review and I think even Russell is happy with it." * 'for-linus' of git://git.linaro.org/people/mszyprowski/linux-dma-mapping: (28 commits) ARM: dma-mapping: use PMD size for section unmap cma: fix migration mode ARM: integrate CMA with DMA-mapping subsystem X86: integrate CMA with DMA-mapping subsystem drivers: add Contiguous Memory Allocator mm: trigger page reclaim in alloc_contig_range() to stabilise watermarks mm: extract reclaim code from __alloc_pages_direct_reclaim() mm: Serialize access to min_free_kbytes mm: page_isolation: MIGRATE_CMA isolation functions added mm: mmzone: MIGRATE_CMA migration type added mm: page_alloc: change fallbacks array handling mm: page_alloc: introduce alloc_contig_range() mm: compaction: export some of the functions mm: compaction: introduce isolate_freepages_range() mm: compaction: introduce map_pages() mm: compaction: introduce isolate_migratepages_range() mm: page_alloc: remove trailing whitespace ARM: dma-mapping: add support for IOMMU mapper ARM: dma-mapping: use alloc, mmap, free from dma_ops ARM: dma-mapping: remove redundant code and do the cleanup ... Conflicts: arch/x86/include/asm/dma-mapping.h
2012-05-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull more networking updates from David Miller: "Ok, everything from here on out will be bug fixes." 1) One final sync of wireless and bluetooth stuff from John Linville. These changes have all been in his tree for more than a week, and therefore have had the necessary -next exposure. John was just away on a trip and didn't have a change to send the pull request until a day or two ago. 2) Put back some defines in user exposed header file areas that were removed during the tokenring purge. From Stephen Hemminger and Paul Gortmaker. 3) A bug fix for UDP hash table allocation got lost in the pile due to one of those "you got it.. no I've got it.." situations. :-) From Tim Bird. 4) SKB coalescing in TCP needs to have stricter checks, otherwise we'll try to coalesce overlapping frags and crash. Fix from Eric Dumazet. 5) RCU routing table lookups can race with free_fib_info(), causing crashes when we deref the device pointers in the route. Fix by releasing the net device in the RCU callback. From Yanmin Zhang. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (293 commits) tcp: take care of overlaps in tcp_try_coalesce() ipv4: fix the rcu race between free_fib_info and ip_route_output_slow mm: add a low limit to alloc_large_system_hash ipx: restore token ring define to include/linux/ipx.h if: restore token ring ARP type to header xen: do not disable netfront in dom0 phy/micrel: Fix ID of KSZ9021 mISDN: Add X-Tensions USB ISDN TA XC-525 gianfar:don't add FCB length to hard_header_len Bluetooth: Report proper error number in disconnection Bluetooth: Create flags for bt_sk() Bluetooth: report the right security level in getsockopt Bluetooth: Lock the L2CAP channel when sending Bluetooth: Restore locking semantics when looking up L2CAP channels Bluetooth: Fix a redundant and problematic incoming MTU check Bluetooth: Add support for Foxconn/Hon Hai AR5BBU22 0489:E03C Bluetooth: Fix EIR data generation for mgmt_device_found Bluetooth: Fix Inquiry with RSSI event mask Bluetooth: improve readability of l2cap_seq_list code Bluetooth: Fix skb length calculation ...
2012-05-24mm: add a low limit to alloc_large_system_hashTim Bird
UDP stack needs a minimum hash size value for proper operation and also uses alloc_large_system_hash() for proper NUMA distribution of its hash tables and automatic sizing depending on available system memory. On some low memory situations, udp_table_init() must ignore the alloc_large_system_hash() result and reallocs a bigger memory area. As we cannot easily free old hash table, we leak it and kmemleak can issue a warning. This patch adds a low limit parameter to alloc_large_system_hash() to solve this problem. We then specify UDP_HTABLE_SIZE_MIN for UDP/UDPLite hash table allocation. Reported-by: Mark Asselstine <mark.asselstine@windriver.com> Reported-by: Tim Bird <tim.bird@am.sony.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-22Merge tag 'driver-core-3.5-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg Kroah-Hartman: "Here's the driver core, and other driver subsystems, pull request for the 3.5-rc1 merge window. Outside of a few minor driver core changes, we ended up with the following different subsystem and core changes as well, due to interdependancies on the driver core: - hyperv driver updates - drivers/memory being created and some drivers moved into it - extcon driver subsystem created out of the old Android staging switch driver code - dynamic debug updates - printk rework, and /dev/kmsg changes All of this has been tested in the linux-next releases for a few weeks with no reported problems. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fix up conflicts in drivers/extcon/extcon-max8997.c where git noticed that a patch to the deleted drivers/misc/max8997-muic.c driver needs to be applied to this one. * tag 'driver-core-3.5-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (90 commits) uio_pdrv_genirq: get irq through platform resource if not set otherwise memory: tegra{20,30}-mc: Remove empty *_remove() printk() - isolate KERN_CONT users from ordinary complete lines sysfs: get rid of some lockdep false positives Drivers: hv: util: Properly handle version negotiations. Drivers: hv: Get rid of an unnecessary check in vmbus_prep_negotiate_resp() memory: tegra{20,30}-mc: Use dev_err_ratelimited() driver core: Add dev_*_ratelimited() family Driver Core: don't oops with unregistered driver in driver_find_device() printk() - restore prefix/timestamp printing for multi-newline strings printk: add stub for prepend_timestamp() ARM: tegra30: Make MC optional in Kconfig ARM: tegra20: Make MC optional in Kconfig ARM: tegra30: MC: Remove unnecessary BUG*() ARM: tegra20: MC: Remove unnecessary BUG*() printk: correctly align __log_buf ARM: tegra30: Add Tegra Memory Controller(MC) driver ARM: tegra20: Add Tegra Memory Controller(MC) driver printk() - restore timestamp printing at console output printk() - do not merge continuation lines of different threads ...
2012-05-21cma: fix migration modeMinchan Kim
__alloc_contig_migrate_range calls migrate_pages with wrong argument for migrate_mode. Fix it. Cc: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Minchan Kim <minchan@kernel.org> Acked-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com>
2012-05-21mm: trigger page reclaim in alloc_contig_range() to stabilise watermarksMarek Szyprowski
alloc_contig_range() performs memory allocation so it also should keep track on keeping the correct level of memory watermarks. This commit adds a call to *_slowpath style reclaim to grab enough pages to make sure that the final collection of contiguous pages from freelists will not starve the system. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> CC: Michal Nazarewicz <mina86@mina86.com> Tested-by: Rob Clark <rob.clark@linaro.org> Tested-by: Ohad Ben-Cohen <ohad@wizery.com> Tested-by: Benjamin Gaignard <benjamin.gaignard@linaro.org> Tested-by: Robert Nelson <robertcnelson@gmail.com> Tested-by: Barry Song <Baohua.Song@csr.com>
2012-05-21mm: extract reclaim code from __alloc_pages_direct_reclaim()Marek Szyprowski
This patch extracts common reclaim code from __alloc_pages_direct_reclaim() function to separate function: __perform_reclaim() which can be later used by alloc_contig_range(). Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Michal Nazarewicz <mina86@mina86.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Tested-by: Rob Clark <rob.clark@linaro.org> Tested-by: Ohad Ben-Cohen <ohad@wizery.com> Tested-by: Benjamin Gaignard <benjamin.gaignard@linaro.org> Tested-by: Robert Nelson <robertcnelson@gmail.com> Tested-by: Barry Song <Baohua.Song@csr.com>
2012-05-21mm: Serialize access to min_free_kbytesMel Gorman
There is a race between the min_free_kbytes sysctl, memory hotplug and transparent hugepage support enablement. Memory hotplug uses a zonelists_mutex to avoid a race when building zonelists. Reuse it to serialise watermark updates. [a.p.zijlstra@chello.nl: Older patch fixed the race with spinlock] Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Tested-by: Barry Song <Baohua.Song@csr.com>
2012-05-21mm: page_isolation: MIGRATE_CMA isolation functions addedMichal Nazarewicz
This commit changes various functions that change pages and pageblocks migrate type between MIGRATE_ISOLATE and MIGRATE_MOVABLE in such a way as to allow to work with MIGRATE_CMA migrate type. Signed-off-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Tested-by: Rob Clark <rob.clark@linaro.org> Tested-by: Ohad Ben-Cohen <ohad@wizery.com> Tested-by: Benjamin Gaignard <benjamin.gaignard@linaro.org> Tested-by: Robert Nelson <robertcnelson@gmail.com> Tested-by: Barry Song <Baohua.Song@csr.com>
2012-05-21mm: mmzone: MIGRATE_CMA migration type addedMichal Nazarewicz
The MIGRATE_CMA migration type has two main characteristics: (i) only movable pages can be allocated from MIGRATE_CMA pageblocks and (ii) page allocator will never change migration type of MIGRATE_CMA pageblocks. This guarantees (to some degree) that page in a MIGRATE_CMA page block can always be migrated somewhere else (unless there's no memory left in the system). It is designed to be used for allocating big chunks (eg. 10MiB) of physically contiguous memory. Once driver requests contiguous memory, pages from MIGRATE_CMA pageblocks may be migrated away to create a contiguous block. To minimise number of migrations, MIGRATE_CMA migration type is the last type tried when page allocator falls back to other migration types when requested. Signed-off-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Tested-by: Rob Clark <rob.clark@linaro.org> Tested-by: Ohad Ben-Cohen <ohad@wizery.com> Tested-by: Benjamin Gaignard <benjamin.gaignard@linaro.org> Tested-by: Robert Nelson <robertcnelson@gmail.com> Tested-by: Barry Song <Baohua.Song@csr.com>
2012-05-21mm: page_alloc: change fallbacks array handlingMichal Nazarewicz
This commit adds a row for MIGRATE_ISOLATE type to the fallbacks array which was missing from it. It also, changes the array traversal logic a little making MIGRATE_RESERVE an end marker. The letter change, removes the implicit MIGRATE_UNMOVABLE from the end of each row which was read by __rmqueue_fallback() function. Signed-off-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Tested-by: Rob Clark <rob.clark@linaro.org> Tested-by: Ohad Ben-Cohen <ohad@wizery.com> Tested-by: Benjamin Gaignard <benjamin.gaignard@linaro.org> Tested-by: Robert Nelson <robertcnelson@gmail.com> Tested-by: Barry Song <Baohua.Song@csr.com>
2012-05-21mm: page_alloc: introduce alloc_contig_range()Michal Nazarewicz
This commit adds the alloc_contig_range() function which tries to allocate given range of pages. It tries to migrate all already allocated pages that fall in the range thus freeing them. Once all pages in the range are freed they are removed from the buddy system thus allocated for the caller to use. Signed-off-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Tested-by: Rob Clark <rob.clark@linaro.org> Tested-by: Ohad Ben-Cohen <ohad@wizery.com> Tested-by: Benjamin Gaignard <benjamin.gaignard@linaro.org> Tested-by: Robert Nelson <robertcnelson@gmail.com> Tested-by: Barry Song <Baohua.Song@csr.com>
2012-05-21mm: page_alloc: remove trailing whitespaceMichal Nazarewicz
2012-05-11mm: raise MemFree by reverting percpu_pagelist_fraction to 0Hugh Dickins
Why is there less MemFree than there used to be? It perturbed a test, so I've just been bisecting linux-next, and now find the offender went upstream yesterday. Commit 93278814d359 "mm: fix division by 0 in percpu_pagelist_fraction()" mistakenly initialized percpu_pagelist_fraction to the sysctl's minimum 8, which leaves 1/8th of memory on percpu lists (on each cpu??); but most of us expect it to be left unset at 0 (and it's not then used as a divisor). MemTotal: 8061476kB 8061476kB 8061476kB 8061476kB 8061476kB 8061476kB Repetitive test with percpu_pagelist_fraction 8: MemFree: 6948420kB 6237172kB 6949696kB 6840692kB 6949048kB 6862984kB Same test with percpu_pagelist_fraction back to 0: MemFree: 7945000kB 7944908kB 7948568kB 7949060kB 7948796kB 7948812kB Signed-off-by: Hugh Dickins <hughd@google.com> [ We really should fix the crazy sysctl interface too, but that's a separate thing - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-10mm: fix division by 0 in percpu_pagelist_fraction()Sasha Levin
percpu_pagelist_fraction_sysctl_handler() has only considered -EINVAL as a possible error from proc_dointvec_minmax(). If any other error is returned, it would proceed to divide by zero since percpu_pagelist_fraction wasn't getting initialized at any point. For example, writing 0 bytes into the proc file would trigger the issue. Signed-off-by: Sasha Levin <levinsasha928@gmail.com> Reviewed-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-08mm: use KERN_CONT in printk() continuation linesKay Sievers
Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Kay Sievers <kay@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-28mm: only IPI CPUs to drain local pages if they existGilad Ben-Yossef
Calculate a cpumask of CPUs with per-cpu pages in any zone and only send an IPI requesting CPUs to drain these pages to the buddy allocator if they actually have pages when asked to flush. This patch saves 85%+ of IPIs asking to drain per-cpu pages in case of severe memory pressure that leads to OOM since in these cases multiple, possibly concurrent, allocation requests end up in the direct reclaim code path so when the per-cpu pages end up reclaimed on first allocation failure for most of the proceeding allocation attempts until the memory pressure is off (possibly via the OOM killer) there are no per-cpu pages on most CPUs (and there can easily be hundreds of them). This also has the side effect of shortening the average latency of direct reclaim by 1 or more order of magnitude since waiting for all the CPUs to ACK the IPI takes a long time. Tested by running "hackbench 400" on a 8 CPU x86 VM and observing the difference between the number of direct reclaim attempts that end up in drain_all_pages() and those were more then 1/2 of the online CPU had any per-cpu page in them, using the vmstat counters introduced in the next patch in the series and using proc/interrupts. In the test sceanrio, this was seen to save around 3600 global IPIs after trigerring an OOM on a concurrent workload: $ cat /proc/vmstat | tail -n 2 pcp_global_drain 0 pcp_global_ipi_saved 0 $ cat /proc/interrupts | grep CAL CAL: 1 2 1 2 2 2 2 2 Function call interrupts $ hackbench 400 [OOM messages snipped] $ cat /proc/vmstat | tail -n 2 pcp_global_drain 3647 pcp_global_ipi_saved 3642 $ cat /proc/interrupts | grep CAL CAL: 6 13 6 3 3 3 1 2 7 Function call interrupts Please note that if the global drain is removed from the direct reclaim path as a patch from Mel Gorman currently suggests this should be replaced with an on_each_cpu_cond invocation. Signed-off-by: Gilad Ben-Yossef <gilad@benyossef.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Christoph Lameter <cl@linux.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Pekka Enberg <penberg@kernel.org> Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Acked-by: Michal Nazarewicz <mina86@mina86.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28mm, coredump: fail allocations when coredumping instead of oom killingDavid Rientjes
The size of coredump files is limited by RLIMIT_CORE, however, allocating large amounts of memory results in three negative consequences: - the coredumping process may be chosen for oom kill and quickly deplete all memory reserves in oom conditions preventing further progress from being made or tasks from exiting, - the coredumping process may cause other processes to be oom killed without fault of their own as the result of a SIGSEGV, for example, in the coredumping process, or - the coredumping process may result in a livelock while writing to the dump file if it needs memory to allocate while other threads are in the exit path waiting on the coredumper to complete. This is fixed by implying __GFP_NORETRY in the page allocator for coredumping processes when reclaim has failed so the allocations fail and the process continues to exit. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mgorman@suse.de> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21page_alloc: remove unused find_zone_movable_pfns_for_nodes() argumentKautuk Consul
find_zone_movable_pfns_for_nodes() does not use its argument. Signed-off-by: Kautuk Consul <consul.kautuk@gmail.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21page_alloc.c: remove add_from_early_node_map()Kautuk Consul
add_from_early_node_map() is unused. Signed-off-by: Kautuk Consul <consul.kautuk@gmail.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21cpuset: mm: reduce large amounts of memory barrier related damage v3Mel Gorman
Commit c0ff7453bb5c ("cpuset,mm: fix no node to alloc memory when changing cpuset's mems") wins a super prize for the largest number of memory barriers entered into fast paths for one commit. [get|put]_mems_allowed is incredibly heavy with pairs of full memory barriers inserted into a number of hot paths. This was detected while investigating at large page allocator slowdown introduced some time after 2.6.32. The largest portion of this overhead was shown by oprofile to be at an mfence introduced by this commit into the page allocator hot path. For extra style points, the commit introduced the use of yield() in an implementation of what looks like a spinning mutex. This patch replaces the full memory barriers on both read and write sides with a sequence counter with just read barriers on the fast path side. This is much cheaper on some architectures, including x86. The main bulk of the patch is the retry logic if the nodemask changes in a manner that can cause a false failure. While updating the nodemask, a check is made to see if a false failure is a risk. If it is, the sequence number gets bumped and parallel allocators will briefly stall while the nodemask update takes place. In a page fault test microbenchmark, oprofile samples from __alloc_pages_nodemask went from 4.53% of all samples to 1.15%. The actual results were 3.3.0-rc3 3.3.0-rc3 rc3-vanilla nobarrier-v2r1 Clients 1 UserTime 0.07 ( 0.00%) 0.08 (-14.19%) Clients 2 UserTime 0.07 ( 0.00%) 0.07 ( 2.72%) Clients 4 UserTime 0.08 ( 0.00%) 0.07 ( 3.29%) Clients 1 SysTime 0.70 ( 0.00%) 0.65 ( 6.65%) Clients 2 SysTime 0.85 ( 0.00%) 0.82 ( 3.65%) Clients 4 SysTime 1.41 ( 0.00%) 1.41 ( 0.32%) Clients 1 WallTime 0.77 ( 0.00%) 0.74 ( 4.19%) Clients 2 WallTime 0.47 ( 0.00%) 0.45 ( 3.73%) Clients 4 WallTime 0.38 ( 0.00%) 0.37 ( 1.58%) Clients 1 Flt/sec/cpu 497620.28 ( 0.00%) 520294.53 ( 4.56%) Clients 2 Flt/sec/cpu 414639.05 ( 0.00%) 429882.01 ( 3.68%) Clients 4 Flt/sec/cpu 257959.16 ( 0.00%) 258761.48 ( 0.31%) Clients 1 Flt/sec 495161.39 ( 0.00%) 517292.87 ( 4.47%) Clients 2 Flt/sec 820325.95 ( 0.00%) 850289.77 ( 3.65%) Clients 4 Flt/sec 1020068.93 ( 0.00%) 1022674.06 ( 0.26%) MMTests Statistics: duration Sys Time Running Test (seconds) 135.68 132.17 User+Sys Time Running Test (seconds) 164.2 160.13 Total Elapsed Time (seconds) 123.46 120.87 The overall improvement is small but the System CPU time is much improved and roughly in correlation to what oprofile reported (these performance figures are without profiling so skew is expected). The actual number of page faults is noticeably improved. For benchmarks like kernel builds, the overall benefit is marginal but the system CPU time is slightly reduced. To test the actual bug the commit fixed I opened two terminals. The first ran within a cpuset and continually ran a small program that faulted 100M of anonymous data. In a second window, the nodemask of the cpuset was continually randomised in a loop. Without the commit, the program would fail every so often (usually within 10 seconds) and obviously with the commit everything worked fine. With this patch applied, it also worked fine so the fix should be functionally equivalent. Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Miao Xie <miaox@cn.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Christoph Lameter <cl@linux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21mm: drain percpu lru add/rotate page-vectors on cpu hot-unplugKonstantin Khlebnikov
This cpu hotplug hook was accidentally removed in commit 00a62ce91e55 ("mm: fix Committed_AS underflow on large NR_CPUS environment") The visible effect of this accident: some pages are borrowed in per-cpu page-vectors. Truncate can deal with it, but these pages cannot be reused while this cpu is offline. So this is like a temporary memory leak. Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Eric B Munson <ebmunson@us.ibm.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21mm, oom: force oom kill on sysrq+fDavid Rientjes
The oom killer chooses not to kill a thread if: - an eligible thread has already been oom killed and has yet to exit, and - an eligible thread is exiting but has yet to free all its memory and is not the thread attempting to currently allocate memory. SysRq+F manually invokes the global oom killer to kill a memory-hogging task. This is normally done as a last resort to free memory when no progress is being made or to test the oom killer itself. For both uses, we always want to kill a thread and never defer. This patch causes SysRq+F to always kill an eligible thread and can be used to force a kill even if another oom killed thread has failed to exit. Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Pekka Enberg <penberg@kernel.org> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21vmscan: only defer compaction for failed order and higherRik van Riel
Currently a failed order-9 (transparent hugepage) compaction can lead to memory compaction being temporarily disabled for a memory zone. Even if we only need compaction for an order 2 allocation, eg. for jumbo frames networking. The fix is relatively straightforward: keep track of the highest order at which compaction is succeeding, and only defer compaction for orders at which compaction is failing. Signed-off-by: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Hillf Danton <dhillf@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-13vfs: fix panic in __d_lookup() with high dentry hashtable countsDimitri Sivanich
When the number of dentry cache hash table entries gets too high (2147483648 entries), as happens by default on a 16TB system, use of a signed integer in the dcache_init() initialization loop prevents the dentry_hashtable from getting initialized, causing a panic in __d_lookup(). Fix this in dcache_init() and similar areas. Signed-off-by: Dimitri Sivanich <sivanich@sgi.com> Acked-by: David S. Miller <davem@davemloft.net> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-23mm: __count_immobile_pages(): make sure the node is onlineMichal Hocko
page_zone() requires an online node otherwise we are accessing NULL NODE_DATA. This is not an issue at the moment because node_zones are located at the structure beginning but this might change in the future so better be careful about that. Signed-off-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-23mm: fix NULL ptr dereference in __count_immobile_pagesMichal Hocko
Fix the following NULL ptr dereference caused by cat /sys/devices/system/memory/memory0/removable Pid: 13979, comm: sed Not tainted 3.0.13-0.5-default #1 IBM BladeCenter LS21 -[7971PAM]-/Server Blade RIP: __count_immobile_pages+0x4/0x100 Process sed (pid: 13979, threadinfo ffff880221c36000, task ffff88022e788480) Call Trace: is_pageblock_removable_nolock+0x34/0x40 is_mem_section_removable+0x74/0xf0 show_mem_removable+0x41/0x70 sysfs_read_file+0xfe/0x1c0 vfs_read+0xc7/0x130 sys_read+0x53/0xa0 system_call_fastpath+0x16/0x1b We are crashing because we are trying to dereference NULL zone which came from pfn=0 (struct page ffffea0000000000). According to the boot log this page is marked reserved: e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved) and early_node_map confirms that: early_node_map[3] active PFN ranges 1: 0x00000010 -> 0x0000009c 1: 0x00000100 -> 0x000bffa3 1: 0x00100000 -> 0x00240000 The problem is that memory_present works in PAGE_SECTION_MASK aligned blocks so the reserved range sneaks into the the section as well. This also means that free_area_init_node will not take care of those reserved pages and they stay uninitialized. When we try to read the removable status we walk through all available sections and hope that the zone is valid for all pages in the section. But this is not true in this case as the zone and nid are not initialized. We have only one node in this particular case and it is marked as node=1 (rather than 0) and that made the problem visible because page_to_nid will return 0 and there are no zones on the node. Let's check that the zone is valid and that the given pfn falls into its boundaries and mark the section not removable. This might cause some false positives, probably, but we do not have any sane way to find out whether the page is reserved by the platform or it is just not used for whatever other reasons. Signed-off-by: Michal Hocko <mhocko@suse.cz> Acked-by: Mel Gorman <mgorman@suse.de> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: David Rientjes <rientjes@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12mm: enum lru_list lruHugh Dickins
Mostly we use "enum lru_list lru": change those few "l"s to "lru"s. Signed-off-by: Hugh Dickins <hughd@google.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12mm: page allocator: do not call direct reclaim for THP allocations while ↵Mel Gorman
compaction is deferred If compaction is deferred, direct reclaim is used to try to free enough pages for the allocation to succeed. For small high-orders, this has a reasonable chance of success. However, if the caller has specified __GFP_NO_KSWAPD to limit the disruption to the system, it makes more sense to fail the allocation rather than stall the caller in direct reclaim. This patch skips direct reclaim if compaction is deferred and the caller specifies __GFP_NO_KSWAPD. Async compaction only considers a subset of pages so it is possible for compaction to be deferred prematurely and not enter direct reclaim even in cases where it should. To compensate for this, this patch also defers compaction only if sync compaction failed. Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: Rik van Riel<riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Dave Jones <davej@redhat.com> Cc: Jan Kara <jack@suse.cz> Cc: Andy Isaacson <adi@hexapodia.org> Cc: Nai Xia <nai.xia@gmail.com> Cc: Johannes Weiner <jweiner@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12page_alloc: break early in check_for_regular_memory()Bob Liu
If there is a zone below ZONE_NORMAL has present_pages, we can set node state to N_NORMAL_MEMORY, no need to loop to end. Signed-off-by: Bob Liu <lliubbo@gmail.com> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12mm: collect LRU list heads into struct lruvecJohannes Weiner
Having a unified structure with a LRU list set for both global zones and per-memcg zones allows to keep that code simple which deals with LRU lists and does not care about the container itself. Once the per-memcg LRU lists directly link struct pages, the isolation function and all other list manipulations are shared between the memcg case and the global LRU case. Signed-off-by: Johannes Weiner <jweiner@redhat.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Reviewed-by: Kirill A. Shutemov <kirill@shutemov.name> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Ying Han <yinghan@google.com> Cc: Greg Thelen <gthelen@google.com> Cc: Michel Lespinasse <walken@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10mm: page_alloc: generalize order handling in __free_pages_bootmem()Johannes Weiner
__free_pages_bootmem() used to special-case higher-order frees to save individual page checking with free_pages_bulk(). Nowadays, both zero order and non-zero order frees use free_pages(), which checks each individual page anyway, and so there is little point in making the distinction anymore. The higher-order loop will work just fine for zero order pages. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10mm: fix off-by-two in __zone_watermark_ok()Michal Hocko
Commit 88f5acf88ae6 ("mm: page allocator: adjust the per-cpu counter threshold when memory is low") changed the form how free_pages is calculated but it forgot that we used to do free_pages - ((1 << order) - 1) so we ended up with off-by-two when calculating free_pages. Reported-by: Wang Sheng-Hui <shhuiw@gmail.com> Signed-off-by: Michal Hocko <mhocko@suse.cz> Acked-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10mm: try to distribute dirty pages fairly across zonesJohannes Weiner
The maximum number of dirty pages that exist in the system at any time is determined by a number of pages considered dirtyable and a user-configured percentage of those, or an absolute number in bytes. This number of dirtyable pages is the sum of memory provided by all the zones in the system minus their lowmem reserves and high watermarks, so that the system can retain a healthy number of free pages without having to reclaim dirty pages. But there is a flaw in that we have a zoned page allocator which does not care about the global state but rather the state of individual memory zones. And right now there is nothing that prevents one zone from filling up with dirty pages while other zones are spared, which frequently leads to situations where kswapd, in order to restore the watermark of free pages, does indeed have to write pages from that zone's LRU list. This can interfere so badly with IO from the flusher threads that major filesystems (btrfs, xfs, ext4) mostly ignore write requests from reclaim already, taking away the VM's only possibility to keep such a zone balanced, aside from hoping the flushers will soon clean pages from that zone. Enter per-zone dirty limits. They are to a zone's dirtyable memory what the global limit is to the global amount of dirtyable memory, and try to make sure that no single zone receives more than its fair share of the globally allowed dirty pages in the first place. As the number of pages considered dirtyable excludes the zones' lowmem reserves and high watermarks, the maximum number of dirty pages in a zone is such that the zone can always be balanced without requiring page cleaning. As this is a placement decision in the page allocator and pages are dirtied only after the allocation, this patch allows allocators to pass __GFP_WRITE when they know in advance that the page will be written to and become dirty soon. The page allocator will then attempt to allocate from the first zone of the zonelist - which on NUMA is determined by the task's NUMA memory policy - that has not exceeded its dirty limit. At first glance, it would appear that the diversion to lower zones can increase pressure on them, but this is not the case. With a full high zone, allocations will be diverted to lower zones eventually, so it is more of a shift in timing of the lower zone allocations. Workloads that previously could fit their dirty pages completely in the higher zone may be forced to allocate from lower zones, but the amount of pages that "spill over" are limited themselves by the lower zones' dirty constraints, and thus unlikely to become a problem. For now, the problem of unfair dirty page distribution remains for NUMA configurations where the zones allowed for allocation are in sum not big enough to trigger the global dirty limits, wake up the flusher threads and remedy the situation. Because of this, an allocation that could not succeed on any of the considered zones is allowed to ignore the dirty limits before going into direct reclaim or even failing the allocation, until a future patch changes the global dirty throttling and flusher thread activation so that they take individual zone states into account. Test results 15M DMA + 3246M DMA32 + 504 Normal = 3765M memory 40% dirty ratio 16G USB thumb drive 10 runs of dd if=/dev/zero of=disk/zeroes bs=32k count=$((10 << 15)) seconds nr_vmscan_write (stddev) min| median| max xfs vanilla: 549.747( 3.492) 0.000| 0.000| 0.000 patched: 550.996( 3.802) 0.000| 0.000| 0.000 fuse-ntfs vanilla: 1183.094(53.178) 54349.000| 59341.000| 65163.000 patched: 558.049(17.914) 0.000| 0.000| 43.000 btrfs vanilla: 573.679(14.015) 156657.000| 460178.000| 606926.000 patched: 563.365(11.368) 0.000| 0.000| 1362.000 ext4 vanilla: 561.197(15.782) 0.000|2725438.000|4143837.000 patched: 568.806(17.496) 0.000| 0.000| 0.000 Signed-off-by: Johannes Weiner <jweiner@redhat.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Michal Hocko <mhocko@suse.cz> Tested-by: Wu Fengguang <fengguang.wu@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Dave Chinner <david@fromorbit.com> Cc: Jan Kara <jack@suse.cz> Cc: Shaohua Li <shaohua.li@intel.com> Cc: Rik van Riel <riel@redhat.com> Cc: Chris Mason <chris.mason@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10mm: exclude reserved pages from dirtyable memoryJohannes Weiner
Per-zone dirty limits try to distribute page cache pages allocated for writing across zones in proportion to the individual zone sizes, to reduce the likelihood of reclaim having to write back individual pages from the LRU lists in order to make progress. This patch: The amount of dirtyable pages should not include the full number of free pages: there is a number of reserved pages that the page allocator and kswapd always try to keep free. The closer (reclaimable pages - dirty pages) is to the number of reserved pages, the more likely it becomes for reclaim to run into dirty pages: +----------+ --- | anon | | +----------+ | | | | | | -- dirty limit new -- flusher new | file | | | | | | | | | -- dirty limit old -- flusher old | | | +----------+ --- reclaim | reserved | +----------+ | kernel | +----------+ This patch introduces a per-zone dirty reserve that takes both the lowmem reserve as well as the high watermark of the zone into account, and a global sum of those per-zone values that is subtracted from the global amount of dirtyable pages. The lowmem reserve is unavailable to page cache allocations and kswapd tries to keep the high watermark free. We don't want to end up in a situation where reclaim has to clean pages in order to balance zones. Not treating reserved pages as dirtyable on a global level is only a conceptual fix. In reality, dirty pages are not distributed equally across zones and reclaim runs into dirty pages on a regular basis. But it is important to get this right before tackling the problem on a per-zone level, where the distance between reclaim and the dirty pages is mostly much smaller in absolute numbers. [akpm@linux-foundation.org: fix highmem build] Signed-off-by: Johannes Weiner <jweiner@redhat.com> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Mel Gorman <mgorman@suse.de> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Dave Chinner <david@fromorbit.com> Cc: Jan Kara <jack@suse.cz> Cc: Shaohua Li <shaohua.li@intel.com> Cc: Chris Mason <chris.mason@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10mm: more intensive memory corruption debuggingStanislaw Gruszka
With CONFIG_DEBUG_PAGEALLOC configured, the CPU will generate an exception on access (read,write) to an unallocated page, which permits us to catch code which corrupts memory. However the kernel is trying to maximise memory usage, hence there are usually few free pages in the system and buggy code usually corrupts some crucial data. This patch changes the buddy allocator to keep more free/protected pages and to interlace free/protected and allocated pages to increase the probability of catching corruption. When the kernel is compiled with CONFIG_DEBUG_PAGEALLOC, debug_guardpage_minorder defines the minimum order used by the page allocator to grant a request. The requested size will be returned with the remaining pages used as guard pages. The default value of debug_guardpage_minorder is zero: no change from current behaviour. [akpm@linux-foundation.org: tweak documentation, s/flg/flag/] Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10mm: avoid livelock on !__GFP_FS allocationsMel Gorman
Colin Cross reported; Under the following conditions, __alloc_pages_slowpath can loop forever: gfp_mask & __GFP_WAIT is true gfp_mask & __GFP_FS is false reclaim and compaction make no progress order <= PAGE_ALLOC_COSTLY_ORDER These conditions happen very often during suspend and resume, when pm_restrict_gfp_mask() effectively converts all GFP_KERNEL allocations into __GFP_WAIT. The oom killer is not run because gfp_mask & __GFP_FS is false, but should_alloc_retry will always return true when order is less than PAGE_ALLOC_COSTLY_ORDER. In his fix, he avoided retrying the allocation if reclaim made no progress and __GFP_FS was not set. The problem is that this would result in GFP_NOIO allocations failing that previously succeeded which would be very unfortunate. The big difference between GFP_NOIO and suspend converting GFP_KERNEL to behave like GFP_NOIO is that normally flushers will be cleaning pages and kswapd reclaims pages allowing GFP_NOIO to succeed after a short delay. The same does not necessarily apply during suspend as the storage device may be suspended. This patch special cases the suspend case to fail the page allocation if reclaim cannot make progress and adds some documentation on how gfp_allowed_mask is currently used. Failing allocations like this may cause suspend to abort but that is better than a livelock. [mgorman@suse.de: Rework fix to be suspend specific] [rientjes@google.com: Move suspended device check to should_alloc_retry] Reported-by: Colin Cross <ccross@android.com> Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: David Rientjes <rientjes@google.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10mm: reduce the amount of work done when updating min_free_kbytesMel Gorman
When min_free_kbytes is updated, some pageblocks are marked MIGRATE_RESERVE. Ordinarily, this work is unnoticable as it happens early in boot but on large machines with 1TB of memory, this has been reported to delay boot times, probably due to the NUMA distances involved. The bulk of the work is due to calling calling pageblock_is_reserved() an unnecessary amount of times and accessing far more struct page metadata than is necessary. This patch significantly reduces the amount of work done by setup_zone_migrate_reserve() improving boot times on 1TB machines. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10mm-tracepoint: rename page-free eventsKonstantin Khlebnikov
Rename mm_page_free_direct into mm_page_free and mm_pagevec_free into mm_page_free_batched Since v2.6.33-5426-gc475dab the kernel triggers mm_page_free_direct for all freed pages, not only for directly freed. So, let's name it properly. For pages freed via page-list we also trigger mm_page_free_batched event. Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10mm: remove unused pagevec_freeKonstantin Khlebnikov
It not exported and now nobody uses it. Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10mm: add free_hot_cold_page_list() helperKonstantin Khlebnikov
This patch adds helper free_hot_cold_page_list() to free list of 0-order pages. It frees pages directly from list without temporary page-vector. It also calls trace_mm_pagevec_free() to simulate pagevec_free() behaviour. bloat-o-meter: add/remove: 1/1 grow/shrink: 1/3 up/down: 267/-295 (-28) function old new delta free_hot_cold_page_list - 264 +264 get_page_from_freelist 2129 2132 +3 __pagevec_free 243 239 -4 split_free_page 380 373 -7 release_pages 606 510 -96 free_page_list 188 - -188 Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
