path: root/mm/oom_kill.c
2006-02-01[PATCH] dump_stack() in oom handlerAndrew Morton
Sometimes it's nice to know who's calling. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] cpuset oom lock fixPaul Jackson
The problem, reported in: http://bugzilla.kernel.org/show_bug.cgi?id=5859 and by various other email messages and lkml posts is that the cpuset hook in the oom (out of memory) code can try to take a cpuset semaphore while holding the tasklist_lock (a spinlock). One must not sleep while holding a spinlock. The fix seems easy enough - move the cpuset semaphore region outside the tasklist_lock region. This required a few lines of mechanism to implement. The oom code where the locking needs to be changed does not have access to the cpuset locks, which are internal to kernel/cpuset.c only. So I provided a couple more cpuset interface routines, available to the rest of the kernel, which simple take and drop the lock needed here (cpusets callback_sem). Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] Optimise oom kill of current taskKirill Korotaev
When oom_killer kills current there's no need to call schedule_timeout_interruptible() since task must die ASAP. Signed-Off-By: Pavel Emelianov <xemul@sw.ru> Signed-Off-By: Kirill Korotaev <dev@openvz.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-10[PATCH] mm: fix-up schedule_timeout() usageNishanth Aravamudan
Use schedule_timeout_{,un}interruptible() instead of set_current_state()/schedule_timeout() to reduce kernel size. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] cpusets: confine oom_killer to mem_exclusive cpusetPaul Jackson
Now the real motivation for this cpuset mem_exclusive patch series seems trivial. This patch keeps a task in or under one mem_exclusive cpuset from provoking an oom kill of a task under a non-overlapping mem_exclusive cpuset. Since only interrupt and GFP_ATOMIC allocations are allowed to escape mem_exclusive containment, there is little to gain from oom killing a task under a non-overlapping mem_exclusive cpuset, as almost all kernel and user memory allocation must come from disjoint memory nodes. This patch enables configuring a system so that a runaway job under one mem_exclusive cpuset cannot cause the killing of a job in another such cpuset that might be using very high compute and memory resources for a prolonged time. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] cpusets: oom_kill tweaksPaul Jackson
This patch series extends the use of the cpuset attribute 'mem_exclusive' to support cpuset configurations that: 1) allow GFP_KERNEL allocations to come from a potentially larger set of memory nodes than GFP_USER allocations, and 2) can constrain the oom killer to tasks running in cpusets in a specified subtree of the cpuset hierarchy. Here's an example usage scenario. For a few hours or more, a large NUMA system at a University is to be divided in two halves, with a bunch of student jobs running in half the system under some form of batch manager, and with a big research project running in the other half. Each of the student jobs is placed in a small cpuset, but should share the classic Unix time share facilities, such as buffered pages of files in /bin and /usr/lib. The big research project wants no interference whatsoever from the student jobs, and has highly tuned, unusual memory and i/o patterns that intend to make full use of all the main memory on the nodes available to it. In this example, we have two big sibling cpusets, one of which is further divided into a more dynamic set of child cpusets. We want kernel memory allocations constrained by the two big cpusets, and user allocations constrained by the smaller child cpusets where present. And we require that the oom killer not operate across the two halves of this system, or else the first time a student job runs amuck, the big research project will likely be first inline to get shot. Tweaking /proc/<pid>/oom_adj is not ideal -- if the big research project really does run amuck allocating memory, it should be shot, not some other task outside the research projects mem_exclusive cpuset. I propose to extend the use of the 'mem_exclusive' flag of cpusets to manage such scenarios. Let memory allocations for user space (GFP_USER) be constrained by a tasks current cpuset, but memory allocations for kernel space (GFP_KERNEL) by constrained by the nearest mem_exclusive ancestor of the current cpuset, even though kernel space allocations will still _prefer_ to remain within the current tasks cpuset, if memory is easily available. Let the oom killer be constrained to consider only tasks that are in overlapping mem_exclusive cpusets (it won't help much to kill a task that normally cannot allocate memory on any of the same nodes as the ones on which the current task can allocate.) The current constraints imposed on setting mem_exclusive are unchanged. A cpuset may only be mem_exclusive if its parent is also mem_exclusive, and a mem_exclusive cpuset may not overlap any of its siblings memory nodes. This patch was presented on linux-mm in early July 2005, though did not generate much feedback at that time. It has been built for a variety of arch's using cross tools, and built, booted and tested for function on SN2 (ia64). There are 4 patches in this set: 1) Some minor cleanup, and some improvements to the code layout of one routine to make subsequent patches cleaner. 2) Add another GFP flag - __GFP_HARDWALL. It marks memory requests for USER space, which are tightly confined by the current tasks cpuset. 3) Now memory requests (such as KERNEL) that not marked HARDWALL can if short on memory, look in the potentially larger pool of memory defined by the nearest mem_exclusive ancestor cpuset of the current tasks cpuset. 4) Finally, modify the oom killer to skip any task whose mem_exclusive cpuset doesn't overlap ours. Patch (1), the one time I looked on an SN2 (ia64) build, actually saved 32 bytes of kernel text space. Patch (2) has no affect on the size of kernel text space (it just adds a preprocessor flag). Patches (3) and (4) added about 600 bytes each of kernel text space, mostly in kernel/cpuset.c, which matters only if CONFIG_CPUSET is enabled. This patch: This patch applies a few comment and code cleanups to mm/oom_kill.c prior to applying a few small patches to improve cpuset management of memory placement. The comment changed in oom_kill.c was seriously misleading. The code layout change in select_bad_process() makes room for adding another condition on which a process can be spared the oom killer (see the subsequent cpuset_nodes_overlap patch for this addition). Also a couple typos and spellos that bugged me, while I was here. This patch should have no material affect. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] mm: quieten OOM killer noiseAnton Blanchard
We now print statistics when invoking the OOM killer, however this information is not rate limited and you can get into situations where the console is continually spammed. For example, when a task is exiting the OOM killer will simply return (waiting for that task to exit and clear up memory). If the VM continually calls back into the OOM killer we get thousands of copies of show_mem() on the console. Use printk_ratelimit() to quieten it. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] print order information when OOM killingMarcelo Tosatti
Dump the current allocation order when OOM killing. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] add OOM debugJanet Morgan
This patch provides more debug info when the system is OOM. It displays memory stats (basically sysrq-m info) from __alloc_pages() when page allocation fails and during OOM kill. Thanks to Dave Jones for coming up with the idea. Signed-off-by: Janet Morgan <janetmor@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] oom-killer disable for iscsi/lvm2/multipath userland critical sectionsAndrea Arcangeli
iscsi/lvm2/multipath needs guaranteed protection from the oom-killer, so make the magical value of -17 in /proc/<pid>/oom_adj defeat the oom-killer altogether. (akpm: we still need to document oom_adj and friends in Documentation/filesystems/proc.txt!) Signed-off-by: Andrea Arcangeli <andrea@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
